3415 connectés
 Page :   1  2  3  4  5  ..  272  273  274  ..  775  776  777  778  779  780
[DEBIAN] - Intégristes barbus, |337, femmes nues...
n°1077264
darxmurf
meow
Posté le 26-09-2008 à 20:55:47  profilanswer
oui... mon xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 1.0  (buildmeister@builder58)  Thu Jul 17 18:39:00 PDT 2008
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 1.0  (buildmeister@builder58)  Thu Jul 17 18:39:42 PDT 2008
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Option         "AIGLX" "on"
EndSection
Section "Files"
    RgbPath         "/usr/X11R6/lib/X11/rgb"
EndSection
Section "Module"
    Load           "dbe"
    Load           "extmod"
    Load           "type1"
    Load           "freetype"
    Load           "glx"
EndSection
Section "ServerFlags"
    Option         "Xinerama" "0"
EndSection
Section "InputDevice"
   # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "LAC photon20vision2"
    HorizSync       28.0 - 80.0
    VertRefresh     56.0 - 85.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
EndSection
Section "Device"
    Identifier     "Videocard0"
    Driver         "nvidia"
    BoardName      "GeForce 8600 GT"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Videocard0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "TwinView" "1"
    Option         "TwinViewXineramaInfoOrder" "DFP-0"
    Option         "metamodes" "DFP-0: 1600x1200 +1600+0, DFP-1: 1600x1200 +0+0"
    Option         "XAANoOffscreenPixmaps"
    Option         "AllowGLXWithComposite" "True"
    Option         "RenderAccel" "True"
    Option         "AddARGBGLXVisuals" "True"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Section "Extensions"
    Option         "Composite" "Enable"
EndSection
Message édité par darxmurf le 26-09-2008 à 20:56:10
Des trucs - flickr - Instagram
n°1077266
darxmurf
meow
Posté le 26-09-2008 à 20:57:17  profilanswer
je pense que je peux dégager ça que j'avais rajouté à la mano au tout début
n°1077267
burn2
Pour ceux qui viendront après
Posté le 26-09-2008 à 20:57:24  profilanswer
    Option         "AIGLX" "on"
Déjà cette ligne tu n'en as pas besoin.
Après tu as le twinview d'activé, tu as deux écrans??? Sinon ça peut poser problème au tout début aussi.
Message édité par burn2 le 26-09-2008 à 20:59:34
n°1077268
multani
Dépressionnisé
Posté le 26-09-2008 à 20:58:06  profilanswer
darxmurf a écrit :
j'ai relancé ...
darxmurf@drx1:~$ fusion-icon
 * Detected Session: gnome
 * Searching for installed applications...
Backend     : gconf
Integration : true
Profile     : darx
Adding plugin decoration (decoration)
Initializing decoration options...done
 * No GLX_EXT_texture_from_pixmap with direct rendering context
 ... nor with indirect rendering, this isn't going to work!
 * Using the GTK Interface
 * Starting Compiz
 ... executing: compiz.real --replace --sm-disable --ignore-desktop-hints ccp
compiz.real (core) - Fatal: glXCreateContext failed
compiz.real (core) - Error: Failed to manage screen: 0
compiz.real (core) - Fatal: No manageable screens found on display :0.0
[:paysan]
Tes drivers nvidia semblent être trop vieux, c'est quelle version que tu as ?
n°1077270
darxmurf
meow
Posté le 26-09-2008 à 21:00:24  profilanswer
burn2 a écrit :
    Option         "AIGLX" "on"
oui, twinview avec les derniers drivers trouvés sur le site de nvidia (aout 2008 )
n°1077271
burn2
Posté le 26-09-2008 à 21:04:11  profilanswer
ça m'a l'air d'être bien chiant sous debian pour avoir compiz. :/
Bon sinon tu peux activer xgl avec:
“gnome-xgl-switch –enable-xgl"
Mais ce n'est absolument pas normal que ça ne marche pas avec les drivers nvidia. :/
Message édité par burn2 le 26-09-2008 à 21:04:19
n°1077272
gee
Bon ben hon
Posté le 26-09-2008 à 21:08:32  profilanswer
Section "Screen"
EndSection
euh ces option ne sont-elles pas censees etre dans device normalement?
"Phildar t'es vraiment une pute pas finie toi! Et Manu le gros porc arrete de t'marrer!"
n°1077275
darxmurf
meow
Posté le 26-09-2008 à 21:13:08  profilanswer
je crois que je vais surtout faire un apt-get purge compiz* :o
EDIT : c'est fait :o
Message édité par darxmurf le 26-09-2008 à 21:13:48
n°1077276
darxmurf
meow
Posté le 26-09-2008 à 21:17:32  profilanswer
là y a de quoi installer la version fusion : http://shame.tuxfamily.org/repo/?cat=11
je vais encore tester...
n°1077279
darxmurf
meow
Posté le 26-09-2008 à 21:27:11  profilanswer
bon j'ai installé le tout avec Emerald et tout... quand je lance y a toujours mes bares de fenêtres qui foutent le camp... si je le lance depuis la console il me dit
Fatal: Failed test: texture_from_pixmap support
Checks indicate that it's impossible to start compiz on your system.
n°1077284
gee
Bon ben hon
Posté le 26-09-2008 à 21:55:27  profilanswer
Que donne glxinfo?
n°1077288
darxmurf
meow
Posté le 26-09-2008 à 22:05:57  profilanswer
c'est fou y a rien qui passe dans les tutos que j'ai trouvé :( je peux lancer le soft et tout mais les barres de fenêtre disparaissent !
darxmurf@drx1:~$ glxinfo
name of display: :0.0
Error: glXCreateContext failed
   visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
 id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x23 24 tc  0 24  0 r  y  .  8  8  8  0  0 16  0  0  0  0  0  0 0 None
0x24 24 tc  0 24  0 r  y  .  8  8  8  0  0 16  8 16 16 16  0  0 0 None
0x25 24 tc  0 32  0 r  y  .  8  8  8  8  0 16  8 16 16 16 16  0 0 None
0x26 24 tc  0 32  0 r  .  .  8  8  8  8  0 16  8 16 16 16 16  0 0 None
0x27 24 dc  0 24  0 r  y  .  8  8  8  0  0 16  0  0  0  0  0  0 0 None
0x28 24 dc  0 24  0 r  y  .  8  8  8  0  0 16  8 16 16 16  0  0 0 None
0x29 24 dc  0 32  0 r  y  .  8  8  8  8  0 16  8 16 16 16 16  0 0 None
0x2a 24 dc  0 32  0 r  .  .  8  8  8  8  0 16  8 16 16 16 16  0 0 None
0x63 32 tc  0 32  0 r  .  .  8  8  8  8  0  0  0  0  0  0  0  0 0 Ncon
darxmurf@drx1:~$
n°1077289
darxmurf
meow
Posté le 26-09-2008 à 22:06:18  profilanswer
et ça aussi
darxmurf@drx1:~$ compiz --replace
darxmurf@drx1:~$
n°1077293
darxmurf
meow
Posté le 26-09-2008 à 22:09:31  profilanswer
bon je vais pas me prendre le chou encore 100 ans je pense...
le truc ça tourne sous ubuntu, opensuze etc mais pas sous Débian et puis voilà ! :) j'ai regardé Beryl et c'est kif kif... donc bon... en fait je voulais pas transformer mon debian en truc de geek horrible, je voulais juste ajouter 2 ou 3 effets de rotation entre les workspaces etc rien de bien méchant :)
n°1077302
darxmurf
meow
Posté le 26-09-2008 à 22:20:44  profilanswer
sinon je passe à ubuntu [:airforceone]
n°1077303
sligor
Posté le 26-09-2008 à 22:27:14  profilanswer
bon refaisons un checkup: peux tu poster le contenu de ces fichiers:
xorg.conf
/var/log/Xorg.0.log
n°1077308
Mjules
Parle dans le vide
Posté le 26-09-2008 à 22:31:27  profilanswer
darxmurf@drx1:~$
il n'arrive pas à initialiser quoique ce soit d'openGL, tu m'étonnes que compiz marche pas.
Je vote pilotes mal installés.
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
n°1077309
multani
Dépressionnisé
Posté le 26-09-2008 à 22:33:16  profilanswer
darxmurf@drx1:~$
C'est pas normal ça [:petrus75]
T'as des messages d'erreurs relatifs à GLX dans les logs de ton serveur X ?
Et le résultat de "aptitude search nvidia -F '%c %p %V' --disable-columns | grep  ^i" ? (pour voir les paquets nvidia que t'as installé)
n°1077310
darxmurf
meow
Posté le 26-09-2008 à 22:36:14  profilanswer
xorg.conf
EndSection
Section "Files"
EndSection
Section "Module"
    Load           "dbe"
    Load           "extmod"
    Load           "type1"
    Load           "freetype"
    Load           "glx"
EndSection
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
EndSection
    Driver         "kbd"
EndSection
Section "Monitor"
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
EndSection
Section "Device"
    Driver         "nvidia"
EndSection
Section "Screen"
    Device         "Videocard0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "DisableGLXRootClipping" "True"
    Option         "DamageEvents" "True"
    Option         "UseEvents" "False"
    Option         "TripleBuffer" "True"
        Depth       24
    EndSubSection
EndSection
EndSection
n°1077311
darxmurf
meow
Posté le 26-09-2008 à 22:37:29  profilanswer
Xorg.0.log
X.Org X Server 1.4.2
Release Date: 11 June 2008
X Protocol Version 11, Revision 0
Build Operating System: Linux Debian (xorg-server 2:1.4.2-5)
Current Operating System: Linux drx1 2.6.26-1-amd64 #1 SMP Wed Sep 10 15:31:12 UTC 2008 x86_64
Build Date: 26 August 2008  06:07:42PM
 Before reporting problems, check http://wiki.x.org
 to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
 (++) from command line, (!!) notice, (II) informational,
 (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Sep 26 22:32:52 2008
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Layout0"
(**) |-->Screen "Screen0" (0)
(**) |   |-->Monitor "Monitor0"
(**) |   |-->Device "Videocard0"
(**) |-->Input Device "Keyboard0"
(**) |-->Input Device "Mouse0"
(**) Option "Xinerama" "0"
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
 Entry deleted from font path.
(WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
(==) FontPath set to:
 /usr/share/fonts/X11/misc,
 /usr/share/fonts/X11/100dpi/:unscaled,
 /usr/share/fonts/X11/75dpi/:unscaled,
 /usr/share/fonts/X11/Type1,
 /usr/share/fonts/X11/100dpi,
(**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/lib/xorg/modules"
(**) Extension "Composite" is enabled
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Loader magic: 0x7c31c0
(II) Module ABI versions:
 X.Org ANSI C Emulation: 0.3
 X.Org Video Driver: 2.0
 X.Org XInput driver : 2.0
 X.Org Server Extension : 0.3
 X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
 compiled for 1.4.2, module version = 1.0.0
 ABI class: X.Org Video Driver, version 2.0
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,29c0 card 1458,5000 rev 02 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,29c1 card 0000,0000 rev 02 class 06,04,00 hdr 01
(II) PCI: 00:1a:0: chip 8086,2937 card 1458,5004 rev 02 class 0c,03,00 hdr 80
(II) PCI: 00:1a:1: chip 8086,2938 card 1458,5004 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1a:2: chip 8086,2939 card 1458,5004 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1a:7: chip 8086,293c card 1458,5006 rev 02 class 0c,03,20 hdr 00
(II) PCI: 00:1b:0: chip 8086,293e card 1458,a002 rev 02 class 04,03,00 hdr 00
(II) PCI: 00:1c:0: chip 8086,2940 card 0000,0000 rev 02 class 06,04,00 hdr 81
(II) PCI: 00:1c:4: chip 8086,2948 card 0000,0000 rev 02 class 06,04,00 hdr 81
(II) PCI: 00:1c:5: chip 8086,294a card 0000,0000 rev 02 class 06,04,00 hdr 81
(II) PCI: 00:1d:0: chip 8086,2934 card 1458,5004 rev 02 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,2935 card 1458,5004 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,2936 card 1458,5004 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,293a card 1458,5006 rev 02 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev 92 class 06,04,01 hdr 01
(II) PCI: 00:1f:0: chip 8086,2916 card 1458,5001 rev 02 class 06,01,00 hdr 80
(II) PCI: 00:1f:2: chip 8086,2922 card 1458,b005 rev 02 class 01,06,01 hdr 00
(II) PCI: 00:1f:3: chip 8086,2930 card 1458,5001 rev 02 class 0c,05,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0402 card 1043,8243 rev a1 class 03,00,00 hdr 00
(II) PCI: 03:00:0: chip 197b,2363 card 1458,b000 rev 02 class 01,06,01 hdr 80
(II) PCI: 03:00:1: chip 197b,2363 card 1458,b000 rev 02 class 01,01,85 hdr 00
(II) PCI: 04:00:0: chip 10ec,8168 card 1458,e000 rev 01 class 02,00,00 hdr 00
(II) PCI: 05:00:0: chip 104c,8025 card 0ee4,3884 rev 01 class 0c,00,10 hdr 00
(II) PCI: 05:06:0: chip 104c,8024 card 1458,1000 rev 00 class 0c,00,10 hdr 00
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,5), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
 [0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
 [0] -1 0 0x00000000 - 0xffffffff (0x100000000) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 1 I/O range:
 [0] -1 0 0x0000b000 - 0x0000bfff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
 [0] -1 0 0xf4000000 - 0xf7ffffff (0x4000000) MX[B]
(II) Bus 1 prefetchable memory range:
 [0] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B]
(II) Bus 2: bridge is at (0:28:0), (0,2,2), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 2 I/O range:
 [0] -1 0 0x0000a000 - 0x0000afff (0x1000) IX[B]
(II) Bus 3: bridge is at (0:28:4), (0,3,3), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 3 I/O range:
 [0] -1 0 0x0000c000 - 0x0000cfff (0x1000) IX[B]
(II) Bus 3 non-prefetchable memory range:
 [0] -1 0 0xfa000000 - 0xfa0fffff (0x100000) MX[B]
(II) Bus 4: bridge is at (0:28:5), (0,4,4), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 4 I/O range:
 [0] -1 0 0x0000d000 - 0x0000dfff (0x1000) IX[B]
(II) Bus 4 non-prefetchable memory range:
 [0] -1 0 0xf8000000 - 0xf9ffffff (0x2000000) MX[B]
(II) Bus 4 prefetchable memory range:
 [0] -1 0 0xfa300000 - 0xfa3fffff (0x100000) MX[B]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 5: bridge is at (0:30:0), (0,5,5), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 5 non-prefetchable memory range:
 [0] -1 0 0xfa100000 - 0xfa1fffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) nVidia Corporation GeForce 8600 GT rev 161, Mem @ 0xf6000000/24, 0xe0000000/28, 0xf4000000/25, I/O @ 0xb000/7
(II) Addressable bus resource ranges are
 [1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
 [0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
 [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
 [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
 [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
 [4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
 [5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
 [0] -1 0 0xfa104000 - 0xfa107fff (0x4000) MX[B]
 [1] -1 0 0xfa108000 - 0xfa1087ff (0x800) MX[B]
 [2] -1 0 0xfa100000 - 0xfa103fff (0x4000) MX[B]
 [3] -1 0 0xfa109000 - 0xfa1097ff (0x800) MX[B]
 [4] -1 0 0xf9000000 - 0xf9000fff (0x1000) MX[B]
 [5] -1 0 0xfa000000 - 0xfa001fff (0x2000) MX[B]
 [6] -1 0 0xfa207000 - 0xfa2070ff (0x100) MX[B]
 [7] -1 0 0xfa206000 - 0xfa2067ff (0x800) MX[B]
 [8] -1 0 0xfa204000 - 0xfa2043ff (0x400) MX[B]
 [9] -1 0 0xfa200000 - 0xfa203fff (0x4000) MX[B]
 [10] -1 0 0xfa205000 - 0xfa2053ff (0x400) MX[B]
 [11] -1 0 0xf4000000 - 0xf5ffffff (0x2000000) MX[B](B)
 [12] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B)
 [13] -1 0 0xf6000000 - 0xf6ffffff (0x1000000) MX[B](B)
 [14] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B]
 [15] -1 0 0x0000c400 - 0x0000c40f (0x10) IX[B]
 [16] -1 0 0x0000c300 - 0x0000c303 (0x4) IX[B]
 [17] -1 0 0x0000c200 - 0x0000c207 (0x8) IX[B]
 [18] -1 0 0x0000c100 - 0x0000c103 (0x4) IX[B]
 [19] -1 0 0x0000c000 - 0x0000c007 (0x8) IX[B]
 [20] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
 [21] -1 0 0x0000ea00 - 0x0000ea1f (0x20) IX[B]
 [22] -1 0 0x0000e900 - 0x0000e903 (0x4) IX[B]
 [23] -1 0 0x0000e800 - 0x0000e807 (0x8) IX[B]
 [24] -1 0 0x0000e700 - 0x0000e703 (0x4) IX[B]
 [25] -1 0 0x0000e600 - 0x0000e607 (0x8) IX[B]
 [26] -1 0 0x0000e500 - 0x0000e51f (0x20) IX[B]
 [27] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
 [28] -1 0 0x0000e300 - 0x0000e31f (0x20) IX[B]
 [29] -1 0 0x0000e000 - 0x0000e01f (0x20) IX[B]
 [30] -1 0 0x0000e200 - 0x0000e21f (0x20) IX[B]
 [31] -1 0 0x0000e100 - 0x0000e11f (0x20) IX[B]
 [32] -1 0 0x0000b000 - 0x0000b07f (0x80) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
 [4] -1 0 0xfa104000 - 0xfa107fff (0x4000) MX[B]
 [5] -1 0 0xfa108000 - 0xfa1087ff (0x800) MX[B]
 [6] -1 0 0xfa100000 - 0xfa103fff (0x4000) MX[B]
 [7] -1 0 0xfa109000 - 0xfa1097ff (0x800) MX[B]
 [8] -1 0 0xf9000000 - 0xf9000fff (0x1000) MX[B]
 [9] -1 0 0xfa000000 - 0xfa001fff (0x2000) MX[B]
 [10] -1 0 0xfa207000 - 0xfa2070ff (0x100) MX[B]
 [11] -1 0 0xfa206000 - 0xfa2067ff (0x800) MX[B]
 [12] -1 0 0xfa204000 - 0xfa2043ff (0x400) MX[B]
 [13] -1 0 0xfa200000 - 0xfa203fff (0x4000) MX[B]
 [14] -1 0 0xfa205000 - 0xfa2053ff (0x400) MX[B]
 [15] -1 0 0xf4000000 - 0xf5ffffff (0x2000000) MX[B](B)
 [16] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B)
 [17] -1 0 0xf6000000 - 0xf6ffffff (0x1000000) MX[B](B)
 [18] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
 [19] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
 [20] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B]
 [21] -1 0 0x0000c400 - 0x0000c40f (0x10) IX[B]
 [22] -1 0 0x0000c300 - 0x0000c303 (0x4) IX[B]
 [23] -1 0 0x0000c200 - 0x0000c207 (0x8) IX[B]
 [24] -1 0 0x0000c100 - 0x0000c103 (0x4) IX[B]
 [25] -1 0 0x0000c000 - 0x0000c007 (0x8) IX[B]
 [26] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
 [27] -1 0 0x0000ea00 - 0x0000ea1f (0x20) IX[B]
 [28] -1 0 0x0000e900 - 0x0000e903 (0x4) IX[B]
 [29] -1 0 0x0000e800 - 0x0000e807 (0x8) IX[B]
 [30] -1 0 0x0000e700 - 0x0000e703 (0x4) IX[B]
 [31] -1 0 0x0000e600 - 0x0000e607 (0x8) IX[B]
 [32] -1 0 0x0000e500 - 0x0000e51f (0x20) IX[B]
 [33] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
 [34] -1 0 0x0000e300 - 0x0000e31f (0x20) IX[B]
 [35] -1 0 0x0000e000 - 0x0000e01f (0x20) IX[B]
 [36] -1 0 0x0000e200 - 0x0000e21f (0x20) IX[B]
 [37] -1 0 0x0000e100 - 0x0000e11f (0x20) IX[B]
 [38] -1 0 0x0000b000 - 0x0000b07f (0x80) IX[B](B)
(II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
(II) "dbe" will be loaded. This was enabled by default and also specified in the config file.
(II) "glx" will be loaded. This was enabled by default and also specified in the config file.
(II) "freetype" will be loaded. This was enabled by default and also specified in the config file.
(II) "record" will be loaded by default.
(II) "dri" will be loaded by default.
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
 Module class: X.Org Server Extension
 ABI class: X.Org Server Extension, version 0.3
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "type1"
(WW) Warning, couldn't open module type1
(II) UnloadModule: "type1"
(EE) Failed to load module "type1" (module does not exist, 0)
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
 compiled for 1.4.2, module version = 2.1.0
 Module class: X.Org Font Renderer
 ABI class: X.Org Font Renderer, version 0.5
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
(II) Module record: vendor="X.Org Foundation"
 compiled for 1.4.2, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "nvidia"
(II) Loading /usr/lib/xorg/modules/drivers//nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
 compiled for 4.0.2, module version = 1.0.0
 Module class: X.Org Video Driver
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
 compiled for 1.4.0.90, module version = 1.3.1
 Module class: X.Org XInput Driver
 ABI class: X.Org XInput driver, version 2.0
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
 compiled for 1.4.0.90, module version = 1.3.0
(II) NVIDIA dlloader X Driver  173.14.12  Thu Jul 17 18:18:16 PDT 2008
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 01:00:0
(--) Assigning device section with no busID to primary device
(--) Chipset NVIDIA GPU found
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
(II) Module fb: vendor="X.Org Foundation"
 ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module "wfb"
(II) LoadModule: "wfb"
(II) Loading /usr/lib/xorg/modules//libwfb.so
(II) Module wfb: vendor="X.Org Foundation"
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"(II) Module "ramdac" already built-in
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
 [18] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
 [19] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
 [20] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
 [21] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
 [22] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
 [23] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B]
 [24] -1 0 0x0000c400 - 0x0000c40f (0x10) IX[B]
 [25] -1 0 0x0000c300 - 0x0000c303 (0x4) IX[B]
 [26] -1 0 0x0000c200 - 0x0000c207 (0x8) IX[B]
 [27] -1 0 0x0000c100 - 0x0000c103 (0x4) IX[B]
 [28] -1 0 0x0000c000 - 0x0000c007 (0x8) IX[B]
 [29] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
 [30] -1 0 0x0000ea00 - 0x0000ea1f (0x20) IX[B]
 [31] -1 0 0x0000e900 - 0x0000e903 (0x4) IX[B]
 [32] -1 0 0x0000e800 - 0x0000e807 (0x8) IX[B]
 [33] -1 0 0x0000e700 - 0x0000e703 (0x4) IX[B]
 [34] -1 0 0x0000e600 - 0x0000e607 (0x8) IX[B]
 [35] -1 0 0x0000e500 - 0x0000e51f (0x20) IX[B]
 [36] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
 [37] -1 0 0x0000e300 - 0x0000e31f (0x20) IX[B]
 [38] -1 0 0x0000e000 - 0x0000e01f (0x20) IX[B]
 [39] -1 0 0x0000e200 - 0x0000e21f (0x20) IX[B]
 [40] -1 0 0x0000e100 - 0x0000e11f (0x20) IX[B]
 [41] -1 0 0x0000b000 - 0x0000b07f (0x80) IX[B](B)
 [42] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
 [43] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(0): Option "RenderAccel" "True"
(**) NVIDIA(0): Option "TwinView" "1"
(**) NVIDIA(0): Option "MetaModes" "DFP-0: 1600x1200 +1600+0, DFP-1: 1600x1200 +0+0"
(**) NVIDIA(0): Option "TwinViewXineramaInfoOrder" "DFP-0"
(**) NVIDIA(0): Option "AllowGLXWithComposite" "True"
(**) NVIDIA(0): Option "TripleBuffer" "True"
(**) NVIDIA(0): Option "UseEvents" "False"
(**) NVIDIA(0): Option "AddARGBGLXVisuals" "True"
(**) NVIDIA(0): Option "DisableGLXRootClipping" "True"
(**) NVIDIA(0): Option "DamageEvents" "True"
(**) NVIDIA(0): Enabling RENDER acceleration
(**) NVIDIA(0): TwinView enabled
(EE) NVIDIA(0): Failed to initialize the GLX module; please check in your X
(EE) NVIDIA(0):     log file that the GLX module has been loaded in your X
(EE) NVIDIA(0):     server, and that the module is the NVIDIA GLX module.  If
(EE) NVIDIA(0):     you continue to encounter problems, Please try
(EE) NVIDIA(0):     reinstalling the NVIDIA driver.
(II) NVIDIA(0): NVIDIA GPU GeForce 8600 GT (G84) at PCI:1:0:0 (GPU-0)
(--) NVIDIA(0): Memory: 524288 kBytes
(--) NVIDIA(0): VideoBIOS: 60.84.41.00.00
(II) NVIDIA(0): Detected PCI Express Link width: 16X
(--) NVIDIA(0): Interlaced video modes are supported on this GPU
(--) NVIDIA(0): Connected display device(s) on GeForce 8600 GT at PCI:1:0:0:
(--) NVIDIA(0):     LAC photon20vision2 (DFP-0)
(--) NVIDIA(0):     LAC photon20vision2 (DFP-1)
(--) NVIDIA(0): LAC photon20vision2 (DFP-0): 330.0 MHz maximum pixel clock
(--) NVIDIA(0): LAC photon20vision2 (DFP-0): Internal Dual Link TMDS
(--) NVIDIA(0): LAC photon20vision2 (DFP-1): 330.0 MHz maximum pixel clock
(--) NVIDIA(0): LAC photon20vision2 (DFP-1): Internal Dual Link TMDS
(II) NVIDIA(0): Display Devices found referenced in MetaMode: DFP-0, DFP-1
(II) NVIDIA(0): Assigned Display Devices: DFP-0, DFP-1
(II) NVIDIA(0): Validated modes:
(II) NVIDIA(0):     "DFP-0:1600x1200+1600+0,DFP-1:1600x1200+0+0"
(II) NVIDIA(0): Virtual screen size determined to be 3200 x 1200
(--) NVIDIA(0): DPI set to (99, 98); computed from "UseEdidDpi" X config
(--) NVIDIA(0):     option
(**) NVIDIA(0): Enabling 32-bit ARGB GLX visuals.
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC?  No, I don't.
(II) resource ranges after preInit:
(II) NVIDIA(0): Initialized GPU GART.
(II) NVIDIA(0): Setting mode "DFP-0:1600x1200+1600+0,DFP-1:1600x1200+0+0"
(II) Loading extension NV-GLX
(II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
(II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(**) Option "dpms"
(**) NVIDIA(0): DPMS enabled
(II) Loading extension NV-CONTROL
(II) Loading extension XINERAMA
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(II) AIGLX: Screen 0 is not DRI capable
(II) Loading sub module "GLcore"
(II) LoadModule: "GLcore"
(II) Loading /usr/lib/xorg/modules/extensions//libGLcore.so
(II) Module GLcore: vendor="X.Org Foundation"
(II) GLX: Initialized MESA-PROXY GL provider for screen 0
(**) Option "CoreKeyboard"
(**) Keyboard0: always reports core events
(**) Option "Protocol" "standard"
(**) Keyboard0: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Keyboard0: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Keyboard0: XkbModel: "pc105"
(**) Option "XkbLayout" "us"
(**) Keyboard0: XkbLayout: "us"
(**) Option "CustomKeycodes" "off"
(**) Keyboard0: CustomKeycodes disabled
(**) Option "Protocol" "auto"
(**) Mouse0: Device: "/dev/psaux"
(**) Mouse0: Protocol: "auto"
(**) Option "CorePointer"
(**) Mouse0: always reports core events
(**) Option "Device" "/dev/psaux"
(**) Option "Emulate3Buttons" "no"
(**) Option "ZAxisMapping" "4 5"
(**) Mouse0: ZAxisMapping: buttons 4 and 5
(**) Mouse0: Buttons: 9
(**) Mouse0: Sensitivity: 1
(II) evaluating device (Keyboard0)
(II) XINPUT: Adding extended input device "Keyboard0" (type: KEYBOARD)
(II) evaluating device (Mouse0)
(II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE)
(--) Mouse0: PnP-detected protocol: "ExplorerPS/2"
(II) Mouse0: ps2EnableDataReporting: succeeded
SetClientVersion: 0 9
ceci dit je suis tombé sur plusieurs forums où en réinstallant les pilotes ça passe
n°1077312
darxmurf
meow
Posté le 26-09-2008 à 22:38:39  profilanswer
drx1:/home/darxmurf# aptitude search nvidia -F '%c %p %V' --disable-columns | grep  ^i
i nvidia-xconfig 1.0+20080522-1
n°1077313
Mjules
Parle dans le vide
Posté le 26-09-2008 à 22:39:48  profilanswer
[:jar jar] et voilà, cherche pas plus loin, vraisemblablement les libs openGL fournis avec le pilote qui sont mal installées.
n°1077316
Riot
Buy me a riot
Posté le 26-09-2008 à 22:41:43  profilanswer
Tu as installé tes drivers comment ? .bin ? apt/aptitude ?
Si apt/aptitude tu as bien installé le paquet nvidia-glx ?
Be the one with the flames.
n°1077317
darxmurf
meow
Posté le 26-09-2008 à 22:42:27  profilanswer
je vais réinstaller les pilotes...
comment on fait déjà pour tuer X11 ?
init.d/gdm stop ?
Message édité par darxmurf le 26-09-2008 à 22:42:36
n°1077318
darxmurf
meow
Posté le 26-09-2008 à 22:43:43  profilanswer
mais sous apt y a rien qui tiens la route pour nvidia non ?
j'avais été chercher la version sur le site de nvidia
n°1077319
sligor
Posté le 26-09-2008 à 22:43:45  profilanswer
/etc/init.d/gdm stop
n°1077320
Riot
Buy me a riot
Posté le 26-09-2008 à 22:43:47  profilanswer
oui
n°1077321
Riot
Buy me a riot
Posté le 26-09-2008 à 22:44:28  profilanswer
Bah si, il suffit d'avoir le repository 'non-free' dans tes sources /etc/apt/sources.lis
n°1077322
darxmurf
meow
Posté le 26-09-2008 à 22:46:18  profilanswer
deb http://ftp.ch.debian.org/debian/ lenny main contrib non-free
deb-src http://ftp.ch.debian.org/debian/ lenny main contrib non-free
deb http://security.debian.org/ lenny/updates main
deb-src http://security.debian.org/ lenny/updates main
n°1077323
darxmurf
meow
Posté le 26-09-2008 à 22:47:51  profilanswer
le meilleur plan est de tuer X11, désinstaller les drivers actuels et réinstaller les autres ?
n°1077324
Riot
Buy me a riot
Posté le 26-09-2008 à 22:49:32  profilanswer
Ok.
- Tu désinstalles le paquet que tu as pris sur le site nvidia
- dans une console en root : "aptitude install module-assistant"
- m-a a-i nvidia (ça télécharge les sources, les compile et installe le paquet généré)
- aptitude install nvidia-glx
- /etc/init.d/gdm start
n°1077327
darxmurf
meow
Posté le 26-09-2008 à 22:59:27  profilanswer
bon là j'ai de la peine à comprendre :(
ta procédure n'a pas marché...
par contre j'ai relancé l'installeur de NVIDIA et now ça marche ! [:paysan]
putain c'est beau quand même ce jouet [:huit]
n°1077342
The Dml
pouet.. pouet ...
Posté le 27-09-2008 à 09:38:17  profilanswer
Salut :)
Certain parmis vous utilisent oracle-xe 10g ?
J'ai un  soucis avec le net Listener, quand je lance oracle il me met bien que le net listener ce lance.
Mais quand j'essaie d'accéder au service web j'ai rien. Et en faisant un  nmap localhost j'ai rien sur le port 8080 :/
Une idée ?
n°1077363
darxmurf
meow
Posté le 27-09-2008 à 12:24:50  profilanswer
Bon y a tout qui marche nickel !
merci pour votre aide en tout cas :jap:
Si vous passez dans le coin je vous offre une bière [:huit]
n°1077364
burn2
Posté le 27-09-2008 à 12:26:38  profilanswer
Quel bidouillage quand meme.  :D
n°1077366
Kortex@HFR
Qu'ils sont cons ces lamas !!!
Posté le 27-09-2008 à 12:37:40  profilanswer
C'est vrai que c'est plus simple avec Intel : rien à faire dans xorg.conf, juste à ajouter cd dépôt puis lancer fusion-icon :)
deb http://download.tuxfamily.org/sham [...] /unstable/ ./
Au coeur du swirl - Mon feed
n°1077367
darxmurf
meow
Posté le 27-09-2008 à 12:40:55  profilanswer
Mais clair :D
oui mais bon hein on fait ce qu'on peut :D
D'ailleurs vu que je suis sur le sujet, y a des tools pour calibrer les écrans sous nux ? j'ai une sonde XRITE mais j'ai rien trouvé de particulier pour calibrer ça...
n°1077371
burn2
Posté le 27-09-2008 à 12:55:00  profilanswer
Ben en temps normal sous nvidia y a rien d'autre à faire qu'installer les pilotes nvidia et tadaaa. Enfin chez ubuntu OpenSuse tout ça ça marche out of the box now.
Sur l'ancienne version d'openSuse c'était prévu pour utiliser XGL du coup, pour le faire sans fallait utiliser la liste de commande notée plus haut, mais sinon avec xgl c'était toujours pilote nvidia + un clic pour activer xgl et tadaaa.
n°1077373
darxmurf
meow
Posté le 27-09-2008 à 13:12:56  profilanswer
dites y a pas moyen de monter mes volumes NTFS sous gnome en user normal ?
je peux les monter en shell en étant root mais ça disparait de la liste des disques dans gnome [:paysan]
n°1077378
burn2
Posté le 27-09-2008 à 13:47:44  profilanswer
En modifiant le fstab tu peux faire qu'ils soient monté en continue en écriture/lecture pour tout le monde.
Par contre pas de gestion d'utilisateur au cas par cas sur du ntfs, c'est soit tout le monde, soit juste root.
Message édité par burn2 le 27-09-2008 à 13:48:07
n°1077380
darxmurf
meow
Posté le 27-09-2008 à 13:53:48  profilanswer
ouaip je suis tombé sur un tuto pour ça je crois que c'est ce que je vais faire.
sinon y a moyen de magouiller un truc en faisant un UMASK apparemment
http://www.linuxforums.org/forum/r [...] olved.html
[neewbe debian]Package mplayer pour debian Woodydebian ou slackware?
du gnu debian dans une sauce apple melangez avec du freebsd et on a[Debian] probleme avec Xfree
[Debian] comment installer KDE 2 voir KDE3 si possible ??comment installe-t-on une debian
disquette de boot debianinstall carte reseau ISA debian
[ncurses] DEBIAN - je peux pas configurer mon noyau Sniff[Debian] stable / unstable
Plus de sujets relatifs à : [DEBIAN] - Intégristes barbus, |337, femmes nues...
