5798 connectés
Quelle caméra IP WIFI PAN TILT IR (d'entrée de gamme) considérez-vous comme ayant le meilleur rapport fonctionnalités-qualité/prix ?
 Page :   1  2  3  4  5  ..  191  192  193  ..  251  252  253  254  255  256
[Topic Unique] FOSCAM FI8908W FI8918W FI8910W & clones
n°681283
Koontzy
Posté le 30-01-2012 à 21:24:08  profilanswer
Nouveauté chez Foscam !
la FI8910W avec IRCUT
infos venant du émail
Secondly, we wanted to let you know about the release of the new Foscam FI8910W. Building on the success of the Foscam FI8918W, the FI8910W distinguishes itself with an embedded IR-Cut filter which provides enhanced picture and color quality, an upgraded and higher quality external housing, greater horizontal panning range as well as an included 2 year extended warranty. For more information visit http://foscam.us/products/foscam-f [...] amera.html
du site internet:
The Foscam FI8910W features high quality video and audio, pan/tilt, remote internet viewing, motion detection, night-vision, embedded IR-Cut filter as well as a built in network video recording system. In addition, it is smartphone compatible (Iphone, Android & Blackberry) as well as viewable over the internet using standard web-browsers. The camera functions well as an Iphone baby monitor or as part of a home or office security system with remote internet monitoring ability.
Building on the success of the Foscam FI8918W, the FI8910W is the latest camera from Foscam Digital Technologies LLC. The FI8910W distinguishes itself with an embedded IR-Cut filter providing enhanced picture and color quality. The IR-Cut filter automatically adjusts the lighting exposure via mechanical filter to provide true and accurately colored images that are not washed out. In addition, the FI8910W has an upgraded and higher quality external housing as well as an included 2 year extended warranty.
Features:
Remote internet monitoring from anywhere in the world
Iphone/Ipad, Android & Blackberry compatible
IR-Cut filter for true color video and images
Two-way audio
300 degree pan, 120 degree tilt
IR lights for night vision up to 8 meters
99.99$ sur le site internet j'ai hâte de voir les revendeurs...
j'avais justement envie de changer de cam a cause des leds qui reflètent sur la vitre chez moi... ;)
n°681284
Koontzy
Posté le 30-01-2012 à 21:26:45  profilanswer
d'autre infos :
Features:
IR cut-off filter for True Colors. *Exclusive to this indoor model.
The IR lights can be turned off manually from the software
Audio quality is improved, there will be no noise when speaking into the camera.
WPA2 Encryption Supported
Added an audio input jack which can be used with an external microphone
Relocated the network light to the back of the camera. Add a power indicator lamp
Allows for remote viewing & recording over LAN or the internet through PC and mobile devices (including Iphone)
Simple to setup with a friendly graphical interface
High image & video quality (Display resolution: 640 x 480 Pixels (300k Pixels))
Two-way audio monitoring
Allows remote Pan/Tilt control (Pan:270deg& Tilt:120deg)
Night vision (up to 8 meters) via auto IR-LED illumination
Infrared Motion Detection (with email notification and image upload via FTP)
Multi-user access with password protection
Supports the IE browser, Firefox as well as most other standard browsers including the standard Safari browser on the Iphone
Wi-Fi compliant with wireless standards IEEE 802.11b/g. Wired connection is also included
Supports both WEP & WPA Encryption
Supports Dynamic IP Addresses such as through dyndns.org
Has multi-level user management system with password protection
j'ai remarquer WPA2 supported... est-ce que ça va régler les problèmes de clé Wifi trop compliqué ou trop longue ?
n°681286
paillassou
Posté le 30-01-2012 à 21:34:21  profilanswer
certains membres avait effectivement parlé de nouveaux modèles FOSCAM
et il semble que pour la FI8910W
ils ont dû faire une nouvelle version avec l'IR CUT ok ;)
http://forum.hardware.fr/forum2.ph [...] 0&filter=1
Message édité par paillassou le 30-01-2012 à 21:38:24
n°681291
c-bi
Posté le 30-01-2012 à 22:02:49  profilanswer
bonsoir a tous :)
Il existe quoi comme solution sonore pour les camera FI8918W ?
Les Fi8908w avec un connecteur pour pouvoir y brancher une sirène externe, mais apparemment ce n'est plus le cas sur les Fi8918w!
Y a-t-il une autre solution pour ces nouveaux modèle ?
Chez moi j'utilise un serveur Zoneminder pour gerer mes Cams. Il est possible de faire jouer un son/musique par le serveur si celui-ci est connecte a un equipement audio, mais j'aimerai surtout une sirene  proche de la camera plutot et je n'ai pas de solution pour l'instant...
Si vous avez une solution, je suis preneur :)
n°681293
paillassou
Posté le 30-01-2012 à 22:06:46  profilanswer
y a toujours l'audio (duplex: micro electret intégré + hp intégré + in mic + out hp) sur la FI8918W... ;)
http://www.chargerbuy.com/blog/fil [...] back-2.jpg
http://wirelesswebcam.org.uk/fosca [...] e-fi8908w/
qualité audio soit-disant mieux => avis perso: toujours aussi bof bof...
Message édité par paillassou le 30-01-2012 à 22:10:08
n°681299
eric29950
Posté le 30-01-2012 à 22:42:31  profilanswer
ou achetez vous vos cameras foscam ?
Je souhaite en acquerir , pouvez vous m'indiquer ou en trouver au meilleur prix sans les acheter directement en chine ...?
merci !
n°681300
cthugha
Messieurs , le youkounkoune
Posté le 30-01-2012 à 22:46:20  profilanswer
merci !
amazon.fr
n°681301
c-bi
Posté le 30-01-2012 à 22:49:39  profilanswer
Exacte :)
il est donc possible d'y brancher des haut-parleur dans cas non?
Comment envoyer du son a la camera dans ce cas ?
merci !
4sureriskfree sur ebay n'est pas trop cher et certains lots sont livrables depuis l'Angleterre
n°681303
Koontzy
Posté le 30-01-2012 à 22:52:33  profilanswer
et merde j'suis toujours en retard... ;)
n°681338
bubulle38
Posté le 31-01-2012 à 09:27:46  profilanswer
BONJOUR
IMPOSSIBLE... si le PC est eteint...  :sarcastic: ça semble logique...
par contre avec le PC allumé, c'est faisable via IE+ActiveX
Mais lorsque je parts plusieurs jours mon pc est éteint, si la webcam détecte une présence, j'ai compris que je peux recevoir une alerte par email mais à quoi ça sert si rien n'a enregistré l'intrus.
n°681342
paillassou
Posté le 31-01-2012 à 09:36:03  profilanswer
ben, tes alertes mails contiennent bien des images des détections..
ou alors il faut associer ta caméra à un NAS SYNOLOGY (enregistrement vidéo)
pour gérer ta caméra de manière plus pro...
mais c'est sûr, là c'est plus couteux...
Message édité par paillassou le 31-01-2012 à 09:43:08
n°681354
akilax
Posté le 31-01-2012 à 11:01:48  profilanswer
j’utilise une foscam FI8918W est-il possible d’enregistrer ma vidéo sur ftp ou sur hubic (http://www.ovh.fr/hubiC/ 25giga gratuit) ?
ou un lien pour un hébergeur ftp gratuit ?
n°681365
cmoarv
Posté le 31-01-2012 à 12:45:35  profilanswer
Bonjour a tous,
J’ai une FOSCAM FI8908W qui a un pb.
Tout allait bien jusqu’à ce qu’elle perde régulièrement la connexion avec mon NAS (Synology) et que finalement elle ne trouve plus du tout le réseau.
Je fais donc appel à vos connaissances et expertises en la matière …
Le pb de cette caméra est qu’elle ne semble pas trouver le réseau au moment du boot et boucle sur sa séquence de boot. Les led réseau a l’arrière (vert/jaune) clignotent mais je ne la vois pas la camera apparaitre dans Ip cam tools .
Concernant la connectivité, la cam est branchée en ressaut filaire en dhcp. La partie réseau fonctionne bien  car en branchant un notebook sur le même câble tout va bien.
J’ai essayé également un RAZ mais ça ne change rien…
Avez-vous connaissance d’un pb similaire et avez-vous des idées sur comment régler ce pb ?
En vous remerciant d’avance.
n°681374
pixeye3300​0
Posté le 31-01-2012 à 13:59:37  profilanswer
Vous voulez vous marrer ?
je viens juste d'acheter une FI8918W (j'ai apris la sortie du nouveau modèle le lendemain, et reçu la mienne aujourd'hui...)  :cry:
Rassurez moi  :cry:  :cry:  :cry:
n°681377
c-bi
Posté le 31-01-2012 à 14:35:46  profilanswer
Si tu peux, teste avec un cable croisé entre ton notebook et ta CAM avec le soft IP camera tool (http://www.e-foscam.com/support.html)
n°681386
paillassou
Posté le 31-01-2012 à 16:51:25  profilanswer
ne t'inquiete pas la FI8918W a encore de longs beaux jours devant elle... ;)
n°681387
c-bi
Posté le 31-01-2012 à 17:16:49  profilanswer
c-bi a écrit :
Exacte :)
Est possible de faire du stream audio sur une FI8918W dans ce cas ?
L'objectif serait de balancer un son de sirene en continue via le haut-parleur integré de la CAM.
Avec VLC, sans passer par l'interface Web, peut-etre ?
n°681402
paillassou
Posté le 31-01-2012 à 18:51:26  profilanswer
rien de méchant:
.... mais vous lisez la première page ???
 :sarcastic:
Message édité par paillassou le 31-01-2012 à 18:52:03
n°681416
cmoarv
Posté le 31-01-2012 à 21:00:40  profilanswer
@c-bi
Merci pour ton aide.
J'ai essayé avec un cable croisé et meme resultat:
1- leger bip du HP
2- Led verte de la cam allumée en fixe pendant ~10s
3- Led verte de la cam eteinte pendant ~5s
4- retour a 1
une idee du pb ?
n°681420
paillassou
Posté le 31-01-2012 à 21:17:43  profilanswer
@cmoarv
ce cycle signifie que ta cam reboote (semble rebooter)...
ta cam est donc:
-soit briquée
-soit HS
-soit elle a un bug... :lol:
l'aurais tu flashée avec un fw non compatible par hasard ?
as tu essayé la procédure recovery (1ere page)
http://www.gadgetvictims.com/2009/ [...] ck-to.html
essaye aussi un autre adaptateur secteur 5V/2A
cela pourrait très bien venir de là...
bon courage
Message édité par paillassou le 31-01-2012 à 21:20:53
n°681423
cmoarv
Posté le 31-01-2012 à 21:21:24  profilanswer
@paillassou
Aucun essai de flash avec un fw non compatible.
Elle perdait la cnx avec mon syno au debut de temps a autre puis de facon plus frequente et maintenant plus rien ne fonctionne ;o(
Je vais tenter le chanchement d'adaptateur et la proc de recovery.
Merci encore
n°681425
paillassou
Posté le 31-01-2012 à 21:24:17  profilanswer
est ce que quand tu ne branches aucun cable RJ45
(cam uniquement alimentée)
elle fait exactement le même cycle que tu as décrit:
1- leger bip du HP
4- retour a 1
Message édité par paillassou le 31-01-2012 à 21:25:01
n°681426
cmoarv
Posté le 31-01-2012 à 21:35:00  profilanswer
@paillassou
Ou exactement la meme chose avec uniquement l'alim
n°681427
paillassou
Posté le 31-01-2012 à 21:45:09  profilanswer
Pour info:
le leger bip du HP  (pop ou clic du HP)
est typique de la cam qui boote...
donc...
Supposition supplémentaire:
il se pourrait aussi que dedans ta cam, un des connecteurs soit débranché, ce qui provoquerait le reboote...
ou l'alim à découpage (adaptateur secteur) qui serait naze et qui ne fournirait pas assez de courant...
Message édité par paillassou le 31-01-2012 à 21:49:24
n°681438
krispan
Posté le 31-01-2012 à 23:35:07  profilanswer
Bonjour à tous...
Je sais mon message tombe comme un cheveu dans la soupe mais je voudrais un avis pour m'aiguiller sur mon problème suivant.
J'ai une camera Heden sur IP déclarée sur dyndns.org . J'étais chez orange en ADSL et en mobile. J'ai acheté le fameux IP CAMVIEWER que vous connaissez tous pour utiliser mon téléphone android en videosurveillance.
Tout s'est bien passé. Tout marchait nickel. Je pouvais en 3G accéder à ma caméra également à partir de n'importe quel réseau extérieur.
Je suis passé chez SFR tout en gardant le mobile orange. Toujours aucun problème.
Et là je suis passé chez SFR en mobile également... et là... c'est le drame:
IP CAMVIEWER a accès à la caméra en wifi (réseau maison) en renseignant son adresse IP (192.etc...)
IP CAMVIEWER n'a pas accès à la caméra en 3G en renseignant le dyndns et le port (alors que ça marchait bien avant !)
Par contre, Firefox (android) accède en 3G à la caméra en page html donc à l'image mais pas le navigateur par défaut qui mouline !
Si qqun a déjà rencontré ce genre de problème... merci d avance de m'aiguiller vers une sortie :)
n°681478
paillassou
Posté le 01-02-2012 à 09:26:20  profilanswer
krispan a écrit :
Bonjour à tous...
que tu y accèdes toujours en local (en WIFI), heureusement, c'est tout a fait normal, heureusement !
pour tes pb d'accès distant
essaye/teste avec d'autres ports externe pour ta NAT sur ta BOX.
vérifie si proxy sur la config  APN du mobile...
vérifie la conf APN SFR sur le mobile...
c'est SFR (mobile) qui doit te bloquer qqchose...
leve le doute en essayant depuis un test d''accès DISTANT depuis un PC qui est sur un réseau autre que SFR (neuf)
genre FREE, orange, numéricable etc...
bon courage
Message édité par paillassou le 01-02-2012 à 09:29:23
n°681495
sylm
Posté le 01-02-2012 à 11:41:33  profilanswer
J'ai eu ce problème avec IPCAMViewer qui ne m'affichait pas mes cameras en 3G, mais uniquement en Wifi (Hotspot SFR, SFRWifi).
Les adresses étaient externes (dyndns, mondomaine.com, ..)
Ma solution changer le user Agent de IPCAMViewer :
  Internet Explorer 6 (par défaut)
en
  IP Cam Viwer v3
(IPCAM Viewer / Paramètres / Network Settings)
Et la miracle mes caméras sont visibles en 3G nickel sur leur adresse externe
PS : IE6 par défaut quelle horreur ...
Message édité par sylm le 01-02-2012 à 11:43:27
n°681518
paillassou
Posté le 01-02-2012 à 13:08:40  profilanswer
[HORS-SUJET / just for fun]
Image d'une de mes cams IP prise ce midi (13H00)
C'est une DLINK DCS-2121 qui est installée dans le grenier d'une maison de l'arrière-pays niçois ;) à ~1000m d'altitude ;)
pour le plaisir des yeux ;)
http://img406.imageshack.us/img406/9397/dcs212101022012.jpg
Message édité par paillassou le 01-02-2012 à 13:10:08
n°681521
medamy
Posté le 01-02-2012 à 13:43:28  profilanswer
Si j'ai bien compris la nouvelle version de la Foscam avec l'IR-cut (outre les améliorations de ce filtre sur la qualité de l'image) permet aussi un contrôle manuel sur les Leds .
Correct?
n°681528
paillassou
Posté le 01-02-2012 à 14:34:57  profilanswer
tags: ir-cut IR CUT filtre infrarouge couleur couleurs vraies naturelle 850nm
la FOSCAM FI8918W permet déjà le controle TOTAL des LEDs IR:
-soit Les LEDs IR sont activées et de ce fait elle sont en mode auto par la LDR (photo-résistance)
=> jour=LEDs éteintes & nuit=LEDs allumées
-soit elles sont totalement désactivées
=> configuration idéale si la caméra est placée derrière une vitre.
Par contre pas de vision nocturne... ou alors il faut déporter un projecteur IR derrière la vitre pour voir dans la nuit ce que la cam visionne...logique...
Sur la FOSCAM FI8910W ou d'autres cam récentes d'autres fabricants (....qui sont quand même plus chères)
ce principe d'utilisation du "filtre IR-Cut" permet d'obtenir une image plus naturelle en journée avec des couleurs plus vraies & naturelles.
cet exemple est pas mal pour se faire une idée
http://imgs.inkfrog.com/pix/andy.lig/Compare-M205W.jpg
gauche => IR-CUT
droite => standard
Message édité par paillassou le 01-02-2012 à 14:44:05
n°681545
medamy
Posté le 01-02-2012 à 16:28:29  profilanswer
merci pour ton éclaircissement paillassou.
Je prospecte pour le moment pour utilisation principalement babyphone/ surveillance ponctuelle.
Question bonus, si tu le permets: Doit-on rebooter la cam si on passe les Leds IR de off vers on et vice-versa?
n°681550
paillassou
Posté le 01-02-2012 à 17:08:59  profilanswer
absolument pas...
n°681554
krispan
Posté le 01-02-2012 à 17:58:03  profilanswer
en
  IP Cam Viwer v3
sylm SYLM SSSSSSSSSSSSSSSSSSSYYYYYYYYYYYYYYYYYYYYYYYYYLMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMm MMMMMMMMMM MMMMMMM
MERRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRCIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII !!!!!!!!!!!!!! (louanges à toi :) )
C'etait bien ça !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! P%++!!!T+%**!!!! de m-----e !!!!!!!!!!!!!!!!!!!!!
Paramètre de mes c------s !!! Jamais j'y aurai pensé ! Et l'autre technicien sfr qui me dit "c'est normal votre téléphone est bridé pour cette application ", je lui ai répondu que cela n'avait rien à voir avec la choucroute, d'après elle je devais souscrire à une option à x euros... pfffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff
Merci 1000 fois.
Il me reste plus qu'à voir pourquoi mon mobile accepte uniquement le partage de connexion 3G uniquement si ma tablette qui l'emprunte utilise Firefox... mais je sais ça n'a rien à voir...
Merci encore !
n°681575
paillassou
Posté le 01-02-2012 à 20:15:40  profilanswer
AH ok je prends note !
merci pour cette info importante concernant le user agent SYLM
merci pour krispan ;)
tags: user agent useragent firefox internet explorer 6 IPCAMViewer IPCAM IP CAM VIEWER 3G WIFI android iphone ddns dyndns host
en
IP Cam Viwer v3
Message édité par paillassou le 01-02-2012 à 20:18:57
n°681593
medamy
Posté le 01-02-2012 à 21:34:58  profilanswer
absolument pas...
n°681623
lucienzaf
Posté le 02-02-2012 à 00:32:53  profilanswer
superbe l'image de paillassou ;)
n°681632
paillassou
Posté le 02-02-2012 à 07:22:50  profilanswer
MERCI
attention, c'est pas une FOSCAM FI8918W, c'est une DLINK DCS2121.
n°681634
bucanero
Posté le 02-02-2012 à 08:21:28  profilanswer
Un rapide message pour remercier les généreux contributeurs et particulièrement paillassou sans lequel rien n'aurait été possible. En suivant vos indications j'ai installé ma foscam, reliée au site perso avec alertes mail et sms. Extra! :D
A voir la longueur du thread, je devine les heures passer à répondre, à synthétiser tout cela pour que le quidam puisse comprendre et appliquer.
Merci, merci beaucoup  :jap:  :jap:  :jap:  :jap:  :jap:  :jap:
PS/ Je n'ai rien à demander, ce message est gratuit, au sens propre du terme. :hello:
n°681637
paillassou
Posté le 02-02-2012 à 09:37:30  profilanswer
@bucanero
et bien c'est super gentil ! (c'est tellement rare, cela a le mérite d'être souligné !...)
merci beaucoup !
mais j'avoue que la 1ere page est quand même un MEGA GROS BORDEL (je reconnais)... certes... :lol:
Message édité par paillassou le 02-02-2012 à 09:40:11
n°681692
orriane
Posté le 02-02-2012 à 16:26:02  profilanswer
Je me joins à Bucanero pour féliciter tous les intervenants sur ce forum : grâce à eux, j'ai pu choisir ma camera IP en toute connaissance de cause (une HEDEN Visioncam v2) puis l'installer.
Par contre, j'ai encore besoin de vos conseils: depuis quelque temps, impossible de la visionner depuis l'extérieur. N'ayant pas d'IP fixe, DYNDNS bloque mon accès de manière répétée... Pour contourner le problème (càd ne plus utiliser DYNDNS), j'aimerais envoyer, via le ftp, le flux de ma caméra sur mon site personnel qui possède une adresse fixe : je pourrais alors consulter les images depuis une page de ce site. Mais je n'y connais pas grand chose : apparemment, je parviens à établir la connexion entre la caméra et mon site mais comment puis-je récupérer ce flux dans une page web?
J'ai vu les scripts proposés page 50 par Paillassou mais ils utilisent  l'adresse IP fixe de la caméra (si je comprends bien). Que dois-je faire dans mon cas? Merci.
Oriane
n°681693
paillassou
Posté le 02-02-2012 à 16:35:54  profilanswer
DYNDNS doit bloquer car il doit y avoir trop de mises-à-jour provenant de ton réseau...
n'aurais-tu pas configuré plusieurs périphériques, sur ton réseau, avec DYNDNS ?
il faut se limiter à UN seul périphérique réseau qui met à jour DYNDNS...
généralement, on privilégie cette config DynDNS sur le routeur/box, en amont du LAN.
bye
Message édité par paillassou le 02-02-2012 à 16:37:33
[Topic Unique] Nouveau Samsung PX2370Pb imprimante Wifi Tout-en-1 : erreur 1053
Heden Visiocam vs FoscamImprimer en wifi CanonMP620
Nouvelle PANASONIC BL-C230 PTZ H264 WiFi CAMERABrother DCP-375C (wifi) : status reste "hors connexion"
[topic unique] Philips 240PW9 - 24" - IPS
Plus de sujets relatifs à : [Topic Unique] FOSCAM FI8908W FI8918W FI8910W & clones
