1664 connectés
 Page :   1  2  3  4  5  ..  487  488  489  ..  1541  1542  1543  1544  1545  1546
[UBUNTU] 25.10 Questing Quokka'' - Topic dédié
n°924826
g-ridaz
Steam/XboxLive: Gridaz
Posté le 19-06-2007 à 15:33:11  profilanswer
# menu.lst - See: grub(8), info grub, update-grub(8)
#            grub-install(8), grub-floppy(8),
#            grub-md5-crypt, /usr/share/doc/grub
#            and /usr/share/doc/grub-doc/.
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
# WARNING: If you are using dmraid do not change this entry to 'saved' or your
# array will desync and will not let you boot your system.
default  0
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout  3
## hiddenmenu
# Hides the menu by default (press ESC to see the menu)
hiddenmenu
# Pretty colours
color cyan/blue white/blue
## password ['--md5'] passwd
# If used in the first section of a menu file, disable all interactive editing
# control (menu entry editor and command-line)  and entries protected by the
# command 'lock'
# e.g. password topsecret
#      password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
# examples
# title  Windows 95/98/NT/2000
# root  (hd0,0)
# makeactive
# chainloader +1
# title  Linux
# root  (hd0,1)
# kernel /vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
### BEGIN AUTOMAGIC KERNELS LIST
## lines between the AUTOMAGIC KERNELS LIST markers will be modified
## by the debian update-grub script except for the default options below
## DO NOT UNCOMMENT THEM, Just edit them to your needs
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specific kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
##      kopt_2_6_8=root=/dev/hdc1 ro
##      kopt_2_6_8_2_686=root=/dev/hdc2 ro
# kopt=root=UUID=1eba9c5c-a3fd-446c-b0cf-af11ebcf2098 ro
## Setup crashdump menu entries
## e.g. crashdump=1
# crashdump=0
## default grub root device
## e.g. groot=(hd0,0)
# groot=(hd1,0)
## should update-grub create alternative automagic boot options
## e.g. alternative=true
##      alternative=false
# alternative=true
## should update-grub lock alternative automagic boot options
## e.g. lockalternative=true
##      lockalternative=false
## additional options to use with the default boot option, but not with the
## alternatives
## e.g. defoptions=vga=791 resume=/dev/hda5
# defoptions=quiet splash locale=fr_FR
## should update-grub lock old automagic boot options
## e.g. lockold=false
##      lockold=true
# lockold=false
## Xen hypervisor options to use with the default Xen boot option
# xenhopt=
## Xen Linux kernel options to use with the default Xen boot option
# xenkopt=console=tty0
## altoption boot targets option
## multiple altoptions lines are allowed
## e.g. altoptions=(extra menu suffix) extra boot options
##      altoptions=(recovery) single
# altoptions=(recovery mode) single
## controls how many kernels should be put into the menu.lst
## only counts the first occurence of a kernel, not the
## alternative kernel options
## e.g. howmany=all
##      howmany=7
# howmany=all
## should update-grub create memtest86 boot option
## e.g. memtest86=true
##      memtest86=false
# memtest86=true
## should update-grub adjust the value of the default booted system
## can be true or false
# updatedefaultentry=false
## ## End Default Options ##
title  Ubuntu, kernel 2.6.20-16-generic
root  (hd1,0)
kernel  /boot/vmlinuz-2.6.20-16-generic root=UUID=1eba9c5c-a3fd-446c-b0cf-af11ebcf2098 ro quiet splash locale=fr_FR
initrd  /boot/initrd.img-2.6.20-16-generic
quiet
savedefault
title  Ubuntu, kernel 2.6.20-16-generic (recovery mode)
root  (hd1,0)
kernel  /boot/vmlinuz-2.6.20-16-generic root=UUID=1eba9c5c-a3fd-446c-b0cf-af11ebcf2098 ro single
title  Ubuntu, kernel 2.6.20-15-generic
root  (hd1,0)
kernel  /boot/vmlinuz-2.6.20-15-generic root=UUID=1eba9c5c-a3fd-446c-b0cf-af11ebcf2098 ro quiet splash locale=fr_FR
initrd  /boot/initrd.img-2.6.20-15-generic
quiet
savedefault
title  Ubuntu, kernel 2.6.20-15-generic (recovery mode)
root  (hd1,0)
kernel  /boot/vmlinuz-2.6.20-15-generic root=UUID=1eba9c5c-a3fd-446c-b0cf-af11ebcf2098 ro single
title  Ubuntu, memtest86+
root  (hd1,0)
kernel  /boot/memtest86+.bin
quiet
### END DEBIAN AUTOMAGIC KERNELS LIST
n°924829
the_big_po​ulet
Flying chicken
Posté le 19-06-2007 à 15:34:53  profilanswer
chaced a écrit :
Qu'elle commande ? a part uuidgen qui genere des uuid aléatoire :D
https://help.ubuntu.com/community/U [...] %28uuid%29
UUIDs can be determined using the vol_id command. For example, to find the UUID for the filesystem on /dev/sda1:
$ sudo /sbin/vol_id -u /dev/sda1
79415992-7093-4a0e-a2e5-4574ed702d05
 [:spamafoote]
edit:  [:benou_grilled]
edit2: d'ailleurs ta commande est + intéressante Gf4x3443 :D
Message édité par the_big_poulet le 19-06-2007 à 15:36:19
n°924830
Gf4x3443
Killing perfection
Posté le 19-06-2007 à 15:36:07  profilanswer
root  (hd1,0)
quiet
savedefault
Et en retirant la locale?
n°924832
g-ridaz
Posté le 19-06-2007 à 15:37:35  profilanswer
Le truc c'est que je démarre donc bien sur mon autre DD, ou grub fonctionne sans soucis. Donc de préférence je préfèrais pas gacher çà :d.
J'ai comme erreur une '15: file not found'... Est ce que je dois spécifier l'endroit ou trouver le lst pour le grub sur le SATA?
Message édité par g-ridaz le 19-06-2007 à 15:38:11
n°924833
Gf4x3443
Killing perfection
Posté le 19-06-2007 à 15:40:20  profilanswer
Bah si tu bootes sur le sata oui, il faut lui indiquer la partition root.
Mais pas sur la CLI du kernel, plutot lors du grubinstall.
n°924836
g-ridaz
Posté le 19-06-2007 à 15:45:16  profilanswer
cad? excuses moi mais là je ne suis plus
Comment lui indiquer?
Je réexplique ce que je veux faire au cas ou:
actuellement grub est sur le DD IDE (sda) et linux sur le DD SATA (sdb) je voudrais que grub soit donc sur le même disque que linux (sdb).
Pour le moment tout fonctionne nickel et j'ai une erreur 15 en programmant le bios pour qu'il boote sur le SATA (sdb) mais pas sur l'IDE(sda).
n°924841
Gf4x3443
Killing perfection
Posté le 19-06-2007 à 15:51:23  profilanswer
En ligne de commande, sur ton disque SATA sdb (en root):
# grub
# grub> root (hd1,0)
# grub> kernel /boot/ <taper sur TAB pour voir si les noyaux sont bien là pour sdb)
# grub> setup (hd1)
Regarder s'il met bien succeeded à tous les stages...
# grub> quit
Rebooter. Donc?
n°924843
chaced
Posté le 19-06-2007 à 15:54:37  profilanswer
Gf4x3443 a écrit :
ls -l /dev/disk/by-uuid/
Merci GF4 mais ca ne résout pas le problème puisqu'il me dit toujours que il n'a pas le fichier, donc il faut que je le lui donne pasque je vais pas taper b à chaque fois que je veux booter.
Je redémarre quand même au cas ou ce b me permette de lui dire de booter dessus par défaut.
Si tu as la liste des noyaux possibles, c'est qu'il arrive à lire le menu.lst. Fait voir ce menu.lst...
Merci fallait le savoir :)
n°924844
the_big_po​ulet
Flying chicken
Posté le 19-06-2007 à 15:55:37  profilanswer
bin tu trouves ça directement dans le Wiki en tapant UUID dans le champ de recherche en meme temps  [:spamafote]
n°924846
chaced
Posté le 19-06-2007 à 15:59:15  profilanswer
Ils auraient simplement du le mettre dans le man d'un coté...
n°924847
g-ridaz
Posté le 19-06-2007 à 16:02:41  profilanswer
# grub
# grub> setup (hd1)
# grub> quit
Rebooter. Donc?
Le TAB à la 3eme ligne ne marche pas
donc je n'arrive pas à afficher la liste, ne me faut-il pas être dans /boot/grub?
Message édité par g-ridaz le 19-06-2007 à 16:03:19
n°924848
Gf4x3443
Killing perfection
Posté le 19-06-2007 à 16:03:30  profilanswer
Et pour:
# grub> kernel / <TAB>
Edit: mouarff, je devine. Tape:
# mount
et donne le résultat.
Message édité par Gf4x3443 le 19-06-2007 à 16:04:09
n°924849
g-ridaz
Posté le 19-06-2007 à 16:04:55  profilanswer
/dev/sdb1 on / type ext3 (rw,errors=remount-ro)
proc on /proc type proc (rw,noexec,nosuid,nodev)
/sys on /sys type sysfs (rw,noexec,nosuid,nodev)
varrun on /var/run type tmpfs (rw,noexec,nosuid,nodev,mode=0755)
varlock on /var/lock type tmpfs (rw,noexec,nosuid,nodev,mode=1777)
procbususb on /proc/bus/usb type usbfs (rw)
udev on /dev type tmpfs (rw,mode=0755)
devshm on /dev/shm type tmpfs (rw)
devpts on /dev/pts type devpts (rw,gid=5,mode=620)
lrm on /lib/modules/2.6.20-16-generic/volatile type tmpfs (rw)
/dev/sda1 on /media/disk type ext3 (rw,errors=remount-ro)
nfsd on /proc/fs/nfsd type nfsd (rw)
rpc_pipefs on /var/lib/nfs/rpc_pipefs type rpc_pipefs (rw)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw)
n°924850
Gf4x3443
Killing perfection
Posté le 19-06-2007 à 16:07:23  profilanswer
root (hd1,0)
et maintenant, tab tab avec:
# kernel (hd1,0)/ <tab tab> , ca te retourne qqc?
n°924851
g-ridaz
Posté le 19-06-2007 à 16:09:31  profilanswer
Nope j'ai même un souci ave root qui est non reconnue en tant que commande, serait ce pasque je l'ai déjà fait une fois?
EDIT: OOps je n'étais pas en root cette fois dsl. Mais la touche TAB ne marche tjr pas
Message édité par g-ridaz le 19-06-2007 à 16:11:11
n°924852
Gf4x3443
Killing perfection
Posté le 19-06-2007 à 16:10:38  profilanswer
Euh, t'es bien dans l'environnement de grub hein?
Edit: avant de taper toutes ces commandes, tu dois avoir un
# grub>
avant.
Message édité par Gf4x3443 le 19-06-2007 à 16:11:18
n°924854
g-ridaz
Posté le 19-06-2007 à 16:11:29  profilanswer
Ouep 'grub>'
EDIT:
J'ai la même erreur 15 en cas de non appui sur TAB qu'au démarrage...
Message édité par g-ridaz le 19-06-2007 à 16:18:44
n°924856
Gf4x3443
Killing perfection
Posté le 19-06-2007 à 16:22:12  profilanswer
Rien compris.
Dis exactement ce que tu fais, avec les index (hdx,x) aussi.
n°924859
g-ridaz
Posté le 19-06-2007 à 16:29:41  profilanswer
En fait je suis ce que tu m'as dis je tape donc exactement:
http://pix.nofrag.com/44/48/9cc3f5771399344fdd98282f9a49t.jpg
(joli flou :))
Message édité par g-ridaz le 19-06-2007 à 16:30:31
n°924860
Gf4x3443
Killing perfection
Posté le 19-06-2007 à 16:30:57  profilanswer
Avec peut être un espace entre kernel et (hd1,0) ? [:itm]
n°924862
g-ridaz
Posté le 19-06-2007 à 16:36:37  profilanswer
Mais cette fois je retombe sur l'erreur15: File not Found puisque Tab ne marche pas.
n°924865
Gf4x3443
Killing perfection
Posté le 19-06-2007 à 16:41:53  profilanswer
Bon ben il semble que ton grub ne puisse lire sur ton disque sata, donc pas de support pour le chipset. Pas de chance...
Edit: et au moins il te détecte les deux disque quand tu fais l'autocomplétion après le "(hd" ? Donne toujours la liste...
Message édité par Gf4x3443 le 19-06-2007 à 16:43:51
n°924867
g-ridaz
Posté le 19-06-2007 à 16:43:30  profilanswer
Euh... c'est triste çà pasque ca veut dire que si je décide de me passer de disque IDE faut changer de mobo par exemple?
NE puis je pas lui indiquer en manuelle?
Message édité par g-ridaz le 19-06-2007 à 16:44:21
n°924868
Gf4x3443
Killing perfection
Posté le 19-06-2007 à 16:44:38  profilanswer
Même l'autocomplétion de disque ne marche pas? C'est balot  [:ginie]
n°924871
g-ridaz
Posté le 19-06-2007 à 16:47:17  profilanswer
J'appuie sur TAB au moment ou je tape : 'root (hd' et là ca ne marche pas? mais est ce bien le moment dont tu parles?
n°924877
Gf4x3443
Killing perfection
Posté le 19-06-2007 à 16:54:11  profilanswer
Oui.
Tu peux voir s'il arrive à reconnaitre l'arborescence avec kernel, notamment s'il trouve un disque, ou un fichier. Manifestement c'est pas le cas, mais n'ayant pas accès à la machine, je vais pas enchainer 35000 commandes pour voir ou est le problème.
Maintenant, je pense que le problème est opérateur dépendant, donc amha, c'est reboot sur sdb en principal, on sort le cd ubuntu et on fait un recovery avec le cd au démarrage.
Tu peux tenter aussi directement:
# grub> root (hd1,0) # je suis d'ailleurs surpris qu'il ne gueule pas ici, surtout s'il t'indique qu'il reconnait la partition...)
# grub> setup (hd1) # pour installer le mbr sur sdb
En croisant les doigts.
n°924881
g-ridaz
Posté le 19-06-2007 à 16:59:31  profilanswer
Mouais risques de niquer l'install... Pas grave j'attendrai de réinstaller, si je chnage de matos ou si j'ai vraiment du temsp à perdre ou autre chose à tester. Va falloir la trouver la raison :s pasque grosse flemme (pour l'instant pas besoin dc je m'en passe)
Merci beaucoup pour toute ton aide ;)
EDIT: j'éspère quand même que c'est pas juste un soucis de 'clavier' pourtant il me dit bien que TAB est utilisable au départ mais bon.
Message édité par g-ridaz le 19-06-2007 à 17:01:01
n°924887
Gf4x3443
Killing perfection
Posté le 19-06-2007 à 17:08:10  profilanswer
Ca te niquera rien du tout. Mais je doute que cela marche, le grub que tu as dans cet environnement est exactement le même que celui au boot. Donc tu te taperas la même erreur.
n°924888
g-ridaz
Posté le 19-06-2007 à 17:10:34  profilanswer
Ok je croyais que comme tu disais en croiant les doigts or comme je suis malchanceux avec les ordis.... Merci ;) je teste et je te dis.
EDIT:
grub> setup (hd1,0)
setup (hd1,0)
 Checking if "/boot/grub/stage1" exists... yes
 Checking if "/boot/grub/stage2" exists... yes
 Checking if "/boot/grub/e2fs_stage1_5" exists... yes
 Running "embed /boot/grub/e2fs_stage1_5 (hd1,0)"... failed (this is not fatal)
 Running "install /boot/grub/stage1 (hd1,0) /boot/grub/stage2 p /boot/grub/menu.lst "... succeeded
Done.
grub>
Message édité par g-ridaz le 19-06-2007 à 17:12:01
n°924898
the_big_po​ulet
Flying chicken
Posté le 19-06-2007 à 17:22:39  profilanswer
et la tout le monde attend l'edit2  [:dents]
Message édité par the_big_poulet le 19-06-2007 à 17:22:47
n°924907
g-ridaz
Posté le 19-06-2007 à 17:41:21  profilanswer
ben ca marche pas quoi...
n°924910
the_big_po​ulet
Flying chicken
Posté le 19-06-2007 à 17:43:40  profilanswer
ah bin moi je m'étais arrêté à succeeded  [:cosmoschtroumpf]
n°924913
g-ridaz
Posté le 19-06-2007 à 17:58:07  profilanswer
Ca semble ne pas suffire :d (les failed but not fatal seraient ils la cause?)
J'avoue que n'y connaissant que dalle je fais un peu à l'aveuglette sans les conseils de chaced et Gf4
n°924969
pactole@
Posté le 19-06-2007 à 21:07:37  profilanswer
ça marche la mise en hibernation chez vous ?
j'ai une nvidia j'ai pas retesté mais j'ai l'impression que c'est à cause du driver nvidia, y compris quand beryl n'est pas actif.
n°924973
pactole@
Posté le 19-06-2007 à 21:14:01  profilanswer
burn2 a écrit :
Mais bon à paremment ça n'arrangera pas mon pb.
This driver does not fix the black window bug issue that some Beryl/Compiz users experience (still a few more months until it will likely be resolved).
c'est justement ce que j'essayer de résoudre lol. Mais bon vu que ça ne me le fait pas trop souvent. c'est pas bien grave.
ça me le fait aussi quand j'ai beaucoup de fenetres ouvertes
n°924975
the_big_po​ulet
Flying chicken
Posté le 19-06-2007 à 21:39:33  profilanswer
advanced beryl option > rendering platform > force aiglx
c'est la seule soluce que j'aie trouvé pour le moment [:spamafote]
n°924981
arkrom
note, ca passait c'etait beau
Posté le 19-06-2007 à 22:39:24  profilanswer
bonsoir a tous j ai descidé de me mettre a linux, j ai donc assemblé une config prevu pour, histoire de pouvoir formater sans aucun remord .
comme me l'avais conseillé un ami qui utilise ubuntu depuis 1 an, j'ai formaté et partionné le DD depuis le live CD ( 2 partition EXT3 + 1 swap + 1pour windows ) puis installé windows XP ( en NTFS  ) et enfin installé ubuntu, l install c est passé (quasi ) sans problème, juste une legere erreur dans les point de montage qui m'a fait recommencer la procedure depuis le depart  :sweat:  .
le grub a detecté mon windows du premier coup et le multiboot s'est mis en place tous seul
j'ai effectué les mise a jours auto de linux Et de windows et tous marche toujours parfaitement
maintenant je sollicite votre aide pour qlq petit problèmes secondaires:
-je n'ai trouvé aucun drivers convenable pour ma CG integré VIA S3, si qlq a un tuyau
-a part firefox et open office et  WINE, quel sont les soft et utilaires qui vont m'etre utile voir indispensable
-on m'a parlé de noyau specifique selon le type de CPU, vous savez lequel est le meilleurs pour un athlon XP core barton socket A
n°924989
Kortex@HFR
Qu'ils sont cons ces lamas !!!
Posté le 20-06-2007 à 00:12:36  profilanswer
Je te conseille le kernel lowlatency, qui est patché pour un peu tout et permet de réduire les latences, comme son nom l'indique. Si tu envisage un peu de MAO, c'est même indispensable. Pour ma part, depuis que je l'ai testé, je l'ai approuvé et adopté pour toute utilisation. En serveur, je sais pas ce que ça donne, mais pour le reste, c'est du bon je pense.
En ce qui concerne le kernel spécifique K7, il me semble qu'il a été abandonné et remplacé par le generic, ou le lowlatency.
n°924994
burn2
Pour ceux qui viendront après
Posté le 20-06-2007 à 00:45:46  profilanswer
Confirmé. LE noyau K7 est remplacé par le générique ;)
n°924995
arkrom
Posté le 20-06-2007 à 00:52:49  profilanswer
donc le generic fournie par fiesty est le meilleur possible, .... un problème  de reglé merci a vous deux
n°925020
exhortae
Membre du Cartel des Médecins
Posté le 20-06-2007 à 08:50:25  profilanswer
je suis poas sûr mais je crois que les drivers via sont déjà intégrés au noyau
sinon il te faudra remplacer msn , perso j'utilise pidgin (mais j'ai du le compiler) car il n'était pas dans les dépôts officiels (mais y'a moyen d'ajouter des dépôts).
Message édité par exhortae le 20-06-2007 à 09:21:43
encore un topic sur les températures[RESOLU] mount_data version 1919251317 is not supported
linux version disquetteLa version 10 de la mandrake dispo en magazine?
Topic Modifier les partitions sous Linux ("Partition Magic")Reiser 4 -- Version finale out - Faq : " Montre moi tes FS"
[Topic Unique] ROX-Filer[hébergement] serveur dédié
[Topic unique] Rox (-Filer) + X Files Explorer[Linux] Je recherche la version de Woody sur DVD
Plus de sujets relatifs à : [UBUNTU] 25.10 Questing Quokka'' - Topic dédié
