4651 connectés
 Page :   1  2  3  4  5  ..  710  711  712  ..  1592  1593  1594  1595  1596  1597
[Topic Unik] Applications Android - read the FP noob !!!
n°1502180
Astroya
Posté le 21-08-2013 à 14:29:23  profilanswer
Fredouye a écrit :
Receive Android notifications on your computer with Krome
http://phandroid.s3.amazonaws.com/ [...] 40x376.jpg
If you’ve been looking for a way to streamline your digital life, Krome might just be the utility app you’ve been looking for. Working together with the Chrome web browser, Krome can push real time notifications from your Android device, onto your computer.
For those apps you don’t want to popping up on your computer (Facebook has a tendency to kill productivity), you can disable specific apps from showing notifications on Chrome. The best part? You can even quickly reply to SMS messages directly from the notification using your computer. Genius.
 [:implosion du tibia]
J'installe :jap:
n°1502181
vave
Nice to meet me
Posté le 21-08-2013 à 14:35:13  profilanswer
Ça se passe par quel moyen la connexion pc <=> mobile ?
Faut être sur le même réseau wifi comme airdroid v1 ou c'est comme airdroid v2 ?
Bel ours Vave, je me dois de l’admettre. -Skyl"win"-  Mais toi tu es intelligent -Homerde- - Ce génie -SkylWINd- JDD S16M72 10:43:46 GMT-DTC +1
n°1502185
Fredouye
Shivers !
Posté le 21-08-2013 à 14:40:16  profilanswer
Ca fonctionne aussi en 3G :)
Le dernier arrivé est fan de Phil Collins
n°1502191
Jileo
Posté le 21-08-2013 à 14:52:38  profilanswer
foul a écrit :
Swiftkey Cloud Out & Installed ! :D
Alors ça donne quoi ? :D
n°1502199
giHefca
occupé à ne rien faire
Posté le 21-08-2013 à 15:06:24  profilanswer
The app uses a secure connection to transfer the data. All notifications are sent via Google Cloud Messaging service. We keep small portions of data (app icons etc) on our servers and right after receiving notification on Chrome, we delete them. You can encrypt your data with your own key, which is NOT synced (you have to enter it in both apps).
n°1502205
LeNullos
Posté le 21-08-2013 à 15:12:38  profilanswer
Jey-B a écrit :
Permet de commander la partie serveur depuis le tél.
Tu fais ça comment ? J'ai Subsonic sur mon tel mais je n'ai jamais vu cette option (enfin, j'utilise Dsub mais c'est identique à peu de choses près)...
JB
n°1502208
Jey-B
Posté le 21-08-2013 à 15:13:56  profilanswer
"Jukebox" de mémoire.
www.aurora-maniacs.com - Tout sur les aurores boréales : prévisions aurores, explications, infos pour organiser un voyage en Laponie, photos..
n°1502216
vave
Nice to meet me
Posté le 21-08-2013 à 15:23:52  profilanswer
n°1502245
Twiddy
Posté le 21-08-2013 à 16:16:07  profilanswer
Un moyen de nettoyer la liste de ses anciennes applis sur google play ?
J'ai de super vieilles applis dans cette liste qui me polluent complètement quand je cherches les applis que j'ai payées.
n°1502260
brestos
Délire d'homme très mince
Posté le 21-08-2013 à 16:30:37  profilanswer
J'ai vu que c'était possible sur le téléphone, dans "mes applications" et l'onglet "toutes", les applications qui ne sont pas installées ont une petite croix en haut à droite, qui les supprime de ta liste d'applis
n°1502270
Twiddy
Posté le 21-08-2013 à 16:45:03  profilanswer
Arf ok, c'est mieux que rien mais c'est nettement moins confortable que sur PC.
n°1502280
Eife
Juste avant le .G - Topic de
Posté le 21-08-2013 à 16:58:41  profilanswer
un appui long sur la vignette d'un appli sur le coté : tu passe en selection multiple et zou :)
n°1502296
Jileo
Posté le 21-08-2013 à 17:20:28  profilanswer
Ça bloque chez moi là connexion au cloud de SwiftKey, c'est parce que j'ai pas l'application google+ ?
n°1502302
tommy febr​uary6
Posté le 21-08-2013 à 17:32:02  profilanswer
Je viens de mettre à jour tapatalk et la màj est payante. Je pense que quand le parc de smartphones installé sera à maturité ça risque de devenir courant sinon des boîtes comme swiftkey ne vendront plus rien car tous les clients potentiels l'auront déjà. Et après on aura le droit aux abonnements à la office 365 avec des apps en location à l'année :-(
n°1502320
Jileo
Posté le 21-08-2013 à 18:29:45  profilanswer
C'était bien ça.
n°1502331
Fredouye
Shivers !
Posté le 21-08-2013 à 18:52:07  profilanswer
En fait Tapatalk HD et Tapatalk ont "fusionné", mais Tapatalk 4 est une MAJ gratuite seulement pour Tapatalk HD.
n°1502367
Origan
Posté le 21-08-2013 à 19:36:54  profilanswer
Anéfé. Je n'avais que le HD et maintenant j'ai la v4 sur mon téléphone également sans avoir rien payé de plus.
n°1502373
foul
Amiga forever...
Posté le 21-08-2013 à 19:49:55  profilanswer
Nouvelle version de Google Keep avec les rappels (basé sur le temps ou le lieu) Yes !!!
http://officialandroid.blogspot.fr [...] -keep.html
edit : apk : https://www.dropbox.com/s/rxr0dk1kp [...] keep-2.apk
Message édité par foul le 21-08-2013 à 22:57:30
n°1502374
brasil
Posté le 21-08-2013 à 19:51:12  profilanswer
Kanwulf a écrit :
Je crois qu'il souhaite juste changer d'appli météo car celle installée d'origine sur son smartphone ne lui convient pas :)
@brasil : Si par exemple tu veux une autre météo comme "weather pro" comme tu l'a mentionné précédemment, tu vas sur le site Google Play (voir lien ci-dessous) et tu télécharges la météo que tu veux.
https://play.google.com/store/apps/ [...] mg.android
Tu peux aussi télécharger les applis météo directement depuis ton smartphone en allant sur l'icone "Play Store"
Ensuite si tu souhaites vraiment désinstaller l'ancienne météo il te faudra les droits root, tu peux déjà dans un premier temps simplement virer les widgets/raccourci pour ne plus les avoir sous les yeux ;)
Tu as tout compris; par contre comment faire pour supprimer la météo qui est affichée d'origine sur ton écran? Car télécharger une autre météo fait qu'elle va remplacer automatiquement l'autre? J'y crois pas!
n°1502378
fafarex
Posté le 21-08-2013 à 19:53:51  profilanswer
Mais sur quel écran à la fin !   :pt1cable:
Tu parle de façon tellement vague que l'on ne sais toujours pas exactement ce que tu veux changer  [:tim_coucou:1]
n°1502379
Kanwulf
Posté le 21-08-2013 à 19:55:30  profilanswer
Tu laisses ton doigt appuyé 2sec sur la météo et tu la déplaces en bas de l'écran, une icône corbeille ou dans le genre devrait apparaitre :)
« Le monde est fondé sur le principe que tous les êtres humains doivent bouffer de la merde, que le goût leur plaise ou pas »
n°1502384
Jileo
Posté le 21-08-2013 à 19:57:41  profilanswer
Ah ça devient intéressant là, je vais retester :D
n°1502394
bluedragon​38
Posté le 21-08-2013 à 20:11:41  profilanswer
Swiftkey avec le cloud alléluia ! Manque plus que la barre de chiffre sur le dessus :D
Topic Vente
n°1502412
Origan
Posté le 21-08-2013 à 20:42:41  profilanswer
Et des flèches sur la version tablette, bordel [:corten:1]
Oui il y en a, mais elles sont bien cachées. Et ils les casent sans problème sur les téléphones  [:syr01]
n°1502413
foul
Amiga forever...
Posté le 21-08-2013 à 20:46:55  profilanswer
Sont dans les options les flèches .. activables ou non ;)
n°1502426
Eife
Posté le 21-08-2013 à 21:10:01  profilanswer
et pas que sur tablette :o
n°1502446
Fredouye
Shivers !
Posté le 21-08-2013 à 21:31:46  profilanswer
Chrome 29 dispo :)
n°1502466
ToonSpirit
PSN & Xboxlive : ToonSpirit
Posté le 21-08-2013 à 21:55:59  profilanswer
Ca sert à quoi le cloud sur un clavier ?
Nippon ni mauvais ! Mon Feedback
n°1502470
bitubo
GT Turbo Addict
Posté le 21-08-2013 à 21:58:28  profilanswer
pour les saisies prédictives entre plusieurs appareils :jap:
j'ai synchro mon S3 et ma Nexus 7 avec Swiftkey aussi
Message édité par bitubo le 21-08-2013 à 21:58:57
n°1502473
ToonSpirit
Posté le 21-08-2013 à 22:01:45  profilanswer
Ok, j'y ai pensé mais je me suis dit qu'il y avait peut être une autre fonctionnalité moins évidente, merci ;)
n°1502495
foul
Amiga forever...
Posté le 21-08-2013 à 22:57:04  profilanswer
Hop apk : https://www.dropbox.com/s/rxr0dk1kp [...] keep-2.apk
n°1502513
toto408
free porn
Posté le 21-08-2013 à 23:52:36  profilanswer
J'ai l'option pour les flèches que sur mon tel :o peut-être est-ce parce que j'utilise le clavier séparé en 2 sur tablette :??:
OverClocking-Masters
n°1502517
Origan
Posté le 22-08-2013 à 00:19:26  profilanswer
Sur la version tablette? Ce serait nouveau... Ce n'etait toujours pas dans la derniere beta.
Message édité par Origan le 22-08-2013 à 00:23:10
n°1502534
tombig
Il est où mon avion?
Posté le 22-08-2013 à 06:53:09  profilanswer
Donc chrome 29 est à nouveau meilleur que chrome bêta? [:klemton]
n°1502540
brasil
Posté le 22-08-2013 à 07:41:07  profilanswer
Merci pour la réponse; et le nouvelle meteo s'affiche automatiquement sut l"écran de demarrage ou il y une manip à faire?
n°1502542
vave
Nice to meet me
Posté le 22-08-2013 à 07:49:15  profilanswer
Tu laisses ton doigt appuyé 2sec sur l'écran et tu choisis "nouveau widget" ou quelque chose comme ça. Tu dois voir la liste des widgets dispo, tu cherches celui de ta nouvelle appli météo.
n°1502703
brasil
Posté le 22-08-2013 à 12:48:32  profilanswer
ok merci je teste
n°1502890
mirzmirz
L'eau, l'air, ma bite.
Posté le 22-08-2013 à 17:28:35  profilanswer
je suis tout nouveau dans l'univers android avec un nexus 4
petit question :
Existe t'il une solution efficace pour avoir une notification du nombre de sms/emails non lu ?
Je trouve que la petite icone en haut de l'écran n'est pas hyper voyante...
EDIT : SMS Popup (vu sur la FP, j'étais passé à coté lors de ma 1ere lecture)
Message édité par mirzmirz le 22-08-2013 à 17:35:10
n°1502895
thony94
Posté le 22-08-2013 à 17:40:18  profilanswer
DashClock est pas mal aussi pour l'écran de verrouillage.
n°1502957
tommy febr​uary6
Posté le 22-08-2013 à 18:55:32  profilanswer
Tu installes apex/nova, le nombre de messages manqués s'affiche dans une petite pastille dans un coin de l'icône sms/mail.
n°1502982
Tempus_Fug​it
tempinou
Posté le 22-08-2013 à 19:25:33  profilanswer
ActiveNotifications est pas mal aussi. Mais fonctionne que sur écran Amoled.
[SONDAGE] HTC Desire ou Sony Ericsson X10 ?Androïd Market application console
Android sur N97 miniBouygues, limite de 5mo et Android
[Topic Unique] HTC DesireGPS bluetech bloqué sur la page d'accueil
Bye Bye Windows 7 ... Hello Android 2.xProblèmes avec applications BlackBerry Curve 8520
[Topic Unique] LG GW620 ( Android) , dispo 2.2 (non officiel)Installer google android sur un HTC jade touch
Plus de sujets relatifs à : [Topic Unik] Applications Android - read the FP noob !!!
