4082 connectés
 Page :   1  2  3  4  5  ..  307  308  309  ..  1593  1594  1595  1596  1597  1598
[Topic Unik] Applications Android - read the FP noob !!!
n°872737
isa1ko
ex- isamu1024
Posté le 12-12-2011 à 21:43:49  profilanswer
tounsi54 a écrit :
Y a pas de mal je compatis clairement  :D
Sinon ces skins pour swiftkey on les trouve ou ?
Et sinon un conseil pour une app pas intrusive pour flasher les codes barres
Je dis pas intrusive car j'en avais vu une sur le market mais qui avait acces à mes contacts ! Le rapport pour flasher des codes  :pfff:
rajouter en contact quelqu'un qui ajoute ses coordonnées en Qr Code sur sa carte de visite ?
n°872758
foul
Amiga forever...
Posté le 12-12-2011 à 21:55:39  profilanswer
Barcode scanner.
Why does Barcode Scanner want access to ...
... my contacts?
QR Codes and Data Matrix codes can encode contact information. Upon scanning such a code, you will be prompted to add the contact information to your contacts list. In addition, Barcode Scanner can encode a contact as a QR Code and present it on-screen, so that a friend can point their phone at your screen to transfer that contact. This is why the app requests permission to write and read contacts. They are not used in any other way.
... my browser history and bookmarks?
Just like contacts, you can share a bookmark with a friend by encoding the URL as a QR Code. It is then shown on screen for him or her to scan with their phone. That's the only thing we use them for.
... my SD card?
Faut pas être parano non plus :-)
You can use Barcode Scanner to email a generated QR code or your scan history. To do this, the barcode image / history CSV file must first be written to device storage, which is why the permission is needed. As a bonus, this makes this output available for retrieval from your SD card directly. It is not used for any other purpose.
n°872776
tounsi54
Posté le 12-12-2011 à 22:07:34  profilanswer
Je savais pas qu'on pouvait faire ça :D
foul a écrit :
Barcode scanner.
... my contacts?
... my SD card?
Ok merci pour ces précisions. Donc selon vous pas de souci alors ?
Je suppose donc que toutes les app de flascode accède à ses informations ? J'ai pas le choix ?
Message édité par tounsi54 le 12-12-2011 à 22:08:18
n°872779
M Poulpe
La porte était ouverte...
Posté le 12-12-2011 à 22:08:51  profilanswer
Ou installer LBE Privacy Settings, qui demandera validation en cas de demande louche.
A +
Flickr
n°872782
tounsi54
Posté le 12-12-2011 à 22:11:58  profilanswer
Ah merci je connais pas du tout, je vais chercher des informartion sur cette app  :jap:
n°872800
Gremlin
Posté le 12-12-2011 à 22:26:28  profilanswer
isa1ko a écrit :
non, aucun n'arrive à égaler correctement, j'ai aussi ce lag pénible à la saisie sur le Nexus S ou le S2 ...
Vous devez vraiment taper à la vitesse de l'éclair pour avoir un lag sur le clavier!  [:kriskraft]
n°872893
tounsi54
Posté le 12-12-2011 à 23:55:22  profilanswer
GO keyboard à l'air pas mal !
On peut configurer le son de tape, il y a le modèle Iphone et j'ai vu le thème Iphone aussi sur l'android market !
C'est ce que je cherchais.
Par contre le clavier est en quwerty comment passer en azerty ? J'ai bien télécharger le dico francais sur le market.
EDIT : J'ai décoché l'anglais dans input et c'est bon
Message édité par tounsi54 le 12-12-2011 à 23:58:00
n°872937
Mak Fouent​e
You killed the wrong girl
Posté le 13-12-2011 à 05:55:51  profilanswer
minux a écrit :
Je viens de découvrir AirDroid, vraiment sympa cette appli de gestion du tel sur PC :)
Je viens de tester vite fait, c'est juste énorme [:ojap]
Par contre j'ai pas encore tripatouiller à fond mais on peut pas passer des appels depuis le pc ? Les sms on peut ce qui est déjà pas mal, mais le vocal ce serait tip-top.
-That's why god made extra bullets
n°872973
Takuya007
GT : Tak le Kuya
Posté le 13-12-2011 à 08:55:29  profilanswer
hello, je cherche une appli ou ptet meme une fonction d'android qui me permette de basculer tous les appels entrant vers la messagerie mais sans couper les données.
Is there anybody out there ?
n°873042
koinkoinko​in
ʞoıuʞoıuʞoıu
Posté le 13-12-2011 à 10:45:01  profilanswer
isa1ko a écrit :
les skins de go keyboard ou swiftkey ne change rien au put**** de lag du clavier. Le seul a peu près correct fut un leak du clavier de ICS installable sur gingerbread.
Ca doit dépendre des téléphones alors[:ninja c3]... Absolument aucun lag sur Swiftkey pour ma part (galaxy S, 2.3.5)
J'avais essayé LazyDroid il y a quelques temps. Il était très lent en mode Wifi mais il proposait un mode usb qui était assez convaincant, y a la même chose sur airdroid?
n°873048
Dephi
Posté le 13-12-2011 à 10:49:04  profilanswer
knahos a écrit :
B'swar  [:cetrio:1]
Vous savez s'il existe une app sympa pour le suivi de colis, hormis celle de la poste qui manifestement est a chier ????
ou 'Suivi par Droid'
http://www.android-software.fr/suivi-par-droid
C celle que j'utilise
n°873117
dafunky
Posté le 13-12-2011 à 11:40:04  profilanswer
Yen a qui utilisent Ice Scream Sandwich? J'aimerais savoir ce que ça vaut...
n°873152
Mak Fouent​e
Posté le 13-12-2011 à 12:18:40  profilanswer
Sur Android 2.3.3 (je parle de celui que j'ai sous les yeux) on peut bloquer tous les appels entrants dans paramètres>appeler>paramètres de blocage d'appels>appels entrants.
Seul problème, je viens d'essayer et il demande un "mot de passe des appels non autorisés" et je n'ai aucune idée de ce que ça peut être :d
Sinon au niveau des applis il y a call blocker, mais il ne me semble pas qu'il propose de renvoyer les appels sur le répondeur, et je ne suis même pas sûr qu'il propose de bloquer tous les appels entrants.
Bref, si quelqu'un a une solution, ça m'intéresse aussi.
J'ai essayé aussi Lazydroid du coup, et je n'ai pas trouvé ça particulièrement lent, après ça dépend sans doute ce que l'on fait. Pour envoyer des sms c'est rapide (airdroid aussi bien que Lazydroid) mais j'avoue que je n'ai pas fait beaucoup de copie de fichiers etc, qui est peut-être assez lent en wifi, par rapport à l'usb.
Mais l'une comme l'autre application ce qui serait vraiment extra, c'est de pouvoir répondre et passer des appels avec le micro-casque sur le pc. Lazydroid, contrairement à airdroid propose de passer des appels et répondre mais il met juste le téléphone en mode haut-parleur.
J'ajoute qu'il n'y a pas de mode usb pour AirDroid.
n°873319
Bonusk
Naaah
Posté le 13-12-2011 à 15:16:26  profilanswer
Day 8 deals:
    HD Widgets
    Instant Heart Rate PRO
    Flight Track
    Train Conductor 2
    Where's My Water
    All By Myself - Little Critter
    Color & Draw for kids HD
    Shazam Encore - repeat from day 4
    Christmas HD - repeat from day 2
    Flick Golf - repeat from day day 2
    Slide IT Keyboard - repeat from day 5
    Sketchbook Mobile - repeat from day 1
http://www.androidpolice.com/2011/ [...] t-10-each/
Message édité par Bonusk le 13-12-2011 à 15:17:14
FEEDBACK - TRANSACTIONS HARDWARE
n°873374
Takuya007
GT : Tak le Kuya
Posté le 13-12-2011 à 16:16:59  profilanswer
En fait j ai trouve simplement dans les parametres d appel.
dans transfert d appel, on peut choisir toujours transferer et mettre le numero de la messagerie
n°873382
Mak Fouent​e
Posté le 13-12-2011 à 16:23:42  profilanswer
C'est à dire ? C'est le numéro que tu appelles pour avoir ton répondeur ou bien ?
Et ça va pas être facturé en plus comme un transfert d'appel classique ?
Edit : Ah ok en fait j'ai vu qu'il y a déjà un numéro pour transférer en cas de ligne occupée etc..., donc ça doit être pareil, donc à priori ça ne doit pas être facturé, faut espérer :d
Edit² : Je viens de me rendre compte aussi que quand j'appelle mon répondeur (chez bouygues) il me propose de taper 5 pour les options de blocage d'appels, et ensuite il propose d'envoyer tous les appels entrants vers la messagerie.
Message édité par Mak Fouente le 13-12-2011 à 16:44:06
n°873427
palos_de_l​a_frontera
Posté le 13-12-2011 à 16:48:34  profilanswer
n°873950
Comet
Posté le 13-12-2011 à 22:09:50  profilanswer
Hello :)
Je cherche une application qui donne l'équivalent du mode avion, mais avec la possibilité d'activer la radio... si quelqu'un a une idée?
n°874023
ddong
Posté le 13-12-2011 à 22:37:33  profilanswer
J'ai installé seesmic, super mais soucis: Malgré l'option lancer au démarrage du système, bah il se lance pas :o J'ai oublié quoi? Suis en 2.3.4 Sony officiel.
n°874266
brisssou
8-/
Posté le 14-12-2011 à 09:03:00  profilanswer
essaie de poser le widget (y en a surement un) sur ton home, ça lancera l'appli
en tout cas j'ai réussi que comme ça avec tweetdeck
HFR - Mes sujets pour Chrome - Firefox - vérifie les nouveaux posts des topics suivis/favoris
n°874284
Fredouye
Shivers !
Posté le 14-12-2011 à 09:30:57  profilanswer
MiLocker, développé à la base pour la ROM MIUI, est disponible : http://app.miui.com/index_en.html
http://lh4.ggpht.com/xaV4AtferuF3qx8suIFtfNQUw7Q6YkkBbq26chY4L-VxL2sez326wxNxeZayxDkw0LrH99WC3Gs6UQPd=s128-chttp://lh6.ggpht.com/HT4CWoCv4LsygoOliBl63E8I5-NUsYFvF3H-OKpdW6cKhIMHfu92Q7wTFJLUCd9PAuGqnF209UHTjDSc=s128-c
(Android 2.3 et plus)
Message édité par Fredouye le 14-12-2011 à 09:31:18
Le dernier arrivé est fan de Phil Collins
n°874506
Fredouye
Shivers !
Posté le 14-12-2011 à 13:09:04  profilanswer
Retour de Swiftkey X à 10 centimes  [:cerveau hurle]
[1] SwiftKeyX **
[2] Sleepy Jack
[3] Deer Hunter 3D
[4] EzPDF
[5] Tank Riders
[6] Zenonia
[7] Collapse
[8] MX Moto
[9] Guns and Glory
[10] Toddler Tapping Zoo
** indicates repeat
n°874509
foul
Amiga forever...
Posté le 14-12-2011 à 13:13:32  profilanswer
putain je me jette dessus des qu'il est la !  :bounce:
n°874512
Fredouye
Shivers !
Posté le 14-12-2011 à 13:19:11  profilanswer
https://market.android.com/details? [...] e.swiftkey :o
n°874514
le_pere_no​el2
Jeux de merde
Posté le 14-12-2011 à 13:20:42  profilanswer
essayez vite fait marche mal sur ICS
n°874515
chris1092
ஹலோ
Posté le 14-12-2011 à 13:22:25  profilanswer
[1] SwiftKeyX **
[2] Sleepy Jack
[3] Deer Hunter 3D
[4] EzPDF
[5] Tank Riders
[6] Zenonia
[7] Collapse
[8] MX Moto
[9] Guns and Glory
** indicates repeat
ça change à quel heure ?
n°874517
chris1092
ஹலோ
Posté le 14-12-2011 à 13:25:52  profilanswer
n°874526
Posté le 14-12-2011 à 13:31:55  answer
C'est moi ou les autorisations qu'il demande sont délirantes? [:klemton] accès contacts, sms, etc.
n°874533
isa1ko
ex- isamu1024
Posté le 14-12-2011 à 13:35:54  profilanswer
Pourquoi donc ?
accès contact pour afficher lors d'un appel entrant la fiche du contact quand le tel est verrouillé
pour les sms, le locker peut dire combien de sms reçus via une petite notification
etc...
il est utilisé depuis un moment sur MIUI et n'a jamais posé le moindre problème ...
Par contre c'est bien le soucis sur Android, les demandes d'autorisations sont génériques et même si on prend le temps de lire les accès demandés, avant de tester l'app on a aucun moyen de voir ce pourquoi cette dernière à besoin de ces privilèges.
Les différents cas d'appli pourrie dernièrement rajoute un peu à la méfiance générale
Message édité par isa1ko le 14-12-2011 à 13:40:40
n°874544
take it or​ leave it
Posté le 14-12-2011 à 13:44:15  profilanswer
Le vieux lag juste avant le verouillage du tél [:kluruit]
J'ai un Desire S pourtant [:tinostar]
n°874558
M Poulpe
Posté le 14-12-2011 à 13:54:19  profilanswer
J'ai une bonne nouvelle : Avec LBE Privacy Guard il n'y a plus de souci. Tu peux "couper" les autorisations qui te dérangent, ou les laisser en suspend jusqu'à ce que l'application fasse une demande.  :)
A+
n°874603
electrocut
Posté le 14-12-2011 à 14:39:13  profilanswer
LBE Privacy Guard n'a jamais très bien marché sur mon HTC Desire 2.3 :(
- Des fuites mémoires à gogo, après 1 jour, LBE prenait 90 Mo de Ram, et Android killait application sur application pour libérer de la mémoire ...
- Après quelques jours, je pouvais utiliser le GPS depuis les applications que j'avais pourtant interdites ...
J'ai donc dû le désinstaller. Dommage, car l'idée était très bonne.
n°874610
M Poulpe
Posté le 14-12-2011 à 14:44:44  profilanswer
Je l'utilise depuis deux mois sans aucun problème (SGS2, ROM 2.3 stock). Si ton expérience est plus ancienne, la version 2.xx est présentée comme une grosse refonte.
A+
Message édité par M Poulpe le 14-12-2011 à 14:45:16
n°874661
Quenteagle
Talk to me, Goose
Posté le 14-12-2011 à 15:25:34  profilanswer
 [:wark0]
téléchargé à l'instant, depuis le temps que je l'attendais !
n°874675
Posté le 14-12-2011 à 15:36:22  profilanswer
Tain mais les mecs qui voulaient pas lâcher 2 euros [:ddr555]
n°874677
methanol
111 & Rolex FeveR
Posté le 14-12-2011 à 15:37:23  profilanswer
[1] SwiftKeyX **
[2] Sleepy Jack
[3] Deer Hunter 3D
[4] EzPDF
[5] Tank Riders
[6] Zenonia
[7] Collapse
[8] MX Moto
[9] Guns and Glory
** indicates repeat
Merci de l'info, première appli que j'achète  [:korner:1]
A base de popopop
n°874749
nicogun
Homo Sapiens Internetus
Posté le 14-12-2011 à 16:42:04  profilanswer
Encore 80% de jeux  [:absolut_limon]
Feedback achats et ventes
n°874812
Quenteagle
Talk to me, Goose
Posté le 14-12-2011 à 17:12:46  profilanswer
 :whistle:
Je l'ai essayé quelques minutes, c'est vraiment le jour et la nuit avec tout ce qui se fait d'autre. SlideIT lui arrive péniblement à la cheville. Pratique que Swift key propose d'analyser les emails/sms/FB pour bâtir une base de mots avant même la première utilisation.
Si j'avais su que j'apprécierai ce clavier à ce point j'aurai probablement lâché mes 2€ :)
n°874817
ham_mer
Posté le 14-12-2011 à 17:16:26  profilanswer
Par contre ils abusent, 7.54Mo et pas déplaçable sur la SD  [:prozac]
RTX 3090 - i9 9900K - 32GB DDR4 - M.2 1TB SSD / Topic London
n°874845
Quenteagle
Talk to me, Goose
Posté le 14-12-2011 à 17:27:01  profilanswer
Quand j'avais un Desire c'était vraiment mon problème principal, même en ayant partitionné la carte SD.
A présent, avec le GS2 c'est le cadet de mes soucis :D
n°874855
isa1ko
ex- isamu1024
Posté le 14-12-2011 à 17:28:50  profilanswer
A+
J'utilise MIUI et la rom intègre un module qui gère les permissions, d'ailleurs cette dernière enlève de facon systematique la surveillance des appels.
Message édité par isa1ko le 14-12-2011 à 17:29:27
[SONDAGE] HTC Desire ou Sony Ericsson X10 ?Androïd Market application console
Android sur N97 miniBouygues, limite de 5mo et Android
[Topic Unique] HTC DesireGPS bluetech bloqué sur la page d'accueil
Bye Bye Windows 7 ... Hello Android 2.xProblèmes avec applications BlackBerry Curve 8520
[Topic Unique] LG GW620 ( Android) , dispo 2.2 (non officiel)Installer google android sur un HTC jade touch
Plus de sujets relatifs à : [Topic Unik] Applications Android - read the FP noob !!!
