2255 connectés
 Page :   1  2  3  4  5  ..  682  683  684  ..  712  713  714  715  716  717
Topik Officiel des drivers vidéo nVidia
n°11381840
Dirty Wing​s
Posté le 23-12-2024 à 15:04:23  profilanswer
Merci pour l'info :jap:
n°11381864
Umi
Posté le 23-12-2024 à 15:40:12  profilanswer
Il y a une version de test de NVCleanstall pour le problème de compatibilité avec nvapp : https://www.techpowerup.com/forums/ [...] pp.330079/
n°11398541
ravenloft
Meilleur jeu du 20ème siècle
Posté le 30-01-2025 à 16:09:00  profilanswer
nouveaux drivers 572.16
https://videocardz.com/driver/nvidi [...] ady-572-16
Gaming Technology
    Game Ready for GeForce RTX 5090, GeForce RTX 5080, and DLSS 4
    List of supported DLSS 4 titles at launch above
    NVIDIA Smooth Motion
    RTX Video Super Resolution optimizations and enhancements, new multiple display settings, Advanced Optimus support, DLSS 4 support
Fixed Gaming Bugs
    Certain G-SYNC Compatible monitors may display flickering when game FPS drops below 60 FPS
    Indiana Jones and the Great Circle may display micro-stutters when Vertical Sync is disabled
    Improved stability for Ubisoft games using the Snowdrop engine
Fixed General Bugs
    [Evernote/QQ/ASUS Armoury Crate] displays higher than normal CPU usage
    Motion blur renders incorrectly in some more cases in Blender Cycles
    [KeyShot2024] TDR on loading the scene Camera Keyframe Animation
Open Issues Discovered
    Changing state of "Display GPU Activity Icon in Notification Area" does not take effect until PC is rebooted
    Unexpected Low Performance on CUDA Vpath Tests for Blackwell GPUs
A new driver-based AI model delivers smoother gameplay by inferring an additional frame between two rendered frames on GeForce RTX 50 Series GPUs
Game Ready
    Kingdom Come: Deliverance II
    Marvel's Spider-Man 2
G-Sync Monitors
    Alienware AW2725Q
    AOC 24G40E
    AOC 25G4S
    AOC Q27G40E
    AOC Q27G4S
    AOC Q27G4ZD
    ASUS VG27UQ1A
    HP OMEN 32x
    I-O Data GD242UD
    LG 27G850A G
    LG 27GX790A
    MSI MAG321CUP
    MSI MPG272UX OLED
    MSI MPG321UX
    MSI MPG321CURX
    MSI MPG322URX
    MSI MPG341CX
    MSI MPG491CQPX
    Philips 27M2N6500
GFE / NVApp Optimal Settings
    DYNASTY WARRIORS: ORIGINS
    Indiana Jones And The Great Circle
    Marvel Rivals
    Path of Exile 2
    SUPERVIVE
Message édité par ravenloft le 30-01-2025 à 16:15:39
Ravenloft
n°11398736
Umi
Posté le 30-01-2025 à 17:05:14  profilanswer
NVCleanstall v1.18.0
v1.18.0 (January 28th, 2025)
    Fixed compatibility with 566.36 and newer
    Added full support for NVIDIA App
https://www.techpowerup.com/downloa [...] leanstall/
n°11398783
coil whine
Renvoie-là au SAV
Posté le 30-01-2025 à 17:33:05  profilanswer
Je n’ai pas trouvé le dlss 4 dans l’app nvidia du nouveau driver. Et vous ?
n°11398792
coil whine
Renvoie-là au SAV
Posté le 30-01-2025 à 17:37:19  profilanswer
En fait ça dépend des jeux. J’ai bien l’option (non changeable) dans cyberpunk, mais pas dans d’autres jeux …
Message édité par coil whine le 30-01-2025 à 17:37:27
n°11398803
erash
Posté le 30-01-2025 à 17:46:40  profilanswer
Mais c'est normal ça non ?
Il faut que le jeu intègre le DLSS 4, ou remplacer la dll dans le répertoire du jeu (via dlssswapper pour plus de simplicité et uniquement si ça supporte le DLSS 3 minimum), sinon aucune raison que ce soit pris en charge de base.
n°11398809
killen
Married Mad
Posté le 30-01-2025 à 17:52:43  profilanswer
Faut savoir, ils disaient qu'on pourrait forcer les jeux DLSS 3.5 à passer en DLSS 4 via nvidia app
n°11398813
coil whine
Renvoie-là au SAV
Posté le 30-01-2025 à 17:53:45  profilanswer
J’avais pas compris ça.
n°11398819
Darkneo95
Posté le 30-01-2025 à 17:58:57  profilanswer
Après avoir mis à jour l'app nvidia ça m'a dit que en allant dans les paramètres globaux du pilote on pouvait forcer le passage en dlss4, mais il n'y a pas l'option.
n°11398832
AnthonyD
»»───(knee)───►
Posté le 30-01-2025 à 18:06:57  profilanswer
Je suis plutôt chaud pour reflex v2 que dlss4 et sa lantence de fou  :D
n°11398870
kenshirooo
Posté le 30-01-2025 à 18:43:56  profilanswer
n°11398897
olioops
Si jeune et déjà mabuse.
Posté le 30-01-2025 à 19:18:39  profilanswer
Le DLSS4 ne provoque pas de latence. Tu confonds avec le FG.
Ne pas confondre gisement épuisé et mine de rien !
n°11398898
petit-tigr​e
miaou
Posté le 30-01-2025 à 19:19:37  profilanswer
Normalement, t'as une option d'override dans le pilote.
https://www.nvidia.com/en-us/geforc [...] -and-more/
Adds DLSS overrides to 75 games and applications
mIaOuUuUuUuUuUu
n°11398899
coil whine
Renvoie-là au SAV
Posté le 30-01-2025 à 19:23:05  profilanswer
Ah oui donc c’est pas n’importe quel jeu dlss. C’était trop beau.
n°11398901
olioops
Posté le 30-01-2025 à 19:24:35  profilanswer
Graphisme/nom du jeu/onglet paramètres du programme/paramètres de pilote/remplacement DLSS.
Le nouveau DLAA est excellent.
Message édité par olioops le 30-01-2025 à 19:31:47
n°11398916
Darkneo95
Posté le 30-01-2025 à 19:40:07  profilanswer
Oui et ça me dit non pris en charge sur une 4080. Il fait une série 5000 ?
n°11398920
erash
Posté le 30-01-2025 à 19:43:00  profilanswer
Ce qui doit revenir à ce que fait dlssswapper, mais c'est cool de l'intégrer.
n°11398927
killen
Married Mad
Posté le 30-01-2025 à 19:52:25  profilanswer
Avec 75% de trucs inconnus..
n°11398930
erash
Posté le 30-01-2025 à 19:57:12  profilanswer
Par contre, ça ne force que le frame gen, pas l'upscaling ?
De ce que je vois dans Nvidia App, ca ne parle que de la génération d'image.
n°11398934
petit-tigr​e
miaou
Posté le 30-01-2025 à 20:01:02  profilanswer
Je ne peux pas te dire. J'attends un ou deux pilotes avant de mettre à jour moi. Le beta test, c'est pas mon truc.
mIaOuUuUuUuUuUu
n°11398944
Eliquis
Posté le 30-01-2025 à 20:16:37  profilanswer
Non ! seul le multiframe gen est pour la série 5xxx
le reste se réparti ainsi...
https://www.nvidia.com/content/dam/en-zz/Solutions/geforce/news/dlss4-multi-frame-generation-ai-innovations/nvidia-dlss-4-feature-chart-breakdown.jpg
n°11398948
Eliquis
Posté le 30-01-2025 à 20:22:32  profilanswer
Je teste tous mes jeux actuels ( pour aider ceux qui ont peur de leur ombre  :D ) c'est vraiment du tout bon. Après il faut aussi des màj de jeux pour que l'intégration soit maximum. Hogwarts Legacy vient de recevoir la sienne, c'est vraiment beau et fin maintenant en DLSS qualité ultra et plutôt fluide ... je continue mes test [:akilae]
Message édité par Eliquis le 30-01-2025 à 20:22:57
n°11398958
ravenloft
Posté le 30-01-2025 à 20:32:21  profilanswer
C'est pour éviter que quelqu'un active dans un jeu multi et active les anti cheat et que ça gueule contre nvidia. Ils veulent éviter de se prendre la classique shitstorm d'internet.
Nvidia va étendre la liste une fois qu'ils auront testé que ça fonctionne.
Comme il y a plus de 600 jeux utilisant le dlss 2 et +, ça va prendre du temps.
Si tu veux forcer pour des jeux que l'app nvidia ne prend pas en compte, faut passer par les outils de la communauté ou le faire manuellement
Message édité par ravenloft le 30-01-2025 à 20:32:58
Ravenloft
n°11398962
coil whine
Renvoie-là au SAV
Posté le 30-01-2025 à 20:36:33  profilanswer
Oui je me doutais bien que les truc anti triche allait poser problème.
n°11398969
AnthonyD
»»───(knee)───►
Posté le 30-01-2025 à 20:44:22  profilanswer
Heu, c'est pas du multi frame gen dlss4 ?  [:tinostar]
n°11398974
ravenloft
Posté le 30-01-2025 à 20:49:22  profilanswer
Par contre, j'ai un soucis, j'ai nfs unbound et une 2060 mais dans nvidia app, réécrire le dlss est grisé alors que normalement ça devrait ne pas l'être vu que le jeu est supporté day one. Bizarre.
Ou alors faut mettre le dernier driver à jour ?
Ravenloft
n°11398975
ravenloft
Posté le 30-01-2025 à 20:50:09  profilanswer
le dlss 4 c'est le dlss tnn, le dlss FG tnn, le dlss ray reconstruction tnn et le dlss frame gen.
Ravenloft
n°11398976
coil whine
Renvoie-là au SAV
Posté le 30-01-2025 à 20:50:24  profilanswer
Ah bah oui, un driver est sorti aujourd’hui.
n°11398977
olioops
Posté le 30-01-2025 à 20:50:59  profilanswer
Tu mélanges un peu, relis ta phrase. Le DLSS4 propose un ensemble de fonctionnalités, le FG est une option désactivable et c'est lui et lui seul qui accentue la latence ( c'est normal puisque c'est une ou plusieurs frame sans interaction possible avec les commandes utilisateurs ), dire que le DLSS4 ( générique ) provoque de la latence est inexact  :) .
Edit : grilled  :o
Message édité par olioops le 30-01-2025 à 20:57:16
n°11398985
ravenloft
Posté le 30-01-2025 à 21:04:32  profilanswer
Je pensais pas que mettre à jour le driver était nécessaire pour pouvoir réécrire le dlss qui vient d'une mise à jour de nvidia app mais oui c'est nécessaire. J'ai installé le dernier driver et maintenant je peux changer le dlss.
Ravenloft
n°11398988
Le Profana​teur
Passéiste désincarné
Posté le 30-01-2025 à 21:06:16  profilanswer
À tes souhaits  :wahoo:
Message édité par Le Profanateur le 30-01-2025 à 21:06:45
n°11398989
coil whine
Renvoie-là au SAV
Posté le 30-01-2025 à 21:06:20  profilanswer
D’ailleurs on peut tester le dlss4 dans 3dmark. Une maj est sortie.
n°11399069
kenshirooo
Posté le 30-01-2025 à 23:55:48  profilanswer
Tiens j'ai eu un truc chelou sur Veilguard ce soir depuis les derniers drivers. En DLSS Quality, réso 4K, FG actif j'ai mon GPU qui se tourne les pousse, souvent à 60/70% et le frame rate qui n'est pas au taquet de mon écran (lock à 117), il est souvent dans les 80/90.
Je n'ai ce comportement qu'en FG, en DLSS seul le GPU passe à 99%. Etrange. Je ne suis évidemment pas CPU limited (25% max)... je ne capte pas. Je n'avais pas ce comportement avant les nouveaux drivers.
Ca me le fait quelque soit la version du DLSS (J,K...)  que je choisis dans l'app nvidia.
n°11399073
AnthonyD
»»───(knee)───►
Posté le 31-01-2025 à 00:10:46  profilanswer
DLSS off : 50.23 FPS
DLSS On : 162.14 FPS
DLSS version DLSS 4
DLSS output resolution 2560 x 1440
Super resolution Performance
Frame generation 2x
Ca va :o
n°11399132
DiB91
Bwaaaaaaah
Posté le 31-01-2025 à 08:52:28  profilanswer
Dire qu'il y a 20 ans, on aurait jeté au feu ces techniques de filou pour gratter des FPS sans effort :love:
Rehost | Collect | Link
n°11399292
MazFire
~ Keep Cool ~
Posté le 31-01-2025 à 11:15:42  profilanswer
Aujourd'hui, on nous vend des technologies avant de nous vendre du nouveau matériel...
n°11399342
Eliquis
Posté le 31-01-2025 à 12:00:20  profilanswer
Du moment que ça fonctionne :o
Indiana Jones et le cercle ancien avec le nouveau DLAA [:omar cheifrai:6] j'étais pas prêt !!!
Message édité par Eliquis le 31-01-2025 à 12:06:02
Levez la tête...
n°11399364
kenshirooo
Posté le 31-01-2025 à 12:23:36  profilanswer
Des gens qui jouent à AW2 depuis la màj de drivers et la dernières maj du jeu? Pas de soucis de craash de votre côté?
Je n'en avais aucun avant et depuis les updates le jeu crash régulièrement (GPU error), j'ai un léger undervolt mais il n'a jamais posé aucun soucis... J'ai tenté sans et j'ai aussi eu un crash...
DLSS4 Balanced et FG2X sur 4080.
n°11399406
kenshirooo
Posté le 31-01-2025 à 13:13:48  profilanswer
Ce problème est complètement résolu avec une réinstall du drivers nvidia après un passage de DDU. Par contre le soucis sur AW2 subsiste... Il semblerait que ce soit le DLSS4 + FG sur les series 4XXX. Bcp de crashs référencés sur reddit.
n°11399411
petit-tigr​e
miaou
Posté le 31-01-2025 à 13:26:39  profilanswer
Merci. Voilà pourquoi je patiente tranquillement avant de m'y mettre :D
mIaOuUuUuUuUuUu
C'est quoi léquivalent dune ATI 9600XT en NVIDIA ?Upgrade d'un PIII 550 pour montage vidéo ??
Problème de sortie vidéo en lecture DivXchanger le ventilo de carte video
Regarder une video sur sa tv...ventilateur carte video gfx malade
Carte uATX avec bonne sortie s-video ?probleme divx video duplicator pro
Deux cartes vidéo installéesrecherche drivers
Plus de sujets relatifs à : Topik Officiel des drivers vidéo nVidia
