4064 connectés
 Page :   1  2  3  4  5  ..  241  242  243  ..  624  625  626  627  628  629
[Topic-Unique] nVIDIA GeForce GTX 590/580/570 ** GF110 inside **
n°7762579
3rik
Casse-toi pauv' con
Posté le 20-01-2011 à 13:30:58  profilanswer
Dites, c'est quoi comme clé qu'il faut pour démonter la carte ? on dirait du torqx
VDS Signature 850W, Koss SB49, Ventilos ||| Feed-Back ||| Sauve toi, sauve moi, et tu sauras où l'acheter le courage
n°7762588
Ludovic036
Posté le 20-01-2011 à 13:34:59  profilanswer
Oui du torx de 6 ou 7
Mon Feed Back : http://forum.hardware.fr/hfr/Achat [...] 7108_1.htm
n°7762611
3rik
Casse-toi pauv' con
Posté le 20-01-2011 à 13:47:35  profilanswer
n°7762622
super_newb​ie_pro
A ta dispoition frère geek :P
Posté le 20-01-2011 à 13:52:53  profilanswer
Bonne nouvelle messieurs, en espérant que la consommation électrique sera moindre et qu'on puisse ENFIN, se battre à armes égales à ce sujet face aux conso/chauffe des cartes ATI sans que ce soit un élément pour les détracteurs :
Nvidia 28nm Geforce aims for Q4 2011
Nvidia is getting close to tape out its 28nm graphics core. The company is aiming to have a new chip in 28nm ready for autumn launch. The target time frame is Q4 2011 for the desktop chip and a bit later for the mobile one.
The chips are made by Nvidia's long term partner, TSMC, so there are no surprises there. TSMC is already taping out some 28nm network chips but graphics chips are far more complex and have billions of transistors these days. It might take them a bit more to get ready for billion(s) transistors graphics cards.
AMD (ATI) graphics is also making its 28nm chips at TSMC and unfortunately for them, Nvidia always gets more love. The specification wars are no on, as both companies have thermal limitations to heed, and as you all know, it is very important to end up at least slightly faster.
The real fight is scheduled for Q4 2011, asuming that both companies can execute flawlessly.
source ; http://www.fudzilla.com/graphics/i [...] or-q4-2011
Message édité par super_newbie_pro le 20-01-2011 à 13:53:32
~ Camping thématique LA RESSOURCE sur l'autonomie ~
n°7762627
wolfflyter
Posté le 20-01-2011 à 13:54:57  profilanswer
C'est pas lié aux performances ?  :??:
該反思的是,往往有幫助
n°7762631
kikou2419
Posté le 20-01-2011 à 13:57:14  profilanswer
Q4 c'est le dernier trimestre, c'est bien ça ?
Mouai enfin même en 28 nm ils peuvent faire une puce chauffant énormément, suffit de rajouter les transistors nécessaires xD
Moi je change pas avant un moment maintenant.. Peut être une 2e gtx 580 d'occaz pour Noël ^^
TU Nvidia Shield Android TV
n°7762634
buffo
Redfarceur :o
Posté le 20-01-2011 à 14:00:15  profilanswer
On parle de finesse de gravure, donc il s'agit d'organiser correctement le die pour les ingénieurs, la performance dépend de l'organisation du die (nombre de transistors, etc), qui dépend de la finesse, enfin je pense que c'est ça.
On peut voir si une femme est vraiment belle, le matin, quand elle se réveille
n°7762703
newcat
Posté le 20-01-2011 à 14:31:47  profilanswer
Bah la  finesse de gravure s'est  toujours transformée en + de transistors pour plus de boulot  :whistle:  et comme il n' ya pas de miracle en physique   >>>  puissance =  energie calorifique a dissiper   :D
 [:aia]
Rien n'est vrai... mais tout est bien expliqué !!!
n°7762714
wolfflyter
Posté le 20-01-2011 à 14:41:40  profilanswer
 [:aia]
 :D http://www.evilspacerobot.com/evil [...] watson.png
該反思的是,往往有幫助
n°7762913
Nowa
XOXO
Posté le 20-01-2011 à 17:07:31  profilanswer
Ma PNY 570 est arrivée ce matin...
C'est des rats chez PNY , je pensais avoir Hawx 2 en bundle , et que dalle en fait [:zytrasnif]
n°7762916
buffo
Redfarceur :o
Posté le 20-01-2011 à 17:08:36  profilanswer
Non mais depuis quelques années les bundles c'est pourri [:ocolor]
n°7762929
chris_san
˙ʇɥƃıɹ ǝʇınb ʇou sı ƃuıɥʇǝɯoS
Posté le 20-01-2011 à 17:12:51  profilanswer
Dans ce cas toutes les marques sont des rats. :D
Message édité par chris_san le 20-01-2011 à 17:13:50
.: FEED-BACK :.      .: Topic Achats/Ventes :.
n°7762943
Nowa
XOXO
Posté le 20-01-2011 à 17:19:23  profilanswer
Certains ont quand même des bundle mieux que d'autres [:thalis]
Message édité par Nowa le 20-01-2011 à 17:19:34
n°7762951
3rik
Casse-toi pauv' con
Posté le 20-01-2011 à 17:21:54  profilanswer
Moi aussi j'aurai keudal avec ma Zotac :cry:
Message édité par 3rik le 20-01-2011 à 17:22:03
n°7762956
buffo
Redfarceur :o
Posté le 20-01-2011 à 17:26:07  profilanswer
Pareil chez MSI  [:prodigy]
n°7762995
3rik
Casse-toi pauv' con
Posté le 20-01-2011 à 17:50:29  profilanswer
Au fait, aux watercooleurs... ça se monte bien le EK GTX 570/580 ? Ou y'a des cales comme pour la 480 ?
n°7763071
seu
M 41
Posté le 20-01-2011 à 18:27:48  profilanswer
ça se monte bien , c'est presque le même pareil que le WB de 480 , et ça se monte encore mieux avec  avec une backplate.
n°7763095
3rik
Casse-toi pauv' con
Posté le 20-01-2011 à 18:38:40  profilanswer
Merci seu,
Donc pas de soucis de vis trop longues/trop courtes toussa ?
Faut toujours intercaler des rondelles en PVC entre le PCB et le WB ?
Message édité par 3rik le 20-01-2011 à 18:40:25
n°7763109
lamedor31
Posté le 20-01-2011 à 18:45:47  profilanswer
Toujours ;)
Ma Config
n°7763114
3rik
Casse-toi pauv' con
Posté le 20-01-2011 à 18:47:13  profilanswer
Comme mon EK 5850 quoi, c'est un peu la misère, faut pas que les rondelles bougent au montage :D
C'est spécifique à EK ou bien ?
n°7763124
lamedor31
Posté le 20-01-2011 à 18:53:35  profilanswer
Oui spécifique à ek et peut être à d'autres marques.
J'ai moi aussi monté un wb 5850, 5970, et 3*470 et c'était pareil.
Ma Config
n°7763125
3rik
Casse-toi pauv' con
Posté le 20-01-2011 à 18:54:41  profilanswer
:jap: :)
Bon alors je tenterai d'être précis dans mes gestes :D
n°7763132
lamedor31
Posté le 20-01-2011 à 18:58:52  profilanswer
Bah c'est pas compliqué, à la limite moi ce qui m'ennuie le plus c'est la découpe des pads :D
Pour les rondelles, je retourne le wb posé sur une table, je place les rondelles autour des trous, le pcb ayant les pads et la pate thermique je l'aligne avec les trous du wb, je le place correctement et je visse c'est tout.
Ma Config
n°7763145
3rik
Casse-toi pauv' con
Posté le 20-01-2011 à 19:05:12  profilanswer
C'est vrai que c'est chiant le découpage des pads :D
J'avais fait exactement comme toi pour le montage ! (wc newbie inside  :whistle:  )
n°7763156
lamedor31
Posté le 20-01-2011 à 19:07:32  profilanswer
Bah je vais démonter 3wb de 470 ce week end ça va m'occuper ^^
Car je passe sur un sli de gtx580 :love:
Ma Config
n°7763188
3rik
Casse-toi pauv' con
Posté le 20-01-2011 à 19:23:01  profilanswer
Pareil, dès que j'ai des sousous, je lui achète sa petite soeur à ma (future) 580 :love:
Tu revends donc tes CG remontées avec le rad d'origine, et les WB à part ?
n°7763194
lamedor31
Posté le 20-01-2011 à 19:27:16  profilanswer
Bah un peu de tout partout ^^
J'ai vendu une 470+2*wb à le_chacal, une 470 à 007sivade, un wb à rarmonix et enfin une 470 en mp à zuluoscar.
Ma Config
n°7763199
buffo
Redfarceur :o
Posté le 20-01-2011 à 19:28:27  profilanswer
Peut être mais en l’occurrence on parle des GTX500 ici [:ocolor]
n°7763200
3rik
Casse-toi pauv' con
Posté le 20-01-2011 à 19:28:37  profilanswer
T'as de la veine, moi mes 5850 partent pas, j'en veux peut-être un peu trop cher (le CF Watercoolé d'XFX 5850 Black Edition => 380€)
n°7763204
lamedor31
Posté le 20-01-2011 à 19:30:07  profilanswer
Bah moi vu que j'ai voulu que ça parte vite, une 470 à 160in ça attire du monde ^^
Ma Config
n°7763210
3rik
Casse-toi pauv' con
Posté le 20-01-2011 à 19:33:05  profilanswer
Ah vi :D
Je reverrai le prix dès lors que mes 5850 seront libres :)
n°7763211
3rik
Casse-toi pauv' con
Posté le 20-01-2011 à 19:34:06  profilanswer
Oui, à bas Amerdé  :whistle:
n°7763217
buffo
Redfarceur :o
Posté le 20-01-2011 à 19:37:12  profilanswer
[:juanmartin:3]
Tu as deux choix pour cette erreur capitale: la mort... Ou le tchi tchi... :whistle:
n°7763219
3rik
Casse-toi pauv' con
Posté le 20-01-2011 à 19:38:31  profilanswer
Je choisis le tchi tchi, je veux profiter de ma 580 :o
n°7763342
XJ5
Posté le 20-01-2011 à 20:37:46  profilanswer
Prince of Persia : Les Sables Oubliés normalement...  [:spamafoote]
n°7763510
GRC92
Posté le 20-01-2011 à 21:37:18  profilanswer
Bonsoir,
J'ai un problème : quand je lance le package 3d vision Version 1.45, la version 2.66 des drivers ne reconnait pas ma 580. De plus, en décompressant il est noté comme : NVIDIA_3D_Vision_Notebook_CD_v1.38_WHQL_International
Avez-vous eu ce problème?
J'ai téléchargé sur le site NVIDIA.
Merci pour vous réponses.
n°7763561
Dugom
Posté le 20-01-2011 à 22:01:26  profilanswer
Tu dois avoir le mauvais driver, il y a un driver Notebook (PC portable) et Desktop (PC fixe), nVidia a du se mélanger les pinceaux, car j'ai moi aussi téléchargé la version Notebook...
Installe ceux-là driver GPU Desktop:
http://fr.download.nvidia.com/Wind [...] l_whql.exe
et driver émetteur: celui-là tu dois déjà avoir le même.
http://www.nvidia.fr/object/geforc [...] er-fr.html
Message édité par Dugom le 20-01-2011 à 22:07:47
n°7763573
GRC92
Posté le 20-01-2011 à 22:05:55  profilanswer
Merci pour l'info. J'essaie tout de suite!
[Topic Unique] Lian Li PC-V1020[Topic Unique] IN WIN Dragon Slayer
[topic unique] Shuttle XPC SH55J2[Topic Unik] boitier PCHC Antec fusion / micro / max / nsk1480 & 2480
[Topic Unique] J&W Minix 890GX-USB3 [Mini-ITX][Test][Topic unique] Samsung Ecogreen F4 - 2 To (HD204UI)
[Topic unique] Cooler Master HAF 912 Plus[TOPIC UNIQUE] Asus Rampage 3 formula
[Topic Unique] Fractal Design Define R6 / R5 / R4 / R3
Plus de sujets relatifs à : [Topic-Unique] nVIDIA GeForce GTX 590/580/570 ** GF110 inside **
