3282 connectés
Allez-vous sauter sur une 6xxx ou bien attendre les 7xxx et le 28nm ?
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  171  172  173  ..  839  840  841  842  843  844
[Topic Unique] AMD Radeon HD 6800 et 6900 ; 40nm dx11
n°7608597
Invite_Sur​prise
Racaille de Shanghaï
Posté le 13-10-2010 à 21:50:41  profilanswer
Radeon HD 6870 officially at 900MHz  - Fudzilla
1050MHz GDDR5 memory
The chip that was supposed to replace Radeon HD 5770 and HD 5750 and that mysteriously ended up with Radeon HD 6870 and Radeon HD 6850 moniker has finally got its clock. It runs at 900MHz.
As we speak AMD is telling chosen press representatives about the specifics of the chips and how they plan to dominate the word. We still don’t see many ATI Radeon HD 5870 owners to be that hot for AMD Radeon HD 6870. I guess the message is that AMD's Radeon is not as good as ATI’s, and of course we are joking, but let us get burned by our beloved fanboys in the comments section. (You mean to tell me that we have fanboys commenting our stories? No way. sub.ed.)
The GDDR5 works at 1050MHz or 4200MHz if you consider that the GDDR5 is quad band and that the card has a 256-bit memory controller. Of course it has a dual slot cooler and of it supports CrossFire. The card also has two six pin power connectors.
The US retail price should land somewhere around 250 USD and we guess that 250 euro should be quite realistic price for EU countries that use this currency. We just got word that the price will be closer to €250, not € / $300 as originally reported.
Launch is on the 22nd October, next Friday and this should be the availability day, at least for a few lucky ones as everything indicates that Radeon HD 6870 might be in short supply.
n°7608609
Neiyro
Posté le 13-10-2010 à 22:01:47  profilanswer
250€ [:gum]
n°7608614
Cizia
Posté le 13-10-2010 à 22:03:00  profilanswer
Ça "fréquence" dur chez ati  :D
Message édité par Cizia le 13-10-2010 à 22:03:21
n°7608620
Invite_Sur​prise
Posté le 13-10-2010 à 22:08:13  profilanswer
Pour la dispo par contre, ça fait plusieurs commentateurs qui annoncent qu'elle ne sera pas mirobolante ...
n°7608621
barbare128
pas de koi se rouler par terre
Posté le 13-10-2010 à 22:09:51  profilanswer
moi au contraire je la trouve poil chéro pour du mdg.
Feed my back : http://forum.hardware.fr/forum2.ph [...] w=0&nojs=0
n°7608624
Neiyro
Posté le 13-10-2010 à 22:10:37  profilanswer
Pour du 900MhZ et plus perfs normalement qu'une 5850 ? Non, c'est pas cher du tout.
n°7608630
Invite_Sur​prise
Posté le 13-10-2010 à 22:14:58  profilanswer
A noter que Monstru du site Lab501 semble avoir reçu les cartes ...
Ahhhh...I am sorry to disapoint you my friend, but that will take a little while, I will have a huge SOC article with all the models, but untill then, lots of work (AMD 6xxx, etc, etc)
n°7608632
paulo-53
Posté le 13-10-2010 à 22:16:20  profilanswer
Partez du principe qu'on trouve des 5850 à 200€ !
Après pour 50€ de plus, ça peut valoir le coup... a voir en fonction des innovations, perfs, etc... :miam:
Feed-back : http://tinyurl.com/kmwycda
n°7608635
Charles K
Posté le 13-10-2010 à 22:18:00  profilanswer
idem, il y en a qui ont oublié qu'il y a 1 ans les 5850 coûtaient 240 € hors promo, et qu'a part la promo du lien de wirmish (qui ne doit pas daté d'il y a longtemps), les 5850 coûtent toujours 240 €
des perfs entre 5850 et 5870 pour 250 € , wait ...  http://forums.civfanatics.com/images/smilies/cwm36.gif
Message édité par Charles K le 13-10-2010 à 22:23:14
n°7608636
Posté le 13-10-2010 à 22:18:06  answer
5750 > 6850
5770 > 6870
Pour moi, cela signifie un changement plus qu'évident de gamme vers le haut ;)
Que ce soit par la nomenclature (sur le chiffre des centaines) ou la proximité des perfs. par rapport à leurs remplaçantes (sur le chiffre des milliers) :jap:
Message édité par Profil supprimé le 13-10-2010 à 22:20:03
Posté le 13-10-2010 à 22:18:06  profilanswer
n°7608637
couillesho​t
Les bouboules et la boubouche
Posté le 13-10-2010 à 22:18:24  profilanswer
ça vient peut être justement de cette fréquence très élevée sur un process moisi de TSMC
:o :o :o
n°7608639
_yakine_
Posté le 13-10-2010 à 22:20:21  profilanswer
 même prix qu'une GTX470, qui est plus perf sous 3Dmayrde 2006 et Vantage  [:lenoun:4]  ?
enfin faut voir avec de vrais bench, mais si plus perf qu'une 470 pour 250 euros, même d'un peu, et surtout meilleure conso, ATi aura sortie une bonne petite carte  [:implosion du tibia]
Message édité par _yakine_ le 13-10-2010 à 22:24:38
Feed-Back: http://forum.hardware.fr/hfr/Achat [...] 4761_1.htm
n°7608642
Posté le 13-10-2010 à 22:21:37  answer
Un peu faible la fréquence de la Ram non?  :??:
n°7608651
Posté le 13-10-2010 à 22:27:28  answer
_yakine_ > je ne sais pas mais tu vas surement pouvoir me dire :jap:
Quel est le prix moyen d'une GTX470 s.t.p. :whistle:?
Merci [:bastinho:2]
n°7608652
Invite_Sur​prise
Posté le 13-10-2010 à 22:29:05  profilanswer
Il semble bien que la HD6870 soit > à la HD5870. Du moins si on en croit, la dénomination après on va vite savoir ...
J'ai l'impression qu'AMD va coller la grille tarifaire de nVidia, en proposant + performant et surtout de façon plus économique. Ensuite, ils vont peut-être lâcher les chevaux niveau watts avec Cayman mais ça restera + raisonnable que chez les verts certainement.
De toute façon, on est proche du bol de sangria comme on dit dans ma région ... [:kokia]
Message édité par Invite_Surprise le 13-10-2010 à 22:29:47
n°7608653
Neiyro
Posté le 13-10-2010 à 22:29:23  profilanswer
Laisses BIERMAN, _yakine_ est un troll/fanboy nVidia fini.
n°7608658
Charles K
Posté le 13-10-2010 à 22:31:52  profilanswer
ouai, j'ai pris en compte que les perfs serait entre 5850 et 5870, si les perfs sont équivalente à la 5870 alors oui le prix est bien
n°7608663
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 13-10-2010 à 22:35:51  profilanswer
Non.
Une puce avec un bus de 256 bit, dont le nombre d'ALUs se situe entre Juniper (128 bit / 800 ALUs) et Cypress (256 bit / 1600 ALUs), ne nécessite pas de mémoire ultra rapide. En fait le ratio bande passante vs nombre d'ALUs de Bart sera bien meilleur que celui des Juniper et des Cypress.
n°7608666
bilbo248
Posté le 13-10-2010 à 22:36:33  profilanswer
Pour 250€ je trouve que çà fait un poil cher aussi..
Rah, c'est plus ce que c'était ati.. :D
Me rappel l'époque ou j'ai acheté ma 4870, aout 2008, 230€..
Photographie |--| Stats BDPV - Photovoltaique
n°7608670
_yakine_
Posté le 13-10-2010 à 22:38:02  profilanswer
le prix moyen, je suis tenté de te dire que je m'en tamponne un peu, on trouve des gtx470 pour 240/250 euros, c'est pas ma faute hein  [:souk] et sans code promo  [:dovakor loves you:5]
Comme le prix de la 5850 trouvé par Wirmish, en dessous de 200 roros, j'ai dis et je dis bravo, rapport prix/ perf miam miam pour cette cg, je suis pas là à dire, non non ça compte pas, c'est pas le prix généralement constaté ça ?!
répondre sur le fond ou fermer sa gentille bouche, merci.
Message édité par _yakine_ le 13-10-2010 à 22:41:41
n°7608676
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 13-10-2010 à 22:39:40  profilanswer
Voici la citation positive du jour:
"I read that AMD ordered more wafer starts for Northern Islands launch than Evergreen launch. I can't remember whether it was twice or three times the number of wafers. Even twice the number of wafer starts for Barts as Cypress would mean 3 times the number of GPUs. This apparently is in addition to Evergreen wafer starts. It appears that, once Barts begins(began) shipping for revenue, Evergreen wafer starts would be(were) shifted to Barts and/or Juniper wafer starts. Best guess is that Cypress wafer start shift to Juniper production resulted in the rumor of 5750/5770 being rebranded 6750/6770. It may be that the reason we are hearing little about Turks is that Turks will be produced at GlobalFoundries and AMD is uncertain about when GlobalFoundries will be ready to ship for revenues. In any case, GlobalFoundries will not be able to begin revenue shipments before February, so if Turks is tied to Global Foundries, AMD will have to be ramping Juniper shipments to take on GTS 450." - dalelaroy
n°7608679
Neiyro
Posté le 13-10-2010 à 22:40:13  profilanswer
Bon t'arrêtes de te la ramener avec tes GTX470 ? Tu casses notre élan là...
n°7608680
Invite_Sur​prise
Posté le 13-10-2010 à 22:40:28  profilanswer
Par contre, ça sent l'embouteillage dans le secteur 200-300€ chez AMD ... Peut-être que les problèmes de dispo aideront à pallier tout ça  [:aurelien_fr]
n°7608682
Posté le 13-10-2010 à 22:41:03  answer
_yakine_ > quel prix de la 470 à sa sortie alors?
Merci ^^
n°7608684
Corleone_6​8
Posté le 13-10-2010 à 22:41:27  profilanswer
Subar a écrit :
Ce qui est marrant chez certains Fanboy ici, c'est que quand il y a renommage chez Nvidia ça crie au scandale est quand c'est AMD bah c'est pas grave...
Les performances stagnent en 1 an !! bah c'est pas grave...
Pour la personne qui parler d'une 307 par rapport à la 308, evidemment que les nouvelles voitures quand bien même plus lourde avance bien plus vite qu'avant.
La vie est une évolution permanente.
Et là, les performances stagnent et tous le monde s'enfou.
Je prends un exemple de renommage chez BOSCH:
Un congélateur GSN40A22 comparer au GSN40A32. On se dit la logique voudrait que la version 32 soit meilleur est bien non le 22 est au dessus du 32. Tout ça pour dire que tous le monde peut se faire avoir avec un marketing tordu.
Ma copine travail à la SNCF et je vous met au défi de trouver un prix unique sur un trajet grande distance. Il y a au moins une dizaine de tarif différent qui fait qu'au final on ne connait plus le vrai prix.
ATI tout comme Nvidia embrouille également les gens que ça vous plaise ou non c'est comme ça et il faut le signaler tout comme chez la concurence.
Maintenant je pense qu'il aurait mieux fallu baisser les prix des 5850/5870 pour tuer la 460/470 plutot que de sortir d'autres cartes.
Tout le monde veut comparer avec la 460 ce qui est normal puisque c'est l'affaire du moment, mais est-ce que quelqu'un ici à penser à comparer avec un sli de 460 qui équivaut grosso modo à une 5970 pour 360/400 euros ??
J'ai hate de voir l'optimisation du crossfire de bart comparer au SLI de 460.
T'es le frère à Stephane910  :??:
Zack38 a écrit :
S'il y a une biGPU... et ça, c'est à mon sens pas gagné, si Bart consomme autant que Cypress.
Ou alors la biGPU sera faite avec deux Cayman bridés.
Et "Antilles", l'aurais tu oublié ?
Même 2 Caïman bridés seront surement (je pense) plus rapide qu'une 5970 vu que la logique voudrait que la mono ce rapproche ou égale la bi-gpu ancienne gen (Mais bon avec le 40 c'est pas gagné)..
Phanteks Enthoo Primo / Seasonic P-860 / Asus Strix B550 E/ Ryzen 5600X WC / 2*16 F4 3600C16 Gskill Ripjaws @3733 / 6900XT Red Devil / Crucial C300 128 Go / Sam 850 Evo 500 Go / Velociraptor 300 Go / Caviar Red 4 To / Caviar Black 1 To
n°7608692
Invite_Sur​prise
Posté le 13-10-2010 à 22:43:51  profilanswer
Qui est donc dalelaroy ? [:ghilghamesh]
Message édité par Invite_Surprise le 13-10-2010 à 22:44:55
n°7608697
_yakine_
Posté le 13-10-2010 à 22:44:20  profilanswer
il est gentil le Bierman  [:churros norris]
alors l'acheteur potentiel va comparer quoi lui ? le prix de la 5870 d'il y a 1 an et celui de la HD6 de novembre ? et bien évidement, il va comparer le prix de la 470 day one et non d'aujourd'hui...
allons[:boxxxy:2]
Message édité par _yakine_ le 13-10-2010 à 22:44:57
n°7608699
Corleone_6​8
Posté le 13-10-2010 à 22:46:02  profilanswer
C'est le Wirmish de là bas ils sont en étroite collaboration :o
n°7608715
Posté le 13-10-2010 à 22:53:17  answer
_yakine_ > OK :jap:
Maintenant on peut parler des gammes (en oubliant le prix, ce n'est pas moi qui en ai parlé)
Donc, dis moi à quoi correspond la nouvelle gamme 6x50 d'AMD?
Merci :d
n°7608723
_yakine_
Posté le 13-10-2010 à 22:55:53  profilanswer
à la HD4x50 quelle question  [:tagazou:2]
n°7608728
Posté le 13-10-2010 à 22:57:43  answer
Bien répondu
Qui taquinera la 480 donc (Topik des GTX 465/470/480) ^^
Merci donc [:haha jap]
n°7608736
hahahafr
Machete don't text
Posté le 13-10-2010 à 22:58:44  profilanswer
J'ai ri.
Feed-back hahahafr Achat/Vente
n°7608738
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 13-10-2010 à 22:59:38  profilanswer
Un nouveau type d'AA -> Morphological Anti-Aliasing
This work introduces an alternative anti-aliasing method offering results whose quality lies between 4x and 8x MSAA at a fraction of its memory and time consumption.
What are the advantages of MLAA over MSAA?
· For similar quality, it is considerably faster, one order of magnitude in the PC case.
· For consoles, where the MSAA sample count is limited due to hardware restrictions, it allows better quality.
· It enables the usage of anti-aliasing in conjunction with Multiple Render Targets, which is specially useful for deferred engines.
· It can provide better quality when HDR is used, as anti-aliasing is performed after tone mapping.
· Anti-aliasing quality can be dynamically adjusted on the fly, depending on the available resources at each frame.
· MLAA is not incompatible with MSAA: this leads to hybrid MSAA-MLAA approaches.
n°7608741
Corleone_6​8
Posté le 13-10-2010 à 22:59:48  profilanswer
[:fuel]
[:power600]
n°7608754
burnout62
Posté le 13-10-2010 à 23:07:10  profilanswer
if((6850 < 5870) && (6850 > 5850)) {
moi =  :??:  :( ;
else { moi =  :love:  }.
Nan sérieux 250€ pour des perfs entre la 5850 et la 5870 bof bof :/ . A voir le reste, mais bon...
n°7608759
Posté le 13-10-2010 à 23:10:18  answer
Tu ne veux pas payer pour de la nouveauté (car pour le moment, on ne connait pas tout, loin de là même sur ces nouvelles cartes), soit
Mais bon, ton argument ne vaut pas grand chose en l'état
Excuse mais je n'ai pas trop envie de développer...
n°7608766
Invite_Sur​prise
Posté le 13-10-2010 à 23:12:54  profilanswer
La vidéo est pas mal ... Merci pour l'info Wirmish [:davidames:4]
n°7608767
Vince@ESIE​E
Posté le 13-10-2010 à 23:13:07  profilanswer
Fiasco....
Un peu plus perf que la 5850..
Et le HDG un peu plus perf que la 5870 ?
Et le HDG Bi gpu  un peu plus perf que la 5970 ?
Bon je sais j'en rajoute à mort, j'espères être agréablement surpris
n°7608770
Corleone_6​8
Posté le 13-10-2010 à 23:13:49  profilanswer
moi =  :??:  :( ;
Bin la 6870 à 250 euros c'est relativement bien, c'est mieu qu'une 5870 plus chère mais certe un petit peu plus perf, mais avec les nouveautés en moin.
Bon à la limite ce segment on s'enfout c'est le rapport perf/prix du HDG qui nous interesse :o
n°7608773
Fouge
Posté le 13-10-2010 à 23:15:50  profilanswer
Ca a l'air trop magique pour être vrai ce MLAA :ouch:
n°7608774
Corleone_6​8
Posté le 13-10-2010 à 23:15:51  profilanswer
Vince@ESIEE a écrit :
Fiasco....
Ha bon tu les a trouvé ou les bench de caïman ça m'interesse... [:canaille]
Message édité par Corleone_68 le 13-10-2010 à 23:18:50
[Topik Unik] Les AMD Radeon™ XFX HD 5870 ─ 587X ● mini BDD ● Sondage ●probleme d'affichage radeon 4870 : affichage surface réduite
[Topic Unique ?] Lian Li PC-8FI : Moyen tour 2010 !! Coming soon !![topic unique] Silverstone SG05 / SG06 / SG07
radeon 3650-3850-4650 agpATI 5750 ou 5770 ?
Probleme ATI HD 5850 POwercolor ati2dvag.dll
Plus de sujets relatifs à : [Topic Unique] AMD Radeon HD 6800 et 6900 ; 40nm dx11
