4977 connectés
 Page :   1  2  3  4  5  6  7  8  9  10  11  12  13  14  15
Le DTS, c'est tout simplement hallucinant !
n°190154
HAL
Pas un jour sans un but
Posté le 21-01-2002 à 13:07:58  profilanswer
très intéressante comme donnée
je ressorts ma spêc. SP/DIF
bandwith occupation : 100KHz up to 6MHz (no DC)
avec  une bande passante comme celle-ci, on fera passer du 2048kb/s sans soucis
PS : no dc kesako :??: si quelqu'un sait
n°190159
DTSman
Keep Of The Sound
Posté le 21-01-2002 à 13:14:09  profilanswer
The stereo CD is a 16-bit medium with sampling at 44.1 kHz. Professional audio has been 20- or
24-bit for some time, and there is increasing interest in higher sampling rates both for recording
and for delivery into the home. Greater bit depths provide extended dynamic range. Higher
sampling rates allow wider frequency response and the use of anti-alias and reconstruction filters
with more favorable aural characteristics.
DTS has been delivering ?better-than-CD quality? throughout its home-audio history. DTS music
and video soundtracks are not only discrete multichannel, but up to 24-bit audio.
When DVD-video appeared, it became possible to deliver 24-bit, 96 kHz audio into the home, but
only in two channels, and with serious limitations on picture. This capability has had little use.
DVD-audio allows 96/24 in six channels, but a new player is needed, and only analog outputs are
provided, necessitating the use of the D/A converters and analog electronics provided in the
player.
DTS 96/24 offers the following:
1. Sound quality transparent to the original 96/24 master.
2. Full backward compatibility with all existing decoders. (Existing decoders will output a
48 kHz signal)
3. No new player required: DTS 96/24 can be carried on DVD-video, or in the video zone
of DVD-audio, accessible to all DVD players.
4. 96/24 5.1-channel sound with full-quality full-motion video, for music programs and
motion picture soundtracks on DVD-video.
5. 96/24 through the S/P-DIF output. DTS 96/24 allows the use of external, very high
quality D/A converters and associated analog electronics chosen by the users.
Tuto ColorHCFR : Home-cinema & Multimedia
n°190167
Drdrake
Pourfendeur d'atmo
Posté le 21-01-2002 à 13:21:17  profilanswer
direct component (partie continue)
n°190204
HAL
Posté le 21-01-2002 à 14:35:48  profilanswer
n°232142
Nashtbg
無駄だ
Posté le 17-03-2002 à 15:28:03  profilanswer
Je viens d'ecouter le bataille du debut de gladiator en DTS sur seulement 2 enceintes....  :ouch: c GENIAL !!!!!!!!!!
 :love: DTS :love:
n°233533
PierRick
Posté le 19-03-2002 à 13:18:22  profilanswer
Tu m'étonnes je sais c'est royal [:olimou]!
Y'a un truc qui me déçoit : j'ai gagné le 25/12/01 le DVD de Démo DTS n°4 sur les années laser.com, et j'ai toujours pas reçu! Quelqu'un est dans le même cas que moi?
n°233835
DTSman
Keep Of The Sound
Posté le 19-03-2002 à 17:17:11  profilanswer
Bizarre! tu devrais leur téléphoner!
Pour ma part j'attends de recevoir les DVD de demo 5 et 6 histoire de faire péter le caisson et de compléter ma ptite collection ;)
n°233941
Nashtbg
無駄だ
Posté le 19-03-2002 à 18:14:04  profilanswer
DTS :love:
n°233944
DTSman
Keep Of The Sound
Posté le 19-03-2002 à 18:15:46  profilanswer
Je dirais même plus : DTS FOREVER ;)
n°234152
PierRick
Posté le 19-03-2002 à 20:40:06  profilanswer
Comment tu fais pour les avoir :??:?
n°234220
DTSman
Keep Of The Sound
Posté le 19-03-2002 à 22:12:13  profilanswer
N'ayant point de stand DTS au dernier salon son et image, je n'ai guere eu le choix que de les commander chez dvdscore.
n°234244
PierRick
Posté le 19-03-2002 à 22:48:23  profilanswer
Ok, j'ai été voir le site, et j'ai vu qu'il n'ont eu que 19 exemplaires du DVD Démo n°, comment est-ce que je peux savoir si ils leur en reste :??: :( ?
Edit (Piaf) : J'ai mal lu : ils ONT 19 pièces en stock donc c'est bon je peux le commander [:olimou]!
A+ :D
[jfdsdjhfuetppo]--Message édité par PierRick--[/jfdsdjhfuetppo]
n°234245
DTSman
Keep Of The Sound
Posté le 19-03-2002 à 22:51:26  profilanswer
Le son DTS va encore fuser dans nos salles ;)
n°234247
PierRick
Posté le 19-03-2002 à 22:57:46  profilanswer
Ca y est, le 5 et le 6 sont commandés [:olimou] [:super chinois]!!
Je te dis dès que je les ai :)!
A+
n°234459
DTSman
Keep Of The Sound
Posté le 20-03-2002 à 12:30:27  profilanswer
Moi aussi :hap:
n°234484
PierRick
Posté le 20-03-2002 à 13:01:46  profilanswer
Tu les as commandé quand? A priori c'est 48H donc ça fait vendredi pour moi :)!
n°234491
PierRick
Posté le 20-03-2002 à 13:05:17  profilanswer
Sérieux là j'ai les boules :sweat:...
C'est ça que tu as commandé? http://www.dvdscore.com/DVDscore/f [...] 1000000120
Moi je les ai acheté séparément, j'en ai pour 85? je crois :cry:!
n°234497
PierRick
Posté le 20-03-2002 à 13:08:21  profilanswer
J'ai vu qu'il existe 3 versions du Demo 5 : http://www.dvdscore.com/DVDscore/c [...] Rechercher
http://www.dvdscore.com/DVDscore/f [...] VD&ID=2126
C'est quoi la différence, l'un est à 29?, l'autre à 44?, et l'autre à 58?!
n°234653
DTSman
Keep Of The Sound
Posté le 20-03-2002 à 15:31:59  profilanswer
Perso, j'ai choisi, le pack 5 & 6 d'un coup d'un seul ;)
C'est en effet moins cher...
n°234783
PierRick
Posté le 20-03-2002 à 17:10:38  profilanswer
:cry: franchement :cry:
n°234788
PierRick
Posté le 20-03-2002 à 17:12:23  profilanswer
La seule différence entre le tien et le mien est que ton Demo 5 est Zone ALL NTSC, alors que le mien est Zone 2... :sweat:
25? en plus pour ça ça fait reuch' :cry:!
n°234811
DTSman
Keep Of The Sound
Posté le 20-03-2002 à 17:32:10  profilanswer
Si la difference réside dans le format vidéo PAl ou NTSC ce n'est pas bien grave. Et puis j'aime bien le NTSC ;)
Pour la difference d'argent ce n'est pas bien grave, ça arrive parfois...
n°234908
PierRick
Posté le 20-03-2002 à 19:36:03  profilanswer
Ouais, et puis de toute façon c'est fait...
Sinon là je maile Les Années Laser parce que du coup je vais avoir le 5 et le 6 avant le 4, alors c'est pas bien grave mais je le veux bien quand même ce-foutu-dvd-que-j'ai-gagné-y'a-trois-mois :D!
n°235714
PierRick
Posté le 21-03-2002 à 18:16:22  profilanswer
DVD Demo DTS n°4 et 5
Suivi de commande : Etat --> Commande envoyée : :love::love:!
n°235722
RukoDWI
Posté le 21-03-2002 à 18:26:45  profilanswer
Compare les pistes DTS et DD5.1 du DVD d'Incassable (regarde la scène de la pluie vers la fin) c'est hallucinnant  :eek2:
Da West Indies c'est de là que vient la lumière
n°235835
byron
Posté le 21-03-2002 à 20:35:53  profilanswer
Quelqu'un sait ce qu'il faut que je fasse pour pouvoir lire un wav DTS?
Mon Audigy est reliée en coax numerique sur mon ampli DTS, mais quand je lis le wav (media player, powerdivx...) j'ai un pschhhhh. et rien d'autre :(
[jfdsdjhfuetppo]--Message édité par byron--[/jfdsdjhfuetppo]
n°236116
DTSman
Keep Of The Sound
Posté le 22-03-2002 à 13:40:01  profilanswer
ça c'est une bonne question ;)
Certains sont parvenus à lire des fichier DTS depuis leur disque dur en utilisant winamp et aucun plugin! Le hic est qu'ils ne possedaient pas un sblive mais une autre carte son.
Avec ma sblive, le seul moyen d'écouter mes piste DTS, c'est de les graver sur CD puis de les lire avec un soft comme WinDVD et PowerDVD. Là le son sort bien par la prise spdif...
n°236206
byron
Posté le 22-03-2002 à 16:03:51  profilanswer
Si tu ne le grave pas, tu as bien ce pshhhhhh equivalent a un enregistrement ou il n'y aurait que du bruit?
Je vais essayer ca quand j'aurais du bon wav dts, parce que la, pour un seul.....
Si seulement j'avais hotel california en DTS  :love:
n°236295
DTSman
Keep Of The Sound
Posté le 22-03-2002 à 17:20:36  profilanswer
Le grésillement obtenu est normal, il est du au fait que ta carte son croit que c'est un fichier wav pcm stéréo classique donc elle le décode et voilà le résultat affreux...
n°236297
byron
Posté le 22-03-2002 à 17:22:22  profilanswer
Je m'en doute ;) Je vais rechercher s'il n'y aurait pas un chtit plug-in. Parce que bon un CD-R pour deux-trois extrait, c'est dommage.
n°236299
byron
Posté le 22-03-2002 à 17:24:02  profilanswer
n°236309
DTSman
Keep Of The Sound
Posté le 22-03-2002 à 17:36:23  profilanswer
Je te le fais pas dire, c'est pourquoi je n'en grave aucun en ce momment ;)
En tout cas si tu trouve un plugin fais m'en part.
n°236350
byron
Posté le 22-03-2002 à 18:30:08  profilanswer
"The multichannel sound requires a player which is compatible with digital audio extraction such as WinAmp with the Digital Audio Plug-in and proper sound card."
n°236367
PierRick
Posté le 22-03-2002 à 19:06:33  profilanswer
J'ai reçu aujourdh'ui les DVD de Demo DTS n° 4, 5, et 6 :love::love:!!! Tous le même jour ça rulezzzz :love:!
Je me suis mater et remater le #4 : putain comment c'est de la bombe :love::love:!!
Le concert des Eagles il déchire tout, putain la qualité sonore c'est hallucinant, l'utilisation des canaux et des surrounds est super bien faite wahou!!
Vivement que je me mate la suite :D!
A+ :hello: !  :)
n°236388
Ninipc
Réalisé sans trucage
Posté le 22-03-2002 à 19:43:46  profilanswer
c'est des simples ou des doubles faces les dvd de demo DTS? [:nofret] :ange:
n°236474
PierRick
Posté le 22-03-2002 à 22:48:12  profilanswer
Je comprends pas ce que tu veux dire...
Ils sont simple face mais je comprends pas le sens de la question...
n°236487
byron
Posté le 22-03-2002 à 23:09:20  profilanswer
A+ :hello: !  :)
C'est quel cd de demo qui comporte un extrait des eagles?
Il vaut combien?
Apparement sur le site de creative labs, l'audigy est "incapable de lire un cd dts de musique,mais peut lire un DVD via un ampli qui decode le DTS" :(
n°236491
PierRick
Posté le 22-03-2002 à 23:19:46  profilanswer
Il vaut combien?
C'est le DVD de demo n°4, et tu peux le gagner "facilement en jouant sur le site des années laser, sois patient et tu le gagneras forcément :)! --> http://www.annees-laser.com/jeux-dts4.php3
Moi j'ai gagné au bout de 94 participations, sachant qu'on peut jouer une fois par jour, et d'ailleurs c'est la meilleure solution pour gagner : jouer tous les jours... Certains gagnent en ayant joué 3 fois le bol... :)!
Sionon si tu es pas patient, tu peux l'acheter ici! --> http://www.dvdscore.com/DVDscore/f [...] 1000000108
Le délai est très bon, reçus (5 et 6) en 3 jours... :)
A+
n°236501
Ninipc
Posté le 22-03-2002 à 23:33:42  profilanswer
je voulais dire couches
n°236503
byron
Posté le 22-03-2002 à 23:40:25  profilanswer
Encore là :D
Grrr, toujours pas trouve comment ripper cette piste dts du dvd :D
n°236506
Ninipc
Posté le 22-03-2002 à 23:42:59  profilanswer
déjà faut ripper les vob, ensuite le seul truc que je connaisse qui permet de sortir le dts c'est vobrator je crois. En clair, tu rip tout le dvd en découpant par cell-id (je pense) ca devrait séparer par chansons, ensuite une fois que t'as le bon vob t'essayes d'extraire la piste DTS avec vobrator
[jfdsdjhfuetppo]--Message édité par Ninipc--[/jfdsdjhfuetppo]
WinDVD 3 with DTS supportAvoir du DTS ave un lecteur pc ?
SB Live! + CD DTS et AC3???DTS qui marche pas tjs, des solutions ???
URGENT PLEASE SOUND BLASTER LIVE 5.1 + AMPLI DOLBY DIGITAL DTS 5.1comment extraire la piste DTS d'un film ?
Liste des DVD avec une piste en DTS (zone 1&2)Trailer DD / DTS / THX
DTS*Gladiator des sales craquements ds les arrières : whyLE DTS !
Plus de sujets relatifs à : Le DTS, c'est tout simplement hallucinant !
