8756 connectés
Vous avez :
 Page :   1  2  3  4  5  ..  303  304  305  ..  399  400  401  402  403  404
[Topic Unique] AMD Radeon R9 Fury (X) & Nano (28nm)
n°9597455
Lykomax
Posté le 31-08-2015 à 10:00:10  profilanswer
http://i-cdn.phonearena.com/images [...] eap-PC.jpg
La dame semble vouloir dire 'la taille ça compte'  :o
Enfin c'est comme ça que je le perçois.
n°9597460
Zurkum
Posté le 31-08-2015 à 10:06:53  profilanswer
Ce topal est vraiment excellent :D à défault des fury :o
n°9597468
enuma
Posté le 31-08-2015 à 10:16:53  profilanswer
Message édité par enuma le 31-08-2015 à 10:17:46
n°9597471
Sylfurd
UUUURUTORAMAN §§
Posté le 31-08-2015 à 10:20:21  profilanswer
Quelques retours intéressant des développeurs de Ashes sur les perfs des cartes AMD avec Async Compute et prometteur sur le comportement de GCN en Dx12:
http://www.overclock.net/t/1569897 [...] t_24356995
From our perspective, one of the surprising things about the results is just how good Nvidia's DX11 perf is. But that's a very recent development, with huge CPU perf improvements over the last month. Still, DX12 CPU overhead is still far far better on Nvidia, and we haven't even tuned it as much as DX11. The other surprise is that of the min frame times having the 290X beat out the 980 Ti (as reported on Ars Techinica). Unlike DX11, minimum frame times are mostly an application controlled feature so I was expecting it to be close to identical. This would appear to be GPU side variance, rather then software variance. We'll have to dig into this one.
I suspect that one thing that is helping AMD on GPU performance is D3D12 exposes Async Compute, which D3D11 did not. Ashes uses a modest amount of it, which gave us a noticeable perf improvement. It was mostly opportunistic where we just took a few compute tasks we were already doing and made them asynchronous, Ashes really isn't a poster-child for advanced GCN features.
Our use of Async Compute, however, pales with comparisons to some of the things which the console guys are starting to do. Most of those haven't made their way to the PC yet, but I've heard of developers getting 30% GPU performance by using Async Compute. Too early to tell, of course, but it could end being pretty disruptive in a year or so as these GCN built and optimized engines start coming to the PC. I don't think Unreal titles will show this very much though, so likely we'll have to wait to see. Has anyone profiled Ark yet?
AFAIK, Maxwell doesn't support Async Compute, at least not natively. We disabled it at the request of Nvidia, as it was much slower to try to use it then to not.
Weather or not Async Compute is better or not is subjective, but it definitely does buy some performance on AMD's hardware. Whether it is the right architectural decision for Maxwell, or is even relevant to it's scheduler is hard to say.
Où on apprend aussi que Maxwell ne gère pas l'Async compute, ce qui ne ravie pas les possesseurs de Geforce ( https://www.reddit.com/r/nvidia/com [...] nchronous/ )
Pour info, les premiers jeux Dx12 arrivent, Fable Legends (la béta vient de commencer) et Gears Of War Ultimate Edition.
L'Async Compute est super important en VR parce qu'il permet de faire de L'Asynchronous Timewarp ( https://developer.oculus.com/blog/a [...] -examined/ ). Les cartes AMD peuvent également tirer leur épingle du jeu sur la VR.
De plus avec la petite taille et le poids de la Fury Nano, je la vois bien intégrée dans un sac à dos pour ce genre de projet VR :D
https://www.youtube.com/watch?v=ur4KQakkmA8
Message édité par Sylfurd le 31-08-2015 à 10:36:42
NNiD: Sylfurd
n°9597852
Marc
Chasseur de joce & sly
Posté le 31-08-2015 à 15:22:03  profilanswer
30% ça semble optimiste, lors de la GDC AMD parlait plutôt de 20-25% et avait fait une démo avec un gain de 17%. Puis plus tard ils ont fait une démo avec un gain de 46% mais pas sûr que ce soit un cas réaliste. Par contre l'Async Compute devait être supporté sur les "Maxwell 2", si c'est pas le cas c'est un avantage certain pour GCN !
n°9597855
kimujix
Posté le 31-08-2015 à 15:25:38  profilanswer
Si c'est confirmé Wirmish va devoir reconsulter les astres pour réajuster ses prédictions sur la date de faillite d'AMD. :lol:
Message édité par kimujix le 31-08-2015 à 15:26:03
n°9597864
- gab
Posté le 31-08-2015 à 15:32:24  profilanswer
Nvidia non plus :D
Async Compute is a standardized API-level feature, which allows an app to better exploit the number-crunching resources of a GPU, by breaking down its graphics rendering tasks. Since NVIDIA driver tells apps that "Maxwell" GPUs supports it, Oxide Games simply created its benchmark with async compute support, but when it attempted to use it on Maxwell, it was an "unmitigated disaster." During to course of its developer correspondence with NVIDIA to try and fix this issue, it learned that "Maxwell" doesn't really support async compute at the bare-metal level, and that NVIDIA driver bluffs its support to apps. NVIDIA instead started pressurizing Oxide to remove parts of its code that use async compute altogether, it alleges.
http://www.techpowerup.com/215663/ [...] tx-12.html
n°9597866
enuma
Posté le 31-08-2015 à 15:34:02  profilanswer
Message édité par enuma le 31-08-2015 à 15:35:17
n°9597868
darkandy
Posté le 31-08-2015 à 15:34:41  profilanswer
En tout cas ça pourrait confirmer que les cartes AMD se débrouille mieux sur le long terme comme les anciennes générations qui se débrouillent toujours aussi bien.
Mais c'est à partir de quel GNC ? (désolé si ça a déjà été dit).
En tout cas, ça fait un effet boule de neige cette histoire d'Async Compute, en faisant une recherche sur Gooooooogle, je me retrouve avec des "NV GPUs do not support DX12 Asynchronous Compute/Shaders."... Moi qui voulais une définition de ce truc, faut que j'épluche...
Message édité par darkandy le 31-08-2015 à 15:38:11
Phenom II 1090T: http://valid.canardpc.com/show_oc.php?id=1766499 Intel Core i5 4670K : http://valid.x86.fr/ka4cpf Ryzen 2600 : https://valid.x86.fr/0byf0r Ryzen 5 3600 : https://valid.x86.fr/fzwdll
n°9597873
Yopfraize
Posté le 31-08-2015 à 15:36:38  profilanswer
Nvidia dans toute sa splendeur comme d'habitude, je parie qu'ils vont proposer une jolie somme pour ne pas se faire ruiner dans les benchs de ce jeu :o
Message édité par Yopfraize le 31-08-2015 à 15:37:54
n°9597875
darkandy
Posté le 31-08-2015 à 15:39:22  profilanswer
Bah oui c'est pas normal qu'AMD a UN avantage sur UNE démo technique, faut corriger ça :lol:
n°9597884
Yopfraize
Posté le 31-08-2015 à 15:48:04  profilanswer
Le plus dégoutant là dedans c'est encore une fois un joli mensonge à la mode GTX970 4gb de Vram ;)
Since NVIDIA driver tells apps that "Maxwell" GPUs supports it [...] it learned that "Maxwell" doesn't really support async compute at the bare-metal level, and that NVIDIA driver bluffs its support to apps
Given its growing market-share, NVIDIA could use similar tactics to keep game developers away from industry-standard API features that it doesn't support, and which rival AMD does [...] We wonder how much of that support is faked at the driver-level, like async compute.
Allez hop ! Apres
- Les "4" Gb de Vram de la 970,
- les Shaders "maison" Nvidia
- Le honteux Gameworks (d'ailleurs je suis content que TechPowerUp le pense aussi)
The company is already drawing flack for using borderline anti-competitive practices with GameWorks
On peut ajouter
- La fausse prise en charge DX12 puisque l'Async Compute est un des éléments principaux de ce dernier
Allez hop, the way it's meant to be pigeoned, c'est la goutte d'eau de la fumisterie, je vais gentiment me retenir d'acheter une 980Ti en septembre :o
Message édité par Yopfraize le 31-08-2015 à 15:53:57
n°9597889
kimujix
Posté le 31-08-2015 à 15:51:28  profilanswer
On va attendre quelques confirmations officielles avant de s'esclaffer, mais si c'est bien le cas... on va avoir droit à une sacrée shitstorm.  :bounce:
Message édité par kimujix le 31-08-2015 à 15:51:57
n°9597897
- gab
Posté le 31-08-2015 à 15:57:41  profilanswer
Y aura aucun shitstorm, même si tout ça est avéré :o
90% des acheteurs s'en moquent, ils regardent les benchs et les recommandations de potes/sur les forums, ce genre de précisions techniques leur passent au-dessus de la tête. Et dans le doute, le mythique "les drivers d'AMD sont pourris" pèsera toujours plus lourd que les pratiques de nvidia.
Pour l'instant, les premières réactions, c'est du déni :D
I think NVIDIA just couldn't be bothered with driver implementation till now because frankly, async compute units weren't really needed till now (or shall I say till DX12 games are here). Maybe drivers "bluff" the support just to prevent crashing if someone happens to try and use it now, but they'll implement it at later time properly. Until NVIDIA confirms that GTX 900 series have no async units, I call it BS.
Message édité par - gab le 31-08-2015 à 16:34:07
n°9597917
enuma
Posté le 31-08-2015 à 16:13:29  profilanswer
n°9597920
- gab
Posté le 31-08-2015 à 16:16:46  profilanswer
C'était assez modéré je crois :D Les réactions étaient assez bien partagées entre les pragmatiques ("ça change rien à son bon comportement constaté dans les jeux/benchs" ) et les opportunistes ("c'est dégueulasse, j'exige que nvidia me rembourse ma 970 et m'offre une 980" ).
Message édité par - gab le 31-08-2015 à 16:17:21
n°9597926
Sylfurd
UUUURUTORAMAN §§
Posté le 31-08-2015 à 16:20:54  profilanswer
les 30% proviennent d'un retour d'un développeur console (PS4 je crois) où l'Async Compute est largement utilisé.
Deus Ex Mankind Divided et Rise of the Tomb Raider en font un usage intensif sur console, à voir ce que ça donne sur la version PC.
NNiD: Sylfurd
n°9597928
beufemisat​eur
Posté le 31-08-2015 à 16:22:09  profilanswer
J'ai bien hâte de voir ce que va donner la 290x et les Fury dans les futurs jeux dx12. :)
n°9597930
cortexzehe​f
Posté le 31-08-2015 à 16:23:00  profilanswer
On dit que ce n'est pas grave du moment qu'on en a pas besoin. Si les jeux DX12 auront besoin de cette compatibilité, les acheteurs de "GTX 980ti (Premium donc)" l'auront dans les fesses. S'ils voient qu'ils ont acheté un GPU ultra cher pour le changer en un an, parce qu'ils ne joueront plus en ultra toutafond 1440p...
n°9597933
TotalRecal​l
Posté le 31-08-2015 à 16:25:36  profilanswer
Vu qu'il n'y a pas grand chose de nouveau, après lecture des 3 dernières pages je suggère cordialement aux spécialistes du troll et bashing AMD de lever un peu le pied, sauf si c'est pour partager un test officiel ou une news pertinente.
En d'autre terme le prochain "scoop exclusif" à la Wirmish ou râbachage des même chose à coups de critiques de plus ou moins bonne foi à la enuma/activation risque fort de se finir par un TT... Et evidemment ça vaut pour tous, pas juste ceux cités !
Message édité par TotalRecall le 31-08-2015 à 16:26:26
Topic .Net - C# @ Prog
n°9597936
kimujix
Posté le 31-08-2015 à 16:26:09  profilanswer
Si c'est confirmé Nvidia fera tout pour décourager les développeurs de faire appel à l'async compute... jusqu'à l'arrivée des premières cartes basées sur Pascal.
n°9597938
cortexzehe​f
Posté le 31-08-2015 à 16:27:48  profilanswer
A coup de gros chèque surement   [:trollol]
n°9597944
Yopfraize
Posté le 31-08-2015 à 16:35:16  profilanswer
Oui sauf que ca risque d'être assez difficile puisque, pour le coup, si j'ai bien lu mes informations sur DX12 c'est l'Async Compute qui fait un des intérêts principaux dudit DirectX (et le boost de perfs qui va avec  :whistle: )
Donc je vois difficilement Nvidia payer à ce point tout le monde afin de rester sur DX11  :heink:
Message édité par Yopfraize le 31-08-2015 à 16:36:32
n°9597954
Spartan88
Posté le 31-08-2015 à 16:47:42  profilanswer
Je suis sous pavillon Nvidia depuis quelques temps déjà (je suis passé par la 280X - 290) parce qu'il faut bien avouer que Nvidia a réussi un sacré coup avec Maxwell sans tout chambouler c'est très bon.
Mais hélas Fury est décevant quand on rapporte ça au prix.
Néanmoins je pense qu'ils ont avec HBM une arme de poids qui peut changer la donne avec une baisse de prix pour le rendre accessible et le 16nm qui arrive, et j'attends beaucoup de AMD sur ce coup (et pour ZEN aussi)
Pour le reste Microsoft ne s'est pas cassé le cul à faire DX12 pour laisser Nvidia le saboter en forçant le DX11
Message édité par Spartan88 le 31-08-2015 à 16:50:55
n°9597955
OrcusZ
Pro AMD | .Net lover
Posté le 31-08-2015 à 16:47:51  profilanswer
Je crois que c'est GCN 1.2 ( c'est les seul à gérer en FULL DX12 )
A confirmer quand même je suis plus très sûr.
Made you your own sentence without believing that of the others...
n°9597958
darkandy
Posté le 31-08-2015 à 16:49:43  profilanswer
En tout cas, il y'a des personnes qui commencent à dire sur les forums : "j'hésite à revendre ma GTX970 pour une R9 290X/390X"  :pt1cable:
Edit : pour coller au topic, vivement le test HFR de la Nano  :D
Message édité par darkandy le 31-08-2015 à 16:52:35
n°9597963
pepes003
Loués soient les Or(d)i
Posté le 31-08-2015 à 16:51:44  profilanswer
Moi j'ai lu all GCN (ACEs compliant):
"and every GCN based GPU has a minimum of two ACEs"
"ACEs debuted with AMD’s first GCN based GPU code named Tahiti in late 2011"
Source: http://wccftech.com/amd-improves-d [...] z3kP9ECLyC
Message édité par pepes003 le 31-08-2015 à 16:58:07
> Mon FEEDBACK <
n°9597968
Gein
Posté le 31-08-2015 à 16:52:41  profilanswer
n°9597969
- gab
Posté le 31-08-2015 à 16:53:08  profilanswer
L'intérêt est à peu près nul, s'ils veulent changer de cg autant le faire quand il y aura des jeux DX12 qui mettront en difficulté leur 970 à cause de ça (si jamais), mais perdre du fric aujourd'hui en prenant un GPU vieux de deux ans qui consomme plus pour à peu près les mêmes perfs... Enfin, c'est la réaction classique :D
Cela dit, s'il y a une vague de 970 en occase à 260€ pour cause de revente compulsive, ça fera toujours des heureux  [:barracus:3]
Message édité par - gab le 31-08-2015 à 16:56:00
n°9597974
kimujix
Posté le 31-08-2015 à 16:57:43  profilanswer
GCN 1.1 et 1.2 ont le même niveau de support de DX12.
n°9597982
Gein
Posté le 31-08-2015 à 17:10:07  profilanswer
n°9597998
Spartan88
Posté le 31-08-2015 à 17:26:17  profilanswer
Aucune raison de vendre une 970 custom pour une 290X/390X, mais alors aucune raison...quand on sait qu'une custom 390X arrive quasiment à faire jeu égal avec une 980 générique.
Alors douiller 450€ pour gagner une poignée d'ips en plus par rapport à une 970...
On va devoir attendre le 16nm pour être fixé, en espérant que d'ici là HBM soit plus accessible à la production
n°9598008
etocal
bebew
Posté le 31-08-2015 à 17:41:54  profilanswer
n°9598011
- gab
Posté le 31-08-2015 à 17:43:30  profilanswer
Maxwell 1 = 750 ti, Maxwell 2 = la série 9xx.
n°9598017
Corleone_6​8
Posté le 31-08-2015 à 17:48:39  profilanswer
Ca déjà été le cas avec DX10 (ou 10.1 ??? Je ne sais plus) il n'y avait que AMD qui était prêt depuis 2 gène et bien sûr pas nVidia... Comme d'hab nV a fait pression et MS a gentiment baissé le froc et c'est penché en avant... Du coup la sortie de DX à prit un gros retard, et l'avantage d'AMD ne servit à rien... (D'après les souvenirs je ne pense pas trop me tromper sur l'histoire.)
Bref ca sera pareil cette fois aussi....
A moins que... c'était quoi les GPU utilisé dans les consoles à cette époque ???
Phanteks Enthoo Primo / Seasonic P-860 / Asus Strix B550 E/ Ryzen 5600X WC / 2*16 F4 3600C16 Gskill Ripjaws @3733 / 6900XT Red Devil / Crucial C300 128 Go / Sam 850 Evo 500 Go / Velociraptor 300 Go / Caviar Red 4 To / Caviar Black 1 To
n°9598019
Spartan88
Posté le 31-08-2015 à 17:52:37  profilanswer
Faut arrêter de fumer, Dx 10.1 n'apportait rien de spécial pour justifier d'en faire la norme. Comme si c'était Microsoft qui était tributaire de Nvidia en plus !
n°9598021
everwind
Posté le 31-08-2015 à 17:57:36  profilanswer
Ati chez crosoft, Nvidia chez Sony
Et sur DX10 c'est surtout les dev qui ne s'y sont pas mis ou alors très tard, et je les comprends quand on voit le peu d'avantage qu'ils avaient à l'utiliser. Pour DX12 c'est un peu plus mais encore limité, on est pas pret de voir des jeux 100% DX12 en majorité.
n°9598030
Corleone_6​8
Posté le 31-08-2015 à 18:09:48  profilanswer
Donc tu cautionne qu'une avancée technologique soit retardé parce que l'un des grands constructeurs n'est pas prêt alors que l'autre si ?? Si on refait l'histoire mais en inversant les rôles (entre AMD et nV) je suis sûr que ca ne serait pas passé comme ca. Même si la dite avancée n'apporte pas un énorme plus, ce sont des manœuvre non acceptable pour nous.. On aurait peut être DX12 depuis un moment si les choses avait tourné "normalement"..
Donc merci d'arrêter de fumer toi aussi..
Oui mais le plus gros blocage venait de nV car leur cartes n'étaient pas compatible.. Si un développeur utilisait DX10 il savait que ca ne tournerait pas sur les 3/4 des cartes graphiques du marché (nV) alors pourquoi s'embêter ??
Bref on va arrêter là car c'est HS, mais je ne suis pas d'accord pour passer ce genre de choses sous silence juste parce que ca n'apporte rien... Phys'x non plus n'apporte rien pourtant quand tu as un carte AMD tu oublie le jeux car tu sais que tu auras des perfs de merde... c'est pareil, même manœuvre non fair play..
Enfin bref..
Message édité par Corleone_68 le 31-08-2015 à 18:10:04
n°9598037
Tigrou
Sans accroc
Posté le 31-08-2015 à 18:20:51  profilanswer
C'est pas faux [:transparency]
Feedback - Stacy's mom
n°9598077
Activation
21:9 kill Surround Gaming
Posté le 31-08-2015 à 19:30:15  profilanswer
C'est sur qu'avec les super slide powerpoint qui disent que 'fury' est cap de dépasser les nvidia en 4K ultra low detail en mode dx12 :o
Dx12 ou pas ta 290x/390x tiendra tout autant le coup que la gtx970 en fullhd
Perso si j'attend les premier gpu 16nm c'est plus pour voir enfin de la '4k' fluide en monogpu sans tout mettre en 'low'
Fury ou 980ti ... Ça reste du bullshit de vouloir balancer de la '4k' en monogpu dx12 ou pas
Et amd non plus ne propose pas l'integralité de ce que permet dx12
Ils ont privilégié sur les gpus actuels ce qui permet de rendre moins minable leur cpu. (Faut dire que leur cpu sont sur xbox et playstation :o )
Coté nvidia ils ont privilégié les feature dx12 lié au rendu
Qui a raison qui a tord sachant que de tout façon les jeux avec un mode dx12 n'arrive que sur octobre/novembre
Et combien de jeux au début
Comme d'hab ça reste ceux qui change plus souvent de gpu dans la tranche 300-350boules qui sont le plus dans le vrai que ceux qui casque 2 fois moins souvent dans un gpu à 600 boules :o
La carte graphique subit aussi l'obso programmé avec ses normes à la con hdmi, hdcp, le rec709 qui passera en 2017 en rec2020, les codecs video, ....
Y a pas que opengl, vulkan, directx
Demain le "un connecteur usb type c pour les unir tous"
Acheter le très haut de gamme gpu tres cher = Foutaise :o
Achète ce qui t'es necessaire à l'instant "t"
On parle de gpu là, pas de placement sur les metaux ou dans des oeuvres d'art ou que sais je
On parle de dépenser du fric dans un composant informatique sujet à l'obso
Message cité 4 fois
Message édité par Activation le 31-08-2015 à 19:32:39
n°9598089
cortexzehe​f
Posté le 31-08-2015 à 19:46:37  profilanswer
300 boules ça reste quand même énorme pour un truc qui devient "obsolète" (à prendre avec des pincettes) trop rapidement...
Message édité par cortexzehef le 31-08-2015 à 19:46:52
Carte Graphique 250€ (AMD/NVIDIA)Radeon R9 280X Tri-X, 3Go ou GeForce GTX 770
Portable pas cher : Intel Celeron N2830 2,16 GHz ou AMD E1-2100 1GHz ?CPU ET CM Choix pour 300 euro max
R9 280X a 15€ ^^R9 290 Tri-X Chauffe beaucoup
Carte graphique R9 290 ou GTX 770 ?R9 290 Trix OC (besoin de conseils sur refroidissement)
Upgrade Radeon 5770 -> GeForce 750
Plus de sujets relatifs à : [Topic Unique] AMD Radeon R9 Fury (X) & Nano (28nm)
