3464 connectés
Laquelle pour vous interesse ?
 Page :   1  2  3  4  5  ..  117  118  119  ..  1325  1326  1327  1328  1329  1330
[Topic Unique] ATI Radeon 4800 Series (RV770 inside)
n°6430680
sasuke87
Posté le 14-06-2008 à 20:03:25  profilanswer
god is dead a écrit :
Y a pleins de parades possible. Le r700 n'est pas encore pour maintenant et on parle déjà d'un gt 200 55 nm.  Si Nv ne jouera pas sur le plan des perfs, ce sera sur les prix, avec une gtx 280 @55nm dans les 450 euros, face à une X2 plus chère, scénario plausible.
Bref, Nv ne restera pas les bras croisés dans tous les cas.
ça c'est claire mais ça prouve qu'ils ne sont plus aussi tranquilles qu'à l'époque de la 8800GTX... bref les chose se compliquent tout de même pour eux, sans pour autant que la situation soit catastrophique.
n°6430684
Posté le 14-06-2008 à 20:05:20  answer
RV770 has 40 texture memory units?
The exact specifications of the AMD/ATI RV770 is still, so close to the launch, under speculation. We know for a fact that the overall design has changed somewhat, but also that AMD will reuse the building blocks of the RV670 core. Just more and better organized. We also know that the RV770 is a bit larger than what was previously rumored, more in the area of ~280-300mm2, which should perhaps convince the still lingering skeptics that RV770 indeed has 800 shader processors. After that FXvideocards posted the texture fillrate of Radeon HD 4850 we can calculate that the RV770 probably has 40 texture memory units, rather than 32. From an architectural point of view that does makes a bit more sense.
The texture fillrate is said to be 24.0GT/s and since we know that the core clock is 625MHz we can calculate the amount of TMUs by dividing the fillrate with the core clock and then we get ~38, rounded up to 40. Not proof, but certainly a possibility. There have been talks about a separate domain clock, and 32TMUs clocked at 750MHz does result in 24GT/s, but separate domain clocks hasn't been proved and we consider this nothing but speculation.
http://www.nordichardware.com/news,7865.html
n°6430687
jangkunlu
Posté le 14-06-2008 à 20:06:17  profilanswer
alex et la 8800 ultra c'est mieux que 8800 GTX non?
dcon entre 9800 GTX et 8800 ultra c'est quoi le mieux?
Message édité par jangkunlu le 14-06-2008 à 20:07:19
n°6430689
Cizia
Posté le 14-06-2008 à 20:07:18  profilanswer
elle fais que grimper ou quoi cette archi?. :D
"9800 GTX et 8800 ultra"
+1 ultra.
mais un peu "hs" ici........ :fou:
 :ange:
Message édité par Cizia le 14-06-2008 à 20:08:18
n°6430691
alexreunio​n
Posté le 14-06-2008 à 20:07:35  profilanswer
C'est un peu du réchauffé tout ça et surtout comme d'hab ce ne sont que des rumeurs. Marre de ces sources en carton pate  :o
Mon feedback
n°6430692
sasuke87
Posté le 14-06-2008 à 20:07:53  profilanswer
jangkunlu a écrit :
alex et la 8800 ultra c'est mieux que 9800 GTX non?
la 8800Ultra c'est le must qui se fait en mono-GPU (du moins tant qu'on aura pas de test officiel de la GTX280  :D )
n°6430695
alexreunio​n
Posté le 14-06-2008 à 20:10:18  profilanswer
ça depend en quelle resolution tu joues principalement. Pour résumer si tu ne depasses pas le 1600 x 1200 ou le 1650 x 1080 tu peux envisager une 9800 GTX. Au dela de cette resolution et encore plus si il y a du FSAA et AF la 8800 Ultra est au dessus car elle a plus de RAM et plus de bande passante memoire.
Mon feedback
n°6430704
jangkunlu
Posté le 14-06-2008 à 20:16:26  profilanswer
oki donc en 22" je vais jouer en 1650
et donc la vaut mieux 9800 GTX et donc si c'est la 9800 GTX la question qui se pose c'est : HD4850 ou 9800 GTX justement mdr
j'ai bien fait de repousser mon achat a fin du mois!j'aurai des idées précise sur les tests au moins
Message édité par jangkunlu le 14-06-2008 à 20:16:50
n°6430715
Aarkann
http://www.framasoft.net/
Posté le 14-06-2008 à 20:21:30  profilanswer
bon, Qui mettra en lien les premiers test officiels ???
n°6430717
super_newb​ie_pro
A ta dispoition frère geek :P
Posté le 14-06-2008 à 20:21:52  profilanswer
4850 CF : 2000 GFLOPs
Je connaissais la 4850 et 4870 mais pas la 4850 CF ni la 4870 CF... c'est quoi ces trucs CF ?
~ Camping thématique LA RESSOURCE sur l'autonomie ~
n°6430718
jesaipacki
Posté le 14-06-2008 à 20:22:13  profilanswer
CrossFire.
n°6430721
Posté le 14-06-2008 à 20:24:15  answer
Je joue sur un 22" avec une 8800GT et je n'ai aucun problème de performances. Au pire, je restreint un petit peu les filtres si ça saccade.
On ne devrait pas tarder à avoir des tests de la HD4850 mais d'après ce qu'on a pu voir jusqu'à maintenant (rumeurs), elle serait au même niveau qu'une 9800GTX. Le plus simple pour toi c'est de prendre la moins chère des deux si les performances sont vérifiées.
n°6430722
johan02
Posté le 14-06-2008 à 20:25:06  profilanswer
on commence à avoir quelques infos (photos et premiers tests) de la HD4850 mais rien sur la HD4870. Est-ce que ça veut dire que la dispo de celle-ci risque d'être pas élevée à la sortie ? :/
n°6430725
Posté le 14-06-2008 à 20:26:37  answer
On a des infos sur la 4850 parce qu'elle est dispo déjà dans certains pays alors que la 4870 elle devrait pas arriver avant juillet.
n°6430747
Maxaks
Posté le 14-06-2008 à 20:37:46  profilanswer
Y a eu une news comme quoi la sortie est repoussée? Les seules infos que je trouve disent que la carte sort le 25 juin.
n°6430750
Cizia
Posté le 14-06-2008 à 20:40:04  profilanswer
test ok,mais pas,par n'importe qui.....
n°6430755
Posté le 14-06-2008 à 20:42:03  answer
Je sais plus où j'avais lu ça ou alors c'était pour la version 1Gb. La date du 25 avait été donnée en effet mais preuve que les gens s'en foutent du NDA vu qu'il y en a qui vendent déjà la 4850.
n°6430758
jangkunlu
Posté le 14-06-2008 à 20:43:53  profilanswer
bon sert a rien je l'achete pr la tester pour vous je suis n'importe qui moi^^
non mais j'attends les tests avec impatience aussi!
n°6430760
Cizia
Posté le 14-06-2008 à 20:45:46  profilanswer
je penser a un site de test et non a une personne....... :D
n°6430766
jangkunlu
Posté le 14-06-2008 à 20:49:48  profilanswer
bah sur ton site c'est une personne qui va le faire!!(bon ok j'arrete de chercher la ptite bête :P)
moi j'attend tranquillement sur ce topic les tests viendront a nous tt seul lol
n°6430780
Hyrius
Posté le 14-06-2008 à 20:58:31  profilanswer
http://forum-images.hardware.fr/themes_static/images_forum/1/flagn1.gif
Pas très intéréssantes ces cartes finalement.
n°6430782
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 14-06-2008 à 20:59:26  profilanswer
Wirmish a écrit :
Et la HD 3870, elle est à combien de % derrière la 8800 GT ?
La 8800gt est en moyenne, et avec les filtres, 20 à 30% supérieure, et tu le sais.
Oui, je sais que tu es dans le camp de nVidia, mais je ne savais pas que la 8800 GT était de 20 à 30% plus rapide...
Alors selon toi la 8800 GT est une carte divine et la HD 3870 c'est de la merde... mais pourtant...
ComputerBase: résultats moyens des benchs de 16 jeux, dont 6 en DX10:
1280x1024 sans filtres: ATi Radeon HD 3870 < 10,6% < Nvidia GeForce 8800 GT
1280x1024 4xAA/16xAF: ATi Radeon HD 3870 < 19,3% < Nvidia GeForce 8800 GT
1280x1024 8xAA/16xAF: ATi Radeon HD 3870 > 5,9% > Nvidia GeForce 8800 GT
En 1280x1024 la 8800 GT est en moyenne 8% plus rapide que la HD 3870.
1600x1200 sans filtres: ATi Radeon HD 3870 < 10,9% < Nvidia GeForce 8800 GT
1600x1200 4xAA/16xAF: ATi Radeon HD 3870 < 7,8% < Nvidia GeForce 8800 GT
1600x1200 8xAA/16xAF: ATi Radeon HD 3870 > 16,6% > Nvidia GeForce 8800 GT
En 1600x1200 la 8800 GT est en moyenne 1% plus rapide que la HD 3870.
2560x1600 sans filtres: ATi Radeon HD 3870 < 8,9% < Nvidia GeForce 8800 GT
2560x1600 4xAA/16xAF: ATi Radeon HD 3870 < 8,8% < Nvidia GeForce 8800 GT
2560x1600 8xAA/16xAF: ATi Radeon HD 3870 > 51,6% > Nvidia GeForce 8800 GT
En 2560x1600 la 8800 GT est en moyenne 11% plus lente que la HD 3870.
Moyenne avec seulement les jeux DX10:
Jeux DX10 sans filtres: ATi Radeon HD 3870 < 5,4% < Nvidia GeForce 8800 GT
Jeux DX10 2560x1600: ATi Radeon HD 3870 < 2,7% < Nvidia GeForce 8800 GT
Jeux DX10 4xAA/16xAF: ATi Radeon HD 3870 < 10,6% < Nvidia GeForce 8800 GT
Jeux DX10 2560x1600 4xAA/16xAF: ATi Radeon HD 3870 > 17,8% > Nvidia GeForce 8800 GT
Donc, elle est où ta 8800 GT qui est supposéement de 20 à 30% plus rapide que la HD 3870 ?  :whistle:
n°6430786
Cizia
Posté le 14-06-2008 à 21:01:07  profilanswer
Hyrius: oh de ta part ca m'etonne... :d
je te voyais déjà mettre une perruque rouge a ton clébard. :D
Message édité par Cizia le 14-06-2008 à 21:01:35
n°6430792
marllt2
Posté le 14-06-2008 à 21:03:43  profilanswer
http://www.hardware.fr/medias/photos_news/00/21/IMG0021675.gif
http://www.hardware.fr/medias/photos_news/00/21/IMG0021676.gif
http://www.hardware.fr/medias/photos_news/00/21/IMG0021677.gif
n°6430793
Cizia
Posté le 14-06-2008 à 21:05:49  profilanswer
oui ben les test hfr,desolé mais bon.
exemple la x2....bien sympa mais bon...
sur d'autre test grande différence.
en plus tjr des test en aa*4..on connais la chanson hein?.... :whistle:
Message édité par Cizia le 14-06-2008 à 21:09:15
n°6430796
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 14-06-2008 à 21:09:32  profilanswer
Hyrius a écrit :
http://forum-images.hardware.fr/th [...] flagn1.gif
En effet, 160€ pour les perfs d'une 9800 GTX, et ça c'est seulement avec le bas moyen-de-gamme d'ATi.
La HD 4870 qui représente le haut moyen-de-gamme doublera sa bande passante et aura une fréquence supérieure de 125 MHz.
C'est vraiment pas intéressant...
Et puis ça fait pas tourner Crysis en FULL EXTRA SUPER SETTING EN 2560 x 1600.
Vous conaissez Crysis, le jeu TWIMTBP pour lequel nVidia a offert 4 millions de dollars à CryTek ?
Crysis, Crysis, Crysis, on t'aimmmmeeeeuuuu Crysis !
Vive Crysis, on ne jouent qu'à Crysis, c'est le meilleur jeu du monddddeeeeee Crysis !
Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis ! Crysis !
n°6430799
Cizia
Posté le 14-06-2008 à 21:11:03  profilanswer
on pourrais pensez a du fanatisme pour ati,mais Wirmish a raison sur le coup....
Message édité par Cizia le 14-06-2008 à 21:11:28
n°6430800
jesaipacki
Posté le 14-06-2008 à 21:11:39  profilanswer
Il délire c'est tout  :o
n°6430801
m@rtiou
Posté le 14-06-2008 à 21:11:46  profilanswer
Les premiers test c'est quand? Demain?
Selon différents témoignages convergents, il semblerait que le Père Noël préfère les gosses de riches
n°6430802
god is dea​d
Demain, j'arrête de poster.
Posté le 14-06-2008 à 21:11:49  profilanswer
T'es un peu lourd toi avec tes trolls anti-nv  [:kiki]
Message édité par god is dead le 14-06-2008 à 21:12:04
n°6430803
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 14-06-2008 à 21:12:09  profilanswer
marllt2 a écrit :
C'est graphs représentent une moyenne faite sur combien de jeux ?
Combien en DX9 et combien en DX10 ?
Moi j'ai mis les résultats moyens provenant de 16 jeux... oui 16 jeux... S E I Z E   j e u x ... et toi ta moyenne elle a une marge d'erreur de combien ?
Est-ce que j'ai dit 16 jeux ? Hé bien oui, c'est bien SEIZE jeux !
8 + 8 = ?
En 2560x1600 avec filtres tout à fond: 8xAA et 16xAF la Radeon HD 3870 est en moyenne 2 fois plus rapide que la GeForce 8800 GT.
Je vais me répéter: LA HD3870 EST DEUX FOIS PLUS RAPIDE QUE LA 8800GT LORSQU'ON MET TOUT À FOND !
Message édité par Wirmish le 14-06-2008 à 21:17:48
n°6430804
stalkerfr
Posté le 14-06-2008 à 21:12:59  profilanswer
Je pense qu'il a pas pris ses médocs :o
n°6430809
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 14-06-2008 à 21:16:54  profilanswer
Désolé, j'ai fait une crysis du coeur...
n°6430813
Aarkann
Posté le 14-06-2008 à 21:19:28  profilanswer
pourquoi crysis ne peut être retenu pour comparer les cartes entres elles :
http://tt-hardware.com/modules.php [...] &sid=10948
5000h pour aider, y sont généreux les techniciens nvidia
n°6430816
Cizia
Posté le 14-06-2008 à 21:23:35  profilanswer
eh oui,ces ca quand tu a le coeur sur la mains........... :D
n°6430818
god is dea​d
Posté le 14-06-2008 à 21:24:32  profilanswer
Oué, si tu raisonnes comme ça, on enlève aussi Obli et les jeux à base d'UE3. Au final, il ne reste rien :whistle:
n°6430821
jeanjean15
buy cheap, buy twice
Posté le 14-06-2008 à 21:25:13  profilanswer
En même temps quand on voit le résultat c'est 50000 heures qu'ils auraient du y passer . [:azylum]
mes_feeds
n°6430830
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 14-06-2008 à 21:29:02  profilanswer
C'est vous, bande de pro-nVidia, qui lancez des trolls ridicules.
Vous me sortez des benchs faits sur 3 ou 4 jeux, c'est complètement débile.
Qui te dit que ces 4 jeux ne font pas tous parti du programme TWIMTBP ?
Et en plus ils ne testent que le 4xAA... alors qu'il existe aussi le 2xAA, le 8xAA et même le 16xAA et le 24xAA.
Sortez-moi des résultats basés sur une quizaine de jeux et qui placent la 8800 GT 20% à 30% devant la HD3870, et peut-être qu'à ce moment-la je pourrais vous croire, mais en attendant, vous pouvez mettre vos 20% à 30% de perfs en plus là où vous savez.
Message édité par Wirmish le 14-06-2008 à 21:30:27
n°6430834
Aarkann
Posté le 14-06-2008 à 21:29:52  profilanswer
on peut pas dire çà; le graphisme est chouette, le moteur physique impressionnant.
Par contre, le jeu est pas vraiment accrocheur. J'ai fait la démo, super jolie mais çà m'a pas donné envie d'acheter le jeu .   (çà vaut pas un DOD en réseau)
n°6430836
campi
V8 FTW
Posté le 14-06-2008 à 21:32:05  profilanswer
quoi ils sont pas bien? ça voudrait dire que j'ai pas bien fait d'acheter une 9600GT? :cry:
bon par contre moi j'aime jouer en AA donc cette excuse de tester en AA c'est normal, bien que quand ATI était devant avec les X1900 on avait bien souvent des tests sans AA :whistle:
n°6430838
Cizia
Posté le 14-06-2008 à 21:32:58  profilanswer
idem...
j'ai u le jeu complet...
blinder d'aliasing je trouve et ma fait c***r au bout d'une heure.
campi: non c'est pas ca...
mais les test sont souvent fais (surtout chez hfr) en "aa*4".et les nvidia sont opti "aa*4" donc avantagé sur des screen test.
en aa*2 ou *8 c'est pas la même chanson....enfin,bien moins avantager et donc les score sont plus proche.
Message édité par Cizia le 14-06-2008 à 21:36:20
ATI ou problème d'isolation électrique?[Topic Unique] Gigabyte GA-P31-DS3L
[ATI 1950gt] pas d'image hors mode VGA par défaut RADEON 9600 PRO 256 DDR2 est ce compatible ?
carte AGP - Radeon HD2600XT ou X1950Pro ?[Topic Unique] DFI LANPARTY "DK" : P35 T2RS et X38
[Topic Unique] Timings Mémoire [travail commun][Topic Unique] - Western digital 640 Go et 320Go (plateau(x) de 320Go)
Lire une source video extérieur sur le PC avec ATI control center[Topic Unique] DFI LANParty LT X38-T2R
Plus de sujets relatifs à : [Topic Unique] ATI Radeon 4800 Series (RV770 inside)
