9236 connectés
 Page :   1  2  3  4  5  ..  34  35  36  ..  53  54  55  56  57  58
OpenSUSE Leap 15.0 out \o/
n°1085980
burn2
Pour ceux qui viendront après
Posté le 30-10-2008 à 11:38:10  profilanswer
Bon voilà le résultat de l'état de mon dd pc portable:
Code :
  1. === START OF INFORMATION SECTION ===
  2. Model Family:     Fujitsu MHT series
  3. Device Model:     FUJITSU MHT2080AT PL
  4. Serial Number:   *****************
  5. Firmware Version: 0022
  6. User Capacity:    80 026 361 856 bytes
  7. Device is:        In smartctl database [for details use: -P show]
  8. ATA Version is:   6
  9. ATA Standard is:  ATA/ATAPI-6 T13 1410D revision 3a
  10. Local Time is:    Thu Oct 30 11:36:46 2008 CET
  11. SMART support is: Available - device has SMART capability.
  12. SMART support is: Enabled
  13. === START OF READ SMART DATA SECTION ===
  14. SMART overall-health self-assessment test result: PASSED
  15. General SMART Values:
  16. Offline data collection status:  (0x00) Offline data collection activity
  17.     was never started.
  18.     Auto Offline Data Collection: Disabled.
  19. Self-test execution status:      (   0) The previous self-test routine completed
  20.     without error or no self-test has ever
  21.     been run.
  22. Total time to complete Offline
  23. data collection:    ( 587) seconds.
  24. Offline data collection
  25. capabilities:     (0x7b) SMART execute Offline immediate.
  26.     Auto Offline data collection on/off support.
  27.     Suspend Offline collection upon new
  28.     command.
  29.     Offline surface scan supported.
  30.     Self-test supported.
  31.     Conveyance Self-test supported.
  32.     Selective Self-test supported.
  33. SMART capabilities:            (0x0003) Saves SMART data before entering
  34.     power-saving mode.
  35.     Supports SMART auto save timer.
  36. Error logging capability:        (0x01) Error logging supported.
  37.     No General Purpose Logging support.
  38. Short self-test routine
  39. recommended polling time:   (   2) minutes.
  40. Extended self-test routine
  41. recommended polling time:   (  80) minutes.
  42. Conveyance self-test routine
  43. recommended polling time:   (   2) minutes.
  44. SMART Attributes Data Structure revision number: 16
  45. Vendor Specific SMART Attributes with Thresholds:
  46. ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  47.   1 Raw_Read_Error_Rate     0x000f   100   100   046    Pre-fail  Always       -       137478
  48.   2 Throughput_Performance  0x0005   100   100   030    Pre-fail  Offline      -       31064064
  49.   3 Spin_Up_Time            0x0003   100   100   025    Pre-fail  Always       -       1
  50.   4 Start_Stop_Count        0x0032   099   099   000    Old_age   Always       -       2268
  51.   5 Reallocated_Sector_Ct   0x0033   100   100   024    Pre-fail  Always       -       8589934592000
  52.   7 Seek_Error_Rate         0x000f   100   100   047    Pre-fail  Always       -       515
  53.   8 Seek_Time_Performance   0x0005   100   100   019    Pre-fail  Offline      -       0
  54.   9 Power_On_Seconds        0x0032   088   088   000    Old_age   Always       -       6100h+22m+43s
  55. 10 Spin_Retry_Count        0x0013   100   100   020    Pre-fail  Always       -       0
  56. 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       2248
  57. 192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       132
  58. 193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       6040
  59. 194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       34 (Lifetime Min/Max 9/50)
  60. 195 Hardware_ECC_Recovered  0x001a   100   100   000    Old_age   Always       -       1404
  61. 196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       281673728
  62. 197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
  63. 198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
  64. 199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
  65. 200 Multi_Zone_Error_Rate   0x000f   100   100   060    Pre-fail  Always       -       23546
  66. 203 Run_Out_Cancel          0x0002   099   098   000    Old_age   Always       -       425928093250
  67. SMART Error Log Version: 1
  68. No Errors Logged
  69. SMART Self-test log structure revision number 1
  70. Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
  71. # 1  Short offline       Completed without error       00%         1         -
  72. SMART Selective self-test log data structure revision number 1
  73. SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
  74.     1        0        0  Not_testing
  75.     2        0        0  Not_testing
  76.     3        0        0  Not_testing
  77.     4        0        0  Not_testing
  78.     5        0        0  Not_testing
  79. Selective self-test flags (0x0):
  80.   After scanning selected spans, do NOT read-scan remainder of disk.
  81. If Selective self-test is pending on power-up, resume after 0 minute delay.
Et le serveur:
Code :
  2. Model Family:     Seagate Barracuda 7200.10 family
  3. Device Model:     ST3320620A
  5. Firmware Version: 3.AAE
  6. User Capacity:    320 072 933 376 bytes
  8. ATA Version is:   7
  9. ATA Standard is:  Exact ATA specification draft version not indicated
  10. Local Time is:    Thu Oct 30 11:40:01 2008 CET
  16. Offline data collection status:  (0x82) Offline data collection activity
  17.     was completed without error.
  18.     Auto Offline Data Collection: Enabled.
  21.     been run.
  23. data collection:    ( 430) seconds.
  25. capabilities:     (0x5b) SMART execute Offline immediate.
  28.     command.
  31.     No Conveyance Self-test supported.
  37.     General Purpose Logging supported.
  39. recommended polling time:   (   1) minutes.
  41. recommended polling time:   ( 115) minutes.
  42. SMART Attributes Data Structure revision number: 10
  43. Vendor Specific SMART Attributes with Thresholds:
  44. ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  45.   1 Raw_Read_Error_Rate     0x000f   118   096   006    Pre-fail  Always       -       189829044
  46.   3 Spin_Up_Time            0x0003   096   095   000    Pre-fail  Always       -       0
  47.   4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       166
  48.   5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  49.   7 Seek_Error_Rate         0x000f   072   060   030    Pre-fail  Always       -       20042384
  50.   9 Power_On_Hours          0x0032   099   099   000    Old_age   Always       -       902
  51. 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
  52. 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       186
  53. 187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
  54. 189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
  55. 190 Airflow_Temperature_Cel 0x0022   070   053   045    Old_age   Always       -       30 (Lifetime Min/Max 22/30)
  56. 194 Temperature_Celsius     0x0022   030   047   000    Old_age   Always       -       30 (0 17 0 0)
  57. 195 Hardware_ECC_Recovered  0x001a   079   061   000    Old_age   Always       -       94700643
  58. 197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
  59. 198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
  60. 199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
  61. 200 Multi_Zone_Error_Rate   0x0000   100   253   000    Old_age   Offline      -       0
  62. 202 TA_Increase_Count       0x0032   100   253   000    Old_age   Always       -       0
  63. SMART Error Log Version: 1
  64. No Errors Logged
  65. SMART Self-test log structure revision number 1
  66. SMART Selective self-test log data structure revision number 1
  67. SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
  68.     1        0        0  Not_testing
  69.     2        0        0  Not_testing
  70.     3        0        0  Not_testing
  71.     4        0        0  Not_testing
  72.     5        0        0  Not_testing
  73. Selective self-test flags (0x0):
  74.   After scanning selected spans, do NOT read-scan remainder of disk.
  75. If Selective self-test is pending on power-up, resume after 0 minute delay.
Les lignes sur le serveur:
M'inquiète :/ J'ai l'impression que malgrés l'age, le dd est en train de lacher. :/ faudrait que je demande de l'aide pour l'analyse de ça savoir si je peux y faire confiance ou pas. Car il a à peine 1 ou 2ans, et que le nombre d'erreur est bien plus grand que sur mon dd de pc portable qui a plus de 3ans. :/  (4 je crois)
Message édité par burn2 le 30-10-2008 à 11:48:35
n°1085985
Changaco
Posté le 30-10-2008 à 11:45:55  profilanswer
veaux a écrit :
bien sur sours kde tout roule mais j;aime pas et le 4 es pas stable...
KDE 4.1 est tout à fait stable.
Liberapay | Mastodon | GitHub
n°1085986
wedgeant
Da penguin inside
Posté le 30-10-2008 à 11:47:47  profilanswer
pas vraiment non :spamafote:
j'ai eu des soucis avec les plasmoids, et surtout à l'ouverture de la session, le loader "freeze" sur le 1er icone, jusqu'au chargement complet de la session :o
Wedge#2487 @HS -#- PW: +∞ -#- Khaz-Modan/Boltiz @WoW
n°1085989
burn2
Posté le 30-10-2008 à 11:55:51  profilanswer
 1 Raw_Read_Error_Rate     0x000f   118   096   006    Pre-fail  Always       -       189829044 (189829044)
195 Hardware_ECC_Recovered  0x001a   079   061   000    Old_age   Always       -       94700662 (94700643)
Pour voir l'évolution.
ça m'inquiètes un peu :/ Je vais demander de l'aide pour être sur parce que là :/
Message édité par burn2 le 30-10-2008 à 11:57:55
n°1086097
Changaco
Posté le 30-10-2008 à 15:09:56  profilanswer
Bah ça c'est pas instable c'est juste buggé ...
Message édité par Changaco le 30-10-2008 à 15:10:06
n°1086098
wedgeant
Da penguin inside
Posté le 30-10-2008 à 15:10:58  profilanswer
ah, et quelle est la différence alors ? [:petrus dei]
n°1086099
Changaco
Posté le 30-10-2008 à 15:13:33  profilanswer
KDE 4.0 c'était instable (ie ça plantait tout le temps). KDE 4.1 est encore un peu buggé mais il plante pas tout le temps et quand il plante en général c'est Plasma et il est relancé immédiatement.
n°1086102
Woka
Posté le 30-10-2008 à 15:16:04  profilanswer
Instable, c'est une couille qui peut arriver à tout moment (ça redémarre, un freeze, ou bien un écran bleu (pour windows), etc...).
Buggé, c'est un truc qui est génant en soi mais qui va pas défoncer l'heure de travail que tu viens de passer à taper un texte sous openoffice..
Je crois que c'est ça la différence :)
n°1093500
burn2
Posté le 28-11-2008 à 11:16:06  profilanswer
Sortie de la RC1 de la V11.1.
ça avance. :)
n°1093519
fhr
Posté le 28-11-2008 à 12:29:58  profilanswer
download du live CD avec KDE 4.2 en cours :)
n°1093971
jaymzwise
Posté le 30-11-2008 à 12:16:33  profilanswer
J'ai un petit problème depuis hier avec ma Suse 11.0.
L'updater ne fonctionne plus correctement.
Il me dit que j'ai 4 correctifs à installer, je lance l'installation et paf, il me redit que j'ai 4 correctifs (les mêmes) à installer...
Comment faire pour lui remettre les idées en place ?
EDIT : C'est bon, un zypper update m'a donné la réponse, problème de conflit entre 2 paquets.
C'est réglé ;)
Message édité par jaymzwise le 30-11-2008 à 12:21:13
n°1093982
the_big_po​ulet
Flying chicken
Posté le 30-11-2008 à 13:27:12  profilanswer
bon je plante mon petit drapal envie de tester un peu autre chose que ma kubuntu que je traine depuis 3 ans :o
n°1093999
burn2
Posté le 30-11-2008 à 14:34:15  profilanswer
jaymzwise a écrit :
C'est réglé ;)
Ah. :)
N'hésites pas. Essaye peut-être plus la 11 tout cours qu'est plus finalisé que la RC? mais bon à toi de voir.
Message édité par burn2 le 30-11-2008 à 14:34:47
n°1094002
the_big_po​ulet
Flying chicken
Posté le 30-11-2008 à 14:45:39  profilanswer
j'ai prit la 11 tout court :jap: mais je me laisserai surement tenter par un ptit test de la RC pas longtemps après l'installation, je me connais  :whistle:
edit: apparemment le truc qui va le plus me manquer c'est aptitude, y a une alternative il semblerait avec smart. vous utilisez quoi comme gestionnaire de paquets :??:
Message édité par the_big_poulet le 30-11-2008 à 14:48:02
n°1094010
burn2
Posté le 30-11-2008 à 15:23:00  profilanswer
Le gestionnaire de base. A savoir yast + zypper...
n°1094038
Batman-Fr
powered by caféine
Posté le 30-11-2008 à 18:03:28  profilanswer
salut à vous
j'etais passé dans ce topic il y a quelques temps car je me montais un serveur de fichiers maison en RAID 1. Apres avoir essuyé quelques difficultés (je ne connais que windows) notamment au niveau de la gestion des erreurs de disque dur de mon md (j'avais posté à ce sujet dans ce topic on m'avais alors renvoyé vers mdadm), des difficultés à parametrer samba et une impossibilité de me connecter au serveur via vnc, je suis finalement repassé à ubuntu et tout fonctionne parfaitement...
je ne suis pas en train de dire que suse caymal :o, je dis que j'ai finalement trouvé mon compte avec ubuntu alors que suse est la seule distri à ma connaissance à permetre lacreation d'un raid avec une GUI, ce qui m'avait fait basculé sur suse 11 apres avoir testé ubuntu, kubuntu, fedora et autres distris grand public...
voila, bonne continuation à vous :hello:
Tout ou rien mais rien que tout ! feed-back : http://forum.hardware.fr/forum2.ph [...] ost=121391
n°1094041
burn2
Posté le 30-11-2008 à 18:05:35  profilanswer
Pour la connexion VNC bizarre, je m'en sers parfaitement, en passant par un tunnel SSH....
Pour samba, je ne m'en suis jamais servi...
Enfin le principal c'est que tu es trouvé ta solution qui te convienne. :)
n°1094052
the_big_po​ulet
Flying chicken
Posté le 30-11-2008 à 19:24:40  profilanswer
bon install terminée, config à peu près finie pour le moment je suis mitigé mais je suis convaincu qu'il faut que je trouve mes marques :)
en vrac les petits trucs qu'il me manque:
- sudo... depuis que je suis sous linux j'ai jamais du me mettre en root du coup c'est bizarre de changer de user en permanence
- zypper est parfait pour les maj par contre j'ai pas encore trouvé s'il y avait moyen d'avoir l'auto completion pour les paquets installables :??:
parce devoir passer par yast => mdp => onglet logiciels => se retrouver devant 8 choix pour trouver "installer" => attendre l'update => taper sa recherche "truc" => attendre le résultat => cocher "trucmuche" => accepter => non je veux rien installer d'autre...
je préférais:
konsole => sudo aptitude install truc [tab] =>"sudo aptitude install trucmuche" => enter => mdp  => enter
Bon maintenant je compte sur vous pour me dire que j'ai raté un truc :o
- kde 4.1.3  :cry: je vais surement pas tarder à passer en RC  faut mettre quoi dans les dépots?  :whistle:
- un ptit détail à la noix: j'ai remis FF en browser/defaut mais si je clique dans kmail sur un lien il m'ouvre une nouvelle instance de FF :/
- la communauté qui a toute première à l'air super, mais bieeeeen moins importante que la communauté ubuntu => google est plus difficile à dompter
un truc que j'ai trouvé super par contre: j'ai galéré avec le livecd pour faire fonctionner mon stick usb wifi basé sur du zd1211rw mais qui ne fonctionne pas avec le driver du kernel => désactiver le module ensuite passer par ndiswrapper et charger le driver windows.
J'ai du m'y reprendre en plusieurs coup sur le livecd j'ai pas compris pourquoi, finalement ça fonctionne du coup je me dis ok banzai j'install et lors du reboot pendant la config post install il détecte automatiquement le module ndiswrapper fait avec le live cd et me demande si je veux l'activer du coup j'ai rien du refaire  :sol:
n°1094054
thana54
made in concept
Posté le 30-11-2008 à 19:38:26  profilanswer
Yast est un peu dur à utiliser. C'est vrai que c'est dur quand on a connu apt-get/aptitude.
note: ne pas faire "apti" [tab] lorsque l'on tape un message :o
n°1094056
mozaia
Posté le 30-11-2008 à 20:04:12  profilanswer
@The_big_poulet
Dans le désordre:
i) la communauté d'ubuntu est la plus grosse. (point final, il n'y a rien à rajouter :), c'est un axiome)
ii) un truc pour tes mises à jour (général). Une fois dans YAST, mise à jour et installation de logiciels, cliques sur /paquet/tous les paquets/mise à jour si une version est disponible. Ca va tout te mettre à jour... S'il te manque un dépôt ou quoi que ce soit, toujours dans la même fenêtre, tu cliques sur /dépôt/gestionnaire de dépôts. Tu peux faire "zypper update" aussi. J'utilise yast, ça me convient. Mais zypper vaut certainement le détour (il faut que je m'y mette). Zypper est bien quand il y a un conflit entre paquets, ça te dit où...
iii)Dans le gestionnaire de dépôts si tu cliques sur /ajouter/, les communautaires te permettent d'installer les dépôts les plus important. En particulier Packman (fais-le-> multimédia inside).
iv)Si tu cherches un paquet dont tu ne connais pas le dépôt: http://packages.opensuse-community.org/ et ensuite tu installes le dépot etc...
v) un lien utile: http://en.opensuse.org/Additional_ [...] positories
vi)une fois installé, tu ne changes pas tout le temps de user... au pire tu mets le mot de passe root pour le système. mauvaise langue. (héhé)
vii)tu as raison, il te faudra quelques jours avant de prendre tes marques, normal.
Message édité par mozaia le 30-11-2008 à 20:33:38
Dimensions Moebius Sésamath
n°1094070
the_big_po​ulet
Flying chicken
Posté le 30-11-2008 à 21:21:40  profilanswer
pour la maj comme je l'ai indiqué c'est super simple je n'ai pas de soucis avec ça, c'est plutot pour l'installation de paquets. Yast est très bien fait, mais j'ai pris l'habitude de ne plus utiliser d'interface graphique pour ce genre d'opération de routine et donc faudra que je m'habitue aux mécanismes de zypper (passer par une recherche avant par exemple)
merci pour tes liens, pour pacman il a déjà été ajouté qd amarok a voulu lire un mp3  :sol:
n°1094080
veaux
Posté le 30-11-2008 à 22:29:29  profilanswer
oui pour la recherche de paquet je faisais sudo zypper se nomdepaquet  et a partir de la je choisisais celui que je voulais.
La recherche dans yast2 est pas super.
Boinc: [AF>Linux] Veaux | http://www.boincstats.com/signature/user_1097016.gif
n°1094082
the_big_po​ulet
Flying chicken
Posté le 30-11-2008 à 23:24:33  profilanswer
de cette manière ça devient beaucoup plus intéressant en effet :jap:
n°1094174
the_big_po​ulet
Flying chicken
Posté le 01-12-2008 à 11:45:04  profilanswer
premier petit foirage (sous virtualbox heureusement)  :whistle:
j'ai voulu évidemment tester la rc1, du coup réflexe d'ubuntiste je vais modifier les dépots avec les adresses de dépots de la rc1
je cherche la commande magique pour une maj de ce type
je tombe sur 'zypper dup'
je lance et je me dis qu'il a pas l'air de faire beaucoup de maj... soit, il demande un reboot et après le reboot la session démarre pas :o
même pas moyen de se connecter en console.
Du coup je fais pas dans la dentelle, j'ai finalement lu que j'aurais plutot du passer par le DVD pour la maj du coup je l'ai téléchargé et maintenant j'ai lancé une réparation on va voir ce que ça donne :)
Mais sinon pour les versions de test y a pas de dépots pendant les beta :??:
n°1094175
burn2
Posté le 01-12-2008 à 11:46:32  profilanswer
Non il n'y a pas de dépôt en général pendant les beta. ça se passe par dvd toutes les majs. ;)
Le dépôt n'arrive qu'en fin de RC voir lors de la validation en version gold ou finale.
Message édité par burn2 le 01-12-2008 à 11:46:58
n°1094177
the_big_po​ulet
Flying chicken
Posté le 01-12-2008 à 11:50:14  profilanswer
bin là ils sont là et vaut mieux pas s'en servir surtout si on est aussi foireux que moi  :D
mais par contre dans le dvd j'ai pas de maj dans le menu :??:
*15 secondes + tard*
et donc il suffit de lancer l'install et il proposera de mettre à jour le système :o
n°1094178
burn2
Posté le 01-12-2008 à 11:51:12  profilanswer
Voilà c'est ça. ;)
n°1094181
the_big_po​ulet
Flying chicken
Posté le 01-12-2008 à 11:52:52  profilanswer
mais c'est fou ça... ça veut dire que si t'es sur une beta, a chaque fois que t'as besoin de maj ajoutée entre temps tu dois te retélécharger tout le DVD?  :heink:
c'est voulu ça? y a une raison?
n°1094184
burn2
Posté le 01-12-2008 à 11:54:45  profilanswer
La beta c'est que pour les tests, c'est pour ça :o
Donc oui faut retélécharger, mais en général tu testes avec la version du cd gnome mais pas le dvd...
Je pense que c'est pour pas saturer les serveurs, tout est mis en place niveau update qu'a la fin.
C'est pour ça qu'a la sortie, les serveur ne sont jamais dead comme chez ubuntu... ça plus aussi le fait que pas mal de monde télécharge en torrent.
n°1094185
the_big_po​ulet
Flying chicken
Posté le 01-12-2008 à 11:57:43  profilanswer
ouai la beta c'est pour les tests mais tu testes surement pas aussi bien en live cd ou dans une machine virtuelle que sur ton système que tu utilises tout les jours :o
sinon j'ai jamais eu de serveur dead avec ubuntu... vu que je migrais systématiquement à la sortie de la RC :D
n°1094188
burn2
Posté le 01-12-2008 à 12:01:27  profilanswer
C'est pas une version live, t'as la version gnome cd non live. ;)
n°1094199
mikala
Souviens toi du 5 Novembre...
Posté le 01-12-2008 à 12:51:58  profilanswer
libre a toi d'installer sudo :)
Intermittent du GNU
n°1094205
mikala
Posté le 01-12-2008 à 13:00:40  profilanswer
tu as des dépots pour factory (le nom de la version de développement):
http://download.opensuse.org/factory/repo/
Intermittent du GNU
n°1094208
the_big_po​ulet
Flying chicken
Posté le 01-12-2008 à 13:09:42  profilanswer
en fait il est installé par défaut :jap:
juste qu'on a pas accès à toutes les commandes avec un user normal même en sudo, faudrait que je check ça pour avoir accès à toutes les commandes
exemple zypper est utilisable avec sudo par contre ifconfig pas
(devoir passer root pour faire un ifconfig c'est un poil exag :D)
mais je me doute que c'est configurable mais vu que c'est qqch que je n'ai jamais du faire va falloir que je cherche un peu :)
n°1094215
mikala
Posté le 01-12-2008 à 13:25:20  profilanswer
je pense que tu dois probablement avoir également un problème de PATH.
Ifconfig étant normalement dans /sbin/ifconfig
Intermittent du GNU
n°1094217
the_big_po​ulet
Flying chicken
Posté le 01-12-2008 à 13:30:35  profilanswer
vi c'est ce qu'il me répond
mais je suis con, évidemment que ça doit bêtement être ça vu que j'ai du récupérer un fichier config qui vient de kubuntu mais qui ne correspond pas sous opensuse...
c'est mon premier changement de distrib faut être indulgent  :whistle:
n°1094272
the_big_po​ulet
Flying chicken
Posté le 01-12-2008 à 16:33:48  profilanswer
hop encore moi!
suites à mes tests, je me rends compte qu'on doit gérer pas mal de dépots
update /oss / non-oss / kde4-core / kde4-community /kde4-xx ...
du coup je me demandais si la liste de dépots est stockée dans un fichier lisible avec un éditeur (on dirait pas mais je préfère demander)
n°1094279
mozaia
Posté le 01-12-2008 à 17:04:47  profilanswer
Ca doit être par là : /etc/zypp
n°1094308
the_big_po​ulet
Flying chicken
Posté le 01-12-2008 à 19:48:41  profilanswer
effectivement, dans /etc/zypp/repos.d très exactement.
mais bon ça fait un fichier par dépot qui contient
[Main Repository (NON-OSS)]
name=Main Repository (NON-OSS)
baseurl=http://download.opensuse.org/distribution/11.0/repo/non-oss/suse
type=rpm-md
enabled=1
autorefresh=1
gpgcheck=1
keeppackages=0
donc les modifier pour pointer vers de nouveaux dépots ça va par contre en créer un nouveau autant passer par le gui...
n°1094309
burn2
Posté le 01-12-2008 à 19:52:28  profilanswer
pour en crééer de nouveau y a une commande zypper qui le fait. ;)
n°1094856
burn2
Posté le 03-12-2008 à 20:08:42  profilanswer
Bon je suis en train de faire un test en entreprise!
Linux qui se tappe l'incruste dans un parc full windows....
Test sur une vielle machine plus utilisée.
Tout est passé out of the box! J'ouvre une session sur le vieux coucou avec un login inclu dans active directory et non présent sur le pc. Et j'ai accès à tout ce qui est partagé! Le tout sans aucune intervention niveau ligne de commande...
Après j'ai fais un test:
Dossier de test: Dossier contenant 1700 fichiers pdf.
Machine sous xp pro:
P4 3.0GHZ HT
1go de ram
DD 120Go
NTFS
Vieux coucou sous OpenSuse 11:
P3 500
192mo de ram
DD 6go
Partition en ReseirFS.
Accès au dossier sous depuis mon pc de boulot (C2D 3go de ram...)
Instantané sur les deux, pas de différence visible (différence pas visible).
Accès depuis le serveur central ou tout le monde se connecte depuis des terminaux qui est sous windows Server 2003:
3 à 4s sur le pc sous xp.
1s sur le vieux coucou......
C'est vraiment flagrand!
Je continu mes tests mais l'admin présent commence à être convaincu... :D
[Linux] Comment faire un petit serveur NAS ? Quelle distrib ?C64 DTV (nouvelle version Commodore 64)
Tester les version beta de Firefox et TBDistrib sur Compact Flash de 256 Mo [MAJ]
openSuse 10.2 et Nvidia qui rameOpenSuse 10.2 et Freeplayer et VLC
Distrib linux TRES légère permettant de faire tourner des photos ?Backtrack => bonne distrib?
{Rech] Distrib facile pour serveur FTP, WEB et PHP[OpenSuse 10.2]
Plus de sujets relatifs à : OpenSUSE Leap 15.0 out \o/
