4551 connectés
 Page :   1  2  3  4  5  ..  14  15  16  ..  52  53  54  55  56  57
foobar2000 (v0.7.x et 0.8.x uniquement) - les composants
n°575394
skeye
Posté le 21-01-2004 à 13:35:24  profilanswer
hpl-nyarlathotep a écrit :
foo_tunes 0.0.5 aplha
type: user interface
foobar version: 0.7.7b
compenent version: 0.0.5 aplha
* buggy explorer tree completely rewritten
* instant reaction of progress bar
* config - playlist font
[g]* config - enable/disable hotkeys (may collide with standard UI keys, use ctrl or alt combinations)
[/g]
Téléchargement.
Topic.
Si les raccourcis clavier se mettent à marcher ca devient intéressant!:D
[edit]
Ca semble marcher! [:volta]
Message édité par skeye le 21-01-2004 à 13:39:28
n°576012
hpl-nyarla​thotep
I failed in life
Posté le 22-01-2004 à 18:33:27  profilanswer
La blacklist des plugins selon zZzZzZz lui-même:
Current banlist (as for 0.8):
- foo_vis_samurize - repeated crash reports, no signs of author fixing the problem
- foo_mirc - repeated crash reports
Known potential troublemakers:
- foo_looks - playlist_format_title_ex crash fixed in latest version
- foo_syfm - repeated weird crash reports, can't identify whether foo_syfm was to blame or not but there were no other suspicious components loaded
- foo_audioscrobbler - repeated crash reports, there are known issues but the author is working on it; supposedly latest version has been stable
- foo_contextsort - repeated crash reports under 0.7.7
If you are an author of one of above and have fixed the issue, please send me a PM to get this list updated.
n°576048
Tang
Plug'n'Troll
Posté le 22-01-2004 à 20:17:32  profilanswer
Lol j'ai cru à un canular avec ton éditiond e titre!!! :lol:
A+ HPL (PS j'ai commencé "Le cachet noir" d'Arthur Machen...)
• • • "La démocratie c'est bien mais il faudrait que les gens soient pas cons..." © Alpacou aux Nouilles • • •
n°576075
karlkox
Posté le 22-01-2004 à 21:32:47  profilanswer
Attend, j'arrive, je vais mettre à jour mes plugins tient, et à moi la célébrité :D
n°576076
karlkox
Posté le 22-01-2004 à 21:33:25  profilanswer
n°576111
hpl-nyarla​thotep
I failed in life
Posté le 22-01-2004 à 22:55:22  profilanswer
Mise à jour:
Quick Tag 0.5a
Compiled with 0.7.7 final sdk on 2004.01.21
Allows you to set predefined metadata fields to files through context menu, aimed at easy rating of files by assigning to keyboard shortcuts.
Note: Ideal solution would be masstagger scripts in context menu, but until then this will do the job.
n°576113
Tang
Plug'n'Troll
Posté le 22-01-2004 à 23:00:26  profilanswer
Eh eh j'ai de l'influence on dirait... (edition de titre)
En meme temps c'est normal je suis député sur discu:
>>>Tang sacré député par décision unilatérale<<<
[:rofl]
Message édité par Tang le 22-01-2004 à 23:00:50
n°577643
hpl-nyarla​thotep
I failed in life
Posté le 26-01-2004 à 14:11:59  profilanswer
foo_tunes 0.0.6 aplha
compenent version: 0.0.6 aplha
* minor fixes
* flicking has been reduced on win2k
* synchro button on explorer toolbar/menu
* added configuration
* playlist font
* header on/off
* hotkeys on/off
* editable columns with any foobar string format
Téléchargement.
Topic.
Message édité par hpl-nyarlathotep le 26-01-2004 à 14:12:15
n°577918
panzemeyer
The torture never stops
Posté le 26-01-2004 à 22:24:13  profilanswer
Je suis en train de faire l'expérience de l'inconvénient principal des plugins (qui sont souvent très utiles on est bien d'accord) : certains ne sont pas compatibles avec la dernière version de foobar, ce qui le fait planter systématiquement. Par ex. chez moi impossible de faire un clic droit avec la 0.77b :/ Il faut alors identifier quel est le component coupable, et ensuite attendre que son développeur le mette à jour :/
n°577923
hpl-nyarla​thotep
I failed in life
Posté le 26-01-2004 à 22:29:26  profilanswer
Le coupable est foo_context_sort.
En fait, si on sélectionne plusieurs pistes, le clic droit ne pose pas de problème, mais avec une seule piste de sélectionné -> crash. C'est ça?
J'en ai fait l'expérience aussi. PP l'a mis dans sa blacklist.
n°578206
_man_
Posté le 27-01-2004 à 15:46:02  profilanswer
Le rythme des releases s'accélère pour foo_tunes :).
foo_tunes 0.0.7 aplha
compenent version: 0.0.7 aplha
* minor fixes
* added background color of column
* stripes mode can be now turned off
Téléchargement.
Topic.
Premières impressions : Il me semble que footunes permette maintenant les mêmes personnalisations de playlist que l'interface par défaut (tests en cours  ;) ) ; c'est d'la balle  :sol:.
Cela dit, je trouve que cette interface alourdit un peu trop foobar (jamais content... :ange: )
Edit : grammaire...
Edit 2 : il y a encore pas mal de bugs  :sweat: ...
Message édité par _man_ le 27-01-2004 à 17:20:31
n°578527
_man_
Posté le 28-01-2004 à 09:52:38  profilanswer
Première version béta de Footunes dite Milestone 0.1.0.  :)
compenent version: 0.1.0
* MILESTONE 0.1.0
* minor fixes
* better algorithm for sizing cover sheet images
* better looking (professional:) toolbar icons (old-style ones still in da package)
Téléchargement.
Topic.
Je ne parviens cependant toujours pas à faire fonctionner mon string avec  :( .
n°578612
skeye
Posté le 28-01-2004 à 13:24:43  profilanswer
* MILESTONE 0.1.0
* minor fixes
Téléchargement.
Topic.
tu dois être sex!:o
Je fonce tester!
n°578669
_man_
Posté le 28-01-2004 à 14:26:49  profilanswer
n°579123
tomati
Posté le 29-01-2004 à 09:55:08  profilanswer
dans foo_tunes 1.0 , pour avoir les boutons de commande ( play , pause etc... ) il faut se mettre en old mod ? , comment puis-je le faire , car dans new mod , j'ai rien et j'arrive pas à trouver le moyen pour passer au old mod .
n°579282
Tang
Plug'n'Troll
Posté le 29-01-2004 à 14:42:04  profilanswer
skeye a écrit :
tu dois être sex!:o
[:rofl]
(j'aurai voulu la faire!)
n°579317
inti
t'as mieux mais tapir
Posté le 29-01-2004 à 16:18:41  profilanswer
heu, y a tjrs pas la possibilité d'avoir une interface genre itunes, avec un classement par tags comme itunes par exemple ?
Genre avoir 3 fenetres de la db ouvertes ?
n°579346
hpl-nyarla​thotep
I failed in life
Posté le 29-01-2004 à 17:33:03  profilanswer
Pouquoi ne pas demander à PP lui-même si tu n'as pas peur qu'il essaie de te dévorer?  :D
n°579799
hpl-nyarla​thotep
I failed in life
Posté le 30-01-2004 à 11:54:57  profilanswer
Je viens de mettre en ligne un site centralisant les composants de foobar2000:
http://foobar2000.free.fr/
Commentaires et suggestions bienvenus.
n°579800
skeye
Posté le 30-01-2004 à 11:55:30  profilanswer
kyle a jeté le sien?
n°579874
Sylver---
Not a geek. Just a human 2.0
Posté le 30-01-2004 à 14:50:18  profilanswer
Ben, ça ne marche po..
j'arrive pas a y acceder, free doit merdre
je recommencerais plus tard !
^_^
n°579882
Sylver---
Posté le 30-01-2004 à 15:00:59  profilanswer
C'st bon ça marche !
Donc bien bien bien, le design est parfais, clair et pas trop couleur, les couleurs n'agressent pas, donc de coté la...  +1
Les plug-in sont bien classé, à chaque fois une petite note d'explication... donc toujours +1
donc moi je dis bravo, bravo !!
On l'a attendu un peu ce site, et je ne le regrette pas du tout !
du tres beau boulot !! :) :)
^_^
n°580223
Gurney_Hal​leck
dévisage des figures
Posté le 31-01-2004 à 11:39:21  profilanswer
salut à tous
j'ai un petit pb avec les codecs suivant :
foo_osd
foo_shuffle
foo_id3v2
(ils sont tous du même auteur : http://www.cqasys.com/projects/kode54/)
au lancement de foobar, j'ai une erreur "stricmp_utf8" et il n'arrive pas à charger le composant.
J'ai la dernière version officielle 0.7.7b, sous win xp
quelqu'un aurait une idée ?
Merci d'avance  :hello:
(j'ai recherché dans le topic, mais j'ai rien trouvé à ce sujet :/)
n°580235
zegilles
Posté le 31-01-2004 à 12:06:00  profilanswer
Ils ont été mis à jour pour la version 0.8, la compatibilité étant brisée avec les versions précédentes de foobar.
n°580238
zegilles
Posté le 31-01-2004 à 12:08:17  profilanswer
C'est vrai qu'il est bien ce site :)
n°580242
Tang
Plug'n'Troll
Posté le 31-01-2004 à 12:26:41  profilanswer
Surtt la page de "credits"... :lol:
Salut zegilles ;)
n°580304
hpl-nyarla​thotep
I failed in life
Posté le 31-01-2004 à 14:07:55  profilanswer
Le site a été présenté sur ha.org:
http://www.hydrogenaudio.org/index [...] =18136&hl=
Question: doit-il être traduit en anglais sachant qu'il existe déjà un site demi-non-officiel-semi-officiel (pour reprendre l'expression)?
Tang: n'hésite pas à demander à quelqu'un disposant de quelques compétences en anglais si tu comptes y intervenir.
“What came first – the music or the misery?” ― Nick Hornby, High Fidelity
n°580311
Tang
Plug'n'Troll
Posté le 31-01-2004 à 14:17:15  profilanswer
Euh je demande à quelqu'un de le tarduire c'ets ça?
(j'atetnds confirmation pour pas faire de boueltte, nénanmoins je suis inscrit donc pas de bleme ;)
n°580836
hpl-nyarla​thotep
I failed in life
Posté le 01-02-2004 à 18:21:11  profilanswer
foo_infobox
v1.3.6 uploaded
no new feature added,just compiled for SDK 0.8b3
download link
n°580840
inti
Posté le 01-02-2004 à 18:32:00  profilanswer
Rah oui :love:
C'est long 2 jours à attendre, merci hpl !
n°581106
zoreil_
Posté le 02-02-2004 à 10:55:22  profilanswer
:love: :jap:
n°581601
Mick4U
GamerTag: Mick4U
Posté le 03-02-2004 à 01:28:47  profilanswer
Salut, j'utilise FooBar2000 depuis un moment déjà, et je trouve ce soft terrible comme vous tous, seulement il me sert aussi de convertisseur MPC>MP3 pour mon autoradio, seulement il m'est venu une idée: un diskwriter qui ne ferais que seulement copier les zik qu'il lit de là où elles se trouvent vers l'emplacement spécifié dans le diskwriter, avec bien sur (d'où l'interêt) le remaniement répertoire/nom de fichier personnlisable comme ça une belle playlist que j'écoute sur mon PC je la transpose prête à être gravée sur CD
Genre un peut de tout de mes divers artiste sur une playlist
et qu'il me met tout par artiste comme je lui demande mais seulement ce qu'il y a dans la playlist, ce qui m'évite de copier/coller manuellement les chanson que je veux dans ma ture par album... vu que parfois nombre de zik par album sont sautée d'où gain de place
n°581603
hpl-nyarla​thotep
I failed in life
Posté le 03-02-2004 à 01:31:11  profilanswer
Ca a été effectivement déjà été demandé sur le forum officiel: un diskwriter qui écrit sans encoder (qui copie seulement en fait).
Pas vu encore malheureusement.
n°581604
Tang
Plug'n'Troll
Posté le 03-02-2004 à 01:37:25  profilanswer
Ca existe peut etre déjà pour le mp3:
suffit p'ttre de convertir en WAV avec l'extension mp3 comme aveec Vdub pour extraire une bande son mp3 sans transcoder...
C'es pas possible?
n°581605
Mick4U
GamerTag: Mick4U
Posté le 03-02-2004 à 01:39:25  profilanswer
ah oui mais là le but dans Vdub était de faire de patcher un Wav avec un header mp3 mais ça restait physiquement un wav
n°581608
hpl-nyarla​thotep
I failed in life
Posté le 03-02-2004 à 01:42:44  profilanswer
Je crois que vous ne parler pas de la même chose.
n°581610
Mick4U
GamerTag: Mick4U
Posté le 03-02-2004 à 01:44:05  profilanswer
je pense aussi lol
sinon rigolez mais je viens de tenter avec CLI encoder, en mettant copy, xcopy et xcopy32 en spécifiant bien sur leur chemin et ça marche pas, ça freeze loool
l'idée était bien là!!
n°581612
Tang
Plug'n'Troll
Posté le 03-02-2004 à 01:55:21  profilanswer
J'ai effectivement bien rigolé... Ce sont des exeutables en mode DOS mais pas le systeme d'exploitation DOS!!!
n°581616
Mick4U
GamerTag: Mick4U
Posté le 03-02-2004 à 02:00:57  profilanswer
ah oui mais j'avais bien spécifier leur place, vu que pour les XCopy c un fichier exe lol
n°581618
Tang
Plug'n'Troll
Posté le 03-02-2004 à 02:02:09  profilanswer
Le monde est cruel ;)
A+
n°581623
Mick4U
GamerTag: Mick4U
Posté le 03-02-2004 à 02:07:53  profilanswer
quand même lol
encore un couche tard aussi
Foobar2000 v0.7 RC5 & LA 0.4 !!??peut on choper uniquement l'instru d'une chanson?
recherche tagger de mp3 pour faire uniquement cela :Problème de son avec KG7 + SB128 PCI (uniquement en acquisition video)
foobar2000 : désormais en version 2 et 64 bit[Topic Unique] Foobar2000 le successeur de Winamp
vob -> avi (uniquement un chapitre) : quel soft ?foobar2000, radio sur le net ca marche ??
[prob]Winfast xp2000 deluxe uniquement mono :(CUSTOM : concours du plus beau Foobar2000
Plus de sujets relatifs à : foobar2000 (v0.7.x et 0.8.x uniquement) - les composants
