8468 connectés
Fréquences + type de vos m.à.j.
Sondage à 2 choix possibles.
Les invités peuvent voter
 Page :   1  2  3  4  5  ..  1014  1015  1016  1017  1018  1019  1020  1021  1022
[Topic Unique] Radeon™ Software Adrenalin 2020 Edition ● CG & APU !
n°11451857
Umi
Posté le 30-10-2025 à 00:17:38  profilanswer
AMD Radeon Adrenalin Edition 25.10.2
AMD Software: Adrenalin Edition 25.10.2 Driver for Windows® 11 (64-bit)
https://www.amd.com/en/resources/su [...] -10-2.html
What's new in AMD Radeon Adrenalin Edition 25.10.2
Oct 29, 2025
    New Product Support:
    AMD Ryzenhttps://github.com/BZHDeveloper1986 [...] g?raw=true  AI 5 330
    New Game Support:
    Battlefieldhttps://github.com/BZHDeveloper1986 [...] g?raw=true  6 (DX12)
    Vampire: The Masquerade – Bloodlines 2 (DX12)
    Expanded Vulkan Support:
    VK_EXT_shader_float8
    VK_KHR_video_decode_vp9
    VK_KHR_video_encode_av1
    VK_KHR_video_encode_quantization_map
    VK_AMDX_dense_geometry_format
    VK_KHR_shader_untyped_pointers
    VK_KHR_present_mode_fifo_latest_ready
    VK_EXT_present_mode_fifo_latest_ready
    VK_KHR_present_id2
    VK_KHR_present_wait2
    Click HERE for more information about other Vulkan® extension support.
    Work Graphs Support:
    Initial introduction of Work Graphs support on Radeonhttps://github.com/BZHDeveloper1986 [...] g?raw=true  RX 9000 series graphics products.
    Fixed Issues:
    Intermittent application crash may be observed while playing The Last of Us Part II on Radeonhttps://github.com/BZHDeveloper1986 [...] g?raw=true  RX 7900 series graphics products.
    Intermittent application crash may be observed while playing FBC: Firebreak on some AMD Ryzenhttps://github.com/BZHDeveloper1986 [...] g?raw=true  processors such as the Ryzenhttps://github.com/BZHDeveloper1986 [...] g?raw=true  AI 300 series and the Ryzenhttps://github.com/BZHDeveloper1986 [...] g?raw=true  8000 series.
    Corruption (missing scan travel lines) may be observed while playing GTFOhttps://github.com/BZHDeveloper1986 [...] g?raw=true  on Radeonhttps://github.com/BZHDeveloper1986 [...] g?raw=true  RX 7000 series graphics products.
    Stutter may be observed while playing games with some VR headsets at 80Hz or 90Hz refresh rate on some AMD Radeonhttps://github.com/BZHDeveloper1986 [...] g?raw=true  Graphics Products such as the Radeonhttps://github.com/BZHDeveloper1986 [...] g?raw=true  RX 7000 series. Users experiencing this issue are recommended to change the refresh rate as a temporary workaround.
    Intermittent application crash may be observed while playing NBA 2K25 in MyCareer mode on Radeonhttps://github.com/BZHDeveloper1986 [...] g?raw=true  RX 9070 series graphics products. AMD is actively working on a resolution to be released as soon as possible.
    Stutter may be observed While playing Baldur’s Gate 3 on some AMD Radeon Graphicshttps://github.com/BZHDeveloper1986 [...] g?raw=true  Products such as the Radeonhttps://github.com/BZHDeveloper1986 [...] g?raw=true  RX 9000 and 7000 series.
    Texture flickering or corruption may appear while playing Serious Sam 4 on Radeonhttps://github.com/BZHDeveloper1986 [...] g?raw=true  RX 6000 series graphics products.
    Shadow corruption on left eye is seen while playing VTOL VR on Radeonhttps://github.com/BZHDeveloper1986 [...] g?raw=true  RX 7000 series and Radeonhttps://github.com/BZHDeveloper1986 [...] g?raw=true  RX 9000 series graphics products.
    CVE-2023-4969 (RDNA only), CVE-2024-21969 (RDNA only), CVE-2024-36323, CVE-2024-36325, CVE-2024-36333, CVE-2025-61964, CVE-2025-61965, CVE-2025-61966, CVE-2025-61967, CVE-2025-61968
n°11451982
shaka-31
Posté le 31-10-2025 à 15:09:55  profilanswer
J'ai installer les 25.10.2 et coïncidence ou pas FH5 ne se lance plus, quelqu'un a le problème ?
PSN Udead31 / GT Yegg4r /Battle.net Yeggar
n°11451983
alriad
ST Power, Makes it Possible
Posté le 31-10-2025 à 15:10:57  profilanswer
Il me semble que j'y ai joué hier soir aprés Battlefield.. MAis je sais plus si c est sur le pc ou sur la PS..
Que la force soit avec Moi... (Attention avec votre sabre laser, vous pourriez vous blesser..)
n°11451997
MEI
|DarthPingoo(tm)|
Posté le 31-10-2025 à 16:36:10  profilanswer
Idem ça plante pendant le chargement après le premier menu...
Encore une fois du grand art d'AMD / Microsoft... :D
n°11452043
alriad
Posté le 31-10-2025 à 20:58:44  profilanswer
Non ca marche niquel chez moi.. J'ai meme gagné une petite dizaine de FPS sur FH5 (196 fps en 3440*1440 p toute option au max..)... Donc ca va. (par contre mon test d'hier etait sur la PS5 car il a fait l'optimisation au demarrage du jeu..) (25h2 avec les dernières maj).
Message édité par alriad le 01-11-2025 à 08:33:37
n°11452156
shaka-31
Posté le 01-11-2025 à 18:21:12  profilanswer
Ok merci  :)
https://rehost.diberie.com/Picture/Get/t/444505
Message édité par shaka-31 le 01-11-2025 à 18:44:20
n°11452173
lestanquet
Posté le 01-11-2025 à 21:03:47  profilanswer
Un scud pour rien en fait  :O
n°11453621
It_Connexi​on
Posté le 14-11-2025 à 10:35:45  profilanswer
Adrenalin Edition 25.11.1 WHQL disponibles
https://www.amd.com/fr/support/down [...] -9070.html
Fixed Issues
    - Intermittent application crash may be observed while playing games with Easy Anti-Cheat enabled when using the Radeon™ Overlay.
    - CPU metrics/tuning may not appear in the AMD Software: Adrenalin Edition™ Application after updating the graphics driver using the AMD Software Install Manager.
Known Issues
    - Intermittent application crash or driver timeout may be observed while loading a saved game in Cyberpunk 2077 with Path Tracing enabled. AMD is actively working on a resolution with the developer to be released as soon as possible.
    - Intermittent application crash or driver timeout may be observed while playing Battlefield™ 6 on AMD Ryzen AI 9 HX 370
    - Intermittent application crash or driver timeout may be observed while playing Roblox Player (Car Zone Racing & Drifting) when task switching between media on Radeon™ RX 7000 series products.
    - Texture flickering or corruption may appear while playing Battlefield™ 6 with AMD Record and Stream on some AMD Graphics Products.
    - Radeon Anti-Lag 2 option may not be available while playing Counter-Strike 2 (DX11) with Radeon Anti-Lag 2 enabled on some AMD Graphics Products, such as the Radeon™ RX 9070 XT. Users experiencing this issue are recommended to use the Vulkan API as a temporary workaround.
    - Intermittent system crashes may be observed while using some high-bandwidth HDMI 2.1 displays during display standby. Users experiencing this issue are recommended to use a DisplayPort connection as a temporary workaround.
Galerie Photo Personnelle
n°11453754
hisvin
Posté le 15-11-2025 à 17:22:46  profilanswer
Je n'avais pas fait attention, mais Adrenalin a disparu suite à l'installation automatique du nouveau pilote.
Edit: Réinstallation manuelle et Adrenalin refonctionne. En fait, pour les gens qui se posent des questions, le fait de ne pas avoir Adrenalin fonctionnel bloque la plupart des améliorations des pilotes (FSR, AA forcé, AMF  etc etc)
Message édité par hisvin le 16-11-2025 à 13:51:26
n°11457306
WipEout 20​97
Processus créatif
Posté le 09-12-2025 à 23:56:23  profilanswer
Et c'est même pas du a un ajout du FSR4, je suppose... C'est encore du 2 tout pourri ? :o
n°11457528
Umi
Posté le 11-12-2025 à 00:23:27  profilanswer
Adrenalin Edition 25.12.1
https://www.amd.com/en/resources/su [...] -12-1.html
n°11457540
It_Connexi​on
Posté le 11-12-2025 à 08:18:50  profilanswer
n°11458183
FeverLight
Posté le 15-12-2025 à 07:10:29  profilanswer
Ce pilote fait n'importe quoi avec ma courbe de ventilation personnalisée, impossible de conserver mon réglage, il est remplacé par des valeurs farfelues.
n°11458186
alriad
Posté le 15-12-2025 à 07:29:14  profilanswer
Perso pas grave vu que même marque que la carte mère je gère avec les drivers générales de la marque  :ange:
n°11458189
It_Connexi​on
Posté le 15-12-2025 à 08:15:31  profilanswer
Le seul soucis que j'ai avec le dernier pilote c'est que CP2077 plante en PT, sur les 2/3 dernières versions je jouais sans soucis
n°11458210
hisvin
Posté le 15-12-2025 à 10:35:14  profilanswer
Je ne sais pas si c'est lié, mais Baldur's gate 3 plante avant le menu (grosso modo, j'arrive à 95% du calcul des shaders et paf plantage).
Sur une Sapphire 7900XT.
Edith(cresson):
Je ne semble pas être seul. Cause inconnue, à priori.
Message édité par hisvin le 15-12-2025 à 21:03:28
n°11458379
quicksilve​r01
Posté le 15-12-2025 à 21:01:31  profilanswer
Pour les dernier drivers j avais hogwarts legacy qui plantait , le jeu se fermait comme ça , et fps lent aussi, mais après un ddu et reinstall plus de plantage et fps ok .
Gerer Linux comme un pro Toi aussi soit --> Linux CachyOs powered
n°11458448
lestanquet
Posté le 16-12-2025 à 07:49:23  profilanswer
Super, drivers claqués de retour quoi  :O
n°11458453
It_Connexi​on
Posté le 16-12-2025 à 08:28:40  profilanswer
Je suis un peu deg pour CP2077 oui, après aucun soucis en RT Psycho mais bon...
Je viens de m'offrir Clair/Obscur pour Noël, j'espère que ça tourne bien avec les derniers pilotes
n°11458545
MazFire
~ Keep Cool ~
Posté le 16-12-2025 à 15:34:38  profilanswer
Souci avec ta 9070 XT ou ta 6950 XT ? :/
n°11458547
havoc_28
Posté le 16-12-2025 à 15:41:02  profilanswer
Non, c'est juste les soucis de crash avec le PathTracing dans CP2077 qui n'a jamais été vraiment résolu coté radeon.
n°11458551
hisvin
Posté le 16-12-2025 à 15:44:28  profilanswer
Il faudrait que je teste par curiosité. :D
n°11458553
havoc_28
Posté le 16-12-2025 à 15:46:32  profilanswer
En fonction des pilotes ça peut crasher au bout de quelques minutes, tout comme ne pas avoir de crash même avec 2/3h de jeu et des disparité d'une carte à l'autre ...
n°11458561
It_Connexi​on
Posté le 16-12-2025 à 17:02:15  profilanswer
Avec la 9070XT
n°11458562
havoc_28
Posté le 16-12-2025 à 17:02:53  profilanswer
De toute façon la 6950XT en PT ... c'est pas exploitable :D.
n°11458563
It_Connexi​on
Posté le 16-12-2025 à 17:03:15  profilanswer
Oui c'est ça, sur les 2-3 derniers pilotes je jouais 2-3h en PT sans aucun soucis, sur le dernier, 10 minutes et black screen + reboot  :sweat:
n°11458564
It_Connexi​on
Posté le 16-12-2025 à 17:03:59  profilanswer
J'ai même pas essayé avec la 6950XT  :D
n°11459304
MazFire
~ Keep Cool ~
Posté le 21-12-2025 à 00:53:56  profilanswer
Je reçois une RX 9070 Prime de chez Asus pour Noël : j'installe quand même les derniers pilotes en date (après DDU) ?
Jeux prévus : Clair obscure Exp 33 et Indiana Jones ;-)
Merci !
n°11459307
sister
Oh hai Marc.
Posté le 21-12-2025 à 01:27:44  profilanswer
Je viens de faire Clair Obscur avec les derniers Adrenalin, aucun problème. :)
Pia !
n°11459318
It_Connexi​on
Posté le 21-12-2025 à 05:22:40  profilanswer
Je l'ai commencé mercredi, une pépite !!
n°11459327
alriad
Posté le 21-12-2025 à 09:14:14  profilanswer
Normal il a été fait avec de l IA. Comment on se ridiculise devant tout le monde en indiquant pas fait avec de l IA…
https://m.jeuxactu.com/clair-obscur [...] p-2jpHGNnQ
Message édité par alriad le 21-12-2025 à 09:15:19
n°11459331
It_Connexi​on
Posté le 21-12-2025 à 09:52:05  profilanswer
Déception...
n°11459333
hisvin
Posté le 21-12-2025 à 10:03:09  profilanswer
Il y a eu usage de l'intelligence artificielle pour générer des textures temporaires sur certains éléments. Ces textures ont été remplacées plus tard. Certaines après la sortie du jeu, ce qui a été reproché (surtout le fait que le studio ne l'ait pas annoncé réellement)
Il ne faut se leurrer, tout le monde le fait ou le fera à court terme.
Message édité par hisvin le 21-12-2025 à 10:04:14
n°11459336
burn2
Pour ceux qui viendront après
Posté le 21-12-2025 à 10:16:01  profilanswer
Pas vraiment non:
Il avait affirmé catégoriquement que l’IA n’avait pas été impliquée dans la partie “créative” du projet, soulignant l’investissement émotionnel et artisanal de l’équipe.
et ça tombe bien c'est l'élément fort du jeu en fait et les points sur lesquels il a gagné. (la musique, le jeu d'acteur, l'histoire)
Qu'ils se soient aidé de l'ia sur la partie technique pure et sur certaines courbe d'apprentissage n'est pas forcément anormal.
Cependant, il avait adopté un ton plus flexible pour le reste : l’usage de l’IA pour des aspects techniques ou logistiques (courbe d’apprentissage, gestion de certains processus, ou éléments de placeholder) ne lui pose pas problème, tant que le jeu fonctionne correctement.
Après oui certaines affiches/textures masives faite par ia dans le décor avait étaient trouvées et enlevé à posteriori.
Message édité par burn2 le 21-12-2025 à 10:22:11
n°11459337
scrumpz
Posté le 21-12-2025 à 10:18:31  profilanswer
L’ia est utilisée depuis longtemps dans l’industrie de jeux vidéo mais d’autres également. Dès que tu utilises un algorithme tu te substitue à une machine… ça n’a aucun sens le but étant de savoir si le créateur a tout fait avec l’ia sans aucun regard critique ni poue servir un propos ou une emotion.
-> A vendre matos Hardaware <-
n°11459339
hisvin
Posté le 21-12-2025 à 10:25:13  profilanswer
Le truc marrant, c'est que l'on avait parlé de ces textures sur le fil "jeux pc". :D
Les premières textures sont "faits" main, mais plus tard, il y avait des textures que, certains, considéraient comme faites par IA. :D
n°11459342
lestanquet
Posté le 21-12-2025 à 10:35:43  profilanswer
Mouais mais c’est le futur c’est comme ça et le pire c'est que beaucoup sont contents  :O
Un livre fait avec IA ? Pas de souci tant que c’est bon  [:daaadou:1]
L’IA est un superbe outil mais qui sera utilisée de façon abusive, c’était couru d’avance, pour certains seul le résultat compte, exit la créativité, le travail et la patte humaine "ce n’est pas grave".
Sinon mes excuses sur le "driver daubé amd", j’ai réinstallé windows et plus de souci  :D
Message édité par lestanquet le 21-12-2025 à 10:36:43
n°11459344
Fouge
Posté le 21-12-2025 à 10:37:49  profilanswer
L'IA est déjà présente dans la plupart des outils qui permettent de dev/concevoir un jeu vidéo.
Ensuite que de l'IA générative soit utilisée pour des textures "temporaires"... j'vois pas ce qu'il y a de décevant, c'est pas ça qui a fait que ce jeu est une pépite ou non, Clair Obscur est justement un bon exemple de créativité humaine :jap:
Cette histoire c'est vraiment chercher des poux :o
edit: ceci dit c'est très bien que ce règlement existe et que la sanction soit tombée (même si ça peut sembler sévère)
Message édité par Fouge le 21-12-2025 à 10:53:42
n°11459346
It_Connexi​on
Posté le 21-12-2025 à 10:43:03  profilanswer
Si c'est juste pour des textures soit...
n°11459350
burn2
Posté le 21-12-2025 à 10:51:47  profilanswer
Heu je pense que toutes les personnes ici présentes ont réagis dans le cadre de clair obscur.
On profite tous des "joies" de l'ia dans le cadre de notre travail et de toutes les dérives en découlant.
Et pas que dans le cadre du travail vu toutes les bouses qui sont pondues partout que ça soit en video ou autre et qui ne sont que du gaspillage de ressource.
EDIT: @Lestanquet t'as enlevé ton message c'est pas bien. :o
Message édité par burn2 le 21-12-2025 à 10:52:25
n°11459352
lestanquet
Posté le 21-12-2025 à 10:57:15  profilanswer
Ça édite entre temps, donc mes messages n’ont plus lieu d’être.
ATI - Problème avec les CATALYST 3.5 +Question concernant ATI 9800 Pro avec HP80A : chaud brulant !!!!!
Probleme Hydravison et ATIAti Radeon 9600 Pro > Gigabyte HIS Saphire ou Club 3D ?
[Topic Unique] ASUS P4C800 / P4P800 (Intel i865/i875)les CG ATI 9xxx les + o/cables , quelle marque ?
Performance des differentes cartes ATI et Nvidia ??LEADTEK A 360 FX 5700 ou ATI 9600 PRO ?
Plus de sujets relatifs à : [Topic Unique] Radeon™ Software Adrenalin 2020 Edition ● CG & APU !
