4971 connectés
Allez-vous sauter sur une 6xxx ou bien attendre les 7xxx et le 28nm ?
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  500  501  502  ..  839  840  841  842  843  844
[Topic Unique] AMD Radeon HD 6800 et 6900 ; 40nm dx11
n°7699368
tenseur1
Posté le 14-12-2010 à 02:18:32  profilanswer
Wirmish a écrit :
"The "default" clock is just the max clock of the card. The TDP max is just the max TDP the card will reach.
Typically, in games, the TDP is always lower than the max, and so it should have no problems running at the clocks it needs to. It's in synthetics (Furmark is an example of this) where TDP often goes way above and beyond the TDP, and so this adjusts clocks.
Just like Orthos can stress all 4 cores at 100%, which isn't typically going to happen, synthetics can stress all 1536SP's at once and drive power way up, so this can change clocks to dynamically keep card within limits
Increasing power 10% isn't automatically going to raise power 10%. To increase max clocks, you still need to OC the card to like 950MHz for example.
However, increasing TDP 10% means the card can run at 275W max for example, so the card will not lower clocks as easily anymore since the threshold is higher - and thus performance overall can increase if your clocks are high enough that it requires a higher power maximum.
For instance, lets say I OC the card to 1000Mhz - and now I draw 280W.. But TDP is kept at 250W. Then, the card keeps hitting the 250W barrier and so my card runs from 800MHz to 1000Mhz up and down, like in that graph, to keep the card below 250W.. However, I slide the TDP power to +20% to 300W, and now my card runs constantly at 1000MHz since it is drawing 280W, less than the 300W. (all #'s are just examples fyi)"
Tu en conclu quoi wirmish ?
n°7699369
ordimans
Posté le 14-12-2010 à 02:18:36  profilanswer
theboss3475 a écrit :
enfin on fait ça depuis un bon moment hein, c'est pas nouveau. Mais si on veut faire une bonne review, et être le plus fiable possible, faut taper dans les moteurs différents. On sait que hawx2 est"sponsorisé" Nvidia, mais à côté de ça, F1 2010 est "patché" favorable aux AMD :)
Sans être indiscret c'est quoi la reso Max qui sera teste ?
2560 ?
Ou y aura du eyefinity ?
Je veux juste un ou deux graph avec eyefinity
Mais pas les 16 moteurs...
n°7699370
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 14-12-2010 à 02:19:13  profilanswer
sasuke87 a écrit :
Les drivers sont à ce point au top pour envisager ce genre de folie? Un crossfire de 6990? Sérieux?  :??:
Une HD 6990 + une HD 6970 ça serait plus raisonnable et sûrement moins CPU limited.
n°7699371
tenseur1
Posté le 14-12-2010 à 02:19:33  profilanswer
pinto, tu as quelle temperature en idle ?
Il y a combien de mode de frequence ? 2 ou 3
( idle, 3d low , 3d ... )
Message édité par tenseur1 le 14-12-2010 à 02:21:48
n°7699372
Pinto
Posté le 14-12-2010 à 02:20:12  profilanswer
Agent heavy a écrit :
Pinto, si tu play en Multi BFBC2, en 1920x1200 avec Aniso 16x et AA2x, est-ce que la fluidité est bonne lors des crashs, des explosions et co ?
edit : Si tu pouvais tester ce serait super :)
Sur cette machine je n'ai qu'un 22" donc 1680X1050 max désolé.
beano34 a écrit :
au risque de passé pour con
MR Pinto avez vous testé votre carte avec les 10.12 officiel
http://sites.amd.com/us/game/downl [...] n7-64.aspx
si c'est le cas im sorry juste une curiosité :jap:
Pas compatible pour le peu que j'ai essayé, il doit falloir modifier le INF...
J'ai gardé pendant 8 mois mon Cross de 5970 et j'étais la plupart du temps satisfait donc oui si le Cross dépasse de beaucoup le tri de 580 pourquoi pas...
n°7699373
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 14-12-2010 à 02:21:48  profilanswer
J'en conclu que c'est parfait pour ceux qui ont de jolis waterblocks.
C'est une condition essentielle pour maximiser l'usage du PowerTune.
Sinon c'est tout de même mieux que le système du caméléon qui est basé sur le software (c-à-d la détection du nom des exe).
Message édité par Wirmish le 14-12-2010 à 02:23:53
n°7699374
Pinto
Posté le 14-12-2010 à 02:22:33  profilanswer
Un 980X entre 4.7 et 5ghz ça devrait suffire  :D
Deux modes apparemment: full 3D et 2D (250/150mhz)
Idle 39°c
Message édité par Pinto le 14-12-2010 à 02:23:09
n°7699375
nenes67
Posté le 14-12-2010 à 02:23:33  profilanswer
pauvre pinto tous le monde s'acharne sur lui  :p  :whistle:
Achats-Ventes / FeedBack
n°7699376
Cizia
Posté le 14-12-2010 à 02:24:10  profilanswer
oui donc quand tu dit "pas transcendante",c'est juste sur des résultats bench ( 3d machin etc..)?  :)
pas de confort "in game"?
Message édité par Cizia le 14-12-2010 à 02:24:49
n°7699377
Agent heav​y
Posté le 14-12-2010 à 02:24:22  profilanswer
Pas de soucis ;)
Feed-back
n°7699378
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 14-12-2010 à 02:24:56  profilanswer
C'est la rançon de la gloire...  :p
n°7699379
tenseur1
Posté le 14-12-2010 à 02:25:22  profilanswer
pinto, c'est quoi ta config ?
En montent la frequence de ton processeur, tu gagnes bcp de fps ?
Message édité par tenseur1 le 14-12-2010 à 02:33:56
n°7699380
johnny-vul​ture
Wesh wesh ma poule !
Posté le 14-12-2010 à 02:25:44  profilanswer
Je veux un test en 2560X1440 !
n°7699381
nenes67
Posté le 14-12-2010 à 02:25:51  profilanswer
a sa place je vous laisseraient tous bavez  [:sir_knumskull]  [:wiwige]  [:atigrou]  :lol:
n°7699382
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 14-12-2010 à 02:26:36  profilanswer
Faire tourner un Cayman sur un vulgaire 22" c'est inhumain. [:-noemie-]
Message édité par Wirmish le 14-12-2010 à 02:27:56
n°7699383
sasuke87
Posté le 14-12-2010 à 02:26:45  profilanswer
Heureusement que tu n'es pas à sa place  :kaola:  :whistle:
n°7699384
johnny-vul​ture
Posté le 14-12-2010 à 02:27:03  profilanswer
 :cry:
Oui il lui faut de l'espace à ce Cayman
 :cry:
Message édité par johnny-vulture le 14-12-2010 à 02:27:15
n°7699385
nenes67
Posté le 14-12-2010 à 02:27:39  profilanswer
 :kaola:  :kaola:  :kaola:  :kaola:  :kaola:   :D
n°7699386
sasuke87
Posté le 14-12-2010 à 02:27:41  profilanswer
C'est tout ce que mérite une carte à 300€ [:aaaaze]
n°7699387
Cizia
Posté le 14-12-2010 à 02:28:49  profilanswer
il y a deux heures elle était trop chère et maintenant plus assez   :whistle:
n°7699388
tenseur1
En même temps, moi je jouerais en 1680*1050 avec ma futur HD 6970
n°7699389
Invite_Sur​prise
Racaille de Shanghaï
Posté le 14-12-2010 à 02:30:35  profilanswer
Ils ont de la chance les coréens, voici un premier footage d'un jeu free-to-play on-line basé sur le Cry Engine 3 :
http://www.youtube.com/watch?v=tULj4KJCL8U
Et c'est toi qui demande 2 GB, en disant que c'est un fail de nVidia ? [:sombrero67]
[:mister yoda]
Message édité par Invite_Surprise le 14-12-2010 à 02:32:32
n°7699390
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 14-12-2010 à 02:30:37  profilanswer
Sacrilège ! [:kzimir]
n°7699391
Cizia
Posté le 14-12-2010 à 02:31:33  profilanswer
en tout cas mon larfeuille est encore plus content que moi  [:uriel]
une 570 2go canadienne pour 330euros,impec  :D
Message édité par Cizia le 14-12-2010 à 02:31:57
n°7699392
nenes67
Posté le 14-12-2010 à 02:31:45  profilanswer
en tous cas faut quel soit trop perf sinon je risque de virer mes 470  :D
ne pas craquer , ne pas craquer  [:minipinguin]  [:minipinguin]  [:minipinguin]  [:minipinguin]  [:minipinguin]
Edit : quoi que ca me suffit largement pour mon 24 pouces  :whistle:
Message édité par nenes67 le 14-12-2010 à 02:34:06
n°7699393
Pinto
Posté le 14-12-2010 à 02:32:35  profilanswer
En jeu hormis BFBC2 ou c'est limite limite et GTA bien sûr c'est largement suffisant compte tenu de la réso (COD BO, Crysis, F1, Dirt 2)  ;)  Il est vrai que je compare bien plus souvent avec des benchs vu que ce pc sert au jeux online pour ma copine et que le 22" lui suffit.
Vais quand même pas dégager mes 580 pour mettre ça sur le 26"  :whistle:
n°7699394
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 14-12-2010 à 02:33:59  profilanswer
Bof... Warface n'est qu'une copie d'un vieux F-T-P qui se nomme War Rock. [:quetzalcoalt]  [:zoub]
n°7699395
tenseur1
Posté le 14-12-2010 à 02:34:34  profilanswer
Ben j'ai qu'un ecran 22 pouces  :)
n°7699396
Invite_Sur​prise
Posté le 14-12-2010 à 02:34:36  profilanswer
Avec le Cry Engine 3 ?
n°7699397
johnny-vul​ture
Posté le 14-12-2010 à 02:34:54  profilanswer
Osef du 26" trop petit encore, sur mon U2711 2560X1440 elle fera bien l'affaire  :D
Message édité par johnny-vulture le 14-12-2010 à 02:35:11
n°7699398
Cizia
Posté le 14-12-2010 à 02:35:15  profilanswer
thanks pinto  :)
edit: deja que je me satisfait de ma vioc sur mon 28p (4870x2),elle ira impec celle ci  :D
Message édité par Cizia le 14-12-2010 à 02:36:17
n°7699399
Pinto
Posté le 14-12-2010 à 02:36:11  profilanswer
Celles de la signature hormis la 6970 qui remplace actuellement la GTX460 (celle là c'est vraiment une balle pour sa catégorie)
Sinon sur le sli de 580 les mhz cpu gagnés font en effet pas mal de bien!
n°7699400
Invite_Sur​prise
Posté le 14-12-2010 à 02:36:16  profilanswer
Et bien change d'écran au passage, c'est pas la ruine vu le prix des écrans  :pt1cable:
n°7699401
Agent heav​y
Posté le 14-12-2010 à 02:36:52  profilanswer
Sur BFBC2 c'est limite en 1680x1050 ?  :ouch:
Message édité par Agent heavy le 14-12-2010 à 02:37:04
Feed-back
n°7699402
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 14-12-2010 à 02:37:25  profilanswer
Évidemment, il faut que tu puisses continuer à chauffer la maison... [:daft punk]
n°7699403
Invite_Sur​prise
Posté le 14-12-2010 à 02:38:11  profilanswer
En water-cooling, il risque pas ... [:nedurb]
n°7699404
Pinto
Posté le 14-12-2010 à 02:38:13  profilanswer
Bah avec l'AAX8 ça arrive que le jeu descende sous les 50fps et en online c'est lourd  :(
n°7699405
Pinto
Posté le 14-12-2010 à 02:39:14  profilanswer
Bah sache que ces cartes ne chauffent vraiment pas beaucoup, en water j'ai 46°c en full à 1ghz pour 1.2v
n°7699406
Cizia
Posté le 14-12-2010 à 02:39:23  profilanswer
c'est pas yoyo qui disait que le 1680 + aa*8 etait largos aussi gourmand que 1920 + aa*4 sur BFBC2?
perso j'en sais rien,j'ai fais que le solo  :D
Message édité par Cizia le 14-12-2010 à 02:39:43
n°7699407
tenseur1
Posté le 14-12-2010 à 02:39:41  profilanswer
Pinto, la HD 6970 arrive au niveau d'une GTX 580 ou pas ?
n°7699409
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 14-12-2010 à 02:40:31  profilanswer
Pourtant...
http://media.bestofmicro.com/C/J/266131/original/bbc2%201680.png
Selon ce graph le Cayman XT devrait toujours être au dessus de 50 FPS MIN.
Message édité par Wirmish le 14-12-2010 à 02:42:23
[Topik Unik] Les AMD Radeon™ XFX HD 5870 ─ 587X ● mini BDD ● Sondage ●probleme d'affichage radeon 4870 : affichage surface réduite
[Topic Unique ?] Lian Li PC-8FI : Moyen tour 2010 !! Coming soon !![topic unique] Silverstone SG05 / SG06 / SG07
radeon 3650-3850-4650 agpATI 5750 ou 5770 ?
Probleme ATI HD 5850 POwercolor ati2dvag.dll
Plus de sujets relatifs à : [Topic Unique] AMD Radeon HD 6800 et 6900 ; 40nm dx11
