8346 connectés
Petit recensement : actuellement combien êtes-vous à avoir une des nouvelles cartes ?
Sondage à 4 choix possibles.
 Page :   1  2  3  4  5  ..  377  378  379  ..  597  598  599  600  601  602
[Topic Unique] RDNA2 - AMD RX6x00 - Navi 2x
n°11010406
Rayaki
Posté le 07-06-2021 à 21:01:17  profilanswer
lapin a écrit :
il me semble que le PCI-E Gen 4 permet de fournir plus de puissance jusqu'à 150 Watts par le port PCI-Express !!!
Non c'est toujours la même puissance
All PCI express cards may consume up to 3 A at +3.3 V (9.9 W). The amount of +12 V and total power they may consume depends on the type of card:[25]:35–36[26]
×1 cards are limited to 0.5 A at +12 V (6 W) and 10 W combined.
×4 and wider cards are limited to 2.1 A at +12 V (25 W) and 25 W combined.
A full-sized ×1 card may draw up to the 25 W limits after initialization and software configuration as a "high power device".
A full-sized ×16 graphics card[21] may draw up to 5.5 A at +12 V (66 W) and 75 W combined after initialization and software configuration as a "high power device".
Ce qui fournit 150W, ce sont les connecteurs 8pins
Optional connectors add 75 W (6-pin) or 150 W (8-pin) of +12 V power for up to 300 W total (2 × 75 W + 1 × 150 W).
Sense0 pin is connected to ground by the cable or power supply, or float on board if cable is not connected.
Sense1 pin is connected to ground by the cable or power supply, or float on board if cable is not connected.
Some cards use two 8-pin connectors, but this has not been standardized yet as of 2018, therefore such cards must not carry the official PCI Express logo. This configuration allows 375 W total (1 × 75 W + 2 × 150 W) and will likely be standardized by PCI-SIG with the PCI Express 4.0 standard[needs update]. The 8-pin PCI Express connector could be confused with the EPS12V connector, which is mainly used for powering SMP and multi-core systems. The power connectors are variants of the Molex Mini-Fit Jr. series connectors. [27]
Clan Torysss.
n°11010413
twain2
Posté le 07-06-2021 à 21:14:32  profilanswer
Vivement jeudi que j essai le drop encore
n°11010427
racsoft1
Après moi le néant
Posté le 07-06-2021 à 21:34:15  profilanswer
Tu auras plus de chance de toucher le jackpot au loto  :o   :D
n°11010449
glop-tropl​op
Posté le 07-06-2021 à 22:00:44  profilanswer
brolysan2 a écrit :
merci encore à sardhaukar, 6900XT enfin là :
https://nsa40.casimages.com/img/202 [...] 699945.jpg
Belle bête  :D
davids a écrit :
bon ma 6900XT a été expédié par AMD via fedex
c'est rapide la livraison ? 24h ? 48h ?
c'est DHL en France ?
Toi aussi tu l’as eu jeudi dernier ?
Je suis dans le même cas mais le numéro de suivi ne donne rien chez FedEx.
Tomber 7 fois, se relever 8.
n°11010490
gamelle
The place to be ...
Posté le 08-06-2021 à 01:53:05  profilanswer
Fin du moi, c'est décidé, je m'inscrit sur la liste pour une 6900XT!
Flickr/Corsair 2500X/Asus ROG STRIX X870I Gaming Wifi/Ryzen 7800X3D / 2x16GO Corsair 6000Cl30 / Asrock RX 9070 XT Taichi
n°11010509
jeje08200
Posté le 08-06-2021 à 08:24:07  profilanswer
Les drop AMD se font toujours le jeudi 15h?
Je vais tenter ma chance pour mettre une 2eme 6900xt.
Est-ce vraiment utile car j'ai rien vu passer sur le net pour approcher du 4k 120hz en ultra.
Vaut mieux attendre le fameux AMD Fidelity FX Super Resolution peut être.
En tout cas, je remercie pipould's pour son drop, monter en full Water et marche a merveille.
n°11010511
davids
Posté le 08-06-2021 à 08:25:20  profilanswer
C'est le jeudi vers 17h30
n°11010514
jeje08200
Posté le 08-06-2021 à 08:30:49  profilanswer
Si je suis déjà pas a l'heure, je ne risque pas d'en avoir ou attendre comme un con ^^
n°11010517
lapin
Posté le 08-06-2021 à 08:47:04  profilanswer
 :??: quel liste, c'est ou !!!??
peut on payer en 10 fois !!!??
n°11010520
minux
On Linux ...
Posté le 08-06-2021 à 08:52:04  profilanswer
FP
Non
n°11010531
baddy
Posté le 08-06-2021 à 09:23:14  profilanswer
lapin a écrit :
dans le menu Paramètre puis affichage puis paramètre Windows HD Color, il faut que:
ULTILISER HDR soit sur Activé
parfois faut forcé la Fréquence à 60 Hz ou 120 Hz dans Paramètres D'affichages Avancés
aussi dans Radeon Software puis roue cranté en haut à droite, puis affichage puis:
Profondeur de Couleur: sélectionne 10 bits par couleurs au minimum.
Format de Pixel: là ça va dépendre mais normalement avec un téléviseur HDMI 2.1 tu peux aller jusqu'à RVB Complet en 4K@120Hz, par contre si le Téléviseur n'est que HDMI 2.0b c'est limité à 4K@60Hz et à YCbCr en 4:2:2 en 12 bits pour le Format de Pixels.
question quel marque et modèle de moniteur ou de Téléviseur utilise tu, parfois il faut rentré dans les paramètres du moniteur ou du téléviseur et pour chaque entrée source HDMI il faut activé la profondeur de couleurs en 10 bits ou plus, parfois par exemple chez les téléviseurs LG le nom c'est HDMI ULTRA HD DEEP COLOUR et il faut l'activé sur le/les bon/s port HDMI sur le quel est branché ta carte graphique.
 :jap: Merci pour le résumé.
Pour info il faut aussi passer le port HDMI en mode "PC" et c'est pas dans le menu settings mais dans le menu de renommage de l'entrée (home dashboard).
n°11010838
glop-tropl​op
Posté le 08-06-2021 à 20:35:18  profilanswer
Oh bordel m commande vient d’être retournée  :mouais:
Renvoyé à l'expéditeur
8 JUIN 18:49
Refusé et retour au centre de tri
8 JUIN 17:34
Départ du centre de tri international
8 JUIN 17:06
Traité au centre de tri
8 JUIN 17:06
8 JUIN 17:06
 [:sisicaivrai]
n°11010841
Aqua-Niki
Posté le 08-06-2021 à 20:38:09  profilanswer
Refusé ? Ca fait un peu peur ça, y a moyen que le livreur se soit servi :/
n°11010855
damiou_03
Posté le 08-06-2021 à 20:56:33  profilanswer
Tu n'as pas des accents dans ton adresse ou dans ton nom? Pas mal de personnes ont eu des retours à l'envoyeur à cause de ça.
n°11010865
opteron144
Posté le 08-06-2021 à 21:05:16  profilanswer
+1 Mon adresse était illisible et je pense que j'ai été sauvé par le fait de le rediriger en relais.
Après c'est souvent que le colis est trop abimé les retours, surtout que le colis est 3 fois trop grand et sans aucun renfort à l'intérieur...
n°11010877
glop-tropl​op
Posté le 08-06-2021 à 21:55:57  profilanswer
J’ai un « ç » dans mon prénom  :sweat:
J’espère que ce n’est pas ça..
n°11010887
Xixou2
Posté le 08-06-2021 à 22:17:34  profilanswer
Une leçon ça ;-(
n°11010889
overloadbi​t
Posté le 08-06-2021 à 22:20:57  profilanswer
Par expérience je mets tout en majuscules nom/prénom et adresse.
n°11010898
Skandranon
☻ X-Trem ☻
Posté le 08-06-2021 à 22:40:57  profilanswer
Salut a tous, n’ayant jamais le temps lors des drops et commençant a desesperer, je me met sur la liste pour une RX6700XT ou meme une 6800XT mais il y a deja bousculade au portillon et pour du 1440p la 6700 sera deja bien meilleur que ma GTX1070. Merci d’avance :bounce:
• Asus ROG STRIX B550-E - AMD Ryzen 7 5800X3D - 32Go Corsair Vengeance - Sapphire Nitro+ RX7900XT - 3 x SSD - Corsair RM850x V3 - Corsair 5000X - H150i Capellix •
n°11010905
damiou_03
Posté le 08-06-2021 à 23:20:15  profilanswer
Tu peux toujours interroger AMD, si ça vient de là, y a peut-être moyen qu'ils te la renvoient...
n°11010906
twain2
Posté le 08-06-2021 à 23:23:50  profilanswer
Franchement je crois qu ils sont injoignable
n°11010917
oufouf84
Posté le 09-06-2021 à 00:52:47  profilanswer
d'autant plus que ce n'est pas AMD qui gère sont shop ;)
n°11010918
Antionn
Posté le 09-06-2021 à 01:03:46  profilanswer
iron60 a écrit :
J'ai pour habitude de vendre sans profit occas au prix correct, une 1060 6go  :love: vendu pendant cette crise à 100 € a une connaissance et moi une vega 56  :love: un peu plus puissante a 130€, c'est différent quant tu as affaire à des connaissances, en tout cas je peu dire qu'elle n'a pas miner  :pt1cable:
C'est un coup de chance, on peut dire ça  :jap:
J'ai jamais rien vendu d'occas jusqu'à présent ... mais je ne me verrais pas non plus faire du profit sur un objet que j'ai utilisé, et donc qui est potentiellement "encore plus d'occasion" que lorsque je l'avais acheté (vu que la quasi totalité de mon matos est acheté d'occas) ...
Et puis avec une V56, t'es pas à la rue quoi :o
alffir a écrit :
Je ne pense pas que ça sera utilisé comme ça, le FSR ne doit pas être miraculeux, c'est de l'upscale un peu moins mauvais, et sur console c'est utilisé depuis la génération X360/PS3.
Je parle de la Series S car c'est la seule console NextGen à avoir une puissance graphique limitée, du coup faire tourner les jeux à une plus faible résolution est la solution la plus simple.
Les développeurs ont toujours intérêt à avoir un jeu joli, sortir un jeu qui demande le FSR pour tourner, ça ne leur fera pas une bonne pub.
Mais comme pour la Xbox S, il pourrait partir du principe que justement, les configs les plus modestes devraient en passer par là, et donc seulement les cartes high-end serait capable de faire tourner le truc correctement :o
Bon, je pousse exprès le truc dans le cadre de la réponse. Même si au fond, je sais pas quoi en penser finalement (tirailler entre mon pessimisme, et la conscience que j'en ai et donc que ça peut être juste que ça).
Pour les cartes plus anciennes, ça peut toujours être ça de pris ceci-dit ... on verra bien :o
Belle bête :o
Du coup je me permets de te retirer de la liste, puisque l'objectif est rempli pour toi :jap:
twain2 a écrit :
Si quelqu'un vend une 6700xt ou une des 6800 au prix amd je suis intéressé
Je me suis permis de t'ajouter à la liste pour les 6800 et 6700XT (ajouté pour l'occasion) au cas où :jap:
Ça c'est pas cool :/
(enfin la carte retournée, pas le "ç" hein :o)
Je t'ai ajouté :jap:
Message édité par Antionn le 09-06-2021 à 01:13:57
Mon topic achat // [TU] Radeon Software // [TU] AMD RDNA2 - RX6x00
n°11010920
Antionn
Posté le 09-06-2021 à 01:32:35  profilanswer
Je m'auto-cite d’une réponse précédemment donné quand à la liste (elle est situé dans le second message de la FP) :
Le but est de tenir une liste de personne intéressé par l'achat d'une des cartes (celle que tu as demandé te concernant donc). Ainsi, si quelqu'un (qui doit donc avoir connaissance de la liste, forcément) veut revendre sa carte (un achat en doublon ou plus, ou acheté récemment mais veut s'en séparer, etc ...), l'idée est de permettre donc de fournir une liste de personne "prioritaire" susceptible de la racheter, parce qu'essayant d'en trouver/choper une sur le site AMD et participant au TU.
Il va s'en dire donc, que le but est de permettre de mettre la main sur des "cartes de références", à leur prix (ou moins !), vu qu'elles sont difficile à choper :whistle:
Le but derrière ça est, avant tout, l'entraide.
Donc le but de la liste, c'est aider à l'acquisition en seconde main, ou première d'une carte si jamais quelqu'un en choppe une ou plusieurs et voulait en re-vendre une.
Si t'es intéressé, je peux t'ajouter à la liste. Il suffira bien sûr, de dire quelle modèle tu veux pour que je t'ajoute au bon endroit :o  (pas besoin de me MP, je lis le TU et màj la liste, même si je ne réponds pas nécessairement de suite :jap:)
Message édité par Antionn le 09-06-2021 à 02:01:33
n°11010922
Aqua-Niki
Posté le 09-06-2021 à 01:46:38  profilanswer
Oula le taulier fait des propositions bizarres ce soir :o
Pour la postérité :
Antionn a écrit :
Il suffira bien sûr, de me dire quelle modèle tu veux pour que je t'aime au bon endroit :o
Message édité par Aqua-Niki le 09-06-2021 à 01:48:31
n°11010925
Antionn
Posté le 09-06-2021 à 01:55:25  profilanswer
[:rofl]
Nan mais je sais même pas comment je me suis retrouvé avec ça d'écrit [:yiipaa:4]  Correcteur auto à tous les coups ... je me suis pas relu ce coup-ci, ça m'apprendra tient :o
Message édité par Antionn le 09-06-2021 à 01:58:37
n°11010927
campi
V8 FTW
Posté le 09-06-2021 à 03:03:00  profilanswer
Il a bon dos le correcteur :o
[:rofl]
n°11010956
sardhaukar
Posté le 09-06-2021 à 09:54:50  profilanswer
Tout cet amour sur ce topic ! C'est meugnon !  [:love911]
n°11011017
iron60
Posté le 09-06-2021 à 11:53:28  profilanswer
Salut Antionn, oui la Vega 56 n'est pas a la rue.
Sérieux je joue en high sur écran 144hz 1440p gsynch compatible freesynch.
~40 FPS a fs2020
+ de 80fps a  Forza horizon 4
dirt5 a + de 60 Fps,
STAR WARs Squadrons a plus de 110 fps, c'est incroyable :)
Celui qui a une 2060 ou Vega 56, ne sont pas a la rue :D
Message édité par iron60 le 09-06-2021 à 11:54:35
n°11011020
brolysan2
Posté le 09-06-2021 à 11:57:06  profilanswer
~40 FPS a fs2020
et elle vaut encore de l'or à priori, vu les prix pratiqués sur leboncoin.  :D
n°11011028
lapin
Posté le 09-06-2021 à 12:07:51  profilanswer
truc chiant ma RX-VEGA56 est HS enfin semi-HS, je ne peux plus lui faire faire des truc lourd.
 Oc impossible ça finira par planter et surtout plant sur des truc genre 15 onglet ouvert sur google chrome et avec une applications avec 15 fenêtrés, peu planter sous Forza Horizon 4.
 Et plante très souvent sur UE5, la carte chauffe à mort pourtant le ventilateur tourne bien!!!!
c'est pour ça que je voulais une RADEON RX 6900 XT, mais en paiement en 10 fois car bon en ce moment je suis à court de pognon.
n°11011031
twain2
Posté le 09-06-2021 à 12:12:16  profilanswer
Ma carte AMD est une 7970
Sur le pc de ma femme 6850
n°11011032
iron60
Posté le 09-06-2021 à 12:12:35  profilanswer
heureusement que je suis tomber sur une connaissance, je voulais au départ une 3060TI, puis 2 mois âpres une 3070, puis 2 mois âpres une 6800 ou 6800XT, voyant que ça devenait compliquer pour moi, j'ai sauté sur la vega 56, je suis ravie.
j'ai démonté la vega 56 fait une révision total, un mods charcutage du support, rajout d'un ventilateur 90, la carte se porte a merveille niveau temp.
Je croise les doigts qu'elle tienne jusqu'à la rentrée prochaine :jap:
n°11011033
minux
On Linux ...
Posté le 09-06-2021 à 12:13:18  profilanswer
Pourquoi pas tout simplement essayer de la démonter, de la nettoyer et de changer la pâte thermique et/ou les pads thermiques si il y en a, ça résoudra peut-être le souci de température ...
J'ai fait ça sur une vieille GTX670 qu'on m'avait donnée et qui plantait de temps en temps comme ça, nettoyage et changement de pâte thermique et plus aucun plantage depuis :)
n°11011036
twain2
Posté le 09-06-2021 à 12:19:58  profilanswer
J ai fais ça sur ma 7970
n°11011037
Quentin-Be​lgium
Posté le 09-06-2021 à 12:25:34  profilanswer
Pour ceux qui veulent une Sapphire 6900 XT Nitro + à 1279,99 euros je peux vous expliquer la technique en MP
Message édité par Quentin-Belgium le 09-06-2021 à 12:26:18
n°11011039
twain2
Posté le 09-06-2021 à 12:27:37  profilanswer
Je veux bien la même technique pour une 6700 ou 6800 mdr
n°11011043
lapin
Posté le 09-06-2021 à 12:36:31  profilanswer
je vais y songé, merci d'autant que j'ai de la Thermal Grizzly Hydronaut un seringue de 26 Grammes !!!!
Message édité par lapin le 09-06-2021 à 12:38:01
n°11011048
iron60
Posté le 09-06-2021 à 12:51:16  profilanswer
Est ce que l'alim est suffisante ? au moins une 600W
Tu dois brancher impérativement les 2 cables pciex 8 broches qui sort de l'alim
Ma vega 56 pompe Max 150W.
Regarde ça sous TechPowerUp GPU-Z regarde rubrique sensors et note les relevés en charge avec furmark par exemple:)
Message édité par iron60 le 09-06-2021 à 12:53:25
n°11011050
lapin
Posté le 09-06-2021 à 13:01:11  profilanswer
c'est un 1000 Watts et avant j'avais un FX8320 OC comme un fou qui pompait en charge jusqu'à 315 Watts d'après un calcul de coin de table basé sur la tension et la fréquence et du fait que j'étais en 1:1 entre le contrôleur et la RAM et pour autant même avec une alimentation de 750 Watts ça passait crème.
c'est juste que y a eut deux trois canicules ou cela à créer des problèmes que y avait pas avant.
n°11011067
iron60
Posté le 09-06-2021 à 14:00:11  profilanswer
lapin, tu as suivi le topic vega 56 ?
Alors l'alim n'est pas en cause, a mon avis tu dois la démonté et suivre le tuto comment remplacé la pâte thermique, j'ai choisi la cryaunot.
Suivre un ordre de serrage, faut pas se planter et décharge toi de l’électricité static avant.
Je suis venu en retard sur topic vega 56, j'ai appris beaucoup de chose juste en lisant, je l'o/c pas, ça me suffit tel quel, au fait c'est une MSI Radeon RX VEGA 56 Air Boost OC- 8 Go avec mémoire HBM2 Hynix.
Pour comparé je te donne mes temps:
GPU temp 74°
GPU temp  Hot Spot 87°
GPU temp Memoire 84
Il y 'a un soft qui pour moi est mortel, Aida , il te fait bruler le cpu, la carte graphique, la mémoire. il te pousse aux max le stress, furmak est gentil a coté et fait que la carte graphique.
A noté que j'ai privilégier le ventilateur en mini de la véga, et bidouillé un ventil supplémentaire de 90, j'ai gagné pas mal.
Je te souhaite de réussir, ou encore mieux avoir une nouvelle 6800 si possible en paiement 10* :jap:
Amd Rysen serie 3000 ou patienceTempératures AMD RX 580 8 Go
Config.Gamer: Intel ou AMD ?.
Question processeur I7 7700K ou AMD Ryzen 3700xUtilisation AMD Ryzen Master
CG Nvidia + CG Amd dans un même PC.[Topic unique] ASUS TUF GAMING B550M-PLUS (wifi) AM4 eternal socket
[Topic Unique] Technologie SMR...Compatibilité AMD Radeon HD 6670
Plus de sujets relatifs à : [Topic Unique] RDNA2 - AMD RX6x00 - Navi 2x
