2381 connectés
Quelle caméra IP WIFI PAN TILT IR (d'entrée de gamme) considérez-vous comme ayant le meilleur rapport fonctionnalités-qualité/prix ?
 Page :   1  2  3  4  5  ..  229  230  231  ..  251  252  253  254  255  256
[Topic Unique] FOSCAM FI8908W FI8918W FI8910W & clones
n°735252
zepolo
Posté le 16-05-2013 à 10:29:12  profilanswer
theuberoverlord a écrit :
It would be much better to see if you can place pressure on the seller. To provide the proper firmware and fixes for your camera model and the hardware version of that camera model.
Don
Sorry Don, la réponse du support FOSCAM est sans ambiguité ...
[#0000FF]The version (11.15.2.17) has stop producing for more than two years. I'm afraid there is no newer firmware for your camera.
You do not need to worry about the security if you protect the IP address and port number well.
Any problem, please feel free to contact me!
Your satisfaction is our goal.
Are you satisfied with our service?
Our aim is to provide perfect service,so your suggestions are appreciated.
If you are not satisfied, please e-mail aftersales@foscam.com with your assessment or feedback.
Peut être les versions plus récentes auront plus de chances :??:
n°735291
foscom
Posté le 16-05-2013 à 16:31:27  profilanswer
Pour rebondir sur cette histoire de port, quelqu'un a-t-il testé un port à 5 chiffres : côté caméra (FI8910W) ça à l'air possible à la saisie, côté routeur (Freebox) je ne sais pas si la redirection est possible ?
Cela permettrait de sortir des ports classiques : 80, 8080 et suivants, tout en respectant les règles :
http://www.iana.org/assignments/se [...] umbers.xml [long à charger...]
"Port numbers are assigned in various ways, based on three ranges: System Ports (0-1023), User Ports (1024-49151), and the Dynamic and/or Private Ports (49152-65535); the difference uses of these ranges is described in [RFC6335]. System Ports are assigned by IETF process for standards-track protocols, as per [RFC6335].  User Ports are assigned by IANA using the "IETF Review" process, the "IESG Approval" process, or the "Expert Review" process, as per [RFC6335].  Dynamic Ports are not assigned."
Du port 49152 à 65535 (Dynamic and/or Private Ports) cela laisse pas mal de choix, avec une moindre probabilité que le port utilisé soit découvert ? A moins qu'il ne soit très rapide de passer tous ces ports en revue ?
n°735392
theuberove​rlord
Posté le 17-05-2013 à 16:41:56  profilanswer
If would appear. The new firmware was released by Foscam for ("Exploit One" ) for current IP Camera models that are/would be, still under warranty. The same cannot be said for older hardware versions, of the same IP camera models. That may no longer be covered by warranty.
Don
CV - About Me: Français English Conseils et exemples gratuits pour vos Camera IP Live IP Cam Demos
n°735419
foscom
Posté le 17-05-2013 à 23:10:20  profilanswer
Quelques tests ce soir avec les cameras MJPEG de démonstration sur Foscam .com et .fr :
Les 3 caméras de foscam.com sont protégées de l'exploit 1, mais pas de l'exploit 2 avec les identifiants fournis.
La caméra de 2012 de casabill.com (.ma) est protégée de l'exploit 1, pas celle de 2009, et aucune des 2 de l'exploit 2 avec les identifiants fournis.
Cela ne fait hélas que confirmer les informations disponibles :-(
edit: qq détails
Message édité par foscom le 18-05-2013 à 19:30:12
n°735620
dd91
Posté le 20-05-2013 à 12:59:05  profilanswer
Bonjour
j'espere etre sur le bon forum... voila je possede 4 camera ip heden... trois qui fonctionne parfaitement no proble, par contre j'en est une qui me pose soucis je m'explique:
lorsque je la branche internet devient lent voir impossible d'afficher une page...
pourtant la cam elle est accessible depuis l'exterieur et interieur sans probleme.
lorsque l'on s'est authentifié sur la cam on peux une fois sur deux se resservir d'internet...
de plus la camera se remet souvent au 1er janvier 1970
des idees sur la question?
cdlt
DD91
Message édité par dd91 le 20-05-2013 à 13:31:41
n°735669
hubert59
Posté le 20-05-2013 à 19:43:40  profilanswer
Bonjour à tous,
Je possède depuis plusieurs années des caméras Foscam et j'en suis pleinement satisfait.
Par contre, je viens d'acheter une Foscam:FI9821W.
En mode filaire, pas de soucis.
Par contre, dès que je veux passer en wifi, la camera apparait bien connecté sur le routeur (vérifié à me connectant au routeur) mais elle n'apparait pas avec l'utilitaire: IP Camera Tool.
Cordialement
n°735692
Noren2
Posté le 20-05-2013 à 22:06:45  profilanswer
Je m’intéresse au camera ip pas cher et du coup je pense aller vers la FI8910W qui me parait être le meilleur rapport qualité prix, en tout cas pour surveiller un petit appartement.
J'ai en revanche une question (peut être un peu con  :D ) :
- Est-ce qu'il est facile de l’éteindre et la redémarrer ?
Genre un bouton on/off, et quand on la rallume y a pas de paramétrage à refaire ça marche tout seul.
L'idée c'est de l'activer quand je vais partir bosser, et la désactiver quand je suis chez moi dans mon petit F2.
Car j'ai pu être témoins des divers hack, j'ai pas franchement confiance et n'ai pas envie qu'on me matte :p
n°735801
foscom
Posté le 22-05-2013 à 08:02:42  profilanswer
Pas d'inter dessus et caméra au plafond : je débranche le transfo en rentrant !
On peut donc aussi utiliser une prise murale commandée par inter, ou un bloc prise avec inter...
Aucun soucis lors de la coupure (au milieu d'envoi de mails + ftp...) ni au redémarrage (tout se remet en place tout seul).
Contre le hack, j'ai détaillé ce que j'ai mis en place il y qq jours sur ce fil, mais je suis preneur d'amélioration du côté des "ports" ?
n°735802
ol666
Posté le 22-05-2013 à 08:13:38  profilanswer
plusieurs solution :
- une prise télécommandée ou un module domotique pour allumer/éteindre la cam
- diriger la cam vers le plafond qd tu rentres chez toi ce que j'ai fait chez moi. Qd je coupe l'alarme, toutes les cam se mettent en position vers le plafond et quand j'active l'alarme, elles se mettent toutes en position de surveillance
n°735889
theuberove​rlord
Posté le 22-05-2013 à 18:12:50  profilanswer
Noren2 a écrit :
Many are not aware that these cameras support many kinds of schedules. Which are not accessible via the normal UI ("User Interface" ) that comes with the camera. That said. These schedules do exist in the cameras configuration. These schedules function much like the Alarm schedule which allow specific days and times to be enabled/disabled.
There is an FTP NOW schedule, which can be used to send images from the camera at specific intervals, on specific days and at specific times. This schedule does not depend on alarms for the camera. It simply uses the FTP NOW schedule and interval for how often and when FTP images are sent by your camera via FTP.
There is also a Forbidden schedule. Which allows the camera to disable images, video and audio on specific days and at specific times. No access to the cameras images, video and audio, will be allowed by any User Level, including Admin User Levels, until the Forbidden schedule does not forbid that specific day and specific time or the Forbidden schedule is disabled. This allows you to basically turn the camera off, while still leaving the camera power on and connected.
Using .cgi commands. One can enable/disable the Forbidden Schedule at will. Example. If you set ALL days and times for the Forbidden schedule to be forbidden. Then, when needed simply enable the Forbidden schedule. Anytime you wish to disable/enable the camera, you can simply use .cgi commands, even as shortcuts to instantly disable/enable your camera. Of course. You can also use the Forbidden Schedule and leave it enabled at all times. So that on specific days and at specific times, your camera will auto-disable images, video and audio and auto-enable images, video and audio when the Forbidden schedule is set to allow images, video and audio.
More details on how the Forbidden Schedule is used can be found here. Virtually ALL MJPEG brands and models and clones that function like the camera models in this thread. Support this feature. This is not limited to only Foscam MJPEG based IP Cameras:
http://foscam.us/forum/completely- [...] tml#p26441
Note: It is not possible to only disable images or video or audio. When the Forbidden schedule is used images, video and audio will be disabled on the specific days and specific times, when the camera is told to enable the Forbidden schedule. Additionally. Once the Forbidden schedule days and times are set. You can simply set the camera to enable or disable the Forbidden schedule. Again, by using a .cgi command, which can even be quickly done by storing those .cgi commands as shortcuts, so that you can do this all by using one-click.
While the Forbidden schedule is enabled and if the Forbidden schedule is set to disable images, video and audio. During the time you or others access your camera. All menu options allowed for the specific User Level are still accessible. For example. Admin User Ids can still access settings and change them. The only things that will not be accessible at those moments are images, video and audio.
Of course, at anytime, even if you have set the camera to forbid images, video and audio, for that day and that time and suddenly have a need to access images, video and audio on that day at that time. You simply need to use a .cgi command to disable the Forbidden schedule during those times to regain access to images, video and audio and do the same, if needed afterward to re-enable the Forbidden schedule afterwards.
Don
Message édité par theuberoverlord le 22-05-2013 à 18:31:44
n°735908
Bladinium
Posté le 22-05-2013 à 20:46:19  profilanswer
hubert59 a écrit :
Bonjour à tous,
Cordialement
Pareille!
n°735935
theuberove​rlord
Posté le 23-05-2013 à 00:34:08  profilanswer
hubert59 a écrit :
Bonjour à tous,
Cordialement
You are very welcome.
Please check to see if your Router/AP has wireless MAC Address security enabled. If it does and you wish to keep it enabled. You will need to add the wireless MAC Address of the camera, before the camera will be allowed to connect wirelessly to your Router/AP.
Note: The cameras have TWO different MAC Addresses. One for wired mode, one for wireless mode. So, please make sure you add the correct MAC Address to the list for wireless MAC Address security. If you have and wish to keep that Router/AP feature enabled.
Don
n°736102
artrox
Posté le 24-05-2013 à 16:03:20  profilanswer
Pour  éviter d'être victime de l'exploit one sur la Foscam FI8908W, vous pouvez, si vous disposez d'un NAS Synology, utiliser le paquet surveillance station pour les accès web et DS Cam pour les accès à partir de votre mobile.
Le NAS servant de rebond pour accéder à la Foscam en local, vous n'êtes plus exposé à l'exploit.
Inconvénient, le logiciel Android DS CAM reste très limité par rapport à IP Cam Viewer que j'utilisais.
n°736200
Noren2
Posté le 25-05-2013 à 16:03:03  profilanswer
Thanks a lot Don, I'll check that " Forbidden Schedule".
Et merci foscom et ol666 ;)
Message édité par Noren2 le 25-05-2013 à 16:03:32
n°736737
bessard
Posté le 31-05-2013 à 13:25:48  profilanswer
J'espère ne pas me tromper de topic !
Ma camera Foscam FI8918w en wifi
Tout fonctionne correctement lorsque je l'interroge à distance (au travers neufbox) par Chrome ou Firefox (sans les fonctionnalités de IE !)
Hélas dés que je valide par IE, l'image de base apparaît puis avant que de voir l'image caméra le pc bloque ..... je n'ai plus qu'à redémarrer par extinction/ré allumage !
Mon PC HP portable HDX18 -1150 EF 2,40 Ghz 4,00 Go de RAM. Carte graphique NVidia GEForce 9600MGT
Sous W7 64
Je viens d'essayer chez un ami avec son Toshiba portable aussi sous w7 ... cela fonctionne correctement !
J'ai bien sur essayé plusieurs réglages de la CG ! IE 7 ..8 ..
Voir même sous Chrome avec IE tab (sous 7,8 ou 9) même défaut !
Bouh ! je désespère
Qui peut m'aider ??
Par avance merci
Daniel
n°736746
bessard
Posté le 31-05-2013 à 15:13:04  profilanswer
The preceding message but in English !
I hope not deceive me topic!
My camera Foscam FI8918W wifi
Everything works fine when I asked remotely (through neufbox) in Chrome or Firefox (without the functionality of IE!)
Unfortunately as soon as I valid IE, the base image then appears before the camera image to see the pc crashes ..... I do not have to restart by extinction / re-ignition!
My PC HP HDX18 laptop EF -1150 2.40 Ghz 4.00 GB of RAM. NVidia GEForce 9600MGT
Under W7 64
I just tried with a friend on his mobile as under w7 Toshiba ... it works properly!
I have tried several settings on the GC! IE 7 .. 8 ..
See even in Chrome with IE tab (under 7.8 or 9) the same defect!
Boo! I despair
Who can help me?
In advance thank you
Daniel
n°736788
lajeff
Posté le 31-05-2013 à 23:08:46  profilanswer
J'ai fait l'acquisition d'une FI8910W.
J'ai un problème pour y accèder depuis l'extérieur.
Voici ma config:
Sur mon routeur la redirection NAT
# Nom Protocole Type Ports externes Adresse IP de destination Ports de destination Activation
1  Cam1  TCP  Port 85 192.168.1.XX 85
Sur l'administration de la webcam :
 DDNS Status   No-Ip Succeed  http://yyyyyyy:85
J'accède bien à ma box depuis le ddns (http://yyyyyyy) mais j'arrive pas accèder à ma cam depuis http://yyyyyyy:85.
des idées ?
n°736799
bessard
Posté le 01-06-2013 à 09:46:30  profilanswer
Bonjour lajeff,
Je te conseille d'aller sur l'excellent site ci-dessous :
http://www.cam-officiel.fr/fr/arti [...] stallation
J'ai personnellement acheter mes cam chez Casabill mais vu l'aide qu'ils apportent !!! je vais me diriger ailleurs pour mes prochains achats.
J'espère pouvoir avoir une réponse de Hardware pour ma question .....
Bon week et bon courage :-)
Cordialement
Daniel
n°736830
sperry
Posté le 01-06-2013 à 18:48:19  profilanswer
Voici ma config:
des idées ?
Quel est ton F.A.I. ?
Sinon, commencer par :
-mettre la Cam en IP attribué par le serveur (dans le paramétrage de la Cam)
-Dans la BOX, fixer l'adresse IP à partir de l'adresse MAC de ta CAM et faire la redirection entre l'IP et le port 85
Dis nous...
n°736834
lajeff
Posté le 01-06-2013 à 20:08:15  profilanswer
Dis nous...
Merci pour vos suggestions.
En fait tout était bien configuré, c'est juste que je ne pouvais pas depuis mon ordinateur sur le réseau accèder à la cam par avec l'adresse internet.  :jap:
Message édité par lajeff le 01-06-2013 à 20:08:36
n°736917
reivax69
Posté le 03-06-2013 à 10:28:07  profilanswer
Bonjour;
est-ce que quelqu'un peut me confirmer que les caméras Heden supportent sans problème le cryptage en WPA2 ?
Je viens de changer mon protocole de WPA à WPA2 sur ma box (sans changer le password) et depuis je n'ai plus d'accès à mes 2 caméras.
Je suppose qu'il faut re-paramétrer mes 2 cams en connexion ethernet, en modifiant simplement le protocole de cryptage ?
n°736922
OUARZA
Posté le 03-06-2013 à 10:52:46  profilanswer
J'ai acheté un petit module CP2102. Lors du démarrage de la cam, je n'ai rien qui s'affiche sur le terminal.
Je crains que ma webcam est morte...
Message édité par OUARZA le 03-06-2013 à 10:52:58
n°737137
ketchoupi1
Posté le 05-06-2013 à 14:02:50  profilanswer
bonjour
j'aimerai comprendre que doit on voir avec les exploits 1 et 2 (first page peut etre)? peuvent ils utiliser le ptz?
en fait via mon alarme domotique elles se tournent vers le plafond quand nous sommes la
si je fais :
XXX.XXX.XXX.XXX etait mon ip publique (en fixe), j'ai essayé en local aussi
http://XXX.XXX.XXX:####//proc/kcore :      j'ai plein de lignes qui s'affichent
http://XXX.XXX.XXX.XXX:####/decode [...] proc/kcore : il demande l'utilisateur et le mdp
par contre je suis carrement a la bourre sur les firmwares car je n'ai jamais fait de mise a jour
j'ose meme pas vous donnez mes versions .... :whistle:
allez pour me faire fouetter :
fi8918 (je crois)
Device Firmware Version   11.22.2.30
Device Embeded Web UI Version   2.4.18.15
fi8910
Device Firmware Version   11.37.2.46
Device Embeded Web UI Version   2.4.10.2
taper pas trop fort .....
Message édité par ketchoupi1 le 05-06-2013 à 14:04:05
n°737141
theuberove​rlord
Posté le 05-06-2013 à 14:27:47  profilanswer
ketchoupi1 a écrit :
bonjour
si je fais :
fi8918 (je crois)
fi8910
Please see these links:
http://forum.hardware.fr/hfr/Hardw [...] tm#t731850
http://forum.hardware.fr/hfr/Hardw [...] tm#t733067
http://forum.hardware.fr/hfr/Hardw [...] tm#t733934
http://forum.hardware.fr/hfr/Hardw [...] tm#t733939
http://forum.hardware.fr/hfr/Hardw [...] tm#t733963
Shows how to test your camera for both vulnerabilities: http://forum.hardware.fr/hfr/Hardw [...] tm#t733983
http://forum.hardware.fr/hfr/Hardw [...] tm#t735121
http://forum.hardware.fr/hfr/Hardw [...] tm#t735213
It should be noted. That Foscam HAS just released a new version of firmware for many MJPEG based IP Cameras that as it states "fixes several vulnerabilities to improve security". There are no specific details as to what these vulnerabilities are. Also, the firmware system versions for these firmware releases, all end with x.x.x.51 and once this version of system firmware is installed "You CANNOT downgrade to previous versions".
More details here: http://foscam.us/forum/new-firmwar [...] tml#p28096
Some older IP Camera hardware versions of current IP Camera models, may not have any new firmware versions. Different hardware versions of the same IP Camera model are denoted by the first two sets of digits in the system firmware version. Such as "11.22.x.x".
You should NOT install any version of firmware for your IP camera, that does not match the first two sets of digits that your current IP Camera has installed for system firmware. You also should not use any firmware for any other IP Camera model. Even if that IP Cameras model has firmware downloads available, that happen to have the same first two sets of digits that do match your IP Camera models system firmware version.
People who have clones or other brands of IP Cameras, that are not Foscam. Should NOT install this new firmware version. Even if the first two sets of digits of your system firmware version match. This is because many IP cameras which use different brands or clones use different IP Camera components internally, that may not be the same as your IP Cameras internal components. This includes many things, some being, different image sensors and wireless boards that because of this. Could render your IP Camera useless. It's best to contact the seller of your IP Camera. Because it's possible that if you try to install this new firmware in your IP Camera and it is not correct for your IP Camera. You may NOT be able to downgrade to the correct version of firmware for your IP Camera. Leaving you with a very expensive paperweight.
Don
Message édité par theuberoverlord le 06-06-2013 à 02:59:06
n°737194
flashlinke​r
Posté le 05-06-2013 à 21:18:48  profilanswer
bon je suis peut etre pas sur le bon topic  ;)
j'ai fais l'acquisition d'une foscam fi 8905W et connecter en filaire tous fonctionne bien , j'ai accès a la cam via mon smartphone , mais je n'arrive pas a la connecté en wifi sur ma freebox revolution qui est en wpa2
ma foscam est une version assez ancienne puisqu'elle est  en Version du Firmware   11.15.2.17
  Version interface web   2.4.9.14
y'a t il une ruse pour la connecté en wifi a une freebox ? j'ai tenté le wpa , pareil :( , une idée de mon souci ? :jap:
topic des bougnats http://forum.hardware.fr/forum2.ph [...] 0&trash_po
n°737216
Bouriquet5​9
Posté le 06-06-2013 à 09:12:43  profilanswer
Bonjour à tous,
Je viens de commander 2 caméras FI8910W que je vais recevoir prochainement.
Je suis actuellement sous windows phone et j'ai vu qu'il n'existait pas spécialement d'appli pour visualiser et commander sa caméra. Du coup je me suis dit pourquoi pas faire une appli convivial et surtout gratuite.
J'aurais cependant besoin d'un coup de main. J'ai vu en première page des commandes pour bouger la caméra, pour activer la surveillance etc.. mais je n'ai pas vu comment récupérer le retour de celle-ci pour savoir si elle est bien en surveillance par exemple.
Ou plus simple auriez-vous une doc qui regroupe toutes les commandes de la caméra possible ?
Mon objectif serait de faire une appli pour windows phone et plus tard pour windows 8, sachant que les deux OS sont très proches.
Merci d'avance pour votre coup de main.
Michael
n°737225
theuberove​rlord
Posté le 06-06-2013 à 13:20:35  profilanswer
Bouriquet59 a écrit :
Bonjour à tous,
Michael
You are very welcome. I am including as much information as possible in this response. So that as needed. Others can use it as a reference. You and/or others can link back to this response directly by using this:
http://forum.hardware.fr/hfr/Hardw [...] tm#t737225
Hello.
There are two methods to interface to these IP Cameras. One is a high level interface, using .cgi commands. The other is a low level interface using http data packets. Here is information and examples. With Live Demos for the high level interfaces as well as a pre-compiled binary for Windows based systems showing the use of the low level interface. Including documentation for both interface levels as well.
Please see this free Interface which includes Live Demos, that work with any Internet browser capable device from Computers to Tablets and Phones to TVs:
http://foscam.us/forum/free-generi [...] tml#p10970
Here is another free Interface which is Windows based, that can monitor as many as 10 IP Cameras at the same time and record video with audio on IP camera alarms. Please note. Normally, only video is recorded on alarms. This also allows you to define the length/time of the video as well as the resolution and FPS ("Frames Per Second" ) rate of the video. Normally alarm recordings, are always 60 seconds long:
http://foscam.us/forum/free-mjpeg- [...] tml#p15874
Here is the documentation for the high level .cgi SDK for these IP Camera models:
http://foscam.us/forum/download/file.php?id=402
Here is the documentation and a full c++ project, including source code, for the low level interface, with a low level pre-compiled binary .exe for Windows example:
http://foscam.us/forum/sample-code [...] tml#p24770
It's also possible to customize the UI ("User Interface" ) that the IP Camera uses, as well as host and store other web pages inside the IP Cameras firmware. Basically using the IP Camera as a self-contained, tiny web server, by storing custom web pages in the IP Camera itself. Please look toward the bottom of the page this link goes to, for more information, on how to go about doing that:
http://www.openipcam.com/forum/ind [...] 473.0.html[url]
The IP Camera has limited memory. So you could not use the IP Camera as a full blown web server. However, you can use the IP Camera as a small mini web server and include custom web pages, in the actual IP Cameras Web UI firmware and/or modify and customize, the standard IP Camera interface, that comes with the IP Camera.
Here is an example of modifying the IP Cameras Web UI firmware, where a custom web page was added. This web page is stored in the IP Cameras memory and was added to the IP Cameras normal Web UI firmware. The normal Web UI of the standard IP Camera interface still works as normal. This is simply another web page that was added to the Web UI firmware.
Now the IP Camera can be used for public access, limited access or private access, to host and supply this web page, directly from the IP Camera. Without any need to use the standard IP Camera interface, that comes with the IP Camera or have a website or web hosting service to store this custom web page. This example is using the free Interface of the first link in this post, with custom configuration options, the Interface supports. It could prompt for logon vs. auto-logon, which is one of the configuration options in the free Interface:
http://cam18372.topipcam.org:90/Ne [...] erator.htm
The above link is hosted and served directly from the IP Camera itself using the DDNS of the IP Camera and name of the custom web page and it can be used and accessed by any Internet browser capable device. From Computers to Tablets and Phones to TVs.
If your ISP IP Address does not change often, you could also simply use your ISP IP Address and the port for the IP Camera and the name of the custom web page with no need to use any DDNS for the IP Camera.
Example: http://68.187.157.136:90/NewWorkingDemoOperator.htm
One could use the links above for private use or in any Email correspondence or on social media sites to say things like "Hey..Take a look at my IP Camera here!" without any need to have a website to host the link above. You could also delete the User Id or change the password in the IP Cameras configuration being used in the link above, to disable the link above, from working, as needed. So it can be turned off/on enabled/disabled easily.
You can also use this internally within your local network. Even if you do not allow remote access from the Internet to your IP Camera by simply accessing the local IP Address and port for your IP Camera and the name of the custom web page. Example:
http://192.168.1.10:90/NewWorkingDemoOperator.htm
Again, you could also have configured this custom web page to prompt for logon vs. auto-logon as it does. So that anyone who uses the link above, would still need to know a valid IP Camera User Id and the password for that IP Camera User Id. This would also allow you to change the User Id or the password, from time to time and only those knowing the new User Id or password ("Even if many others had the link above, from the past" ). Would not be able to access the IP Camera, using the link above, without knowing the new User Id or new password.
In fact. Even with using the auto-logon option in the above link. If I were to delete the User Id or change the password in the IP Cameras configuration, which is being used in the link above. The same web page, being used in the link above, would now prompt for logon. So there are easy ways to go from auto-logon to prompt for logon without changing/modifying the actual web page the IP Camera is using or installing a new custom Web UI firmware for the IP Camera.
Of course you could also create and store custom web pages in the IP Camera, that have nothing to do with the IP Camera. "About Me" web pages with pictures and background images, other web pages with links to your social media sites, another web page of your resume and so on. Use your imagination.
As you can see there are many options to create custom interfaces for these IP Cameras and access those custom interfaces. I tried to cover all possibilities here. So that you and others can pick the ones that fit your needs.
Without trying to bore anyone to tears. There is one important factor when creating interfaces for these IP Cameras that needs to be considered. These IP Cameras only support ("Four" ) formally logged in concurrent connections. Once this limit is reached, all other requests for formally logged in connections WILL be refused or denied, by the IP Camera.
Formally logged in connections include: Copies of the standard IP Camera interface that comes with the IP Camera that are logged in, Video Streams directly to the IP Camera that are active, applications that use the low level interface to the IP Camera, as well as many, if not most, 3rd party applications.
You can emulate this limit, by trying to exceed the limit by using any combination of the above. Example, try using five different browser windows to logon to the IP Camera, at the same time. Using the standard IP Camera interface that comes with the IP Camera. The fifth logon, will be refused or denied. This is important to know as a IP Camera owner. Because you can be running so many things at the same time for a IP Camera, that you can LOCK yourself out of accessing that IP Camera, until or unless a connection is released.
This also becomes extremely important if you want your IP Camera to be viewed from a website for public access. Because done wrong, it will only allow and support, four website visitors to access your IP Camera, at one moment of time, denying all other visitors access to your IP Camera. Worse, once four website visitors are viewing your IP Camera, you the IP Camera owner, will not be able to access your IP Camera, until one of those four website visitors stops viewing your IP Camera.
The Interfaces that I create ("Including the example custom web page stored in the IP Camera itself and the free Interface example" ). Use short-term connections. Leaving all four of your formally logged in connections available for use, by other interfaces. So this limit of ("Four" ) concurrent formally logged in connections does not apply to my Interfaces. The limit of concurrent connections for my interfaces, shown here, is ("Eighty" ) concurrent connections. It's actually higher than eighty, since this number is short-term connection in flight ("Outstanding requests that have not yet received a response. Which are concurrently in progress" ). This is by design, whereas many if not most, 3rd party developers, are using the formally concurrently logged in connections.
You can also emulate this. Simply by opening more than four browser windows using my Interfaces, to the same IP Camera. Your connections to the IP Camera, once they exceed four, will not be denied or refused, as is normally the case, when using other interfaces to your IP Camera.
IMHO. If you are going to create an interface to these IP Cameras and not allow the interface to be used by ALL Internet browser capable devices. It's somewhat like going to medical school to end up specializing as a foot doctor, who only works with big toes, on left feet only. While you may get patients that use your services. Most likely not as many as other foot doctors that work with anything that has to do with feet!
No disrespect to foot doctors intended. Point being, the second you start specializing and confining who your audience is for your IP Camera interface, based on what Operating System and/or device, they use or can use your IP Camera interface on. You limit the possible uses of your interface to a much smaller group than the entirety of all IP Camera owners who use these IP Cameras. This maybe important if you intend to charge for your IP Camera interface as well. Most of the large computer manufactures, have learned this lesson the hard way, as tablets and other mobile devices have increased in sales. Their sales have decreased, because they did not keep their eye on the ball.
This is easy for me to say. Since my primary goal was/is to provide free interfaces for all IP Camera owners of these IP Camera models. Which I have created interfaces for. I did and continue to do this because I saw many frustrated IP Camera owners who were needing to purchase special applications for each device they used to access their IP Cameras and/or wanted to for private use or to allow limited or public access to their IP Cameras, that would work with all Internet browser capable devices, at no cost. Not limiting that access to four at a time, or locking the IP Camera owner out of their own IP Cameras, when that limit is reached. So, this is just my opinion based on those complaints and observations.
Don
Message édité par theuberoverlord le 06-06-2013 à 19:13:24
n°737255
Bouriquet5​9
Posté le 06-06-2013 à 21:21:04  profilanswer
Merci beaucoup pour la réponse très complète.
Je vais regarder ça de près et vous tiens au courant dans l'avancement de mon projet
n°737258
bessard
Posté le 06-06-2013 à 21:39:24  profilanswer
bonjour à tous
Snif ! pas eu de réponse à mon post du 31 mai !
Quelqu’un peut-il m'aider
Merci  d'avance
Daniel
n°737268
theuberove​rlord
Posté le 06-06-2013 à 23:23:32  profilanswer
bessard a écrit :
bonjour à tous
Merci  d'avance
Daniel
Please see this about using IE ("Internet Explorer" ) browsers with these IP Cameras on 64 bit based systems:
http://foscam.us/forum/set-recordi [...] tml#p13412
Don
Message édité par theuberoverlord le 07-06-2013 à 00:53:31
n°737280
bessard
Posté le 07-06-2013 à 09:37:05  profilanswer
Hello Theuberoverlord,
Thank you for your answer
I am testing and you want to know
See you later
Daniel
n°737346
bessard
Posté le 07-06-2013 à 16:48:54  profilanswer
Thank you,I read the link on IE and IP camera on 64 bit system.
So I connected with IE10 32-bit, as shown in the post.
Unfortunately the result was the same, complete blockage of PC dice appearance of video. Forced to turn off the PC! what bad luck !
Help !
Message édité par bessard le 07-06-2013 à 18:00:13
n°737575
bessard
Posté le 10-06-2013 à 16:34:47  profilanswer
A priori pas de réponse, pas de solution .....!
Tant pis je vais donc devoir me contenter d'une visu incomplète avec Chrome.....!
see you later
Daniel
n°737579
patochelil​le
Posté le 10-06-2013 à 17:04:35  profilanswer
Pour ma part cela fait longtemps que j'ai abandonné ie sous win , utilise android et plus de problèmes pour la gestion de ta caméra
Déjà constaté ton problème avec neufbox et pas de solution ,désolé
n°737593
theuberove​rlord
Posté le 10-06-2013 à 19:03:56  profilanswer
Help !
What operating system are you using?
Please see this as well:
http://foscam.us/blog/foscamipcame [...] ol-module/
Don
n°737614
bessard
Posté le 10-06-2013 à 23:40:53  profilanswer
Hello Don
As indicated in my email of 31 May I work with Windows 7 and Internet Exlorer 10 64 ou 32 bits.
I checked the settings from Internet Options in IE, they correspond to those indicated by your link: http://foscam.us/blog/foscamipcame [...] ol-module/
Unfortunately the result is always the same: the emergence of the dice of the video camera, complete blockage of the PC, have to manually turn it off and reboot.
Daniel
n°737616
theuberove​rlord
Posté le 10-06-2013 à 23:52:56  profilanswer
bessard a écrit :
Hello Don
Daniel
Using the 32 bit version of IE Version 9. Please try using IE "Compatibility mode".
If that fails to change things. Please try checking IE Internet Options:
Tools -> Internet Options -> Programs -> Manage Add Ons
Check to see if the ActiveX is installed and enabled for the camera.
Don
n°737620
bessard
Posté le 11-06-2013 à 00:46:59  profilanswer
I am attaching two links: screenshot for activex. log event viewer after shutdown the PC
http://cjoint.com/?3FlaNMSxEj8
http://cjoint.com/?3FlaOEKSzQG
What do you think ?
n°737622
theuberove​rlord
Posté le 11-06-2013 à 01:31:43  profilanswer
What do you think ?
On your cameras logon screen. Do you see a link to the ActiveX? If so right click on it and choose "Run As Administrator.
If not then. Disable, then remove the current ActiveX controls you show in your first picture and access the cameras logon screen and re-install them. By going to the cameras logon screen afterwards.
Again. It would seem you are using IE 10 now. So, have you tried IE Compatibility mode when at the cameras logon screen as well?
You can do that by going to the cameras logon screen in IE 10 and then doing this from the IE menu:
Tools -> Compatibility View
Don
Message édité par theuberoverlord le 11-06-2013 à 01:32:57
n°737650
magnum081
Posté le 11-06-2013 à 13:44:01  profilanswer
Bonjour à tous, je souhaite vous faire part de mon probléme. Je dispose d'une Camera ip HEDEN Motorisée WiFi - VisionCam - CAMHED04IPWB. Elle fonctionnait trés en wifi et depuis le 07 juin 2013. Elle ne fonctionne plus. Je l'ai branché avec le cable ethernet sur ma freebox v5 mais le logiciel ipcamtools, ne la reconnait pas. Je l'ai réinitialisé à plusieurs reprises mais rien n'y fait. Lorsque je la débranche et rebranche, le voyant vert de la camera reste fixe et la camera ne tourne pas dans tous le sens. Est ce que quelque'un aurait eu déjà ce genre de problème. Est ce que ma caméra est morte ou pas. Merci à tous ceux qui me répondront.
n°737651
paillassou
Posté le 11-06-2013 à 13:48:04  profilanswer
Bonjour
(désolé si tu l'as déjà fait)
Appui long >30s, avec un objet pointu (non-métallique si possible)
sur le sur le petit bouton poussoir RESET qui est situé dessous la base.
la cam doit rebooter et tous les réglages sont effacés et remis par défaut.
bon courage
[Topic Unique] Nouveau Samsung PX2370Pb imprimante Wifi Tout-en-1 : erreur 1053
Heden Visiocam vs FoscamImprimer en wifi CanonMP620
Nouvelle PANASONIC BL-C230 PTZ H264 WiFi CAMERABrother DCP-375C (wifi) : status reste "hors connexion"
[topic unique] Philips 240PW9 - 24" - IPS
Plus de sujets relatifs à : [Topic Unique] FOSCAM FI8908W FI8918W FI8910W & clones
