6113 connectés
 Page :   1  2  3  4  5  6  7  8  9  10  11  12  13  14  15
[Topic Unique] Abit AB9 QuadGT
n°5432447
aster
Chaotic Neutral
Posté le 26-03-2007 à 14:14:36  profilanswer
Nouveau BIOS Beta 7 pour Abit QuadGT : M621E_11.B07  -  Miroir
Originally Posted by Richh
Okay, before y'all fill Nelly's pm box asking for a copy of this BIOS, I've had a look at it, and it is not the universal answer to everybody's prayers, so read the following and count to ten before you do anything:
1) It *is* a new *beta* BIOS, build 11 beta 7, compiled on 13/03/07.
2) It appears as though the power management is broken in the same way that B06's was. As such, you do not get any dynamic voltage management, and I strongly suspect that those of you who experienced stuck multipliers will continue to do so with this one
3) The BIOS now seems to function properly when the ICH8R is selected to run in RAID mode. The AHCI option ROM also runs during POST. This should allow those of you who want to connect optical drives to the SATA1-6 ports while also running the controller in RAID mode to do so.
It also appears as though the boot device prioritisation has been properly fixed (the "fix" in B06 was a temporary kludge).
4) As a result of the fix above, the POST process now takes longer due to the AHCI ROM enumerating the attached hard disks.
5) I am unaware as yet if there are any changes at a performance/overclocking/memory level - Nelly will hopefully be looking at this aspect later.
In short, the only issue that this BIOS seems intended to address is the full functionality of the ICH8 RAID controller + optical drive problem. I have not tested yet whether it is actually fixed, but see no reason why it won't work - I'll find out for sure later.
As such, the only people who, at time of writing, will appear to gain an advantage from this new BIOS are those wanting to mix a RAID array and optical drives on the SATA1-6 ports. For anyone else, this build is arguably a backward step over B6R.
Of course there should be room for a "B7R", but I need to more fully understand what is in this new release before I know what I can change on it.
En gros ce bios n'est utile que si on veut mixer un Raid et des disques optiques sur l'ICH8R.
Richh nous prépare une version moddée de ce bios pour y inclure ses avancées sur la gestion du multi.
n°5432528
boblemagni​fique
Modo de nuit , Dodo de jour
Posté le 26-03-2007 à 14:57:39  profilanswer
Supair :o
Bon me tate a laisser les 5 phases sans rad avec un ventilo ou leurs mettre des ptits rads , j'hésite encore :/
n°5432587
aster
Chaotic Neutral
Posté le 26-03-2007 à 15:35:56  profilanswer
Tu veux bien faire une tof des Mos avant d'y foutre un rad?
Si tu pouvais également mesurer l'entraxe du rad stock Mos...
:jap: :jap:
n°5432590
boblemagni​fique
Posté le 26-03-2007 à 15:36:32  profilanswer
je te fais qd je démonte , c'est pas bien gros en tous qu'a :D
n°5432592
aster
Chaotic Neutral
Posté le 26-03-2007 à 15:38:28  profilanswer
[:athome]
n°5432753
boblemagni​fique
Posté le 26-03-2007 à 17:09:15  profilanswer
En forcant a mettre des rads , il y a une résistance qui a sauté , mais spa grave ca sert a qued :D
Sinon 5.8cm entre les 2 trous (milieu) et 0.6cm entre chaques phases
http://boblemagnifique36.free.fr/Hardware/Motherboard/AbitAb9QuadGT/QuadGT12.jpg
http://boblemagnifique36.free.fr/Hardware/Motherboard/AbitAb9QuadGT/QuadGT13.jpg
http://boblemagnifique36.free.fr/Hardware/Motherboard/AbitAb9QuadGT/QuadGT14.jpg
n°5432814
aster
Chaotic Neutral
Posté le 26-03-2007 à 17:38:57  profilanswer
T'es un sacré bourrin  [:darkmavis]
Ca me rappelle une 6600GT qui a mangé un coup de tournevis.
Bilan : 9 resistances en moins et 15Mhz en plus :D
Ta fix est d'une laideur qui je l'espère n'a d'égal que son efficacité :o
Merci pour les mesures en tout cas et bon bench  [:bigbrother]
n°5433509
guynemer
Trust rather than monogamy
Posté le 26-03-2007 à 22:34:59  profilanswer
J'adore la boite de la NF7S en dessous :D
n°5433766
boblemagni​fique
Posté le 27-03-2007 à 01:21:53  profilanswer
Un Morceau de plastique j'ai trouvé , 2 trous et fix home made :D
Au moment que ca tiens , osef :D
Aucun gain chez moi :( le max arrive vers 524/525mhz avec ou sans vmod avec le 6400 (avec vmod sur le 6600)
n°5434108
aster
Chaotic Neutral
Posté le 27-03-2007 à 12:19:39  profilanswer
Le Vmch mod sert à rien quoi... :spamafote:
Et avec le Q6600 ?
n°5434139
boblemagni​fique
Posté le 27-03-2007 à 12:42:20  profilanswer
Bah si vu que j'ai un gain pour le 6600 , je dois etre limite a 524/525 a cause du chipset je pense
Le Q6600 j'ai pas encore tester ;)
n°5434176
amdvsintel
Posté le 27-03-2007 à 13:06:40  profilanswer
Moi ma X1950 Pro a ramasse un coup de ventillo :D
Rien de cassé :jap:
n°5434297
aster
Chaotic Neutral
Posté le 27-03-2007 à 14:23:30  profilanswer
Ce que je voulais dire c'est que le vmod permet pas de repousser le max de la mobo.
D'ailleurs, bizarement, 525 semble etre le Max chez tout le monde :??:
n°5437796
er_nordico
Nunc est bibendum
Posté le 29-03-2007 à 13:41:35  profilanswer
Visiblement les vacances de l'equipe chargée des bios ont été utiles :bounce:
<quote> "... B08 has almost all the rough edges - including the power management - fixed. Not done any proper performance/overclocking tests with it yet, and there do seem to be a couple of minor issues that won't be noticed by the bulk of the user base, but in all the major respects it's there..."
reste a voir les problemes remanents et si comme ça semble le cas le coef est reparé :)
n°5437876
guynemer
Posté le 29-03-2007 à 14:22:27  profilanswer
il se dl ou ce nouveau bios ? :D
n°5438534
er_nordico
Nunc est bibendum
Posté le 29-03-2007 à 19:13:56  profilanswer
<quote> "It does not solve everything, a lot better than B06/07, still working with it but it appears solid enough to post it up later today. Hopefully Rich will be able to take care of a couple of small things (eSATA not working with IDE Optical drives on the JMicron controller, and power management under Vista) with it.  (no real performance increases, FSB was up a little, memory performance slightly different, no 1333 strap)"
A priori en dehors de l'esata.... pas de gros soucis...
n°5439195
aster
Chaotic Neutral
Posté le 30-03-2007 à 09:45:50  profilanswer
Bios 08 Beta
Pas grand chose de transcendant.
+ Amelioration de quelques perfs :??:
+ Meilleure gestion de l'alimentation et du multi (Merci Richh)
- eSATA + IDE sur Jmicron impossible : OSEF :D
Message édité par aster le 30-03-2007 à 09:45:59
n°5439432
dlm90
Posté le 30-03-2007 à 12:56:53  profilanswer
[:drapo]
n°5442083
guynemer
Posté le 01-04-2007 à 00:33:18  profilanswer
L'option C1E dans le bios ca correspond à quoi ?
n°5443951
aster
Chaotic Neutral
Posté le 02-04-2007 à 10:06:18  profilanswer
C'est une fonction d'économie d'energie qui sert aussi de sécurité thermique.
La fréquence du CPU est diminuée quand le CPU est inactif ou qu'il a trop chaud.
n°5445399
guynemer
Posté le 02-04-2007 à 23:01:30  profilanswer
c un truc encore différent du speed step ?  ca y ressemble bcp pourtant
n°5446309
Posté le 03-04-2007 à 14:41:00  answer
Bon j'ai po lu :o mais à partir d'ici, si :jap:
n°5446345
matos666
Posté le 03-04-2007 à 14:53:39  profilanswer
enfin une carte qui tiens 475 en fsb , yahoo je crois avoir trouvé mon bonheur :D
n°5446413
dami1stm
Eco-coco φ
Posté le 03-04-2007 à 15:13:53  profilanswer
C'est un bon choix  :jap:
"La liberté d'expression n'a d'ennemis que ceux qui veulent se réserver le droit de tout faire" - "Seems all have gone insane for gold"
n°5446498
matos666
Posté le 03-04-2007 à 15:59:15  profilanswer
now vu que j'aime bien dfi je vais essayer de chopper des infos sur cette future carte ;)
n°5446508
dami1stm
Eco-coco φ
Posté le 03-04-2007 à 16:04:31  profilanswer
Oui, c'est un autre bon choix, mais là il faut attendre un peu  :D
n°5446904
matos666
Posté le 03-04-2007 à 18:43:23  profilanswer
Sinon à part la dfi quelle carte concurence cette abit au niveau fsb sans vmod car suis une bille en soudure :)
Message édité par matos666 le 03-04-2007 à 18:43:48
n°5446912
dami1stm
Eco-coco φ
Posté le 03-04-2007 à 18:45:06  profilanswer
En FSB simple? La P5B Deluxe, mais en FSB strap 1066 c'est la seul pour le moment...  :o
n°5446926
matos666
Posté le 03-04-2007 à 18:50:48  profilanswer
Je viens du monde AMD opteron, tu peux parlé en VF pour "strap 1066" :)
Message édité par matos666 le 03-04-2007 à 18:51:17
n°5446940
dami1stm
Eco-coco φ
Posté le 03-04-2007 à 18:55:56  profilanswer
Pour faire simple sur les autre CM en P965, en depassant les 400 de FSb le chipset change de Strap et les perfs mémoire s'effondrent, donc pas good...
Avec la Abit, pas de probleme le strap reste le même  :jap:
n°5446964
matos666
Posté le 03-04-2007 à 19:04:27  profilanswer
ah.....ok ya un topic qui explque tout ca ou pas ?
c'est parce que la ram ne se synchronisait plus ?
n°5446966
Posté le 03-04-2007 à 19:05:44  answer
La synchro est réglable, nuance ;)
Pour le strap => http://forum.hardware.fr/hfr/Overc [...] 9659_1.htm
n°5446986
matos666
Posté le 03-04-2007 à 19:15:48  profilanswer
ah oui c'est comme les 1000 à pas depasser sur une dfi lol :D
n°5447188
guynemer
Posté le 03-04-2007 à 21:00:13  profilanswer
ah ouais sur les autres en 1066 c koi le FSB max ?
n°5447462
guynemer
Posté le 03-04-2007 à 23:09:30  profilanswer
je me suis répondu tt seul : 400 :D
n°5447826
aster
Chaotic Neutral
Posté le 04-04-2007 à 10:07:04  profilanswer
Y'en a du monde ici tout à coup! :D
En strap 1066 sur P5B Deluxe, ya moyen d'aller à 430+ pour les chanceux.
Mais il faut le faire avec clockgen car pour etre en strap 1066 faut booter à 400.
Sur Gigabyte, c'est 300 le seuil de basculement. :sweat:
La QuadGT peut aller à ~520, soit son MaxFSB :love: & :/
C'est quand meme dommage qu'elle n'aie pas de strap 1333 pour pousser encore le FSB.
Pour les Cold-Bencheurs, le layout est chouette car le socket est facile à isoler.
Mais avec "seulement" 520MHz, elle peut pas rivaliser avec la P5B Dlx et ses 641MHz (Bob!)
Et pour les gens qui font pas de l'extreme, dommage de pas pouvoir pousser la RAM à plus de 550MHz.
Certains on eu la chance de tomber sur de bonnes puces D9 et ne peuvent pas les exploiter :whistle:
n°5447870
matos666
Posté le 04-04-2007 à 10:42:42  profilanswer
Que viens faire le strap avec le fsb ?
A priori si c'est comme le NF4, tu as juste à mettre le coef qui va bien pour pas de passer les 1000.
n°5447874
darckcryst​al
Anima Sana In Corpore Sano
Posté le 04-04-2007 à 10:45:58  profilanswer
[:drapal]
[Mon Topic ACH/VDS/ECH]
n°5447898
aster
Chaotic Neutral
Posté le 04-04-2007 à 11:07:07  profilanswer
C'est completement différent du NF4.
Ce dont tu sembles te rappeler, c'est que HTT*LDT<1000
Ca ne s'applique pas du tout aux C2D.
Le strap, c'est un ensemble de timings Chipset. Ca joue sur les perfs mémoire.
Parce que sur les Core2, le controlleur memoire est dans le Chipset et pas dans le CPU comme les A64.
Le strap 1066 est plus agressif que le 1333.
Sur la plupart des mobos, le reglage de strap n'apparait pas.
C'est implicite en fonction du FSB.
Exemple : La P5B Deluxe
Si FSB <= 400 strap 1066
Si FSB  >  400 strap 1333
La QuadGT permet de choisir parmi les straps 800 et 1066, mais pas 1333 :/
n°5447900
darckcryst​al
Posté le 04-04-2007 à 11:09:22  profilanswer
faut imaginer le strap comme un escalier, quand on veux monter on change de marche et on perd en perf.
pour la QuadGT meme si on peux choisir de strap 1333 elle tient pas mal le strap 1066 :love:
n°5448009
matos666
Posté le 04-04-2007 à 11:58:15  profilanswer
Ok mais vu que le strap du AB9 est au max à 1033, ca veut dire qu'a partir d'un fsb de 267 on passe à 1033 non ?
Donc vous êtes entrain de me dire que le strap limite la montée du fsb en bref.
Abit NV7m & XP 2600+ BARTON FSB 333 Mhz, possible ?[TOPIC UNIQUE] LCPower Utilisable ou Pulverisable
Fan chipset sur Abit KV7[Topic Unique] 8800 GTS 320 mo
[Topic Unique]P5N32-E Sli et vcore bloqué au dessus d'un FSB de 1200[Topic unique] Meilleurs DVD vierges avec MàJ P1
[Topic]PC matx à base de C2D/Ci5/Ci7:petit mais costaud![Topic unique] Meilleurs graveurs DVD avec MàJ P1
[Topic Unique]Asus Striker ExtremeTests et dispo Abit IN9 en France
Plus de sujets relatifs à : [Topic Unique] Abit AB9 QuadGT
