5531 connectés
 Page :   1  2  3  4  5  ..  115  116  117  ..  2952  2953  2954  2955  2956  2957
### [Matos] - News - Spéculations et même des vertes et des pas mûres
n°1233009
Cygne_d_Et​ang
Punk's not dead
Posté le 13-10-2006 à 12:48:32  profilanswer
on peut avoir le brut de la femme de Kitagawa plutot en mp ? :o
n°1254402
alainphoto
Posté le 26-10-2006 à 11:25:49  profilanswer
encore des rumeurs ... qui ne parlent pas beaucoup de stabilisation  :fou:
http://www.dcresource.com/forums/s [...] hp?t=24045
Canon is working hard on the next generation of DSLR's, all of which are built around DIGIC III. By PMA next year, Canon will refresh the entire range (except the 400D) with new cameras which boast the following standard features.
    * DIGIC III
    * Anti-Dust
    * Lower noise, higher ISO (> 3200), higher dynamic range
So with those bits in mind, the source went on to talk about the upcoming models.
The 30D's sucessor will have the following improvements.
    * Improved sensor as described above. Not the same as the one in the 400D.
    * DIGIC III
    * Still 5 FPS
    * More AF points and faster and more accurate AF.
    * Anti-Dust
    * 1.6X Crop Factor
Obviously, no price range was given since these are prototype products, but you can imagine that the price will be similar ($1299 sounds about right).
Pretty believable stuff. Now we get to the interesting part which is related to the 5D AND is very consistent with the hefty rebates on the 30D and 5D that you will see next month.
The 5D will be partitioned into two models, a lower end model and a higher end model.
The Lower Model would be a repackaged 5D in a smaller 30D-sized body with DIGIC III, Anti-Dust, and improved AF (like the 30D successor). This would sell for less than the 5D goes for currently. If I had to a venture a guess, somewhere in the low $2000's would be about right, or even $1999 if Canon were feeling generous.
The Higher Model would include a new 16 MP sensor like the 1DS Mark II (though not the same), DIGIC III, improved AF like before, and a 5 FPS burst rate rather than 3 FPS. This would sell for a similar price to the current 5D. I would guess that $2999 would be about right.
The source is pretty reliable as he visited Canon Japan to preview these cameras and broke the news on the 400D very accurately. This all sounds pretty plausible, otherwise I wouldn't be reporting it.
Message édité par alainphoto le 26-10-2006 à 11:25:58
Photographie du Japon
n°1254405
Toxin
Carpe ★★ Vitam
Posté le 26-10-2006 à 11:26:55  profilanswer
Feraient bien de faire un 1600 plus propre avant d'aller chatouiller le 6400, tiens.
n°1254414
Cygne_d_Et​ang
Punk's not dead
Posté le 26-10-2006 à 11:30:18  profilanswer
et de bons viseurs (on peut pas greffer un viseur de reflex argentique simple, clair et degagé, m'en fiche moi du rappel des infos, t'as qu'a regarder le lcd)
n°1254421
alainphoto
Posté le 26-10-2006 à 11:32:15  profilanswer
bah de toutes façons pour moi, gagner une "vitesse" en terme de qualité ISO ne me fera pas dépenser plusieurs milliers d'euros :o
donc j'attendrais probalement le modèle de dans deux ans (putain :D) en priant pour qu'il ait la stab :) c'est pas plus mal ça m'aidera probalement à éviter de folles dépenses :D
et alors au lieu d'être avec le 20D sur mon 70-200 2.8 à 200mm sur f4 + iso 800 + 1/320 eme je pourrais faire du f4 + iso 1600 + 1/100 :love:
n°1254454
Poogz
Posté le 26-10-2006 à 11:46:36  profilanswer
Prend un 70-200 f2.8 ou f4 IS :o
n°1254459
Anathema
Justice for all...
Posté le 26-10-2006 à 11:47:54  profilanswer
Tu crois pas que c'est un peu ce que suggère le "lower noise" dans la partie caractéristiques standards des nouveaux modèles ?
n°1254610
Toxin
Carpe ★★ Vitam
Posté le 26-10-2006 à 13:25:31  profilanswer
Tu ne crois pas que c'est du vaste pipeau marketing d'élucubrer sur un boitier qu'on ne verra pas avant un an ?
Il serait plus rationnel de faire du 1600 et du 3200 plus propre avant d'aller chercher plus haut, plutôt que de nous servir une soupe de propos lénifiants.
n°1254611
Anathema
Justice for all...
Posté le 26-10-2006 à 13:28:05  profilanswer
Je cherche le rapport et je reviens.
n°1254716
Poogz
Posté le 26-10-2006 à 14:35:31  profilanswer
Au revoir Anath, on t'aimais bien mais on va pas te revoir avant longtemps  :sweat:
n°1254735
alainphoto
Posté le 26-10-2006 à 14:48:53  profilanswer
un peu cher le 70-200 IS  :o 1000 € pour la stab non merci je suis pas crésus  :D
je préfère attendre un boitier stabilisé, ok c'est moins bien, mais c'est universel et bien moins cher ... dans l'idéal j'aurais un 17-55 (ou un 27-70 en FF) 2.8 IS et un 70-200 IS bien sûr, le tout sur un 1Ds mkII évidement  :D envoyez vos dons  [:acherpy]
Clair, au niveau market c'est les pixels et les hauts ISO qu'ils vont vendre, mais ce que les photographes veulent, c'est un 800 impécable et un 1600 très bon  :) (actuellement sur mon 20D je passe le 800 sans soucis mais le 1600 que si je suis forcé)
Enfin c'est bien qu'ils travaillent sur les ISO, ils vont p'tet se calmer un peu sur les pixels du coup :D
Message édité par alainphoto le 26-10-2006 à 14:49:58
n°1254739
Poogz
Posté le 26-10-2006 à 14:50:04  profilanswer
je préfère attendre un boitier stabilisé, ok c'est moins bien, mais c'est universel et bien moins cher ... dans l'idéal j'aurais un 17-55 2.8 IS et un 70-200 IS bien sûr, le tout sur un 1Ds mkII évidement  :D envoyez vos dons  [:acherpy]
[:paysan] Tu risque d'attendre longtemps (même si tu gagne au loto)
n°1254741
JeanY
ça le fait grave...
Posté le 26-10-2006 à 14:50:46  profilanswer
ça serait bien qu'ils pensent à travailler la dynamique du capteur aussi...
après, pour les pixels, c'est bon, y'en a assez
Ma galerie : Lanzarote page 25
n°1254742
alainphoto
Posté le 26-10-2006 à 14:50:52  profilanswer
c'était un exemple, j'ai d'ailleurs édité :)
n°1254747
Anathema
Justice for all...
Posté le 26-10-2006 à 14:53:06  profilanswer
Tu crois pas que c'est un peu ce que suggère le "higher dynamic range" dans la partie caractéristiques standards des nouveaux modèles ?
n°1254835
Poogz
Posté le 26-10-2006 à 15:56:00  profilanswer
[:azylum]
n°1254836
Oxygen3
Tears from the moon
Posté le 26-10-2006 à 15:56:07  profilanswer
Tu vas chercher le rapport et tu reviens aussi ? :D
Metro-Pole ▬ Réseau A Suivre...: Annuseries|LeVillage|pErDUSA
n°1254896
Toxin
Carpe ★★ Vitam
Posté le 26-10-2006 à 16:38:25  profilanswer
[:azylum]
Premier post de plus de trois mots de Poogz sans faute :o
n°1254912
Anathema
Justice for all...
Posté le 26-10-2006 à 16:43:28  profilanswer
Coup sous la ceinture, 1er avertissement.
n°1254916
Toxin
Carpe ★★ Vitam
Posté le 26-10-2006 à 16:44:59  profilanswer
Je me disais que j'avais heurté un 300 f/4 dans la manoeuvre :o
n°1254917
Poogz
Posté le 26-10-2006 à 16:45:21  profilanswer
n°1254920
Cygne_d_Et​ang
Punk's not dead
Posté le 26-10-2006 à 16:46:29  profilanswer
et en plus, avec des mots de plus de 3 lettres [:aloy]
n°1254922
Poogz
Posté le 26-10-2006 à 16:47:25  profilanswer
Peut etre même qu'il comprend pas tous les mots :o
n°1254932
Anathema
Justice for all...
Posté le 26-10-2006 à 16:52:03  profilanswer
Il doit être lénifié :o
n°1254935
Poogz
Posté le 26-10-2006 à 16:54:20  profilanswer
Dans une soupe [:dark]
n°1254940
Toxin
Carpe ★★ Vitam
Posté le 26-10-2006 à 16:56:34  profilanswer
Au marketing.
n°1254946
Toxin
Carpe ★★ Vitam
Posté le 26-10-2006 à 16:57:58  profilanswer
Bon bordel de chiotte, il me les envoie mes colis high tech, ce satané vendeur d'outre Rhin ?
n°1254949
Poogz
Posté le 26-10-2006 à 16:59:30  profilanswer
T'y crois si peux à l'envois du colis que tu poste dans le topic spéculation....
n°1254955
Toxin
Carpe ★★ Vitam
Posté le 26-10-2006 à 17:01:22  profilanswer
Voilà enfin tout ça pour dire qu'avec ces annonces de Canon pour leur prochain boitier num, je vais me mettre plus activement encore à l'argentique :D
n°1254962
Poogz
Posté le 26-10-2006 à 17:03:43  profilanswer
C'est sur qu'avec les boitiers num actuels, plus moyen de faire des tophs :/
n°1254968
Toxin
Carpe ★★ Vitam
Posté le 26-10-2006 à 17:06:32  profilanswer
Je vais surtout pas faire la même chose (MF).
n°1254970
Poogz
Posté le 26-10-2006 à 17:07:48  profilanswer
Donc finalement rien à voir avec ce topic :d
n°1254979
Anathema
Justice for all...
Posté le 26-10-2006 à 17:13:51  profilanswer
Rien à voir non plus avec des annonces de Canon, ce n'est qu'une rumeur et qui date au moins de mi-septembre [:anathema]
Message édité par Anathema le 26-10-2006 à 17:14:16
n°1255035
Oxygen3
Tears from the moon
Posté le 26-10-2006 à 17:54:07  profilanswer
n°1255036
Anathema
Justice for all...
Posté le 26-10-2006 à 17:55:09  profilanswer
Oxygen3 a écrit :
voire de mi-aout :o
Je parlais de la rumeur telle quelle (au mot près).
n°1255037
Oxygen3
Tears from the moon
Posté le 26-10-2006 à 17:55:37  profilanswer
elle est sortie juste apres la pré annonce du 400D :o
n°1256004
tharkun
Je suis un Génie !
Posté le 27-10-2006 à 04:07:42  profilanswer
je vais revendre mon 30d bientôt moa :sol:
meilleur AF, et plus d'iso propres, ça me branche bien :love:
je pense par contre qu'on pourra attendre longtemps la stab des capteurs chez canon :)
je savais pas que le système anti dust du 400d ne faisait que faire vibrer le filtre devant le capteur par contre jusqu'à ce que je démonte le bouzin :ouch: le capteur lui ne bouge pas :o
n°1256024
Jubijub
Parce que je le VD bien
Posté le 27-10-2006 à 07:53:23  profilanswer
vous z'avez qu'à arreter d'être pauvres et acheter des optiques IS/VR, non mais :o
Jubi Photos : Flickr - 500px
n°1256042
Poogz
Posté le 27-10-2006 à 08:36:03  profilanswer
[:tartragnan]
n°1256045
herissonal​unettes
Posté le 27-10-2006 à 08:37:05  profilanswer
Je croyais que c'etait de la merde la stab par capteur, que la stab a la canon c'etait mieux!
A oui, mais bon c'est vrai que personne ne peux s'acheter la stab canon, et que maintenant que presque tt le monde l'aura sauf canon, ca doit faire raler!
Je pense aussi que canon va mettre du temps a sortir une stab boitier, car de tte facon, ca ne se rajoutera pas a la stab objectif, donc si il la sortent, ca risque de rendre la gamme d'objo stabilisés assez caduque!avec un gros manque a gagner!
mais bonfaudra bien compenser le faire, ne desesperez pas, sinon il vont trop perdre de marché amateur!sauf si ils bradent les objo!
n°1256357
Anathema
Justice for all...
Posté le 27-10-2006 à 12:22:54  profilanswer
[:manust]
Plus de sujets relatifs à : ### [Matos] - News - Spéculations et même des vertes et des pas mûres
