4469 connectés
 Page :   1  2  3  4  5  ..  107  108  109  ..  987  988  989  990  991  992
[Topic Unique] AMD Radeon R9/R7 200; HD 7000 Southern Islands (28nm)
n°8140490
MEI
|DarthPingoo(tm)|
Posté le 06-12-2011 à 10:05:46  profilanswer
Sauf si les 7950 n'ont pas du tout le même die (cf 256 bits vs 384 bits) et sont en VLIW4. ;)
n°8140524
fire du 57
The futur is Fusion
Posté le 06-12-2011 à 10:39:28  profilanswer
 :non:  Au dernières nouvelles la 7950 sera du GCN !  :jap:
Message édité par fire du 57 le 06-12-2011 à 10:39:38
"Si vous ne changez pas en vous-même, ne demandez pas que le monde change"
n°8140613
Invite_Sur​prise
Racaille de Shanghaï
Posté le 06-12-2011 à 12:07:13  profilanswer
Magnifique le 28nm chez GloFo :
Back in the summer it was reported that GloFo’s 28nm yield was zero. At that time, AMD re-wrote its fab agreement with GloFo saying it would only pay for working die.
More recently yields of one or two working die per wafer have been reported. Such a slow improvement would be enough to make AMD throw in the towel and move to TSMC.
GloFo is one of the IBM club which has gone for the gate first approach to manufacturing at 28nm, though the IBM common platform alliance has now said it will go to gate last on 20nm.
TSMC went with gate last at 28nm and points out that, when 20nm comes along towards the end of next year, it will be on its second generation of gate last.
http://www.electronicsweekly.com/A [...] r-28nm.htm
GloFo, un allié de poids pour AMaÿDaÿ  :jap:
n°8140620
seth-01
Posté le 06-12-2011 à 12:13:30  profilanswer
TSMC went with gate last at 28nm and points out that, when 20nm comes along towards the end of next year, it will be on its second generation of gate last.http://www.electronicsweekly.com/Articles/23/11/2011/52368/amd-reported-to-be-giving-up-on-glofo-for-28nm.htm
GloFo, une allié enclume de poids pour AMaÿDaÿ  :jap:
n°8140630
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 06-12-2011 à 12:26:51  profilanswer
GloFo, alité des mois, pauvre AMaÿDaÿ  :jap:
Samsung fait aussi parti de l'Alliance (IBM) et annonce que ses premiers chips en 32nm HKMG Gate First (Exynos 4212) entreront en production au 2e trimestre 2012.
Ça fait peur pour le 28nm...
n°8140632
fire du 57
The futur is Fusion
Posté le 06-12-2011 à 12:27:34  profilanswer
A votre le 28nm vas être annulé ?...
Message édité par fire du 57 le 06-12-2011 à 12:27:51
n°8140636
micky78
Get ripped or die tryin'
Posté le 06-12-2011 à 12:33:57  profilanswer
A t'on la chance de voir très rapidement une carte fanless (surtout au vue des TDP) à la sortie des 7xxx ? 7770 par exemple
n°8140643
Gigathlon
Quad-neurones natif
Posté le 06-12-2011 à 12:39:48  profilanswer
Ce qui fait peur, c'est surtout la confusion qui semble régner dans cette alliance. On décide un truc et puis non en fait, on va faire autrement... ah, mais moi j'ai déjà commencé à m'équiper, c'est con...
n°8140645
fire du 57
The futur is Fusion
Posté le 06-12-2011 à 12:41:06  profilanswer
C'est vrai que c'est hallucinant ! Surtout que cette "alliance" est êxtremement importante ! :jap:
n°8140695
videderien
Posté le 06-12-2011 à 13:39:53  profilanswer
Oui, ils vont sauver le monde fin 2012.
n°8140699
Fouge
Posté le 06-12-2011 à 13:44:39  profilanswer
La fin du monde c'est plutôt Juin 2012 ;)
n°8140729
mum1989
Posté le 06-12-2011 à 14:08:39  profilanswer
AMD Radeon HD 7000 fiasco as Bulldozer - likely Yes!
 AMD sent to several manufacturers info-slides about the new Radeon HD Graphics 7000. According to first estimates results in the slides, AMD-fans will be disappointed. Game performance against the current shitty-slow cards with Cayman not significantly increased, but consumption is relatively high for an advanced 28nm process. Stay tuned .... some slides will be here soon!
 PS. Specs floating web in these days ARE all BS! ! ! ! ! ! ! ! !
Source OBR
Il ne sait peut être que dénigrer AMD, mais il a bel et bien eu raison pour Bulldozer (avec quelques slides truqués cependant).
n°8140766
aliss
Rhyme the Rhyme Well
Posté le 06-12-2011 à 14:45:48  profilanswer
A la grande différence qu'il possèdait un ES de ce dernier alors que ça semble ne pas être le cas pour les 79xx.
A la place d'AMD j'innonderais sa boîte mail d'infos bidons, juste pour le fun.  :D
n°8140769
RONIN 512
Posté le 06-12-2011 à 14:48:09  profilanswer
Source OBR
ça c'est grave, si ces faits s'avèrent exactes, je serai vraiment déçu, je n'ai ni la volonté ni la tolérance de supporter un deuxième bulldozer-like fiasco.
si AMD n'assure pas cette fois ci, je tournerai définitivement vers le côté du caméléon :non:  :non:  :non:  :non:  :non:  :non:  :non:  :non:  :non:
Message édité par RONIN 512 le 06-12-2011 à 14:48:29
n°8140777
gliterr
Posté le 06-12-2011 à 14:51:58  profilanswer
si c'est le 28nm la cause du soucis, ca sera le meme chez Nvidia.
n°8140781
noobzed
Where is Brian ? DTC !
Posté le 06-12-2011 à 14:54:35  profilanswer
sauf qu'il yen a un qui a ouvert sa gueulle qu'il aurait des cartes pour la noel voire le debut d'année et un autre ( les verts :D ) qui a ouvert sa gueulle en disant qu'ils seraient la pour fin 2012 donc ca fait 1 an de difference entre les 2:o
FEEDBACK HFR
n°8140787
aliss
Posté le 06-12-2011 à 14:59:56  profilanswer
Ils "ouvrent leur gueule" sur le fait d'être les premiers sur une nouvelle finesse de gravure et sur ce plan c'est légitime puisque c'est le cas depuis des années.  ;)
n°8140788
noobzed
Posté le 06-12-2011 à 15:01:07  profilanswer
ranafoutre ce que tu dis :o je dis vrai moi :D
FEEDBACK HFR
n°8140789
Yoyo_5
Posté le 06-12-2011 à 15:02:00  profilanswer
nVidia foire toutes ses nouvelles gravures, c'est pas trop dur pour AMD d'être le premier du coup. :p
¤ Paix et félicité ¤
n°8140790
RONIN 512
Posté le 06-12-2011 à 15:02:02  profilanswer
Absolument pas, ci l'architecture ne marche pas comme il faut, ce n'est pas la finesse de gravure qu'il faut blâmer :non:
Message édité par RONIN 512 le 06-12-2011 à 15:02:28
n°8140798
Yoyo_5
Posté le 06-12-2011 à 15:09:32  profilanswer
Souvent c'est lié, tu graves pas ce que tu veux comme tu le veux, et sur une archi ce sera plus simple que sur une autre.
n°8140813
MEI
|DarthPingoo(tm)|
Posté le 06-12-2011 à 15:20:10  profilanswer
C'est vrai seulement depuis le Fermi en fait... :o
n°8140852
Yoyo_5
Posté le 06-12-2011 à 16:07:23  profilanswer
Je rectifie, chaque gravure non maîtrisée depuis un certain temps et non toute nouvelle. ^^
Et non, les FX c'était pareil, c'est pour ça qu'nVidia évitait et restait prudent. Le RV770 les a calmés, ils ont été obligés de suivre et de prendre des risques autrement ATI/AMD aurait toujours été devant. ;)
Message édité par Yoyo_5 le 06-12-2011 à 16:14:09
n°8140893
gliterr
Posté le 06-12-2011 à 16:33:14  profilanswer
Il faudrait deja voir les tests avant de jauger tout ca.
n°8140951
Gigathlon
Quad-neurones natif
Posté le 06-12-2011 à 17:27:58  profilanswer
En même temps, si on va par là BD n'est pas foiré architecturalement parlant mais ne peut pas monter suffisamment haut en fréquence, ce qui peut être mis sur le dos du process, ou pas.
Quoi qu'il en soit, il serait évidemment étonnant qu'un quelconque GPU puisse faire "sensiblement" mieux que Cayman en jeu... sachant qu'on arrive à être pas mal limités par autre chose que le GPU même en 2560x1600.
Du moment qu'ils ne nous refont pas le coup du Cayman avec son perf/watt à la baisse (et même assez fortement si on prend Barts comme référence), on a pas trop à s'en faire.
Message édité par Gigathlon le 06-12-2011 à 17:30:18
n°8140953
RONIN 512
Posté le 06-12-2011 à 17:28:44  profilanswer
le problème ce que OBR avait raison par le passé, et tous ses tests avec le bulldozer se sont montrés justes par la suite, donc ça craint pour les HD 7000 :cry:
Message édité par RONIN 512 le 06-12-2011 à 17:29:15
n°8140965
RONIN 512
Posté le 06-12-2011 à 17:40:38  profilanswer
Désolé, mais le core i7 2600k fait beaucoup mieux avec 200Mhz de moins que le FX-8150, donc c'est loin d'être un problème de gravure mais d'architecture, en outre, je trouve que le 32nm des bulldozer est bien aboutie puisque ces processeurs montent plutôt bien en fréquence.
n°8140970
ordimans
Posté le 06-12-2011 à 17:45:19  profilanswer
Euh en 5760 le seul truc qui limite c'est le GPU pour l'instant....
n°8140986
Yoyo_5
Posté le 06-12-2011 à 17:58:14  profilanswer
Pour les CPU, il a fait pouf plouf, il avait 5 chances sur 6 de tomber juste. Pour les CG, il prend des risques, il n'a qu'une chance sur 10 pour que ce soit vrai. ^^
Chiffres totalement arbitraires, comme ce qu'OBR raconte, c'est de bonne guerre. [:implosion du tibia]
n°8140996
Fouge
Posté le 06-12-2011 à 18:01:33  profilanswer
RONIN 512 a écrit :
Je trouve que le 32nm des bulldozer est bien aboutie puisque ces processeurs montent plutôt bien en fréquence.
Tu trouves ? Ca fait à peine mieux que leur ancienne génération 45nm, et à peine mieux que le concurrent (+200MHz) alors que c'est une architecture censée monter haut en fréquence.
Tu vas me dire que c'est parce que le CPU contient un très grand nombre de transistors alors que non, il y en a "que" 1.2 milliard* soit un nombre similaire à SB 4C (1.16Md).
Au final, je trouve qu'au contraire BD a du mal à monter en fréquence  [:razorbak83] Et c'est à mon avis en partie la raison de son manque de perf.
* avec 2Md de transistors, l'argument aurait pu être valide :o
Message édité par Fouge le 06-12-2011 à 18:03:01
n°8141040
aliss
Posté le 06-12-2011 à 18:38:33  profilanswer
Il faut dire qu'OBR s'est planté à plusieures reprises par le passé alors forcément pour quelqun ne l'ayant lu que pour ses annonces et ses leaks à propos du Bulldo, il peut paraître fiable...
Pour l'instant il ne fait que déclarer que les specs sur le net sont fausses (manque de bol il ne dit pas lesquelles.. ;) ) et qu'il possède des infos via des slides de performance, c'est bien maigre comme "scoop".
Je me réjouis de voir si il va réussir à mettre la main sur un ES tant il doit être blacklisté par AMD après les propos orduriers qu'il a tenu à leur égard des mois durant.  :D
Message édité par aliss le 06-12-2011 à 18:39:26
n°8141044
maerens
Posté le 06-12-2011 à 18:41:36  profilanswer
mais quel bouffon cet OBR, moi il me fait trop pitier sur ce coup là.
Crossfire R9-290x/290 (1Ghz 1300mhz;1Ghz 1350),I5 4690K 4,6Ghz 1,25V; Asus sabertooth Z97 Mark2; Cooler Master HAF X; Samsung 840 PRO 128GO ; Caviar Green EARS 1TO; Caviar RED EFRX 2TO; 8GB G-SKILL 1600 cl8; CORSAIR AX860I .
n°8141045
fire du 57
The futur is Fusion
Posté le 06-12-2011 à 18:41:59  profilanswer
Ils a surement un pote qui à beaucoup d'action et qui lui passe les ES le problème c'est qu'a mon avis AMD ne vas pas Blacklister cet actionnaire ! :jap:
n°8141048
maerens
Posté le 06-12-2011 à 18:45:41  profilanswer
un ES de quoi, il est en total contradiction avec ce que j'ai vu, il abuse.
n°8141051
fire du 57
The futur is Fusion
Posté le 06-12-2011 à 18:47:24  profilanswer
Non mais pas forcement tout de suite ! :jap: mais plutôt un petit peu avant la sortie ;)
PS : La c'est du grand n'importe quoi à la OBR  :sol:
Message édité par fire du 57 le 06-12-2011 à 18:49:20
n°8141052
Fouge
Posté le 06-12-2011 à 18:47:32  profilanswer
aliss a écrit :
Pour l'instant il ne fait que déclarer que les specs sur le net sont fausses (manque de bol il ne dit pas lesquelles... ;) )
Ben toutes, il le dit :o
Wirmish a d'ailleurs levé un lièvre concernant celles de la HD7950 (son nombre d'ALU) ce qui met un coup de pied à la crédibilité de leaks comme celui-là.
n°8141058
maerens
Posté le 06-12-2011 à 18:52:04  profilanswer
le pire c'est que quand ce type à l'air sur de lui c'est pas bon signe, mais alors dans ce cas la je comprendrais plus rien à ma vie, AMD foire ses modèles finaux mais pas les proto??
n°8141082
Yoyo_5
Posté le 06-12-2011 à 19:13:11  profilanswer
Tu l'as vu tourné ? ^^
n°8141083
barbare128
pas de koi se rouler par terre
Posté le 06-12-2011 à 19:14:13  profilanswer
il faut revenir sur le sujet les gens siouplait !!!!
sinon, pas de nouvelles infos sur mon coté. Et au vu des arguments de wirmish à propos des 4 CUs  par cache, je ne peux que confirmer que ce multiple serra respecté.
Pour ma part, je pense que 2560 alu, serait un bon compromis pour les 7970.
Feed my back : http://forum.hardware.fr/forum2.ph [...] w=0&nojs=0
n°8141088
maerens
Posté le 06-12-2011 à 19:17:37  profilanswer
ben oui je vous l'ai déja dit, mais des benchs théoriques. OBR lui dit avoir vu des jeux tourner, mais je sais pas comment il a fait parce que il y a 3 semaines il y avait pas des drivers adéquats donc soit il a installer des drivers pourrave et se viande soit les benchs théoriques c'est encore plus pourris que ce que je croyais.
n°8141093
warlan
L'Heretik
Posté le 06-12-2011 à 19:22:27  profilanswer
Franck7511 sors de ce corps  :lol:
AMD 6850 ou Nvidia gtx 460 ?Une question rapide pour l'achat d'un ssd+chip7 AMD
Choix alimentation (i5 760 et AMD HD6870) ?Radeon HD6870 vs Geforce 460 GTX vs GTX 470
Quel Radeon HD pour un 32" ?[Topic unique] LanBoy Air
radeon 6850Home Cinema : AMD / nVidia
ventilateur AMD Phenom II X2 555 Black...SSD sur contrôleur AMD, AHCI ou IDE, et quels pilotes ?
Plus de sujets relatifs à : [Topic Unique] AMD Radeon R9/R7 200; HD 7000 Southern Islands (28nm)
