2872 connectés
Fréquences + type de vos m.à.j.
Sondage à 2 choix possibles.
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  973  974  975  ..  1017  1018  1019  1020  1021  1022
[Topic Unique] Radeon™ Software Adrenalin 2020 Edition ● CG & APU !
n°11235620
BloodyCarn​age
Posté le 30-03-2023 à 18:20:45  profilanswer
J'imagine qu'ils se disent que la bande passante ne coûte pas cher de nos jours, ou que c'est pire chez nvidia.
Nothing's so bad it can't get worse
n°11235650
Col Hanzap​last
Jurassic geek. Vive le cobol !
Posté le 30-03-2023 à 19:21:44  profilanswer
"The Last of Us" est sponsorisé par AMD et fourni en cadeau pour l'achat d'une 6000 ou 7000: https://www.amd.com/fr/gaming/last- [...] source=301
" Il n'y a aucune chance pour que l'iPhone s'attribue une part de marché significative. Aucune chance. " (Steve Ballmer 2007)
n°11236870
Col Hanzap​last
Posté le 04-04-2023 à 08:51:21  profilanswer
AMD Software: Adrenalin Edition 23.4.1 Release Notes
Highlights
    Support for:
        Meet Your Maker™
    Game optimizations for The Last of Us™ Part 1
Fixed Issues
    Video playback in browsers using hardware acceleration may appear blurry on some AMD Graphics Products, such as the Radeon™ RX 7900 XT.
    Mouse cursor may appear invisible in Citrix Workspace™.
    Performance Metrics Overlay may intermittently disappear when playing full-screen videos from STEAM™.
Known Issues
    High idle power has situationally been observed when using select high-resolution and high refresh rate displays on Radeon™ RX 7000 series GPUs.
    Video stuttering or performance drop may be observed during gameplay plus video playback with some extended display configurations on Radeon™ RX 7000 series GPUs.
    Some virtual reality games or apps may experience lower-than-expected performance on Radeon™ RX 7000 series GPUs.
    Brief display corruption may occur when switching between video and game windows on some AMD Graphics Products, such as the Radeon™ RX 6700 XT.
    Water corruption in Hogwarts Legacy™ may occur on some AMD Graphics Products, such as the Radeon™ RX 580.
    Blocky water corruption in Red Dead Redemption 2™ may occur using Vulkan® API.
Important Notes
    Factory Reset has been temporarily disabled as a precautionary measure while we address isolated installation issues that have been reported during PC upgrades. Users may use AMD Cleanup Utility as a temporary option.
Package Contents
AMD Software: Adrenalin Edition 23.4.1 Driver Version 22.40.43.07 for Windows® 10 and Windows® 11 (Windows Driver Store Version 31.0.14043.7000).
n°11236965
Bordel
Bordel !!!
Posté le 04-04-2023 à 15:12:24  profilanswer
C'était pas déjà le cas lors de la dernière maj?
n°11236974
It_Connexi​on
Posté le 04-04-2023 à 15:36:47  profilanswer
"Mouse cursor may appear invisible in Citrix Workspace™"
J'ai ça sur HFR typiquement
Galerie Photo Personnelle
n°11236975
wazany
Posté le 04-04-2023 à 15:37:31  profilanswer
Je l'avais avant de faire la maj je l'ai plus mais ca revient selon les drivers
n°11236977
It_Connexi​on
Posté le 04-04-2023 à 15:41:47  profilanswer
le coup du curseur ? Mince je l'ai sur la 6800 et la 6950XT malgré le différentes MAJ de pilotes, bon après on m'a donné une solution encore plus simple que je n'ai pas encore appliquée : passer le curseur en noir  :D
n°11237004
wazany
Posté le 04-04-2023 à 16:49:21  profilanswer
Ah rioen dit sur la reponse rapide j'ai bien le curseur mais pas sur l'autre type de reponse
n°11237005
It_Connexi​on
Posté le 04-04-2023 à 16:49:50  profilanswer
n°11237078
wazany
Posté le 04-04-2023 à 22:30:30  profilanswer
j'ai fais une clean install car j'avais des soucis dans mes jeux (blouque a 2 fps :o) et maintenant je revois le curseur
n°11237122
clement150​382
Posté le 05-04-2023 à 09:22:49  profilanswer
Tu peux également désactiver l'accélération matériel sur les logiciels qui posent problème ;)
Je n'ai plus le souci depuis que je l'ai fait sur Outlook, Chrome et Thunderbird.
n°11237123
chrisleurn
Hardcore Will Never Die !
Posté le 05-04-2023 à 09:27:10  profilanswer
1 coup j'ai le bug, 1 coup je l'ai plus, la avec les 23.3.2, je l'ai pas  :D
n°11237133
It_Connexi​on
Posté le 05-04-2023 à 10:10:52  profilanswer
n°11241656
Col Hanzap​last
Posté le 21-04-2023 à 09:09:50  profilanswer
Adrenalin Edition 23.4.2 Release Notes
Highlights
    Support for:
        Dead Island 2™
            Up to 14% increase in performance in Dead Island 2™ @ 4k, using AMD Software: Adrenalin Edition™ 23.4.2 on the Radeon™️ RX 7900 Series GPUs, versus the previous software driver version 23.4.1 RS-556
            Up to 15% increase in performance in Dead Island 2™ @ 4k, using AMD Software: Adrenalin Edition™ 23.4.2 on the Radeon™️ RX 6000 Series GPUs, versus the previous software driver version 23.4.1 RS-557
        Boundary™
        Additional Vulkan® extensions. Click here for more information.
Fixed Issues
    Blocky water corruption may occur in Red Dead Redemption 2™ when using the Vulkan® API.
    Missing text or a white disk may appear in Google Earth VR™.
    Application crashes may be intermittently observed after enabling the render preview window in Unreal Engine 5™.
    A blank or black screen may occur after a driver upgrade using certain display configurations.
Known Issues
    Video stuttering or performance drops may be observed during gameplay and video playback with some extended display configurations on Radeon™ RX 7000 series GPUs.
    Some virtual reality games or applications may experience lower-than-expected performance on Radeon™ RX 7000 series GPUs.
Important Notes
Package Contents
AMD Software: Adrenalin Edition 23.4.2 Driver Version 22.40.51.01 for Windows® 10 and Windows® 11 (Windows Driver Store Version 31.0.14051.1000).
n°11243644
Col Hanzap​last
Posté le 28-04-2023 à 01:16:20  profilanswer
Adrenalin Edition 23.4.3 Release Notes
Highlights
    Support for:
        STAR WARS Jedi: Survivor™
Fixed Issues
    Red corruption may occur in World War Z™: Aftermath when using the Vulkan® API.
    Longer than expected shader compilation time when first launching THE LAST OF US™ Part I.
Known Issues
    Application crash may be intermittently observed while playing RuneScape™ on some AMD Graphics Products, such as the Radeon™ RX 5700 XT.
Important Notes
    AMD is working with the game developers of Hogwarts Legacy™ to resolve issues with water corruption on some AMD Graphics Products, such as the Radeon™ RX 580.
Package Contents
AMD Software: Adrenalin Edition 23.4.3 Driver Version 22.40.51.05 for Windows® 10 and Windows® 11 (Windows Driver Store Version 31.0.14051.5006).
n°11245956
Col Hanzap​last
Posté le 06-05-2023 à 19:32:37  profilanswer
Je suis en train de tester la migration Seven vers Win10. J'ai bien fixé le système pour qu'il ne m'installe pas les drivers Microsoft de son goût.
Je vise radeon-software-adrenalin-2020-22.6.1-win10-win11-64bit-legacyasics-june23-2022-legacy.exe pour une R9 280X.
J'ai bien perdu une après-midi avant de me rappeler que l’installateur d’Adrénaline n'installe rien si on coche la case "Paramètres d'usine" !
[:roger21:1]
n°11246370
Tigrou
Sans accroc
Posté le 08-05-2023 à 19:23:40  profilanswer
Bonsoir ici :)
J'ai un souci de driver je pense. Je m'explique: quand je laisse mon PC allumé avec Firefox lancé, parfois quand je reviens la machine est plantée. Il me semble que c'est depuis 1 jour ou 2, quand j'ai updaté mon driver; je suis passé du 21.10.2.0 -beta mais qui marchait très bien pendant près d'un an et demie- au dernier WHQL à
ce jour; le 23.4.3.0.
Je me suis dit que peut-être le GPU "s'endormait" un peu trop et que si je fixais une fréquence un petit peu plus élevée que "0 MHz" en idle les crashs ne se produiraient plus. Donc je suis allé dans le panneau de contrôle et j'ai remarqué que je ne pouvais pas le faire, c'est-à-dire que je fais bien le réglage
(par exemple je mets 600 MHz et je valide bien sûr) mais en contrôlant avec GPU-Z par exemple la fréquence reste à zéro :??:
Donc je me dis que ça vient peut-être de là. Qu'en pensez-vous?
PS: j'ai maintenant activé l'accélération matérielle de Firefox, on verra si ça va mieux..
PPS: re-crash sans Firefox cette fois-ci, en idle pendant que j'écoutais de la musique. Ça pue cette histoire :sweat:
Demain je tenterai de repasser sous le driver précédent, on verra bien :/
Message édité par Tigrou le 08-05-2023 à 20:12:51
Feedback - Stacy's mom
n°11246384
BloodyCarn​age
Posté le 08-05-2023 à 20:21:07  profilanswer
En dehors du fait que t'as mis à jour le driver quelques jours avant les plantages, rien n'indique de ton problème vient de la CG.
T'aurais poussé l'UV du CPU un peu trop loin que ça ne m'étonnerait pas.
n°11246453
Tigrou
Sans accroc
Posté le 09-05-2023 à 09:28:43  profilanswer
Si seulement ça pouvait n'être que ça.. :sweat:
Mais dans l'UEFI le seul paramètre que j'ai touché est celui de la RAM où j'ai activé son profil XMP. Tout le reste est par défaut; CPU comme GPU.
Je pense à la CG parce qu'à un moment où j'ai eu un crash, le panneau de config du driver ne voulait plus apparaître quand j'ai voulu y accéder et il y a eu un message d'erreur du style "Le pilote a été remplacé par windows, bla-bla-bla..." (je ne me souviens pas du message exact).
Et GPU-Z ne m'indiquait plus que 3 ou 4 courbes, au lieu des 14 habituelles (comme quand on n'a pas de driver installé quoi..).
Je vais essayer de revenir au driver précédent pour voir :pfff:
Message édité par Tigrou le 09-05-2023 à 09:44:11
n°11247706
wazany
Posté le 14-05-2023 à 15:24:45  profilanswer
C'etait ce message
https://cdn.discordapp.com/attachments/723237706288857141/1107297001487487056/image.png
Car ca va faire 2 fois que ca me le fais, c'est apparut apres vouloir etendre mon ecran ou j'ai eu un plantage des driver je reboot et j'ai ca
n°11247712
Tigrou
Sans accroc
Posté le 14-05-2023 à 16:06:59  profilanswer
Oui il me semble bien, à part que c'était en français me semble-t-il..
J'aurais dû prendre un screenshot [:transparency]
Tu as quelle version du driver toi?
C'est dingue ça; je passe plus d'un an avec un driver en beta et pas un problème rien du tout, et là quand je passe sous un WHQL j'ai des crashes [:tinostar]
J'aimerais tester sans laisser le GPU descendre à 0 MHz en idle pour voir mais je n'y arrive pas. Même quand je règle une fréquence minimum dans le panneau de contrôle ça redescend quand même à 0 quand je ne touche plus à rien :pfff:
Message édité par Tigrou le 14-05-2023 à 22:47:48
n°11247715
Col Hanzap​last
Posté le 14-05-2023 à 16:15:32  profilanswer
Il faut choisir NON dans cette fenêtre pour que Windows ne remplace pas les drivers par ceux de son choix.
https://i.postimg.cc/mgg9GNX8/Parametres-Installation-Peripheriques.jpg
n°11247717
wazany
Posté le 14-05-2023 à 16:16:51  profilanswer
j'ai les 23.4.3. Mais je pense que c'est plus windowb qui chie dans la colle la car il est pas cense dl des nouveau driver de lui meme
n°11247720
wazany
Posté le 14-05-2023 à 16:23:45  profilanswer
@Col oui j'avais vue ca mais moi j'ai un soucis
https://media.discordapp.net/attachments/723237706288857141/1107312184398196877/image.png
 :pt1cable:
n°11247725
Tigrou
Sans accroc
Posté le 14-05-2023 à 16:37:47  profilanswer
Moi aussi c'est ceux-là que j'ai.. [:transparency]
n°11247739
It_Connexi​on
Posté le 14-05-2023 à 17:38:49  profilanswer
https://media.discordapp.net/attach [...] /image.png
 :pt1cable:
Tu es sur un pc pro ?
n°11247743
wazany
Posté le 14-05-2023 à 17:44:11  profilanswer
Nop
n°11247745
It_Connexi​on
Posté le 14-05-2023 à 17:44:50  profilanswer
Tu es sur ton pc perso ?? Tu es sur un domaine ?
n°11247748
wazany
Posté le 14-05-2023 à 17:46:46  profilanswer
pc perso et aucun domaine je suis admin quand je regarde mon compte
n°11247750
It_Connexi​on
Posté le 14-05-2023 à 17:52:20  profilanswer
ça m'en bouche un coin la :D
n°11247807
BloodyCarn​age
Posté le 14-05-2023 à 21:35:52  profilanswer
Certaines applis de bidouille pour désactiver des spywares et autres services douteux reposent sur des clés de registres qui sont elles-mêmes utilisées par des GPO. Du coup, windows peut avoir l'impression que certaines GPO ont été activées, d'où le message.
Message édité par BloodyCarnage le 14-05-2023 à 21:36:11
n°11250136
Col Hanzap​last
Posté le 25-05-2023 à 00:07:54  profilanswer
AMD Software: Adrenalin Edition 23.5.1 Release Notes
Highlights
    Support for:
        The Lord of the Rings: Gollum™
            Up to 16% increase in performance in The Lord of the Rings: Gollum™ @ 4k, using AMD Software: Adrenalin Edition™ 23.5.1 on the Radeon™️ RX 7900 Series GPUs, versus the previous software driver version 23.4.3 RS-577
            Up to 12% increase in performance in The Lord of the Rings: Gollum™ @ 4k, using AMD Software: Adrenalin Edition™ 23.5.1 on the Radeon™️ RX 6000 Series GPUs, versus the previous software driver version 23.4.3 RS-578
Fixed Issues
    Application crash or driver timeout may be observed during video playback using DaVinci Resolve™ Studio.
    Higher than expected memory usage during shader compilation time when first launching THE LAST OF US™ Part I.
    Intermittent system crash while playing Call of Duty®: Modern Warfare® II on some AMD Graphics Products, such as the Radeon™ RX 580.
Known Issues
Important Notes
Package Contents
AMD Software: Adrenalin Edition 23.5.1 Driver Version 22.40.57.02 for Windows® 10 and Windows® 11 (Windows Driver Store Version 31.0.14057.2005).
n°11250229
Gimli Oake​nshield
Pro lurker since 2007 ™
Posté le 25-05-2023 à 11:33:41  profilanswer
Col Hanzaplast a écrit :
Fixed Issues
Ca c'est cool, c'était bien relou  :jap:
n°11250267
wazany
Posté le 25-05-2023 à 13:41:21  profilanswer
Ça ressemble à mon problème j'avais du couper un écran lancer discord sur navigateur et virer les shaders et ça semble tenir donc là je vais tester sans faire tout ca
n°11250289
alriad
ST Power, Makes it Possible
Posté le 25-05-2023 à 14:39:56  profilanswer
    Support for:
FAudrait déjà qu'il soit sorti.. Ce matin il etait pas dispo.. (j'ai toujours pas eu ma clé..)
Message édité par alriad le 25-05-2023 à 14:40:28
Que la force soit avec Moi... (Attention avec votre sabre laser, vous pourriez vous blesser..)
n°11250293
havoc_28
Posté le 25-05-2023 à 14:43:50  profilanswer
alriad a écrit :
Faudrait déjà qu'il soit sorti.. Ce matin il etait pas dispo.. (j'ai toujours pas eu ma clé..)
Ils sont bien dispo sur le site d'AMD ? C'était peut être pas le cas ce matin oui. Les 7600 sont normalement censés être disponible à l'achat aujourd'hui dans l'après midi un truc du genre ? :o.
Message édité par havoc_28 le 25-05-2023 à 14:46:34
n°11250296
alriad
Posté le 25-05-2023 à 14:48:06  profilanswer
Je parlais de Gollum  ;)
n°11250299
havoc_28
Posté le 25-05-2023 à 15:03:17  profilanswer
Les pilotes optimisés sortent souvent 2/3 jours avant la sortie officielle du dit jeu, donc tout va bien.
n°11250520
Col Hanzap​last
Posté le 26-05-2023 à 09:44:09  profilanswer
https://www.techpowerup.com/forums/attachments/1685087068626-png.297621/
https://www.techpowerup.com/forums/attachments/gollum-jpg.297581/
Message édité par Col Hanzaplast le 26-05-2023 à 09:46:40
n°11250529
alriad
Posté le 26-05-2023 à 10:11:04  profilanswer
Gollum avec un  i5 13500 et 6700XT
en 2560 * 1440 87 ips en elevé. et 62 si RT activé.
Donc ca tourne plutot bien.
n°11250677
shinji3rd
Posté le 26-05-2023 à 22:08:49  profilanswer
Known Issues
Un peu pénible, marre de brancher mon deuxième écran sur l'igpu pour pas pomper 90W+  :o
ATI - Problème avec les CATALYST 3.5 +Question concernant ATI 9800 Pro avec HP80A : chaud brulant !!!!!
Probleme Hydravison et ATIAti Radeon 9600 Pro > Gigabyte HIS Saphire ou Club 3D ?
[Topic Unique] ASUS P4C800 / P4P800 (Intel i865/i875)les CG ATI 9xxx les + o/cables , quelle marque ?
Performance des differentes cartes ATI et Nvidia ??LEADTEK A 360 FX 5700 ou ATI 9600 PRO ?
Plus de sujets relatifs à : [Topic Unique] Radeon™ Software Adrenalin 2020 Edition ● CG & APU !
