8192 connectés
Fréquences + type de vos m.à.j.
Sondage à 2 choix possibles.
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  245  246  247  ..  1017  1018  1019  1020  1021  1022
[Topic Unique] Radeon™ Software Adrenalin 2020 Edition ● CG & APU !
n°4496260
hubert-fel​ix
Posté le 09-12-2005 à 13:10:35  profilanswer
Je viens de tester ces drivers,excellent.
Ils sont vraiment optimiser pour l'hyper-threading. :)
pas comme les drivers nvidia,soit disant multi-threadee,et qui finalement n'apportent rien. :fou:
voila un graphe de la charge processeur (P4C 3.2) sous 3D05.
*avec les 5.11:
http://img236.imageshack.us/img236/5968/3d055116dp.jpg
*et les 5.12:
http://img236.imageshack.us/img236/5526/3d55121au.jpg
et encore plus flagrant dans les jeux.
n°4496266
chrisleurn
Hardcore Will Never Die !
Posté le 09-12-2005 à 13:11:37  profilanswer
  [:dawa]
Unauthorized download
We're sorry, but this download request cannot be authorized. As an option, you may visit any of the pages below for information about ATI services and products:
   1. ati.com home
      Connect to ATI's latest information.
   2. Customer Care
      Access technical support, drivers, and frequently asked questions.
There could be several reasons why you're seeing this page:
    * You clicked on a link on a site that is not part of the ATI domain.
    * You're using a download manager. Download managers usually offer to search for alternative download locations. While this is nice for the user, it's bad for the webmaster because a download which originated on another site could theoretically still be downloaded from this site, without anybody knowing.
      Workaround to this restriction: Set up your download manager to send a HTTP referrer, and when you click on a link on the ATI site the download will then be authorized.
    * Your browser did not send a referrer. This normally happens if you right click on a link and select save-as, or if you copy and paste a link into a new browser window and press Enter. It may also be that your browser is set up to not send any referrer. Left clicking on a link works just fine and has been tested in IE, FireFox, Netscape , Opera and Mozilla.
    * Some software firewalls (such as Norton Personal Firewall or ZoneAlarm) remove the referrer from HTTP requests which will block any downloads on any site that does a referrer check. Hence such options should always be turned off. In Norton go to the Privacy Settings and disable browser privacy (which doesn't really protect your privacy anyway as your IP address will always be logged regardless of that setting), in ZoneAlarm go to Privacy -> Cookie Control -> Custom and uncheck "remove private header information".
    * If you use a mozilla based browser (Mozilla, Firefox or Netscape Navigator), referrer sending can also be deactivated (it is activated by default). To change that setting, browse to "about:config", then search for "network.http.sendRefererHeader". If the value is set to 1, referrer sending is enabled, if it is set to 0, it is disabled. To enable it, double click on it, then change the value.
We're sorry for any inconvenience this may cause.
n°4496268
ITM
Avatar peint à la main
Posté le 09-12-2005 à 13:12:26  profilanswer
Faudrait quelqu'un qui test avec un vrai dual core :love:
n°4496275
god is dea​d
Demain, j'arrête de poster.
Posté le 09-12-2005 à 13:14:41  profilanswer
*avec les 5.11:
*et les 5.12:
Intéressant pour mon ptit P4C.
Mais en pratique ça donne quoi?
n°4496276
Rio Grande
bande de nains
Posté le 09-12-2005 à 13:15:33  profilanswer
chrisleurn a écrit :
[:dawa]
Unauthorized download...
grilled et en plus pas besion de quoté toute la page  :o
Topics : NFSU2 - NFS : Most Wanted - Volant PC Site :  NFS-Mania.com
n°4496278
ITM
Posté le 09-12-2005 à 13:16:43  profilanswer
Dommage pour vous, moi ça marche...  :lol:
Allez je le fous sur mon FTP si je peux :hello:
n°4496279
chrisleurn
Posté le 09-12-2005 à 13:17:12  profilanswer
M'en fout  [:dawao]
n°4496297
punkoo
Posté le 09-12-2005 à 13:26:19  profilanswer
Une fois de plus, personne n'a testé le mode théatre de ces drivrers??
Moi comme avec les 5.11, l'image est degueullasse, beaucoup plus écrasée et une impression de scintillement surtout sur les sous-titres.
Franchement j'en ai ras le bol de cette marque de merde, j'ai l'impression qu'ils testent rien (surtout sur la stv). J'suis obligé de rester avec les 5.10 pour que ca soit nikel ; Or ayant une carte à 300€ j'ai un peu la larme à l'oeil.
Mon problème c'est que les màj des pilotes sont importantes pour les jeux, donc concrétetement je fait comment???
n°4496299
ITM
Posté le 09-12-2005 à 13:27:03  profilanswer
Fallait acheter nvidia :o
n°4496308
rootsayen
Jungle Cat
Posté le 09-12-2005 à 13:33:34  profilanswer
Punkoo t'as été voir sur d'autres forums notement ricains si c'est un problème massif ou isolé ?
"Being solitary is being alone well; being alone luxuriously immersed in doings of your own choice, aware of the fullness of your own presence rather than the absence of others."
n°4496353
punkoo
Posté le 09-12-2005 à 13:52:14  profilanswer
Florian? (c jf llool)
n°4496356
ITM
Posté le 09-12-2005 à 13:54:20  profilanswer
Bon, essayez ça:
Version à priori avec Control Panel : http://rapidshare.de/files/8865647 [...] 2.exe.html
n°4496378
rootsayen
Jungle Cat
Posté le 09-12-2005 à 14:01:41  profilanswer
C'est bien moi ^^
n°4496382
punkoo
Posté le 09-12-2005 à 14:02:55  profilanswer
excellent!
je vais t'encoyer un mp soon
n°4496404
[DALTON]Jo​e
Posté le 09-12-2005 à 14:10:55  profilanswer
Yoda_57 a écrit :
Ah bon, pour toi c'est donc mieux de laisser à un utilisateur lambda qui par définition de sait pas ce qu'il fait mais aime bien faire joujou la possibilité d'overclocker sa carte graphique ? :sarcastic:
Faut arrêter les mecs, les drivers çà ne sert pas qu'à faire joujou à la maison poru gagner 3FPS hein...
 :heink:
comme ATI Tray Tool quoi..... je m'en sers à 90% pour les reglages AA/AF
mais aussi pour la prise de screenshots, il peut aussi remplacer FRAPS, etc...
et le lambda que tu decris il est tres bien avec le CCC de toute façon... et vu le gland que c'est apparemment il ne vaut mieux pas lui laisser un PC entre les mains  :whistle:
et de plus:
http://gjweb.free.fr/att%20install.jpg
enfin ce lambda et l'anglais ça doit faire deux aussi
et l'overclocking: gain de 3 fps (qui ne veut rien dire de toute façon sans la moyenne totale de fps...) c'est pas le cas de tout le monde...
La simu automobile online: LFS - Hattrick: ASWB (177185)
n°4496737
ITM
Posté le 09-12-2005 à 17:03:36  profilanswer
Bon, je confirme:
5.12 avec CONTROL PANEL (version du control panel : 6.14.10.5173)
Le CCC attendra encore [:joce]
n°4496748
punkoo
Posté le 09-12-2005 à 17:09:20  profilanswer
Ceux qui utilisent la sortie télé en mode théatre et télé 4/3 de préférence, peuvent me dire si ca marche bien pour eux??
n°4496767
Ben59
Posté le 09-12-2005 à 17:18:42  profilanswer
ITM a écrit :
Bon, je confirme:
Merci beaucoup pour le lien   :hello:
n°4496781
quicksilve​r01
Posté le 09-12-2005 à 17:31:24  profilanswer
Sa marche bien pour moi  :hello:
Gerer Linux comme un pro Toi aussi soit --> Linux CachyOs powered
n°4496792
punkoo
Posté le 09-12-2005 à 17:35:19  profilanswer
Sérieux ? télé 4/3?
Ton ratio a pas changé?? (genre je veut dire par là l'image est pas moins grande qu'avant)
Moi, sur les vidéos qui avaient très peu de bandes noire, elles occupent maintenant beaucoup plus de place, et j'ai aussi l'impression qu'il y a énormement plus de scintillement (ma télé est 60hz mais ca allait très bien avant avec les 5.10)
C'est pe etre spécifique à ma sapphire x800xl, mais je trouve ca bizar. Depuis les 5.11 je peut plus mettre à jour mes pilotes à cause de ça, obligé de laisser les 5.10
n°4496796
quicksilve​r01
Posté le 09-12-2005 à 17:37:00  profilanswer
Moi j'ai la sapphire 9600 en attendant de remettre ma 9800pro que je vais zalmannifie, j'ai une tv 55cm 60Hz aussi, sa pete les yeux, en texte c'est flou mais en video c'est normal pour moi , désolé [:spamafote]
n°4496808
punkoo
Posté le 09-12-2005 à 17:41:01  profilanswer
J'ai aussi remarqué un truc bizare : Lorsque je lançe un jeux (peut-importe lequel, suffit que la carte taffe) et que, une fois le jeux quitté, je lance une vidéo (un divx koi) sur ma télé (mode théatre donc) après j'ai comme des lignes horizontales qui apparaissent, j'suis obligé de redémarrer pour que les lignes disparaissent...
Trop space.
Pis rien à voir aussi, c koi ce message d'erreur que je vois toujours lorsque j'install une ati, 'zero display service error' ou un truc du genre à la fin de l'install?
Je me doute que y'a pas de probs par la suite (me rappele meme plus de l'époque où je le voyais pas tellement ca dure), mais bon ca fait pas très sérieux
n°4496812
punkoo
Posté le 09-12-2005 à 17:41:58  profilanswer
Oki, on utilise pas la meme carte donc c'est clair c'est pas comparable.
Merci en tt cas pour ton témoignage
n°4496816
quicksilve​r01
Posté le 09-12-2005 à 17:43:32  profilanswer
Je crois que sa m'est arrivé une fois l'erreur d'install avec la 9800pro, j'ai tout supprimé : driver dans ajout suppresion + driver cleaner etc...
Et tout installer manuellement.
Sinon mon réglage tv :
http://img522.imageshack.us/img522/3372/9600tv5dv.th.png
Edit : j'ai 2 sapphire : une 9600 et une 9800 pro ; ras sur les 2 cartes  :jap:
Message édité par quicksilver01 le 09-12-2005 à 17:44:26
n°4496826
ITM
Posté le 09-12-2005 à 17:46:33  profilanswer
oui effectivement ça parait expliquer bien des choses :D
Jamais eu ça sur ma 9800Pro ni sur la X800XT :/
n°4496850
punkoo
Posté le 09-12-2005 à 17:54:19  profilanswer
Bah apparramment c'est super classique comme problème, suffit de regarder sur google, et ça n'a aucune incidence
D'ailleurs j'ai pas dis que ma carte fonctionnait pas, j'ai aussi ce message d'erreur avec les 5.10 et tt va bien
J'ai aussi ce message avec une 7500, une 9250 et j'en passe
n°4497105
homer666
Posté le 09-12-2005 à 19:26:39  profilanswer
sur le site d'ATI il y a les catalyst 5.12 sans control Center voila le lien:
https://support.ati.com/ics/support [...] olderID=27
n°4497116
ITM
Posté le 09-12-2005 à 19:30:43  profilanswer
Il merdeleur site chez moi :/
Pour ceux qui peuvent pas y avoir accès, y'a un lien rapidshare à la page d'avant :jap:
n°4497126
yo59
OCBoy
Posté le 09-12-2005 à 19:34:55  profilanswer
c'est normal que le lien ne fonctionne pas, ATI refuse les liens directs, il faut passer par la page d'accueil des drivers depuis quelques temps.
n°4497131
homer666
Posté le 09-12-2005 à 19:37:27  profilanswer
faut dire que leur site est tres lent depuis quelque temps...
n°4497848
Yoda_57
Marc, gagame, c'était mieux
Posté le 10-12-2005 à 08:43:59  profilanswer
[DALTON]Joe a écrit :
:heink:
et de plus:
C'est bien ce que je dis... :)
Art ?|Pro ?|Sport ?| ACH/VDS matos photo divers
n°4497921
dwarfy
Posté le 10-12-2005 à 10:19:55  profilanswer
punkoo a écrit :
Sérieux ? télé 4/3?
http://www.driverheaven.net/showthread.php?t=93089
Et on apprécie mon anglais parfaitement nul.
n°4498284
johnbroot
n00b Inside
Posté le 10-12-2005 à 13:37:55  profilanswer
C'est beau ça la perfection dans la nullité. :D
"Tout le monde sait que les immigrés viennent vivre du RSA en prenant les emplois des français. L'immigré de Schrödinger" Gottorp
n°4498309
punkoo
Posté le 10-12-2005 à 13:45:08  profilanswer
Merci pour ce lien. Me disait bien que j'était pas le seul.
En tt cas c bien d'avoir contacté ati pour ca, j'hésitai aussi.
Tout comme toi, j'attend de voir si ils vont corriger ce prob (revenir en arrière ou proposer plus d'options), sinon ca sera ma dernière ati aussi (j'utilise enormement ma stv)
Message édité par punkoo le 10-12-2005 à 13:48:54
n°4498419
tonio65
Posté le 10-12-2005 à 14:23:31  profilanswer
Merci , pour le lien pour les 5.12 avec control panel , ça marche.   :jap:
n°4498586
dwarfy
Posté le 10-12-2005 à 15:39:29  profilanswer
Te gène pas pour t'inscrire et poster un message dans mon thread pour montrer que je suis pas le seul à rester aux 5.10 à cause de ça.
Terry Makedon lit ce forum, ce serait pas plus mal qu'on soit plusieurs à essayer de leur faire entendre raison.
n°4498612
frandon
Citation personnelle associée
Posté le 10-12-2005 à 15:54:13  profilanswer
je suis avec les 5.11 en rage theatre (rapport HL identique a la source et rapport HL péripéhrique aff 16/9) sur une 9200se et aucun PB.
je pense même que l'image est plus détaillée sur ma TV 16/9
c'est zarb quand même votre Pb :/
Cdlt,
n°4498642
dwarfy
Posté le 10-12-2005 à 16:10:05  profilanswer
Non mais, c'est juste que t'as le même problème que nous mais qu'il te gène pas. J'ai passé 9250, 9800, x800, x700mobile sur des sony 55cm et 92cm. Et évidemment, toujours pareil (et même moi sur ce thread au début des 5.11 j'ai dit que ça me génait pas et que je voyais pas la différence, mais en fait ... si :D et ça me gène beaucoup).
T'es *obligé* d'être en 720x576 depuis les 5.11 en theater mode. Donc on est tous logés à la même enseigne.
En NTSC j'arrive à avoir à peu près des résultats comparable à ce que j'avais avant, mais c'est pas le top. Et les couleurs sont cradasses, faut corriger avec sa tv ou dans les drivers.
En PAL j'ai une image un brin écrasé et surtout toutes l'image. je préférais mon overscan d'avant ou je perdais un peu à gauche, un peu à droite mais avec de belles couleurs et forcément une plus grande image.
n°4498646
Sleeve
Posté le 10-12-2005 à 16:11:52  profilanswer
drapal
n°4498658
jujudu64
Posté le 10-12-2005 à 16:19:58  profilanswer
omega 5.12 out le 10/12/05 presents sur guru3d :)
ps : dsl si deja dit :/
n°4498678
matthiman
de Gilead
Posté le 10-12-2005 à 16:33:41  profilanswer
Merci pour l'info ;)
Ventes - Feedback
ATI - Problème avec les CATALYST 3.5 +Question concernant ATI 9800 Pro avec HP80A : chaud brulant !!!!!
Probleme Hydravison et ATIAti Radeon 9600 Pro > Gigabyte HIS Saphire ou Club 3D ?
[Topic Unique] ASUS P4C800 / P4P800 (Intel i865/i875)les CG ATI 9xxx les + o/cables , quelle marque ?
Performance des differentes cartes ATI et Nvidia ??LEADTEK A 360 FX 5700 ou ATI 9600 PRO ?
Plus de sujets relatifs à : [Topic Unique] Radeon™ Software Adrenalin 2020 Edition ● CG & APU !
