2198 connectés
 Page :   1  2  3  4  5  ..  78  79  80  ..  1539  1540  1541  1542  1543  1544
[UBUNTU] 25.10 Questing Quokka'' - Topic dédié
n°730202
DDT
Few understand
Posté le 16-09-2005 à 02:51:59  profilanswer
/pool/main/g/gst-plugins0.8/gstreamer0.8-alsa_0.8.11-0ubuntu2_i386.deb
/pool/main/g/gst-plugins0.8/gstreamer0.8-audiofile_0.8.11-0ubuntu2_i386.deb
/pool/main/g/gst-plugins0.8/gstreamer0.8-cdparanoia_0.8.11-0ubuntu2_i386.deb
/pool/main/g/gst-plugins0.8/gstreamer0.8-dv_0.8.11-0ubuntu2_i386.deb
/pool/main/g/gst-plugins0.8/gstreamer0.8-dvd_0.8.11-0ubuntu2_i386.deb
/pool/main/g/gst-plugins0.8/gstreamer0.8-esd_0.8.11-0ubuntu2_i386.deb
/pool/main/g/gst-plugins0.8/gstreamer0.8-flac_0.8.11-0ubuntu2_i386.deb
/pool/main/g/gst-plugins0.8/gstreamer0.8-gnomevfs_0.8.11-0ubuntu2_i386.deb
/pool/main/g/gst-plugins0.8/gstreamer0.8-gsm_0.8.11-0ubuntu2_i386.deb
/pool/main/g/gst-plugins0.8/gstreamer0.8-hermes_0.8.11-0ubuntu2_i386.deb
/pool/main/g/gst-plugins0.8/gstreamer0.8-jpeg_0.8.11-0ubuntu2_i386.deb
/pool/main/g/gst-plugins0.8/gstreamer0.8-misc_0.8.11-0ubuntu2_i386.deb
/pool/main/g/gst-plugins0.8/gstreamer0.8-musepack_0.8.11-0ubuntu2_i386.deb
/pool/main/g/gst-plugins0.8/gstreamer0.8-oss_0.8.11-0ubuntu2_i386.deb
/pool/main/g/gst-plugins0.8/gstreamer0.8-plugin-apps_0.8.11-0ubuntu2_i386.deb
/pool/main/g/gst-plugins0.8/gstreamer0.8-sdl_0.8.11-0ubuntu2_i386.deb
/pool/main/g/gst-plugins0.8/gstreamer0.8-speex_0.8.11-0ubuntu2_i386.deb
/pool/main/g/gst-plugins0.8/gstreamer0.8-theora_0.8.11-0ubuntu2_i386.deb
/pool/main/g/gst-plugins0.8/gstreamer0.8-vorbis_0.8.11-0ubuntu2_i386.deb
/pool/main/g/gst-plugins0.8/gstreamer0.8-x_0.8.11-0ubuntu2_i386.deb
Ok il manque des plugins interessants, mais y en a quand même :o
(z'avez qu'à encoder en ogg/theora d'abord :D)
Message édité par DDT le 16-09-2005 à 02:52:08
n°730221
ory
Posté le 16-09-2005 à 08:47:37  profilanswer
Zzozo a écrit :
M'en suis aperçu  [:dao]
C'est bien l'idée du "tout sudo" pour l'utilisateur Lambda  [:dao]
Mais je sens que ça va vite me péter les burnes  [:itm]    :whistle:
bah non.
Tu veux lancer un prog en root ?
sudo programme
Tu veux un shell en root ?
sudo -s
Mettre un mot de passe root est désormais inutile
n°730222
ory
Posté le 16-09-2005 à 08:48:32  profilanswer
gee a écrit :
même si tu utilises sudo, je pense que c'est pas un mal d'avoir un autre compte admin, "just in case" ... donc le root direct aussi chez moi.
 :heink: sudo te permettra toujours de passer en root, le compte root n'a plus d'utilité en utilisation directe  :o
n°730223
ory
Posté le 16-09-2005 à 08:49:52  profilanswer
Zzozo a écrit :
Tsss ... mauvaise langue ... Totem est bien là  [:dao]
Bon ok, il peut pas lire grand chose, vu que un tas de codecs (qui a dit tous .. tsss  [:dao] ) sont pas installés   :whistle:
problèmes de droits, toussa..
Regarde du côté d'EasyUbuntu pour installer tous ces trucs proprio rapidement
n°730261
alien cons​piracy
hardtrance addict
Posté le 16-09-2005 à 11:12:54  profilanswer
Je comprends pas les gens qui n'arrive pas à se faire à sudo. :/
n°730263
JerryCrazy
Le plus crazy des crazy
Posté le 16-09-2005 à 11:18:02  profilanswer
Je m'y suis fait rapidement personnelement :D
n°730265
ory
Posté le 16-09-2005 à 11:19:59  profilanswer
Surtout qu'en plus sudo c'est bien plus pratique et souple, plus qu'un seul mot de passe à retenir (et éviter de mettre le même pour user/root  :sarcastic: ), permet un contrôle fin via sudoers, interdit aux débutants de se logguer en root via l'interface graphique (plus efficace que de mettre un fond d'écran rouge et un "attention !" ), et d'autres choses...
n°730268
BiBi Max
Posté le 16-09-2005 à 11:23:19  profilanswer
Tu arrives à faire marcher tes alias avec sudo ?
Ex : tu modifies un fichier de conf avec emacs, il te generes un fichier tilde. J'ai l'habitude de lancer un alias pour cleaner le rep mais avec sudo c'est mort.
Ou alors j'ai loupé un truc.
BiBi Max
n°730270
ory
Posté le 16-09-2005 à 11:25:45  profilanswer
soit tu configure emacs pour qu'il ne fasse plus de sauvegardes de ce type, soit tu ajoute sudo au début de ton alias
n°730273
BiBi Max
Posté le 16-09-2005 à 11:31:31  profilanswer
et si j'ai des alias spécifiques au root ;-)
Nan sérieux, sudo c'est pratique mais il arrive qu'il devienne plus dangereux et plus contraignant qu'une console en root.
(Genre sudo qui ne te redemande plus ton mot de passe dès lors que tu as executé une commande avec sudo + prefixage de sudo dans les alias)
sudo tres bien pour un ptit apt-get update ugrade mais des fois une vraie console est nécessaire.
BiBi Max
n°730274
ory
Posté le 16-09-2005 à 11:34:50  profilanswer
sudo -s  ;) et tu auras ton shell en root
n°730319
alien cons​piracy
hardtrance addict
Posté le 16-09-2005 à 12:43:20  profilanswer
sudo -H -s
max@castor-mobile:~$ sudo -s
root@castor-mobile:~# echo $HOME
/home/max
root@castor-mobile:~# exit
exit
max@castor-mobile:~$ sudo -H -s
root@castor-mobile:/home/max # echo $HOME
/root
root@castor-mobile:/home/max # exit
exit
Message édité par alien conspiracy le 16-09-2005 à 12:44:36
n°730320
Joseph Des​ire
Posté le 16-09-2005 à 12:44:02  profilanswer
il rajoute quoi le -H par rapport au -s ?
n°730321
alien cons​piracy
hardtrance addict
Posté le 16-09-2005 à 12:44:52  profilanswer
j'ai édité mon message
edit: et puis man sudo :o
Message édité par alien conspiracy le 16-09-2005 à 12:45:13
n°730323
Joseph Des​ire
Posté le 16-09-2005 à 12:47:31  profilanswer
ya un truc que je pige pas dans la logique de Ubuntu. Si avec sudo -H -s on a les droits root, à quoi sert la console SuperUtilisateur que l'on peut lancer comme ca en 1 click ? A part faire doublon.
n°730326
alien cons​piracy
hardtrance addict
Posté le 16-09-2005 à 12:49:39  profilanswer
Ca disparait dans Breezy.
n°730328
Joseph Des​ire
Posté le 16-09-2005 à 12:57:08  profilanswer
ah :) c'était la question existentielle hier, comme quoi.....
n°730330
belgique
Posté le 16-09-2005 à 12:58:14  profilanswer
Ca sert à te lancer une console sans devoir connaître la commande sudo tiens, c'est très pratique pour les débutants (et les autres aussi :D)
edit : pourquoi ça disparait :(
Message édité par belgique le 16-09-2005 à 12:58:39
n°730332
alien cons​piracy
hardtrance addict
Posté le 16-09-2005 à 13:01:03  profilanswer
Bien parcque si on va au bout de la logique, un débutant ne dois pas avoir besoin de la console, mais dans le cas où il doit en faire usage se sera plus que probablement en suivant un guide ou aider d'une personne qui elle connaitra la commande sudo -s. Enfin c'est comme ca que je le conçois dans mon esprit.
n°730343
dofor
:F
Posté le 16-09-2005 à 13:40:29  profilanswer
tiens j'ai fait un peu comme zzozo, j'ai mis une ubuntu sur un bout de partoche pour tester
mais comme lui, ma distrib préférée est et restera la gentoo :F
sudo c'est chiant pour les alias du .bashrc du root...
Enfin sinon la distrib est sympa en général
la gestion des modules est RELOU par contre (blacklist etc)
n°730344
alien cons​piracy
hardtrance addict
Posté le 16-09-2005 à 13:42:11  profilanswer
Je viens de donner la solution au dessus. Faut regarder dans les man de temps en temps.  :o
n°730348
dofor
:F
Posté le 16-09-2005 à 13:53:56  profilanswer
exact ça marche :jap:
C'est un peu plus long à taper que su, mais ça marche :D
Y'a des repositories avec la dernière version de qemu et kqemu?
Une des choses qui me manquent sur ubuntu, c'est la propreté dans l'install de softs non libres (genre q3 jusqu'à y'a pas longtemps, ut2004, qemu, cedega...)
J'aime pouvoir me reposer sur le système de paquets pour tout, et pas seulement pour les softs libres ^^
n°730349
JerryCrazy
Posté le 16-09-2005 à 13:55:51  profilanswer
Beagle va être integré a Ubuntu? :) ça a l'air sympa comme logiciel, mais, pour l'instant, en backport, j'ai pas pu le démarrer même en suivant l'aide du site officiel de Beagle [:joce]
n°730350
dofor
:F
Posté le 16-09-2005 à 13:57:32  profilanswer
il est dans breezy
n°730351
JerryCrazy
Posté le 16-09-2005 à 13:59:12  profilanswer
C'est vrai que les paquets pour les jeux proprio, ça serait bien, je me rappele sur Mandriva/Mandrake sur PLF avoir trouvé un paquetage pour Wolfenstein Enemy Territory
Je n'ai pas vraiment cherché sur Ubuntu mais, je n'ai rien vu pour l'instant
Message édité par JerryCrazy le 16-09-2005 à 14:00:26
n°730352
JerryCrazy
Posté le 16-09-2005 à 13:59:35  profilanswer
dofor a écrit :
il est dans breezy
Super alors :jap:
Je me demande bien ce qu'il va manquer a Ubuntu pour concurencer Windows Vista [:joce]
Message édité par JerryCrazy le 16-09-2005 à 13:59:52
n°730353
dofor
:F
Posté le 16-09-2005 à 14:01:45  profilanswer
oué pour les paquets de jeux proprio je vois pas :/
pareil pour d'autres softs, genre kqemu
je me rends compte de la réactivité de gentoo sur les sorties de softs, c'est assez impressionnant finalement
Et effectivement en tant que distrib facile d'accès je trouve ubuntu très réussie! :)
n°730357
JerryCrazy
Posté le 16-09-2005 à 14:12:33  profilanswer
J'ai pas compris, Mono, c'est un client ".NET" ? :sweat:
Pourquoi utiliser du .NET pour ça ? :sweat:
n°730358
multani
Dépressionnisé
Posté le 16-09-2005 à 14:18:27  profilanswer
C'est pas un client .Net, c'est une machine virtuelle .Net [:dawao]
Comme Java quoi [:petrus75]
n°730362
alien cons​piracy
hardtrance addict
Posté le 16-09-2005 à 14:26:38  profilanswer
une machine virtuelle et un framework. :D
n°730363
alien cons​piracy
hardtrance addict
Posté le 16-09-2005 à 14:27:24  profilanswer
L'interet c'est d'ensuite en faire un alias du style alias su = 'sudo -H -s' :D
n°730364
multani
Dépressionnisé
Posté le 16-09-2005 à 14:34:31  profilanswer
n°730386
gee
Bon ben hon
Posté le 16-09-2005 à 15:34:35  profilanswer
ok et le jour ou ton compte est flingue tu le fais comment le sudo -s ?
n°730393
DDT
Few understand
Posté le 16-09-2005 à 15:47:17  profilanswer
Tu démarres en runlevel 1 :o
Puis bon je vois pas trop comment ce genre de trucs peut arriver...
n°730394
ory
Posté le 16-09-2005 à 15:48:43  profilanswer
Ca t'arrive souvent de flinguer des comptes ? :D
n°730405
Zzozo
Modérateur
Un peu, passionément, à la fol
Posté le 16-09-2005 à 16:04:41  profilanswer
sudo/su ça change pas grand chose, si en face l'utilisateur est pas responsable et/ou ne comprend pas bien ce qu'il fait ...
un sudo rm (et tu peux mettre autant de protections que tu veux pour l'empêcher, si le mec est déterminé à faire une connerie, il la fera, tout seul ou avec l'aide d'un copain qui "s'y connait" ) raté ça aura le même résultat q'un rm raté lancé en root ...
C'est avant tout une question d'éducation, de prises de bonnes habitudes, de concentration, je pense, AMHA
Ca fait 10 ans que je me frotte à Linux (et plus concernant Unix), alors ok le sudo ca peut plaire, seulement, perso, j'ai pris certaines habitudes avant la généralisation de sudo, notamment j'ai "aliasé" toutes les commandes "dangereuses" (comme rm etc ...) afin de me créer un "filet", pour limiter les dégats, si un jour, malgré toute mon attention, je commettais une bêtise ...
De même, je ne travaille en root que pour les taches que j'estime indispensables, pour le reste, bah mon user habituel me suffit ... [:spamafote]
Message édité par Zzozo le 16-09-2005 à 16:12:26
« Ce qui ne vous tue pas vous rend plus fort » F. Nietzsche | « Vise_ la Lune. Si tu rates, au pire, t'es dans la merde » Un poète disparu dans le cercle
n°730409
Zzozo
Modérateur
Posté le 16-09-2005 à 16:09:25  profilanswer
Mais là t'es plus dans une utilisation pour Monsieur tout le monde ...  plus vraiment dans le cas de l'utilisation d'une machine perso ...
Le type qui sait faire tout ce que tu décris là, ben il est conscient des dégats que peut causer le fait de travailler avec trop de privilèges, et il aura mis en place d'autres sécurités, que le sudo ... parce qu'il en est capable ... [:spamafote]
C'est comme l'histoire du mot de passe unique ... le type qui sait faire tout ce que tu décris, il a des mots de passe différents (et des "vrais" mdp ... ) ... il s'occupe bien sa "machine", fais bien toutes les MAJ de sécurité, etc ...  bref, c'est pas un utilisateur "ordinaire", il connait tous les dangers d'une utilisation "je m'en foutiste"/ignorante ...
Message édité par Zzozo le 16-09-2005 à 16:13:06
n°730427
alien cons​piracy
hardtrance addict
Posté le 16-09-2005 à 16:23:56  profilanswer
sudo ne t'empêche pas d'aliaser toutes les commandes. Pour le reste tu as raison, c'est une question "d'éducation".
Message édité par alien conspiracy le 16-09-2005 à 16:24:32
n°730430
multani
Dépressionnisé
Posté le 16-09-2005 à 16:25:30  profilanswer
Oui, enfin bon, ça reste une question de préférences au final ... [:kiki]
n°730437
ory
Posté le 16-09-2005 à 16:28:53  profilanswer
 :??: j'ai justement pris l'exemple de Mandriva qui te fout un fond d'écran rouge quand tu te loggue en root au gestionnaire de connexions, c'est pas du monsieur tout le monde ça ?
n°730441
alien cons​piracy
hardtrance addict
Posté le 16-09-2005 à 16:32:58  profilanswer
L'idée c'est que Monsieur tout le monde n'aie jamais à utiliser la console; par facilitée il n'a qu'un seul mot de passe à retenir et l'utilisation est limitée au programme lancé par gksudo. Maintenant si quelqu'un ouvre une console et tappes "sudo rm un fichier" alors c'est déjà un utilisateur avancée (à mon sens) et qui par conséquent connaît le fonctionnement de sudo.
Message édité par alien conspiracy le 16-09-2005 à 16:33:35
encore un topic sur les températures[RESOLU] mount_data version 1919251317 is not supported
linux version disquetteLa version 10 de la mandrake dispo en magazine?
Topic Modifier les partitions sous Linux ("Partition Magic")Reiser 4 -- Version finale out - Faq : " Montre moi tes FS"
[Topic Unique] ROX-Filer[hébergement] serveur dédié
[Topic unique] Rox (-Filer) + X Files Explorer[Linux] Je recherche la version de Woody sur DVD
Plus de sujets relatifs à : [UBUNTU] 25.10 Questing Quokka'' - Topic dédié
