6576 connectés
 Page :   1  2  3  4  5  ..  514  515  516  ..  981  982  983  984  985  986
Les écrans OLED - Panasonic - Philips - Lg -Sony ...
n°2259424
Posté le 16-11-2020 à 22:33:16  answer
Essaye avec le de-judder à 0 ou 1, et pousse le de-blur vers le milieu, voire à fond. Tu me diras si tu vois des artefacts.
Posté le 16-11-2020 à 22:33:16  profilanswer
n°2259433
Leica
James bonds furieux
Posté le 17-11-2020 à 00:41:06  profilanswer
Je vais essayer :jap:
Et pour info éclatant à votre avis il met quoi en gros ?
n°2259439
Posté le 17-11-2020 à 09:54:55  answer
Je ne sais pas, surtout que j'utilise la TV en anglais :d
n°2259440
Leica
James bonds furieux
Posté le 17-11-2020 à 09:57:17  profilanswer
C'est le "Clear" (qui chez moi génère pas mal d'artefacts).
n°2259441
Posté le 17-11-2020 à 10:12:28  answer
Clear, je dirais de-judder entre 2 et 5, mais c'est vraiment une estimation à la louche.
Smooth, le de-judder est clairement poussé plus loin, entre 8 et 10.
Difficile d’être plus précis.
https://www.reddit.com/r/OLED/comme [...] e_between/
They are both fram interpolation. Basically what happens is this:
Film and tv are 24hz ("FPS" ). so, there are 24 new frames in a second. So, what happens if you want to run your TV at 60Hz? well, you can show each frame 3 times, or you can use some algorithm that looks at 2 frames, guesses whats in-between, and makes "new frames". Now, the director figured your brain would just figure out what is in between, since usually TV's or projectors have some sort of g2g delay. That is, it takes time for a pixel to go from one frame to the next, and that helps "stitch" the frames together in your mind. Problem is on OLED no such delay exists so things seem choppy, this reduces the choppiness.
The problems are that the algorithm isnt perfect and sometimes you notice. Also, its usually TOO smooth. The only difference between de-judder and de-blur is one is 60hz interpolation and the other is 120hz.
Recommendations are usually 10-10 if it doesn't bother you, 0-0 is it does, and between 1 and 3 for each if the jumpiness of pan shots bother you but you dont want a soap opera.
There is also Black Frame Insertion (AKA BFI/OLED Motion) that works in a different way. See, you can trick your brain into making better "guesses" at the in-between frames if you turn the back-light off between frames. Old CRT tvs would do this just by their nature, but with LCD and oled the back-light persists. So, if you have a pixel going from red to blue, it transitions from red to blue. Now, if you showed the pixel in red. Then turned the pixel all the way off, then made it blue, your brain soothes that out for you. So, basically, instead of an algorithm guessing what the images between frames are, n black frames are inserted, turning off the back-light and forcing your brain to "guess better". This works well but can dim the image quite a bit, make some people sick, and can cause flashing in video-games if you cant keep your frame-rate up.
edit: for clear and smooth. one is 10-0 and the other is 0-10, I think.
Donc d'après lui, de-blur est inutile sur du contenu à moins de 60 fps (mais sur Gemini Man par exemple, il doit fonctionner), seul de-judder importe.
Par-contre il se trompe sur les presets, car Clear a un effet sur les films en 24 fps.
Message édité par Profil supprimé le 17-11-2020 à 10:25:30
n°2259443
Leica
James bonds furieux
Posté le 17-11-2020 à 10:34:17  profilanswer
Super intéressant merci ! J'ai lu le thread. Du coup je vais faire des essais avec très peu (genre 0-0 ou 1-1), voir ce que ça donne. :bounce:
n°2259448
Posté le 17-11-2020 à 10:55:37  answer
0-0 c’est off :d
n°2259452
tonymontan​a2013
Posté le 17-11-2020 à 11:16:17  profilanswer
moi j'ai mis de-judder à 2 et de-blur à 0 + RealCinema On et pour l'instant ca me convient
de ce que je me souviens de mes tests, Smooth ca n'allait pas, Clear c'était mieux, Off ca passait du moment que RealCinema était activé
rou-rou
n°2259453
Leica
James bonds furieux
Posté le 17-11-2020 à 11:16:36  profilanswer
Ah fuck..; J'avais lu que activé à 0/0 c'était pas pareil que désactivé tout court... JE RÊVE D'UN GROS MANUEL DE RÉGLAGES...
n°2259454
Posté le 17-11-2020 à 11:18:52  answer
Leica a écrit :
Ah fuck..; J'avais lu que activé à 0/0 c'était pas pareil que désactivé tout court. […]
Où as-tu lu ça ? ça n'a pas de sens.
Posté le 17-11-2020 à 11:18:52  profilanswer
n°2259457
Leica
James bonds furieux
Posté le 17-11-2020 à 11:25:39  profilanswer
Entre autres sur les réglages conseillé de "Ciné du Loup", où il fait bien la différence entre "Désactivé" et "Utilisateur (Saccade à 0 et Tâche/zone flou à 0)".
Et ça me semblait bizarre aussi pour tout dire... :o
n°2259461
Posté le 17-11-2020 à 11:59:58  answer
Connais pas. Le gars raconte peut-être des conneries :d
n°2259463
tchupac
Posté le 17-11-2020 à 12:00:30  profilanswer
J'avais remarqué que le mode isf(dark) (et probablement la version clair) avait par défaut le flou à 10 (et l'autre à 0). J'avoue que ça ne m'a jamais gêné et je l'ai juste remarqué en allant voir les options ahah.
Par contre, en mode "cinéma SDR" avec le trumotion activé sur cinema, ça me semblait trop fort (car ça ralentit l'action fortement quand il est activé - comme un effet de ralenti à cause de l'ajout d'image pour compenser logiquement). Donc, je suis d'accord que le retrait du flou ("de-blur" ) aide mais le "dejudder" je n'aime pas du tout. En HDR, je n'ai rien d'activé (par défaut en mode cinéma c'est désactivé) et ça ne m'a jamais ennuyé.
Message édité par tchupac le 17-11-2020 à 12:01:15
n°2259464
ganon304
Posté le 17-11-2020 à 12:37:49  profilanswer
Pour ce réglage en particulier je sais pas mais ses reglages sur le c6v c'est juste au poil même si chaque dalle à une calibration différente.
Mon topique achat/vente: http://forum.hardware.fr/forum2.ph [...] w=0&nojs=0
n°2259478
vanloque
\o/ Buy the dip Shinji ! \o/
Posté le 17-11-2020 à 15:23:38  profilanswer
Mooms y'a que pour le p0rn que je veux bien approuver le TrueMotion :o
n°2259481
Captainpou​larde
Posté le 17-11-2020 à 15:48:59  profilanswer
Je serais bien étonné que ce soit tourné en 24ips.  :o
n°2259482
vrolok
J'ai soif...
Posté le 17-11-2020 à 15:54:15  profilanswer
par contre dans certains films j'ai déjà vu 24 pis
--> smiley roucas
L'alcool tue lentement... on s'en fout on n'est pas pressé
n°2259483
vanloque
Posté le 17-11-2020 à 15:55:04  profilanswer
Y'a beaucoup de contenu 4K à 24 ou 25 fps justement :lol:
Mais aussi parfois du 4K@60fps
Message édité par vanloque le 17-11-2020 à 15:55:22
n°2259491
Rocknroll
Posté le 17-11-2020 à 17:50:43  profilanswer
Drapal !
Je suis actuellement sur un plasma Hitachi 42" de 2003  [:adodonicoco] que mes parents mon refilé depuis quelques années.
Depuis mon passage chez un darty, ou je suis resté scotché 10 mn devant un oled 4k (je suis en 720 sur la télé  :D ), j'ai envie de changer.
Je vise un 48cx, pas la place de mettre plus de toute manière, pendant le black friday.
J'ai un peu peur en lisant le topic, j'ai pas de doctorat en réglage de télé, c'est possible de s'en sortir normalement, genre toucher à rien et c'est beau quand même ? :o
Message édité par Rocknroll le 17-11-2020 à 18:11:00
n°2259492
Posté le 17-11-2020 à 17:54:48  answer
Vise plutôt un 55", ça coute moins cher.
Je peux te faire passer une certification en réglages de TV OLED LG anglais/français, tarifs en MP :o
n°2259498
Art Core
Posté le 17-11-2020 à 19:04:24  profilanswer
Il y a une LG 65" sur LBC qui me fait de l'oeil mais le mec a plus le carton donc c'est hyper risqué. Personne a un carton de 65" qui traîne :D (en IDF) ?
If I'm gonna die, I'm gonna die historic on the fury road!
n°2259525
BSG
Posté le 18-11-2020 à 01:16:17  profilanswer
En quoi le fait qu'il n'y a pas de carton rend la vente plus risquée ?
n°2259526
caneton91
GT : Can3t0n
Posté le 18-11-2020 à 07:22:18  profilanswer
Je pense avoir retrouver l’annonce  :o
Par contre, le carton des oled, il faut quand même prévoir du très bon scotch car le dessous n'est pas tenu de base avec le carton mais tout se maintient par les sangles.
Après je ne sais pas si les emboîtages de ps sont compatibles entre les modèles lg
n°2259531
Rocknroll
Posté le 18-11-2020 à 08:33:52  profilanswer
Pas la place pour un 55  [:tim_coucou]
n°2259535
Spaune
Cordialement
Posté le 18-11-2020 à 08:55:14  profilanswer
Mais si
n°2259542
Posté le 18-11-2020 à 10:02:36  answer
Pousse les murs  :D
n°2259543
Art Core
Posté le 18-11-2020 à 10:05:59  profilanswer
Ben pour déplacer la télé. Vu comme les dalles sont fines, il faut nécessairement un emballage rigide pour éviter tout risque.
n°2259549
tchupac
Posté le 18-11-2020 à 11:02:26  profilanswer
Rocknroll a écrit :
Drapal !
Ca dépend surtout de ton "exigence", si tu es très satisfait d'habitude des réglages par défaut, oui tu peux utiliser par défaut sans soucis. C'est largement mieux que la moyenne des tvs LCD je trouve (par défaut le calibrage est dans la bonne moyenne ^^).
Comme dit plus haut pour moi, le seul réglage que j'ai vraiment changé c'est la température des couleurs que j'ai mis en warm2 sur tous les modes qui ne l'étaient pas (et que j'utilise) comme le "game mode". Les modes SDR isf (dark), isf(clair) et filmmaker étaient déjà bon et je n'ai rien changé - idem pour le HDR (cinéma). Car c'est plus naturel et beaucoup moins bleuté (moins fatiguant + plus réaliste = bonus). Juste que si on est habitué à des images bleutées (99% des tvs par défaut), il faut peut-être 1 semaine d'adaptation où on va se dire "c'est trop jaune" mais après c'est bon on reviendra plus jamais en arrière. :p
Message édité par tchupac le 18-11-2020 à 11:03:20
n°2259551
BSG
Posté le 18-11-2020 à 11:08:27  profilanswer
Dans le coffre d'une voiture entourée de couvertures cela en peut pas suffire ?
n°2259552
Joe l'indi​en 94
Posté le 18-11-2020 à 11:20:15  profilanswer
La partie la plus fine de la dalle est vraiment pas épaisse, je ne m’y risquerais pas.
Pour ma part j’ai viré le carton, il était vraiment trop encombrant.
"L'argent n'a pas d'odeur mais la femme a du flair"
n°2259553
fneuf
Quoi de neuf doc ?
Posté le 18-11-2020 à 11:25:17  profilanswer
Quand tu lis les conditions de vente de certains revendeurs, virer le carton, c'est virer sa garantie avec  :o
A moins de remettre la main sur un carton si besoin, cf quête de Art Core
[ACH]16 Go DDR2 (4x4GB) || ESI Juli@ XTe (PCIe) || Nokia 808 PureView   ///_-__-_\\\   [VDS] Thrusmaster GT // Philips SE330 // Sony MPS-70
n°2259554
Art Core
Posté le 18-11-2020 à 11:29:16  profilanswer
Oui voilà, ça sent un peu la cata pour la rentrer ou la sortir du coffre. Surtout sur une taille aussi grande.
n°2259556
nosdeuxxo
Posté le 18-11-2020 à 11:47:16  profilanswer
Je suis en quête d'un 48CX aussi (pas la place pour plus également), sous les 1400€ habituels qu'on retrouve en ce moment chez les vendeurs, donc si vous voyez passer quelque chose, MP :o
n°2259558
phantom62
Posté le 18-11-2020 à 11:53:02  profilanswer
J'ai le carton de ma LG C9 65' en stock à Paris, mais je le garde justement en cas de déménagement...
n°2259562
tonymontan​a2013
Posté le 18-11-2020 à 12:31:23  profilanswer
je l'ai fait, avec une 65 LG justement, ca passe
rou-rou
n°2259564
Kroma X am​orK
Angel's demon
Posté le 18-11-2020 à 12:33:31  profilanswer
C'est kon parce que le 55" est à 1350€ chez CDiscount. :D
n°2259565
Art Core
Posté le 18-11-2020 à 12:35:17  profilanswer
Audacieux. Sinon je découvre des sites qui vendent des cartons pour écrans plats, mais je crois qu'il y en a aucun d'aussi grand pour un 65" :
https://www.ecocarton.fr/cartons-d% [...] iaux-c-21/
Mais de toute façon la question se pose plus la télé a l'air vendue, c'est peut-être un lurkeur d'ici qui a eu l'idée d'aller se la prendre après mon post  :??: Tant pis, on va attendre le Black Friday gentiment :o.
Message édité par Art Core le 18-11-2020 à 12:36:17
n°2259566
Leica
James bonds furieux
Posté le 18-11-2020 à 12:35:45  profilanswer
Heureusement...  :whistle: Sinon, si on jette le carton on ne peut plus JAMAIS déplacer son TV... Faut juste faire un peu gaffe et être délicat.
n°2259588
hyptnos
GT : Gui iom
Posté le 18-11-2020 à 14:29:14  profilanswer
[:soulafa] Baisse de prix / réduction [:soulafa]
Certes pas énorme mais toujours appréciable.
Il s'agit cette fois de la LG 55CX qui est affiché à 1349€ chez Cdiscount (1390€ chez lacono)
Tarif normal habituel : 1690€
Pour rappel le 55B9 est toujours a 1099€ chez Boulanger.
Le téléviseur LG 55CX est vendu seulement 1350 € par Cdiscount, soit un prix inférieur de 350 € par rapport au prix habituellement constaté sur notre comparateur (1700 €). Il faudra probablement attendre le Black Friday 2020, qui aura lieu la semaine prochaine, pour obtenir une meilleure offre, et encore, s'il reste suffisamment de stock.
https://www.lesnumeriques.com/tv-te [...] 57135.html
Message édité par hyptnos le 18-11-2020 à 14:29:42
n°2259603
tonymontan​a2013
Posté le 18-11-2020 à 15:42:30  profilanswer
audacieux mouais, c'est pas du sucre non plus, suffit de faire un peu attention  [:spamafote] écran emballé dans du cellophane + posé sur un plaid et ça passe sans souci
la TV est d'ailleurs assez légère pour une 65 ça m'a étonné par rapport à mon 65 plasma précédent, elle doit faire 25kg max
Message édité par tonymontana2013 le 18-11-2020 à 15:43:22
rou-rou
n°2259611
Rambo95
Posté le 18-11-2020 à 16:10:54  profilanswer
Drap sur l'écran, dalle enroulée dans du bulle, et une planche coté écran en plus pour protéger la dalle, il devrait rien lui arriver.
Le tout c'est d'éviter toute contrainte, sur le haut de la dalle.
La garantie et le SAV sur les écrans LCDHesitation entre 3 ecrans LCD, je ne m'y connais pas...
Ecrans Plasma/LCD > plafond de paiementsAttendre les écrans SED, ça vaut le coup?
UPSCALING des DVD et écrans appropiés3 écrans hd ready, aidez moi à faire le bon choix, merci
Ecrans LCD "presque donnés" : que choisir : LG, Samsung, Sharp,ToshibaDiffusion de contenus sur écrans
Bureau étendu sur 4 ecrans.quels ecrans lcd ?????
Plus de sujets relatifs à : Les écrans OLED - Panasonic - Philips - Lg -Sony ...
