9611 connectés
Sujet(s) à lire :
 Page :   1  2  3  4  5  ..  141  142  143  144  145  146
Page Suivante
[Topic Unique] Overclocking AMD Zen 3 - PBO2 / CO - 5Ghz+
n°2600646
hydrosaure
Posté le 16-09-2025 à 18:41:15  profilanswer
Oui, rien de bien méchant.
ça ressemble à ça:
[General]
stressTestProgram = PRIME95
runtimePerCore = auto
coreTestOrder = Default
numberOfThreads = 1
maxIterations = 1
suspendPeriodically = 1
# The test modes for Prime95
mode = SSE
# The FFT size preset to test for Prime95
# These are basically the presets as present in Prime95, plus an additional few
# Note: If "mode" is set to "CUSTOM", this setting will be ignored
# Smallest         4K to   21K - Prime95 preset text: "tests L1/L2 caches, high power/heat/CPU stress"
# Small           36K to  248K - Prime95 preset text: "tests L1/L2/L3 caches, maximum power/heat/CPU stress"
# Large          426K to 8192K - Prime95 preset text: "stresses memory controller and RAM" (although dedicated memory stress testing is disabled here by default!)
# Huge          8960K to   MAX - Anything beginning at 8960K up to the highest FFT size (32768K for SSE/AVX, 51200K for AVX2, 65536K for AVX512)
# All              4K to   MAX - 4K to up to the highest FFT size (32768K for SSE/AVX, 51200K for AVX2, 65536K for AVX512)
# Moderate      1344K to 4096K - special preset, recommended in the "Curve Optimizer Guide Ryzen 5000"
# Heavy            4K to 1344K - special preset, recommended in the "Curve Optimizer Guide Ryzen 5000"
# HeavyShort       4K to  160K - special preset, recommended in the "Curve Optimizer Guide Ryzen 5000"
# You can also define a single FFT size by just entering the value, or your own range by entering two FFT sizes joined by a hyphen, e.g 36-1344
# Default: Huge
FFTSize = HeavyShort
et donc jongler entre les 3 derniers FFTSize.
Les tests eux même sont variables en durée selon la taille des FFT de quelques minutes par core à ~25 minutes sur mon 5700x qui a été testé.
n°2600726
headquaker
Posté le 08-10-2025 à 12:34:32  profilanswer
un truc que je me demande c'est comment dans le classement 3D Mark, quelqu'un peut avoir un 5800X3D à 4.8Ghz
Helldivers 2, une petite composition : https://www.youtube.com/watch?v=JGW [...] nnel=HeadQ - Soundcloud : https://soundcloud.com/headquaker/tracks
n°2600733
hydrosaure
Posté le 09-10-2025 à 13:35:33  profilanswer
Turbo Clock:  up to 4.5 GHz
De base 4.5GHz en boost, tu mets +200MHz dans les paramètres du bios donc déjà 4.7 GHz (avec du 47x100Mhz).
Tu montes un tout petit peu le BCLK à 102/103:
47 x 102 = 4794
47 x 103 = 4841
apres la stabilité je sais pas.
n°2600734
Umi
Posté le 09-10-2025 à 13:40:09  profilanswer
Il me semble que le 5800X3D est complètement bloqué en O/C, seul l'UV est possible.
n°2601413
Ali-Pacha
AW
Posté le 29-01-2026 à 23:30:04  profilanswer
Déterrage, je découvre le PBO avec mon "nouveau" 5700X (config ITX de recyclage DDR4), c'est assez rigolo :D
Au dernier réglage, CO -30 all cores (trouvé par Ryzen Master),
+200 en boost
..et ma MoBo chinoise (JGinyue B550i) limite visiblement PPT / TDC / EDC à respectivement 100-105 / 65 / 95, mettre plus dans le Bios n'a aucun effet.
On gratte un peu de perfs, ça tourne all cores entre 4750 et 4850, a priori stable (OCCT long et CB R26) :jap:
Et forcément, à une centaine de watts maxi maxi, ça ne chauffe pas des masses.
Ali
Message édité par Ali-Pacha le 29-01-2026 à 23:31:02
n°2601414
Umi
Posté le 30-01-2026 à 01:17:15  profilanswer
J'ai réglé mon 5900X à 160/120/160, il ne dépasse pas les 80°c sous CBR23, je n'entend même pas les ventilos s’affoler :d
n°2601596
Ganon551
Posté le 16-02-2026 à 19:46:17  profilanswer
Bonsoir !
Je vais upgrader mon immortelle plateforme AM4 (je l'ai depuis le 1600x), remplacer mon 3600x par idéalement un 5800x.
Ma carte mère est une Asus Rog Strix b350-f gaming.
Apparemment de ce que j'ai pu lire en mettant à jour le BIOS je devrais pouvoir faire tourner le processeur sans souci. Ma question ici est plutôt de savoir si je serais en mesure de le tweaker un peu. Sans en arriver à des extrémités j'aime bien voir un peu ce dont est capable mon processeur. La carte mère état ancienne et sur un chipset plutôt entrée/milieu de gamme, je me demande si mon choix d'un 5800x est le bon ou s'il ne vaudrait pas mieux aller vers un 5600x. Je précise que j'ai un H115i comme cooling. Le souci de ce genre d'aio est l'absence de flux d'air sur les rad VRM.
Quelqu'un ici a une expérience de 5700x et supérieurs sur une carte B350 ?
Merci :jap:
n°2601597
Umi
Posté le 16-02-2026 à 20:07:22  profilanswer
Le 5800X est un peu un Zen 3 O/C d'usine, il suffira de régler PPT/TDC/EDC manuellement  pour être optimisé, et si tu as accès aux réglages liés à Curve Optimizer tu pourras en plus l'undervolter, à voir si tu as accès à ça une fois le 5800X installé.
Essaye avec
PPT: 120W
TDC: 80A
EDC: 110A
Et si tu as accès à CO, essaye -15 all cores pour commencer.
Compares tes scores CBR23.
n°2601603
Ganon551
Posté le 17-02-2026 à 22:54:36  profilanswer
Merci pour ta réponse.
Pour le moment je ne peux pas tester, je cherche toujours un 5800x d'occasion. Mon interrogation était surtout en lien avec ma CM et ses étages d'alimentation.
Mais dès que je peux j'essaie les réglages que tu conseilles et je reviens ici !
Mon btag : ganon551#2549
n°2601606
hydrosaure
Posté le 18-02-2026 à 10:25:43  profilanswer
Ganon551 a écrit :
Bonsoir !
Merci :jap:
C'est mon cas: une des premières fournées de B350 des plus modestes avec une Gigabyte AB-350m avec un 5700x.
ça marche impec, les derniers BIOS donne accès aux menus PBO et j'ai fait le tuning avec CoreCycler (OC + Undervolt) ici https://forum.hardware.fr/forum2.ph [...] 0#t2600620
n°2601607
Ali-Pacha
AW
Posté le 18-02-2026 à 10:27:28  profilanswer
Assez content de mon 5700X, rockstable à PBO +200 / CO -30, il tourne à 90 watts maxi et est très légèrement au-dessus d'un 5800X stock dans les benchs [:backfire]
Ali
n°2601609
Umi
Posté le 18-02-2026 à 12:23:15  profilanswer
Ali
Quels score CBr23 ?
Avec le 5800X @PBO stock et CO -30, je tapais les les 16100:
https://i.imgur.com/cwhEUv1.png
Et avec les réglages PBO un peu optimisés, je perdais environ 100 points mais le CPU chauffait nettement moins:
https://i.imgur.com/5JWchjf.png
n°2601610
Ali-Pacha
AW
Posté le 18-02-2026 à 12:33:34  profilanswer
J'utilise CB R26, 3490 vs 3441 sur le 5800X
Ali
Message édité par Ali-Pacha le 18-02-2026 à 12:33:52
n°2601612
Umi
Posté le 18-02-2026 à 13:14:23  profilanswer
Ah, je ne savais même pas qu'il y avait une version 2026  :o
Dommage de ne pas utiliser le R23, ça permet de comparer avec une large base, et, à titre perso, les scores des versions 2024 ou 2026 ne me parlent pas, alors que ceux des versions R23, oui.
https://www.majorgeeks.com/mg/getmi [...] nch,1.html
n°2601613
Ali-Pacha
AW
Posté le 18-02-2026 à 13:18:10  profilanswer
Je préfère R24 / R26 parce qu'ils sont un peu plus agressifs sur le CPU (températures), en tout cas sur ce que j'ai pu tester.
Ali
n°2601614
Umi
Posté le 18-02-2026 à 13:34:36  profilanswer
Je vois, après si le but est de tester la stabilité et de faire chauffer, il vaut mieux se tourner vers des outils dédiés, ce n'est pas ce qui manque: y-cruncher, Prime95, OCCT, CoreCycler pour les tests cœurs par cœurs, etc...
P.S: 2026≠R26, le système de numérotation a changé avec la version 2024 (la version R23 était sortie en 2020).
Message édité par Umi le 18-02-2026 à 13:37:09
n°2601615
Ali-Pacha
AW
Posté le 18-02-2026 à 13:39:38  profilanswer
Ben ça fait partie des outils. Je peux avoir une config parfaitement stable en OCCT / Y-Cruncher / Prime95 qui plante quand même sous CB, même si ce dernier ne fera pas chauffer autant. Pas plus tard qu'il n'y a pas longtemps avec mon 265K, où CB est celui qui stresse le plus le uncore. Autant prendre le CB qui chauffe le plus [:backfire]
J'ai rien contre R23, je l'utilisais pas mal il y a encore un an, je ferai un test pour toi ce soir si j'y pense  [:threesixmafia]
Ali
Message édité par Ali-Pacha le 18-02-2026 à 14:04:17
n°2601617
Umi
Posté le 18-02-2026 à 13:57:03  profilanswer
Ali-Pacha a écrit :
[…] . Je peux avoir une config parfaitement stable en OCCT / Y-Cruncher / Prime95 qui plante quand même sous CB […]
Alors là je suis étonné !
Ali-Pacha a écrit :
[…] J'ai rien contre R23, je l'utilisais pas mal il y a encore un an, je ferai un test pour toi ce soir si j'y pense  [:threesixmafia]   […]
 [:cerveau charlest]
J'ai fait un test CB2026 viteuf, avec plein d'applis ouvertes en arrière-plan donc le score est pas hyper optimisé, mais voici (j'ai plus le 5800X pour pouvoir tester donc c'est avec le 5900X):
https://i.imgur.com/zQ3BqJN.png
Message édité par Umi le 18-02-2026 à 13:57:46
n°2601618
Ali-Pacha
AW
Posté le 18-02-2026 à 14:03:11  profilanswer
Si tu as pris le temps de lire le (long désolé :D) post que j'ai linké, tu verras que je tombe sur des instabilités sous PassMark pour un test qui n'a aucune vocation à éprouver la chauffe ou la stabilité (Render Test 2D). Aussi bien sur 9700X que sur un 265K, même si sur ce dernier, HWinfo pointe clairement le Uncore, beaucoup moins sollicité par OCCT / Prime95 / Y-Cruncher.
Pour le 5800X sous CB 2026, c'est le score qu'il y a dans les références ( 5441 ) [:backfire]. Des chances que la hiérarchie soit la même avec R23.
Quoiqu'il en soit, je suis vraiment content de ce petit 5700X. Même si ma mobale Jginyue B550i limite clairement EDC/TDC/PPT (respectivement 95A/65A/100W), c'est pile poil ce qu'il fallait pour cette config que j'ai montée dans un Fractal Terra, je tourne à 78-79°C avec un Rad TR AXP120-X67 donc inutile de monter plus haut en PPT en réalité, et c'est parfaitement équilibré avec la RTX 4070. Un bon recyclage de mes 2 x 16go de DDR4-PC3200 :jap:
Ali
Message édité par Ali-Pacha le 18-02-2026 à 14:12:55
n°2601619
Umi
Posté le 18-02-2026 à 14:42:02  profilanswer
Ta CM ne te laisse pas toucher à PPT/TC/EDC c'est ça ? Curieux de voir ton score CBr23.
J'ai refait un run CB 2026 avec le minimum de logiciels ouverts, je gagne tout de même plus de 170 points.
https://i.imgur.com/HOxrxmM.png
n°2601620
Ali-Pacha
AW
Posté le 18-02-2026 à 14:59:14  profilanswer
Si, il y a bien les réglages dans le bios, mais ça ne sert à rien de mettre plus que les valeurs que j'ai indiquées, la mobale ne les dépassera pas.
Et c'est là qu'on voit que CB est vraiment fait pour les Core Ultra, mon 265k tourne à 8400 environ sur le 2026  [:cerveau ddr555]
Ali
n°2601621
Ali-Pacha
AW
Posté le 18-02-2026 à 21:01:56  profilanswer
Chose promise chose due :
https://rehost.diberie.com/Picture/Get/r/491547
Le "théorique" est visiblement à 14309, et celui du 5800X 15228.
Comme je l'écrivais plus haut, ce sont les valeurs max de PBO sur ma mobale JGinyue B550i, mettre plus dans le bios n'a aucun effet, ça plafonne. Je ne saurai jamais ce qu'il peut donner en mettant un PBO de 5800X  [:cerveau zytrasnif] :D
Et de toute façon il manquera 100 mhz quoiqu'il arrive :jap:
Mon 9700X en PBO 162W / CO -20 [:tachyon:1]  Et mon 265K "bridé" à 225W (normalement c'est 250 :o )  [:john_tgv:8]
https://rehost.diberie.com/Picture/Get/r/491554 https://rehost.diberie.com/Picture/Get/r/491550
9700X et 265K sont très proches en single Core, le premier en a 8 et le second a 8 "P-Cores" (+12 E-Cores), c'est assez cohérent avec les résultats en gaming où il sont globalement comparables :jap:
Ali
Message édité par Ali-Pacha le 18-02-2026 à 21:38:20
n°2601622
Umi
Posté le 18-02-2026 à 22:58:28  profilanswer
Tu devrais poster tout ça dans le topic Cinebench R23.
n°2602082
hydrosaure
Posté le 06-06-2026 à 16:40:38  profilanswer
Ouch....3 ans apres un tuning:
https://img.super-h.fr/images/2026/06/06/85039162aa8eb344d2617f7ce9f147a1.png
n°2602084
Umi
Posté le 06-06-2026 à 18:52:12  profilanswer
Quels réglages dans CoreCycler ? C'est la dernière version ? pourquoi le lancer en admin ?
Il y a 3 ans, tu avais fait les mêmes tests ?
n°2602085
hydrosaure
Posté le 07-06-2026 à 10:07:22  profilanswer
A l'époque ça devait encore être avec OCCT.
Cela a fonctionné pendant très longtemps pour ce que je lui demandais à cette machine. (virtu, calculs intensifs, compilation)
Là c'est surtout que là j'ai des plantages donc j'investigue...j'ai d'abord cru à une RAM HS mais non.
n°2602086
Fouge
Posté le 07-06-2026 à 11:21:49  profilanswer
T'as utilisé quel algo ? YCRUNCHER ou alors Prime95 en Large/Moderate ?
n°2602087
hydrosaure
Posté le 07-06-2026 à 18:59:49  profilanswer
Prime95 en SSE avec le preset Moderate et HeavyShort
n°2602503
Luzog
Posté le 29-09-2026 à 13:43:14  profilanswer
Bon ben après quelques mois, je viens de me rendre compte que mon 5700X avec -30 CO sur tous les coeurs n'était pas stable.
J'ai juste lancé Da Vinci pour dérusher des vidéos en 4k (vidéos venant d'une caméra RED avec 600Go de donnée). J'ai eu 2 reboot en moins de 5min.
Je n'avais eu aucun plantages avant ça (config utilisée quasi exclusivement pour de la bureautique/web et jeux vidéos en 4k).
Du coup, je pense que Da Vinci est un bon moyen de tester les CO :o
Mon Feed--Achats/Ventes
n°2602511
Umi
Posté le 29-09-2026 à 20:08:31  profilanswer
Tu avais fais des tests de stabilité avec CoreCycler ?
n°2602514
Luzog
Posté le 30-09-2026 à 06:50:58  profilanswer
Ah non non, j'avais fait ça à l'arrache en mode, on verra bien :D
En fait, l'historique fait que j'avais pas envie de me prendre la tête. J'ai toujours eu des problèmes avec ma config, jusqu'à ce que je me rende compte que c'est les ports thunderbolt de ma carte mère qui foutaient clairement la merde (reboot intempestifs). En gros, impossible de stabiliser ma ram à 3600mhz avec le thunderbolt activé sur ma carte mère. La seule possibilité était de laisser la ram à 2666mhz.
Du coup, quand j'ai trouvé la solution à tous mes problèmes (désactiver le thunderbolt), je me suis dit (après avoir testé @stock) que j'allais en profiter pour voir si je pouvais utiliser le CO (en me disant que je verrai déjà si ça plante à -30 avant de remonter tout doucement).
Là, ça faisait plus ou moins 3 mois que j'utilisais la config sans faire de montage (jeux vidéo, surf, multimedia).
Et quand j'ai lancé da vinci, ça a quasi planté instantanément. Bon, c'est du rush en 6k avec une caméra RED, donc très très lourd (600go de données). Mais je me dis que da vinci est sûrement un bon moyen de tester la stabilité de sa machine :D
n°2602516
Umi
Posté le 30-09-2026 à 07:35:34  profilanswer
C'est surtout qu'il doit faire booster un ou deux cœurs, situation où le CPU donne moins de tension, donc UV trop important => crash.
CoreCycler permet de tester cœur par cœur, et, si tu as le courage, d'appliquer un offset CO par cœur.
Message édité par Umi le 30-09-2026 à 07:41:31
n°2602519
Luzog
Posté le 30-09-2026 à 13:56:19  profilanswer
Oui, j'avais un peu suivi comment ça fonctionnait et qu'en charge lourde, le CPU pouvait ne pas poser problème mais qu'en charge sur un cœur, ça pouvait être compliqué.
J'ai pas trop envie de faire du corecycler. J'ai mis -10 sur tous les cœurs et je verrai bien :D
n°2602520
Umi
Posté le 30-09-2026 à 14:10:54  profilanswer
CoreCycler tourne automatiquement, tu configures vite fait le ini et après tu le laisses tourner, il peut même reprendre en cas de reboot je crois.
n°2602521
Luzog
Posté le 30-09-2026 à 14:27:16  profilanswer
Je vais regarder un peu alors :)
Merci :jap:
Page Suivante
Overclocking basique 9900KF sur B360M-KWC Ekwb changement de config (Intel vers AMD)
[Topic Unique] Cinebench R23 ¤ Postez vos scoresresultats OC I5 9600K+ reglage bios 1.27v 5Ghz
[Topic Unique] L'OC ou UV des vos RTX 3060ti/70/80/90Aide Overclocking 10900k svp
Problème d'overclocking r7 1700AMD 3900X + Dark Rock Pro 4 : temp elevée !
Mon premier OC GPU - AMD FuryApprendre l'overclocking
Plus de sujets relatifs à : [Topic Unique] Overclocking AMD Zen 3 - PBO2 / CO - 5Ghz+
