3771 connectés
 Page :   1  2  3  4  5  ..  487  488  489  ..  713  714  715  716  717  718
Topik Officiel des drivers vidéo nVidia
n°8770240
c lina
aka soyinka
Posté le 25-06-2013 à 15:16:04  profilanswer
[:hellov]
320.49-beta-driver
source                        [:bigsmilev]
n°8770281
Moonly
Ready? Let's dance!
Posté le 25-06-2013 à 15:40:40  profilanswer
The following sections list the important changes and the most common issues resolved since version 320.18. This list is only a subset of the total number of changes made in this driver version. The NVIDIA bug number is provided for reference.
Windows Vista/Windows 7 Fixed Issues
- [Battlefield 3]: Blue rectangles appear when exploding a car within the game. [1282583]
- [Eve Retribution]: There is image corruption in the game. [1282302]
- [Call of Duty: Black Ops 2]: There are artifacts and graphics corruption in the game. [1277657]
- [GeForce GTX 670]: The GPU runs at a higher performance level more frequently with dual monitors enabled. [1279437]
- [GeForce GTX 670][Battlefield 3]: The graphics in the game are corrupted. [1281730]
- [GeForce GTX 680][Assassin’s Creed 3]: There is purple corruption during gameplay. [1290918]
- [SLI][3D Vision][GeForce GTX 680M][Notebook]: The internal display goes blank after installing the driver and enabling SLI or stereoscopic 3D. [1297104]
- [SLI][Surround][GeForce GTX 670]: 2D Surround cannot be enabled when SLI is enabled. [1303522]
- [SLI][Tom Clancy`s Ghost Recon Future Soldier]: SLI profile needs to be updated. [1292762]
Windows 8 Fixed Issues
- [GeForce GTX 680][Stereoscopic 3D]: The NVIDIA Control Panel->Set up stereoscopic 3D->Stereoscopic 3D display type setting reverts from HDMI Checkerboard to 3DTV Play after rebooting the system. [1294390]
Bon, y'a un peu de progrès. Je testerai ça dans la soirée. :)
| Créateur de feu PC-Updates.fr | Ardent défenseur des formats 21:9 & 16:10 | Ma chaîne YouTube : gameplay de jeux vidéo exclusivement PC |
n°8771360
tistou77
Geek Inside!!
Posté le 26-06-2013 à 10:48:22  profilanswer
Il y aurai des 325.71 sur Windows Update
http://catalog.update.microsoft.co [...] 18.13.2571
ET dispo sur Guru3d
http://forums.guru3d.com/showthread.php?t=379843
Message édité par tistou77 le 26-06-2013 à 11:21:25
n°8771488
la_taupe
myope-la-boum
Posté le 26-06-2013 à 12:07:41  profilanswer
Drivers certifiés pour coller à la preview de Win8.1, chiants à installer et plus vieux que les 320.49b (donc peut-être pas tous les fixes). Bof :o
n°8774217
Audiz
Posté le 28-06-2013 à 11:58:32  profilanswer
J'ai une gtx 770 sur les pilotes beta 320.49, sur certains jeux ma fréquence ne dépasse pas 535mhz, autant certains vieux jeu ce n'est pas gênant, autant sur un jeu récent c'est terriblement chiant car je n'arrive pas à 60fps. Je suis nouveau chez les verts et je comprends rien à ce pilote, y'a bien une option pour dire à ma carte d'envoyer tout ce qu'elle a dans le ventre non ? J'ai essayé "privilégié mode d'alimentation maximale" rien n'y fait, toujours 535mhz. Jveux du 1228mhz a 99% !
Edit : Problème résolu, c'est bien "privilégié mode d'alimentation maximale" qu'il fallait faire, puis redémarrer le pc pour que ça soit pris en compte.
Message édité par Audiz le 28-06-2013 à 12:28:41
n°8774307
Moonly
Ready? Let's dance!
Posté le 28-06-2013 à 13:42:50  profilanswer
Sous Windows 8.1, les 325.71 s'installent automatiquement. Cela dit, une version 326.01 WHQL, plus récente d'un jour que les 320.49, est en train d'être déployée via Windows Update. Elle n'est pas accessible à tout le monde et tous les modèles de carte.
EDIT : liens mis à jour.
Message édité par Moonly le 28-06-2013 à 14:01:18
n°8777059
c lina
aka soyinka
Posté le 01-07-2013 à 17:03:20  profilanswer
n°8777065
kamikaze24
Posté le 01-07-2013 à 17:06:30  profilanswer
Toujours des plantages avec GRID 2 et les 320.39.(reout bureau sans rien, plein de joueurs avec ls mêmes soucis).
Je tente les 320.49. Sinon je modderais les 314.22 pour que ça passe avec ma GTX770 .
n°8777076
FanDeSkaP
Posté le 01-07-2013 à 17:15:05  profilanswer
Comment faire pour modder les 314.22 pour GTX 770 : Moi aussi j'ai les retour bureau sans rien, je suis prêt à tout là :(.
n°8777081
Space
Profil: Maux des rateurs
Posté le 01-07-2013 à 17:17:01  profilanswer
Tu vas me donner ta GTX 770 , je t'envoies mon adresse par MP comme ça tu ne seras plus ennuyé avec ta 770 :jap:
n°8777091
FanDeSkaP
Posté le 01-07-2013 à 17:23:43  profilanswer
Bon peut être pas à ça :p.
n°8777114
paetrix
Posté le 01-07-2013 à 17:40:05  profilanswer
salut,
y a t il quelqu un qui les a testé?j attends des feedback d utilisateurs après les problèmes avec les 320.18...
merci  :)
Core I7 4770K de stock car il faut chaud en ce moment/Scythe Mugen 2 Rev.B/CM Asus Z87-A/12 Go@1600Mhz/ Gigabyte geforce RTX2070 Super 8 Go/1 HDD 6To et 3 SSD 2*2 To et 1*256Go/Alim Corsair TX/Antec Eleven Hundred/Ecran Led Samsung 24 pouces(1080)/win10 6
n°8777175
kamikaze24
Posté le 01-07-2013 à 18:31:30  profilanswer
Cf post au dessus, je les ai installés pas encore testé de jeux. ça devrait pas tarder.
n°8777244
bauer_atti​tude
Bonne fête du voile d'hiver
Posté le 01-07-2013 à 19:10:54  profilanswer
Here a manual how to get your GTX770 to work with 314.22
First you have to download my INF http://netload.in/dateiGTByDiVLEk/nv_dispi.inf.htm
1. Download 314.22 from Nvidias Website
2. Extraxt the "314.22-desktop-win8-win7-winvista-64bit-international-whql.exe" with 7zip so you get the folder with the driver and then navigate to folder "C:\NVIDIA\DisplayDriver\314.22\Win8_WinVista_Win7_64\International\Display.Driver" (Your folderstructure could look a little different from mine and you can use x86 drivers of curse)
3. Copy and paste my modded "nv_dispi.inf" (the one you have downloaded from netload) in the "Display.Driver" folder overwriting the existing one.
4. Now you are able to install 314.22 with your GTX770, your GXT770 now should pass the hardwarecheck
5. To install the driver execute "setup.exe" in the "C:\NVIDIA\DisplayDriver\314.22\Win8_WinVista_Win7_64\International" folder
6. There can appare a window saying that the driver is not signatured, click on install anyway (Win8-user may have to enable an option that unsignatured driver can be installed -> google it please)
7. Enjoy bugfree playing.
You are free to share and link this modded inf-file and the instruction on other forums.
Source : https://forums.geforce.com/default/ [...] -23-13-/70
Steam ID
n°8777611
peufly
Posté le 02-07-2013 à 00:14:28  profilanswer
Bonsoir a tous, bon petit feedback des 320.49 WQHL pour ma part RAS, meilleur fluidité sur BF3 je dirais même très bonne, pas eu de souci au niveau des textures même si avec les 320.18 cela me l'avais fait qu'une seul fois depuis leurs sortie.
Pas de crache non plus.
Je vous fais part aussi de mon expérience a propos de la pâte thermique de ma CG.
Pour ceux qui cherche a ce que l'overboost de leur CG fonctionne le plus souvent possible au taquet je vous conseil de refaire la pâte thermique de celle ci (se n'est pas trop dur a faire).
Avant je prenais 73°C avec comme température ambiante 21°C et là avec 23°C la CG ne dépasse pas les 70°C donc l'overboost est resté a son maximum toute la soirée sur deux sessions de 2H chaque une.
Voilà si sa peut servir.
Comme pâte thermique j'utilise de la Artic Silver MX-5.
Sur ceux bonne soirée. :sleep:
n°8777613
Le Profana​teur
Passéiste désincarné
Posté le 02-07-2013 à 00:16:48  profilanswer
Je tourne avec les 320.39 sans pb (BF3; Metro 1&2 par exemple)
GTX 770
7 64bits
Message édité par Le Profanateur le 02-07-2013 à 00:17:08
n°8781213
champidelb​ois
Posté le 04-07-2013 à 22:46:53  profilanswer
Les 320.39 ça allait (est ce que aurait duré ça ne je ne sais pas), les 320.49 me font des freezes bureau plus ou moins longs avec erreur nvlddmkm dans l'observateur d'évènements.
MSI GTX 560 Ti oc
Win 7 64
Bref, de retour sur les 314.22 :D
> Achat/Vente <
n°8781217
Le Profana​teur
Posté le 04-07-2013 à 22:58:37  profilanswer
Suis passé aux 320.49, idem au 39. pas de soucis à reporter.
n°8781819
Till Linde​mann
heirate mich
Posté le 05-07-2013 à 15:24:21  profilanswer
on a une diff entre les 320.49 béta et ceux whql ?
n°8787417
romain2711​1
Liberté !
Posté le 10-07-2013 à 19:42:38  profilanswer
Qui pourrais me dire si c'est encore possible de "forcé la fréquence de rafraichissement" avec les 320.49 et une 8800gt ?
J'ai tester avec les coolbits2 mais ça marche pas. :(
Certain jeux s’affiche en 50hz et bizarrement ma TV aime pas ça du coup l'image est toute moche et pas centré. :kaola:
Romain
n°8788359
Altarius
As de la digression
Posté le 11-07-2013 à 15:53:14  profilanswer
Je suis passé au 320 avec les .49, sans avoir eu connaissance des problèmes de drivers, j'ai eu de belles frayeurs avec un bug souris, puis un freeze. Chose qui ne m'arrivait plus depuis bien longtemps.
Après avoir soupçonné un virus puis ma carte, (je viens d'avoir une 8800gts 512 qui est DCD) v'la que je découvre que les drivers buggent diversement, et comme je viens de passer des 314 au 320 [:biboo_].
Bizarrement pas dans les jeux apparemment.
C'est inadmissible cette histoire  :o
Dsl pour les fautes - ne pas juger est une clé qui change le monde - Mensonge, propagande et manipulation, bienvenue chez les médias.
n°8788381
Till Linde​mann
heirate mich
Posté le 11-07-2013 à 16:10:26  profilanswer
j ai exactement le même problème sur ma GTX460 avec toute la série des 320 whql ou beta, du coup je reste au 314
n°8790951
Altarius
As de la digression
Posté le 14-07-2013 à 06:48:50  profilanswer
Sur mon deuxième PC je n'avais pas de problème, mais là je viens d'avoir un truc louche en faisant tourner Unigine Heavan. Je ne sais pas si c'est le driver 320 ce coup ci. CA doit dépendre des configs vu que ces ennuis semblent ne pas toucher tout le monde.
Je vais laisser ce driver quand même pour "observer" ce qui se passe.
Sinon, je ne pense pas qu'un driver tue une CG mais ça correspond pile poil au décès de ma tendre et aimée 8800 GTS 512. Heureusement qu'elle m'a quitté juste avant que je n'installe le pilote cassos parce que j'aurais eu un gros doute [:ofou]
n°8790978
ol1v1er
Posté le 14-07-2013 à 09:41:31  profilanswer
Aucun soucis avec ma 660 et les 320.49 depuis la sortie, du tout bon.
n°8790994
kamikaze24
Posté le 14-07-2013 à 10:19:04  profilanswer
Idem avec ma Lightning GTX770. contrairement aux autres pilotes.
n°8791263
la_taupe
myope-la-boum
Posté le 14-07-2013 à 17:07:19  profilanswer
Pareil, passage de 680 à Titan avec les 320.49 sans souci.
Toujours pareil avec les "vieilles" cg nv, faut se trouver un pilote correct et laisser tomber les màj au bout d'un temps :sweat:
n°8791871
Altarius
As de la digression
Posté le 15-07-2013 à 13:10:18  profilanswer
Sur la 8800 GTS640 de remplacement, le 320.49 semble bien fonctionner.
Pour mon PC principal, je n'avais pas installé le 3D vision et autres trucs, juste le pilote, PhysX et l'audio. Mais je ne pense pas que ça joue.
n°8791966
Till Linde​mann
heirate mich
Posté le 15-07-2013 à 14:57:14  profilanswer
je pense que je vais faire ça :/
n°8792173
la_taupe
myope-la-boum
Posté le 15-07-2013 à 17:38:47  profilanswer
@Altarius: je pense pas non plus, j'installe toujours que pilote + PhysX.
n°8792578
Altarius
As de la digression
Posté le 16-07-2013 à 07:37:41  profilanswer
Oui aussi  :jap:
n°8792639
nature48
Posté le 16-07-2013 à 09:13:17  profilanswer
toujours pas disponible afterburner.
Marre de voir ce message à chaque démarrage.
edit : download3.msi.com/files/downloads/uti_exe/vga/MSIAfterburnerSetup300Beta11.zip  :whistle:
Message édité par nature48 le 16-07-2013 à 09:16:15
Je vends mon compte Steam, Origin, Uplay = http://steamcommunity.com/id/nature48/
n°8792760
bauer_atti​tude
Posté le 16-07-2013 à 11:21:10  profilanswer
Depuis que j'ai installé les 326.01 sur mon Win 7 64 bits, j'ai le panneau NVidia qui se met en mode "Ne répond pas" quand je veux changer un paramètre 3D :??:
Je suis obligé de le relancer 3 fois pour qu'ils veuillent bien me laisser changer un paramètre...
C'est déjà arrivé à l'un d'entre vous? Ça peut venir de quoi?
J'ai tenté de réinstaller les drivers et c'est pareil.
Ça pourrait venir du fait que les drivers 326.01 sont destinés à Win 8.1 et non à Win 7 64 bits?
Merci d'avance.
Steam ID
n°8793017
Moonly
Ready? Let's dance!
Posté le 16-07-2013 à 15:01:50  profilanswer
Les 326.01 étant destinés à Windows 8.1, il aurait été probable que ton souci vienne de là. Cela dit, il m'a fait le coup une fois sous Windows 8.1 aussi, donc le pilote est quand même fautif.
Message édité par Moonly le 16-07-2013 à 15:02:32
n°8793042
bauer_atti​tude
Posté le 16-07-2013 à 15:15:28  profilanswer
Ok :jap:
Parce que moi c'est systématique...
Steam ID
n°8793437
Rayaki
Posté le 16-07-2013 à 18:41:10  profilanswer
ca fait 4 ou 5 drivers que ca plante systematiquement 1 ou 2 fois avant l'affichage du panneau Nvidia.
Par contre, si je l'ouvre de suite (avant la fin des downloads de Windows sous le bureau), ca s'ouvre bien !
Doit donc y avoir un process qui fait conflit avec :o
Clan Torysss.
n°8793494
Space
Posté le 16-07-2013 à 19:24:51  profilanswer
n°8793562
B1LouTouF
PSN : Geo62280 / GT : Mr Geo
Posté le 16-07-2013 à 20:37:06  profilanswer
quelqu'un a pris des sonic sur steam ? J'ai le transformed qui me fait des accoups.. les 2 autres " sonic adventure 2 et épisode 4 " ne se lance même pas :lol:
FeedBack
n°8794106
DiB91
Bwaaaaaaah
Posté le 17-07-2013 à 11:47:14  profilanswer
Bien évidemment oui, mais pas encore lancé, comme 90% des jeux que j'achète en soldes :o
Rehost | Collect | Link
n°8794110
B1LouTouF
Posté le 17-07-2013 à 11:48:22  profilanswer
pareil :lol:
FeedBack
n°8795608
c lina
aka soyinka
Posté le 18-07-2013 à 15:03:34  profilanswer
n°8795839
Moonly
Ready? Let's dance!
Posté le 18-07-2013 à 17:23:38  profilanswer
Ils ne passent pas chez moi sous Windows 8.1 avec une GTX 670. Je peux choisir les composants à installer, mais en cliquant sur suivant, j'arrive direct en échec, et il me met juste "non installé" sur les composants en question.
Bon, bah tant pis, ils ont encore besoin de bosser le truc pour Windows 8.1 (après la galère avec leur màj via Windows Update).
C'est quoi léquivalent dune ATI 9600XT en NVIDIA ?Upgrade d'un PIII 550 pour montage vidéo ??
Problème de sortie vidéo en lecture DivXchanger le ventilo de carte video
Regarder une video sur sa tv...ventilateur carte video gfx malade
Carte uATX avec bonne sortie s-video ?probleme divx video duplicator pro
Deux cartes vidéo installéesrecherche drivers
Plus de sujets relatifs à : Topik Officiel des drivers vidéo nVidia
