3917 connectés
 Page :   1  2  3  4  5  ..  748  749  750  ..  775  776  777  778  779  780
[DEBIAN] - Intégristes barbus, |337, femmes nues...
n°1501696
rat de com​bat
attention rongeur méchant!
Posté le 12-07-2025 à 08:20:31  profilanswer
C'est un SSD (de sauvegarde justement :o ) branché en externe (USB C). J'ai testé un autre port et câble. J'espère que c'est juste le boîtier externe, faut que je fasse plus de tests...
n°1501705
rat de com​bat
Posté le 12-07-2025 à 17:24:24  profilanswer
Et merde, visiblement c'est le SSD qui est foutu. :kaola:
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.1.0-37-amd64] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model:     WD Blue SA510 2.5 1000GB
Serial Number:    2xxxxxxxxxxxxxx
LU WWN Device Id: xxxxxxxxxxxxxxx
Firmware Version: 52020100
User Capacity:    1.000.204.886.016 bytes [1,00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
TRIM Command:     Available, deterministic
Device is:        Not in smartctl database 7.3/5319
ATA Version is:   ACS-4, ACS-2 T13/2015-D revision 3
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sat Jul 12 17:16:47 2025 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: FAILED!
Drive failure expected in less than 24 hours. SAVE ALL DATA.
No failed Attributes found.
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
     was never started.
     Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0) The previous self-test routine completed
     without error or no self-test has ever
     been run.
Total time to complete Offline
data collection:   (    0) seconds.
capabilities:     (0x71) SMART execute Offline immediate.
     No Auto Offline data collection support.
     Suspend Offline collection upon new
     command.
     No Offline surface scan supported.
     Self-test supported.
     Conveyance Self-test supported.
     Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
     power-saving mode.
     Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
     General Purpose Logging supported.
Short self-test routine
recommended polling time:   (   1) minutes.
Extended self-test routine
recommended polling time:   (  10) minutes.
Conveyance self-test routine
SMART Attributes Data Structure revision number: 0
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  5 Reallocated_Sector_Ct   0x0032   100   100   010    Old_age   Always       -       20
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       1
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       23
165 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       1048589
166 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
167 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       24
168 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       1
169 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       300
170 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       20
171 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
172 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
173 Unknown_Attribute       0x0032   100   100   005    Old_age   Always       -       0
174 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       3
184 End-to-End_Error        0x0032   100   100   097    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
194 Temperature_Celsius     0x0022   100   100   014    Old_age   Always       -       29 (Min/Max 16/32)
199 UDMA_CRC_Error_Count    0x0032   100   100   000    Old_age   Always       -       0
230 Unknown_SSD_Attribute   0x0032   100   100   000    Old_age   Always       -       4294967297
232 Available_Reservd_Space 0x0033   100   100   004    Pre-fail  Always       -       91
233 Media_Wearout_Indicator 0x0032   100   100   000    Old_age   Always       -       324
234 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       257
241 Total_LBAs_Written      0x0030   253   253   000    Old_age   Offline      -       268
242 Total_LBAs_Read         0x0030   253   253   000    Old_age   Offline      -       2
244 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
Warning! SMART ATA Error Log Structure error: invalid SMART checksum.
SMART Error Log Version: 1
No Errors Logged
C'est quoi ce délire?? Le truc a été branché genre 20 fois et a dû voir genre 500Go (et encore) écriture maxi?? Y'a un firmware bomb dans ces WD Blue?
(Oui, branché avec un tout autre adaptateur SATA-USB que tout à l'heure.)
*râle* :o
EDIT: Bon bah visiblement y'a un bug critique dans le FW. En bricolant y'a moyen de faire une màj depuis Manchot OS aussi, mais est-ce que ça va réanimer mon disque?? Rhaaaaa.
EDIT2 :o Quelle marque prendre à part Crucial (dont j'ai déjà un SSD et il vaut mieux avoir des disques/fabriquants différents!)? C'est pour un SSD 1To SATA. WD Green, Kingston (que 960Go), Lexar, ... ???
Message édité par rat de combat le 12-07-2025 à 17:52:48
n°1501710
thana54
made in concept
Posté le 12-07-2025 à 19:37:45  profilanswer
J'ai du crucial mx500, bx500, du sandisk extreme, ca tient bien pour le moment en externe.
Mais bon, le matos d'il y a quelques années doit pas avoir les mêmes perfs/endurances que les "mêmes" modèles achetés maintenant (changement de puces/controlleurs sans prévenir)
Message édité par thana54 le 12-07-2025 à 19:38:45
n°1501711
li1ju
ho putain, ça tourne !
Posté le 12-07-2025 à 19:47:03  profilanswer
dommage tous ces "unknown attribute" :/
fais un "sudo update-smart-drivedb" puis à nouveau un smartctl, voir si tu peux avoir le nom des attribus, ça t'aidera peut etre :)
la on voit que ya eu 20 secteurs réalloués. en soit ca ne devrait pas etre grave.
et on voit que la valeur de "233 Media_Wearout_Indicator" est encore à 100, soit 100% encore utilisable (normalement cette valeur baisse progressivement, faut s'inquieter quand elle est trop basse)
Message édité par li1ju le 12-07-2025 à 19:53:52
n°1501712
rat de com​bat
Posté le 12-07-2025 à 20:00:45  profilanswer
D'après ce que j'ai vu Sandisk (que j'apprécie pour les clés USB) a racheté la division SSD de WD, du coup j'hésite à prendre du Sandisk pour le remplacement... Et Crucial j'en ai plusieurs, c'est du bon matos mais pour les sauvegardes faut pas prendre deux fois la même chose...
Merci, mais c'est le firmware qui a merdé et (plus ou moins) détruit le SSD, c'est un problème connu mais dont j'ignorais l'existence jusqu'à tout à l'heure... Dans son état "normal" (FW pas encore crashé) le résultat smartmontools est très complet pour ce SSD (qui doit dater de 2023 ou du genre).
La question c'est vraiment par quoi (hors Crucial) le remplacer, car WD pour moi c'est mort. :kaola:
n°1501713
thana54
made in concept
Posté le 12-07-2025 à 20:09:55  profilanswer
Essaye de trouver un ssd avec cache pour un sdd qui doit rester en externe. J'ai un fikwot 4To DRAM-less, c'est une limace en disque externe (ca varie trés fortement entre 180Mo et 10Mo), il est maintenant dans un portable ca va "mieux" mais c'est l'os qui gère le "cache" en ram du pc.
Idem, j'ai un "nvme" WD blue c'est une limace en externe. En fait y a plus rien de bien en nvme ou sata externe à bon prix. J'ai toujours pas trouvé de remplaçant au samsung 970 EVO plus 1To et 2To, les gen4 sont au mieux du même niveau et à cache moins gros et plus cher.
n°1501714
li1ju
Posté le 12-07-2025 à 20:13:38  profilanswer
ha ok. rip :/
perso j'ai eu des mauvaises experiences avec les crucial
jamais eu de probleme avec des samsung.
n°1501715
rat de com​bat
Posté le 12-07-2025 à 20:15:34  profilanswer
"fikwot" (le nom m'inspire pas confiance déjà...) c'est du bas de gamme / limite "no name" non? :o
Cache ou pas cache bof, c'est pour faire des sauvegardes de temps en temps, pas pour une utilisation constante et intensive... C'est vraiment la fiabilité (du SSD et donc aussi du fichu firmware) qui importe, pas la vitesse.
EDIT: Pour préciser: En principe j'utilise encore des HDD pour mes sauvegardes, mais là c'est la sauvegarde "de la dernière chance" qui est stockée à un autre endroit (donc pas chez moi) pour les catastrophes genre feu etc. Et comme cette sauvegarde "voyage" régulièrement en voiture je préfère un SSD plutôt que un HDD sensible au niveau mécanique etc...
EDIT: @li1ju: Noté pour Samsung. :jap:
Message édité par rat de combat le 12-07-2025 à 20:18:17
n°1501716
thana54
made in concept
Posté le 12-07-2025 à 20:22:55  profilanswer
Oui c'est clairement de l'entrée de gamme, le seul à l'époque qui proposait du 4To à moins de 200€. C'est pour du stockage temporaire le temps d'encoder des vidéos (ca bouffe de la place les bluray :o) et de l'envoyer sur du raid + sauvegarde sur plus gros hdd.
n°1501727
darxmurf
meow
Posté le 12-07-2025 à 22:16:10  profilanswer
     was never started.
     been run.
     command.
     power-saving mode.
No Errors Logged
*râle* :o
Regarde pour mettre à jour le FW il y a des disques qui repartent après ça.
Sinon pour les marques, Samsung, Kingston ça marche pas mal et surtout, ils fabriquent aussi de la ram donc sont au point sur ce type de matos.
Perso je ne prends jamais de no name, genre les trucs de 4Tb à 200 bal, jamais [:tinostar]
Des trucs - flickr - Instagram
n°1501731
thana54
made in concept
Posté le 13-07-2025 à 09:03:00  profilanswer
J'en avais marre de me trainer que 500Go plutôt rempli sur lequel j'avais jamais la place que je recherchais, j'en étais même venu à faire des copies sur carte sd..., et je voulais pas payer plus de 200 balles, j'ai tenté, j'ai vu où ca marche "mieux" mais je ne retenterai pas.
n°1501735
burn2
Pour ceux qui viendront après
Posté le 13-07-2025 à 10:26:19  profilanswer
Niveau ssd perso je ne prends que des samsungs, jamais eu de soucis (même si même là il y a eu une série de samsung qui au tout début ont eu des soucis de firmware, donc ça touche tout le monde).
Sandisk j'en utilisais quelques un avant le rachat par WD.
Je crois d'ailleurs que WD arrête la partie SSD pour se concentrer sur les DD, et que sandisk retrouve son "indépendance" niveau SSD donc peut-être qu'ils redeviendront aussi fiables qu'avant.
n°1501737
rat de com​bat
Posté le 13-07-2025 à 13:25:49  profilanswer
Je viens de commander un SSD Samsung 1To pour remplacement. Le truc WD je vais tenter une màj firmware pour au mieux récupérer l'"historique" des sauvegardes (dans l'état actuel mount échoue), mais je ne fais plus confiance à ce SSD même si il devait repartir... (Edit: Je vais par contre attendre la réception du nouveau SSD avant de bricoler, sachant que je vais devoir brancher le SSD en interne aussi pour màj et vu l'emplacement de ma tour c'est pas tout simple... Oui j'ai pas d'autre tour de dispo, c'est pas digne de hfr, je sais. :o )
Pour WD et Sandisk, quand on regarde chez WD il faut choisir HDD/SSD et pour ces derniers on attérit chez Sandisk.
Message édité par rat de combat le 13-07-2025 à 13:27:50
n°1501750
thana54
made in concept
Posté le 14-07-2025 à 10:23:22  profilanswer
un honteux bidouillage c'est digne de hfr :o
n°1501817
darxmurf
meow
Posté le 17-07-2025 à 10:59:38  profilanswer
Pour ton firmware, on dirait que fwupdmgr gère le disque, tu peux potentiellement le flash depuis là. J'ai planté un WD blue dans ma machine pour tester, il me le trouve
├─WD Blue SA510 2.5 1000GB:
│     Device ID:          xxxxx
│     Summary:            ATA drive
│     Current version:    52048100
│     Vendor:             Western Digital (OUI:001b44, ATA:0x101C)
│     Serial Number:      xxxx
│     GUIDs:              5d599dac-3937-5acf-8720-0853fa005c37 ← IDE\WD_Blue_SA510_2.5_1000GB________________52048100
│                         4e23ea8e-2850-53de-9dd8-ada1bcb77acf ← IDE\0WD_Blue_SA510_2.5_1000GB________________
│                         b0bdbd65-cd39-5403-a863-cad02113f44b ← WD Blue SA510 2.5 1000GB
│     Device Flags:       • Internal device
│                         • Updatable
│                         • System requires external power source
│                         • Needs a reboot after installation
│                         • Device is usable for the duration of the update
│                         • Can tag for emulation
n°1501819
rat de com​bat
Posté le 17-07-2025 à 13:03:52  profilanswer
Je vais regarder ça, les (anciennes) infos sur internet disaient que ça ne fonctionne pas avec fwupdmgr. :??: De toute façon faut que je planque le truc dans mon PC en SATA directement (donc accéder au PC etc) et dans le doute autant partir sur le logiciel fourni par WD. J'aimerai pouvoir récupérer les données == l'historique des sauvegardes.
EDIT: Pas de SA510 dans la BDD: https://fwupd.org/lvfs/search?value=sa510
Mais comme - une fois de plus - La Poste ne tient pas ses promesses j'aurais le nouveau disque que demain au mieux. (Et j'attend d'avoir reçu et testé le nouveau avant de bricoler le WD.)
Je ferai un retour. :jap:
Message édité par rat de combat le 17-07-2025 à 13:53:01
n°1501869
rat de com​bat
Posté le 19-07-2025 à 14:33:11  profilanswer
Ah mais! :kaola:
J'ai tenté un flash du firmware du WD vu que j'ai (enfin) reçu le Samsung. Donc créer une clé USB, sortir la tour de son emplacement, DÉBRANCHER LE SSD SYSTÈME, brancher le WD, booter depuis clé USB, lancer le bazar (interface digne des années 90 par ailleurs):
firmware download completed with error
error code: 6
error subcode: 20740
message: device error detected, status 51h, error 4h
Et maintenant? Je pense que vais copier l'historique des sauvegardes depuis le second SSD, le SSD WD finira détruit aux DEEE et WD sur ma liste noire.
:pfff:  :pfff:  :pfff:
J'ai pas trouvé ces codes d'erreurs sur le net, mais si quelqu'un sait quelque chose... :jap:
EDIT: La tentative de màj firmware semble avoir achevé le SSD! J'arrive même plus à lire des données "brutes" avec dd! Donc PRUDENCE si vous êtes dans cette situation!
Message édité par rat de combat le 19-07-2025 à 14:35:02
n°1501875
darxmurf
meow
Posté le 19-07-2025 à 17:10:24  profilanswer
Ah mais! :kaola:
error code: 6
Le disque est détecté ou pas? Si oui, ddrescue
Après, une erreur disk ça arrive à toutes les marques donc c'est un peu le pas de bol
Message édité par darxmurf le 19-07-2025 à 17:10:58
n°1501876
JerryCrazy
Le plus crazy des crazy
Posté le 19-07-2025 à 20:35:39  profilanswer
Debian 13.0 "Trixie" sort le 9 août : https://lists.debian.org/debian-dev [...] 00003.html
[:lynk]
Message édité par JerryCrazy le 19-07-2025 à 20:37:05
My Digital Life - Ferrovia - FerroviaClub - Jeux Linux
n°1501877
rat de com​bat
Posté le 19-07-2025 à 20:50:44  profilanswer
détecté oui, mais impossible de lire quoi que ce soit (bon j'ai pas testé ddrescue, mais avec dd aucune chance). Après comme je disais c'est des sauvegardes, donc pas de données de perdues (directement), "juste" l'historique de sauvegarde. Je vais copier depuis l'autre disque et ça devrait être bon. Même si ddrescue peut faire quelque chose, ça risque de prendre 3 semaines pour un SSD 1To...
Non, à la base c'était un firmware foireux et un système de màj de firmware digne des années 90 et qui ne fonctionne pas. Après certes, des soucis de firmware y'a pas ça que chez WD, ça je te l'accorde.
n°1501881
jeffk
Posté le 19-07-2025 à 23:20:47  profilanswer
Ouai j'ai vu, pas de bol j'ai formaté toutes les machines sur 12 avant les vacances (je suis prof), car j'arrivais pas lancer l'installation sur 13, en prenant le Netboot le plus récent de Trixie et mon miroir perso j'avais "The kernel used by this installer does not match the latest kernel available in the archive".
Message édité par jeffk le 19-07-2025 à 23:21:25
Le topic des badistes : 5 grammes de plumes, des tonnes d'émotions.
n°1501882
burn2
Posté le 19-07-2025 à 23:45:33  profilanswer
Ah on a une date. :D
Bon ben vu les dispos et les températures, installation vers septembre pour moi donc.
Message édité par burn2 le 19-07-2025 à 23:47:18
n°1501883
MilesTEG1
Posté le 20-07-2025 à 00:14:51  profilanswer
Ce sera quoi la procédure pour MAJ depuis 12.x ?
(Désolé de la question de noob  :o )
Mes ventes : [FeedBack] http://forum.hardware.fr/hfr/Achat [...] 4599_1.htm
n°1501884
jeffk
Posté le 20-07-2025 à 00:33:13  profilanswer
Code :
  1. sudo apt update && sudo apt dist-upgrade --autoremove -y
  2. sudo reboot (si nouveau kernel)
  3. sudo sed -i 's/bookworm/trixie/g' /etc/apt/sources.list
  4. sudo apt update
  5. sudo apt upgrade --without-new-pkgs
  6. sudo apt full-upgrade
  7. sudo reboot
  8. sudo apt autoremove --purge
faire attention aux source list custom
Message édité par jeffk le 20-07-2025 à 00:36:30
n°1501885
MilesTEG1
Posté le 20-07-2025 à 00:35:38  profilanswer
jeffk a écrit :
Code :
  4. sudo apt update
  7. sudo reboot
Merci  :jap:
Tu veux parler du nouveau format de sources.list ?
En debjesaisokusquoi  ?
Y a t’il un convertisseur de l’ancien format au nouveau ? (Pour les dépôts qui ne sont pas ceux de Debian OS)
n°1501887
jeffk
Posté le 20-07-2025 à 00:39:50  profilanswer
Non je voulais parler des sources list custom dans sources.list.d/
Par exemple un virtualbox.list qui aurait comme valeur :
Code :
  1. deb [arch=amd64 signed-by=/usr/share/keyrings/oracle-virtualbox-2016.gpg] https://download.virtualbox.org/virtualbox/debian bookworm contrib
C'est pas rare que les repo custom aient des cannaux par version comme tu peux le voir en cliquant là : https://download.virtualbox.org/vir [...] ian/dists/
C'est pareil pour dropbox par exemple avec
Code :
  1. deb https://linux.dropbox.com/debian/ bookworm main"
https://linux.dropbox.com/debian/dists/
Et sinon oui apt a un convertisseur, lors d'un apt update par exemple il va demander si oui ou non tu veux convertir.
La dernière fois que j'ai installé 13 "fresh", à la fin de l'installation il y a encore les "vieux" sources list, et c'est lors du premier update qu'il te demande si oui ou non tu veux convertir.
Message édité par jeffk le 20-07-2025 à 00:43:14
n°1501888
hido45
Posté le 20-07-2025 à 00:56:59  profilanswer
Pour les détails sur la migration voir ici :
https://www.debian.org/releases/trixie/releasenotes
n°1501891
404 Not Fo​und
人の夢は!!!終わらねェ!!!!
Posté le 20-07-2025 à 09:33:29  profilanswer
jeffk a écrit :
Code :
  1. sudo apt upgrade --without-new-pkgs
  2. sudo apt full-upgrade
Pourquoi pas en une passe ? :??:
n°1501892
Kyjja
Y'a pot !
Posté le 20-07-2025 à 09:45:09  profilanswer
Pouet
Problème de droits lors du montage d'un dossier NAS SMB/CIFS [:kyjja:3]
Extrait de /etc/fstab :
Code :
  1. //openmediavault.local/multimedia/ /mnt/NAS_Multimedia cifs credentials=/home/username/.smbcredentials 0 0
Les partages se montent bien, mais avec le user root. Je dois donc passer sudo dès que je veux modifier des fichiers dedans.
=> Quelle config dois-je adopter pour que mon user habituel puisse R/W dans ces dossiers montés ?
n°1501894
burn2
Posté le 20-07-2025 à 10:01:27  profilanswer
Pour être sûr que le socle soit à jour avant de rajouter les nouveaux pgms.
Perso j'ai toujours fais comme ça sur toutes mes majs.
n°1501895
404 Not Fo​und
人の夢は!!!終わらねェ!!!!
Posté le 20-07-2025 à 10:37:57  profilanswer
Le dependency tree ne suffit pas pour gérer le problème ?
Message édité par 404 Not Found le 20-07-2025 à 10:38:09
n°1501901
rat de com​bat
Posté le 20-07-2025 à 13:25:53  profilanswer
Ah la joie de la gestion des droits d'accès sous Linux, toujours un plaisir. :o
Je connais pas le SMB, mais perso je regarderais déjà à qui appartient /mnt/NAS_Multimedia juste au pif. :o
n°1501902
rat de com​bat
Posté le 20-07-2025 à 13:27:39  profilanswer
Malgré les réponses, avant un full-upgrade je conseille VIVEMENT de lire le manuel fourni avec la nouvelle version et aussi de faire une sauvegarde complète du système avant. En effet il y a parfois des subtilités à savoir et un upgrade qui se passe mal ça peut être très casse-tête à réparer (au point de devoir tout réinstaller).
n°1501903
li1ju
Posté le 20-07-2025 à 13:28:56  profilanswer
pluzun :D
dans ton fichier .smbcredentials, tu dois avoir un username et password
donc le dossier de montage doit appartenir au user en question.
démonte ton partage, puis :
sudo chown tonuser:tongroup /mnt/NAS_Multimedia
et remontes le.
Message édité par li1ju le 20-07-2025 à 13:29:18
n°1501905
rat de com​bat
Posté le 20-07-2025 à 13:34:51  profilanswer
Ah et tant qu'on y est je vérifierai aussi les droits d'accès au fichier .smbcredentials :o Car il me semble que j'ai dû constater une fois que le ~ était lisible par tout le monde sur une config, mais c'était peut-être une erreur de config?
n°1501907
Kyjja
Y'a pot !
Posté le 20-07-2025 à 14:04:35  profilanswer
Hum.
Dès que le montage se fait, le own passe à root:root
Ca sent le problème de config dans fstab cette affaire [:kyjja:3]
Edith : ;smbcredential est forcément lu, puisque j'ai accès au contenu du dossier monté (mais tout est owné par root:root)
Message édité par Kyjja le 20-07-2025 à 14:06:40
n°1501909
rat de com​bat
Posté le 20-07-2025 à 14:11:17  profilanswer
Perso j'ai eu ces histoires de droits X fois avec des DD/clé externes et à chaque fois je galère. :o
Sinon ton smbcredential est forcément lu oui, mais il doit être uniquement lu par le système. Il ne doit pas être lisible pour n'importe qui (les autres utilisateurs du PC). Tu peux toujours faire un ls -l dessus pour vérifier.
Edit: Le moteur de recherche me sort p.ex. ceci https://askubuntu.com/questions/143 [...] force-user ; à priori une config à faire au niveau du serveur SMB??
Message édité par rat de combat le 20-07-2025 à 14:13:49
n°1501910
Kyjja
Y'a pot !
Posté le 20-07-2025 à 14:14:00  profilanswer
chmod 600 :o
n°1501911
rat de com​bat
Posté le 20-07-2025 à 14:14:35  profilanswer
600 c'est très bien déjà pour le credentials. Tu as vu mon Edit pour le problème initial?
n°1501913
Kyjja
Y'a pot !
Posté le 20-07-2025 à 15:36:52  profilanswer
Ouais :o
C'est pas un soucis du partage :
- l'accès via smb est ok en r/w depuis ce pc et cet user
- idem avec un client Windows 11
NB : Système de fichier en ext4, apparemment ça peut être casse pied niveau autorisation.
Les permissions des points de montages sont reset en drwxr-xr-x  2 root root lors du montage (alors que j'ai chmod 777 et chown monuser/monuser le point de montage )
n°1501914
darxmurf
meow
Posté le 20-07-2025 à 15:52:33  profilanswer
Kyjja a écrit :
Pouet
Code :
Essaie de modifier tes options de montage en
user,credentials=/home/username/.smbcredentials
Message édité par darxmurf le 20-07-2025 à 16:01:24
[neewbe debian]Package mplayer pour debian Woodydebian ou slackware?
du gnu debian dans une sauce apple melangez avec du freebsd et on a[Debian] probleme avec Xfree
[Debian] comment installer KDE 2 voir KDE3 si possible ??comment installe-t-on une debian
disquette de boot debianinstall carte reseau ISA debian
[ncurses] DEBIAN - je peux pas configurer mon noyau Sniff[Debian] stable / unstable
Plus de sujets relatifs à : [DEBIAN] - Intégristes barbus, |337, femmes nues...
