1743 connectés
 Page :   1  2  3  4  5  ..  1835  1836  1837  ..  2228  2229  2230  2231  2232  2233
[Topic unique] Claviers mécaniques
n°996110
Posté le 01-05-2020 à 10:49:49  answer
Et ceci, on en parle ?
https://www.allthingsergo.com/wp-co [...] GP4650.jpg
Posté le 01-05-2020 à 10:49:49  profilanswer
n°996114
_PixelNinj​a
⌨ #Ω60
Posté le 01-05-2020 à 12:03:02  profilanswer
Puree a écrit :
Clairement, perso je me demande pourquoi pas comme ça aussi :
https://i.ytimg.com/vi/nsJWVVbGc8M/maxresdefault.jpg
Le nombre de mecs que tu vois sur les réseaux sociaux adopter ce genre de posture de merde qui te défonce les coudes, ça fait peur.
Dr. Levi Harrison sur le sujet :
These are positions I commonly see in individuals who play CSGO, and it has even appeared in other games/genres. This particular style of playing forces the elbows away from the body, and in turn, pulls the head and neck forward. Simply put, these positions, though they may benefit your play in the short term, may potentially lead to the development of:
• Wrist Tendonitis – This wrist/forearm alignment can lead to the unnatural flexion of the wrist, hence, causing additional stress with each press.
• Tennis Elbow – Again, being out of alignment, and RSI in general can be a compounding issue, and can cause pain in the elbow and upper forearm.
• Neck & Shoulder Pain – The angling of the arm/shoulder in these particular positions can cause additional stress on the shoulder, as it forces the user’s shoulder/arm into an unbalanced, ergonomically poor position.
Again, as previously mentioned, you may not feel the harm of these play styles in the short term, however, during long hours of practice, scrimmaging, or competition prep, this may not only deteriorate your performance, but also your health.
n°996115
Jubijub
Parce que je le VD bien
Posté le 01-05-2020 à 12:08:03  profilanswer
Merci pour les réponses étayées. Je vais donc continuer sans.
Jubi Photos : Flickr - 500px
n°996116
- gab
Posté le 01-05-2020 à 12:27:14  profilanswer
J'ai jamais compris pourquoi ce gimmick de posture est aussi répandu [:gnub]
Je veux dire, pas besoin de l'adopter, j'ai mal rien qu'en la regardant [:zedlefou:1]
n°996117
Posté le 01-05-2020 à 12:33:10  answer
Parce qu'un PGM l'a adoptée et que tous les kikous de 16 ans qui rêvent de devenir PGM se sont mis à l'adopter parce que si un PGM se tient tout de travers c'est que ça permet de farguer plus :o
C'est un peu comme tout le délire du matos pour "gamers", c'est juste de la merde mais comme des PGM les utilisent (ils sont payés pour) et bien on a tout une génération d'idiots qui achètent du Razer, Fnatic et j'en passe :/
Message édité par Profil supprimé le 01-05-2020 à 12:33:30
n°996118
Kenshineuh
Posté le 01-05-2020 à 12:36:45  profilanswer
Non, cela vient de l'époque des LAN de CS 1.6 entre autre. Les claviers TKL n'étaient pas répandu et il fallait placer beaucoup de joueur sur de tout petit bureau. Donc pour avoir un plus grand surface pour la souris, on mettait le clavier à la vertical.
Et certains anciens joueurs continuent de jouer comme ça par habitude.
Message édité par Kenshineuh le 01-05-2020 à 12:36:58
n°996119
- gab
Posté le 01-05-2020 à 12:37:47  profilanswer
Ça a du sens :jap:
n°996120
_PixelNinj​a
⌨ #Ω60
Posté le 01-05-2020 à 12:43:34  profilanswer
Les joueurs qui utilisent des full size dans les e-sports le font pour gagner de la place horizontale sur le bureau et certains avancent que c'est plus confortable (me demande pas j'en sais rien :o). Les gens le reproduisent par mimétisme. Le problème c'est l'absence de réflexe de faire des recherches sur le sujet. C'est la même pour les spacebar inversées — c'est reproduit parce que RandomFrankP et consorts le font ; leur public suit. On est au point où les gens disent que c'est plus ergonomique... C'est chaud.
Message édité par _PixelNinja le 01-05-2020 à 12:45:22
n°996121
Posté le 01-05-2020 à 12:50:36  answer
Il y a un effet de mimétisme quand même :/
Parce que j'ai pas mal joué à des FPS avec des full ssize et je n'ai jamais mis mon clavier de travers :o
Après c'est un fait, j'avais également mis ma spacebar  en inversé pour faire comme, mais bon, avec un peu de temps je me suis rendu compte qu'en plus d'être un non sens, c'était inconfortable quand on a une posture correcte :)
n°996122
giHefca
occupé à ne rien faire
Posté le 01-05-2020 à 13:09:09  profilanswer
https://heavymetalkeyboards.com/
Ca doit pas être terrible un boitier comme ça non ?
En plus avec du powder coating, ça ne risque pas de se barrer au fil du temps ?
Message cité 4 fois
Message édité par giHefca le 01-05-2020 à 13:09:47
n°996123
sackboy22
Posté le 01-05-2020 à 13:12:03  profilanswer
RAS sur ma souris Clutch de Fnatic, les marques "gamer" font parfois du bon matos :jap:
n°996126
- gab
Posté le 01-05-2020 à 13:31:45  profilanswer
Le powder coating, c'est de la peinture cuite au four, c'est franchement solide. Faut vraiment donner des coups pour abîmer.
n°996127
giHefca
Posté le 01-05-2020 à 13:41:48  profilanswer
C'était déjà comme ça il y a 20 ans en LAN (et souvent chez soi)
Low sensi pour la souris (40-50cm d'amplitude), clavier full size, peu de place, chaise/table pas à la bonne hauteur
Il y a la théorie et la pratique [:spamafote]
n°996131
giHefca
Posté le 01-05-2020 à 13:52:31  profilanswer
https://youtu.be/UtMnqarm2iM
 [:delarue5]
n°996132
- gab
Posté le 01-05-2020 à 13:57:25  profilanswer
Honnêtement dans le genre industriel je trouve ça pas mal, si le 95 est compatible avec un pcb de 1800 ça me tenterait presque :D (en fonction du prix, sinon je le fais pour moi en alu)
Message édité par - gab le 01-05-2020 à 13:57:55
n°996133
404 Not Fo​und
Posté le 01-05-2020 à 13:57:55  profilanswer
Quand je jouais beaucoup aux FPS, j'inclinais légèrement le clavier pour avoir le poignet gauche droit. Ca dépend de ta position, en particulier l'angle des coudes "vu de haut".
C'est plus résistant que la peinture mais moins que l'anodisation ...
n°996177
Zippopotam​me
Posté le 02-05-2020 à 09:56:39  profilanswer
C'est ce qu'on retrouve sur les vélos genre de peinture ?
n°996180
Puree
Posté le 02-05-2020 à 10:33:51  profilanswer
Mes boîtiers caselabs c’est du powder coating. Je les ai depuis des années et c’est comme au premiers jours et je les déplace régulièrement dans la maison
Mes Achats/Ventes
n°996187
patpro
BOfH
Posté le 02-05-2020 à 12:52:21  profilanswer
Il claque en jaune, j'adore :)
Je suis root, si vous me voyez rire, vérifiez vos backups...
n°996190
_MoebiuS_
Paranoïd Androïd
Posté le 02-05-2020 à 13:31:56  profilanswer
Mmmm, ça serait bien tentant, mais c'est encore un coup à avoir une case qui va attendre pendant 9 mois ses touches :D
https://heavymetalkeyboards.com/col [...] ts/hmkb-90
https://oblotzky.industries/product [...] 4170337412
The Magic Words are Squeamish Ossifrage.
n°996193
giHefca
Posté le 02-05-2020 à 13:40:21  profilanswer
J'en ai pris un en beige finalement
Le jaune me plait bien mais je n'ai pas beaucoup de sets pour l'accompagner (et comme j'aime bien changer souvent de sets :o)
n°996196
jubeat
Mais pousse toi !
Posté le 02-05-2020 à 14:00:26  profilanswer
Je ne suis pas sûr, à confirmer par quelqu'un qui connait mieux... Peut-être sur des vélos de grande distribution.
Le powder coating, ou thermolaquage en français, c'est beaucoup utilisé dans l'industrie et le bâtiment : portails, menuiseries, ...
War Thunder : Karamazoff
n°996210
paulotheki​d
TURBO POSTEUR
Posté le 02-05-2020 à 16:58:14  profilanswer
Vulcan 122 + Pudding
https://reho.st/medium/self/f976702771497216f6df88627896b037ef268649.jpg
NB :
La stabilisation ne fonctionne pas (barre d'espace, shift entre autre)
D'autres essais :
https://reho.st/thumb/self/fc24baf381ac2afe9268cf1230449822134f414e.jpghttps://reho.st/thumb/self/29c51ca482704b946a9c09d09b9d0b72f89cf569.jpg
Message édité par paulothekid le 02-05-2020 à 17:00:41
The wrong man in the right place can make all the difference
n°996231
tristanlag​neaux
Posté le 02-05-2020 à 22:00:53  profilanswer
Mon clavier est monté depuis un bon mois, chez le mec à qui j'ai commander le build, mais a cause du confinement, j'attends, ca fais plus de 3 mois :fou:
je n'en puis plus. :fou:
n°996234
ouf
Posté le 03-05-2020 à 00:06:03  profilanswer
J'aime mon clavier
Vraiment je l'aime
Aujourd'hui j'ai cru le perdre
Tout s'est bien terminé, j'ai pu le sauver
Mais me connaissant, je pourrais revivre le même stress, et peut-être le perdre pour de bon
Le fait est que si je voulais acquérir le même, je ne pourrai pas, il n'existe plus...
C'est un KBT Pure Pro 60
Connaissez-vous un modèle de clavier avec ces caractéristiques  ?
- MX Blue (de préférence)
- en 60%
- avec les flèches de direction dans le coin bas/droite
- LED (bleu ou multicolor)
- azerty
- de qualité
- coloris noir
n°996235
Puree
Posté le 03-05-2020 à 00:32:17  profilanswer
Il est possible de reconstituer le layout du KBT pure pro 60 avec d'autres matériaux et large choix de switch, donc te tracasses pas trop pour l'avenir ;)
Mes Achats/Ventes
n°996236
ouf
Posté le 03-05-2020 à 00:53:15  profilanswer
Dis m'en plus s'il te plait
n°996242
Zippopotam​me
Posté le 03-05-2020 à 09:43:01  profilanswer
C'est bien la même chose s'il s'agit de thermolaquage
n°996243
Posté le 03-05-2020 à 09:43:54  answer
C'est un 60% ? En effet, assez simple à trouver, voir en FP pour les liens des vendeurs en Europe :)
n°996244
Gilbert Go​sseyn
Dr Liara T'Soni
Posté le 03-05-2020 à 10:15:27  profilanswer
https://reho.st/medium/self/f976702 [...] 268649.jpg
NB :
D'autres essais :
https://reho.st/thumb/self/fc24baf3 [...] 4f414e.jpghttps://reho.st/thumb/self/29c51ca4 [...] 9cf569.jpg
Il est chouette celui-ci. Il existe en ISO-Fr ? (je pense que c'est un ISO-UK la)
Tant que la couleur de la peau sera plus importante que celle des yeux, nous ne connaitrons pas la paix. ● L'écriture, c'est la mémoire du futur. ● Mods FO4
n°996246
Puree
Posté le 03-05-2020 à 11:35:20  profilanswer
n'importe quel case 60% compat poker/etc... + pcb GK64/Dz60 avec une plate en left shift 2u et des mx blue/autres, faudra surement réutiliser ton keyset. La seule partie non ressemblante (et tant mieux) c'est la partie barre espace, la taille de la barre espace pure pro est pas vraiment trouvable, à voir avec un split spacebar
Mes Achats/Ventes
n°996253
- gab
Posté le 03-05-2020 à 12:32:28  profilanswer
+1. Les PCB/plates qui proposent la disposition la plus proche du Pure Pro ont en général un rang inférieur comme ça :
https://reho.st/preview/self/203a2439ad1c1d77f260ae718d73aa899e9a3b15.png
Mais c'est fonctionnellement la même chose, et ça rend l'utilisation d'autres keysets beaucoup plus facile vu que la barre espace est standard.
n°996254
Ashkaran
Vive la Liberté, bordel !
Posté le 03-05-2020 à 12:37:22  profilanswer
Bonjour et drapal :)
je me suis offert le Logitech G413, après 2 mois il me semblait assez sale alors j'ai démonté les touches avec l'outil livré avec le clavier.
Depuis j'ai certaines touches qui tiennent pas bien.
1) ce type de clavier est  il fait pour être démonté régulièrement ?
2) une idée ? appuyer plus fort sur les touches récalcitrantes ? colle ? acheter des touches neuves ? car en les démontant j'ai peut être écarté certaines tiges internes des capuchons ?
merci :)
Perf Bourse des Frers POGNON|| Le Topic Bourse | Bijoux personnalisés
n°996282
paulotheki​d
TURBO POSTEUR
Posté le 03-05-2020 à 17:29:23  profilanswer
tu parles du clavier ? C'est un ISO-Fr Roccat Vulcan 122 (Touché tactile, un peu genre brown)
C'est un kit de touche ansi-US... donc oui pas mal de soucis.
Je suis en train de chercher un kit ISO-Fr justement, car ce n'était pas le montage initial - elles sont destiné à un keychron K6 commandé le 28 :D - mais ça le fait bien sur le Vulcan aussi.
Pour être précis c'est ce kit là : https://www.amazon.fr/gp/product/B0 [...] UTF8&psc=1
Qui ne correspondent pas il y a : "<", les shifts, la barre d'espace, entrée, "*", ainsi que les étiquettes sur les touches !
(shift droit + espace ne tiennent pas bien)
Donc j'ai laissé les touches originales pour celle qui me manque, et ce n'est pas très choquant :
https://reho.st/thumb/self/ba4be7959a46b9714b5e7cefb27771f8eac47176.jpg
n°996283
paulotheki​d
TURBO POSTEUR
Posté le 03-05-2020 à 17:33:13  profilanswer
merci :)
Pour aider : https://www.reddit.com/r/LogitechG/ [...] roke_help/
Ca a l'air d'être les mêmes touches que sur le G910, tu peux toutes les démonter pour nettoyer. N'oublie pas d'apporter toute ta patience avec toi, je l'ai fait hier, j'en ai eu pour 3 heures... Sans être très satisfait.
n°996290
bardemeteo​re
Posté le 03-05-2020 à 21:25:27  profilanswer
Par hasard. Je suis à la recherche d'un numpad..
Critères :
Usb
Case noire / grise
Switch gateron red ou cherry red / black (du linéaire sans ce style en gros)
Les caps n'ont pas trop d'importance.
C'est assez urgent, la Cao avec un TKL c'est pas terrible :o
La dernière solution : reprendre mon membrane fake apple.. Sauvez moi  :D
Topic Achats/Ventes
n°996295
TECHNOm@st​er 2202
Posté le 04-05-2020 à 02:38:14  profilanswer
Au final je me suis commandé le Ducky Channel One 2 Skyline TKL sur le shop HFR à 96€.
Il était dispo avec les switch Brown (coup de bol).
J’ai pris le ducky car après réflexion je préfère d’abord tester un clavier mécanique en ISO-FR (oui c’est la facilité  :d)
Message édité par TECHNOm@ster 2202 le 04-05-2020 à 02:39:08
n°996301
Posté le 04-05-2020 à 08:34:33  answer
Critères :
Usb
Case noire / grise
Toi il te faut ceci, https://www.befr.ebay.be/itm/Leopol [...] ngim7h864g
Je l'ai en MX Brown, il est vraiment parfait [:fredmoul:1]
n°996302
Posté le 04-05-2020 à 08:36:35  answer
https://reho.st/thumb/self/ba4be795 [...] c47176.jpg
C'est quand même pas super clean de mélanger deux sets qui n'ont pas le même profil de touche :/
n°996303
ttyb0
sysadmin, libriste, hacker
Posté le 04-05-2020 à 09:14:38  profilanswer
bon choix  [:neuropsy:4]
[Ventes]
n°996305
Yionel
Profil : lactique
Posté le 04-05-2020 à 09:51:04  profilanswer
Finalement, pour mon 1e clavier méca, je vais prendre le Ducky Channel One 2 SF RGB (Cherry MX RGB Brown)
https://media.ldlc.com/bo/images/fiches/clavier_joueur/ducky/one_2_sf/1.jpg
Par contre, il n'est disponible qu'en juillet sur ldlc (est-ce que je peux me fier à cette date ?)
 [:cerveau totoz]
Quel clavier, beau, pratique, gamer, avec ou sans fil, pas trop cher ?clavier Anglais
Boutons de raccourcis Web - Clavier Logitech Desktop MXClavier USB sur A7V333
Clavier Non Identifié - Asus A7v600pile pour vieil IBM
[PB]Clavier et souris sans fil LABTECrecherche clavier "naturel"
a quand les clavier wireless thermaltake ??cherche un CLAVIER pour portable PACKARD BELL
Plus de sujets relatifs à : [Topic unique] Claviers mécaniques
