burn2 Pour ceux qui viendront après |
Code :
- X Window System Version 7.2.0
- Release Date: 22 January 2007
- X Protocol Version 11, Revision 0, Release 7.2
- Build Operating System: Linux Ubuntu
- Current Operating System: Linux Pc-fixe 2.6.20-13-generic #2 SMP Sun Mar 25 00:21:25 UTC 2007 i686
- Build Date: 04 April 2007
- Before reporting problems, check http://wiki.x.org
- to make sure that you have the latest version.
- Module Loader present
- Markers: (--) probed, (**) from config file, (==) default setting,
- (++) from command line, (!!) notice, (II) informational,
- (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
- (==) Log file: "/var/log/Xorg.0.log", Time: Thu Apr 5 13:42:22 2007
- (==) Using config file: "/etc/X11/xorg.conf"
- (==) ServerLayout "Default Layout"
- (**) |-->Screen "Default Screen" (0)
- (**) | |-->Monitor "Écran générique"
- (**) | |-->Device "NVIDIA Corporation NV40 [GeForce 6800]"
- (**) |-->Input Device "Generic Keyboard"
- (**) |-->Input Device "Configured Mouse"
- (WW) The directory "/usr/share/X11/fonts/cyrillic" does not exist.
- Entry deleted from font path.
- (WW) The directory "/usr/share/X11/fonts/CID" does not exist.
- (WW) `fonts.dir' not found (or not valid) in "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID".
- (Run 'mkfontdir' on "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID" ).
- (**) FontPath set to:
- /usr/share/X11/fonts/misc,
- /usr/share/X11/fonts/100dpi/:unscaled,
- /usr/share/X11/fonts/75dpi/:unscaled,
- /usr/share/X11/fonts/Type1,
- /usr/share/X11/fonts/100dpi,
- /usr/share/X11/fonts/75dpi,
- /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
- /usr/share/fonts/X11/misc,
- /usr/X11R6/lib/X11/fonts/misc,
- /usr/share/fonts/X11/cyrillic,
- /usr/share/fonts/X11/100dpi/:unscaled,
- /usr/share/fonts/X11/75dpi/:unscaled,
- /usr/share/fonts/X11/Type1,
- /usr/X11R6/lib/X11/fonts/Type1,
- /usr/share/fonts/X11/100dpi,
- /usr/share/fonts/X11/75dpi,
- (==) RgbPath set to "/etc/X11/rgb"
- (==) ModulePath set to "/usr/lib/xorg/modules"
- (II) Open ACPI successful (/var/run/acpid.socket)
- (II) Loader magic: 0x81c92e0
- (II) Module ABI versions:
- X.Org ANSI C Emulation: 0.3
- X.Org Video Driver: 1.1
- X.Org XInput driver : 0.7
- X.Org Server Extension : 0.3
- X.Org Font Renderer : 0.5
- (II) Loader running on linux
- (II) LoadModule: "pcidata"
- (II) Loading /usr/lib/xorg/modules//libpcidata.so
- (II) Module pcidata: vendor="X.Org Foundation"
- compiled for 7.2.0, module version = 1.0.0
- ABI class: X.Org Video Driver, version 1.1
- (++) using VT number 7
- (II) PCI: PCI scan (all values are in hex)
- (II) PCI: 00:00:0: chip 10de,01e0 card 0000,0000 rev c1 class 06,00,00 hdr 80
- (II) PCI: 00:00:1: chip 10de,01eb card 1695,1000 rev c1 class 05,00,00 hdr 80
- (II) PCI: 00:00:2: chip 10de,01ee card 1695,1000 rev c1 class 05,00,00 hdr 80
- (II) PCI: 00:00:3: chip 10de,01ed card 1695,1000 rev c1 class 05,00,00 hdr 80
- (II) PCI: 00:00:4: chip 10de,01ec card 1695,1000 rev c1 class 05,00,00 hdr 80
- (II) PCI: 00:00:5: chip 10de,01ef card 1695,1000 rev c1 class 05,00,00 hdr 80
- (II) PCI: 00:01:0: chip 10de,0060 card 1695,1000 rev a4 class 06,01,00 hdr 80
- (II) PCI: 00:01:1: chip 10de,0064 card 1695,1000 rev a2 class 0c,05,00 hdr 80
- (II) PCI: 00:02:0: chip 10de,0067 card 1695,1000 rev a4 class 0c,03,10 hdr 80
- (II) PCI: 00:02:1: chip 10de,0067 card 1695,1000 rev a4 class 0c,03,10 hdr 80
- (II) PCI: 00:02:2: chip 10de,0068 card 1695,1000 rev a4 class 0c,03,20 hdr 80
- (II) PCI: 00:06:0: chip 10de,006a card 1695,1008 rev a1 class 04,01,00 hdr 00
- (II) PCI: 00:08:0: chip 10de,006c card 0000,0000 rev a3 class 06,04,00 hdr 01
- (II) PCI: 00:09:0: chip 10de,0065 card 1695,1000 rev a2 class 01,01,8a hdr 00
- (II) PCI: 00:1e:0: chip 10de,01e8 card 0000,0000 rev c1 class 06,04,00 hdr 01
- (II) PCI: 01:09:0: chip 1814,0201 card 1462,6834 rev 01 class 02,80,00 hdr 00
- (II) PCI: 01:0b:0: chip 10ec,8139 card 1695,9001 rev 10 class 02,00,00 hdr 00
- (II) PCI: 01:0d:0: chip 1106,3044 card 1695,900e rev 80 class 0c,00,10 hdr 00
- (II) PCI: 02:00:0: chip 10de,0041 card 1043,817c rev a1 class 03,00,00 hdr 00
- (II) PCI: End of PCI scan
- (II) Host-to-PCI bridge:
- (II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
- (II) Bus 0 I/O range:
- [0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
- (II) Bus 0 non-prefetchable memory range:
- [0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
- (II) Bus 0 prefetchable memory range:
- (II) PCI-to-ISA bridge:
- (II) Bus -1: bridge is at (0:1:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
- (II) PCI-to-PCI bridge:
- (II) Bus 1: bridge is at (0:8:0), (0,1,1), BCTRL: 0x0002 (VGA_EN is cleared)
- (II) Bus 1 I/O range:
- [0] -1 0 0x00009000 - 0x0000afff (0x2000) IX[B]
- (II) Bus 1 non-prefetchable memory range:
- [0] -1 0 0xdb000000 - 0xdcffffff (0x2000000) MX[B]
- (II) Bus 1 prefetchable memory range:
- [0] -1 0 0x60000000 - 0x600fffff (0x100000) MX[B]
- (II) Bus 2: bridge is at (0:30:0), (0,2,2), BCTRL: 0x000a (VGA_EN is set)
- (II) Bus 2 non-prefetchable memory range:
- [0] -1 0 0xd8000000 - 0xdaffffff (0x3000000) MX[B]
- (II) Bus 2 prefetchable memory range:
- [0] -1 0 0xd0000000 - 0xd7ffffff (0x8000000) MX[B]
- (--) PCI:*(2:0:0) nVidia Corporation NV40 [GeForce 6800] rev 161, Mem @ 0xd8000000/24, 0xd0000000/27, 0xd9000000/24
- (II) Addressable bus resource ranges are
- [1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
- (II) OS-reported resource ranges:
- [0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
- [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
- [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
- [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
- [4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
- [5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
- (II) PCI Memory resource overlap reduced 0xc0000000 from 0xcfffffff to 0xbfffffff
- (II) Active PCI resource ranges:
- [0] -1 0 0xdc004000 - 0xdc0047ff (0x800) MX[B]
- [1] -1 0 0xdc002000 - 0xdc0020ff (0x100) MX[B]
- [2] -1 0 0xdc000000 - 0xdc001fff (0x2000) MX[B]
- [3] -1 0 0xdd000000 - 0xdd000fff (0x1000) MX[B]
- [4] -1 0 0xdd004000 - 0xdd0040ff (0x100) MX[B]
- [5] -1 0 0xdd003000 - 0xdd003fff (0x1000) MX[B]
- [6] -1 0 0xdd002000 - 0xdd002fff (0x1000) MX[B]
- [7] -1 0 0xc0000000 - 0xbfffffff (0x0) MX[B]O
- [8] -1 0 0xd9000000 - 0xd9ffffff (0x1000000) MX[B](B)
- [9] -1 0 0xd0000000 - 0xd7ffffff (0x8000000) MX[B](B)
- [10] -1 0 0xd8000000 - 0xd8ffffff (0x1000000) MX[B](B)
- [11] -1 0 0x0000a800 - 0x0000a87f (0x80) IX[B]
- [12] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]
- [13] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
- [14] -1 0 0x0000b400 - 0x0000b47f (0x80) IX[B]
- [15] -1 0 0x0000b000 - 0x0000b0ff (0x100) IX[B]
- [16] -1 0 0x0000c000 - 0x0000c01f (0x20) IX[B]
- (II) Active PCI resource ranges after removing overlaps:
- (II) OS-reported resource ranges after removing overlaps with PCI:
- (II) All system resource ranges:
- [4] -1 0 0xdc004000 - 0xdc0047ff (0x800) MX[B]
- [5] -1 0 0xdc002000 - 0xdc0020ff (0x100) MX[B]
- [6] -1 0 0xdc000000 - 0xdc001fff (0x2000) MX[B]
- [7] -1 0 0xdd000000 - 0xdd000fff (0x1000) MX[B]
- [8] -1 0 0xdd004000 - 0xdd0040ff (0x100) MX[B]
- [9] -1 0 0xdd003000 - 0xdd003fff (0x1000) MX[B]
- [10] -1 0 0xdd002000 - 0xdd002fff (0x1000) MX[B]
- [11] -1 0 0xc0000000 - 0xbfffffff (0x0) MX[B]O
- [12] -1 0 0xd9000000 - 0xd9ffffff (0x1000000) MX[B](B)
- [13] -1 0 0xd0000000 - 0xd7ffffff (0x8000000) MX[B](B)
- [14] -1 0 0xd8000000 - 0xd8ffffff (0x1000000) MX[B](B)
- [15] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
- [16] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
- [17] -1 0 0x0000a800 - 0x0000a87f (0x80) IX[B]
- [18] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]
- [19] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
- [20] -1 0 0x0000b400 - 0x0000b47f (0x80) IX[B]
- [21] -1 0 0x0000b000 - 0x0000b0ff (0x100) IX[B]
- [22] -1 0 0x0000c000 - 0x0000c01f (0x20) IX[B]
- (II) LoadModule: "i2c"
- (II) Loading /usr/lib/xorg/modules//libi2c.so
- (II) Module i2c: vendor="X.Org Foundation"
- compiled for 7.2.0, module version = 1.2.0
- (II) LoadModule: "ddc"
- (II) Loading /usr/lib/xorg/modules//libddc.so
- (II) Module ddc: vendor="X.Org Foundation"
- (II) LoadModule: "extmod"
- (II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
- (II) Module extmod: vendor="X.Org Foundation"
- Module class: X.Org Server Extension
- ABI class: X.Org Server Extension, version 0.3
- (II) Loading extension SHAPE
- (II) Loading extension MIT-SUNDRY-NONSTANDARD
- (II) Loading extension BIG-REQUESTS
- (II) Loading extension SYNC
- (II) Loading extension MIT-SCREEN-SAVER
- (II) Loading extension XC-MISC
- (II) Loading extension XFree86-VidModeExtension
- (II) Loading extension XFree86-Misc
- (II) Loading extension XFree86-DGA
- (II) Loading extension DPMS
- (II) Loading extension TOG-CUP
- (II) Loading extension Extended-Visual-Information
- (II) Loading extension XVideo
- (II) Loading extension XVideo-MotionCompensation
- (II) Loading extension X-Resource
- (II) LoadModule: "freetype"
- (II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
- (II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
- compiled for 7.2.0, module version = 2.1.0
- Module class: X.Org Font Renderer
- ABI class: X.Org Font Renderer, version 0.5
- (II) Loading font FreeType
- (II) LoadModule: "glx"
- (II) Loading /usr/lib/xorg/modules/extensions//libglx.so
- (II) Module glx: vendor="NVIDIA Corporation"
- compiled for 4.0.2, module version = 1.0.9755
- ABI class: X.Org Server Extension, version 0.1
- (II) Loading extension GLX
- (II) LoadModule: "int10"
- (II) Loading /usr/lib/xorg/modules//libint10.so
- (II) Module int10: vendor="X.Org Foundation"
- (II) LoadModule: "vbe"
- (II) Loading /usr/lib/xorg/modules//libvbe.so
- (II) Module vbe: vendor="X.Org Foundation"
- compiled for 7.2.0, module version = 1.1.0
- (II) LoadModule: "nvidia"
- (II) Loading /usr/lib/xorg/modules/drivers//nvidia_drv.so
- (II) Module nvidia: vendor="NVIDIA Corporation"
- Module class: X.Org Video Driver
- (II) LoadModule: "kbd"
- (II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
- (II) Module kbd: vendor="X.Org Foundation"
- Module class: X.Org XInput Driver
- ABI class: X.Org XInput driver, version 0.7
- (II) LoadModule: "mouse"
- (II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
- (II) Module mouse: vendor="X.Org Foundation"
- compiled for 7.2.0, module version = 1.1.1
- (II) NVIDIA dlloader X Driver 1.0-9755 Mon Feb 26 23:23:13 PST 2007
- (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
- (II) Primary Device is: PCI 02:00:0
- (--) Assigning device section with no busID to primary device
- (--) Chipset NVIDIA GPU found
- (II) Loading sub module "fb"
- (II) LoadModule: "fb"
- (II) Loading /usr/lib/xorg/modules//libfb.so
- (II) Module fb: vendor="X.Org Foundation"
- ABI class: X.Org ANSI C Emulation, version 0.3
- (II) Loading sub module "wfb"
- (II) LoadModule: "wfb"
- (II) Loading /usr/lib/xorg/modules//libwfb.so
- (II) Module wfb: vendor="NVIDIA Corporation"
- compiled for 7.1.99.2, module version = 1.0.0
- (II) Loading sub module "ramdac"
- (II) LoadModule: "ramdac"
- (II) Loading /usr/lib/xorg/modules//libramdac.so
- (II) Module ramdac: vendor="X.Org Foundation"
- compiled for 7.2.0, module version = 0.1.0
- (II) resource ranges after xf86ClaimFixedResources() call:
- (II) resource ranges after probing:
- [15] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
- [16] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
- [17] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
- [18] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
- [19] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
- [20] -1 0 0x0000a800 - 0x0000a87f (0x80) IX[B]
- [21] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]
- [22] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
- [23] -1 0 0x0000b400 - 0x0000b47f (0x80) IX[B]
- [24] -1 0 0x0000b000 - 0x0000b0ff (0x100) IX[B]
- [25] -1 0 0x0000c000 - 0x0000c01f (0x20) IX[B]
- [26] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
- [27] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
- (II) Setting vga for screen 0.
- (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
- (==) NVIDIA(0): RGB weight 888
- (==) NVIDIA(0): Default visual is TrueColor
- (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
- (**) NVIDIA(0): Enabling RENDER acceleration
- (II) NVIDIA(0): Support for GLX with the Damage and Composite X extensions is
- (II) NVIDIA(0): enabled.
- (II) NVIDIA(0): NVIDIA GPU GeForce 6800 at PCI:2:0:0 (GPU-0)
- (--) NVIDIA(0): Memory: 131072 kBytes
- (--) NVIDIA(0): VideoBIOS: 05.40.02.15.00
- (II) NVIDIA(0): Detected AGP rate: 8X
- (--) NVIDIA(0): Interlaced video modes are supported on this GPU
- (--) NVIDIA(0): Connected display device(s) on GeForce 6800 at PCI:2:0:0:
- (--) NVIDIA(0): LG 700S (CRT-1)
- (--) NVIDIA(0): LG 700S (CRT-1): 400.0 MHz maximum pixel clock
- (II) NVIDIA(0): Assigned Display Device: CRT-1
- (WW) NVIDIA(0): No valid modes for "1280x854"; removing.
- (WW) NVIDIA(0): No valid modes for "1200x800"; removing.
- (II) NVIDIA(0): Validated modes:
- (II) NVIDIA(0): "1280x1024"
- (II) NVIDIA(0): "1280x960"
- (II) NVIDIA(0): "1280x800"
- (II) NVIDIA(0): "1280x768"
- (II) NVIDIA(0): "1152x864"
- (II) NVIDIA(0): "1152x768"
- (II) NVIDIA(0): "1024x768"
- (II) NVIDIA(0): "800x600"
- (II) NVIDIA(0): "640x480"
- (II) NVIDIA(0): Virtual screen size determined to be 1280 x 1024
- (--) NVIDIA(0): DPI set to (98, 104); computed from "UseEdidDpi" X config
- (--) NVIDIA(0): option
- (--) Depth 24 pixmap format is 32 bpp
- (II) do I need RAC? No, I don't.
- (II) resource ranges after preInit:
- [0] 0 0 0xd9000000 - 0xd9ffffff (0x1000000) MX[B]
- [1] 0 0 0xd0000000 - 0xd7ffffff (0x8000000) MX[B]
- [2] 0 0 0xd8000000 - 0xd8ffffff (0x1000000) MX[B]
- [3] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
- [4] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
- [5] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
- [6] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
- [7] -1 0 0xdc004000 - 0xdc0047ff (0x800) MX[B]
- [8] -1 0 0xdc002000 - 0xdc0020ff (0x100) MX[B]
- [9] -1 0 0xdc000000 - 0xdc001fff (0x2000) MX[B]
- [10] -1 0 0xdd000000 - 0xdd000fff (0x1000) MX[B]
- [11] -1 0 0xdd004000 - 0xdd0040ff (0x100) MX[B]
- [12] -1 0 0xdd003000 - 0xdd003fff (0x1000) MX[B]
- [13] -1 0 0xdd002000 - 0xdd002fff (0x1000) MX[B]
- [14] -1 0 0xc0000000 - 0xbfffffff (0x0) MX[B]O
- [15] -1 0 0xd9000000 - 0xd9ffffff (0x1000000) MX[B](B)
- [16] -1 0 0xd0000000 - 0xd7ffffff (0x8000000) MX[B](B)
- [17] -1 0 0xd8000000 - 0xd8ffffff (0x1000000) MX[B](B)
- [18] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
- [19] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
- [20] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
- [21] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
- [22] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
- [23] -1 0 0x0000a800 - 0x0000a87f (0x80) IX[B]
- [24] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]
- [25] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
- [26] -1 0 0x0000b400 - 0x0000b47f (0x80) IX[B]
- [27] -1 0 0x0000b000 - 0x0000b0ff (0x100) IX[B]
- [28] -1 0 0x0000c000 - 0x0000c01f (0x20) IX[B]
- [29] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
- [30] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
- (II) NVIDIA(0): Setting mode "1280x1024"
- (II) Loading extension NV-GLX
- (II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
- (II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
- (==) NVIDIA(0): Backing store disabled
- (==) NVIDIA(0): Silken mouse enabled
- (**) Option "dpms"
- (**) NVIDIA(0): DPMS enabled
- (II) Loading extension NV-CONTROL
- (==) RandR enabled
- (II) Initializing built-in extension MIT-SHM
- (II) Initializing built-in extension XInputExtension
- (II) Initializing built-in extension XTEST
- (II) Initializing built-in extension XKEYBOARD
- (II) Initializing built-in extension XC-APPGROUP
- (II) Initializing built-in extension XAccessControlExtension
- (II) Initializing built-in extension SECURITY
- (II) Initializing built-in extension XINERAMA
- (II) Initializing built-in extension XFIXES
- (II) Initializing built-in extension XFree86-Bigfont
- (II) Initializing built-in extension RENDER
- (II) Initializing built-in extension RANDR
- (II) Initializing built-in extension COMPOSITE
- (II) Initializing built-in extension DAMAGE
- (II) Initializing built-in extension XEVIE
- (II) Initializing extension GLX
- (**) Option "CoreKeyboard"
- (**) Generic Keyboard: Core Keyboard
- (**) Option "Protocol" "standard"
- (**) Generic Keyboard: Protocol: standard
- (**) Option "AutoRepeat" "500 30"
- (**) Option "XkbRules" "xorg"
- (**) Generic Keyboard: XkbRules: "xorg"
- (**) Option "XkbModel" "pc105"
- (**) Generic Keyboard: XkbModel: "pc105"
- (**) Option "XkbLayout" "fr"
- (**) Generic Keyboard: XkbLayout: "fr"
- (**) Option "XkbVariant" "latin9"
- (**) Generic Keyboard: XkbVariant: "latin9"
- (**) Option "CustomKeycodes" "off"
- (**) Generic Keyboard: CustomKeycodes disabled
- (**) Option "Protocol" "ImPS/2"
- (**) Configured Mouse: Device: "/dev/input/mice"
- (**) Configured Mouse: Protocol: "ImPS/2"
- (**) Option "CorePointer"
- (**) Configured Mouse: Core Pointer
- (**) Option "Device" "/dev/input/mice"
- (**) Option "Emulate3Buttons" "true"
- (**) Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50
- (**) Option "ZAxisMapping" "4 5"
- (**) Configured Mouse: ZAxisMapping: buttons 4 and 5
- (**) Configured Mouse: Buttons: 9
- (II) XINPUT: Adding extended input device "Configured Mouse" (type: MOUSE)
- (II) XINPUT: Adding extended input device "Generic Keyboard" (type: KEYBOARD)
- (II) Configured Mouse: ps2EnableDataReporting: succeeded
- Could not init font path element /usr/X11R6/lib/X11/fonts/misc, removing from list!
- Could not init font path element /usr/share/fonts/X11/cyrillic, removing from list!
- Could not init font path element /usr/X11R6/lib/X11/fonts/Type1, removing from list!
- (II) NVIDIA(0): Setting mode "1024x768_75"
- (II) NVIDIA(0): Setting mode "CRT-1:1024x768_85@1024x768+0+0"
- (WW) NVIDIA(0): Error while parsing panning domain in mode description
- (WW) NVIDIA(0): "1280x800@60@1280x800+0+0"
