3583 connectés
Sujet(s) à lire :
 Page :   1  2  3  4  5  ..  7  8  9  ..  31  32  33  34  35  36
[Topic Unique] Mantle : l'API GPU d'AMD
n°9035644
predator06
Posté le 30-01-2014 à 12:06:21  profilanswer
Des chiffres données par DICE
Test case 1: Low-end single-player
CPU/GPU: AMD A10-7850K (‘Kaveri’ APU), 4 cores @ 3.7 GHz
Settings: 720p MEDIUM settings.
OS: Windows 7 64-bit
Level: Singapore “Beach”
This area is heavy on the CPU as it is quite a lot of action going on, but the game is primarily GPU-bound both on DX and with Mantle but thanks to GPU optimizations with Mantle we get a good performance improvement.
Result: 26.6 ms/f -> 23.3 ms/f = 14% faster
Test case 2: Standard 64-player multiplayer
CPU: AMD FX-8350, 8 cores @ 4 GHz
GPU: AMD Radeon 7970 3 GB (AMD will add support for the AMD Radeon™ HD 7970 in a later stage of Mantle’s release schedule, learn more)
Settings: 1080p ULTRA 1x MSAA
OS: Windows 8 64-bit
Level: Siege of Shanghai
Level was tested with 64 “pseudo players” that we have for our own internal testing that simulates heavy game workload that we have in multiplayer in order to get more deterministic results compared to full real multiplayer. 64 players on the large Battlefield levels is really demanding of the CPU so this test case is primarily CPU-bound.
Result: 18.87 ms/f -> 15.08 ms/f = 25.1% faster
Test case 3: High-end single-player with multiple GPUs
CPU: Intel Core i7-3970x Extreme, 12 logical cores @ 3.5 GHz
GPU: 2x AMD Radeon R9 290x 4 GB
Settings: 1080p ULTRA 4x MSAA
Level: South China Sea “Broken Flight Deck”
This single-player scene is heavy on both the CPU and GPU with lots of action going on. Test was done on the highest end Intel CPU on Windows 8, which is the fastest option before Mantle thanks to DirectX 11.1. Still this CPU is not fast enough to keep the 2 290x GPUs fed at 1080p on Ultra settings so we get a significant CPU performance bottleneck which results in major performance improvement when enabling Mantle.
Result: 13.24 ms/f -> = 8.38 ms/f = 58% faster
Message édité par predator06 le 30-01-2014 à 12:07:03
5800X 3D // PNY 4080 // DDR4 3600 MHz // B550 tomahawk
n°9035651
Mini_BN
Le Goujat est un fromage !
Posté le 30-01-2014 à 12:10:09  profilanswer
Et BF 4 demande les drivers plus récents pour fonctionner à plein régime ...Mantle serait donc bien présent ! :)
n°9035652
jojos92
Quand on aime on ne compte pas
Posté le 30-01-2014 à 12:10:21  profilanswer
aaaa voilà enfin du concret !
LG 32GX850A OLED 4K 165HZ | i9 10900 @4,6ghz | 32Go de RAM | RTX 3080 FE @1920mhz/900mv
n°9035653
Eife
Juste avant le .G - Topic de
Posté le 30-01-2014 à 12:10:25  profilanswer
le test case 2 est pas mal proche de ma conf (i5 3570k a la place du fx).
+25% waouh pas mal du tout! vivement qu'ils integrent les GCN 1.0 :)
n°9035662
aliss
Rhyme the Rhyme Well
Posté le 30-01-2014 à 12:17:16  profilanswer
Suprennant qu'ils obtiennent des chiffres plus importants que la division marketing d'AMD... :D
En outre les 58% avec un gros cpu paraissent pour le moins étranges, malgré l'utilisation de 2 gpu's.
W&S mais si ils arrivent à de tels gains, possible que je reprenne de'AMD lors du passage en 20nm.
Message édité par aliss le 30-01-2014 à 12:18:15
n°9035740
Damze
Posté le 30-01-2014 à 13:39:04  profilanswer
Ça me parait énorme non ?
58% sur un PC déjà très haut de gamme o.o
Je verrai ce soir...j'aimerai bien avoir également 10fps de plus en moyenne sur ma 270X :O
n°9035771
Eife
Posté le 30-01-2014 à 13:59:44  profilanswer
pareil, ça m'a un peu fait tiquer...
n°9035788
mazingerz
Posté le 30-01-2014 à 14:08:31  profilanswer
non c'est logique les chiffre AMD sont donné avec un seul GPU et par rapport a windows 8.1
or dans BF3 win8 + 10% de perf que seven grace à dx11.2 (que n'a pas seven)
donc voilà
Message édité par mazingerz le 30-01-2014 à 14:08:54
n°9035790
mazingerz
Posté le 30-01-2014 à 14:10:04  profilanswer
une des grosse amélioration des mantle et le gain sur le multi thread
un FX est bien + perf que ton pross en multi thread (8thread)
n°9035795
Damze
Posté le 30-01-2014 à 14:12:26  profilanswer
A voir, j'ai cru lire que BF4 n'étais pas capable d'utiliser + de 4 thread en même temps.
Et en plus je ne sais pas comment ça compte, vu que les FX c'est 50/50 des "core" et des "modules" (qui ne peuvent pas faire certaines opérations comme un core si j'ai bien compris)
n°9035799
mazingerz
Posté le 30-01-2014 à 14:16:52  profilanswer
BF4 utilise 8 thread déjà même sans mantle
n°9035803
aliss
Posté le 30-01-2014 à 14:19:59  profilanswer
donc voilà
Qu'est ce que BF3, l'os utilisé ou encore dx11.2 dont aucune carte 100% compatible n'a vu le jour viennent faire là ?
n°9035813
Mini_BN
Posté le 30-01-2014 à 14:29:01  profilanswer
En tout cas, j'ai de grosses pertes de performances depuis ce matin ...
J'avais les 13.12 (qui m'affichaient du 13.11), et j'étais plutôt sur du 90 FPS en jeu , alors que la, j'ai à peine du 60 FPS en ayant re-téléchargé les 13.12 sur le site AMD ...
n°9035815
aliss
Posté le 30-01-2014 à 14:30:18  profilanswer
Tu as vérifié que certaines options du CCC n'ont pas été modifiées avec ces nouveaux drivers ?
n°9035822
mazingerz
Posté le 30-01-2014 à 14:37:11  profilanswer
BF4 pardon
pour le reste renseigne toi tu n'a pas l'air à jour depuis 1 an ou 2 ans ;)
Message édité par mazingerz le 30-01-2014 à 14:38:52
n°9035826
Mini_BN
Posté le 30-01-2014 à 14:39:40  profilanswer
J'ai tout viré, et remis les 13.11 beta 9.5, on va voir si ça change :D
Message édité par Mini_BN le 30-01-2014 à 14:40:29
n°9035839
aliss
Posté le 30-01-2014 à 14:47:05  profilanswer
mazingerz a écrit :
BF4 pardon
Kepler et CGN ne sont pas dx11.2 à proprement parlé, 11.0 pour le premier avec une certaine gestion des "tiled ressources" et 11.1 pour le second :o
Quant aux résultats annoncés par DICE pour le 3970x avec 2 290, on peut lire ceci :
Alors maintenant si un écart de 58% dans ces conditions te parait "normal", nous n'avons pas la même notion de la normalité.  ;)
Message édité par aliss le 30-01-2014 à 14:47:52
n°9035847
Mini_BN
Posté le 30-01-2014 à 14:52:15  profilanswer
Bon, pas de gain en retournant aux 13.11 beta 9.5 ... je remet les 13.12 du coup, en attendant les 14.1 ce soir :)
EDIT : et 1 black screen juste après réinstall des 13.12 ... mon 1er BS. A surveiller.
Message édité par Mini_BN le 30-01-2014 à 14:59:17
n°9035864
aresias
Posté le 30-01-2014 à 15:09:06  profilanswer
déjà tu as passé l'utilitaire pour faire une désinstallation clean des drivers ?
n°9035868
MoNgOoS3
Gnah
Posté le 30-01-2014 à 15:11:29  profilanswer
Vérifie pendant que tu joues que les fréquences de ton GPU ne reste pas à une fréquence trop basse.
n°9035871
Mini_BN
Posté le 30-01-2014 à 15:15:03  profilanswer
Le GPU reste à 1.100Mhz (R9-290 OC)
Le CPU est bien à 4.5Ghz (i7 2600k OC)
Je tenterais une désinstal avec l'utilitaire qui va bien, et une résinstall des 13.12 ...
n°9035881
Posté le 30-01-2014 à 15:26:18  answer
aliss a écrit :
Je me demande combien de temps cela va prendre pour qu'AMD assure un support optimal pour les cartes basées sur CGN 1.0.
Je prends l'exemple du frame pacing au delà du 1600p, il aura fallu prêt de 6 mois entre les premiers catalyst beta l'intégrant et les 14.1...
faut relativiser
pour l'instant , y a que du mono gpu
et pour un gamer disposant d'une 260/270/280 , à moins de tourner avec un apu ou un i3 sur une 280 :/
y a quand même peu de chances d'être cpu limited
à la limite , c'est le support du cross qui me parait le plus urgent car c'est là qu'on va retrouver des cas de cpu limited même avec un cpu hdg
et dans ce cas précis parmi les gcn 1.0 seul le cross de 280 et 270 sont concernés , et là oui c'est dommage pour eux
en ce qui me concerne par exemple , j'ai rien à espérer de mantle , tout du moins pour ce jeu , ma config est plutôt équilibrée et je devrais plus être gpu limited qu'autre chose
et ça sera également le cas de beaucoup d'utilisateurs de gcn 1.0 pour ne pas dire la majorité :/
Edit: , bug ? la dernière page ne m'est apparu qu'après validation du message  :heink:
Message édité par Profil supprimé le 30-01-2014 à 15:30:06
n°9035888
aresias
Posté le 30-01-2014 à 15:28:32  profilanswer
Il faut savoir quand même que c'est le tout début de Mantle et que pour l'instant il y a que des optimisations CPU. Les optimisations GPU sont encore en R&D. Bref ça peut que monter.
n°9035897
mazingerz
Posté le 30-01-2014 à 15:32:09  profilanswer
je pensais que tu parlais de test non officiel
AMD à donné ces gain vs windows 8
n°9035898
Mini_BN
Posté le 30-01-2014 à 15:33:18  profilanswer
Désinstallation avec l'utilitaire, réinstallation des 13.12 ... Toujours dans les 58-63 FPS sur BF4 (Tout à fond).
Pour moi, leur mise à jour est la responsable.
Je ferais des essais sur les autres jeux dans 2 heures, j'en ai marre la ^^
n°9035902
duflotte
Posté le 30-01-2014 à 15:34:04  profilanswer
ce que tu dis n'a pas vraiment de sens. puisque mantle fait sauter un verrou pris en compte lors de la CONCEPTION d'un jeu.
certaine maniere de faire la 3D pourraient devenir exploité , et c'est ca qui pourrait changer la donne.
mais faut reconnaitre que 40% de gain sur un cpu bas de gamme , epaulé d'un GPU haut de gamme, ca doit faire chier intel , quelque chose maison ...
n°9035910
aliss
Posté le 30-01-2014 à 15:39:12  profilanswer
Plutôt nVidia, les machine à base d'Intel en profiteront tout autant pour peu que le gpu soit CGN 1.0 et plus.
n°9035923
reve22
Posté le 30-01-2014 à 15:47:04  profilanswer
Les deux en fait ...
Les CPU "multicore" sont moins cher chez AMD => pourquoi acheter intel pour plus cher et moins bien (en jeux).
Les GPU nVidia non compatible Mantle => aucune raison de les acheter si ils sont plus cher ... pour moins de perf (a moins d'avoir un CPU @ 1000€ ... ah ahahahahaha)
n°9035937
Fouge
Posté le 30-01-2014 à 15:52:17  profilanswer
C'est vrai, mais les APU/CPU AMD sont globalement moins perf que les Intel, ils en profiteront donc plus : l'écart se réduira dans les jeux Mantle.
Ca peut vraiment faire un argument de vente pour les joueurs... à condition que Mantle se retrouve dans une grosse majorité de jeux, mais ça ne touchera pas les joueurs qui prendront des CG nVidia quoiqu'il arrive.
n°9035945
aliss
Posté le 30-01-2014 à 15:57:43  profilanswer
De tous les exemples fournis aujourd'hui par DICE et AMD, c'est le 3970x avec ses radeons en crossfire qui propose le plus gain, je trouve ça assez cocasse que Mantle tire aussi bien partie des threads de l'hexa d'Intel.
Mais du coup on peut se demander si ça va vraiment modifier la hiérarchie des cpu's et booster les ventes de cpu's d'AMD.
A mon sens si Mantle prend, c'est principalement nVidia qui a du soucis à se faire.
n°9035967
Fouge
Posté le 30-01-2014 à 16:06:49  profilanswer
Au alors, malgré Mantle, les gros CPU Intel restent les plus à même de monter dans des framerate élevés (cas d'utilisation d'un CF de 2 grosses CG dans une résolution classique mono-écran).
A mon avis non (juste des écarts moins important), et non pour les APU/CPU
Par contre pour les Radeon, possible que cela joue niveau ventes au détail (au détriment d'nVidia donc).
Message édité par Fouge le 30-01-2014 à 16:09:50
n°9035991
tfpsly
Sly
Posté le 30-01-2014 à 16:17:15  profilanswer
En gros, gestion manuelle des deux GPU, plus efficaces que le Xfire dans ce cas (car le driver Xfire ne peut pas savoir comment fonctionne l'engin du jeu).
n°9036040
fuzzfactor
Cherche pc portable !
Posté le 30-01-2014 à 16:47:47  profilanswer
Ah d'accord, donc en gros avec ,ma r9 280x je suis *****,je suis pas en GCN 1.1... Ils sont sérieux ? La r9 280x doit représenter au moins 50% des ventes d'amd...
Pfff
Message édité par fuzzfactor le 30-01-2014 à 16:55:26
n°9036056
mazingerz
Posté le 30-01-2014 à 16:56:00  profilanswer
non faut attendre un peut plus longtemps
n°9036062
reve22
Posté le 30-01-2014 à 17:00:04  profilanswer
Sur le site de Dice, les tests "medium" sont fait avec une 7970 ... donc pas GCN 1.1 et annoncent 25% de gain.
Le GCN 1.0 est donc quasi pret ...
n°9036063
fencerone
Posté le 30-01-2014 à 17:00:07  profilanswer
Ceux qui ont des R9 se frottent les mains. Moi je suis en CrossX de Pitcairn, c'est juste un espoir de stabilité.
Mais dans combien de temps ?
J'ai un peu peur que ça devienne une release tout les six mois ce truc.
n°9036070
fuzzfactor
Posté le 30-01-2014 à 17:05:10  profilanswer
Oui lais déjà le temps que ça a mit pour arriver... J'ose pas imaginer combien de temps ça va mettre pour le GCN 1.0
n°9036085
duflotte
Posté le 30-01-2014 à 17:12:44  profilanswer
d'apres les slides, l'ecart se reduira a PEAU DE CHAGRIN , entre un bas de gamme AMD a 100 boules , et un haut de gamme a 1000 boules. c'est ca qui dechire
http://img15.hostingpics.net/pics/842035amdcpuscaling640x303.jpg
Message édité par duflotte le 30-01-2014 à 17:16:38
n°9036086
bob3301
Posté le 30-01-2014 à 17:14:00  profilanswer
Je m'excuse de mon ignorance mais cgn ça correspond a l'architecture ???
7970 = cgn 1.0 = 280x ?
n°9036090
aliss
Posté le 30-01-2014 à 17:16:26  profilanswer
CGN 1.1
- Radeon HD 7790
- Radeon R7 260/260X
- Radeon R9 290/290X
- APU A-Series 7000
CGN 1.0
- Radeon HD 7700/7800/7900 (sauf 7790)
- Radeon HD 8000 OEM
- Radeon R9 270/270X/280X
- Radeon HD 7700M/7800M/7900M
- Radeon HD 8000M
- Radeon R5 M230, R7 M265, R9 M290X
http://www.hardware.fr/news/13551/ [...] 4-10h.html
n°9036092
Roxpotatoe​s
Posté le 30-01-2014 à 17:16:33  profilanswer
De toute facon les pilotes nvidia sont bien mieux optimisé pour éviter le cpu limited.
http://pclab.pl/zdjecia/artykuly/c [...] eforce.png
http://pclab.pl/zdjecia/artykuly/c [...] radeon.png
Amd fait que rattraper son retard ( en avouant leurs incompétence sur dx )
AMD ou autre ?AMD ou Intel
[conseil] - upgrade CG+CPU+GPU[HFR] Actu : Samsung a-t-il honte d'intégrer des APU AMD?
Conseil HTPC envoyer image tv et projecteur 3D AMD 7790[HFR] Actu : AMD Catalyst 13.11 Beta : R200, 4K et EyeFinity
AMD ou nVidia, l'heure du bilan : qui est le plus fiable ?GPU qui ne chauffe pas, possible ?
[HFR] Actu : AMD lance les Radeon R7 250 et R7 240[HFR] Dossier : AMD Radeon R9 280X, 270X et R7 260X en test
Plus de sujets relatifs à : [Topic Unique] Mantle : l'API GPU d'AMD
