3549 connectés
 Page :   1  2  3  4  5  ..  699  700  701  ..  712  713  714  715  716  717
Topik Officiel des drivers vidéo nVidia
n°11454486
worm'skill​er
Le roi de la petit côte
Posté le 21-11-2025 à 13:57:37  profilanswer
ce qui est amuisant c'est que sous app nvidia les drivers sont mis comme datant d'avril 2025
"le prix passe, la qualité reste"
n°11456368
Dirty Wing​s
Posté le 04-12-2025 à 15:53:02  profilanswer
591.44 de sortie !!!
https://www.nvidia.com/fr-fr/drivers/results/
3.1.1 Fixed Gaming Bugs
> Battlefield 6: Gaming stability issues
> Counter-Strike 2: Text may appear slightly distorted when in-game resolution is lower
than the native resolution of the display
> Like a Dragon: Infinite Wealth: Light flickering after driver update on some system
configurations
> Like a Dragon Gaiden: The Man Who Erased His Name: Corruption after driver update
on some system configurations
> Black Myth: Wukong: Lower performance in driver branches newer than R570
> Monster Hunter World: Iceborne: Some particle effects may be missing on GeForce
RTX 50 Series GPUs
> Call of Duty: Black Ops 3: Gameplay becomes dim over time
> Madden 26: Stability issues
> Users running R580 branch drivers (58x.xx) or newer may observe lower performance in
some games after updating to Windows 11 October 2025 KB5066835
> The Witcher 3: Wild Hunt: Random corruption on main character's sword corruption
3.1.2 Fixed General Bugs
> Adobe Premiere Pro: Freeze During Export Using Hardware Encoding
> Sophos Home Antivirus: System stability issues
> Green line observed while viewing videos in Chromium browser on GeForce RTX 50
Series GPUs
n°11456376
Umi
Posté le 04-12-2025 à 16:21:31  profilanswer
n°11456393
Dirty Wing​s
Posté le 04-12-2025 à 16:53:11  profilanswer
Merde, j'ai mis le mauvais lien :bounce:
Message édité par Dirty Wings le 04-12-2025 à 16:53:55
n°11456395
Quentin-Be​lgium
Posté le 04-12-2025 à 16:54:14  profilanswer
alors ça dit quoi les perfs ?
n°11456401
tistou77
Geek Inside!!
Posté le 04-12-2025 à 17:05:39  profilanswer
L'ancien control panel fournit avec le driver ne fonctionne plus avec cette version ?
J'ai ce message quand je veux le lancer (menu contextuel et icone dans le systray)
https://i.ibb.co/9QBWjny/Capture.png
n°11456402
Dirty Wing​s
Posté le 04-12-2025 à 17:05:42  profilanswer
Perso, vu que je n'avais remarqué aucune baisse de perfs de mon coté (rtx4090), pour moi ras avec ces pilotes pour le moment.
Tester sous ac rally et where winds meet.
@tistou77 >aucun soucis de mon coté, ça fonctionne (windows 11 25H2).
Message édité par Dirty Wings le 04-12-2025 à 17:08:24
n°11456415
Umi
Posté le 04-12-2025 à 17:45:49  profilanswer
Chez moi (driver installé avec NVCleanstall), il ne se lance même pas...
EDIT: après un reboot ça fonctionne.
Message édité par Umi le 04-12-2025 à 17:50:24
n°11456419
tistou77
Geek Inside!!
Posté le 04-12-2025 à 17:47:47  profilanswer
Ok merci, ça ne vient pas de mon PC alors :D
Une alternative pour désactiver/paramétrer le Shader Cache ?
J'ai essayé avec Nvidia Inspector, mais le répertoire revient à chaque fois, donc les réglages ne sont pas prit en compte je pense
n°11456420
Umi
Posté le 04-12-2025 à 17:50:39  profilanswer
En fait après un reboot ça fonctionne.
Tu as redémarré le PC ?
n°11456421
tistou77
Geek Inside!!
Posté le 04-12-2025 à 17:54:45  profilanswer
Oui j'ai redémarré
Si je ne trouve pas, j'essaierai de réinstaller les drivers
n°11456423
ravenloft
Meilleur jeu du 20ème siècle
Posté le 04-12-2025 à 17:57:05  profilanswer
Chez moi ça fonctionne et sans reboot
Message édité par ravenloft le 04-12-2025 à 17:57:29
Ravenloft
n°11456435
petit-tigr​e
miaou
Posté le 04-12-2025 à 19:30:12  profilanswer
Pour la p'tite info, ces pilotes restaurent l'usage de Physx en HW sur les RTX 50 pour certains jeux compatibles dont les Batman Arkham. Certains du moins, pas tous.
mIaOuUuUuUuUuUu
n°11456451
tistou77
Geek Inside!!
Posté le 04-12-2025 à 21:07:11  profilanswer
En installant les anciens drivers par dessus, le control panel fonctionne...
Puis installation des nouveaux toujours pas dessus, ça fonctionne :pt1cable:
Habituellement, je supprime toujours les anciens avant d'installer les nouveaux, je vais re tester comme cela
n°11456497
Arriock
Posté le 05-12-2025 à 09:28:53  profilanswer
Bonjour, avec le nouveau driver je n'ai plus de problème de scintillement sur mon Dell G2332Q sur les vidéos en pleine écran quand le G-Sync est activé :)
n°11456512
pharmajo
Posté le 05-12-2025 à 10:19:24  profilanswer
Tellement dommage que le physx soit tombé dans l'oubli c'était bluffant.
n°11456522
Midship1
Posté le 05-12-2025 à 11:09:43  profilanswer
Installé ce dernier driver hier.
-Couleur (surtout le rouge) sont devenues flashy
-Apparition de saccades dans FS2024 .
Ces deux defauts avaient disparus depuis quelques mois.......retour à l'ancien pilote et de nouveau impec.
Donc a essayer mais pas génial.
n°11456535
Umi
Posté le 05-12-2025 à 11:53:40  profilanswer
Surtout ne nous précises pas quelle CG tu as  :o
n°11456537
Midship1
Posté le 05-12-2025 à 12:01:43  profilanswer
n°11456538
MazFire
~ Keep Cool ~
Posté le 05-12-2025 à 12:07:30  profilanswer
DDU effectué ?
n°11456540
Midship1
Posté le 05-12-2025 à 12:10:01  profilanswer
Non, mais quand j'ai monté ma tour il y un an j'ai eu le même problème pendant 3/4 mois et puis les derniers pilotes ont arrangé les choses.
n°11456542
Scrabble
Posté le 05-12-2025 à 12:18:18  profilanswer
Surtout ne nous precise pas combien de VRAM elle a  :o
n°11456551
Midship1
Posté le 05-12-2025 à 12:56:18  profilanswer
Ça va changer tout si je vous dis 8 Go.?
Et sans Joker !
Mon dieu quelle amabilité.!
Et surtout quelle humilité.
n°11456554
Umi
Posté le 05-12-2025 à 13:00:30  profilanswer
Sinon tu remplis ta config, comme ça on saura :o
n°11456558
petit-tigr​e
miaou
Posté le 05-12-2025 à 13:20:16  profilanswer
Oui, les Batman en étaient de bonnes démos. T'avais plein de détails rajoutés, tu revenais difficilement en arrière.
mIaOuUuUuUuUuUu
n°11456560
DiB91
Bwaaaaaaah
Posté le 05-12-2025 à 13:23:45  profilanswer
Après, me faisant l'avocat du diable, y a-t'il vraiment un besoin ?
N'y a-t'il pas de technologie à minima équivalente que les moteurs modernes ne puissent gérer nativement, dans le GPU ou, au pire, sur le CPU ?
Quand je me remémore des démos de l'époque (ie : les maps "promo" pour Unreal Tournament 3 qui ajoutaient des effets de météo et de déformation uniquement disponibles sur GPU ou carte additionnelle compatible PhysX), il ne me semble pas que ce soit des trucs qu'AMD ou nVidia ne puissent gérer nativement (tessellation, shaders, bump mapping...)
Message édité par DiB91 le 05-12-2025 à 13:26:08
Rehost | Collect | Link
n°11456567
Le Profana​teur
Passéiste désincarné
Posté le 05-12-2025 à 13:36:33  profilanswer
À l'époque c'était évidemment gérable en natif par l'unique CG. Mais c'était un gouffre niveau performance, d'où la nécessité d'avoir une carte esclave juste pour ça.
n°11456641
ravenloft
Posté le 05-12-2025 à 17:40:21  profilanswer
Mon premier bug depuis longtemps avec les drivers nvidia qui sont apparus sur les derniers. Quand l'écran revient de veille, l'écran se met à flasher de manière récurrente. Obligé de redémarrer pour que le bug disparaisse.
Ravenloft
n°11456643
ravenloft
Posté le 05-12-2025 à 17:44:12  profilanswer
Si tu regardes tous les jeux modernes, aucun ne gère les effets aussi importants qu'on pouvait avoir dans le premier mirror's edge.
C'est sans doute possible avec les cpus modernes mais encore faut-il avoir des moteurs capables et visiblement ça n'existe pas ou alors c'est pas utilisé.
Les consoles limitent surtout avec leur puissance cpu limitée
Ravenloft
n°11456667
DiB91
Bwaaaaaaah
Posté le 05-12-2025 à 18:54:06  profilanswer
Ah je savais pas pour Mirror’s Edge. J'avais lu qu'il était porte étendard de la tesselation d’AMD, mais je savais pas qu'il utilisait PhysX !! J'ai hâte de relancer ça  :love:  :love:
Par contre oui je te suis totalement dans ton constat, le plus frappant étant évidemment le downgrade technique entre FarCry 2 et FarCry 3 ...
n°11456671
petit-tigr​e
miaou
Posté le 05-12-2025 à 18:59:40  profilanswer
Dans Batman, les mouvements de cape dissipaient la brume par exemple. C'était bluffant pour l'époque.
Dans Mafia 2, les douilles et trous dans le décor rendaient comme aucun jeu auparavant. C'était vraiment sympa. Des p'tits détails qui mis bout à bout renforçaient l'immersion visuelle.
mIaOuUuUuUuUuUu
n°11456674
DiB91
Bwaaaaaaah
Posté le 05-12-2025 à 19:05:23  profilanswer
:love:
Ca me rappelle des frissons de la bonne époque 3DFx ça !
Le jeu des 7 différences... qui faisaient toute la différence :love:
n°11456680
tistou77
Geek Inside!!
Posté le 05-12-2025 à 19:52:16  profilanswer
Bon un coup de DDU et installe des nouveaux et c'est tout bon :)
n°11456689
Midship1
Posté le 05-12-2025 à 20:37:32  profilanswer
DDU c'est un désinstallateur?
J'ai Revo Pro ça peur le faire aussi?
Merci.
n°11456693
tistou77
Geek Inside!!
Posté le 05-12-2025 à 20:42:32  profilanswer
Merci.
https://www.guru3d.com/download/dis [...] -download/
n°11456707
ravenloft
Posté le 05-12-2025 à 21:22:17  profilanswer
Il n'y avait pas de tesselation pour mirror's edge donc tu dois confondre avec un autre jeu.
Ravenloft
n°11456742
DiB91
Bwaaaaaaah
Posté le 06-12-2025 à 07:40:07  profilanswer
Très certainement :jap:
n°11456811
bjone
Insert booze to continue
Posté le 06-12-2025 à 15:32:34  profilanswer
Mirror's Edge c'est plus les tissus (cloth) de PhysX. (Accélérable par la carte PCIe à l'époque)
https://www.youtube.com/watch?v=HH93CXpMei4
Message édité par bjone le 06-12-2025 à 15:33:48
n°11456813
Le Profana​teur
Posté le 06-12-2025 à 15:40:02  profilanswer
Et pas que les tissus :d
https://www.youtube.com/watch?v=q8DaIyj4RS8
Bizarre, cela ne m'a pas marqué en son temps contrairement aux Batman Asylum/city par exemple [:gratgrat]
n°11456814
Umi
Posté le 06-12-2025 à 16:05:09  profilanswer
Et si ça ne marche pas ou mal avec les drivers modernes (c'est un jeu de 2008 pour rappel), il y a des solutions:
https://steamcommunity.com/app/1741 [...] 976080324/
Message édité par Umi le 06-12-2025 à 16:09:14
C'est quoi léquivalent dune ATI 9600XT en NVIDIA ?Upgrade d'un PIII 550 pour montage vidéo ??
Problème de sortie vidéo en lecture DivXchanger le ventilo de carte video
Regarder une video sur sa tv...ventilateur carte video gfx malade
Carte uATX avec bonne sortie s-video ?probleme divx video duplicator pro
Deux cartes vidéo installéesrecherche drivers
Plus de sujets relatifs à : Topik Officiel des drivers vidéo nVidia
