3651 connectés
Quelle carte prendrez-vous ?
 Page :   1  2  3  4  5  ..  308  309  310  ..  820  821  822  823  824  825
[Topic Unique] ATI Radeon HD 5800 et 5900 Series (RV870 inside)
n°7137892
bubub
Posté le 28-09-2009 à 15:19:16  profilanswer
Sapphire 5870 reçu , montage en cours :)
n°7137898
vanhoenack​er
Posté le 28-09-2009 à 15:21:04  profilanswer
je cite la 260 en exemple car c'est ce qu'a grandEST, la comparaison lui parlera sans doute plus  :jap:
bubub : photos, benchs, OC, WC, Vmod enfin tout quoi  :D
et dans 10 minutes s'il te plait  :jap:
Message édité par vanhoenacker le 28-09-2009 à 15:22:40
n°7137900
Posté le 28-09-2009 à 15:21:33  answer
Personal review d'ici demain? [:mister_k]
n°7137904
asmomo
Posté le 28-09-2009 à 15:24:07  profilanswer
ldre@mer a écrit :
pour le moment je tourne avec la maj 1.1 de batman
sinon pour le tuto rapide:
Just a recap of everything I did to get the ati card to render graphics and the nvidia card to do the gpu accelerated physx.
This is done on Windows 7 RTM build 7600
1. Have the ati card installed in the pci-e slot 1 and the nvidia card in the pci-e slot 2.
2. Have the vga, dvi or hdmi cable plugged into the ati card to the monitor, have no cord plugged into the nvidia card, it just needs to be in the slot.
3. Install the 185.68 drivers and update to the latest standalone physx driver, http://www.nvidia.com/object/physx_9.09.0814.html
4. RESTART
5. Go into screen resolution and under multiple displays click extend display's, set the nvidia card to vga device, it will still work even though it's not plugged into the monitor. Then drag the #2 display to the bottom right corner of display #1, this way you won't be dragging programs off the screen to another screen that's not really there. LOOK AT THE PICTURES.
6. Then right click on the desktop, click nvidia control panel, then simply enable physx.
7. Download and run fluidmark to see if it's working.
8. Enjoy your physx games. All physx games I tested worked fine except mirror's edge which you have to download the physx performance patch which a guy made on youtube. Just extract the contents to the mirror's edge binary folder. http://rapidshare.com/files/244473 [...] _PhysX.rar
ps important: fonctionne uniquement avec Xp et seven
à noter que j'utilise CUDA pour SETI, et que dans ce cadre je vais sur des forums de gens qui font comme moi (notamment pour avoir des applications optimisées). Il y a des fous qui ont des CG juste pour cet usage, genre ils mettent une 295 dans le PC du bureau, en carte secondaire, en laissant la merde d'origine pour l'écran (comme ça ils perdent pas la moindre miette de puissance pour afficher le bureau ^^). Et ben ça pose des pb pour CUDA, ils doivent mettre un faux câble vidéo sur la carte (un câble coupé et bidouillé) sinon ça ne marche pas. Je me demande si ça ne vient pas des drivers.
n°7137909
asmomo
Posté le 28-09-2009 à 15:31:39  profilanswer
80€ une 4870 1Go ?
n°7137916
M3tatek
Teuf toujours tu m'interesses
Posté le 28-09-2009 à 15:35:51  profilanswer
bubblegum a écrit :
Quels sont les boitiers, pas trop cher et assez bien foutu qui ferait rentrer la carte ?
Actuellement j'ai une Antec 3700BQE
http://img25.imageshack.us/img25/6549/antec.jpg
n°7137918
Modération
Posté le 28-09-2009 à 15:37:56  answer
trajouf a écrit :
Dans le cul!
 [:carambar eloustic]
n°7137920
lenoun
ho macumba... macumba...
Posté le 28-09-2009 à 15:38:37  profilanswer
sachant qu'en faisant une petite manip le big boy se met facilement complètement à l'exterieur laissant la place au Noctua (normalement ! :D)
Voir ici
n°7137946
asmomo
Posté le 28-09-2009 à 16:00:28  profilanswer
Activation a écrit :
petite question
au vu de ce qui est annoncé en conso pour la HD5850 ça tiend avec 1 seul connecteur 6pins
alors pourquoi les photos qu on voit en on 2 ?
c est de l incitation à pas acheter de HD5870 ou le design n a rien à voir avec les photos qu on voit
(n empeche 1 seul connecteur sur le coté plutot que 2 à l arriere ça aurait plus à qqs uns à mon avis)
Bah pour l'OC c'est pitêtre mieux.
Et puis c'est pour pas se mettre les fabricants d'alim' à dos :d
n°7137951
bubub
Posté le 28-09-2009 à 16:02:58  profilanswer
lol!
Bon montage nickel ,j'ai un nine ,elle passe sans prob! :)
Le bruit ,rien a dire elle est silencieuse ,disons que je l'entend pas plus que ma 4870 avec un musachi! donc niveau bruit ça me va impec!
je viens de tester NFS shift ,j'ai gagné facile entre 20 et 30fps ,allez j'y retourne ,je vais tester GTA 4 ;)
n°7137952
dragonor1
Posté le 28-09-2009 à 16:03:01  profilanswer
entre une
---4870 512mo  95/99euros
---4890 1go      149euros ( peu etre bientot 130?)
et une 5850 à 250 ou une 5870 350euros
mon choix est trés vite fait
sa sera  48xx  :love:
n°7137957
Marc
Chasseur de joce & sly
Posté le 28-09-2009 à 16:05:02  profilanswer
petite question
Un 6 broches = 75W.
La 5870 tire jusqu'à 130W sur les 2 6 broches (sous Fur), donc non, ca ne marche pas avec un seul sur la 5850 non plus.
Message édité par Marc le 28-09-2009 à 16:05:29
n°7137959
asmomo
Posté le 28-09-2009 à 16:06:01  profilanswer
Très intéressant comme message dragonor1...
Message édité par asmomo le 28-09-2009 à 16:06:29
n°7137960
asmomo
Posté le 28-09-2009 à 16:07:11  profilanswer
Marc a écrit :
Un 6 broches = 75W.
Il y a aussi 75W par le port PCIe, non ?
n°7137964
Marc
Posté le 28-09-2009 à 16:09:03  profilanswer
En théorie oui en pratique les CG tirent rarement autant sur ce port
Message édité par Marc le 28-09-2009 à 16:10:18
n°7137967
dragonor1
Posté le 28-09-2009 à 16:11:46  profilanswer
j'attend des retours d'utilisateur  / baisse de prix des dite 5850 et 5870
et surtout leur dispo en vrai ( parce que le launch  22septembre et la dispo 1mois apres )  pour craké :o
Message édité par dragonor1 le 28-09-2009 à 16:12:14
n°7137972
code34
Posté le 28-09-2009 à 16:14:24  profilanswer
bubub a écrit :
lol!
tu peux en dire un peu plus ?  :lol:  fais une video youtube :p
Canon 30D + 17-40 mn 4 L :p
n°7137976
bubblegum
Posté le 28-09-2009 à 16:18:03  profilanswer
La carte ne fait elle pas 28cm ? donc exit le p183 ?
Et sinon dans les 70€ il y a quoi  :whistle:
n°7137980
kangoorico
Posté le 28-09-2009 à 16:21:29  profilanswer
tu vire la cage de DD superieure et ca rentre largement  :bounce:
n°7137981
bubblegum
Posté le 28-09-2009 à 16:22:28  profilanswer
Ok pour l'astuce.
Et pour un boitier bien moins cher ?
n°7137982
dll_75
Posté le 28-09-2009 à 16:22:48  profilanswer
y'a t-il un heureux nouveau propriétaire de 5870 qui peut nous donner la longueur exacte de la carte?
n°7137984
asmomo
Posté le 28-09-2009 à 16:23:26  profilanswer
Ah bon, je croyais que t'avais commandé une 4870 512Mo ?
n°7137990
LAs3R
Posté le 28-09-2009 à 16:29:18  profilanswer
drapal
n°7137994
Yoyo_5
Posté le 28-09-2009 à 16:31:55  profilanswer
bubub a écrit :
lol!
J'attends ton retour dur GTA IV. :jap:
Tu pourras essayer d'active l'AA SuperSampling dans les pilotes pour voir si avec GTA IV ça fonctionne sans trop ramer ? :D
¤ Paix et félicité ¤
n°7138013
bubub
Posté le 28-09-2009 à 16:49:38  profilanswer
ça tourne bien ,même très bien ,je suis assez surpris ,je pensez pas gagner sur GTA 4 ,j'essaye avec l'aa.
n°7138016
code34
Posté le 28-09-2009 à 16:51:42  profilanswer
qu'est ce que t'en penses au niveau du bruit ? :D
n°7138017
asmomo
Posté le 28-09-2009 à 16:53:25  profilanswer
boblemagnifique a écrit :
Il faudra etre patient , ca m'etonnerai que  ATI fasse une grosse serie sur ce modele la (qui est plus un modele de démonstration pour montrer le savoir de chez ATI) que d'un modele de vente comme les 5850/5870/5870x2 classique :jap:
Surtout que même pour un bourrin qui veut afficher sur 6 écrans, 2 5870 en xfire devraient faire l'affaire (et la puissance ne serait pas de trop). à condition que les drivers permettent d'utiliser toutes les sorties bien sûr.
Perso j'avoue que je vois pas trop l'intérêt d'une image avec des barres au milieu (pour le tri-screen c'est différent, on a un écran central et 2 écrans bonus).
Au fait les testeurs, personne n'a essayé avec des écrans latéraux de résolution différente de l'écran central, ou c'est marqué de pas le faire de toute façon ?
Je pense notamment aux heureux possesseurs d'une configuration 30" central, 20" 4/3 latéraux en portrait.
marllt2 a écrit :
Et quelle est l'explication ?  :??:
Parce que sur le papier elle devrait être au minimum au niveau d'une 4870 X2.
Est-ce dû à la BP, qui a été plutôt calibrée pour les futurs jeux DX11 ? Même si le cas 4770 fait penser le contraire ?
Pê que plus on calcule d'images, plus on a besoin de BP mémoire par image. Ou peut-être que les latences deviennent un goulot.
@chewie a écrit :
oui mais non :o
Ce genre de graph ne doit pas etre lu seul. Une carte dix fois moins cher mais 9 fois moins performante sera donc plus intéressante selon ce calcul. Mais vu qu'aucun jeux ne sera jouable, ca ne tient pas la route.
Faudrait que si la moyenne de fps est < à 30 fps( ou plus, c'est le genre de débat qui peut durer 20 ans) la carte n'apparaisse pas dans le graph.
Clair, il faudrait un graph dynamique pour pouvoir filtrer. Aussi, il faudrait des filtres sur ces résolutions, une grosse carte on met l'aniso et l'AA (enfin l'aniso on le met toujours, et même l'AA dur de s'en passer je trouve).
dragonlore a écrit :
justement les arrondis vraiment rond, c'est au contraire une grosse différence et amélioration. La tesselation va justement enfin arrêter le phénomène des arêtes qu'on se tape depuis le début de la 3d, la faut au manque de polygones.
Genre une stargate (pas forcément dans un jeu éponyme, mais tous ceux qui utilisent ce genre de choses) anguleuse, ou une planète anguleuse, c'est sûr que c'est la lose. M'enfin pour moi c'est plus une question de volonté des game designers que les jeux tournent sur du mdg, qu'un réel manque d'une fonction, qui empêchait d'avoir du vrai rond. L'intérêt de la tesselisation, je suppose, c'est que si t'as une ptite carte tu l'as pas et basta, les designers n'ont donc pas à se compliquer la vie.
Vous montriez des images de quake 3, mais j'ai aussi souvenir d'une Porsche de 100 000 polygones il y a des années, comme exemple de ce que la prochaine carte de la mort allait permettre (et qu'on n'a jamais vu en jeu).
Kurchak a écrit :
Ah ouais j'avais pas pensé au multi screen...
Mais bon comme je continue d'essayer d'évaluer ce qui est évaluable pour une personne normale...
Donc je compare un mono GPU à un mono GPU, et non a un bi GPU, de même le crossfire c'est bien mais ca apporte pas tant que ca...
et je pense mono écran.
Après c'est jsute que vous êtes tous des hardcore gamers, donc des mecs pas normaux cqfd :-p
Vivement Janvier Février et un taf pour pouvoir changer ma config et faire peter une 5850 sur un 24, ca devrait être suffisant
le commun des mortels
Une "personne normale" n'a même pas entendu parler de la 5870, en général si elle connait le mot geforce c'est déjà beau.
Message édité par asmomo le 28-09-2009 à 16:56:10
n°7138020
Mekky76
Posté le 28-09-2009 à 16:55:48  profilanswer
prenons quelques instants de réflexion, disons nous que dans le futur la HD 5870 sera vendue 90 euros, sera obsolète, et que les gens baveront sur la HD 6870, c'est une méthode éfficace contre l'achat impulsif ! *pas acheter, pas acheter ! je suis dans le futur !*  :lol:  :lol:
n°7138025
bubub
Posté le 28-09-2009 à 17:02:54  profilanswer
impec , c'est la plus silencieuse que j'ai eu de cartes , et j'en ai eu :D
yoyo >> ça marche pas l'aa sous gta?
n°7138035
Mekky76
Posté le 28-09-2009 à 17:13:12  profilanswer
la 5850 OC capable de battre la 5870  :ouch:  :ouch:  :ouch:
n°7138043
Zenus
Posté le 28-09-2009 à 17:19:54  profilanswer
Je trouve ça inquiétant qu'on ai toujours pas vu de 'vrai' test de la 5850 (pas celui de techpowerup.com).
Je pense que sur certains jeux directX 9&10, la 5850 approche de trop près les perfs de la 4890 (Anno1404, fallout3 : qui m'interressent particulièrement)
Les perfs ne doivent vraiment décollé qu'à partir de directX11 et sur une poignée de jeux ou la 4890 est insuffisante (Far Cry 2, Clear Sky).
Sur d'autre jeux les perfs se détache de la 4890 mais ce sont des jeux à presque 100img/s ou la 4890 suffit amplement.
Du coup dans le doute et j'ai commandé une 4890 moins chère pour attendre une carte super top à 250€ (5850 super OC, 5870 2 go, 5890, GT300).
n°7138045
dll_75
Posté le 28-09-2009 à 17:20:31  profilanswer
bubub, tu peux la mesurer (longueur en cm) STP ?
Message édité par dll_75 le 28-09-2009 à 17:21:42
n°7138052
Fouge
Posté le 28-09-2009 à 17:23:09  profilanswer
Pas d'AA dans GTA4.
n°7138053
starduck
Posté le 28-09-2009 à 17:24:12  profilanswer
 :lol:  :whistle:
n°7138055
asmomo
Posté le 28-09-2009 à 17:24:38  profilanswer
jeanjean15 a écrit :
Oui , surtout que cela évite d'acheter une carte son spécialisée qui coute de 120 à 220 euros .  :)
Je crois pas que la carte son soit vraiment le point limitant quand tu veux entendre du master audio. C'est plutôt l'install sonore à 5000€, le projecteur à 5000€ et la salle dédiée de 30m² dans ta baraque  :whistle:
n°7138057
mic_12
Posté le 28-09-2009 à 17:25:31  profilanswer
hem hem :whistle:
Message édité par mic_12 le 28-09-2009 à 17:26:07
Site photo
n°7138059
Posté le 28-09-2009 à 17:27:50  answer
T'habites à combien de kilomètres? [:ycar:1]
n°7138066
Yoyo_5
Posté le 28-09-2009 à 17:35:20  profilanswer
Nope, pas d'AA, en tout cas pas comme on le connait pour les autres jeux. C'est pour ça que je te demande de tester en SuperSampling direc dans les pilotes, pour voir si ça fonctionne. :jap:
Sinon, y a un petit mod pour GTA IV qui permet d'activer un AA SuperSampling, mais pas super stable mais qui le rend déjà très beau. :jap:
n°7138068
Ryoushi
Posté le 28-09-2009 à 17:36:11  profilanswer
http://www.comptoir-hardware.com/a [...] prise.html
Phenom II™ X4 940BE / Noctua NH-U12P / G.Skill Kit Extreme2 2 x 2 Go PC8500 PI / ATI Radeon HD4870x2 2Go + Accelero Xtrem / OCZ 32 Go Core Series S-ATA II / Asus M3A32-MVP Deluxe
n°7138073
Marc
Posté le 28-09-2009 à 17:41:11  profilanswer
La récap en moyenne de fps  [:prozac]
Pourquoi c'est pas une bonne idée
Exemple de deux cartes sous 3 jeux :
- 1er jeu : 70 fps pour la 1ere, 100 pour l'autre
- 2nd jeu : 70 fps pour la 1ere, 100 pour l'autre
- 3è jeu : 200 fps pour la 1ere, 140 pour l'autre
Moyenne de framerate des deux côtés, 113.3 fps, donc les cartes ont les mêmes perfs ...
Sauf que sous le 1er et le second jeu, la 1ère carte est 42% plus rapide, et c'est l'inverse dans le 3è jeu = la 1ère carte est donc en moyenne 18.6% plus performante.
Message édité par Marc le 28-09-2009 à 17:48:03
Configuration (Intel inside) - Est-elle homogène ?Problème overclock Radeon HD4850
Reboot unique au démarrage... Normal ou pas?Radeon HD4870 ou 50 + C2D E6400 = bon ménage ?
Probleme sortie TV sur Radeon 9500 proATI HD3870 vers 4850-4870 ???
[Topic unique] Aide à la présentation de nouvelles configurations PC[Topic Unique] problèmes sur les G84 et G86 de Nvidia [8400 8600]
Plus de sujets relatifs à : [Topic Unique] ATI Radeon HD 5800 et 5900 Series (RV870 inside)
