3407 connectés
 Page :   1  2  3  4  5  ..  413  414  415  ..  1028  1029  1030  1031  1032  1033
[Topic Unique] NVIDIA GeForce GTX 660Ti/670/680/690/760/770 (GK104)
n°8336711
rorogeek
Geek one day, geek everyday !
Posté le 04-06-2012 à 02:27:16  profilanswer
Les mecs, je viens de commencer à folder sur ma GTX 670.
Pour l'instant : 17349 PPD estimés x 2, alors que j'ai qu'une CG... Ca détecte une GTX 680 et GTX 670, mais ça marche, et ça fait péter le score, ça me change du CPU (SMP) et d'ATI !
Si ça en intéresse, voici ce que j'ai suivi :
OK, I finally got it... here's what you do:
Must use V7 client in expert mode.  Follow THESE ( http://folding.typepad.com/news/20 [...] lient.html ) instructions first, then...
1) Start the V7 client, pause the GPU client(s) if running.
2) go to 'Start' > 'All Programs' > 'FAHClient' > 'Data Directory' [it links directly to data location], then dbl click 'work' and delete your GPU-related directories.  The directories are those with names '00', '01', etc, which match your 'Work Queue' number on the V7 client expert main page.  Be sure you do not delete any CPU or non-680 directories.
3) go back to the V7 client and click 'Configure', dbl click the first 680 GPU entry (repeat for other 680's as necessary)
4) scroll down to 'Extra slot options (expert only)' and look for an Add button on the lower right and click it.
5) under 'Name:' enter "client-type" and under 'Value:' enter "beta", click OK
6) Return to main V7 screen, look under 'Folding Slots' and for each GPU right-click > 'Fold'
7) If they don't start properly just restart the folding client.
I'm doing 20k PPD on the stock clocks of my reference card.  WU 8019 at 8% so far.
Simplement :
1) Copier le "GPUs" dans le dossier data de F@H, lancer F@H
2) Mettre en pause F@H, supprimer le contenu des dossiers et 00 et 01 dans le dossier "data/wu",
3) Passer en expert si c'est pas déjà fait, aller dans les options, et mettre Name : "client type" value : "beta" pour les deux GPU
4) Enjoy
http://image.noelshack.com/fichier [...] FAH670.png
Aux observateurs, oui, la nuit va être courte, mais au moins je me couche l'esprit tranquille, le PC en full burn, foldant, et la connexion à donf qui récupère des fichiers en 3D de ma seedbox en FTP, petit plaisir de geek de savoir que ça mouline pendant que je dors !
Message édité par rorogeek le 04-06-2012 à 07:05:43
GLHF !
n°8336712
cacahuete
Posté le 04-06-2012 à 02:50:35  profilanswer
Rien pané
n°8336731
rorogeek
Posté le 04-06-2012 à 07:07:07  profilanswer
Folding at home, programme qui permet d'aider la science avec ton CPU et GPU en gros, en leur faisant calculer ou dans le jargon "folder" des trucs. C'est développé par l'université de Standford et y'a un paquet de gens qui le font, notamment parce qu'il y a un classement et que y'a un côté "celui qui a la plus grosse", et qu'en plus c'est utile. Le but est d'expliquer (et donc de trouver des solutions) pour des maladies dégénératives comme Alzeimer, en faisant des simulations d'une étape cruciale chez certaines protéines de l'organisme, à savoir, leur repliement (folding). :)
PPD : Points per day dans le jargon.
Et les cartes nVidia utilisent le CUDA, et son très performantes à ça. :)
Message édité par rorogeek le 04-06-2012 à 07:15:11
GLHF !
n°8336757
seth-01
Posté le 04-06-2012 à 09:07:32  profilanswer
sur ton screen ............... Y'A TON IP !!!!  :o
n°8336780
gta007
Posté le 04-06-2012 à 09:41:15  profilanswer
Bundle de la Asus Gtx 670 dc2 top pour confirmation:
Carte
Adaptateur molex / pciexpress
Notice
DVD installation
C'est tout j'oublie rien? Je prépare le retour...
Mon Feed-back
n°8336825
wnorton
Je suis néerlandophone
Posté le 04-06-2012 à 10:37:03  profilanswer
Reçu ma Evga GTX680 OC+  :love:  petit photo comme promit instal revient après quelque benchs pour la faire chauffé  :pt1cable:
Je suis néerlandophone une fois
n°8336827
Alis_70
Posté le 04-06-2012 à 10:38:36  profilanswer
je connaissais folding@home, mais j'en profite pour réagir la dessus. Faire tourner ton pc et surtout une grosse CG (=consommer) pour quelqu'un d'autre j'ai un peu du mal. C'est pour la science j'ai envie de dire Ok, mais le coté classement "je fais plus de point que toi" je trouve ça complètement ridicule.
Message édité par Alis_70 le 04-06-2012 à 10:40:02
n°8336830
wnorton
Posté le 04-06-2012 à 10:38:55  profilanswer
Carte
Notice
DVD installation
Tu avais quoi ton problème avec ?
surement lu mais vue les différents souci me rappelle plus  [:bobflo]
n°8336842
mrdoug
Posté le 04-06-2012 à 10:46:46  profilanswer
Etant toujours dans la réflexion d'un éventuel changement de pateforme, je suis tombé sur ce test  :D
http://www.pcgameshardware.com/screenshots/original/2012/04/Test-Ivy-Bridge-DT-TES5-Skyrim1.png
 :cry:
n°8336844
lexx123
Posté le 04-06-2012 à 10:47:41  profilanswer
Carte
Notice
DVD installation
Moi la mienne je l'echange demain contre une 670 gtx giga oc ou je fait un crossfire avec ma 7970.J'en ai trop marre de ces problèmes.(stuttering, crash...)
n°8336846
Alis_70
Posté le 04-06-2012 à 10:49:32  profilanswer
http://www.pcgameshardware.com/scr [...] kyrim1.png
 :cry:
et ? c'est quoi le problème ?
n°8336847
cacahuete
Posté le 04-06-2012 à 10:49:33  profilanswer
Merci :jap:
n°8336849
sarrasin
Posté le 04-06-2012 à 10:52:17  profilanswer
Carte
Notice
DVD installation
bizarre moi j'ai aucun souci, vous avez dû bidouiller la carte pour avoir ces problèmes ?
Message édité par sarrasin le 04-06-2012 à 11:01:19
n°8336874
emeralfish
Posté le 04-06-2012 à 11:19:32  profilanswer
Asus Gtx 670 dc2 top reçue ce vendredi,
J'ai un peu testé ce week-end (principalement Diablo), quelques test 3Dmark, Unigine 3.0 et OCCT 3D pendant 1h.
Aucuns souçis rencontré, température max de 80° après 1h d'OCCT, et je n'ai pas remarqué d'effet de stuttering.
Etant donné que je n'ai pas BF3, il y a d'autres moyens de tester plus a fond la carte pour être sur qu'elle est 100% OK ?
Aussi pas d'OC, ni autre chose, juste installée dans le PC, et réinstallation des derniers drivers.
Pour ceux qui posaient la question 7.9 pt à l'indice Win7 avec ma GTX 570 et également 7.9 avec la 670  :jap:
Pour le moment très content de mon achat  :)
n°8336881
gta007
Posté le 04-06-2012 à 11:24:33  profilanswer
Non c'est pas un problème d'interface chaise clavier, j'en ai monté des cartes graphiques...
La carte est d'origine j'ai même pas touché au bios.
Par contre j'ai beaucoup joué a BF3 et le problème est assez sournois, tu peux jouer parfais sans problèmes 2h puis ça merde sans raisons. Tu baisse encore l'oc, puis ça remerde. Ainsi de suite... Et à la fin tu te dis que tu as une carte de merde :o et tu vois que t'es pas le seul. J'ai cherché aussi sur d'autres forums il y a des cas similaires.
Mon Feed-back
n°8336911
dennis3169
Posté le 04-06-2012 à 11:53:43  profilanswer
Dites vous avez pas des problèmes avec Max Payne 3 et la 3D Vision, parce que moi ça fait que de crasher.
Et pourtant j'ai aucun problème avec les autres jeux.
n°8336915
burnout62
Posté le 04-06-2012 à 11:58:13  profilanswer
C'est toi ça ? http://forums.nvidia.com/index.php?showtopic=230767
Sinon bah voilà :D .
Il va être noté 3D Vision Ready :
http://forums.nvidia.com/index.php?showtopic=230761
Message édité par burnout62 le 04-06-2012 à 11:59:14
n°8336919
dennis3169
Posté le 04-06-2012 à 12:01:08  profilanswer
 :lol: Non c'est pas moi, mais c'est exactement le même problème :
La mission 1 tout se déroule impec, la mission 2 c'est crash land ...
Du coup faut attendre des news drivers.
n°8336941
wnorton
Posté le 04-06-2012 à 12:34:30  profilanswer
Comme promit Actaruxs voilà 2 photos du Backplate, je confirme bien il ne touche pas les composants;)
il y a des entretoises plus un patch thermique niveau GPU.
http://i42.servimg.com/u/f42/16/92/14/13/p1070441.jpg
http://i42.servimg.com/u/f42/16/92/14/13/p1070442.jpg
Message édité par wnorton le 04-06-2012 à 12:35:22
n°8336961
neo4k
Posté le 04-06-2012 à 12:54:30  profilanswer
J'ai ouvert un topic sur le forum Asus ROG ...
Merci à ceux qui ont des problèmes de se référencer !
http://www.republic-of-gamers.fr/F [...] #post89476
n°8336985
wnorton
Posté le 04-06-2012 à 13:05:30  profilanswer
Voilà carte installer premier test 3Dmark2011 nickel en idle 36° full 68°, la fréquence GPU default clock 1059MHz maxi boost  1176 MHz, tout @ stock 3DMark2011 P 10509  :love:
http://i42.servimg.com/u/f42/16/92/14/13/3dm20111.jpg
n°8337024
KillGrin
Posté le 04-06-2012 à 13:22:56  profilanswer
J'ai reçu une Gigabyte Nvidia GTX 690 samedi dernière.
Elle fonctionne parfaitement bien dans Max Payne 3, Skyrim etc...
Mais je rencontre une problème sur Diablo 3:
Le jeu est super fluide (normal) mais parfois, pendant un changement de zone, l'ecran reste noir 2-3 seconde de plus et la carte graphique retourne au fréquense 2D.
Ce qui entraine 15-20 images par seconde juste après le chargement. Là j'ai ensuite 2 possibilitées :
1 - Alt/Tab + ouverture puis fermeture d'un programme/fichier + retour sur Diablo 3 = retour à la normal pendant X chargements.
2 - Je continue mais au prochain chargement j'ai droit à un plantage du jeux pur et simple avec parfois une message d'erreur disant que le driver à cessé de fonctionner.
Je pense que c'est sois le jeu sois les drivers, car j'ai pu jouer toute la journée à Skyrim et Max Payne sans aucun soucis. avez vous une idée de resolution ?
Message édité par KillGrin le 04-06-2012 à 13:25:36
n°8337027
Mseirco
Posté le 04-06-2012 à 13:26:19  profilanswer
Un SLI de 670 gtx --->4GB de VRAM<--- commence a me faire l'oeil. En remplacement de mon sli de 580 GTX qui consome plus et qui a surtout moin de VRAM.
Exciste t'il un model ASUS avec ventilard custom DCU 2 en version 4GB dans le commerce? ou au pire EVGA? Toujours avec 4Gb de VRAM!
Y'at'il un problem reconnu sur le SLI de 670 GTX? Comme stuttering ou autre bug majeur?
EDIT: pour un SLI, il serait mieux avoir des model ventilard d'origine qui expulse l'aire chaude a l'exterieur du boitier? Comme les evga SIGNATUR pars exemple? Mais avec model custom, les cartes chaufferont beaucoup moin non?
Message édité par Mseirco le 04-06-2012 à 13:32:32
n°8337031
renardin6
Nobody reads this
Posté le 04-06-2012 à 13:30:26  profilanswer
Des fois je me dis que j'ai été comme ça à une époque à poster des benchs et tout... et bordel, que de temps perdu... Get a life :) (je sais je vais me faire troller pour ça... ha ha)
n°8337035
estebadia
Cobra Space Adventure
Posté le 04-06-2012 à 13:35:52  profilanswer
quels reglages pour etre fluide en 1080p et en 3d sur max payne (670 oc inside) ?
https://robertsspaceindustries.com/ [...] eadventure |
n°8337037
dennis3169
Posté le 04-06-2012 à 13:38:27  profilanswer
Tu peux oublier la 3D sur Max Payne 3, le jeux crash
n°8337051
nass9500
Posté le 04-06-2012 à 13:55:40  profilanswer
j'ai vu que certain d'entre vous flasher leur gtx 6.
quelqu'un pourrais m'expliquer comment faire pour flasher sa Gtx 680 (une asus de ref) avec un bios avec des fréquences plus haute sans avoir à toujours jouer avec msi afterburner ou evga x précision.
Merci pour votre aide
n°8337053
estebadia
Posté le 04-06-2012 à 13:58:17  profilanswer
euh ma foi aucun crash chez moi (4 h de jeu)
même en 3d ou cela ramait c est tout (tout a fond)
n°8337078
kyky
Je suis newbie et alors,
Posté le 04-06-2012 à 14:25:56  profilanswer
Reçu aussi ma EVGA GTX680 SC signature . J'ai un Bins de moins que sur la gainward Phantom  :sweat: . Mais en contre parti la baisse de bins c'est a partir de 80° et non 70° comme sur la Gainward .J’attends plus que mon Wb. :D
Edit:
J'ai pas résisté a faire un test
3DMK11
en SLI
http://3dmark.com/3dm11/3582039
Seul
http://3dmark.com/3dm11/3581853
3DMK06
en SLI
http://3dmark.com/3dm06/16702771
Sous Heaven 3.0
87 Fps
Message édité par kyky le 04-06-2012 à 16:00:00
le progrès ne vaut que s'il est partage par tous.Ce que je vends
n°8337084
Mseirco
Posté le 04-06-2012 à 14:38:27  profilanswer
C'est les quels les models qui monte une backplate d'origine? asus DCU2? (NON TOP= et evga 670? (non superclocked)??
n°8337088
sarrasin
Posté le 04-06-2012 à 14:42:51  profilanswer
Résultats de ma Asus 670 Dcu II TOP + proc 2600K @4.6
http://3dmark.com/3dmv/4120536
n°8337089
Tomlechti
ID PSN : Tomlechti
Posté le 04-06-2012 à 14:43:44  profilanswer
Question conne : C'est quoi un "bins" ??
Ou comme dirait un célèbre personnage de film : "Mais qu'est-ce que c'est que ce Bins ?" [:presse papier]
Message édité par Tomlechti le 04-06-2012 à 14:45:26
n°8337090
Fouge
Posté le 04-06-2012 à 14:46:19  profilanswer
C'est 13MHz. De rien :o
n°8337113
Roth Welle​s
Posté le 04-06-2012 à 15:06:58  profilanswer
as-tu essayé de flasher en non Top et essayé de la faire tourner aux même fréquences que la Top, histoire de voir si ça n'est pas un simple problème de bios sur la Top qui fait planter certaines cartes comme la tienne ?
n°8337116
Roth Welle​s
Posté le 04-06-2012 à 15:09:16  profilanswer
KillGrin a écrit :
je crois qu'il y a des problèmes avec ce jeu, qui affecte les 6x0. Tu trouverais sans doute plus de réponse et de meilleures réponses sur un topic dédié au jeu, ici ou ailleurs.
n°8337122
Alis_70
Posté le 04-06-2012 à 15:16:08  profilanswer
comme si il y avait besoin de bidouiller une carte pour se retrouver avec un modèle défectueux.  [:airforceone]
n°8337130
estebadia
Posté le 04-06-2012 à 15:29:15  profilanswer
ma foi, vouloir augmenter l'OC de cartes deja bien OC c est une bidouille...
je ne comprendrais jamais le but d'acheter OC pour OC plus... pour gagner 3 fps et un gros zizi sur 3d mark ? :D
je bench, je teste, mais telle que sortie d usine.
Apres on lit "mouais kepler a un pb je comprends pas que ma TOP crash je l'ai juste un peu oc " ....
n°8337132
Tomlechti
ID PSN : Tomlechti
Posté le 04-06-2012 à 15:30:06  profilanswer
Voilà, ma GTX680 va aller retrouver son concepteur  :D
Je viens de la déposer à la poste.
Le plus chiant c'est le code postal de la ville où ça part ... La machine de la poste ne le connaît pas (celui dUPS non plus vous me direz  :D )
n°8337141
davids
Posté le 04-06-2012 à 15:38:38  profilanswer
pourquoi? elle est défectueuse?
n°8337149
wnorton
Posté le 04-06-2012 à 15:41:08  profilanswer
Edit:
en SLI
Seul
Sous Heaven 3.0
87 Fps
Tu devrais avoir plus avec ta signature normalement tu as 10170 en graphique  :heink:
n°8337150
Tomlechti
ID PSN : Tomlechti
Posté le 04-06-2012 à 15:41:31  profilanswer
Tomlechti a écrit :
Bon là je ne comprends absolument plus rien ...
J'ai réinstallé BF3, j'ai fait toutes les mises à jour et ... toujours pareil ...
Cette fois, j'ai réussi à faire des photos de ce problème :
http://i42.servimg.com/u/f42/12/02/51/28/p1010315.jpg
http://i42.servimg.com/u/f42/12/02/51/28/p1010316.jpg
Je ne sais plus quoi penser ...
A cela il faut rajouter un autre "bug" : Je joue quelques minutes et d'un coup il retourne sous Windows mais je suis obligé de passer par le CTRL+ALT+SUPPR pour ensuite arrêter le processus BF3 ...
Je précise que ce bug se matérialise après moins de 5 minutes de jeu.
Voilà pourquoi elle repart  :D  :cry:  :sweat:
J'ai envoyé les mêmes photos au SAV Zotac et ils m'ont dit qu'il semble que ma carte soit défectueuse
Message édité par Tomlechti le 04-06-2012 à 15:43:32
Concours Nvidia / questions sur les... questionsCartes Mères Z68 GIGABYTE, laquelle choisir ?
Panneau de configuration NVIDIA ?[HFR] Actu : 5 cartes A75 FM1 pour ASRock
Probleme aprés installation carte NVIDIA GEFORCE 8400 GS[HFR] Actu : Nvidia lance les GTX 580M et 570M
[HFR] Actu : 4 cartes Socket FM1 pour Gigabyte[Topic Unique] Problème pour mettre à jour sa carte réseau
Gestion des ventilateurs 3 pins avec les cartes mères P67Configuration MCP73VE NVIDIA MCP73
Plus de sujets relatifs à : [Topic Unique] NVIDIA GeForce GTX 660Ti/670/680/690/760/770 (GK104)
