8783 connectés
Fréquences + type de vos m.à.j.
Sondage à 2 choix possibles.
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  961  962  963  ..  1017  1018  1019  1020  1021  1022
[Topic Unique] Radeon™ Software Adrenalin 2020 Edition ● CG & APU !
n°11132734
stefostef
Posté le 29-06-2022 à 12:22:16  profilanswer
Les  22-5-2 sont sortis le 27/06  je les avait pas  dans la notification de mise à jour en gros même chose que les  22.5.1 avec encore un gain supplémentaire de 8% sur les vieux jeux DX11 comparativement aux  22.5.1
https://www.amd.com/en/support/kb/r [...] win-22-5-2
Nano Torrent 12600K Biostar B660GTN 32go 3600cs16  Red dragon 6800XT MATEVIEW GT 34 Win 11
n°11132875
wazany
Posté le 29-06-2022 à 20:15:28  profilanswer
pas le temps de niaiser voila les 22.6.1
Highlights
Support for F1 2022™
Up to 5% increase in performance in F1 2022 @ 4k Ultra High settings, using AMD Software: Adrenalin Edition 22.6.1 on the Radeon™️ RX 6950 XT, versus the previous software driver version 22.5.2 RS-486
Up to 4% increase in performance in F1 2022 @ 4k Ultra High settings, using AMD Software: Adrenalin Edition 22.6.1 on the Radeon™️ RX 6800 XT, versus the previous software driver version 22.5.2 RS-487
Up to 6% increase in performance in F1 2022 @ 4k Ultra High settings, using AMD Software: Adrenalin Edition 22.6.1 on the Radeon™️ RX 6750 XT, versus the previous software driver version 22.5.2 RS-488
Fixed Issues
Performance drop may be experienced while playing Fortnite™ with Multithreaded Rendering and DirectX® 11 API on some AMD Graphics Products such as the Radeon™ RX 6900 XT.
Stuttering may be experienced while playing Overwatch™ with some AMD Graphics Products such as the Radeon™ RX 6700 XT.
Higher than expected CPU usage when Instant Replay is enabled on some AMD Graphics Products such as the Radeon™ RX 6900 XT.
Fan Tuning option may be missing on some AMD Graphics Products such as the Radeon™ RX 590.
https://www.amd.com/en/support/kb/r [...] win-22-6-1
n°11134933
Col Hanzap​last
Jurassic geek. Vive le cobol !
Posté le 10-07-2022 à 18:09:02  profilanswer
C'est moi ou les drivers 6900XT pour Seven64 ne sont plus legacy ?! En une minute j'ai fait un bon d'un an...  :lol:
https://www.amd.com/en/support/kb/r [...] 2-6-1-win7
https://i.postimg.cc/9M9cBLmB/6900-XT-02-05-21-28-4-22.png
Message édité par Col Hanzaplast le 10-07-2022 à 18:11:43
" Il n'y a aucune chance pour que l'iPhone s'attribue une part de marché significative. Aucune chance. " (Steve Ballmer 2007)
n°11134934
Posté le 10-07-2022 à 18:14:19  answer
D'un autre côté, une licence W7 EST une licence W10 ..
n°11134959
Lermite
Posté le 10-07-2022 à 19:15:17  profilanswer
https://i.postimg.cc/9M9cBLmB/6900- [...] 8-4-22.png
Les mises à jour pour Windows 7 semblent à la traîne par rapport à celle pour Windows 10:
https://zupimages.net/up/22/27/xsge.png
n°11135131
wazany
Posté le 11-07-2022 à 14:20:07  profilanswer
D'un côté Windows 7 voilà quoi :o
n°11135176
Posté le 11-07-2022 à 16:58:41  answer
Oui, sachant que la migration 7>10 fonctionne toujours, gratuitement ..
Je l'ai pratiquée ce week-end :jap:
n°11135186
Col Hanzap​last
Posté le 11-07-2022 à 17:26:44  profilanswer
Avec Win11 ma R9 280X a aussi fait un bon...
https://i.postimg.cc/Kj7cxRNw/R9280-X-11-05-21-28-4-22.png
n°11135196
Col Hanzap​last
Posté le 11-07-2022 à 17:41:24  profilanswer
Aucune de mes cartes mères n'est compatible Win11. J'installe donc Win10 avec ma clef Seven64 puis je force la migration Win10 -> Win11 avec un utilitaire ad-hoc. Ensuite je passe un coup de WPD pour virer la télémétrie.
n°11135203
Lermite
Posté le 11-07-2022 à 18:28:45  profilanswer
Mes deux PCs sont voués à rester sur Windows 10 indéfiniment.
L'un a une config trop vielle/modeste pour avoir quoi que ce soit compatible avec Windows 11.
L'autre plus musclé bloque seulement à cause de son Ryzen 1700 auquel il manquerait je ne sais plus quelle fonctionnalité donc osef Windows 11 pour lui aussi.
n°11135208
hisvin
Posté le 11-07-2022 à 18:46:21  profilanswer
Juste la puce de sécurité. Je crois qu'on peut la rajouter ou faire croire au système d'installation qu'elle est en place. De toute manière, W10 n'est pas encore sur la voie de garage donc il n'est pas nécessaire de stresser.
Message édité par hisvin le 11-07-2022 à 18:47:06
n°11135945
bluehangel
Posté le 14-07-2022 à 17:20:37  profilanswer
https://www.touslesdrivers.com/inde [...] _code=8362
Alors que les drivers Radeon Adrenalin Edition 21.5.2 WHQL de juin 2021 devaient normalement être les derniers à supporter le système d'exploitation Windows 7, un an plus tard, AMD est revenu sur sa décision et vient de publier une nouvelle mise à jour pour ce vieux système qui n'est, pour rappel, plus supporté par Microsoft depuis janvier 2020 mais qui continue d'être utilisé par quelques rares gamers.
Ces nouveaux drivers AMD Radeon Software Adrenalin 2020 Edition pour Windows 7 sont numérotés 22.6.1 mais il ne faut pas se faire d'illusions car ils ne sont pas basés sur la toute dernière branche 22.10 du printemps 2022 mais sur une vieille branche 21.20. D'ailleurs, le fichier INF est daté du 17/06/2021 et le pilote a été signé WHQL le 25/06/2021. Bref, ce pilote est resté rangé à prendre la poussière dans un tiroir pendant une année avant qu'AMD se décide à le publier !
Qu'est-ce qui a donc motivé AMD pour proposer une nouvelle mise à jour pour Windows 7 ? D'après les notes de version du pilote 22.6.2, il est uniquement question de la correction d'un problème d'installation des drivers de certains GPU avec Seven comme le Radeon RX 6900 XT. A priori c'est tout. Toutefois, vues les différences de numérotation entre les précédents drivers 21.5.2 (21.09.03.08) et 22.6.2 (21.20.01.14), il est probable que plusieurs autres optimisations soient présentes.
Ces drivers 22.6.1 supportent les cartes graphiques des familles Radeon RX 400/500, Radeon RX Vega, Radeon RX 5000 mais aussi Radeon RX 6000. Vue la date interne de ce pilote (juin 2021), tous les GPU Navi 2X sortis depuis cette époque ne sont bien évidemment pas supportés. On pense notamment aux modèles Radeon RX 6650 XT/6750 XT/6950 XT, au tout récent Radeon RX 6700 ou encore à certains autres Radeon RX 6000 Series mobiles. Cela dit, d'après AMD, les GPU legacy Radeon HD 7000/8000 Series sont même supportés alors que leur dernier pilote, le le 16.2.1, datait de 2016 !
Une autre originalité frappe cette version 22.6.1 puisque ce ne sont en réalité pas un mais bien deux fichiers distincts qui ont été publiés par AMD. Le premier dont nous venons de parler et le second qui est réservé aux deux GPU Radeon RX 6400 et Radeon RX 6500 XT même si en réalité en analysant le fichier INF, on voit que les autres GPU récents manquants de la gamme Radeon RX 6000 Series sont également supportés et peuvent donc théoriquement désormais fonctionner sous Windows 7. Voilà une bonne nouvelle pour les intéressés.
Au passage, ce second pilote 22.6.1 pour les Radeon RX 6000 Series est beaucoup plus récent puisqu'il est daté du 28/04/2022. Il se base en revanche sur la branche 21.09 (21.09.12.01) et n'est pas certifié WHQL.
En ce qui concerne les systèmes d'exploitation modernes Windows 10 et Windows 11, leur pilote n'a toujours pas été actualisé en version 22.6.1 et ils en restent à l'AMD Software : Adrenalin Edition 22.5.2.
Feed back
n°11135990
Fouge
Posté le 14-07-2022 à 21:43:21  profilanswer
Histoire de compléter leur article :
J'imagine qu'ils ne parlent que de Windows 7, parce que sur Windows 10 la branche Legacy a continué à avoir quelques MAJ malgré leur avertissement* : la précédente version des HD7xxx c'était les 21.5.2
* The latest available drivers appear below. This product has been moved to a legacy support model and no additional driver releases are planned.
Petit des tableau recap de version des driver Legacy en fonction de l'OS :
https://snipboard.io/MSHGip.jpg
On voit sur quels OS AMD a continué à faire des efforts :o
Ce que je note aussi, c'est que malgré le non-support officiel de Windows 11 (cet OS n'apparait pas dans la liste proposée par AMD) le fichier s'appelle radeon-software-adrenalin-2020-22.6.1-win10-win11-64bit-legacyasics-june23-2022-legacy.exe donc y'a moyen de tenter la chose pour les rares personnes qui ont un GPU Legacy sur Windows 11.
Ca doit dépendre des GPU, les 22.6.1 WHQL sont proposés pour Win10&11 avec les GPU Legacy, les Vega 64, les RX6000 (en Optionnal) etc.
Ensuite si on extrait ces drivers 22.6.1 WHQL (en rouge les différences).
Version Windows 7 64bit (version RX6400/6500)
WHQL : non
RadeonSoftwareEdition : Adrenalin 2020
RadeonSoftwareVersion : 22.6.1
BuildVersion : 21.09.12.01-220428a-380405E-RadeonSoftware
AMD display driver : 04/28/2022, 27.20.20912.1002 (signé le 22/06/2022)
Version Windows 7 64bit (version standard)
WHQL : oui
BuildVersion : 21.09.12.01-220428a-380461C-RadeonSoftware
AMD display driver : 04/28/2022, 27.20.20912.1002 (certifié le 23/06/2022)
Version Windows 10 64bit (version Legacy)
WHQL : oui
BuildVersion : 21.09.12.01-220428a-380462C-RadeonSoftware
Ces driver sont tous issus de la branche 21.09, sont datés et signés de cette année et sont WHQL (sauf version RX6400/6500).
Je me demande con comment ils ont trouvé ces informations :??:
Message édité par Fouge le 17-07-2022 à 10:11:20
n°11136150
fabrs2_ben​chmark
Posté le 15-07-2022 à 18:13:29  profilanswer
tu as la dernière mise à jour bios sur ta rog crosshair pour support windows 11?
https://www.hardwareluxx.de/communi [...] 28903/#2.7
n°11136178
Lermite
Posté le 15-07-2022 à 20:01:05  profilanswer
Non, je suis resté au 7201 parce que les versions ultérieures n'ont fait que dégrader le comportement de mon 1700, notamment vis à vis de la RAM dont j'ai optimisé à mort les timings.
Ce n'est de toute façon pas la carte mère qui bloque pour W11 mais le processeur, mon antique Ryzen 1700 au seul prétexte qu'il ne gère pas je-ne-sais-plus-quelle-fonctionnalité au niveau hardware parce qu'à 3,8 GHz, ses performance sont toujours loin d'être ridicules par rapport aux prérequis simplifiés: "1 gigahertz (GHz) ou plus, avec au moins 2 cœurs"  :kaola:
Sur ce, ça fait un moment que je n'ai pas retesté sa compatibilité avec Win 11 alors que les prérequis ont pu s'assouplir depuis ma dernière tentative.
Mais je ne sais même pas ce que W11 m'apporterait de plus ou mieux par rapport à mon Win 10 actuel qui répond très bien à mes attentes. Je reste donc relativement indifférent à l'idée de ne pouvoir passer à Win 11.
EDIT: J'ai retesté la compatibilité avec Win 11 et même combat: toujours refusée à cause de mon Ryzen 1700 dont je n'ai aucune intention de me séparer donc osef Win 11.
Message édité par Lermite le 15-07-2022 à 20:10:50
n°11136183
burn2
Pour ceux qui viendront après
Posté le 15-07-2022 à 20:43:45  profilanswer
Module tpm manquant oui.
Il faut voir si tu ne peux pas en mettre un externe.
n°11136190
Lermite
Posté le 15-07-2022 à 20:56:20  profilanswer
Non, ma carte mère gère le TPM sans aucun problème. Ce n'est pas du tout ça qui bloque.
C'est mon processeur et seulement lui.
https://zupimages.net/up/22/28/9xuc.png
Message édité par Lermite le 15-07-2022 à 21:07:35
n°11136217
seth-01
Posté le 15-07-2022 à 23:05:53  profilanswer
obsolescence programmée !   :fou:
n°11136321
fabrs2_ben​chmark
Posté le 16-07-2022 à 19:02:49  profilanswer
sinon un rysen 5700x pour le remplacer,avec de meilleur perf pour ta ram(mon rysen 1600 assez capricieux avec la ram) et consommation de 65 watts en tdp pour le cpu.
n°11136325
Lermite
Posté le 16-07-2022 à 19:18:30  profilanswer
Il me semble que ma carte mère n'accepte les Ryzen que jusqu'aux Zen 2, à savoir les 3xxx.
Je n'ai déjà pas les moyens de remplacer le processeur alors la carte mère  :ange:
Concernant la RAM, sa gestion dépend entre autres de la carte mère.
Mon 1700 était au début sur une Prime X370 Pro qui était une vraie catastrophe pour sa gestion de la RAM. La marge d'optimisation était très faible. Ma HOF 3600 C17 atteignait péniblement 3000 Mhz avec des timings pourris.
Quand je l'ai remplacée par une Crosshair VI Hero, ça a été la révélation, comme si ma RAM s'en trouvait débridé. Elle tenait alors plus de 3400 Mhz avec des timings optimisés.
Je l'ai depuis redescendue à 3333 Mhz pour être sur qu'une éventuelle instabilité ne vienne pas d'elle mais sans toucher aux timings:
https://zupimages.net/up/22/28/fkyx.png
C'est une des raisons pour lesquelles je n'ai aucune envie de me séparer cette carte mère.
Si un remplacement du processeur est envisageable à terme, il est hors de question si c'est juste pour passer à Windows 11.
n°11136330
fabrs2_ben​chmark
Posté le 16-07-2022 à 19:51:01  profilanswer
il y a eu la mise à jour rysen 5000(x3d) sur les chipsets x370,c'est le cas chez msi est bien d'autres.
n°11136331
seth-01
Posté le 16-07-2022 à 20:01:45  profilanswer
J'ai une Crosshair VI Hero à base de X370 avec un beau Ryzen 9 5900X dessus et ca marche impec !  :whistle:
n°11136333
Lermite
Posté le 16-07-2022 à 20:07:13  profilanswer
Voila qui est bon à savoir  :jap:
n°11136386
[Toine]
A la demande générale...
Posté le 17-07-2022 à 08:55:59  profilanswer
Flash quand même le bios avant de te débarrasser de ton CPU actuel :D
Et sinon j'ai une PRIME X370 PRO avec de la 3200C14@3600C14 , ça tournait aussi bien sur un 3700X que sur un 5950X donc pas vu de souci niveau gestion ram.
C'est plutôt le Ryzen en fait qui est en cause . Et après faut jouer avec le VDDRSOC
Message édité par [Toine] le 17-07-2022 à 08:58:05
n°11136398
Lermite
Posté le 17-07-2022 à 10:12:32  profilanswer
J'ai joué avec absolument tous les paramètres disponibles pour stabiliser ma RAM.
Ma RAM ne voulais rien savoir avec la Prime X370 Pro alors que passer à la C6H l'a réellement débridée.
La C6H donne accès à plus de paramètres affectant la RAM donc peut-être que l'ajustement d'un de ces paramètres exclusifs à cette carte mère a permis d'optimiser la RAM sans plus d'instabilité chronique indépendante du paramétrage.
J'imagine donc que la C6H permet de pallier plus efficacement les faiblesses de mon 1700 via à via de la RAM de part son paramétrage plus fourni.
Quoi qu'il en soit, comme mon 1700 fonctionne parfaitement et est toujours assez puissant pour ce que j'en fait, je n'ai aucune raison de le remplacer étant donné que je ne vois même pas l'intérêt que j'aurais à passer à Win 11 même après m'être renseigné sur ce qu'il apporte par rapport à Win 10.
n°11138664
Col Hanzap​last
Posté le 27-07-2022 à 16:17:16  profilanswer
AMD Software: Adrenalin Edition 22.7.1 Now Available!
Highlights
    Swordsman™ Remake.
    Radeon™ Boost using Variable Rate Shading with Elden Ring™, Resident Evil Village™ and VALORANT™.
    Microsoft® Windows® 11 version 22H2.
    Microsoft® Agility SDK Release 1.602 including new minor features.
    Microsoft® Agility SDK Release 1.606 including Microsoft® Shader Model 6.7.
    Additional Vulkan® extensions. Click https://www.amd.com/en/support/kb/r [...] win-vulkan for more information.
    AMD Noise Suppression
        Our newest feature: AMD Noise Suppression reduces background audio noise from your surrounding environment using a real-time deep learning algorithm, providing greater clarity and improved concentration whether you are focused on an important meeting or staying locked-in on a competitive game. To learn more, check out our blog post https://community.amd.com/t5/gaming [...] a-p/531860!.
    OpenGL® Optimizations
        Up to 79% increase in performance in Minecraft™ @ 4k Fabulous settings, using Radeon™ Software Adrenalin 22.7.1 on the Radeon™️ RX 6950XT, versus the previous software driver version 22.6.1 RS-491
        Up to 75% increase in performance in Minecraft™ @ 4k Fabulous settings, using Radeon™ Software Adrenalin 22.7.1 on the Radeon™️ RX 6400, versus the previous software driver version 22.6.1 RS-495
    Radeon™ Super Resolution
        Expanded support for discrete Radeon™ RX 5000 and 6000 series GPUs on AMD Ryzen™ processor notebooks with hybrid graphics.
        RSR has been improved to provide a more seamless experience in borderless fullscreen mode with a performance/quality slider to personalize your gaming experience.
Fixed Issues
    Lower than expected Folding@home™ compute performance with OpenCL™ API on some AMD Graphics Products such as the Radeon™ RX 6800.
    Auto Undervolt may disable Zero RPM fan feature.
    Hitman 3™ may freeze when rapidly switching between windows in Fullscreen Exclusive mode.
    Video upscaling in browsers appears blurry with some AMD Graphics Products such as the Radeon® RX 6900 XT Graphics.
    Enhanced Sync may cause games to lock to 15FPS with video playback on extended monitors.
Known Issues
    Stuttering may be experienced while playing Call of Duty®: Warzone™ on the Caldera map with some AMD Graphics Products such as the Radeon™ RX 6900 XT Graphics.
    Radeon™ Super Resolution may fail to trigger after changing resolution or HDR settings on games such as Nioh™ 2.
    Virtual Reality headsets may flicker with some AMD Graphics Products such as the Radeon™ RX 6800 XT Graphics.
    GPU utilization may be stuck at 100% in Radeon performance metrics after closing games on some AMD Graphics Products such as Radeon™ 570.
    Display may flicker black during video playback plus gameplay on some AMD Graphics Products such as the Radeon™ RX 6700 XT.
    Enhanced Sync may cause a black screen to occur when enabled on some games and system configurations. Any users who may be experiencing issues with Enhanced Sync enabled should disable it as a temporary workaround.
Release notes: https://www.amd.com/en/support/kb/r [...] win-22-7-1
n°11138851
Col Hanzap​last
Posté le 28-07-2022 à 12:39:28  profilanswer
Bonne nouvelle: Le FSR2.0 arrive sur Chernobylite. Mauvaise nouvelle: DX12 obligatoire.
n°11138860
wazany
Posté le 28-07-2022 à 13:36:58  profilanswer
Pourquoi c'est une mauvaise nouvelle dx12?
n°11138862
chrisleurn
Hardcore Will Never Die !
Posté le 28-07-2022 à 13:41:46  profilanswer
increase performance in minecraft
En fait ils ont refait leur driver openGL pour Minecraft spa possible autrement [:tinostar] je viens de tester en modé, c'est du mini x2 ici en 1080p [:tinostar] cette fluidité sur du Minecraft modé [:tinostar] je peux foutre 120fps constant sans problème, alors qu'avant je faisais du 45/70fps :ouch:
Ptain ils ont mis le temps [:sigi]
J'espère que ça fonctionne aussi bien sur autre chose que du Navi2 :o  :o
n°11138866
hisvin
Posté le 28-07-2022 à 13:54:19  profilanswer
Pendant longtemps, les jeux en Dx12 étaient injouables même dans le menu sur la Rx580x mais, maintenant ça marche.
n°11138898
MEI
|DarthPingoo(tm)|
Posté le 28-07-2022 à 15:54:18  profilanswer
De tout temps ATI/AMD à toujours été très mauvais en compat. puis en perfs OpenGL vs NVIDIA. Donc fait du x2, ça ne m'étonne même pas... :spamafote:
n°11139006
Antionn
Posté le 29-07-2022 à 10:21:09  profilanswer
Assez étrangement, je n'ai jamais vraiment noté de problèmes sur les quelques jeux en DX12 auxquelles j'ai pu jouer (Metro Exodus, Division2, sûrement un ou deux autres que j'ai oublié aussi) avec ma propre RX480/580 ... en dehors des instabilités que je provoquais moi-même en tout cas :o
Par contre le boost de performances/de fluidité lui, valait le coup :ange:
Mon topic achat // [TU] Radeon Software // [TU] AMD RDNA2 - RX6x00
n°11139215
archeo
Posté le 30-07-2022 à 08:49:49  profilanswer
Je ne sais pas si c'est dû à une mise à jour des drivers de ma Sapphire RX570 mais j'ai remarqué quelque chose d'étrange au niveau des ventilos.
Systématiquement lorsque je redémarre le PC après l'avoir mis en veille moi-même ou, de façon plus aléatoire lorsque PC s'est mis en veille après un certain temps d'inactivité, j'ai les ventilos qui se transforment en turbine pendant quelques secondes avant de se remettre à l'arrêt. Ca fait 18 mois que j'ai cette carte dans le PC et ce n'est que récemment que j'ai observé ce phénomène.
Y a t-il un réglage particulier à opérer dans Adrenalin pour supprimer ça ?
n°11139216
Col Hanzap​last
Posté le 30-07-2022 à 08:57:46  profilanswer
Avec les R9 280X, le nettoyage automatique des ventilateurs les fait tourner à fond tant qu'on est dans le BIOS au boot.
n°11139218
archeo
Posté le 30-07-2022 à 09:04:22  profilanswer
Au démarrage du PC, il y a effectivement ce décrassage mais là, ça le fait parfois quand c'est juste l'écran qui s'est mis en veille alors que le PC ne l'est pas puisque dans les paramètres Win10, j'ai dit d'éteindre l'écran au bout de 20 mn mais de ne jamais éteindre le PC.
n°11139219
Col Hanzap​last
Posté le 30-07-2022 à 09:20:16  profilanswer
Justement quand j'écoute de la musique avec VLC à travers les haut-parleurs de l'écran, il suffit que ce dernier passe en veille pour que la musique s'arrête. C'est très ch...  :D
Je pense que c'est du au fait que l'image et le son passent par la prise HDMI. Quand la Radeon coupe la prise HDMI, elle coupe tout ! L'image et le son.
Message édité par Col Hanzaplast le 30-07-2022 à 09:27:48
n°11139223
archeo
Posté le 30-07-2022 à 09:33:33  profilanswer
Pour le coup, effectivement, j'ai changé d'écran il y a quelques mois et à cette occasion, je suis passé d'une connectique DVI à une connectique HDMI.
Du coup, je peux peut être dire à Windows de ne jamais mettre l'écran en veille mais gérer cet aspect directement dans les paramètres de l'écran ?
n°11139556
Mikci28
1+1=11
Posté le 31-07-2022 à 17:01:38  profilanswer
Slt moi cest pareil rx580 ventilo qui se mette à font de temps en temps, le seul moyen que j ai trouvé c est de passer la gestion des ventilos en manuel.
Mon Feedback
n°11139562
Col Hanzap​last
Posté le 31-07-2022 à 17:13:23  profilanswer
Passer ces clefs de la registry à zéro fait que les ventilateurs ne s’arrêtent jamais quand on revient au bureau windows, donc globalement meilleur refroidissement.
https://i.postimg.cc/SKH5v4dY/Enable-Ulps.jpg
Message édité par Col Hanzaplast le 31-07-2022 à 19:30:07
n°11139563
archeo
Posté le 31-07-2022 à 17:14:04  profilanswer
Pour l'instant, je suis passé par un simple écran de veille mais ça ne me satisfait pas totalement car ça laisse l'écran allumé, à pleine consommation électrique, pas très tendance  :non:
Mais cette gestion des ventilo, elle se trouve dans quel menu ?
Message édité par archeo le 31-07-2022 à 17:14:29
n°11139568
Mikci28
1+1=11
Posté le 31-07-2022 à 17:28:43  profilanswer
Dans performance/réglage de adrenaline
https://static-pepper.dealabs.com/threads/content/gd9xm/2005761.jpg
Message édité par Mikci28 le 31-07-2022 à 17:30:29
Mon Feedback
ATI - Problème avec les CATALYST 3.5 +Question concernant ATI 9800 Pro avec HP80A : chaud brulant !!!!!
Probleme Hydravison et ATIAti Radeon 9600 Pro > Gigabyte HIS Saphire ou Club 3D ?
[Topic Unique] ASUS P4C800 / P4P800 (Intel i865/i875)les CG ATI 9xxx les + o/cables , quelle marque ?
Performance des differentes cartes ATI et Nvidia ??LEADTEK A 360 FX 5700 ou ATI 9600 PRO ?
Plus de sujets relatifs à : [Topic Unique] Radeon™ Software Adrenalin 2020 Edition ● CG & APU !
