4638 connectés
Fréquences + type de vos m.à.j.
Sondage à 2 choix possibles.
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  913  914  915  ..  1017  1018  1019  1020  1021  1022
[Topic Unique] Radeon™ Software Adrenalin 2020 Edition ● CG & APU !
n°10606706
lapin
Posté le 25-07-2019 à 20:07:51  profilanswer
nouveau driver Radeon Software
Radeon™ Software Adrenalin 2019 Edition 19.7.3 Release Notes
https://www.amd.com/en/support/kb/r [...] win-19-7-3
Radeon Software Adrenalin 2019 Edition 19.7.3 Highlights
Support For
Wolfenstein™: Youngblood
Up to 13% better performance with Radeon™ Software Adrenalin 2019 Edition 19.7.3 in Wolfenstein: Youngblood than with Radeon™ Software Adrenalin 2019 Edition 19.7.2RS-304
Radeon GPU Profiler on Radeon RX 5700 series graphics products
Microsoft PIX on Radeon RX 5700 series graphics products
Added Vulkan® Support
VK_EXT_display_surface_counter
This extension defines a vertical blanking period counter associated with display surfaces. It provides a mechanism to query support for such a counter from a VkSurfaceKHR object
VK_AMD_pipeline_compiler_control
This extension provides a way to set per-pipeline compiler options, for instance, to relax rounding rules when working with mixed-precision floating point values.
VK_AMD_shader_core_properties2
This extension exposes additional, AMD specific shader core properties for a physical device
VK_EXT_subgroup_size_control
This extension provides additional control over subgroup size, allowing applications for instance to opt-in to different subgroup sizes on devices supporting more than just one.
VK_KHR_imageless_framebuffer
This extension allows framebuffers to be created without the need for creating images first, allowing more flexibility in how they are used, and avoiding the need for many of the compatibility rules.
VK_KHR_variable_pointers
This extension allows implementations to indicate their level of support for the SPV_KHR_variable_pointers SPIR-V extension. The SPIR-V extension allows shader modules to use invocation-private pointers into uniform and/or storage buffers, where the pointer values can be dynamic and non-uniform. This release adds the optional VariablePointers support.
Fixed Issues
League of Legends™ may fail to launch on Radeon RX 5700 Series Graphics with Windows®7 system configurations.
Radeon RX 5700 series graphics products may experience DirectX®9 application crashes or hangs after an express upgrade of Radeon Software.
Windows Mixed Reality may fail to launch when Radeon Image Sharpening is enabled on Radeon RX 5700 series graphics products.
Audio may be out of sync with videos when using Radeon ReLive VR.
Incorrect values may be shown in the power gauge for Radeon WattMan while applications are running on AMD Radeon VII.
AMD Log Utility Driver may intermittently fail to install on Windows®7 system configurations.
Radeon Anti-Lag may experience slight performance drops on some gaming applications when enabled.
Minor stuttering may occur when playing Fortnite™ during the first few minutes of gameplay on AMD Radeon RX 5700 Series Graphics.
Radeon Overlay may experience flickering in Vulkan® API games when Radeon Image Sharpening is enabled.
Corruption may be observed in some tests when running Adobe™ Premier Pro 2019 benchmarks.
Known Issues
Some system configurations may experience green color corruption after install of Radeon Software when running Windows® 10 May 2019 update.
Stutter may be experienced when Radeon FreeSync is enabled on 240hz refresh displays with Radeon RX 5700 series graphics products.
Radeon Performance Metrics may report incorrect VRAM utilization.
AMD Radeon VII may experience elevated memory clocks at idle or on desktop.
Radeon Overlay may intermittently fail to appear when toggled in game.
Audio for clips captured by Radeon ReLive may be corrupted or garbled when desktop recording is enabled.
Radeon RX 5700 Series Graphics may experience a black screen during uninstall on Windows®7 system configurations. A work around is to perform uninstall in safe mode.
Recording clips with Radeon ReLive may result in blank clips on Radeon RX 5700 Series Graphics with Windows®7 system configurations.
Enabling Enhanced Sync may cause game, application or system crashes on Radeon RX 5700 series graphics products.
n°10606994
PsykOoO
Posté le 26-07-2019 à 12:33:59  profilanswer
Crash systématique en passant sur le 19.7 avec ma RX 480.  :o
n°10607045
scrumpz
Posté le 26-07-2019 à 14:25:42  profilanswer
Ouais je pense qu'il y a de sérieux problèmes avec la 19.7 sur les rx480...
-> A vendre matos Hardaware <-
n°10607142
BloodyCarn​age
Posté le 26-07-2019 à 16:04:26  profilanswer
Sauf que je n'ai pas de problème particulier avec ma 480 et que j'ai fait toutes les versions 19.7.x.
Nothing's so bad it can't get worse
n°10607198
scrumpz
Posté le 26-07-2019 à 17:13:25  profilanswer
Cela dépend peut être des versions custom ou non.
Comme avec les nvidia, mort prématurée certaines séries...
En faisant des recherches j'ai vu pas mal de personnes se plaindre des mêmes soucis que moi ou rapproché à mes problèmes avec les 17.7.x
Après il y a tellement de paramètre à prendre en compte que la corrélation est pas forcément avérée et s'il y trop peu d'unités en cause va trouver le problème...
Message édité par scrumpz le 26-07-2019 à 17:14:32
n°10608409
ledesillus​ionniste
Posté le 28-07-2019 à 19:48:38  profilanswer
Je n'ai pas de gros problèmes sur ma rx570 avec les 19.7.x
Le plus gros que je vois c'est le fait d'avoir parfois 2fois radeon settings chargé au démarrage (2x l'icone dans la zone de notif).
Je passe par contre sur les .3, j'attends le debug de cette version avant d'installer, les bugs connu des .3 me tentent pas.
Message édité par ledesillusionniste le 28-07-2019 à 19:55:29
n°10608595
Bobox
Yuri Orlov :)
Posté le 29-07-2019 à 08:35:04  profilanswer
Perso j'ai constaté une baisse de perf sur forza horizon avec cette dernière béta, j'étais bloqué à 60fps en 4k en whql et maintenant j'ai des variations entre 55 et 60fps
n°10609080
lapin
Posté le 29-07-2019 à 22:25:24  profilanswer
Radeon Software Adrenalin 2019 Edition 19.7.4 Highlights
https://www.amd.com/en/support/kb/r [...] win-19-7-4
ça ne corrige quasiment rien un crash sur GTA V.
Fixed Issues
Grand Theft Auto™ V may experience an application crash or hang on Radeon RX 5700 series graphics products.
Known Issues
n°10609473
chriskenob​y
Que la force soit avec vous
Posté le 30-07-2019 à 15:15:34  profilanswer
Hello, je colle la news ici au cas ou ;)
https://www.cowcotland.com/news/682 [...] 9-7-3.html
n°10609809
burn2
Pour ceux qui viendront après
Posté le 30-07-2019 à 22:53:01  profilanswer
Avec wattman on ne peut pas changer la courbe de ventilation pour obtenir quelque chose de plus silencieux sur ces gpus là?
Autant sur une RX580 and co c'est un peu chiant de faire sa courbe parce qu'on perd le ventilateur à 0 en idle (bon perso je l'ai fais vu que sous windows je ne fais que jouer) autant sur un gpu ou le ventilo tourne déjà en idle c'est quoi l'inconvénient de refaire sa courbe?
n°10610591
AwsomeReli​que
Posté le 01-08-2019 à 09:26:03  profilanswer
19.7.5 vient de sortir:
https://www.amd.com/en/support/kb/r [...] win-19-7-5
Message édité par AwsomeRelique le 01-08-2019 à 09:26:36
n°10610775
scrumpz
Posté le 01-08-2019 à 12:51:46  profilanswer
et un seul jeu résolu.. c'est quoi ce délire de sortir ces patchs pour un jeu...
Il serait temps qu'il fasse des mise à jour incrémentale pour éviter de download la totalité des drivers à chaque fois...
Après c'est peut être pas possible avec le système windows...  [:canard sans bec:4]
n°10610835
AwsomeReli​que
Posté le 01-08-2019 à 14:13:46  profilanswer
Oui, ça fait beaucoup de drivers en si peu de temps, mais apparemment il se passe des trucs ou coulisses, genre des gain de perf sous linux (mais là c'est sous windows :whistle: ), des optimisations etc
Message édité par AwsomeRelique le 01-08-2019 à 14:16:59
n°10610886
PowerMarce​l
Full Chip Crew
Posté le 01-08-2019 à 14:59:37  profilanswer
Perso je rencontre occasionnellement des soucis de flickering avec ma 5700 XT, j'espère qu'il s'agit uniquement d'un soucis logiciel, le fait qu'il y ait un nouveau pilote tous les trois jours semble confirmer que de nombreux soucis persistent de ce côté.
n°10610954
BloodyCarn​age
Posté le 01-08-2019 à 16:05:22  profilanswer
Il y a toujours eu "un nouveau pilote tous les trois jours", ce sont des beta. Si tu n'installes que les versions recommandées, c'est environ un par mois.
n°10611031
m_gab
Posté le 01-08-2019 à 18:28:02  profilanswer
Avec ma rx580 aussi en idle mais c'est lié à Firefox chez moi, résolu le problème en passant sur Chrome.
n°10612224
PowerMarce​l
Full Chip Crew
Posté le 04-08-2019 à 15:08:34  profilanswer
En désactivant l'accélération matérielle dans FF il me semble que je n'ai plus eu de soucis dans FF, cependant j'ai pu l'observer dans le menu de Rage.
Je viens de passer en HDMI et là tout semble OK dans tous les cas, j'ai réactivé l'accélération matérielle dans FF, RAS.
Si le soucis vient de mon câble DP je suis assez surpris, c'est un câble de qualité, pas très long et que j'ai utilisé sans soucis avec ma Vega 64, ma RX 480, mon HD 7790...
Je ferai peut-être d'autres tests par la suite.
n°10612283
AwsomeReli​que
Posté le 04-08-2019 à 18:21:49  profilanswer
Je crois que c'est un problème qu'on peut rencontrer avec certains monitors. Des fois, en changeant le câble DP, on règle le problème de flickering, mais c'est pas garantie.
Dans mon cas, j'ai pas voulu changer de câble DP, parce qu'avec un refresh rate à 144hz j'ai plus de problème, alors qu'à 120/100 (je reste pas en 144hz parce le vcore ne se met pas en idle) j'ai des blackscreen intermittents...ce qui est contradictoire.
Je suis passé au hdmi, et là, plus de problème avec aucun taux de rafraîchissement (et la carte se met bien en idle). par contre, je crois que perd un peu en saturation et couleur.
C'est un truc software, que malheureusement, AMD n'a pas corrigé.
n°10614236
ledesillus​ionniste
Posté le 08-08-2019 à 22:08:37  profilanswer
J'ai finalement quand même mis les 19.7.5 et j'ai observé des clignotements d'items sur les écrans de pause de Devil may cry 5.
Message édité par ledesillusionniste le 08-08-2019 à 22:08:52
n°10616273
lapin
Posté le 12-08-2019 à 18:23:04  profilanswer
nouveau drivers Radeon Software Adrenalin 2019 Edition 19.8.1 Highlights
https://www.amd.com/en/support/kb/r [...] win-19-8-1
Support For
Microsoft® PlayReady®3.0
 Supported on Radeon RX 5700 series graphics products.
Fixed Issues
Some system configurations may experience color corruption after install of Radeon Software when running Windows® 10 May 2019 update. Issue is resolved in the latest Windows® Update 18362.267 (KB4505903)
Radeon Chill settings may not sync with game profile settings when changed in-game through Radeon Overlay
Radeon RX 5700 series graphics products may experience a black screen or flickering when applying auto overclocking memory with games or applications running in fullscreen
Radeon AntiLag may slightly impact performance in select games
Known Issues
Important Notes
AMD Ryzen™ Mobile Processors with Radeon™ Vega Graphics FAQ for Radeon Software Adrenalin 2019 Edition can be found here.
n°10619718
scrumpz
Posté le 19-08-2019 à 10:58:18  profilanswer
[3615 my life /on]
J'ai changé le refroidissement du CPU, nettoyé le GPU et changé la pate thermique et désossé mon alimentation pour enlever la poussière ainsi que dans tout le boitier et je n'ai plus de problème de "irlq not less or equal"
Donc pour ceux que ça pourrait aider, faite le ménage même s'il n'y pas beaucoup de poussière
[36 15 my life /off]
n°10620365
yoyo0601
Posté le 20-08-2019 à 13:17:02  profilanswer
Bonjour a tous, fraichement revenu chez amd j ai quelques soucis avec ces pilotes adrenalin, peut etre que vous aurait un fix pour moi :)
1er soucis: je ne peux pas changer la resolution sur ma tv 4k je suis degouté..seul le 1080p passe les autres c est blackscreens d office ou des fourmis comme a l ancienne sur le reseau hertzien. Par le bureau windob ou radeon setting que sa soit en hdmi ou display port.
2e: en Vr si je lance le soft oculus avant wattman pour activer mon profil d oc j ai une souris qui reste bloqué sur la lentille droite en bas gauche c est inevitable :/
3e: le dernier pilote me donne des bluescreens avec le mode sapin de noel de ma cm, bsod pareil avec gpu tweak et quelques autres...
Downgrade forcé en 19.0 car plus de bsod et la compatibilité avec mes progs/games Ok, windows reconnait les resolutions de la tv mais rien ne marche alors qu avec les derniers adrenalin il ne reconnait strictement rien 1080p max aulieu de 3840x2160 sa pique un peu xD
la config
ryzen 3600@4,27
rx5700xt
2x8 3200mhz
ssd toussa
merci d avance
n°10620386
lapin
Posté le 20-08-2019 à 14:09:32  profilanswer
la config
ryzen 3600@4,27
rx5700xt
2x8 3200mhz
ssd toussa
merci d avance
Tente une fréquence de 59hz pour les définitions 3840*2160 ou 4K.
Prends garde à être en YCbCr en 4:2:2 pour avoir accès au 10 et 12 bits pour avoir accès au HDR.
éventuellement change de câble HDMI, un modèle de marque XO exemple un câble  HDMI XO de 3 mètres à 7,95€ https://www.amazon.fr/C%C3%A2ble-Vi [...] B07D5F4VFJ
les ports display port sont très capricieux.
ça fait dès mois que les drivers radeon ne fonctionne pas bien avec les définitions élever en 60 Hz ça ne fonctionne pas bien mais en 59 Hz ça fonctionne correctement j'ai du vrai HDR en 12 bits par couleurs en 3840*2160.
n°10620476
yoyo0601
Posté le 20-08-2019 à 16:52:30  profilanswer
Hello merci pour ton retour
j ai bien le meme code couleur que tu cites mais seulement en 8bits alors que j ai du 12b sur la 1070 avec la meme chose.
J ai donc reussi a faire marcher la 4k@60hertz uniquement sur l un des ports display en desactivant le hdcp dans le radeon setting...on s accroche koi xD
Concernant les cables ils sont ok, l hdmi fonctionne correctement avec nvidia et sur la ati seulement en display port, le second est neuf.
J ai toujours une 390x qui traine qui n accepte la 4k@30h seulement, ça m a mis le doute lol encore merci
n°10620482
lapin
Posté le 20-08-2019 à 17:04:26  profilanswer
peut tu faire un capture d'écran du menu YCbCr et des autres paramètres.
aussi dans Paramètres Windows 10 puis système vérifie que Windows HD Colors est activé pour avoir le HDR, bon sauf si ton moniteur n'est pas HDR.
tente le 59 Hz dans le menu Paramètres d'affichage Avance puis dans Propriétés de la Carte vidéo pour l'affichage 1, puis dans l'onglet écran tu choisi la fréquence 59 Hz et là tente le YCbCr en 4:2:2 et en 12 bits ça devrait fonctionner.
n°10620535
yoyo0601
Posté le 20-08-2019 à 18:27:51  profilanswer
https://ibb.co/wWMM6nb
https://ibb.co/p2XFsL1
Je suis totalement perdu sur la gtx du laptop branché a la tv en hdmi j ai bien ypbr 1.1.1 en 3840x2160@60hertz
J aurai du le preciser mais la tv n a pas le hdr, la maintenant je n arrive plus a avoir de signal sur la tv seule avec la rx..j ai pu voir brievement Resolution de signal actif 38..x21.. mais resolution de bureau 1920x1080 puis j ai reboot pour reactiver le hdcp maisj aurai pas due xD
Honnetement je ne pensais pas que des pilotes pouvaient etre aussi foireux=>19.7.1 je vais reinstaller une enieme fois et laisser en Fhd le temps de me decider si je la renvois, elle envoit du steack en vr c est vraiment dommage mais le confort et le hevc manquant vallent probablement bien 100euros de plus. Encore merci pour ton aide
n°10620551
lapin
Posté le 20-08-2019 à 18:47:02  profilanswer
ha donc peut être est il normal que tu soit bloquer en 8 bits par couleurs.
tu devrais activé la mise à l'échelle par le GPU.
ça fait 2 mois que l'affichage déconne en HDMI en Display Port je ne sais je n'en utilise pas sur mes écrans.
pour infos la garantie de liaison HDMI ne concerne pas le HDCP mais un truc qui tente de faire en sorte que tu n'ai pas d'écran noir ou de déconnexion de l'affichage.
de toute façon avec une 5700 tu es obliger d'utilisé un driver récent car avec les anciens driver ils ne connaissent pas la 5700.
à la marche un coup de DDU en mode sans échec dans windows 10 pour désintaller proprement les drivers.
édit: pour infos la Garantie de liaison HDMI ne concerne pas le HDCP, mais tente d'évité un risque d'écran noir ou de déconnexion de l'affichage ou des artefacts d'images.
Message édité par lapin le 20-08-2019 à 18:50:29
n°10620575
yoyo0601
Posté le 20-08-2019 à 19:13:27  profilanswer
Deja fait le DDU maintes fois aujourd hui :), je n arrive toujours plus a avoir de l affichage seule sur la tv, seulement en mode etendu ou clone en 1080p sur les deux et la j ai bien le choix pour la tv 8/10/12bites pour les couleurs en ypbr 444 pour le 12b du moins...
Un vrai casse tete xD j ai essayé en 59hertz sa ne change pas grand chose non plus, ma tv est toute simple pourtant, j y branche deux laptops en 4k l un avec la gtx et l autre avec le chip intel du i5 car il n y a que sa depuis deux ans sans chichi, sa marche du premier coup comme sa devrait etre le cas.
Peut on simplement se passer de radeon setting? car j ai l impression qu outre les pilotes quelque chose interfere entre les parametres d affichages windows et le radeon setting. Quand j essais en mode etendu de repasser sur la tv, elle affiche dans son petit cadre en haut de l ecran la bonne resolution Fhd mais blackscreen puis repasse en mode etendu dans la seconde.
J utilise gpu tweak qui me permet de loader mes profils d oc/underclock en moins de 3 clicks la ou ou pour arriver a wattman deja bref je pourrai largement me passer de cette usine a gaz meme s il est beaucoup plus precis xD
n°10622812
PowerMarce​l
Full Chip Crew
Posté le 26-08-2019 à 01:36:47  profilanswer
Petit retour sur les pilotes 19.8.1 WHQL du 22 août.
Je rencontrais divers problèmes avec ma RX 5700 XT. Principalement dus aux changements de fréquences GPU et RAM.
Concrètement dans les jeux peu demandeurs la carte restais à un niveau de performance insuffisant pour faire tourner les jeux.
Le streaming sous Firefox (Netflix surtout) provoquait aussi des fluctuations de fréquence qui provoquaient des lignes horizontales furtives plus ou moins fréquentes.
Bref, ces soucis sont pour moi réglés avec ces pilotes 19.8.1 WHQL.
Le seul reproche que je peux faire encore est la fréquence du ventilo qui reste à ~1050 RPM au repos, problème présent depuis les 19.7.3.
n°10623009
Antionn
Posté le 26-08-2019 à 14:59:10  profilanswer
Tu ne trouveras plus que la version 19.8.1 WHQL sur le site AMD ;)
Oui c'est une bonne idée, je posterai un petit retour sur ce topic une fois devant mon clavier.
Ah ... pas trouvé et je viens de re-regarder.
Pareille que pour Radeon Settings qui ne me le proposait pas :o
Bon, faut croire que je maitrise pas encore le site d'AMD et tout :/
Par contre sur le site de GURU3D, c'est bien affiché comme WHQL.
Bref, pas grave, vu que ce sont les mêmes :o
NB : je poste la réponse ici pour pas polluer le TU Navi :o
Mon topic achat // [TU] Radeon Software // [TU] AMD RDNA2 - RX6x00
n°10623031
PowerMarce​l
Full Chip Crew
Posté le 26-08-2019 à 15:45:09  profilanswer
En fait tu le trouves d'office, sans qu'ils aient précisé qu'il est WHQL  ;)
https://i.ibb.co/bByCY2Y/Annotation-2019-08-26-154341.png
La version non certifiée était datée du 12 ou 13, la certifiée du 20  ;)
Une fois installé, si tu exécutes un dxdiag.exe tu peux le vérifier ici :
https://i.ibb.co/0YvwdPf/Annotation-2019-08-26-154611.png
Message édité par PowerMarcel le 26-08-2019 à 15:46:58
n°10623048
Antionn
Posté le 26-08-2019 à 16:48:00  profilanswer
Anéfé elle était bien marquée du 20, donc c'est bon :jap:
Et dxdiag.exe le confirme bien aussi :jap:
Bon bah plus qu'à faire chauffer la Radeon de longues heures endiablées pour tester [:nozdormu]
Message édité par Antionn le 26-08-2019 à 16:51:33
n°10623207
AwsomeReli​que
Posté le 26-08-2019 à 23:30:58  profilanswer
n°10623485
Antionn
Posté le 27-08-2019 à 16:13:09  profilanswer
Petit Bilan de l'aventure "updatons les drivers" :
19.8.1 : artefact "damiers" dés que j'ai appuyé sur "Jouer" dans ma biblio Steam pour PCARS2 [:breezer lemon:2]
19.8.2 : BSOD sous PCARS 2 [:akilae]
Un intense bonheur est né en moi là [:cabri74]
Donc toutes les versions récentes des drivers ne passent plus sur ma carte. N-ième retour en 19.1.1 ...
Et j'ai fait une vérification des fichiers locaux avec Steam ... R.A.S bien sûr.
n°10623487
PowerMarce​l
Full Chip Crew
Posté le 27-08-2019 à 16:15:30  profilanswer
Ce serait peut-être mieux davoir une branche de pilote gcn et une autre rdna :/
n°10623488
lapin
Posté le 27-08-2019 à 16:15:42  profilanswer
fait un rapport de bug, bon il ne liront pas surtout si c'est en français ils n'ont jamais lu les miens, mais si y a suffisamment de personne pour gueuler contre les m^mes problèmes ben à un moment donnée ils ce diront qu'il faut faire quelques chose.
n°10623618
Antionn
Posté le 27-08-2019 à 20:05:34  profilanswer
Je suppose que lors de l'installation, l'installeur sait faire la différence en reconnaissant le matériel ... mais oui, sait-on jamais :/
Cette carte me pousse à la détéster ... si je trouve pas de solution, je vais la remplacer ... mais c'était pas franchement prévu. Et par quoi ... v'là une autre question  :kaola:
Je peux toujours toujours essayer de le faire en anglais ... je dis pas que ce sera bien, mais si peux leur faire lire, je peux essayer [:spamafote]
Sur quelle site/forum/contact il est préférable de leurs signaler ... j'ai jamais fait ça donc j'ai pas trop idée de où est-ce que c’est le mieux ?
Message édité par Antionn le 27-08-2019 à 20:05:52
n°10623720
lapin
Posté le 27-08-2019 à 22:03:33  profilanswer
via les drivers tu a un bug tracker: https://www.feedback.amd.com/se/5A1E27D219333DAD
n°10623730
scrumpz
Posté le 27-08-2019 à 23:01:10  profilanswer
ne tkt pas, en français ils te répondrons sans problème.
Je l'ai fait plusieurs fois et ils m'ont toujours repondu.
Tu vas dans la section support du site amd ;)
n°10624797
Antionn
Posté le 29-08-2019 à 23:09:22  profilanswer
Bon bah je vais essayer de les contacter par cette voie là alors :jap:
Je me suis déjà inscrit sur leur forum ... je m'y colle dés que j'ai plus la flemme :o
Ceci dit, je viens d'avoir la maj 1903 de Windaube (que je ne désirais pas plus que ça, mais bon, vu qu'il la faite en douce ...), je vais réessayer la 19.8.2 au cas où ...
Mais pas sur Pcars 2, j'ai trop mal aux bras là, le G27 me les a tués [:mangez-moi]
Edit : pour le coup j'y crois pas du tout avec W10 1903, mais c'est surtout que sur un malentendu ,on sait jamais et comme j'ai la flemme :o
Message édité par Antionn le 29-08-2019 à 23:49:09
n°10625536
quicksilve​r01
Posté le 31-08-2019 à 19:37:44  profilanswer
Avec les derniers drivers d'amd je crois que j'ai besoin d'une centrale nucleaire  :o
https://zupimages.net/up/19/35/n3pd.jpg
 :lol:  :lol:  :lol:  :lol:  :lol:  :lol:
Gerer Linux comme un pro Toi aussi soit --> Linux CachyOs powered
ATI - Problème avec les CATALYST 3.5 +Question concernant ATI 9800 Pro avec HP80A : chaud brulant !!!!!
Probleme Hydravison et ATIAti Radeon 9600 Pro > Gigabyte HIS Saphire ou Club 3D ?
[Topic Unique] ASUS P4C800 / P4P800 (Intel i865/i875)les CG ATI 9xxx les + o/cables , quelle marque ?
Performance des differentes cartes ATI et Nvidia ??LEADTEK A 360 FX 5700 ou ATI 9600 PRO ?
Plus de sujets relatifs à : [Topic Unique] Radeon™ Software Adrenalin 2020 Edition ● CG & APU !
