4380 connectés
 Page :   1  2  3  4  5  ..  288  289  290  ..  1004  1005  1006  1007  1008  1009
Graphical open bar (des infos, des intox, aux extraits de TheInq)
n°3171889
syntaxx_er​ror
Posté le 03-05-2004 à 10:09:40  profilanswer
NV40 new shoes outed as GeForce 6800 Ultra Extreme
http://www.the-inquirer.com/?article=15661
OUR INQUIRER STORY here suggests that Nvidia's just released – but not yet shipped to retail - high-end sixth-generation GeForce 6800 Ultra (NV40), has had its clock frequencies raised.
We can now clarify this further and say that all the indications are that these higher-clocked parts will be introduced under the model name 'Nvidia GeForce 6800 Ultra Extreme'.
For any Nvidia board partner to ship a GeForce 6800 Ultra, the GPU clock must be set to at least 400MHz and the memory at 550MHz. These frequencies are as per the NV40 reference samples Nvidia initially shipped to the press during the last few weeks, and upon which all reviews to date have been based.
As we also indicated, the press samples of the 'GeForce 6800 Ultra Extreme' that have just been shipped feature a 450MHz core but with the same 550MHz memory clock (1100MHz G-DDR3).
But if you want any 6800 Ultra you better raid your piggy bank fast, because we've heard that only 2000 of the 10,000 NV40 GPUs produced are expected to qualify at the '6800 Ultra' clock rate of 400MHz.
If that's not, "Limited Edition" enough and you want some of the 6800 Ultra Extreme action that select reviewers are receiving just now, you should be forming a line outside retailers that specialise in only Gainward, and maybe XFX products.
This is because it's been suggested that only 200 or so pieces might make the grade as a '6800 Ultra Extreme' with its 450MHz clock.
Gainward will almost certainly introduce both air and liquid cooled variants of GeForce 6800 Ultra. Two of the models seem likely to be called the Gainward PowerPack! Ultra-2600 TV/DVI and the Gainward CoolFX Ultra-2600 'Golden Sample'.
We suggest that the 450MHz 6800 Ultra Extreme core will form only the starting point for Gainward's overclockers wet-dream, the liquid-cooled CoolFX Ultra-2600 'Golden Sample', and we suggest that 500MHz is Gainward's target for the GPU Core.
If Gainward can mate such a core with GDDR3 that is officially rated to 600MHz, and extract a bit more frequency there too, then as things look, such a product may be the only one based upon Nvidia GeForce 6800 Ultra that could topple ATI's most high-end 16x1 R420 offering
Message édité par syntaxx_error le 03-05-2004 à 10:21:39
n°3171897
rycky
Posté le 03-05-2004 à 10:15:43  profilanswer
C'est sur que la situation n'a plus rien à voir avec l'époque 9700pro/5800ultra ou la carte nvidia souffraient de gros défaut, la, dans tout les cas la 6800u reste une carte fantastique au niveau puissance par rapport à la génération précédente et même si elle se fait dépasser par la X800XT (c'est une hypothése un!) elle reste une carte sans gros point faible contrairement au nv30...
Moi ce qui m'ennuie plus concernant la solution nv c'est l'autre article de the inquirer (bon je sais c'est pas fiable) concernant la production de 6800u qui semble problématique. Enfin l'avenir nous le dira, si en juin il est facile de se procurer à prix correct la 6800u ce sera à n'en pas douter une réussite commerciale surtout si la X800pro est bien vendue à 499$, quid alors du prix de la X800XT?
Message édité par rycky le 03-05-2004 à 10:21:05
n°3171932
Fouge
Posté le 03-05-2004 à 10:32:38  profilanswer
Perdu mon [:drapo]
n°3171933
Posté le 03-05-2004 à 10:33:13  answer
Tout celà s'annonce intéressant.
Au final si Ati et Nvidia n'arrivent pas à se départager sur le plan des performances on risque d'assister à une belle guerre des prix qui nous sera bénéfique.
Pour autant je m'interroge sur ces surrenchères de type : Ati augmente la fréquence de son XT, Nvidia prépare une version Ultra Extrème, sans parler les "optimisations" souvent douteuses chez Nvidia, et tout çà pour gagner quelques FPS supplémentaires sur des cartes qui sont de toute façon limitées par leur bande passante et par la puissance des CPU actuels, et au prix d'une consommation électrique gargantuesque et d'un dégagement de chaleur qui devrait suivre les mêmes proportions.
Perso je ne trouve pas çà très raisonnable.
n°3171935
Posté le 03-05-2004 à 10:34:38  answer
Je pense que la réussite commerciale sera pour la version GT.
Quand au X800pro il ne restera pas bien longtemps à 499$ je suis même prêt à parier que les prix vont vite chutter.
n°3171948
evildeus
Posté le 03-05-2004 à 10:41:53  profilanswer
La 6800 super Ultra semble etre une version limitée pour des intégrateurs haut de gamme donc pas en vente chez les distributeurs du coin...
But if they think they're going to hold onto it, they're smoking something hallucinogenic - Jen-Hsun Huang
n°3171958
latif18
Posté le 03-05-2004 à 10:45:19  profilanswer
En gros , ce sera pour alien-ware
n°3171960
Willyzekid
Posté le 03-05-2004 à 10:46:44  profilanswer
....et pour les reviewers :D
Horizon pas Net, reste à la buvette!!
n°3171967
syntaxx_er​ror
Posté le 03-05-2004 à 10:52:27  profilanswer
Si cette version ultra extreme ça reste une rev.A01, y aura bien un petit rigolo pour nous balancer le bios de la bête... :D
n°3171973
magic-sim
Attention, pougnat radioactif
Posté le 03-05-2004 à 10:56:02  profilanswer
T'façon, ça se modifie un bios, hein :D pas besoin du bios original :D et j'en connais qui vont bien azoter tout ça :D
n°3171975
Schimz
Bouge pas, meurs, ressuscite !
Posté le 03-05-2004 à 10:58:50  profilanswer
mais sinon, je suis du même avis. quand j'ai vu cette 6800 a 2 molexs faire peiner un pékat 3.2 => "bon bah je vais plutôt me prendre une 5900xt"
Message édité par Schimz le 03-05-2004 à 11:00:23
n°3171981
syntaxx_er​ror
Posté le 03-05-2004 à 11:01:33  profilanswer
vi, visibelement Gainward prévoit des versions watercoolées à 500/600 !  :ouch:
n°3171982
Oxygen3
Tears from the moon
Posté le 03-05-2004 à 11:02:15  profilanswer
en gros un P4EE like surtout
bref un truc sans aucun intéret si ce n'est un intéret marketing, ce qui est clairement abuser
la XT PE n'EST PAS la version PCI express
Metro-Pole ▬ Réseau A Suivre...: Annuseries|LeVillage|pErDUSA
n°3171989
Oxygen3
Tears from the moon
Posté le 03-05-2004 à 11:03:53  profilanswer
c'était attendu, reste à savoir si c'est vrai  :D
n°3172015
syntaxx_er​ror
Posté le 03-05-2004 à 11:13:04  profilanswer
ba y a pas mal d'info précises données par the Inq, notamment sur gainward, donc je doute que ce soit faux... :)
De toute façon, comme dit plus haut, on en verra jamais la couleur de cette version Extreme car en nb limité !
Message édité par syntaxx_error le 03-05-2004 à 11:13:36
n°3172019
magic-sim
Posté le 03-05-2004 à 11:14:30  profilanswer
Houlà :D ce sera Gainward Mega Force Testosterone 3543453456354 Ultra Extreme³ Golden Sample HotFuckingMommaBenchmarkingFasterThanAnythingElseAvailableIn10SamplesAndCosting1000Bucks
 [:tilleul]
Bon, c'est sûr que si on peut se le permettre, pourquoi pas, mais sinon.........
Message édité par magic-sim le 03-05-2004 à 11:15:18
n°3172047
syntaxx_er​ror
Posté le 03-05-2004 à 11:25:44  profilanswer
On voit que marc est occupé à bencher le R420 et à pondre son article, y a pas eu de news sur hfr depuis le 29/04 [:tinostar]
Marc > Est-ce que la théorie du "Pas Kif Kif" tient toujours maintenant que tu as fait des tests ?  :D
Message édité par syntaxx_error le 03-05-2004 à 11:28:42
n°3172067
magic-sim
Posté le 03-05-2004 à 11:38:35  profilanswer
Auu moins il est pas venu se plaindre :D
n°3172185
evildeus
Posté le 03-05-2004 à 12:47:46  profilanswer
http://www.gamers-depot.com/  ;)
n°3172191
magic-sim
Posté le 03-05-2004 à 12:50:44  profilanswer
Au moins ils auront mis moins de tmeps que pour avoir  un nombre "suffisant" de 5800 Ultra :)
n°3172231
tridam
Profil : Equipe HardWare.fr
Posté le 03-05-2004 à 13:08:45  profilanswer
Quand vous voyez une rumeur sur des changements de fréquences ou sur l'apparition d'un nouveau dérivé d'un GPU etc, si vous pensez que c'est vrai n'oubliez pas d'avoir une petite pensée pour les testeurs qui n'ont pas le droit ni de manger ni de dormir à cause du boulot causé par ces éventuels changements :o
Message édité par tridam le 03-05-2004 à 13:09:35
n°3172238
chrisleurn
Hardcore Will Never Die !
Posté le 03-05-2004 à 13:12:28  profilanswer
On va te pleindre :o  :o
[:joce]
n°3172239
magic-sim
Posté le 03-05-2004 à 13:12:38  profilanswer
Quoi, vous êtes pas sous perfusion ?  [:hakan_fr]
n°3172241
evildeus
Posté le 03-05-2004 à 13:13:31  profilanswer
He ho, à chacun son boulot hein  :whistle:  :hello:
PS: courage  :jap:
n°3172250
syntaxx_er​ror
Posté le 03-05-2004 à 13:19:00  profilanswer
Je prends ça pour des aveux  :D ...Donc les changements de fréquence sont bien une réalité  :)
n°3172256
Oxygen3
Tears from the moon
Posté le 03-05-2004 à 13:21:08  profilanswer
je vois surtout que ca va etre des cartes invendables et invendues mais qui seront testées quand même  :pfff:
n°3172263
evildeus
Posté le 03-05-2004 à 13:22:57  profilanswer
A priori non, elle feront parti de PC genre Alienware
n°3172272
syntaxx_er​ror
Posté le 03-05-2004 à 13:28:00  profilanswer
niveau prix, oui c'est clair ça sera pas les cartes graphiques du peuple mais de l'élite ! [:meganne]...C'est plus une question d'image et donc de marketing qu'autre chose...C'est la vitrine technologique !
n°3172273
syntaxx_er​ror
Posté le 03-05-2004 à 13:28:37  profilanswer
faut-il encore avoir envie et besoin d'un pc alienware...:/
n°3172277
@chewie
Posté le 03-05-2004 à 13:30:43  profilanswer
mais pour faire "aillepeu" voyons :o
n°3172282
syntaxx_er​ror
Posté le 03-05-2004 à 13:33:25  profilanswer
[:mlc], hype ? Alienware ça fait jacky, pas hype... :o  :D
Message édité par syntaxx_error le 03-05-2004 à 13:33:38
n°3172284
Gonishi
Posté le 03-05-2004 à 13:33:51  profilanswer
rycky a écrit :
47fps a FarCry en 1280*1024 aa4x & aniso8x c'est sympa qd même surtout que la 6800u dans le test de marc plafonne à 37fps. Bon le Fx51 est > au P4 3.2 donc je ne sais pas dans quelle proportion cela avantage la X800XT mais si c'est vrai ces chiffres sont impressionants je trouvent.
avec le path des fx en plus  :o
n°3172290
rycky
Posté le 03-05-2004 à 13:37:55  profilanswer
Oui c'est vrai mais qu'apporte t'il réellemeent en perfs au nv40 ce path nv3x? Evildeus a linké peu après l'annonce de nouveaux forceware corrigeant un pb de Z-culling sous FarCry et qui boosterait (conditionnel  ;) ) de 20% les perfs de la 6800u. En rajoutant à ceci à un athlon Fx51 on doit plus être loin des 47fps, quid de la qualité par contre [:spamafote]
Message édité par rycky le 03-05-2004 à 13:39:36
n°3172295
tridam
Posté le 03-05-2004 à 13:39:43  profilanswer
Avec le path R300 la 6800 ne perd que quelques miettes niveau performances et tous les petits bugs de qualité disparaissent.
n°3172297
rycky
Posté le 03-05-2004 à 13:41:12  profilanswer
:??: Visiblement ce n'est pas ce qu'en dit Tridam...
Edit: Trop tard j'avais vu Magic  :D  ;)
Message édité par rycky le 03-05-2004 à 13:41:42
n°3172304
magic-sim
Posté le 03-05-2004 à 13:43:18  profilanswer
Me basais sur des chiffres deje sais plus quel site, mais bon, il était péas spécialement fiable non plus :D
n°3172305
Gonishi
Posté le 03-05-2004 à 13:43:52  profilanswer
une dizaine de fps de plus qu'une 9800XT si je me souviens bien  [:figti]
n°3172313
Gonishi
Posté le 03-05-2004 à 13:46:39  profilanswer
tiens là ils disent (sur une news du 30/04) que ce serait 499$ pour la XT et 299$ pour la pro
Message édité par Gonishi le 03-05-2004 à 13:58:30
n°3172319
evildeus
Posté le 03-05-2004 à 13:50:01  profilanswer
C'est pas trop ce que l'on avait vu, enfin, merci de rectifier :)
n°3172321
Gonishi
Posté le 03-05-2004 à 13:50:45  profilanswer
de toute façon tant qu'on a pas le patch 1.2, vaut mieux pas se prononcer.
n°3172338
magic-sim
Posté le 03-05-2004 à 13:59:48  profilanswer
Fa fé fur et fertain
[Demande infos] Top AchatComment imprimer les infos du bios ?
Quel carte Open Gl la mieux adapte a 3dsMAXBesion d'infos sur les Graveur de DVD chui perdu
couldn't load open glNEC ND-1300: cherche infos
Mise a jour bios KT7A, prob direct x et open gl geforce 2 pro!!Salut je voudrait des infos sur l'instalation d'un processeur
Rech infos sur le nouveau graveur de DVD liteon multiformat !!!![INFOS a la con] si vous avez des PB avec votre ABIT NF7-S REV2.0
Plus de sujets relatifs à : Graphical open bar (des infos, des intox, aux extraits de TheInq)
