6579 connectés
Laquelle pour vous interesse ?
 Page :   1  2  3  4  5  ..  983  984  985  ..  1325  1326  1327  1328  1329  1330
[Topic Unique] ATI Radeon 4800 Series (RV770 inside)
n°6739488
R95
Posté le 12-12-2008 à 23:21:36  profilanswer
Utilise driver cleaner pour le CCC.
n°6739492
Ferhat
Y'a pas le feu...
Posté le 12-12-2008 à 23:26:09  profilanswer
Pour ceux qui n'arrivent plus à upgrader les drivers (bug BSOD concernant uniquement les CF de 4850 sous vista x64) :
(1) Make sure that your 48xx Crossfire system is running normally with a set of CATs that works for you. For me, that was 8.10.
(2) Install the CAT 8.11's normally--I use the full CCP and driver install package.
(3) After install, reboot the system immediately into SAFE MODE.
(4) From SAFE MODE, go to ADMINISTRATIVE TOOLS/SERVICES and locate the ATI External Event Service. Set this service to DISABLED. Reboot normally into your standard operational mode.
(5) After boot, from the systray open the CCP. Go to the Crossfire section. You should see Crossfire check box empty even though you've installed the drivers with your Crossfire bridges connected. Check the box and hit "Apply" and be amazed to see that your system does not immediately bsod! Hit "OK" to close the CCP.
(6) Reboot into your normal operational mode again, go to CCP from the systray and check out your Crossfire settings which should now register checked, indicating that your Crossfire system is operating normally. You are done and problem solved. Since the ATi External event service is now disabled, however, you will have to reboot between turning crossfire on and off, but your bsod's should now be a thing of the past.
There's a method to this madness. You have to install the 8.11's prior to going into safe mode to disable the AEE service, and that's because when the drivers install they automatically set this service to "automatic," so if you try disabling the service before you install the 8.11's it won't help since the driver install will reset the service to automatic.
n°6739495
jugurtha94
PSN:hfrien
Posté le 12-12-2008 à 23:27:37  profilanswer
je vais reformater j'en ai raz-le-***
sa va lfaire ;)
j'ai juste peur qu'il ai raison
que ma carte est dead quoi oula sa sa va me faire mal au cul
mais garantie rdc...
Le sexe c'est bon seulement quand c'est dur
n°6739522
R95
Posté le 12-12-2008 à 23:54:48  profilanswer
Bon par contre j'ai installé les drivers HDMI mais au demarage j'ai toujours " PCI truck detecté " une astuce ?
n°6739526
jugurtha94
PSN:hfrien
Posté le 12-12-2008 à 23:59:31  profilanswer
:lol:  instal...
n°6739535
DrDooM
Posté le 13-12-2008 à 00:03:47  profilanswer
hop si quelqu'un pouvait me répondre : http://forum.hardware.fr/forum2.ph [...] w=0&nojs=0
n°6739537
jugurtha94
PSN:hfrien
Posté le 13-12-2008 à 00:05:35  profilanswer
si tu joue pas garde celle de base et puis bon avec hp toussa il sont chiant a enlever les driver nv->ati
n°6739542
DrDooM
Posté le 13-12-2008 à 00:11:37  profilanswer
je compte faire une install propre de l'OS. c'est juste que j'aurais aimé avoir un ordre de puissance entre 9500GT, 9500GS et HD4550, avec juste un pourcentage moyen pour me faire une idée :)
n°6739543
shelton
novey
Posté le 13-12-2008 à 00:13:42  profilanswer
exemple:8.10(CD de sapphire)
ATT+CCC(j'arrive pas a désinstaler CCC)
ATI2DVGA
8.11
att+ccc
meme chose
et 8.2 aussi...
demain je vais test avec une HD4870 et une HD4850 pour voir apres jvou tien au jus ;)
Et en faisant les choses correctement?
Enlèves tout.
Reboot en mode sans echec
Nettoyage avec driver Cleaner puis CCleaner. > Reboot (option)
Installation du Display Driver > reboot
Installation de la dernière version d'ATT, désactivation du service ATI Hotkey Poller, installation des driver de l'écran (option) > reboot
Configuration d'ATT (penses à désactiver le service ATI Hotkey Poller avant de configurer ATT, tu risques d'avoir des BSOD)
Et normalement tout roule..
J'ai eu bien des soucis avec des drivers foireux mais jamais très longtemps en nettoyant correctement  :)
n°6739545
jugurtha94
PSN:hfrien
Posté le 13-12-2008 à 00:15:56  profilanswer
merci l'ami je te tien au jus demain puisque la j'ai mis la cm a la boite toussa (passage de p5n-t deluxe a p5e) donc fleme mais jte tien au jus sinon 520w sa suffit pour un CROSS ?
n°6739574
han_solo
in Thë Ðëëp ßluë
Posté le 13-12-2008 à 01:01:03  profilanswer
jugurtha94
En ce qui me concerne, impossible d'installer les catalyst 8.11 où 8.12 sur mon PC sans avoir un bsod aléatoire quand je quitte un jeu.
Etrangement, si je met les catalyst 8.10 tout fonctionne correctement ^^. J'ai tout réinstallé pensant comme toi que le pb serait réglé mais ... en vain.
Ce qui me fait râler c'est que j'ai monté pour des amis 2 autres machines toutes neuves avec des 4870 et que tout fonctionne parfaitement normalement avec a peu de choses près les mêmes composants que moi ^^
Apparement j'ai trouvé le moyen de ne plus avoir de bsod : désinstaller les CC et ne mettre que le pilote graphique. Comme quoi, parfois il ne faut pas trop se prendre la tête.
Message édité par han_solo le 13-12-2008 à 01:02:43
Thanks to ImageShack for Free Image Hosting - Ma validation CPU-Z ICI
n°6739666
saebalyon
le roi de l'aurtogafe
Posté le 13-12-2008 à 09:11:03  profilanswer
Désoler de déranger vue ma 4850 est vraiment louche (impossible a overclocker, 2 prise de courant, des bsod par moment .... enfin plein de merde divers)
J’ai donc décidé de faire 2 test full qualité de suite sur 3dmark 2006, tous option au maxi dans les catalyse (8.10) et ca me donne ce résultat : http://citymonsite.site.voila.fr/fullqualite.jpg
Pour les bsod que j’avais, pour le moment ca c'est calmer, j'ai ventilé plus le pc (antec p182) et ca a l'air d'aller
Le résultat pour une 4850 son correct ou pas ? Ou faut t'il je la renvoi au SAV ?
Merci de votre aide fort sympathique
n°6739677
nhemles
Mort aux assistés
Posté le 13-12-2008 à 09:49:20  profilanswer
Impossible à overclocker -> l'overclocking n'est pas garanti, si tu n'as pas de bol ta carte ne monte pas, point barre.
Plein de merde drivers -> Vire ton Windows piraté, tes jeux crackés, ton overclocking pas stable, vérifie que ça ne chauffe pas trop, etc. Et fais toi un système propre pour passer aux 8.12.
Le résultat est correct, sous 3DMark ton processeur limite. Le SAV va bien se foutre de ta gueule si tu leur renvoie ta carte alors qu'elle est fonctionnelle.
n°6739682
saebalyon
Posté le 13-12-2008 à 09:55:32  profilanswer
j'ai rien de piraté -_- , faut arete de voir des pirate de partous -_- (c'est mon pc du taf , donc les truc pirate :x, le patron aimerai pas :D )
et vais essayer ton conseille pour le 8.12, et j'ai pas écrit drivers mais divers :p
merci de la reponse ^^
n°6739686
nhemles
Mort aux assistés
Posté le 13-12-2008 à 09:58:21  profilanswer
Ah parce que tu overclockes les PCs du taf :sarcastic: ?
n°6739734
goahould
Posté le 13-12-2008 à 10:58:16  profilanswer
goahould a écrit :
donc je viens d'installer atitool et/ou atitray tool et aucun des 2 ne voit les fréquences de ma CG,une MSI R4870-T2D512-OC
du coup je n arrive pas a regler la vitesse du ventilos comment cela se fait il que ces 2 softs ne fonctionnent pas avec ma carte
personne ne sait pouequoi ces soft ne voient pas ma carte correctement
n°6739745
saebalyon
Posté le 13-12-2008 à 11:09:36  profilanswer
On est une entreprise ouvert en tous (mon voisin lui mais bien des photos cochon dessus :D genre femjoy :p ) , t'en ce n’est pas pirate ca vas ^^ P.S : un a mis des Chaussons chauffants USB sur son pc :D
Fin de la parenthèse, désolée du trolage :p
Bon pour 8.12 j'ai essayé, gagner 100 point :D purée de rire mais bon c'est la vie :D
Pour l'overclockage de la carte c'est dommage
Faudra je pense à installer la 2 eme sur le pc pour de meilleur résultat (c'est la même que la première, dommage si j'avais su pour l'overclock j'aurai prit autre chose), mais bon faut quand même pixmania ce réveille a m'envoyer ma 750w corsaire :(
Vue tous les site teste avec des proc intel , ca fait mal au bide de voir de si grosse diference en resultat , on a pas tous du intel :(
n°6739750
jugurtha94
PSN:hfrien
Posté le 13-12-2008 à 11:13:28  profilanswer
han_solo a écrit :
jugurtha94
bon cette aprem je vais allé prendre ma p5e et je vous tien au jus ;)
mais dans le BOSD il disent quoi?
Message édité par jugurtha94 le 13-12-2008 à 11:15:29
n°6739787
Skandranon
☻ X-Trem ☻
Posté le 13-12-2008 à 11:43:55  profilanswer
http://www.rueducommerce.fr/Compos [...] on-PCS.htm
Commandé à l'instant ! Ahhhh  :D
• Asus ROG STRIX B550-E - AMD Ryzen 7 5800X3D - 32Go Corsair Vengeance - Sapphire Nitro+ RX7900XT - 3 x SSD - Corsair RM850x V3 - Corsair 5000X - H150i Capellix •
n°6739821
kyky
Je suis newbie et alors,
Posté le 13-12-2008 à 12:03:43  profilanswer
Il sort quand l'asus HD4870 matrix  :??:
En janvier c'est trop tard il y aura le RV775 XT  :D
Message édité par kyky le 13-12-2008 à 12:04:14
le progrès ne vaut que s'il est partage par tous.Ce que je vends
n°6739853
TheCreator
Posté le 13-12-2008 à 12:28:19  profilanswer
salut, je viens de recevoir ma 4870gse 1go, et j'aimerais savoir comment fonctionne le mode turbo!
c'est en rapport avec l'oc? ça fait chauffer? pourquoi ne pas la mettre tout le temps en turbo?
merci d'avance :D
n°6739865
MetallixX9​74
1 Octet = 8 kms.
Posté le 13-12-2008 à 12:35:09  profilanswer
:fou:  Phoque Oeuf Need For Speed Undercover,  :non:  Un jeu à éviter;
Avec mon Crossfire HD4850+HD4870 et mon Q9550@stock en 1600 x 1200 Aa6x le jeu est saturé d'aliasing  :heink: et ça tourne en moyenne à 35 Fps avec des chutes vertigineuse à 17 Fps voire moins  :sweat: .
Non mais bientôt il faudra qu'ils proposent dans la boite du jeu un bundle jeux+Cg qui va avec  :pt1cable:
n°6739868
Activation
21:9 kill Surround Gaming
Posté le 13-12-2008 à 12:37:18  profilanswer
le dernier need for speed ou je me suis un peu marré c est le undergrounds... et encore fallait pas désactivé le blur sinon bonjour l aspect immonde des vehicules avec les textures mal positionné sur les vehicule
comme quoi les effets poudre aux yeux tel le blur c est souvent là pour masqué la feignantise des dev plus qu autre chose (sous entendu plus que d offrir de la valeur ajouté)
Message édité par Activation le 13-12-2008 à 12:37:43
n°6739871
funky 83
Posté le 13-12-2008 à 12:38:14  profilanswer
Ce n'es pas ta config le pb mais bien le jeu qui est une daube graphique codé a la va vite avec une équipe doté de moufle  :o . (un peu la meme équipe qui a fait le portage console vers pc pour gta4 )
Feedback
n°6739877
MetallixX9​74
1 Octet = 8 kms.
Posté le 13-12-2008 à 12:41:33  profilanswer
J'ai mis un le Patch HD non officiel, bah c'est pas terrible non plus ! Je mets ma main au feu que c'est encore un jeu optimisé pour les moteurs Nvidia  :p
Message édité par MetallixX974 le 13-12-2008 à 12:42:23
n°6739879
mikythebad
Posté le 13-12-2008 à 12:42:02  profilanswer
Ou alors les pilotes Ati ne sont pas optimisés pour ce jeu en crossfire, car moi avec une hd4870 non oc + Q6600@3.8ghz, 4go ram... en 1920*1200 tout a fond ca tourne a peu près bien, je n'ai pas de chute a 17fps, je suis entre 60 et 25fps a peu près.
₪ Mon Topic d'achat/vente
n°6739883
MetallixX9​74
1 Octet = 8 kms.
Posté le 13-12-2008 à 12:45:04  profilanswer
Oui peut être aussi, m'enfin bon  :lol:
n°6739893
MetallixX9​74
1 Octet = 8 kms.
Posté le 13-12-2008 à 12:54:01  profilanswer
:sweat:
http://img393.imageshack.us/img393 [...] 763sg3.jpg
Message édité par MetallixX974 le 13-12-2008 à 12:55:51
n°6739901
rouhaud
cybermodercom
Posté le 13-12-2008 à 12:56:43  profilanswer
avis aux expert,
je travaille dans un cybercafé a pau, et j'ai rapporter ma tour pour tester deux trois trucs avant de l'installer sur les pc du cyber ( j'ai l'occasion d'essayer de monter en plus de ma hd4850 une carte graphique radeon x1900xt ) a votre avis est que le crossfire va fonctionner entre une 4850 et une x1900xt. sachant que j'ai une carte mere p5w dh ( chipset i975 )
tel: 0581314275 https://www.ippi.fr?referer=rouhaud
n°6739904
alexreunio​n
Posté le 13-12-2008 à 12:57:51  profilanswer
rouhaud a écrit :
avis aux expert,
non ça ne marchera pas
Mon feedback
n°6739906
MetallixX9​74
1 Octet = 8 kms.
Posté le 13-12-2008 à 12:59:35  profilanswer
rouhaud a écrit :
avis aux expert,
Négatif chef, ça marchera pas  :non:
n°6739912
Yoyo_5
Posté le 13-12-2008 à 13:01:37  profilanswer
Tu seras peut-être moins heureux quand tu apprendras que le modèle envoyé par RDC n'est plus le même que le précédent... :whistle:
Moi, perso, je le suis... :o
Message édité par Yoyo_5 le 13-12-2008 à 13:02:04
¤ Paix et félicité ¤
n°6739930
shelton
novey
Posté le 13-12-2008 à 13:13:37  profilanswer
Désactives le service ATI Hotkey Poller.
Moi j'ai des BSOD de temps en temps quand je touche à l'AA ou l'AF via ATT avec les 8.12 :sarcastic:
Je suis repassé au 8.8..
Au passage quelqu'un pourrait-il me donner le poids du fichier ati2dvag.dll des cata 8.12 xp?
xp32 sp2
n°6739940
Yoyo_5
Posté le 13-12-2008 à 13:30:17  profilanswer
Ouaip, mais tu peux avoir une piste quand tu leur téléphones pour savoir. ;)
n°6739946
Yoyo_5
Posté le 13-12-2008 à 13:33:16  profilanswer
Ils te diront que c'est soit Gainward, soit Palit, soit Powercolor, mais ils ne te diront pas précisément ce que tu veux savoir. :/
Le dernier retour ici faisait mention d'une GS, donc c'est pas une mauvaise chose en soit (sauf si on veut watercooler). ;)
n°6740175
Skandranon
☻ X-Trem ☻
Posté le 13-12-2008 à 16:19:33  profilanswer
Euh ? Je vais bien recevoir une PCS+ 1Go ?
Elle a quoi de différent à l'autre ?
n°6740207
Digaboy
Posté le 13-12-2008 à 16:44:39  profilanswer
y me semble avoir vu des wb pour les gs sur docmicro
ATI ou problème d'isolation électrique?[Topic Unique] Gigabyte GA-P31-DS3L
[ATI 1950gt] pas d'image hors mode VGA par défaut RADEON 9600 PRO 256 DDR2 est ce compatible ?
carte AGP - Radeon HD2600XT ou X1950Pro ?[Topic Unique] DFI LANPARTY "DK" : P35 T2RS et X38
[Topic Unique] Timings Mémoire [travail commun][Topic Unique] - Western digital 640 Go et 320Go (plateau(x) de 320Go)
Lire une source video extérieur sur le PC avec ATI control center[Topic Unique] DFI LANParty LT X38-T2R
Plus de sujets relatifs à : [Topic Unique] ATI Radeon 4800 Series (RV770 inside)
