4573 connectés
 Page :   1  2  3  4  5  ..  138  139  140  ..  987  988  989  990  991  992
[Topic Unique] AMD Radeon R9/R7 200; HD 7000 Southern Islands (28nm)
n°8152883
Charles K
Posté le 17-12-2011 à 18:36:07  profilanswer
Il y a ça aussi qui est intéressant :
Sometimes you know something for a while and you can not say. Thanks to a leak of semi-accurate, we can finally say that the Radeon HD 7900 -, 7800 - and 7700-series, all three use the all-new Next-Core Graphics architecture!
The HD 7600 -, 7500 -, 7400 - and 7300-series are direct rebrand of the previous generation. The HD 7400 video cards are exact copies of the HD 6400 cards, the HD 7300 GPUs are the same as the HD 6300 graphics cards and the HD 7600 - and HD 7500-series remain unchanged and are based on the Turkish-GPU, we already encountered in the HD 6000-series. Everything from the HD 7600 series is seen down, based on the old architecture (VLIW5) and therefore only available to OEMs.
The release of the HD 7970 and HD 7950 follows on January 9, on 22 December the reviews of the HD 7970 already
http://www.bouweenpc.nl/nieuws/har [...] chitectuur
n°8152885
Charles K
Posté le 17-12-2011 à 18:37:34  profilanswer
Invite_Surprise a écrit :
Power part Tune:
Introduces more granular power control more granularity, entirely based on digital technology (State register? ), Independent of the driver and configuration files.
"Black screen" State or when the PC goes into idle mode, GPU cores into the 0-Watt status, fans will turn off at this time, CFX configuration when this technique is to attract
7970 TDP is about 210 Watts, 7,950 is ... To be determined.
7,970 is 925 MHz frequency (2048 Core/32 CU), memory is 384-bit@5.5 GT/s.
7,950 core frequency specifications to be determined, but the core number is 1792/28 CU, the memory bus is still 384-bit, but the rate reduction for 5GT/s (AMD home is not fully determined) level.
http://we.pcinlife.com/forum.php?m [...] d=32935310
Si c'est vrai, alors OBR le hater a dit de la merde, donc tant mieux  :D
Message édité par Charles K le 17-12-2011 à 18:38:08
n°8152897
aliss
Rhyme the Rhyme Well
Posté le 17-12-2011 à 18:43:36  profilanswer
Power part Tune:
Ah, castration au niveau des rops également, je doute fort que cette fois-ci une xx50 puisse de débloquer en xx70.
n°8152918
frag_facil​e
32X forever
Posté le 17-12-2011 à 18:55:18  profilanswer
210W de TDP ca nécessite un 8 et un 6 pins en alim ???
n°8152937
Charles K
Posté le 17-12-2011 à 19:08:56  profilanswer
C'est sensé aller jusqu’à 225w avec 6+6 pin donc 2 possibilités :
- les photos qu'on a vu sont des ES et rien empêche que la carte finale possède 6+6 pin avec un tdp inférieur à 225 w (210), la 5870 par exemple est 6+6pin alors que le pcb possède les traces pour 6+8
- la carte fait + de 225 watt et possède 6+8 pin
Message édité par Charles K le 17-12-2011 à 19:09:48
n°8152940
Sphinx314
Plutonien masqué
Posté le 17-12-2011 à 19:10:33  profilanswer
8 pins = 150 W
6 pins = 75 W
150 + 75 = 225 W d'appoint
Mais il y a encore l'alim par le PCIe...
EDIT: grilled!   :D
Message édité par Sphinx314 le 17-12-2011 à 19:11:54
n°8152944
aliss
Posté le 17-12-2011 à 19:15:29  profilanswer
C'est sans doute 210w avec la limite artificielle de powertune.
n°8152952
kalidrimmm
Posté le 17-12-2011 à 19:24:15  profilanswer
tu sais ou on peut la pre order aussi?
n°8152955
franck7511
Posté le 17-12-2011 à 19:25:18  profilanswer
Bah sur ce site il semble qu'on puisse la pré-order. Cela dit, faut pas oublier que les tarifs sont sûrement un peu gonflés...
n°8152958
aliss
Posté le 17-12-2011 à 19:26:31  profilanswer
Ce shop hollandais se fait mousser à chaque sortie de gpu en étant les premiers à proposer des pré-commandes à des prix ridiculement élevés.
n°8152959
kalidrimmm
Posté le 17-12-2011 à 19:26:35  profilanswer
non mais je veux savoir si vous connaissez d'autres sites ou on peut la pre order
Message édité par kalidrimmm le 17-12-2011 à 19:31:29
n°8152963
aliss
Posté le 17-12-2011 à 19:30:52  profilanswer
Tu devrais attendre le 22 décembre afin de voir ce que valent les HD79xx et d'avoir des pré-commandes à des tarifs honnêtes.
n°8152966
barbare128
pas de koi se rouler par terre
Posté le 17-12-2011 à 19:31:25  profilanswer
inutile de pré-order, tu l'auras pas plus vite et tu te fais entuber de 200€ :o
Surtout que niveau stock, il devrait y en avoir pour tout le monde, vu le prix de base ;)
Feed my back : http://forum.hardware.fr/forum2.ph [...] w=0&nojs=0
n°8152995
fire du 57
The futur is Fusion
Posté le 17-12-2011 à 20:04:19  profilanswer
Rolala à 5jours...On a aucune rumeur qui converge sur un seul est unique point ! --'
"Si vous ne changez pas en vous-même, ne demandez pas que le monde change"
n°8153015
franck7511
Posté le 17-12-2011 à 20:17:24  profilanswer
Sur un intervalle de ]-20%;80%[, toutes convergent dedans.
Ouais, c'est bien vrai ça :o
Tu attends la sortie et tu te fais ton idée à ce moment...
Message édité par franck7511 le 17-12-2011 à 20:22:24
n°8153023
Kenshin011
Posté le 17-12-2011 à 20:23:11  profilanswer
On a quand même l'air d'être sur du nombre de CU, ROP, largeur du bus, fréquence...
Mon Feedback ! => http://forum.hardware.fr/hfr/Achat [...] 7027_1.htm
n°8153035
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 17-12-2011 à 20:33:53  profilanswer
Ouais, et c'est rien pour me rassurer.
n°8153038
moujet
Chef de Projet
Posté le 17-12-2011 à 20:37:08  profilanswer
maerens a écrit :
si les dev exploitaient à 100% LE gpu? nous aurions 150% de perfs en plus, déja exploiter à 100% est impossible et vu le temps qu'il faudrait pour optimiser tout les archi existante c'est impossible aussi, voila pourquoi il faut table sur du +40%
et pour les 60% c'est largement possible sous les exe directx11(moteur natif) face à cayman.
et puis je ne vois pas en quoi 60% 'est dantesque
Geforce 8 VS 7900GTX? jusqu'à +300%
HD 4870 VS HD 5870? + 60-80%
j'en passe des meilleurs.
alors les deux fondeurs n'ont soit plus de couille, soit ils se disent toute facon avec les consoles autant tabler sur du +30% et prendre les gens pour des pigeons.
D'accord sur les consoles mais autant Amd que Nvidia préfėre que tu changes ta carte tous les 1 ou 2 ans ou alors que tu  contribus à liquider les stocks des géns précédentes en te faisant un Crossfire?
Pour preuve toutes les cartes mères sortent avec au Minimum 2 ports  Pcie et les inconvénients de cette formule s'estompent peu à peu (sauf le facteur conso forcément)...
Tout comme beaucoup des gens de ce forum je risque de m'équiper en 7xxx non pas par nécessité mais surtout parcequ'on va me faire croire que c'est indispensable voir nécessaire  :pfff:
Message édité par moujet le 17-12-2011 à 20:43:23
n°8153044
barbare128
Posté le 17-12-2011 à 20:41:50  profilanswer
moujet a écrit :
D'accord sur les consoles mais autant Amd que Nvidia préfėre que tu changes ta carte tous les 1 ou 2 ans ou alors que tu :pfff:  contribus à liquider les stocks des géns précédentes en te faisant un Crossfire?
Pour preuve toutes les cartes mères sortent avec au Minimum 2 ports  Pcie et les inconvénients de cette formule s'estompent peu à peu (sauf le facteur cons forcément)...
c'est completement inutile si t'a déjà une 6950-6970.
Après ça dépends de ta config, et de tes jeux, et de ta résolution. C'est clair si t'a six écrans 30" c'est pas la même que si tu as 1 écran 22", si tu joue à BF3, crysis 3, .... , ou au démineur,
enfin bref tu m'as compris j'espère. Perso j'ai bien envie de l'acheter même si je sais que ça m'est inutile. Mais je vais je pense sauter cette gen, car pas de tunes.  :jap:
n°8153045
Activation
21:9 kill Surround Gaming
Posté le 17-12-2011 à 20:44:35  profilanswer
faut attendre la sortie de GTA V cétou :o
et même là à voir des jeux genre skyrim, d'ici que ça soit un ivy bridge qui soit plus intéressant d'acheter :D
enfin bon les FANs de AMD seront heureux, ils vont avoir enfin un monogpu qui va dépasser les gtx580
bon après y aura les déçu à espérer que la HD7970 sera aussi perf qu'une hd6990  [:vince_astuce]
Message édité par Activation le 17-12-2011 à 20:46:33
n°8153047
Bobox
Yuri Orlov :)
Posté le 17-12-2011 à 20:45:49  profilanswer
+1 et encore  [:ofou]
n°8153048
BlueScreen​Junky
Posté le 17-12-2011 à 20:46:05  profilanswer
flipette_dentaire a écrit :
+1, une 6990 c'est plutôt +70% sur une 6970. :/
Putain mais 30% ce serait minable. :(
Ca dépend du prix et de la conso... De toutes façons ça en fera la carte mono-GPU la plus puissante (peut être pour quelques semaines seulement, mais peu importe), et si elle est bien placée au niveau tarif et qu'elle a pas besoin d'un ventilateur de sèche cheveux pour la refroidir, ça peut être excellent.
kroks- a écrit :
la asus est à 1000mhz au lieu de 925 c'est bon signe pour l'overclocking :D
Y a un slide ou ils disent qu'elle monte à "1000Mhz et au delà"... Bon c'est un slide promotionnel mais s'ils marquent ça dessus c'est que je pense effectivement qu'ils sont assez confiants dans les possibilités d'overclocking de la carte ^^
Message édité par BlueScreenJunky le 17-12-2011 à 20:49:10
n°8153049
Activation
Posté le 17-12-2011 à 20:49:16  profilanswer
bah vu qu'ils ont viré un port dvi pour avoir un slot entier de grille de ventilation... c est que ça doit plus chauffer qu'une hd6970 faut croire
n°8153052
moujet
Chef de Projet
Posté le 17-12-2011 à 20:52:23  profilanswer
On se rejoint complètement je te rassure! Et je risque de reporter aussi cet achat car acheter un GPu à la sortie je l'ai fait l'an dernier pour mes 2 Hd6870 pour les voir dégringoler en prix avec l'arrivée du HDG... je revendrais mon matos avant que mes cartes perdent trop pour me positionner ensuite sur les hd7xxx probablement  :whistle:
Message édité par moujet le 17-12-2011 à 20:53:13
n°8153053
BlueScreen​Junky
Posté le 17-12-2011 à 20:52:52  profilanswer
Ou qu'elle est plus silencieuse, ou qu'ils veulent que le modèle de référence puisse s'overclocker, ou qu'ils ont voulu diminuer les coûts de production du rad...
Bref, on saura lors des premiers tests. (Ce sera peut-être de la grosse merde hein, mais pour le moment rien ne permet de l'affirmer).
PS : Ah et oui, je pense que si t'as une 69x0 elle sera inutile, mais de toutes façons c'est très rarement justifié d'acheter deux générations consécutives de CG.
Message édité par BlueScreenJunky le 17-12-2011 à 20:54:01
n°8153058
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 17-12-2011 à 20:55:45  profilanswer
 "Notre 7970 sera longue comme ça!" - Rory
http://www.3dnews.ru/_imgdata/img/2011/12/16/621598/amd_rory_read_event.jpg
http://www.bouweenpc.nl/wp-content/uploads/2011/12/southern-islands-575x298.png
http://h8.abload.de/img/desktop_2011_12_17_19pp2ny.png
Message édité par Wirmish le 17-12-2011 à 21:00:55
n°8153068
Activation
Posté le 17-12-2011 à 21:03:12  profilanswer
perso j ai bazardé mon cross de hd5870 en aout pour partir sur une gtx580 en septembre donc les hd7xxx je les attend franchement pas, surtout si seulement 2048 ALUs
préfère attendre les hd8xxx et gtx7xx ou je reviendrait au surround gaming
bref laisser au 28nm le temps de se "décanter" et à GCN de faire son trou
mais plus que GCN laissé à AMD la chance de corriger ses erreurs avec une puissance geometrique minable sur le cayman avec son soit disant bi graphic engine qui devait "cartonner"
bref beta testeur sur hd5870 avec le eyefinity, je passe mon tour pour le beta testing de "gcn" aux autres
gcn n'étant que le bout le plus visible de l iceberg "tahiti" ... pour un joueur en tout cas
Message édité par Activation le 17-12-2011 à 21:04:24
n°8153115
Cizia
Posté le 17-12-2011 à 21:47:12  profilanswer
tu en parle comme si la 580 était sortie il y a 10 ans   :whistle:
Message édité par Cizia le 17-12-2011 à 21:48:29
n°8153134
kalidrimmm
Posté le 17-12-2011 à 22:18:44  profilanswer
n°8153136
Fouge
Posté le 17-12-2011 à 22:21:10  profilanswer
J'espère que c'est le prix public, marre des sauts de puce.
n°8153161
maerens
Posté le 17-12-2011 à 22:51:17  profilanswer
bab55 a écrit :
Rah ce topic il est drôle : toute les pages y'a fire qui change de point de vue, maerens et ses cartes monstrueuses sont bien moins présente, wirmich il a disjoncté, acti il est pas content, MEI il dénigre, bref certain change, d'autre moins, mais c'est toujours aussi drôle.
Qui va enfin faire comme moi et attendre du concret ?
les  cartes seront des tueuses comme je l'ai dit, mais pas pour nous.
Crossfire R9-290x/290 (1Ghz 1300mhz;1Ghz 1350),I5 4690K 4,6Ghz 1,25V; Asus sabertooth Z97 Mark2; Cooler Master HAF X; Samsung 840 PRO 128GO ; Caviar Green EARS 1TO; Caviar RED EFRX 2TO; 8GB G-SKILL 1600 cl8; CORSAIR AX860I .
n°8153164
maerens
Posté le 17-12-2011 à 22:54:37  profilanswer
de 1 le crossfire c'est le mal, ca chauffe, ca consomme
et surtout les jeux ne sont pas fluide, le crossfire n'est qu'un vaste c.... marketing.
n°8153166
fire du 57
The futur is Fusion
Posté le 17-12-2011 à 23:02:57  profilanswer
Je me demande si je vais pas prendre un Cross de 6970 et les Watercooler....
n°8153169
maerens
Posté le 17-12-2011 à 23:07:41  profilanswer
tu vas être décu, le lag stuttering et tout et tout.
n°8153176
fire du 57
The futur is Fusion
Posté le 17-12-2011 à 23:17:53  profilanswer
Je vais y réfléchir... Mais bon on verra pour les Radeon 7k et si jamais c'est pas super et bien je croiserais les doigts pour avoir un GK104...
n°8153178
maerens
Posté le 17-12-2011 à 23:19:51  profilanswer
toute facon vu de ce que tu pars même une HD 4850 te ferai faire un arrêt cardiaque.
n°8153180
noobzed
Where is Brian ? DTC !
Posté le 17-12-2011 à 23:20:57  profilanswer
est ce que les perf sous truczip sera repercuté sur les 6xxx ?
FEEDBACK HFR
n°8153181
maerens
Posté le 17-12-2011 à 23:21:51  profilanswer
non pas du tout.
PQ crois tu qu'elles vont couter si cher quand je disais 520€ il y a quelques semaines, on m'a jeté des pierres.
Message édité par maerens le 17-12-2011 à 23:23:37
n°8153185
BlueScreen​Junky
Posté le 17-12-2011 à 23:26:45  profilanswer
Ben euh... Encore heureux que tu attends pas les prochaines cartes avec une GTX580 o_O (Enfin à moins que t'aies les moyens de mettre 400 euros dans une carte tous les 6 mois, mais je pense que c'est pas le cas d'une majorité de personnes).
On est donc bien d'accord, en remplacement d'une 5850 ou GTX 470 ce sera surement intéressant de changer de carte pour une HD7000, mais avec une carte de la génération précédente peu d'intérêt.
Et ce que tu dis confirme ce que je pense après avoir vu mon frère s'acharner à essayer de faire du SLI et du crossfire pendant des années pour toujours finir par craquer et prendre une carte mono-GPU : Ca vaut pas le coup de se prendre la tête à faire du SLI/Xfire, trop d'inconvénients par rapport à ce que ça apporte.
n°8153187
fire du 57
The futur is Fusion
Posté le 17-12-2011 à 23:27:15  profilanswer
C'est pas tout a fait faux !  :pt1cable:  :pt1cable:
maerens a écrit :
non pas du tout.
Moi j'ai rien dis je me suis juste étouffé en voyant le prix !  :o
Petite question ! L'archi pourrait permettre l'améliorations de la vitesse de rendu ( et autres ) sous des programmes adobe ? Ou de création 3D ?
n°8153195
Charles K
Posté le 17-12-2011 à 23:36:14  profilanswer
T'sais les cartes ça se revend, t'es pas obligé de mettre 400 à chaque fois, vous êtes pas des geek les mecs  :o
Message édité par Charles K le 17-12-2011 à 23:36:32
AMD 6850 ou Nvidia gtx 460 ?Une question rapide pour l'achat d'un ssd+chip7 AMD
Choix alimentation (i5 760 et AMD HD6870) ?Radeon HD6870 vs Geforce 460 GTX vs GTX 470
Quel Radeon HD pour un 32" ?[Topic unique] LanBoy Air
radeon 6850Home Cinema : AMD / nVidia
ventilateur AMD Phenom II X2 555 Black...SSD sur contrôleur AMD, AHCI ou IDE, et quels pilotes ?
Plus de sujets relatifs à : [Topic Unique] AMD Radeon R9/R7 200; HD 7000 Southern Islands (28nm)
