10122 connectés
Allez-vous sauter sur une 6xxx ou bien attendre les 7xxx et le 28nm ?
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  387  388  389  ..  839  840  841  842  843  844
[Topic Unique] AMD Radeon HD 6800 et 6900 ; 40nm dx11
n°7670921
Xantar_Eoz​enn
Posté le 23-11-2010 à 16:21:26  profilanswer
Pour info, les mêmes schémas pour la 5870 à l'époque :
http://www.hardware.fr/medias/phot [...] 026881.jpg
http://www.hardware.fr/medias/phot [...] 026883.jpg
n°7670922
aliss
Rhyme the Rhyme Well
Posté le 23-11-2010 à 16:23:02  profilanswer
Ca y ressemble tout de même un peu dans l'idée, voir ce qu'en dit Theo,
What is Cayman? Two Graphics Engines with fifteen 64-core Clusters each for a grand total of 1920 cores
In the second slide, you can see that Cayman GPU actually features a Dual graphics engine, essentially, you can compare Cayman to two Barts GPUs combined into one. You still have the same 256-bit memory controller known from Evergreen parts [Cypress] and Barts, the affordable Northern Islands part [Radeon HD 6800 Series], but now the memory controller is loaded from two independent graphics engines.
Dual Graphics Engines are consisted out of Geometry and Vertex Assemblers, Tessellator unit and Rasterizer/Z operations feeding into Shader Engine
Both Graphics engines receive orders from one Command Processor, but they're aggressively performing load balancing using the tile-based method, much akin to the way how certain multi-GPU methods work. Each Graphics Engine is consisted out of Rasterizer [ROP] and aggressive Hierarchical Z from one side and Geometry Assembler, Vertex Assembler and Tessellator from another.
http://www.brightsideofnews.com/ne [...] eiled.aspx
n°7671042
sharshar
Slava Ukraini
Posté le 23-11-2010 à 17:44:04  profilanswer
si ils arrivent a faire ne serait-ce qu'un peu plus perf (5%) pour moins cher, ca serait de la bombe bébé  [:ahmadinejad_wins]
PSN : aLka94/Sharshar_Bling
n°7671046
Yoyo_5
Posté le 23-11-2010 à 17:46:53  profilanswer
S'ils font plus perf, ce sera plus cher. [:ojap]
¤ Paix et félicité ¤
n°7671083
toto le su​per hero
Your life is just a choice
Posté le 23-11-2010 à 18:19:14  profilanswer
+1, ça fait un moment que le prix d'une carte n'est pas dependant de son cout de production mais plutot de son positionnement en terme de perf !
n°7671092
toto le su​per hero
Posté le 23-11-2010 à 18:23:54  profilanswer
nhemles a écrit :
Reprenons vu qu'on sait maintenant qu'on a 480 processeurs vec4 pour Cayman XT [:o_doc]
L'hypothèse de processeurs vec4 plus gros que les processeurs vec5 a été démentie par le slide AMD signalant qu'ils sont 10% plus petits. On sait aussi par ce même slide que grosso modo les processeurs vec4 sont aussi performants que les vec5. Vu le wording utilisé, en fait ils doivent être un peu moins performants, disons 95%.
Cypress fait 334mm² pour 2.15 milliards de transistors et 320 processeurs vec5, donc pour 480 processeurs vec5, on a besoin de 3.23 milliards de transistors. Donc pour des processeurs vec4 (10% plus petits), il suffit de 2.9 milliards de transistors. Avec la même densité que Cypress, ça fait un die de 451mm². C'est moins que Fermi avec ses 520mm². Donc consommation moindre et coût de la puce inférieur. Ça promet des cartes moins chères, sauf si le prix de la mémoire flambe (512 Mo d'écart avec une GTX580).
La HD5870 2 Go c'est 0.8*GTX580 en performances. Les processeurs en augmentation de 50%, si rien d'autre ne bride et à la fréquence GPU du Cypress, promettent 50% de performances en plus, on est donc 20% plus performant qu'une GTX580. Les processeurs vec4 valant 95% des processeurs vec5, on arrive à :
HD6970 2 Go = 114% * GTX580
Le Cayman XT récupère la couronne de la performance, tout en consommant moins que le GF110, et en coûtant moins cher.
Bonus : Vu que la puce sera à priori plus petite que le GF110, TSMC ne doit pas avoir trop de mal à la graver.
C'est un peu vite calculer. On a déjà vu a mainte reprise que les perf d'une carte n'etait pas forcement en rapport avec sont nombre de processeur. On a déjà vu AMD pourrir des cartes (2800 ?) avec un nombre de processeur impressionnant et des choix plus que discutable sur le reste de l'archi. De même les perf du fermi sont presque decevante au vu du nombre de proc.
n°7671106
barbare128
pas de koi se rouler par terre
Posté le 23-11-2010 à 18:33:21  profilanswer
tout dépends des yields et du nombre de galettes commandés, pour vendre plus s'il y a plus de stock ça peut faire chuter les prix ;)
Feed my back : http://forum.hardware.fr/forum2.ph [...] w=0&nojs=0
n°7671124
kaiser52
Posté le 23-11-2010 à 18:43:22  profilanswer
Les stocks ça influence plus le prix revendeur.
Ca permettra juste d'aligner le prix revendeur avec le MSRP annoncé, si il est annoncé plus haut que celui de la GTX580, ça ne descendra pas plus bas. :jap:
Benchmarks du peuple - Crysis War - Vide grenier ! - nVIDIA Tegra
n°7671132
Activation
21:9 kill Surround Gaming
Posté le 23-11-2010 à 18:49:29  profilanswer
interessant
t as besoin de plus de transistors avec tes vec4 qu'en a le gpu lui même incluant les rops/les SP, les graphique engine, les caches ....
 [:cytrouille]
gf100 3,2 milliards de transistors
bref faut arrêter la bibine et pensé que tout se scale sur ce que bouffe en transistor les ALUs dans le GPU :o
Message édité par Activation le 23-11-2010 à 18:51:47
n°7671194
Lyto
Posté le 23-11-2010 à 19:35:35  profilanswer
Edit : j'ai rien dit...
Message édité par Lyto le 23-11-2010 à 19:37:38
L'innovation, c'est extra :)
n°7671211
obzn_bench​mark
Posté le 23-11-2010 à 19:45:33  profilanswer
Dual Graphique Engines ? on peu considérer ça comme un dual-core ?
car bon 1920sp c'est pile le double de la 6850 ...
Ach/Vds | FeedBack
n°7671223
tenseur1
Posté le 23-11-2010 à 19:54:09  profilanswer
Non !
La HD 6850 n'as aucun rapport avec la HD 6970
L'une c'est basé sur sp 5D et l'autre sur sp 4D
n°7671272
Activation
Posté le 23-11-2010 à 20:35:04  profilanswer
n'empeche toutes les info là ça soulève bien des questions
la premiere est ce que du coup avec le 28nm celui qui remplacera cayman n'aura pas 3 ou 4 graphique engine
si bien qu'au final la nouvelle archi AMD consiste en des 'core RADEON' [1graphique engine+480SP] qui s oppose aux core CUDA
ces même core seront commun avec ceux dans les APU de amd
donc ça veut dire que chaque 'core RADEON' s'occupe d'une partie de l'image
donc un cayman et ces successeurs travail en "SFR" même en monogpu ?
remarqué moi je vois un aspect pratique à de tel 'core RADEON' en virtualisation
on pourrait allouer des 'core radeon' à des machines invité sur la machine hote et du coup enfin pouvoir taper dans du directx sur une machine invité
bref enfin des jeux récent utilisable sur des machines virtuelles (pas juste des "abandonware" maxi directx8 )
tout ça avec une relative opacité de "bah alors ils en sont ou des drivers pour les HD69xx rien filtre dans les hotfix actuel"
EDIT: et l'histoire du DMA et de off chip cache machin
à terme c'est pas pour déboucher sur un aspect plus "ROPs" coté mémoire que coté GPU
et donc plus avoir besoin de multiplier par 'n' la mémoire pour 'n' gpu présent sur un PCB
Message édité par Activation le 23-11-2010 à 20:47:19
n°7671288
Invite_Sur​prise
Racaille de Shanghaï
Posté le 23-11-2010 à 20:47:49  profilanswer
nApoleon vient de poster quelques résultats de 3DMark 2011
3DMark 11 eXtreme模式
HD6870___2302
HD6850___2269
GTX 460 1GB___1772
http://tof.canardpc.com/preview2/04b2d286-5d46-4fab-abb7-2d146212e0b0.jpg
http://www.chiphell.com/thread-141210-1-1.html
Les Radeons semblent très bien se comporter sur ce bench  :jap:
Message cité 4 fois
Message édité par Invite_Surprise le 23-11-2010 à 20:50:39
n°7671291
0b1
There's good in him
Posté le 23-11-2010 à 20:50:56  profilanswer
3DMark 11 eXtreme模式
HD6870___2302
HD6850___2269
GTX 460 1GB___1772
http://tof.canardpc.com/preview2/0 [...] 12e0b0.jpg
Tout comme avec Vantage...
n°7671299
Yoyo_5
Posté le 23-11-2010 à 20:55:24  profilanswer
3DMark 11 eXtreme模式
HD6870___2302
HD6850___2269
GTX 460 1GB___1772
Ce que ça ne dit pas, c'est à combien de FPS ça tourne... ^^
+1. ^^
Message édité par Yoyo_5 le 23-11-2010 à 20:56:01
n°7671311
Corleone_6​8
Posté le 23-11-2010 à 21:00:57  profilanswer
Activation a écrit :
dire que le 13decembre je suis en déplacement pour mon taff ... trop degoute je vais être le dernier de la bande à pouvoir lire les tests  :o
Quelle bande ??  :heink:
mdc888 a écrit :
Pinaise, j'y ai passé tellement d'heures sur carma que j'en ai une larme à l'oeil.
D'ailleurs j'aimerai bien me refaire qq partie tiens, mais faudrait remonter une config win95
Bah mode compatibilité et je suis sûre que ça fonctionnerait encore :o (Quoi que c'est possible peu être..)(Demande à notre bêta testeur de drivers sur GTA 4 je suis sûre qu'il a essayé [:ddr555])
Message édité par Corleone_68 le 23-11-2010 à 21:03:07
Phanteks Enthoo Primo / Seasonic P-860 / Asus Strix B550 E/ Ryzen 5600X WC / 2*16 F4 3600C16 Gskill Ripjaws @3733 / 6900XT Red Devil / Crucial C300 128 Go / Sam 850 Evo 500 Go / Velociraptor 300 Go / Caviar Red 4 To / Caviar Black 1 To
n°7671323
Fouge
Posté le 23-11-2010 à 21:07:16  profilanswer
3DMark 11 eXtreme模式
HD6870___2302
HD6850___2269
GTX 460 1GB___1772
Les HD6850 et 6870 ont des scores similaires, étrange :heink:
n°7671325
Corleone_6​8
Posté le 23-11-2010 à 21:09:52  profilanswer
P-ê OC la 6850 ? Enfin c'est pas dans l'interet du test mais bon..
n°7671331
le_duc
PlaTyPuS
Posté le 23-11-2010 à 21:11:44  profilanswer
Petite question, j'ai une ASUS 6850 et j'aimerais savoir comment on fait switcher le son du HDMI vers le DisplayPort.... ça me paraît être une opération plus que basique, mais je n'arrive a trouver ça ni dans Catalyst Control Center, ni dans les paramètres Windows.....
Pour l'instant quand je suis branché en HDMI, pour avoir le son sur le displayPort, je dois déconnecter le HDMI, mettre le DisplayPort et remettre le HDMI.......... un peu fastidieux tout de même non???  :sarcastic:
Merci pour vos réponses.
n°7671347
Corleone_6​8
Posté le 23-11-2010 à 21:23:50  profilanswer
Perso je n'ai pas la reponse, mais tu auras p-ê plus de reponses sur ce topic http://forum.hardware.fr/hfr/Hardw [...] 6876_1.htm ;)
n°7671386
sasuke87
Posté le 23-11-2010 à 21:45:46  profilanswer
3DMark 11 eXtreme模式
HD6870___2302
HD6850___2269
GTX 460 1GB___1772
Donc c'est ça l'avenir de la tesselation [:lol_yvele]
nvidia nous a menti avec hawk 2 et consort?  :whistle:
n°7671389
Activation
Posté le 23-11-2010 à 21:46:29  profilanswer
en mode extreme hein :o ça ecrase bien la courbe des scores :o
et y a la memoire vive et le cpu qui joue
on bench pas juste la CG
Message édité par Activation le 23-11-2010 à 21:47:21
n°7671396
Activation
Posté le 23-11-2010 à 21:50:05  profilanswer
la tess n'est qu'une feature parmis d'autres offerte sur directx 1x
si les devs commence enfin à se bouger le cul c'est que le parc de windows vista/7 à enfin dépassé le parc de WinXP
donc il dev enfin en dx1X
y avait pas qu'une histoire de portage console en cause
Message édité par Activation le 23-11-2010 à 21:52:03
n°7671397
guig2000
Posté le 23-11-2010 à 21:50:37  profilanswer
Cette histoire de TDP contenu me chiffonne quand même:
Dans le cas de la Stereo3D, où la carte est très stressée (chez moi FUEL en S3D charge plus ma CG que furmark), j'ai peur d'un nivèlement des perfs par le bas.
chez nvidia ils font pareil sur la gtx580?
Message édité par guig2000 le 23-11-2010 à 21:51:33
Guig Esprit du Sage
n°7671406
Activation
Posté le 23-11-2010 à 21:55:35  profilanswer
bah oui, après à mon avis le mécanisme doit se mettre en branle quand tu fait plein d opération similaire sur une période étrangement trop longue
genre d'avis que ça doit se mettre en branle quand un folding@home tourne
un jeu le framerate varie car tu bouge donc tu n affiche pas constamment les même chose, et les evenements scripté ssont aléatoire
donc la charge n'est déjà pas constante
tout comme un fraps va te remonter le nb de fps en temps reel doit pas être bien compliqué à un amd ou un nvidia de détecté un comportement douteux du hardware qui laisse présagé un truc lourdingue genre un furmark ou un truc sauce "SETI"  ou "boinc" en train de tourner
Message édité par Activation le 23-11-2010 à 21:59:16
n°7671411
Yoyo_5
Posté le 23-11-2010 à 21:59:13  profilanswer
Que ce soit avec ou sans 3D, la charge doit être kif kif bourricot pour le GPU, donc pas de soucis à se faire. ;)
Par contre les perfs sont fatalement divisées par plus ou moins 2. :/
n°7671427
Corleone_6​8
Posté le 23-11-2010 à 22:12:54  profilanswer
Et c'est là que ça fait mal :/
n°7671454
guig2000
Posté le 23-11-2010 à 22:26:07  profilanswer
Non, chez moi la carte est plus chargé avec 3D que sans.
J'avais une led d'erreur allumée en permanence et dès le boot sur ma 4870, mais comme ça l'avait toujours fait, je croyais que c'était normal, que ça voulait dire "power-on" ou un truc du style. Pourtant dès que je jouait en 3D j'avais des plantages sur les zones chargées en shaders dans les jeux. Par exemple quand je regardait des étendues d'eau dans Dragon Age, la carte plantait. J'ai cru d'abords à un bug du pilote 3D (iz3D), d'ailleurs j'ai fait plusieurs signalement. Mais je me suis rendu compte plus tard que c'était ma carte qui était défectueuse (problème de VRM) car elle plantait avec trop de jeux dès que j'étais en 3D (RUSE, FUEL). Pourtant elle faisait tourner sans problèmes des tests comme furmark et autres.
Ce qui montre bien que la stéréo3D charge fortement la CG.
Après c'est sur, si tu es déjà limité par le GPU en mono, cela ne changera rien en stéréo.
Message édité par guig2000 le 23-11-2010 à 22:29:26
Guig Esprit du Sage
n°7671495
MEI
|DarthPingoo(tm)|
Posté le 23-11-2010 à 22:51:29  profilanswer
Blue Apple a écrit :
Pas plus que les réglages foireux en AA par défaut de nVidia qui faussent les benchs sur pas mal de sites (genre xbitlabs).
Non, c'est pas les réglage de NVIDIA qui faussent les benchs, c'est le QI d'un huitre de l'utilisateur.
Si tu choisis AA4X ou AA8X dans N'IMPORTE QUEL jeux Direct3D/OpenGL, t'aura du MSAA. Les modes avec CSAA, faut soit que le jeux le prennent pas defaut, soit avoir tripatouillé dans les pilotes. Et là dans les pilotes, ils suffit de lire l'aide quoi... :spamafote:
n°7671498
hyksos_sow​o
Posté le 23-11-2010 à 22:52:52  profilanswer
Désolé mais ça prouve rien dutout.
furmark utilise 100% des unités de calcul 100% du temps, c'est impossible de charger le GPU plus que ça, dans ton cas ce qu'il ce passe est que ATI ont du faire du throttle sur furmark pour éviter de faire griller les VRM de la carte, ça été ajouté au driver à un certain moment et ça affect les cartes 4XXX.
Mais sans ce throttle furmark charge infiniment plus tes cartes que n'importe quel jeux en 3D.
n°7671505
Corleone_6​8
Posté le 23-11-2010 à 22:57:29  profilanswer
 :lol:  :lol:
Forcement c'est jamais nV c'est l'utilisateur..  :lol:
n°7671506
nhemles
Mort aux assistés
Posté le 23-11-2010 à 22:58:42  profilanswer
Corleone_68 a écrit :
 :lol:  :lol:
C'est MEI hein, c'est pas sa faute le pauvre [:marc]
n°7671522
seu
M 41
Posté le 23-11-2010 à 23:18:08  profilanswer
ça va Mei?   :p
http://sellerie-equishop.oxatis.com/Files/20877/248A.jpg
Si t'es sage , a nowel je t'enlève tes œillères.....
Message édité par seu le 23-11-2010 à 23:18:52
n°7671528
kaiser52
Posté le 23-11-2010 à 23:26:39  profilanswer
Source ?
n°7671531
Corleone_6​8
Posté le 23-11-2010 à 23:28:34  profilanswer
[:power600] [:al zheimer]
Désolé je ne sais pas si c'etait pour rire mais quand j'ai lu ça j'ai rigolé.
n°7671533
Yoyo_5
Posté le 23-11-2010 à 23:29:00  profilanswer
Nawak, OCCT GPU charge le GPU encore plus que Furmark donc finalement il ne charge plus que 90 voire même 85% du GPU en comparaison de OCCT GPU. [:tinostar]
n°7671537
Corleone_6​8
Posté le 23-11-2010 à 23:30:25  profilanswer
Ha bon ?  :??:
n°7671539
Fouge
Posté le 23-11-2010 à 23:31:13  profilanswer
Le mieux c'est d'Arma2 :
Les paramètres proposé pour l’antialiasing dans le jeu sont peu clairs et différents entre les cartes AMD et Nvidia. Du côté d’AMD, 3 modes sont proposés : faible, moyen et élevé. Ils correspondent au MSAA 2x, 4x et 8x. Du côté Nvidia, ça se complique :
- faible et moyen = MSAA 2x
- élevé et très élevé = MSAA 4x
- 5 = MSAA 4x + CSAA 8x (appelé 8x dans les pilotes Nvidia)
- 6 = MSAA 8x (appelé 8xQ dans les pilotes Nvidia)
- 7 = MSAA 4x + CSAA 16x (appelé 16x dans les pilotes Nvidia)
- 8 = MSAA 8x + CSAA 16x (appelé 16xQ dans les pilotes Nvidia)
Un bel exemple simple et intuitif, qui donne l'assurance qu'un même réglage utilise le même AA chez ATI que chez nVidia :jap:
n°7671540
kaiser52
Posté le 23-11-2010 à 23:31:34  profilanswer
Je pense que la mesure d'utilisation est plutôt biaisée.
Sous Furmark je suis entre 90 et 97% d'utilisation.
Sous OCCT 99.99%.
En jeu, je suis souvent au niveau de Furmark (Voir plus), sans pourtant chauffer autant, je chauffe souvent moins. :/
n°7671542
duck69
Posté le 23-11-2010 à 23:32:44  profilanswer
secalex a écrit :
380€ la 6970 [:cbrs]
si comme le dis Wirmish , comparable a une Cf de 6870 j'achète le jour même.
T'a la variante Duck qui consiste a manger des tomates farcies chez papa/maman, avoir la vie d'un moine au moyen age, acheter des drouilles au moment où elles valent rien, les revendre à *2 10 ans plus tard.
[Topik Unik] Les AMD Radeon™ XFX HD 5870 ─ 587X ● mini BDD ● Sondage ●probleme d'affichage radeon 4870 : affichage surface réduite
[Topic Unique ?] Lian Li PC-8FI : Moyen tour 2010 !! Coming soon !![topic unique] Silverstone SG05 / SG06 / SG07
radeon 3650-3850-4650 agpATI 5750 ou 5770 ?
Probleme ATI HD 5850 POwercolor ati2dvag.dll
Plus de sujets relatifs à : [Topic Unique] AMD Radeon HD 6800 et 6900 ; 40nm dx11
