7909 connectés
Fréquences + type de vos m.à.j.
Sondage à 2 choix possibles.
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  1017  1018  1019  1020  1021  1022
[Topic Unique] Radeon™ Software Adrenalin 2020 Edition ● CG & APU !
n°11485760
hisvin
Posté le 20-08-2026 à 10:23:02  profilanswer
Il faut pluôt utiliser chill et le mettre à 60-60 par exemple
n°11485789
kakal33
Posté le 20-08-2026 à 18:32:09  profilanswer
y a pas eu de nouveau pilote pour la sortie du DLC et màj du moteur graphique de Stalker 2, j'ai eu des crashs au lancement du jeu :fou:
n°11485822
Umi
Posté le 21-08-2026 à 09:01:12  profilanswer
Adrenalin Edition 26.8.1 Driver Release Notes
Highlights
    New Product Support
        AMD Radeon™ RX 9050 4GB
    New Game Support
        Resonance: A Plague Tale Legacy
        STAR WARS Zero Company™
        Call of Duty®: Modern Warfare® 4 Open Beta Early Access
    Fixed Issues
        Marvel Rivals™ and Subnautica 2 may fail to launch in a multi-adapter (combined graphics) configuration on Radeon™ RX 7000 series and above graphics products.
        Call of Duty®: Modern Warfare® III may crash on startup in a combined graphics configuration on Radeon™ RX 9000 series graphics products.
        AMD Software: Adrenalin Edition recording and replay features may fail to save the captured file when no audio output device is selected on Radeon™ RX 9000 series graphics products on Windows® 10.
Known Issues
    Failure to install may be observed while installing AI Bundle components in some regions with limited access to HuggingFace and GitHub.
    AMD Smart Access Memory may become disabled after driver installation on Windows® 10 systems.
    AMD FSR Upscaling and AMD FSR Frame Generation may show as inactive in AMD Software: Adrenalin Edition while playing Call of Duty®: Modern Warfare® 4 Open Beta Early Access when enabled on Radeon™ RX 9000 series graphics products.
    Anti-Lag 2 may show as inactive in AMD Software: Adrenalin Edition after disabling Frame Generation in Resonance: A Plague Tale Legacy.
    Cyberpunk 2077 recommends a minimum of 6GB of video memory. AMD Radeon™ RX 9050 4GB users experiencing issues are recommended to set graphics intensive features to low or off.
    Intermittent game crash may be observed while playing Starfield on Radeon™ RX 9000 series graphics products. Users experiencing this issue are recommended to install AMD Software: Adrenalin Edition 26.7.1.
n°11485823
hisvin
Posté le 21-08-2026 à 09:05:45  profilanswer
 :whistle:
n°11485824
Umi
Posté le 21-08-2026 à 09:20:02  profilanswer
Qu'est-ce qui est drôle ?
n°11485826
alriad
ST Power, Makes it Possible
Posté le 21-08-2026 à 09:22:09  profilanswer
Ben la contradiction..
Cyberpunk 2077 demande mini 6 gb de VRAM et ils disent que les 9050 4 GB doivent avoir les graphiques en bas.. donc que ca fonctionne quand même avec 4 GB... alors que sur la meme phrase ils disent le contraire..
Edit : oula ca tire a balle, j'essayais d'aider..  :pt1cable:
C'est un forum restez cool les zumi..
Message édité par alriad le 21-08-2026 à 09:50:31
Que la force soit avec Moi... (Attention avec votre sabre laser, vous pourriez vous blesser..)
n°11485828
Umi
Posté le 21-08-2026 à 09:31:36  profilanswer
Il y a marqué Recommande, pas exige.
Et ce n'est pas à toi que la question s'adresse.
n°11485851
Pey'j McBa​con
Posté le 21-08-2026 à 11:37:15  profilanswer
Pauvre petit chou va.
n°11485860
Umi
Posté le 21-08-2026 à 12:00:52  profilanswer
Merci pour votre intervention pertinente M. McBacon.
n°11485869
Scrabble
Posté le 21-08-2026 à 12:51:35  profilanswer
La RX 9050 4Go n'est pas une carte graphique de jeu
n°11485871
havoc_28
Posté le 21-08-2026 à 12:58:07  profilanswer
Les cas de figures où cette carte est "justifiable" sont tout du moins limités ...
Un IGP suffit en général quand y a pas besoin de beaucoup de puissance graphique, à la limite si y a besoin d'augmenter le nombre de sortie d'affichages, mais pour ça y a des solutions moins onéreuses (coucou A380, qui offre en plus 4 sorties contre 3 sur la 9050 et 6 GO de vram :o).
En plus elle se contente même pas de l'alimentation fournit par le port PCI-E, faut obligatoirement un 6+2 pins.
Message édité par havoc_28 le 21-08-2026 à 13:00:10
n°11485874
Fouge
Posté le 21-08-2026 à 13:18:28  profilanswer
Si
n°11485879
Umi
Posté le 21-08-2026 à 13:46:57  profilanswer
Avec le 780M, le GPU intégré sur mon 7840HS, je fais ce score sur CP2077 v2.3:
https://i.imgur.com/CX3nwmuh.png
n°11488199
didizebest
Posté le 11-09-2026 à 18:22:23  profilanswer
j'ai un soucis avec ma config : le pilote de ma CG (RX 9700) plante au démarrage de windows.
Quand j'arrive sur le bureau (windows 11) j'ai l'écran qui devient noir puis se rallume, le fond d'écran qui n'apparait pas..etc et un rapport d'erreur d'Adrenalin.
Chose étrange, ça le fait à chaque fois au premier allumage, quand je redemarre le PC, ça marche nickel aprés.
J'ai essayé de désinstallé proprement les drivers et de réinstaller, j'ai desactivé l'ultra fast boot dans mon bios, rien n'y fait.
Quelqu'un saurait-il d'où vient le problème ? :D
n°11488202
MazFire
~ Keep Cool ~
Posté le 11-09-2026 à 18:46:36  profilanswer
Un bon coup de DDU et réinstalle propre ?
n°11488203
didizebest
Posté le 11-09-2026 à 19:01:42  profilanswer
Déjà essayé, le problème persiste !
n°11488247
scrumpz
Posté le 12-09-2026 à 08:02:53  profilanswer
Tente un dism sfc scannow.
Check la poussière dans l’ordi.
Tente un reset bios voir mise a jour.
Tente une version inférieur de drivers gpu.
Tente également de réinstaller les drivers chipset (cpu) avec réinstallation propre.
Si cela fonctionnait avant quelque chose à sûrement changé.
est-ce que Windows update est toujours par défaut sur l’installation des drivers ? Si oui il faut désactiver cette fonction.
-> A vendre matos Hardaware <-
n°11488256
It_Connexi​on
Posté le 12-09-2026 à 09:48:16  profilanswer
+1, première chose que je fais après l'installation de Windows
Galerie Photo Personnelle
n°11488257
didizebest
Posté le 12-09-2026 à 09:51:07  profilanswer
Merci pour ta réponse, j'avais déjà testé plusieurs fois le dsim sfc scannow, sans succés.
La poussière, j'ai regardé, pas de soucis.
Mon bios est à jour et j'ai pas changé la version depuis au moins 6 mois/1 an.
J'ai réinstallé les drivers chipset.
J'ai fait une désinstallation du driver avec DDU (again) en désactivant l'installation part défaut de windows update, puis réinstallation des drivers en "driver only".
Bilan : même problème.
J'arrête le PC, j'attends un peu, je le démarre. Arrivé sur le bureau, tout à l'air ok, je lance un jeu (Plague tale resonnance), le jeu freeze sur la première image (animation logo de l'éditeur). Retour bureau.
Je redemarre le PC, je relance le lance dès l'arrivée sur le bureau sans attendre : ça fonctionne normalement.
En fait, ce que je trouve étrange, c'est cette histoire de "après un redemarrage ça marche nickel" systématiquement. Comme si le GPU avait du mal à démarrer "à froid"
n°11488260
hisvin
Posté le 12-09-2026 à 10:18:20  profilanswer
Et au niveau alimentation, ça se présente comment?
n°11488261
bluehangel
Posté le 12-09-2026 à 10:24:04  profilanswer
check la liste des programmes qui démarrent au lancement,dans le gestionnaire de tâches
Message édité par bluehangel le 12-09-2026 à 10:24:55
Feed back
n°11488262
didizebest
Posté le 12-09-2026 à 10:30:12  profilanswer
J'ai une Corsair 750W, ce qui devrait être plus que suffisant pour ma config (Intel 12400 + RX 9700 (non XT)).
n°11488263
didizebest
Posté le 12-09-2026 à 10:33:38  profilanswer
voilà :
https://rehost.diberie.com/Picture/Get/f/543318
C'est volontairement minimaliste :D
Message édité par didizebest le 12-09-2026 à 10:34:32
n°11488282
scrumpz
Posté le 12-09-2026 à 12:48:16  profilanswer
voilà :
Honnêtement demande à chatgpt ou Claude code si tu as.
il va te faire checker des logs système et toutes les erreurs etc… tu lui ce que tu as déjà fait comme tu vas passer déjà les étapes redondante.
n°11488298
It_Connexi​on
Posté le 12-09-2026 à 13:48:00  profilanswer
Oui ça consomme rien ça, même pas besoin de câble sur la carte de mémoire :o :o :o
n°11488301
hisvin
Posté le 12-09-2026 à 13:56:45  profilanswer
AMD recommende minimum une 750 watts. Après il faut voir toute la config.
A titre perso, j'ai pris une 850 pour une carte plus ancienne (7900xt pulse).
n°11488303
It_Connexi​on
Posté le 12-09-2026 à 14:00:16  profilanswer
J'ai une 750w sur ma conf en 5700 et 9070xt, ça passe sans soucis oui.
La c'est la SL, sur la TUF ils recommandent une 850w de mémoire
n°11488306
minux
On Linux ...
Posté le 12-09-2026 à 14:06:31  profilanswer
Le pc de mon fils avait une 750W (Seasonic), mais avec un 5600x et une 6900XT le pc lui claquait dans les pâtes régulièrement en jeux (sûrement les pics de conso de la 6900XT), je lui ai collé une 850W, depuis plus de souci.
n°11488308
didizebest
Posté le 12-09-2026 à 14:11:49  profilanswer
Bah c'est raisonnable quoi haha, 300W pour la CG, 100W  pour le CPU, c'est "large" :o
ça tourne nickel en jeux sur les gros AAA, c'est pas un problème de stabilité en jeu, c'est vraiment un trucàlacon au premier démarrage du PC, une fois que je redémarrage je peux jouer des heures sur stalker 2 et compagnie sans le moindre soucis
Message édité par didizebest le 12-09-2026 à 14:15:32
n°11488343
It_Connexi​on
Posté le 12-09-2026 à 18:55:32  profilanswer
n°11488344
It_Connexi​on
Posté le 12-09-2026 à 18:56:31  profilanswer
Non je te chambrais car tu parlais de 9700, c'est très vieux comme GPU, contrairement à la 9070  :D
n°11488379
didizebest
Posté le 12-09-2026 à 22:49:32  profilanswer
C'était le top à l'époque, ATI Radeon  :sol:
n°11488382
MazFire
~ Keep Cool ~
Posté le 12-09-2026 à 23:12:15  profilanswer
La version Pro était une référence !
Suivie ensuite quelques mois plus tard par la 9800 Pro, tout aussi mythique en son temps :)
n°11488384
LePcFou
Delinquant textuel
Posté le 12-09-2026 à 23:24:33  profilanswer
C'est la seule fois ou ati a vendu plus de cartes qu'nvidia car ils n'avaient que des fx en face qui étaient un peu de la daube
Message édité par LePcFou le 12-09-2026 à 23:26:14
Je reste dans mon coin enfermé chez moi et je regarde la fin du monde tranquillement car j'y peux rien
n°11488385
MazFire
~ Keep Cool ~
Posté le 12-09-2026 à 23:27:20  profilanswer
En effet, certainement leur pire génération ces FX 5xxx !
nVidia s'était bien rattrapé sur la génération suivante (les 6600 GT ont eu un certain succès avec leur rapport prix/performances intéressant)
n°11488390
havoc_28
Posté le 12-09-2026 à 23:53:52  profilanswer
X800 ? :o.
https://www.guru3d.com/data/publish/196/8d47c8492f8054f8918cb0785051a7afe7ae92/add-in-board-gpu-market-share-2002-to-q3-2016.png
Que les 9700 aient grandement permis à ATI de prendre la tête niveau performance et de gagner en aura et part de marché,  oui, mais ce n'est qu'avec la génération suivante, qu'ATI a vendu plus de cartes.
Même si les Geforce 6000 étaient bien meilleurs que les FX, en terme de perf brutes les X800 étaient un poil devant (850XT PE) :o.
Message édité par havoc_28 le 13-09-2026 à 00:08:32
n°11488399
It_Connexi​on
Posté le 13-09-2026 à 04:11:33  profilanswer
Yes, j'avais une Asus X850XT AGP
n°11488409
LePcFou
Delinquant textuel
Posté le 13-09-2026 à 09:05:21  profilanswer
Il leur manquait un truc ça s'appelait le hdr de mémoire. que les nvidia 6K avaient.
Mais c'était des cartes puissantes.
Message édité par LePcFou le 13-09-2026 à 09:06:23
n°11488410
Scrabble
Posté le 13-09-2026 à 10:16:07  profilanswer
C'est trop vague, nvidia 6K, quand on cherche sur google ca renvoie a plein de modeles differents.
Sois plus precis
n°11488412
MazFire
~ Keep Cool ~
Posté le 13-09-2026 à 10:45:50  profilanswer
Non, c'était de souvenir les Shaders model 3.0 qui manquaient aux X8xx
Mais les 6x00 de chez nVidia étaient trop faibles pour l'exploiter correctement ^^
n°11488419
Fouge
Posté le 13-09-2026 à 12:15:00  profilanswer
Sois plus precis
6ème génération de GF ;) https://www.hardware.fr/articles/49 [...] rueux.html
Je me souviens encore de ma 6800 unlockée avec succès :love: https://www.techspot.com/news/17708 [...] -6800.html
ATI - Problème avec les CATALYST 3.5 +Question concernant ATI 9800 Pro avec HP80A : chaud brulant !!!!!
Probleme Hydravison et ATIAti Radeon 9600 Pro > Gigabyte HIS Saphire ou Club 3D ?
[Topic Unique] ASUS P4C800 / P4P800 (Intel i865/i875)les CG ATI 9xxx les + o/cables , quelle marque ?
Performance des differentes cartes ATI et Nvidia ??LEADTEK A 360 FX 5700 ou ATI 9600 PRO ?
Plus de sujets relatifs à : [Topic Unique] Radeon™ Software Adrenalin 2020 Edition ● CG & APU !
