8347 connectés
 Page :   1  2  3  4  5  ..  897  898  899  ..  1028  1029  1030  1031  1032  1033
[Topic Unique] NVIDIA GeForce GTX 660Ti/670/680/690/760/770 (GK104)
n°8778108
AVatar66
Oy Wazzoks !
Posté le 02-07-2013 à 14:19:46  profilanswer
Invite_Surprise a écrit :
Hier, j'ai testé 2 méthodes pour rajouter du jus à ma 680 Lightning et les 2 fonctionnent au poil :
1- artmoney :
And...as always: USE AT YOUR OWN RISK
-Download ArtMoney SE v7.39
-Open Afterburner 2.2.3
-Right-click ArtMoney and select Run as Admin, then click continue
-Select Afterburner from the drop-down list in the center
-Set the core voltage (or any voltage you want to 'edit') in Afterburner to a number other than +0 (just to help narrow results) and click Apply. For this example, we'll assume you set the core voltage to +31mv
-Click Search in ArtMoney and enter 31 in the value box and then click OK, then click OK again
-Change that same voltage in Afterburner to another number, we'll say +63mv, then click Apply
-Click Filter in ArtMoney and change the Value box to the new voltage value you just applied in Afterburner and click OK, then OK again
-Click the top arrow in ArtMoney to move the top value listed in the left column to the right column (If you did the search and filter correctly, then the addresses for each voltage you should have come up with depending what you were editing are- Core = 00449000, Memory = 00449030, Aux = 00449060)
-Once you moved one of those into the right column, right-click it and go to Set Value, enter the voltage off-set you would like, then click OK, and notice that it's changed in ArtMoney
-Now, change one of the clock speeds so that you are able to click the Apply button in Afterburner, and then click it. You will now see the edited voltage jump to the amount you entered in ArtMoney
BE CAREFUL WHAT YOU ENTER. Make sure the voltage sliders in Afterburner jumped to where they were supposed to before you put any type of load on the card
2- Rbby258 MORE voltz.exe
http://tof.canardpc.com/view/300b3 [...] 283e34.jpg
Cela fonctionne très bien et il est possible de dépasser les limitations apportés par nVidia ainsi. A priori, ça fonctionne sur les autres cartes également.
Par contre, il faut faire très très attention et avoir un très bon cooling car ça envoie du jus comme vous le demandez !
Je déconseille vivement de NE PAS dépasser 120 niveau Core Voltage car cela donne déjà 1.4v avec multimètre sur la 680 Lightning donc faites très très attention.
La solution avec Rbby258 MORE voltz.exe est vraiment simple d'utilisation comparée à artmoney, plus fastidieuse.
Toutes les informations peuvent être trouvées ici : http://www.overclock.net/t/1398725 [...] weak/0_100
Rhoooo....Coquinou va,je teste ça direct en rentrant!  :jap:
Message édité par AVatar66 le 02-07-2013 à 14:20:31
Topic Transactions + FeedBack
n°8778112
sicqo
unleash the dragon...
Posté le 02-07-2013 à 14:20:37  profilanswer
la AMP! edition de Zotac vient de remonter à 429€ sur RDC
ça conforte mon choix à 419€  ;)
n°8778113
sat 08
Team Haque-Barre
Posté le 02-07-2013 à 14:20:41  profilanswer
A 1.4v ça doit commencer à bien envoyer [:azylum]
Pur produit AHB
n°8778116
AVatar66
Oy Wazzoks !
Posté le 02-07-2013 à 14:22:35  profilanswer
Ce soir c'est clim en direct sur le boitier et tous les ventilos a fond a 1.4v pour peut être atteindre les 1450Mhz? ;)
n°8778118
sat 08
Team Haque-Barre
Posté le 02-07-2013 à 14:23:23  profilanswer
Et pendant les premiers jour oû tu ne voulais pas , elle était a combien ?
Moi j'ai gagner 64€ ( hors reduc ) sur ma 780 wf3 à l'avoir pris de suite  :o
Pur produit AHB
n°8778120
sat 08
Team Haque-Barre
Posté le 02-07-2013 à 14:24:34  profilanswer
Fait ça lorsque Madame ne regardera plus la télé par contre  [:azylum]
Pur produit AHB
n°8778132
Invite_Sur​prise
Racaille de Shanghaï
Posté le 02-07-2013 à 14:30:26  profilanswer
J'ai pas réussi à valider 1424MHz sur 3DM11 avec le cooling d'origine en mettant les fans à 100% pour ma part. Testé hors boitier.
Message édité par Invite_Surprise le 02-07-2013 à 14:33:41
n°8778154
lou9200
Eradication.Originale.Solvante
Posté le 02-07-2013 à 14:40:47  profilanswer
J'comptai commander la GB 770oc 2go à l'instant
elle vient de monter de 359€ (hier) à 375€ sur grosbill :/
la GB 760 oc 2go est "toujours" à 259€" elle ...
y'a d'la demande, ca en profite pour vendre plus cher (ce qui est bien français ca, tiens...), loi du commerce ...
bin ma loi d'consommateur elle va du coup pas l'prendre et encore attendre, quitte à la prendre ailleur malgrès l'serieux de grosbill ...
7D, 17-55 2.8, 85 1.8, 70-200 4L | server TM Valley | mon FeedBack HFR
n°8778155
AVatar66
Oy Wazzoks !
Posté le 02-07-2013 à 14:40:50  profilanswer
A 1.31v j'avais passé une ou deux fois a 1411 sur heaven :D esperons pouvoir faire plus ;)
Ça va sentir le BBQ ce soir! (cooler d'origine aussi ;) )
D'autan plus qu'avec le bios que j'ai,je ne perd pas de bin passé 70°C,on va voir ;)
Ce n'est pas ma femme qui regarde la télé,c'est la télé qui regarde ma femme :o
Message édité par AVatar66 le 02-07-2013 à 14:41:36
n°8778183
sicqo
Posté le 02-07-2013 à 14:53:03  profilanswer
449€  :)
n°8778186
Invite_Sur​prise
Posté le 02-07-2013 à 14:55:11  profilanswer
1.31v renvoyé par AfterBurner correspond à ~1.38v en charge avec le multimètre.
Jamais de perte de bins également avec le BIOS LN², j'ai pas essayé l'autre BIOS à vrai dire  [:aurelien_fr]
A noter que j'ai vu passer un 187% en power limit pendant le run quand même  :D
n°8778197
AVatar66
Oy Wazzoks !
Posté le 02-07-2013 à 15:02:22  profilanswer
Ah ouais  :sweat: je vais pas aller trop trop loin en voltage du coup :D,a 1354/1777,elle monte a 75°C avec ventilo a 70% donc je vais preparer les boules quies pour monter plus haut :D
J'ai jamais fait gaffe au power limit,ça sert a rien ça,hein? :D je le fout a 300% comme toujours et ça fonctionne bien :D
n°8778207
Invite_Sur​prise
Posté le 02-07-2013 à 15:08:14  profilanswer
Dis-toi que la valeur 100 donne 1.38v, 120 1.4v, 140 1.43v, 160 1.45v ...
Donc la marge de manœuvre est limitée par le cooling, c'est sûr.
Je vais attendre de monter le WB pour pousser les tests un peu +
Message édité par Invite_Surprise le 02-07-2013 à 15:08:49
n°8778221
AVatar66
Oy Wazzoks !
Posté le 02-07-2013 à 15:14:34  profilanswer
n°8778248
Le Profana​teur
Passéiste désincarné
Posté le 02-07-2013 à 15:39:48  profilanswer
1- artmoney :
Je déconseille vivement de dépasser 120 niveau Core Voltage car cela donne déjà 1.4v avec multimètre sur la 680 Lightning donc faites très très attention.
J'avais lu que c'était compatible qu'avec une seule puce de monitoring, et par exemple la msi gaming n'était donc pas compatible.
n°8778259
AVatar66
Oy Wazzoks !
Posté le 02-07-2013 à 15:46:11  profilanswer
Juste pour info,tu as essayer de rajouter du jus a la memoire et en Aux? J'ai tjr entendu dire que ça rendait instable,peux tu le confirmer/infirmer?
n°8778273
Invite_Sur​prise
Posté le 02-07-2013 à 15:53:47  profilanswer
Je suis toujours à +100 Corre, +100 Mem et +20 Aux pour une utilisation H24 et je rencontre pas de problème de plantage en jeu @1372/7000 fan en Auto.
Les seuls soucis peuvent provenir lors de la sortie de veille prolongée où la tension est + basse que prévue en charge, sinon, ça roule.
Il me semble que ça marche seulement avec le chip CHL8318 oui.
Message édité par Invite_Surprise le 02-07-2013 à 16:00:18
n°8778279
AVatar66
Oy Wazzoks !
Posté le 02-07-2013 à 15:56:24  profilanswer
Thanx Dude :jap:
Ce soir je teste ça :)
n°8778287
sat 08
Team Haque-Barre
Posté le 02-07-2013 à 16:00:15  profilanswer
sicqo a écrit :
449€  :)
ok :jap:
Pur produit AHB
n°8778289
sat 08
Team Haque-Barre
Posté le 02-07-2013 à 16:01:40  profilanswer
AVatar66 a écrit :
Thanx Dude :jap:
ça sent le sapin  [:azylum]
Pur produit AHB
n°8778293
calagan57
BF3 : calagan57
Posté le 02-07-2013 à 16:09:20  profilanswer
Hello!
dites moi une GTX680 j'suis à 1.175V de VGPU, à combien je peux monter en étant "safe". La bête sera plus tard WC  :jap:
merci à vous! :hello:
Waterbox
n°8778295
AVatar66
Oy Wazzoks !
Posté le 02-07-2013 à 16:09:57  profilanswer
Optimiste :)
Non : Vrm,RAM,GPU >80°C je coupe tout :D
Donc la mise en terre de ma 680 est pas pour tout de suite ;)
calagan57 a écrit :
Hello!
1.25v pour une carte de ref c'est deja bien ;) en plus si t'en a deux sa va faire chaud la dedans :D
Message édité par AVatar66 le 02-07-2013 à 16:11:49
n°8778310
Le Profana​teur
Posté le 02-07-2013 à 16:20:18  profilanswer
Voilà. :d
Bon, je refinalise l'o/c CPU, puis je m'occupe de la lightning correctement.
Là ça tourne au max en 1267 par défaut, et ça passe automatiquement à 1280 juste en mettant +12mV [:transparency]
PS : la 680 et la 770 ne sont pas les mêmes, qq composants du PCB sont manquants voir différents sur la 770 (par exemple, il manque des trucs sur le 2e PCB pour la 770, j'ai pu le constater avec la notice de montage du waterbloc qui est documenté avec une 680)
n°8778322
Invite_Sur​prise
Posté le 02-07-2013 à 16:28:32  profilanswer
Ces cartes, c'est un peu Kepler done right !
Le fait qu'elles soient équipées d'un très bon système de refroidissement, d'un étage d'alimentation costaud et qu'il soit permis de rajouter du jus en fait ce qu'il se fait de mieux dans cette génération de cartes.
J'espère que la 780 Lightning permettra ce genre de facéties également, avec des OC canons.
n°8778324
AVatar66
Oy Wazzoks !
Posté le 02-07-2013 à 16:30:27  profilanswer
Et comment ! [:zest:1]
Message édité par AVatar66 le 02-07-2013 à 16:31:01
n°8778327
Invite_Sur​prise
Posté le 02-07-2013 à 16:31:59  profilanswer
AVatar66 a écrit :
Optimiste :)
100% fan à 1.42v, j'ai pas atteint les 80°, 78° hors boitier.
J'ai pas fait gaffe aux VRM par contre :/
n°8778396
drebbin
Posté le 02-07-2013 à 17:18:50  profilanswer
:ouch:
La MSI GTX 770 Gaming est passée elle sur Grosbill de 350€ à 395€ !!!  :lol:
 +45€ !  :pt1cable: (certes elle était 30€ moins chère chez eux que partout ailleurs)
Les pourris !  C'est la première fois que je vois ça !  :heink:
J'ai commandé ma MSI 770 Gaming juste à temps pour 353€ fdpin ...  :sol:
Message édité par drebbin le 02-07-2013 à 20:29:13
n°8778414
AVatar66
Oy Wazzoks !
Posté le 02-07-2013 à 17:29:09  profilanswer
Je viens de rentrer chez Wam :)
Je te dis ça tout de suite !
EDIT: Impossible de dépasser 1415Mhz :/ malgrès le voltage en plus +130Vcore/+100Vram/+20 Vaux....Bon c'est quand même bien ;)
Message édité par AVatar66 le 02-07-2013 à 18:02:22
n°8778429
fabounay
Posté le 02-07-2013 à 17:40:49  profilanswer
Sur ma gtx 770 lightning le power limit est bloqué a 109% max, je suis sous le bios ln2 et j'ai la dernière version de msi afterburner, ducoup je peu pas faire grand chose, y a un moyen de l'augmenter je vois que certain peuvent aller jusqu'a 300%  :ouch:
n°8778499
Khiryu
Posté le 02-07-2013 à 18:36:19  profilanswer
Arf je guettais la même que toi pour juillet ben tant pis, on attendra...
n°8778514
Domicron
Posté le 02-07-2013 à 18:49:54  profilanswer
Tiens c'est bizarre, sur la WF3 je peux aller jusqu'à 111% avec la version 3 beta 10 de AB :D
n°8778530
kamikaze24
Posté le 02-07-2013 à 19:04:00  profilanswer
La position ln2 m'a foutu des ré-détection de matériel en boucle. Je pense que entre les pilotes, afterburner et la GX770 tout est trop récent encore ...
n°8778545
Le Profana​teur
Posté le 02-07-2013 à 19:19:01  profilanswer
Idem, et même avec le béta je suis aussi sur 109%. 320.39 et 320.79 (windows 7) essayés....
n°8778567
aliquide
Non
Posté le 02-07-2013 à 19:29:26  profilanswer
Perso avec les 320.18 et AB 2.3.1 ( :o ), j'peux aller à 111% :heink:
Topic ACH/VDS FEED
n°8778714
sicqo
Posté le 02-07-2013 à 21:18:26  profilanswer
LDLC vient de faire un effort sur les AMP! Zotac
http://www.ldlc.com/fiche/PB00148422.html#aff107
(ils font payer la livraison relais)
n°8778721
drebbin
Posté le 02-07-2013 à 21:26:19  profilanswer
415€ pas donné ! + la livraison (Obligation de s'inscrire pour avoir le cout de la livraison sur LDLC :  :fou: )
n°8778729
SpiteFire
Posté le 02-07-2013 à 21:33:50  profilanswer
Question con: les cg ont des mises a jours pour leur bios? si oui on les trouve ou? site du fabriquant?
n°8778733
Dadounou
La Fouine Informatique
Posté le 02-07-2013 à 21:37:09  profilanswer
:hello: à tous, juste au cas où
MSI N670 Power Edition
http://media.materiel.net/live/184890.jpg
Bundle complet, sous garantie 3 ans (04.08.12)
Il monte jusqu'à 1320 MHz pour le GPU. Côté RAM +400 MHz sous afterburner. :love: :love:
http://img560.imageshack.us/img560/4193/zb3q.jpg
Prix: 250€ IN
DISPONIBLE
Message édité par Dadounou le 03-07-2013 à 17:47:24
Topic [ACH-VDS] --- FeeDBacK
n°8778775
Le Profana​teur
Posté le 02-07-2013 à 22:16:11  profilanswer
On parle des 770 lightnings, pas des windforce.
n°8778787
aliquide
Non
Posté le 02-07-2013 à 22:29:28  profilanswer
Ah pardon  [:ddr555]
Topic ACH/VDS FEED
n°8778877
drebbin
Posté le 02-07-2013 à 23:37:48  profilanswer
Etant donné le prix des GTX 760 (~250€) qui s'overclockent de folie (+20% de perfs) je vois pas trop l'intérêt ...  :??:
Concours Nvidia / questions sur les... questionsCartes Mères Z68 GIGABYTE, laquelle choisir ?
Panneau de configuration NVIDIA ?[HFR] Actu : 5 cartes A75 FM1 pour ASRock
Probleme aprés installation carte NVIDIA GEFORCE 8400 GS[HFR] Actu : Nvidia lance les GTX 580M et 570M
[HFR] Actu : 4 cartes Socket FM1 pour Gigabyte[Topic Unique] Problème pour mettre à jour sa carte réseau
Gestion des ventilateurs 3 pins avec les cartes mères P67Configuration MCP73VE NVIDIA MCP73
Plus de sujets relatifs à : [Topic Unique] NVIDIA GeForce GTX 660Ti/670/680/690/760/770 (GK104)
