3185 connectés
 Page :   1  2  3  4  5  ..  705  706  707  ..  713  714  715  716  717  718
Topik Officiel des drivers vidéo nVidia
n°11470808
cyberfred
Posté le 10-03-2026 à 15:12:59  profilanswer
j'avoue que je n'avais pas mesuré avec les 595.71, juste constaté comme beaucoup la perte de 100-150 Mhz en fréquence max du gpu !
Fréquence max que j'ai retrouvé avec les hotfix 595.76 :jap:
n°11470831
ravenloft
Meilleur jeu du 20ème siècle
Posté le 10-03-2026 à 16:59:03  profilanswer
https://www.reddit.com/r/nvidia/com [...] iscussion/
Nouveau driver
New feature and fixes in driver 595.79:
Game Ready
This new Game Ready Driver provides the best gaming experience for the latest new games supporting DLSS 4 technology including Crimson Desert and DEATH STRANDING 2: ON THE BEACH.
Applications
The March NVIDIA Studio Driver provides optimal support for the latest new creative applications and updates including Topaz NeuroStream, Lightricks LTX-2.3, Windows ML support for VoiceMod, and the latest updates for FLUX.2 Klein 9B and ComfyUI.
Fixed Gaming Bugs
    FIXED Crimson Desert: Game crashes when launched on R595 drivers [5861012]
    FIXED Resident Evil Requiem: White glowing light/dots may appear in game when Subsurface Scattering is enabled [5915673]
    FIXED Star Citizen: Game client crashes when launched [5935027]
Fixed General Bugs
    FIXED When the graphics card is overclocked, GPU voltage may become capped, preventing it from boosting to expected levels [5934973]
    FIXED Intermittent application crash or driver timeout may be observed when playing multikey DRM content in a browser on HDCP 1.x monitors [5934450]
Open Issues
Includes additional open issues from GeForce Forums
    Enshrouded: Missing terrain in some areas [5955501]
    Arknights: Endfield: stutter may be observed in some gameplay [5950402]
Message édité par ravenloft le 10-03-2026 à 16:59:27
Ravenloft
n°11470878
cyberfred
Posté le 10-03-2026 à 22:01:04  profilanswer
bon je vais quand même  pas me précipiter dessus cette fois ci :D, n'ayant aucun souci avec les 595.76,  j'attendrai les retours ! (Death Stranding 2 et Crimson desert j'y jouerai plus tard dans l'année)
n°11470904
Alogart
Posté le 11-03-2026 à 10:15:23  profilanswer
de toute façon, 595.76=595.79...
y a que le statut whql qui change :jap:
n°11470908
cyberfred
Posté le 11-03-2026 à 10:57:34  profilanswer
merci pour ton retour, je pensais qu'il y avait autre chose
bien noté pour le statut whql :jap:
n°11472389
Dirty Wing​s
Posté le 24-03-2026 à 15:52:43  profilanswer
595.97 de sortie !!!
https://www.nvidia.com/fr-fr/drivers/results/
Halo Infinite: Texture corruption may occur on R595 drivers
HITMAN World of Assassination: Game stability issues when NVIDIA Smooth Motion is enabled
Game stability issues after enabling DLSS FG when Instant Replay is enabled
Message édité par Dirty Wings le 25-03-2026 à 16:24:09
n°11472533
ravenloft
Posté le 25-03-2026 à 18:01:52  profilanswer
GeForce Hotfix Display Driver version 596.02
Discussion
P.S. It's literally a fix for 1 game. If you do not play this game, you do not need to install this Hotfix
Article: https://nvidia.custhelp.com/app/ans [...] /kw/596.02
Download Link: https://international-gfe.download. [...] dch.hf.exe
Reminders:
    Hotfix driver will not be available in NVIDIA App and needs to be downloaded from the link above.
    After installing the Hotfix driver, NVIDIA App will show some old driver date. This is normal as Hotfix driver does not exist in NVIDIA App database and it reverted to an old default changelog and dates.
    If you do not care about the fixes listed below, this Hotfix driver is no different vs WHQL 595.97 Driver.
    These fixes will be incorporated into the next WHQL driver release
NVIDIA Driver forum thread is here: Link Here
Submit driver feedback directly to NVIDIA: Link Here
From the Article:
GeForce Hotfix Display Driver version 596.02 is based on our latest Game Ready Driver 595.97.
This hotfix addresses the following:
    Arknights: Endfield: Stutter may be observed in during gameplay [5950402]
Message édité par ravenloft le 25-03-2026 à 18:02:16
Ravenloft
n°11473514
Space
Profil: Maux des rateurs
Posté le 05-04-2026 à 16:53:15  profilanswer
Hello :hello:
J'ai un écran avec les refresh rate suivant au niveau des drivers nvidia 240hz 180hz 144hz 120hz et 60hz.
Je voudrais rajouter un mode 100hz sans passer par le mode de résolutions personnalisées des drivers Nvidia.
J'ai installé Custom Resolution Utility.
J'ai rajouté un mode 100hz mais truc que je pige pas c'est qu'au niveau des drivers Nvidia ce mode 100 hz s'est bien rajouté dans quelques résos comme le 1920x1440 , 1920x1200 et 1600x1200 mais n'est pas présent sur les toutes autre résos.
Il y a des habitués de CRU parmi vous, vous voyez la manip à faire pour l'avoir sur toutes les résos :??:
https://i.postimg.cc/ZqcKqrfB/12.png
https://i.postimg.cc/MTgTkzPN/11.png
Message édité par Space le 05-04-2026 à 16:54:39
n°11473517
petit-tigr​e
miaou
Posté le 05-04-2026 à 18:05:21  profilanswer
Si ça ne se fait pas, c'est que pour une raison ou une autre, ton écran ne le supporte pas.
mIaOuUuUuUuUuUu
n°11473527
Space
Posté le 05-04-2026 à 19:14:58  profilanswer
Il le supporte vu que je peux mettre en 100 hz quelque soit la réso en passant par les resolutions personnalisée des drivers Nvidia.
Je pense que j'utilise pas la bonne manip avec CRU...
n°11473849
DiB91
Bwaaaaaaah
Posté le 10-04-2026 à 11:33:01  profilanswer
Hmm, pardonnez ma question un poil HS et probablement naïve, mais où est-ce qu'on commande les cartes graphiques "Founders Edition" de nVidia ? :??:
Sur leur site officiel, ils ne sont même plus référencés comme constructeur :??:
https://rehost.diberie.com/Picture/Get/f/504927
Rehost | Collect | Link
n°11473852
Space
Posté le 10-04-2026 à 12:09:43  profilanswer
ils sont certainement en rupture sur les FE.
Si tu tiens au FE (perso je les éviterais sur les 5000), tu en trouveras certainement sur Amazon mais cela sera des vendeurs tiers.
Personne ne voit la manip pour CRU pour ma question ci-dessus ? :o
n°11473853
DiB91
Bwaaaaaaah
Posté le 10-04-2026 à 12:17:27  profilanswer
Merci Space.
C'est pas pressé, plutôt un caprice à vrai dire...
Je repasserai quand il y aura eu stock.
n°11473939
MagnumFr
Posté le 11-04-2026 à 15:11:27  profilanswer
NVIDIA App 11.0.7 disponible :
- Disponibilité de la génération dynamique multi-images (DLSS 4.5)
Vous pouvez désormais profiter de la fonctionnalité de génération dynamique d'images avec le DLSS 4.5 sur les GPU GeForce RTX série 50. Sélectionnez le mode "Dynamique" pour ajuster intelligemment le nombre d'images générées en cours de gameplay selon une fréquence d'images cible, de manière à équilibrer la fréquence d'images, la qualité visuelle et la réactivité.
Les nouveaux modes de génération multi-images 5X et 6X du DLSS 4.5 disponibles sur les GPU GeForce RTX série 50 permettent d'augmenter les fréquences d'images en résolution 4K dans les titres qui prennent en charge le path tracing. Associés à NVIDIA Reflex, ces modes contribuent à générer des images supplémentaires avec un impact minimal sur la réactivité.
La mise à jour du modèle DLSS 4.5 de génération d'images pour les GPU GeForce RTX série 50 et GeForce RTX série 40 améliore les interfaces utilisateur en jeu en intégrant des données supplémentaires disponibles pour certains jeux, ce qui améliore la qualité visuelle et la clarté des éléments statiques de l'interface utilisateur.
Pour bénéficier d'une qualité d'image optimale et de performances de pointe lorsque vous utilisez ShadowPlay, vous devez disposer du pilote GeForce Game Ready le plus récent. o Pour profiter des fonctionnalités DLSS, allez dans Graphismes > Paramètres du programme > Paramètres de pilote > Forcer le DLSS - Mode de génération d'images.
- Compilation automatique des shaders (beta)
Permet de reconstruire les shaders DirectX 12 lorsque votre système est inactif, réduisant ainsi la fréquence de compilation de l'environnement d'exécution de vos jeux après la mise à jour des pilotes.
- Mises à jour du Panneau de configuration
Ajout d'une option de résolution personnalisée dans Système > Affichage > Propriétés d'affichage.
DMFG et shaders auto :miam:
Topic Achats & Ventes – Topic inventaire matériel
n°11473960
DiB91
Bwaaaaaaah
Posté le 11-04-2026 à 17:48:07  profilanswer
Et toujours ce beau doigt d'honneur aux possesseurs de Turing et Ampere :/
n°11473961
havoc_28
Posté le 11-04-2026 à 17:50:30  profilanswer
Semi, le FG/MFG reste exclu aux RTX 4000/5000 respectivement, mais la composante super résolution et le RayReconstruction dans leurs dernières versions est toujours utilisable sur Turing / Ampère. Mais bon ça c'est depuis l'introduction même du FG, ça n'a pas changé depuis et ça ne risque pas.
Message édité par havoc_28 le 11-04-2026 à 17:52:00
n°11473963
Alogart
Posté le 11-04-2026 à 17:52:37  profilanswer
havoc_28 a écrit :
Semi, le FG/MFG reste exclu aux RTX 4000/5000 respectivement, mais la composante super résolution et le RayReconstruction dans leurs dernières versions est toujours utilisable sur Turing / Ampère. Mais bon ça c'est depuis l'introduction même du FG, ça n'a pas changé depuis :o.
Ouai enfin, le ray construction doit bien piquer sur turing ^^. Je suspecte un sous-dimensionnement hardware dédié :jap:
Message édité par Alogart le 11-04-2026 à 17:54:14
n°11473964
havoc_28
Posté le 11-04-2026 à 17:55:12  profilanswer
Turing le RT ça pique tout court si le jeu est minimum lourd à ce niveau, y a pas de miracle pour des cartes qui ont quasiment 8 ans.
Y a pas de miracle non, après Nvidia laisse le choix à l'utilisateur du moins pour ce qui est du Super Resolution et du RayReconstruction. Pour le Super Resolution, si c'est trop lourd on peut toujours repasser sur le preset J/K de Transformer (introduit avec le DLSS 4)  ou revenir aux dernières moutures de l'ancien modèle CNN E/F.
Message édité par havoc_28 le 11-04-2026 à 18:00:05
n°11473966
Alogart
Posté le 11-04-2026 à 17:58:39  profilanswer
Oui effectivement ^^. Mais je crois techniquement parlant que le ray reconstruction, c'est le denoiser dlss, et donc pas les mêmes puces que le rt :jap:
Message édité par Alogart le 11-04-2026 à 18:01:52
n°11473969
havoc_28
Posté le 11-04-2026 à 18:02:02  profilanswer
Alogart a écrit :
Oui effectivement ^^. Mais je crois techniquement parlant que le ray construction, c'est le denoiser dlss, et donc pas les mêmes puces que le rt :jap:
C'est les Tensore Core qui accélèrent l'atténuation du bruit oui.
n°11474746
petit-tigr​e
miaou
Posté le 16-04-2026 à 17:09:38  profilanswer
596.21
https://www.nvidia.com/fr-fr/geforc [...] ls/267183/
GRD uniquement.
Game Ready
    PRAGMATA
    NTE (Neverness to Everness)
    Windrose
Project G-Assist
    Enhanced Recommendations and Controls
Fixed
Known Issues
    [God of War: Ragnarok]: Certain textures may intermittently flash white during gameplay. [5856704]
mIaOuUuUuUuUuUu
n°11475975
ravenloft
Posté le 28-04-2026 à 16:41:21  profilanswer
New feature and fixes in driver 596.36:
Game Ready
This new Game Ready Driver provides the best gaming experience for the latest new games supporting DLSS 4.5 technology including Conan Exiles Enhanced.
Applications
The April NVIDIA Studio Driver provides optimal support for the latest new creative applications and updates including Adobe Premiere Pro, DaVinci Resolve 21, Wondershare Filmora, Maxon Redshift 2026.4, Lightricks LTX Desktop, and Reincubate Camo. In addition, this NVIDIA Studio Driver offers support for the new GeForce RTX 5070 Laptop GPU (12GB).
Gaming Technology
Adds support for the GeForce RTX 5070 Laptop GPU (12GB)
Fixed Gaming Bugs
    FIXED God of War: Ragnarok: Certain textures may intermittently flash white during gameplay. [5856704]
    FIXED Assassins Creed Shadows: Flickering on character model clothing [5987951]
    FIXED The Crew Motorfest: Grass and vegetation flickering [5950261]
Fixed General Bugs
    FIXED Blocky artifacts when playing back H.264 content with DXVA 2.0 [6058551]
    FIXED Blender 5.0.1 EEVEE: Non-shader nodes connected to the material output rendered as black (zero value) [5965763]
Ravenloft
n°11477371
ravenloft
Posté le 12-05-2026 à 18:09:00  profilanswer
New feature and fixes in driver 596.49:
Game Ready
This new Game Ready Driver provides the best gaming experience for the latest new games supporting DLSS and RTX technologies including Forza Horizon 6, Directive 8020, and Subnautica 2.
Fixed Gaming Bugs
    FIXED Enhanced smoothness when DLSS Frame Generation is used with V-SYNC. [5999586]
Fixed General Bugs
    FIXED Foundry Mari 7.0v2 viewport displays flickering [6102981]
Ravenloft
n°11478068
Umi
Posté le 21-05-2026 à 16:43:45  profilanswer
Mettez à jour vos pilotes NVIDIA maintenant, votre sécurité est en jeu !
NVIDIA a publié un bulletin de sécurité majeur concernant ses pilotes graphiques pour Windows et Linux, révélant une série de vulnérabilités critiques. La société recommande une mise à jour immédiate. Les utilisateurs équipés des versions les plus récentes, comme la 596.36 ou supérieure sur Windows, sont déjà protégés contre ces failles potentiellement dévastatrices.
Linux est particulièrement touché:
https://www.gamingonlinux.com/2026/ [...] -may-2026/
https://nvidia.custhelp.com/app/ans [...] /a_id/5821
n°11478075
ravenloft
Posté le 21-05-2026 à 17:18:10  profilanswer
C'est corrigé depuis 1 mois dans le driver sortit il y a un mois
Ravenloft
n°11478092
Umi
Posté le 21-05-2026 à 20:00:16  profilanswer
Depuis les 596.36 oui, mais certains sont peut-être encore sur une ancienne version, pour telle ou telle raison, tout le monde ne saute pas immédiatement sur les derniers pilotes, surtout quand la carte commence à dater, le dernier pilote est rarement le meilleur.
n°11478100
ravenloft
Posté le 21-05-2026 à 20:43:46  profilanswer
Oui mais sur les corrections de failles, c'est bien de mettre à jour assez souvent car des failles de cette nature, nvidia en corrige souvent.
Ravenloft
n°11478125
petit-tigr​e
miaou
Posté le 22-05-2026 à 07:51:26  profilanswer
Probabilité que tu sois attaqué via cette faille: 0.000001%
Donc bon les titres à sensations comme ça... On mettra à jour en temps voulu.
mIaOuUuUuUuUuUu
n°11478531
cedric39
Posté le 26-05-2026 à 15:37:07  profilanswer
Nouveau driver : 610.47               !
https://www.nvidia.com/fr-fr/drivers/details/271575/
SUPPRESSION du panneau de configuration Nvidia
Remarques sur le panneau de configuration NVIDIA - Extrait du forum GeForce
    Remarque : Avec l’introduction de notre dernière mise à jour de l’application NVIDIA, toutes les fonctionnalités du panneau de configuration NVIDIA activement prises en charge pour les utilisateurs de GeForce ont été modernisées et transférées vers le nouveau client.
    Après 20 ans de bons et loyaux services, le panneau de configuration NVIDIA classique est officiellement abandonné pour les pilotes Game Ready et Studio. Pour les utilisateurs de NVIDIA RTX PRO, le panneau de configuration NVIDIA restera disponible jusqu'à ce que les fonctionnalités professionnelles soient intégrées à l'application NVIDIA.
    Les installations existantes du panneau de configuration NVIDIA resteront sur les systèmes des utilisateurs, sauf s'ils effectuent une installation propre, et les utilisateurs qui ont toujours besoin du panneau de configuration NVIDIA peuvent continuer à le télécharger à partir du Microsoft Store, mais nous n'ajouterons pas de fonctionnalités, de correctifs ou d'autres modifications .
Nouvelles fonctionnalités et correctifs du pilote 610.47 :
Ce nouveau pilote Game Ready offre la meilleure expérience de jeu pour les derniers jeux prenant en charge les technologies DLSS et RTX, notamment 007 First Light, LEGO® Batman™ : Legacy of the Dark Knight, EA SPORTS™ F1® 25 : 2026 Season Pack et World of Tanks : HEAT.
Applications
Le pilote NVIDIA Studio de mai offre une prise en charge optimale des dernières applications créatives et mises à jour, y compris des versions optimisées pour les performances de ComfyUI et Llama.cpp.
Nouveautés de la version 610
    Prise en charge de CUDA 13.3
    Ajoute les dernières améliorations de performances, corrections de bugs et améliorations de pilotes.
Correction de bugs de jeu
    CORRIGÉ Like a Dragon : Infinite Wealth : scintillement des ombres/lumières après la mise à jour du pilote [5973185]
    CORRIGÉ Enshrouded : Terrain manquant après la mise à jour du pilote [5955501]
    CORRIGÉ Des artefacts visuels peuvent apparaître dans certains jeux utilisant le moteur Godot [5948805]
    CORRIGÉ Améliorations de la stabilité des jeux multi-écrans lors de l'utilisation de la synchronisation verticale [5343252]
Correction de bugs généraux
    CORRIGÉ Adobe Lightroom Classic : Problèmes de stabilité de l’application [6090770]
    CORRIGÉ Autodesk Forma : Fuite de mémoire lors de l’orbite de la caméra lorsque OpenGL est utilisé [5935127]
    CORRIGÉ : L'écran Apple Studio Display XDR n'affiche plus que du 480p après la mise à jour du pilote [5976295]
    CORRIGÉ Samsung The Frame : L’utilisation du mode Jeu de l’écran désactive des fonctionnalités clés [5825631]
Message édité par cedric39 le 26-05-2026 à 15:52:33
''9800X3D // RTX 4090 // 32Go de RAM 6000Mhz CL30 // NVME : Samsung 980 PRO 1To //be quiet! Silent Base 802 // AIO NZXT X62 // Samsung Odyssey Néo G8
n°11478532
Umi
Posté le 26-05-2026 à 16:06:26  profilanswer
Bon et bien il va probablement falloir passer sur cette nouvelle app.
Message édité par Umi le 26-05-2026 à 16:16:03
n°11478534
Le Profana​teur
Passéiste désincarné
Posté le 26-05-2026 à 16:35:34  profilanswer
Note : ne jamais installer le 610.47 et ses suivants.
Ça promet....
Heureusement je n'ai qu'une 3080 Ti...
Message édité par Le Profanateur le 26-05-2026 à 16:40:50
n°11478535
Umi
Posté le 26-05-2026 à 16:50:56  profilanswer
3070 FE ici, je vais attendre les premiers retours...
Après, si tu lis le changelog, le panneau de contrôle continuera de fonctionner, mais il ne sera plus maintenu.
n°11478536
cedric39
Posté le 26-05-2026 à 16:58:03  profilanswer
Le panneau de configuration Nvidia reste si on installe nouveau driver par dessus l'ancien
Mais si on désinstalle Via DDU , le panneau Nvidia ne sera plus la
Entièrement remplacer par Nvidia APP
On peut remettre l'ancien panneau en passant par le Store Microsoft..
Mais en vrai c'est juste une question d'habitude, tous les paramètres sont dispo' dans Nvidia App, faut juste s'y faire, je vais me forcer à l'utiliser
n°11478539
DiB91
Bwaaaaaaah
Posté le 26-05-2026 à 17:08:34  profilanswer
Ça promet....
3080 Ti ici aussi (FE sur le PC gaming et Mobile sur le laptop), pourquoi bloquer l'installation ? :??:
C'est uniquement pour la "disparition mais en fait non" du Control Panel ou tu as eu des soucis ? :ouch:
n°11478540
Space
Posté le 26-05-2026 à 17:12:46  profilanswer
c'est bon à savoir.
Au final les derniers drivers qui proposaient le panneau de config Nvidia sont les 596.49 ?!
n°11478546
tistou77
Geek Inside!!
Posté le 26-05-2026 à 19:06:04  profilanswer
J'ai aussi l'ancien Control Panel, désinstallé les anciens et installé les nouveaux
n°11478547
DiB91
Bwaaaaaaah
Posté le 26-05-2026 à 19:19:23  profilanswer
Et l'installeur propose toujours les drivers PhysX en optionnel :D
n°11478548
Dirty Wing​s
Posté le 26-05-2026 à 19:42:34  profilanswer
Il fonctionne ? Chez moi, quand je clic dessus il ne se passe rien du tout.
Edit: problème résolu, j'ai réinstaller l'appli via le store.
Message édité par Dirty Wings le 26-05-2026 à 19:45:13
n°11478550
tistou77
Geek Inside!!
Posté le 26-05-2026 à 19:49:43  profilanswer
Oui il fonctionne, je peux paramétré
Je suppose qu'il n'est plus présent lors de nouvelle installation (ou passage DDU)
Message édité par tistou77 le 26-05-2026 à 19:50:09
n°11478551
Dirty Wing​s
Posté le 26-05-2026 à 20:36:51  profilanswer
ça doit etre ça certainement.
Merci :jap:
n°11478558
Miky 2001
N'y pense même pas !!!
Posté le 26-05-2026 à 21:46:08  profilanswer
Je débarque peut être mais on peut avoir en même temps l’appli nvidia et le contrôle panel ?
Si c’est le cas, une action dans l’un se visualise dans l’autre ?
C'est quoi léquivalent dune ATI 9600XT en NVIDIA ?Upgrade d'un PIII 550 pour montage vidéo ??
Problème de sortie vidéo en lecture DivXchanger le ventilo de carte video
Regarder une video sur sa tv...ventilateur carte video gfx malade
Carte uATX avec bonne sortie s-video ?probleme divx video duplicator pro
Deux cartes vidéo installéesrecherche drivers
Plus de sujets relatifs à : Topik Officiel des drivers vidéo nVidia
