3302 connectés
  Air Cooling
  [Topic Unique] Scythe Musashi VGA Cooler
 Page :   1  2  3  4  5  ..  20  21  22  23  24  25
Page Précédente
n°1789711
Derdak
oldskool mapper !!
Posté le 01-09-2008 à 16:31:13  profilanswer
TOPIC - SCYTHE MUSASHI VGA COOLER
http://www.scythe.co.jp/images/kama/musashi/musashi-inst02.jpg
http://www.scythe.co.jp/images/kama/musashi/musashi-inst01.jpg
Voila un ventirad trés intéressant , livré avec deux ventilos scythe de 100mm de diamètre et 12mm d'épaisseur , de quoi se monter un SLI/crossfire sans chauffe et bruit ...
il est aussi question d'un potar sur bracket PCI pour regler les ventilos indépendamment  :love:
trés bon potentiel , pour n'importe quelle carte sur le marché , sauf bien sur les GTX280 et 260 :(
Compatible :
Radeon 9***
Radeon X***
Radeon X1300
Radeon X1600
Radeon X1650
Radeon X1800
Radeon X1900
Radeon X1950
Radeon HD2600
Radeon HD2900 XT
Radeon HD3650
Radeon HD3850
Radeon HD3870
Radeon HD4850
Radeon HD4870 Series
Radeon HD4830
Radeon HD4890
Radeon HD5850
Radeon HD5870
GeForce FX5900
GeForce 6600
GeForce 6800
GeForce 7300
GeForce 7600
GeForce 7800
GeForce 7900
GeForce 8500
GeForce 8600
GeForce 8800GT ( g92 )
GeForce 8800GTS ( g92 )
GeForce 9600
GeForce 9800GTX
GeForce 9800GT
GeForce 9800GTX+
GTS250
entraxes :
http://www.comptoir-hardware.com/images/stories/_cg/entraxes_vga.png
les news :
Scythe Musashi VGA Cooler Spotted in Japanese Stores
Japanese PC cooling specialist, Scythe released the "Musashi" SCVMS-1000 VGA cooler spotted at a Japanese store. This double-fan aluminum cooler suits all popular card designs although the GeForce GTX 200 series isn't advertised.
The cooler consists of an aluminum fin arrays of unequal sizes through which pass four nickel-plated copper heatpipes, two in opposite direction of the other two. The GPU contact block from which those pipes project out itself isn't in the center. On one the other side of the fin arrays are two 100 mm, 12 mm thick PWN controlled fans which have individual speed controls provided by two knobs on an expansion bracket. These regulate the speeds of the fans between 800 and 2500 rpm (combined noise level 12.5 dB to 29.22 dB depending on the fans' rpm).
les tests :
Francais :
- http://www.caseandcooling.fr/refro [...] he-musashi
- http://www.total-tuning.net/module [...] ge&pid=246
- http://www.cowcotland.com/articles [...] sashi.html
Anglais :
- http://www.dreamwarecomputers.com/ [...] /index.htm
comparatif Ventirads GPU chez PuissancePC ( merci DivX :) ) :
- http://www.comptoir-hardware.com/a [...] s-gpu.html
Video sur lesnumeriques : http://www.lesnumeriques.com/news_id-4543.html
Message édité par Derdak le 12-09-2010 à 22:21:47
UT99 singleplayer : Project Zephon
n°1789716
bluedragon​38
Posté le 01-09-2008 à 16:44:26  profilanswer
Preum's  encore un beau rad !! lui le GFX chilla ! :D
Topic Vente
n°1789726
M600
ShitOps Engineer
Posté le 01-09-2008 à 17:02:20  profilanswer
Derdak a écrit :
livré avec deux ventilo scythe de 120mm et 12cm d'epaisseur
:ouch:
"C'est pas après avoir chier dans son froc qu'il faut serrer les fesses". F. Nietzsche. 7 octobre 1870.
n°1789732
Posté le 01-09-2008 à 17:18:05  answer
The pression statique de malade :ouch:
Message édité par Profil supprimé le 01-09-2008 à 17:20:24
n°1789733
Derdak
oldskool mapper !!
Posté le 01-09-2008 à 17:19:23  profilanswer
oops , petite erreur :whistle: .... rectifiée :)
.. par contre , certains sites mentionnent les ventilos comme etant des 120mm , et d'autres des 100mm :/ qui croire ?
n°1789734
Posté le 01-09-2008 à 17:20:31  answer
Ca semble être les mêmes que les ventilos scythe pour le refroidissement des disques durs ITA KAZE (100 x 100 x 12mm) donc des KAZE JYU SLIM
Message édité par Profil supprimé le 01-09-2008 à 17:22:46
n°1789736
Derdak
oldskool mapper !!
Posté le 01-09-2008 à 17:21:38  profilanswer
ah ok , merci du renseignement ;)
n°1789737
bluedragon​38
Posté le 01-09-2008 à 17:23:41  profilanswer
Et puis tu bidouille pour mettre 2x120 au pire :whistle:
Topic Vente
n°1789738
ghe
Posté le 01-09-2008 à 17:24:25  profilanswer
un nouveau concurrent du s1?  :p
hâte de voir se qu'il vaut comparé à lui.
n°1789739
bluedragon​38
Posté le 01-09-2008 à 17:25:27  profilanswer
il est surtout moins epais ... ( avec ventilos )
Message édité par bluedragon38 le 01-09-2008 à 17:25:36
Topic Vente
n°1789740
Derdak
oldskool mapper !!
Posté le 01-09-2008 à 17:27:42  profilanswer
la ou il faut voir , au niveau des perfs , c'est comment le placement des caloducs va agir pour le refroidissement ... ils ne traversent pas le radiateur comme sur le S1 ou le GFXchilla ...
on aura peut-etre droit a une version avec 4 caloducs plus tard :)
Message édité par Derdak le 01-09-2008 à 17:29:03
n°1789744
bluedragon​38
Posté le 01-09-2008 à 17:35:23  profilanswer
Je vois sur la boite c'est pas marqué "hd4xxx family" ...
Ils sont idiots ou quoi de sortir des radiateurs non compatibles avec les CGs récentes ??
Topic Vente
n°1789755
Derdak
oldskool mapper !!
Posté le 01-09-2008 à 17:58:02  profilanswer
la majorité des rads deja compatibles HD3xxx sont compatibles HD4xxx ( parfois quelques modifs sont a effectuer mais en general, y'a pas trop de probleme ) .. je pense qu'il n'y aura aucun probleme pour le mettre sur les nouvelles ati ;)
n°1789922
Posté le 02-09-2008 à 10:48:14  answer
n°1789923
Posté le 02-09-2008 à 10:49:19  answer
Il est bien compatible avec les HD4850 et 4870
http://www.scythe.co.jp/cooler/images/musashi-400.jpg
http://www.scythe.co.jp/images/kama/musashi/musashi-inst4850s.jpg
http://www.scythe.co.jp/images/kama/musashi/musashi-300fu.jpg
Message édité par Profil supprimé le 02-09-2008 à 10:50:37
n°1790049
bluedragon​38
Posté le 02-09-2008 à 18:08:06  profilanswer
Cool ! Avec toute la panoplie pour les VRM et tout ! :love: je crois que je vais craquer sur celui ci quand il sortiras !
Ca date der sortie ... c'est quand ? :whistle:
Message édité par bluedragon38 le 02-09-2008 à 18:08:18
Topic Vente
n°1790068
Derdak
oldskool mapper !!
Posté le 02-09-2008 à 18:59:37  profilanswer
je crois que je vais craquer aussi :love:
il semble etre le meilleur conpromis comparé au T-rad et S1 :)
pas de date annoncée malheureusement :/ enfin pour l'instant , esperons plus d'infos dans les jours a venir ..
merci Sharp pour l'info de compatibilité avec les 4xxx ;)
n°1790211
noobzed
Where is Brian ? DTC !
Posté le 03-09-2008 à 00:09:55  profilanswer
oui mais pas bcp de caloducs :/
n°1790221
beretta93
Posté le 03-09-2008 à 00:29:09  profilanswer
Pas mal pour gagner en place et en silence, mais pour le refroidissement ça ne doit pas être le top.
Reste à voir son prix en france.
>>>FEED<<<
n°1790232
bluedragon​38
Posté le 03-09-2008 à 02:27:17  profilanswer
J'ai l'impression que les caloducs sont quand même plus gros que les S1 ! apres a voir !
Topic Vente
n°1792399
noobzed
Posté le 09-09-2008 à 12:53:53  profilanswer
n°1792409
oizoweb
le fil rouge sur le bouton ?
Posté le 09-09-2008 à 13:33:49  profilanswer
plus en stock :(
Mon topik hardware vide
n°1792410
Derdak
oldskool mapper !!
Posté le 09-09-2008 à 13:34:11  profilanswer
merci a toi noobzed :jap: donc on peut deja dire entre 30-40e ..
Message édité par Derdak le 09-09-2008 à 13:34:55
n°1795865
Terenas
Posté le 19-09-2008 à 16:53:51  profilanswer
drapal sur le topic pour suivre son arrivée
edit :
un test en allemagne qui apparait très prometteur. A comparer au Trad²
http://www.computerbase.de/artikel [...] enkuehler/
edit 2 : dispo vers le 3/10 ici
http://www.caseking.de/shop/catalo [...] 11048.html
Message édité par Terenas le 19-09-2008 à 17:05:39
_.·´¯)Mon feedback(¯`·._ || What shall we die for ?
n°1796130
Derdak
oldskool mapper !!
Posté le 20-09-2008 à 13:32:30  profilanswer
ah ! merci bien Terenas :) ca se presente bien quand meme , aussi bien que le HR03 , et avec deux caloducs en moins :)
n°1796454
zombiie
Posté le 21-09-2008 à 14:03:43  profilanswer
drap :p
n°1796462
bluedragon​38
Posté le 21-09-2008 à 14:27:12  profilanswer
Est ce qu'AC vont sortir un Xtrem pour hd4xxx ? ( sauf si cela a déjà été fait :whistle: ) car bon le radiateur a pas l'air tiptop VS l'extreme :(
Message édité par bluedragon38 le 21-09-2008 à 14:27:26
Topic Vente
n°1796464
zombiie
Posté le 21-09-2008 à 14:30:00  profilanswer
je pense pas que un Xtrem soit prévu pour les HD48*0
n°1798922
m16
Posté le 28-09-2008 à 19:54:04  profilanswer
[:drapo]
n°1798960
cleyt64
On my way !
Posté le 28-09-2008 à 22:42:29  profilanswer
Selon le test indiqué plus haut les caloducs sont de 6mm , j'aurais cru a du 8mm .
En tous cas c'est un bon rad a coté du vf1000 !
Je croix que mon vf1000 va gentillement rester sur ma 8800gt et que je vais attendre avant de changer le rad de ma 4870!
Il est là !!!
n°1798961
crazybiscu​it78
Posté le 28-09-2008 à 22:54:55  profilanswer
Mouais  :heink:
en faite si on trouve les mêmes ventilo ailleurs le S1 est de la même épaisseur
n°1798964
zombiie
Posté le 28-09-2008 à 23:05:05  profilanswer
n°1798965
bluedragon​38
Posté le 28-09-2008 à 23:05:49  profilanswer
Un peux en "retard" ton quote non ? :D
Enfin bref je vais deja voir si je peux réussi a caller mon HR03 r600 ( en le moddant bien entendu ... sur ma hd4870 ! )
Topic Vente
n°1798970
crazybiscu​it78
Posté le 28-09-2008 à 23:19:56  profilanswer
ce qui m'étonnes c'est qu'il ressemble comme 2 gouttes d'eau à celui qui monté sur le shuriken sauf que d'un côté on un 3 fils et de l'autre un 4 fil PWM  :sweat:  dmg
Mieux faut tard que jamais  :p  en plus ça fait genre celui qui lit les thread avant de poster (alors qu'il suffit de répondre à un post au hasard :D )
nan, c'était juste inspiré de ce que madbarth avait fait sur un S1 avec 2 de ces ventilo dessus dans un autre thread... http://img133.imageshack.us/img133/2326/5431024x768mq7.th.jpg  ça en jette hein  :sol:
sauf qu'à 11€ le ventilo + le prix d'un S1 c'est plus très rentable fasse au musashi  :sweat:
j'sais plus quoi faire :(
Message édité par crazybiscuit78 le 28-09-2008 à 23:31:48
n°1799017
Fssabbagh
Satsui no Hado
Posté le 29-09-2008 à 10:38:28  profilanswer
fait plouf plouf  :lol:
Messatsu !
n°1799185
nffg
Hello.
Posté le 29-09-2008 à 17:27:37  profilanswer
Faudrait encore que le Scythe Musashi sois trouvable quelque part en vente...
n°1801989
nffg
Hello.
Posté le 06-10-2008 à 22:42:26  profilanswer
tjs pas de news ? :o
n°1802132
guigs23
Posté le 07-10-2008 à 14:02:01  profilanswer
Personnellement j'ai reçu le Musashi pour test mais j'ai pas eu les dates de disponibilité en magasin.
Topic de vente: http://forum.hardware.fr/hfr/Achat [...] 8206_1.htm
n°1802154
bluedragon​38
Posté le 07-10-2008 à 15:33:18  profilanswer
Alors ca donne quoi réellement :love:
Topic Vente
n°1802163
nffg
Hello.
Posté le 07-10-2008 à 16:27:31  profilanswer
On attend tes impressions alors guigs23 :o
Page Précédente
  Air Cooling
[ Topik Unique ] Vos bureaux rev 3.0ccooler master hyper tx 2
[Topic unique] Quel waterblock pour une HD4870 ?[Topic Unique] Votre avis sur les 10 images limitées par post
[Topic Unique] les waterblocks pour Radeon 4870X2[Topic Unique] Régulation et O/C GTX260
Noctua NF-U12P ou Cooler master GeminII[Topic Unique] Refroidir en air le GT200
[Topic Unique]Overclocking Nehalem Core i7 i5 i3Cooler Master CoolViva Pro : compatible GTS512 ?
Plus de sujets relatifs à : [Topic Unique] Scythe Musashi VGA Cooler
