3947 connectés
 Page :   1  2  3  4  5  ..  20  21  22  23  24  25
[tomik sûrement officiel] NV 35 !
n°2341889
mareek
Et de 3 \o/
Posté le 03-04-2003 à 22:09:27  profilanswer
Evildeus a écrit :
mareek ok, mais il me semble que Marc avait (plus ou moins) donné la fin du 1er NDA et ensuite celui de novembre (certes pas 2 mois avant mais qd meme ;))
il a du être flou, comme dans le message que j'ai posté.
"I wonder if the internal negative pressure in self pumping toothpaste tubes is adjusted for different market altitudes." John Carmack
n°2341891
evildeus
Posté le 03-04-2003 à 22:10:28  profilanswer
Prolongement je pense ;)
NV35 to Be Formally Announced Next Month.
With Cards to Follow in Early June or Late May?
Taiwanese media-sources revealed that NVIDIA?s next-generation NV35 graphics processor will be formally announced next-month with actual graphics cards appearing shortly afterwards.
We told you in the past that NVIDIA?s NV35 graphics chip had been taped out by CeBIT Hannover 2003 and was even demonstrated behind the closed doors during the show. Even if it was not the final revision of the chip, I remember NVIDIA claiming that it usually takes the Santa Clara-based fabless semiconductor company about 100 days to start the mass production after the first tape-out (100 Days Tape Out To Production, as NVIDIA calls it), so, if we presuppose that the NV35 was taped out in late February or early March, we can expect the company to start the production in mid to late May. As a result, actual graphics cards can reach the shelves of the stores in early June or even late May in the best case.
Remember that NVIDIA and IBM said that the latter will produce GeForce FX-series of graphics processors starting this Summer. Hence, if IBM actually makes the NV35 GPU, we will see appropriate graphics cards sometime later than in early June. Though, these are only assumptions.
NV35 GPU is going to be a considerably improved GeForce FX 5800 (NV30) graphics processor with several modifications made in order to boost performance, yield and other obstacles that presently do not let NVIDIA to start selling its GeForce FX 5800 solutions in mass quantities. The graphics cards based on the new graphics processor will utilise DDR SDRAM memory and feature 256-bit bus, providing more bandwidth than the current DDR-II memory with 128-bit bus on the GeForce FX 5800 Ultra.
http://www.xbitlabs.com/news/video [...] 41724.html
Message édité par evildeus le 03-04-2003 à 22:11:13
But if they think they're going to hold onto it, they're smoking something hallucinogenic - Jen-Hsun Huang
n°2341896
mareek
Et de 3 \o/
Posté le 03-04-2003 à 22:11:08  profilanswer
MagiSim a écrit :
quand un NDA est fini, il en remettent un ?  [:trey azagthoth]
je crois que dans le cas du nV30, la fin du NDA a été repoussé pour des raisons "inconnues"  :whistle:
Message édité par mareek le 03-04-2003 à 22:11:51
n°2342557
evildeus
Posté le 04-04-2003 à 08:47:21  profilanswer
:bounce:
n°2342793
Marc
Chasseur de joce & sly
Posté le 04-04-2003 à 11:06:43  profilanswer
Evildeus > Cette news et toutes celles qui ont suivit concernant une annonce du NV35 le mois prochain proviennent de l'article dans lequel Digitimes indiquait que le RV350 allait être produit fin avril et non pas en juin (depuis quand il a été prévu en Juin ? :D ) afin d'être en face du NV35 (RV350 vs NV35, bien sûr :D). Dans cet article Digitimes indiquait "Nvidia plans to introduce its NV35, an updated version of the GeForce FX 5800 (NV30), in May". Mais bon, étant donné le reste des infos peu crédible dans le papier, je ne sais pas quel crédit apporter à cela ...
NVIDIA a indiqué que la prod serait pour cet été, et que la puce ne serait annoncée que lorsqu'elle serait quasi dispo. Reste à savoir ce que ca veut dire quasi dispo, car si c'est une annonce en Mai, et que les puces sortent des chaines dans le meilleurs des cas à partir du 21 Juin, ca fera + d'un mois mini entre l'annonce du NV35 et la dispo des cartes.
Enfin bon une annonce en Mai ou en Juin semble crédible, ca ferait tard après :/
n°2342840
evildeus
Posté le 04-04-2003 à 11:26:46  profilanswer
Yep Marc, mais cela fait un petit moment que Mai/juin semble etre la date de lancement (rumeurs). Maintenant, si Nvidia veut reprendre la tete pendant un moment (4-6 mois) il faut qu'ils arrivent à sortir la carte cet été, plutot au début.
Mais bon, tu as plus d'infos que moi (nous) sur la chose ;)
J'espère pour eux qu'ils vont enfin réussir à sortir une carte potable (400+MHz/400+MHz chip/mémoire bus 256 bits) rapidement, parce que je vois pas Ati ralentir la cadence (sauf pb avec le 0.13 micron)
n°2342850
Marc
Posté le 04-04-2003 à 11:31:45  profilanswer
A ce propos, il est où le 9600 ?  :ange:
n°2342865
mareek
Et de 3 \o/
Posté le 04-04-2003 à 11:38:58  profilanswer
il a les même infos que nous sur la production: Jen a annoncé publiquement que la production du nV30 commencerait cet été. Donc toutes les rumeurs qui annoncent une production avant l'été sont fausses.
n°2342867
mareek
Et de 3 \o/
Posté le 04-04-2003 à 11:39:49  profilanswer
dans les PC medion [:boidleau]
n°2342874
Oxygen3
Tears from the moon
Posté le 04-04-2003 à 11:42:02  profilanswer
on s'en fout c'est une merde le 9600  :whistle:
Metro-PoleRéseau A Suivre...: Annuseries|LeVillage|pErDUSA
n°2342880
MagiSim
Magique, et oui !
Posté le 04-04-2003 à 11:43:54  profilanswer
Chai ALDI !  [:ruxx]
Pour savoir pourquoi je suis magique, faut me connaître !
n°2342886
Oxygen3
Tears from the moon
Posté le 04-04-2003 à 11:45:22  profilanswer
oui, tres bien, mais je redis ce que j'ai déjà dis y'a 20 pages:
un lancement en juin ou juillet avec une dispo rapide c'est louche ...
suffit de voir tts les lancements de ces dernieres années, y'a pas bcp qui ont été lancés en juin:
nf2: annoncé juillet, dispo novembre
RV300: annoncé juillet, dispo octobre
R300: annoncé juillet, dispo septembre
parhelia, annoncée juin, tt le monde s'en fout (dispo juillet ?)
bref, je vois pas trop l'intéret économique d'un lancement/annnoce en juin
mai semble plus crédible, mais apparement les puces sont pas tout à fait pretes pour un lancement en mai :/
enfin bref c zarb
pour le r9600, on a tout intéret a ce qu'il arrive pas trop vite, histoire de garder les r9500pro plus perfs et tres similaires :D
n°2342901
evildeus
Posté le 04-04-2003 à 11:50:18  profilanswer
Heu, ben sur le papier chez Ati?  :ange:
n°2342903
evildeus
Posté le 04-04-2003 à 11:51:40  profilanswer
Encore faut il qu'ils ne ce soient pas plantés avec les 9600 TX  :whistle:
n°2343146
Ernestor
modo-coco :o
Posté le 04-04-2003 à 14:15:46  profilanswer
Le troll du vendredi  :sol:
http://www.nofrag.com/news/avr2003/04/5612.html
Exclu mondiale : Half Life 2 exclusivement sur les cartes nVidia
Vendredi 4 avril 2003 à 12h24 par Dr Loser
SPOnG se targue d'avoir mis la main sur un scoop : des employés de nVdia leur auraient assuré que Valve est sur le point de faire en sorte que Half-Life 2 fonctionne exclusivement sur les cartes 3D de nVidia.
Ce genre d'accord entre un développeur et un constructeur de carte 3D serait le premier au monde et, toujours d'après les employés de nVidia, serait loin d'être le dernier. Les gars de SPOnG prétendent être au courant depuis déjà un moment qu'ATI et nVidia cherchent à établir ce genre d'accords avec les développeurs pour faire en sorte que de futurs bestsellers ne fonctionnent que sur leurs cartes.
L'un des prétendus employés de nVidia ajoute : "D'ici quelques mois, vous allez constater d'importants changements dans l'industrie des jeux PC et ce, dès l'E3 où seront diffusées les premières annonces officielles. Au lieu de parler de jeux PC, vous devrez alors parler de jeux nVidia ou ATI, tout comme vous distinguez actuellement les jeux Nintendo et Sony."
SPOnG conclut son article en nous assurant que ce scoop sera confirmé en mai, pendant l'E3.
Je doute de la véracité de ces informations. Reste à savoir si toute cette intox est un coup de pub diffusé par SPOnG ou pa le constructeur nVidia. Ou qui sait... peut-être que durant l'E3 Valve va vraiment annoncé qu'Half-Life 2 est en développement et ne fonctionnera que sur les cartes nVidia! *rires*
n°2343233
evildeus
Posté le 04-04-2003 à 14:55:44  profilanswer
J'ai déjà vu les débats sur les fora anglo-saxons, ca me suffit :D
n°2343542
evildeus
Posté le 04-04-2003 à 16:48:44  profilanswer
Petit SS en 16*AA + 8*AF en 1024.
http://www.bjorn3d.com//Material/Images/211_Vietcong1.jpg
http://www.bjorn3d.com/ubbthreads/ [...] o=&fpart=1
n°2343547
MagiSim
Magique, et oui !
Posté le 04-04-2003 à 16:50:10  profilanswer
Dommage que la compression soit faite au marteauu piqueur.... ça accentue encore l'effet de l'aAA.... :/
n°2343560
evildeus
Posté le 04-04-2003 à 16:54:51  profilanswer
Et une jolie démo d'effets de lumières (cartes DX9 ... heu des Ati?  :whistle: )
*edit* merde le lien :D
http://www.daionet.gr.jp/~masa/rthdribl/index.html
Message édité par evildeus le 04-04-2003 à 16:55:13
n°2343571
evildeus
Posté le 04-04-2003 à 16:58:58  profilanswer
pourquoi au marteau piqueur?
n°2343594
blazkowicz
Posté le 04-04-2003 à 17:09:00  profilanswer
il est immonde ce screenshot :lol:
forcément, seulement 80ko pour une grosse image...
n°2343595
Marc
Posté le 04-04-2003 à 17:09:07  profilanswer
C quoi ce screenshot pourri :lol:
n°2343608
MagiSim
Magique, et oui !
Posté le 04-04-2003 à 17:14:55  profilanswer
Voilà, ils ont exprimé  clairement ce que j'osais pas te dire sous peine de te choquer... :D
n°2343669
evildeus
Posté le 04-04-2003 à 17:39:14  profilanswer
Ah ouais :/ ben c'est parce que moi je l'ai enregistré en bmp  :lol: (2.8Mo  :sol: )
n°2343711
MagiSim
Magique, et oui !
Posté le 04-04-2003 à 17:55:05  profilanswer
Bon, sinon, c'est bien sympa ta démo, ça tourne très bien... Vivement les Radeon 20.000 qu(on puisse avoir ça en temps réel sur un jeu complet :D (40 fps tous effets actifs en fenêtré de base).
n°2345004
evildeus
Posté le 05-04-2003 à 11:23:30  profilanswer
:bounce:
n°2345007
hide
Posté le 05-04-2003 à 11:25:55  profilanswer
cool on aura ça comme jeux dans 2 ans [:huit]
Et si c’était ça la vie / Et si on nous l’avait pas dit ?
n°2345455
Oxygen3
Tears from the moon
Posté le 05-04-2003 à 15:02:15  profilanswer
j'adore les videos dans les jeux quand ca utilise pas le moteur du jeu :o
n°2345835
hide
Posté le 05-04-2003 à 18:00:26  profilanswer
:lol:  :sweat:
n°2346987
evildeus
Posté le 06-04-2003 à 11:08:41  profilanswer
:bounce:
n°2347313
blazkowicz
Posté le 06-04-2003 à 14:02:01  profilanswer
c'est de l'ironie ?  :whistle:
n°2347683
Oxygen3
Tears from the moon
Posté le 06-04-2003 à 16:27:32  profilanswer
n°2347840
hide
Posté le 06-04-2003 à 17:55:20  profilanswer
[:zebra33]
n°2347955
MagiSim
Magique, et oui !
Posté le 06-04-2003 à 18:44:09  profilanswer
PTDRAM ! ! ! [:xp1700]
A part que comme d'hab, on parle de techmachin, mais jaùmais de HFR, lollll !
Splendide !
n°2348021
supermimy
L' AC3/DTS ca roxxe sa maman
Posté le 06-04-2003 à 19:16:43  profilanswer
Pourquoi fodrait t-il peter des RAM ?  :whistle:
 [:azzaro75]    <<< je cours me cacher  :pt1cable:
n°2348038
MagiSim
Magique, et oui !
Posté le 06-04-2003 à 19:25:38  profilanswer
Tttends, je viens avec toi !  :love:
n°2348179
evildeus
Posté le 06-04-2003 à 20:24:56  profilanswer
Annonce à l'E3?  :whistle:
http://www.e3expo.com/current_exhibitors/?search=M-P
n°2348226
mareek
Et de 3 \o/
Posté le 06-04-2003 à 20:44:41  profilanswer
tu le fais exprès ? :o
Jen-Hsun Huang a annoncé officiellement que la production du nV35 commencerait cet été et que l'annonce serait faite juste avant la dispo. Ca ne peut donc pas être à l'E3 qui se déroule mi mai.
n°2348231
evildeus
Posté le 06-04-2003 à 20:48:19  profilanswer
First look de...? ;)
n°2348278
mikestewar​t
Air Roll Spinnin'
Posté le 06-04-2003 à 21:09:09  profilanswer
Je suis d'accord avec Evildeus (pour une fois :D ) : Nvidia va faire une annonce du NV35 à l'E3, sinôn ça serait quoi ce nouveau produit ? :) (en plus avec les rumeurs... ;) ) Mais ça sera une annonce à l'image de celle du NV30, specs et demo et c'est tout (avec bien sûr quelques chiffres alléchants :D ). Pour les reviews faudra attendre cet été ! :)
Message édité par mikestewart le 06-04-2003 à 21:11:08
n°2348457
segaman
Posté le 06-04-2003 à 22:16:10  profilanswer
voulez pas faire un chti resumé souplait...
ca fais un moment qu'je calle sur ff7 et ouais 2 jour d'affilé donc plus eu le temp de me maintenir a jour niveau news...
[Topic Officiel] CM SiS655 PIV ( Gigabyte dispo debut fevrier ) suiteTopic Officiel ASUS P4G8X - E7205 P4 + DUAL DDR [BIOS Beta 1005.1]
[Topic Officiel] Asus A7N8X (nForce2)[Topic officiel] ABIT NF7-S nForce 2
[TOPIC OFFICIEL] -<<Cartes Mères SIS 655/FX - P4 HT - Dual DDR>>-[tomik sûrement officiel] NV 35 !
[TOPIC OFFICIEL] <<< Cartes mères SIS 655 - P4 HT - Dual DDR >>>[Topic officiel] ASUS A7V333
Plus de sujets relatifs à : [tomik sûrement officiel] NV 35 !
