8479 connectés
 Page :   1  2  3  4  5  ..  324  325  326  ..  347  348  349  350  351  352
[Topic Unique]Overclocking Nehalem Core i7 i5 i3
n°2102250
Zouhir93
Posté le 20-03-2011 à 19:33:58  profilanswer
Merci :jap:
n°2102288
Fouge
Posté le 20-03-2011 à 20:19:06  profilanswer
Attendez, vous comparez le Tj et le Tcase ? Si c'est comme sur les C2D/C2Q, ça n'a aucun sens.
Tcase: Technically this refers to the temperature that you can measure using a thermocouple embedded in the centre of the heat spreader, but this is only done in the factory by Intel or by users willing to drill their heat spreaders open to insert a thermocouple.
Tcase Max: Can be found on the Intel Processor Spec Finder. This is often confused by users as the maximum temperature for the cores, but in actual fact it refers to the maximum temperature that should be reached by the Tcase sensor. This specification is rounded to a relatively precise 0.1 C.
Tjunction: Synonymous with core temperatures and calculated based on the output from the DTS using the formula shown further down in this post*.
Tjunction Max: This is the maximum temperature the cores can reach before the PROCHOT# signal is sent and thermal throttling is activated, although throttling typically occurs a degree or two below this. In this post Tjunction Max refers to either the actual throttling point for a core/CPU or what is used by a temperature monitoring program.
* Tjunction = (Tjunction Max – DTS output)
edit: et ce que renvoient les logiciels, c'est le Tjunction de chacun des cores
Message édité par Fouge le 20-03-2011 à 20:22:05
n°2102293
wolfflyter
Posté le 20-03-2011 à 20:23:53  profilanswer
on parlait de la valeur indiqué par Intel pour le Cpu 920D0 , 67.9 degrès.
該反思的是,往往有幫助
n°2102298
Fouge
Posté le 20-03-2011 à 20:25:56  profilanswer
Oui j'ai bien compris que vous parliez du Tcase Max. Par contre, vous en faites quoi de cette valeur ? Les logiciels renvoient le Tjunction, pas le Tcase.
n°2102309
wolfflyter
Posté le 20-03-2011 à 20:30:44  profilanswer
C'est quoi la valeur Cpu dans le bios ?  :??:
 :whistle:
Message édité par wolfflyter le 20-03-2011 à 20:31:40
該反思的是,往往有幫助
n°2102318
Fouge
Posté le 20-03-2011 à 20:36:24  profilanswer
C'est quoi la valeur CPU dans le bios ?  :??:
 :whistle:
Heu... quelque chose se rapprochant du Tcase ? :whistle:
D'ailleurs, elle se situe où (physiquement) cette sonde ? Pas le souvenir d'avoir vu cette valeur sur toutes les mobos.
n°2102363
tistou77
Geek Inside!!
Posté le 20-03-2011 à 21:38:13  profilanswer
la temp la plus "réel" et celles des cores (TJmax) ;)
celle du CPU n'est pas vraiment fiable (situé sous le socket si j'ai bonne mémoire)
Message édité par tistou77 le 20-03-2011 à 21:39:22
n°2102369
wolfflyter
Posté le 20-03-2011 à 21:46:34  profilanswer
Comme sur le Socket A ?  :D
該反思的是,往往有幫助
n°2102373
tistou77
Geek Inside!!
Posté le 20-03-2011 à 21:49:16  profilanswer
peut être :D
n°2102375
wolfflyter
Posté le 20-03-2011 à 21:51:51  profilanswer
En tout cas concernant la valeur "core" si il est facile de lui faire dire n'importe quoi
il n'en va pas de meme avec la valeur Cpu  :D
該反思的是,往往有幫助
n°2102382
tistou77
Geek Inside!!
Posté le 20-03-2011 à 22:07:14  profilanswer
en effet, on ne peut pas "régler" la valeur CPU (comme avec le TJMax), mais c'est plus la temp du socket que du CPU (vu quelle est situé à ce niveau)
pour les cores, si le TJmax est bien reglé dans le soft de monitoring (en général c'est le cas) c'est buenos :D
dans tout les cas, c'est la temp des cores la plus importante, osef de celle du CPU :D
pour un 920D0 (et autre i7) la temp max (conseillé) à ne pas dépasser sur core en bench est de 75/80° ;)
Message édité par tistou77 le 20-03-2011 à 22:11:17
n°2102398
wolfflyter
Posté le 20-03-2011 à 22:40:56  profilanswer
Chez toi mais pas chez moi :D
je précise que je n'ai pas posé de question concernant la température Cpu ou Cores.
Je n'ai pas de soucis de température ni d'inquiètude ou bug a ce niveau  :jap:
該反思的是,往往有幫助
n°2102405
tistou77
Geek Inside!!
Posté le 20-03-2011 à 22:53:12  profilanswer
c'est pour ca que je répondais à la question posé par Zouhir (je crois) plus haut et non à toi :D
c'est trop d'honneur de me comparer à tout les OCeur experimenté et autre :lol:
je suis flaté :D
mais bon, tu vas bien trouver quelque chose à redire, hein ^^
n°2102407
wolfflyter
Posté le 20-03-2011 à 23:11:36  profilanswer
je suis flaté :D
Elles sont juste tes sondes ?  :D
Voila j'ai dit quelque chose  :p
該反思的是,往往有幫助
n°2102589
Posté le 21-03-2011 à 14:41:28  answer
+1 pour ne se baser que sur la T° des coeurs
Les concepteurs de programmes de lecture connaissent bien les valeurs à appliquer par processeur au DTS
C'était d'ailleur pareil sur Core2, la seule lecture (corrigée) des sondes suffisait amplement
La T° résultante maximum n'a que peu évolué depuis...
Message édité par Profil supprimé le 21-03-2011 à 14:42:08
n°2102598
wolfflyter
Posté le 21-03-2011 à 15:07:03  profilanswer
Vous l'aimez pas la valeur Cpu...........  :D
該反思的是,往往有幫助
n°2102607
Posté le 21-03-2011 à 15:23:37  answer
Car elle n'est pas fiable
Si c'était elle qui devait 'commander', on aurait tellement de Posts vides pour rien...
Message édité par Profil supprimé le 21-03-2011 à 15:24:32
n°2102620
wolfflyter
Posté le 21-03-2011 à 15:35:07  profilanswer
Commander quoi ?
la ventilation du cpu si celui ci est trop chaud par exemple ?  :whistle:
該反思的是,往往有幫助
n°2102636
Posté le 21-03-2011 à 16:03:20  answer
La ventilation n'a rien à voir
Si ça chauffe ça ventile c'est tout
Nous on régule en fonction de ce qu'on voit
& la température qu'on considère comme chaude, c'est celle des coeurs
Imagine que le refroidissement soit mal géré par ta sonde 'Case', genre un coeur @90°C et les autres sous les 75 (syndrome de l'IHS/rad./Block/pâte etc. mal positionnés), que se passe-t-il au sein du CPU?
Bah là c'est pareil, le contrôle se fait et doit se faire en fonction de ce qu'il se passe à l'intérieur car c'est de là que viennent les calories!
n°2102637
Zouhir93
Posté le 21-03-2011 à 16:04:50  profilanswer
Je suis perdu
n°2102640
Posté le 21-03-2011 à 16:08:07  answer
Moi aussi, mais pas par mes dires
Laisse, on n'en sortira jamais de cette histoire tasson
Le Topic Core2 que j'ai eu l'honneur d'animer, faisait sur des pages et des pages le constat que la T° IHS n'était en aucun cas celle qui fallait retenir pour réguler les ventilos...
Ce dont fait allusion wolfflyter, c'est que les cartes mères régulent le ventilateur PWM du CPU en fonction de cette température
Comment est-elle obtenue, pas grand monde ne le sait!
Chaque fabricant ayant apparemment sa formule secrête....
n°2102645
wolfflyter
Posté le 21-03-2011 à 16:32:27  profilanswer
Zouhir93 a écrit :
Je suis perdu
Tu n'as pas a l'etre , tu as eu les bonnes informations chez Intel.
67.9 degrès Cpu pour le 920 D0.
On peut s'amuser a demander des screens des sondes Cpu et core afin d'établir un état des lieux.
Beaucoup de combinaisons sont possibles :
Temp cpu = Temps core, Temp core inferieur a Temp cpu , Temp cpu inferieur a Temp ambiant etc.......
Le sujet est très vaste  :D
該反思的是,往往有幫助
n°2102647
Posté le 21-03-2011 à 16:34:02  answer
Et surtout tellement débattu et tellement arrivé à mâturité
Les enseignements ne sont pas destinés à être remis en question
 [:esrevni] Copyrighté par les constructeurs de mobos de bois [:jesse james:4]
Message édité par Profil supprimé le 21-03-2011 à 16:36:29
n°2102648
wolfflyter
Posté le 21-03-2011 à 16:38:36  profilanswer
Montre lui un exemple cpu , core ?  :whistle:
Message édité par wolfflyter le 21-03-2011 à 16:38:55
該反思的是,往往有幫助
n°2102649
MEI
|DarthPingoo(tm)|
Posté le 21-03-2011 à 16:39:50  profilanswer
Ce que l'on ne sait pas c'est comment la régulation est programmée.
Mais la T° du CPU, bien sur que l'on sait d'où elle vient : du PECI. Si Intel a fait le PECI c'est pour ça hein, pas pour que des softs comme CoreTemp soit fait... :o
n°2102651
MEI
|DarthPingoo(tm)|
Posté le 21-03-2011 à 16:42:38  profilanswer
Merde mon pauvre E4300 il a passé quasi 3 mois en full 24/24 à 92-93°C... :ange:
Et il n'est pas mort...  :whistle:
Tant que tu restes stable et que le throttling ne s'active pas, et donc que tu n'est pas à Tjmax, no soucy, le CPU ne va pas claquer, et n'en souffre pas.
Perso j'ai jamais eu de CPU à moins de 70°C en full... le but de la régulation c'est juste un peu ça... :spamafote:
n°2102652
MEI
|DarthPingoo(tm)|
Posté le 21-03-2011 à 16:44:57  profilanswer
Elle est moins fiable, mais suffisante pour une régulation thermique. Notamment parce que les DTS sont dans les cœurs, et ni dans le contrôleur RAM, ni dans l'IGP, ni dans le L3.
Cette sonde est censé (d'après Intel) être placé dans un endroit stratégique pour avoir une T° "moyenne" du CPU.
Le soucis, c'est que (au moins jusqu'au Core 2), elle n'est pas numérique, mais analogique et que du coup, faut que le fabricant de mobo calibre bien sont BIOS et que la précision donc reste moindre.
n°2102653
wolfflyter
Posté le 21-03-2011 à 16:47:44  profilanswer
Oui Mei Non faut pas dire tout ça  :D
Il est très important que le Cpu soit a une température acceptable pour son propriétaire et non
pour son Cpu  :jap:
 [:fading]
該反思的是,往往有幫助
n°2102656
Posté le 21-03-2011 à 16:51:03  answer
pour son Cpu ses coeurs :jap:
fÿcksaÿd [:chrisleurn]
EDIT: sinon ça marche po :o
Cf. les coeurs @90°C pendant que le CPU se traine 60°C
Message édité par Profil supprimé le 21-03-2011 à 16:52:22
n°2102658
MEI
|DarthPingoo(tm)|
Posté le 21-03-2011 à 16:57:45  profilanswer
Si t'as une mobo avec un BIOS en carton c'est autre chose. :spamafote:
n°2102659
Posté le 21-03-2011 à 16:58:49  answer
Que je sache, il n'y a que rarement de problèmes pour la lecture des coeurs!
Message édité par Profil supprimé le 21-03-2011 à 16:58:56
n°2102662
wolfflyter
Posté le 21-03-2011 à 17:08:46  profilanswer
Fais voir que Mei se trompe   :jap:
Il n'y a pas de Bios qui se trompe n'est ce pas  :p
Toutefois ....... j'ai eu des trucs bizarres avec Maximus et Q9550S  :whistle:
Mais la valeur Temps Cpu était juste.
 [:fading]
該反思的是,往往有幫助
n°2102670
Mattip
Posté le 21-03-2011 à 17:38:48  profilanswer
Yeah, je sors les cacahuètes pour vous suivre.
C'est reparti sur un débat temp core vs temps CPU.
Sur ce coup je mise sur Wolf.
n°2102671
tistou77
Geek Inside!!
Posté le 21-03-2011 à 17:43:12  profilanswer
Zouhir93 a écrit :
Je suis perdu
faut pas être perdu;)
le TJMax d'un i7 est à 101°, si ton CPU en bench monte à 75/80° par exemple (temp des cores) c'est pas grave, et y a encore de la marge :D
tout en sachant qu'en utilisation "normale" (jeux, surf, etc...) ton CPU ne montera pas à cette temp
et comme le dit MEI, tu pourrais avoir une temp de 90° en bench, que ton CPU ne s'en porterai pas plus mal, (t'auras changé de CPU avant qu'il montre des signes de fatigues :D)
après c'est vrai qu'on préfère avoir la temp la plus basse possible
et la plupart du temps, ce sont les tensions le plus néfaste au composants et non les temps ;)
c'est pour ça que je disais "conseillé" ;)
après y a les sécurités propre au CPU, le throttle, etc...
 [:fading]
comment tu le sais? t'as mis une sonde dans le socket? :D
pourquoi faudrait il un débat sur quelque chose, où tout le monde sait (sauf Wolf apparement) que c'est osef la temp CPU
Message édité par tistou77 le 21-03-2011 à 17:48:15
n°2102672
Mattip
Posté le 21-03-2011 à 17:48:06  profilanswer
La temps CPU c'est la seule valeur que tu peux encore à peu près vérifier en IDLE
n°2102673
Zouhir93
Posté le 21-03-2011 à 17:49:02  profilanswer
Ok
n°2102674
tistou77
Geek Inside!!
Posté le 21-03-2011 à 17:50:42  profilanswer
verifier avec un soft de monitoring?
après perso, connaitre la temp du socket ne m'interresse pas plus que ça ;)
n°2102677
Mattip
Posté le 21-03-2011 à 17:55:10  profilanswer
Avec un soft de monitoring et un thermomètre.
Température du socket ou sonde de température de l'IHS ? Je pense plus à cette dernière.
n°2102828
Posté le 21-03-2011 à 21:08:10  answer
OSEF de l'Idle
En charge, la dégradation du CPU est plus importante
Alors dire que 90°C n'est pas dangereux, certes
Mais alors autant ne pas s'inquiéter des températures
Voire carrément faire confiance au throttle auto.
Ou le désactiver, ou les 2 (désactiver le throttle + ne jamais s'inquiéter des tempés)
Pour les plus dinguozs :o
n°2102871
sinclair_w​ilde
Posté le 21-03-2011 à 22:45:48  profilanswer
Si ça en intéresse certains, je revends pas mal de matériel ici (Core i7 920 D0, ASUS R2G, 6Go OCZ Platinum) :
n°2102872
tistou77
Geek Inside!!
Posté le 21-03-2011 à 22:50:09  profilanswer
perso je trouve aussi que 90° c'est un peu trop, mais MEI n'a pas l'air d'avoir eu de problème avec son proc (archi du proc différente aussi je crois)
sinon 75/80° max c'est bien en bench, sachant que le proc n'atteindera cette temp qu'en bench
overclocking dangereux ?Overclocking Sempron 3200+
Problème overclocking E 8200[CPU]Quad core, differences
Probleme OC 8800 GTS 512 , Le core ne s'overclock pas !Overclocking Impossible sur EP45-DS3R
Question sur overclocking.Overclocking Q9300
Noob en Overclocking 8800GTS512Pb overclocking ram synchronisé au CPU
Plus de sujets relatifs à : [Topic Unique]Overclocking Nehalem Core i7 i5 i3
