3918 connectés
Etes vous globalement satisfait de votre eVGA680i
 Page :   1  2  3  4  5  ..  77  78  79  ..  100  101  102  103  104  105
eVGA 680i NForce680i [topic unique]
n°5939636
scalpatif
GT: scalpatif
Posté le 12-10-2007 à 14:47:07  profilanswer
No Drivers Found
We're sorry, but the drivers you are searching for are not available. Please contact our Tech Support at 888/881-EVGA (3842) or through our Tech Support Form.
j'ai pas compris ta phrase angela ni le lien...tu peut m'eclaircire?^^
noob powaa^^
Ma Galerie // GT: scalpatif
n°5939648
angela-pcs
Posté le 12-10-2007 à 14:53:25  profilanswer
FLOPPY (Floppy Disk and Disk Drive Required)
    * Download the following executable: NF68_P29.exe ( ftp://ftp.evga.com/bios/NF68_P29.exe )
    * Insert blank floppy disk into drive and run executable
    * Restart machine, and set floppy as the primary boot device
    * Press "Y" to program BIOS
    * After flash, power off PC completely, on reboot load defaults in BIOS
CD Method (Blank CD and CD Rewritable Drive Required)
    * Download the following .iso file: ( ftp://ftp.evga.com/bios/NF68_P29.iso )
    * Use a CD Burning software to burn the .iso image onto a blank CD (Nero, Alochol 120%, etc)
    * Restart machine, and set the CD Drive as the primary boot device
    * The BIOS flash process will begin, Press “Y” to program BIOS
    * After flash remove the CD, power off PC Completely
    * Turn on the PC and load defaults in BIOS
Windows Installation - Alternate installation method
    * Before updating your BIOS, please load BIOS defaults by hitting the delete key during POST and select: “Load Defaults.” Now select “Save & Exit Setup.” After that has been completed please follow these instructions:
    * Download the following files: NVIDIA Update Center and NF68_P29.bin  ( http://us.download.nvidia.com/down [...] center.exe ) ( ftp://ftp.evga.com/bios/NF68_P29.bin )
    * Install the latest NVIDIA Update Center and run the program. (Use ONLY the above version, DO NOT use any previous version of NVIDIA Update Center.)
    * Once Update Center opens, Check the box “Clear CMOS” and then hit apply at the bottom right hand corner
    * Now select browse and locate NF68_P31.bin
    * Select load bios
    * After update center finishes, completely shutdown your system
    * Once the system is off, unplug your PSU and press the power button on the front of your case. (This will discharge the Motherboard.)
    * Wait 30-60 seconds to turn on or plug in your PSU and start up your system
    * Press "Delete" to once again enter the BIOS, and load defaults. Save and exit; your system BIOS is now updated.
n°5939653
scalpatif
GT: scalpatif
Posté le 12-10-2007 à 14:58:42  profilanswer
ok mais chui vraiment obligé de flasher mon bios?
et apres le flashage je dois reinstaller windaube?
n°5939661
angela-pcs
Posté le 12-10-2007 à 15:02:17  profilanswer
Oui
Oui  :D
Meuh nonnnnnnn
n°5939689
wolfflyter
Posté le 12-10-2007 à 15:09:56  profilanswer
angela-pcs
C'est pas risqué que sanada95280 flashe son bios ?
je le la sens pas sur ce coup.
Si decision prise je recommande la solution via CD rom avec
double voir triple précaution pour la remise part default de son
bios avant changement de bios.
car :
machine déja planté par default , ram possible.
n°5939702
scalpatif
GT: scalpatif
Posté le 12-10-2007 à 15:14:24  profilanswer
merci wolffly...^^
donc sûr je le flash?
n°5939703
angela-pcs
Posté le 12-10-2007 à 15:14:49  profilanswer
Le hot flash cay bon apres quoi ^^
La soucis de démarrage plutôt ( ce que j'ai pigé quoi  )
n°5939714
scalpatif
GT: scalpatif
Posté le 12-10-2007 à 15:17:11  profilanswer
and so what?
n°5939728
angela-pcs
Posté le 12-10-2007 à 15:19:57  profilanswer
Flash par cd rom
n°5939738
wolfflyter
Posté le 12-10-2007 à 15:21:41  profilanswer
sanada95280
As tu d'autre barrette mémoire ?
n°5939787
scalpatif
GT: scalpatif
Posté le 12-10-2007 à 15:44:40  profilanswer
bah j'en ai une de 1gb de pc 3500 mais l'est tellement vieille tu crois que ca passe sur cette cm?
n°5939809
scalpatif
GT: scalpatif
Posté le 12-10-2007 à 15:55:46  profilanswer
dur j'arrive pas a graver l'image sur le disque avec nero 7 il me dis impossible d'effectuer la fonction disc at once...chier 2 cd de niquées^^
en mode pas de bol...
n°5939824
wolfflyter
Posté le 12-10-2007 à 16:03:55  profilanswer
n'oublie pas l'option verifié les données gravés dans néro.
pas de truc multi cessions tout ça , un cd = un bios.
attention ta ram semble mal fonctionner change la avant le bios
(precaution).
tu va dans la boutique du quartier ==> DDR2 pas cher , une barrette.
Message édité par wolfflyter le 12-10-2007 à 16:04:33
n°5939837
scalpatif
GT: scalpatif
Posté le 12-10-2007 à 16:09:22  profilanswer
t'est serieu? ma ram elle dechire j'ai choisi cette ram expres avec cette cm il parrait qu'elle est mortelle dessus, je l'ai testée sur un autre pc elle fonctionne tres bien, comment ke ca se vois qu'elle fonctionnerai mal?
en plus chui carrément a sec ce mois ci je peut pas en acheter une autre juste pour tester....
comment je fait pour nero? pour enlever le multisessions?verifier les données apres gravure j'ai trouvé mais le multisessions...
Message édité par scalpatif le 12-10-2007 à 16:10:40
n°5939840
wolfflyter
Posté le 12-10-2007 à 16:10:45  profilanswer
il faut un cd neuf.
Pour la ram fait comme tu veux.
n°5939852
scalpatif
GT: scalpatif
Posté le 12-10-2007 à 16:16:34  profilanswer
non mais c t d cd neufs que j'ai utilisé mais il me dis :
echec de la gravure:impossible d'effectuer la fonction disc at once
n°5940098
JackCarver​3
Posté le 12-10-2007 à 18:18:57  profilanswer
En début de semaine, j'avais un pb de ram également et de démarrage avec code erreur 1d et 1c, j'ai mis en fonctionnement, dans le bios, le profil epp, et tout est revenu dans l'ordre...
edit : Sli ready memory dans fsb & memory config
Avant de te lancer à un flashage hasardeux de la carte...
Message édité par JackCarver3 le 12-10-2007 à 18:32:53
n°5940277
scalpatif
GT: scalpatif
Posté le 12-10-2007 à 19:44:05  profilanswer
bah en fait c'était comme ca avant que ca deconne, mais bon la j'ai remis et ca remarche, si ca redeconne je flasherai, par contre toujours pas de soluce pour graver l'image sur le cd av nero, toujours le meme probleme...
n°5940294
wolfflyter
Posté le 12-10-2007 à 19:47:31  profilanswer
sanada95280
comment essais tu de graver l'image ?
tu ne peux pas flasher de bios si il n'est pas remis par default
avant changement du bios.
Si tu flash avec des erreurs mémoire tu va tuer la carte mère
(bios corrompu ).
n°5940305
scalpatif
GT: scalpatif
Posté le 12-10-2007 à 19:53:29  profilanswer
hum ok c'est deja bon a savoir...
bah pour graver l'image j'ouvre nero start smart, ensuite je choisis CD et ensuite je fait graver une image sur un disque ensuite je choisis l'image , je coche verifier les données apres la gravure et je clique sur graver et la la gravure se lance...
j'ai pourtant assez souvent gravé des images sur un cd mais la il me dis probleme^^
n°5940335
wolfflyter
Posté le 12-10-2007 à 20:01:06  profilanswer
sanada95280
telecharge memtest sous windows lance un test de 1024 mo
nero a peut etre des erreurs a cause de la ram qui bug tout.
n°5940435
scalpatif
GT: scalpatif
Posté le 12-10-2007 à 20:50:09  profilanswer
euh alors je lance un test mais il s'arete jamais , jl'ai stoppé vers les 104% ( je pige pas pk il depasse les 100%) mais bon ca va j'ai poiroté 45 min a appuyer sur la barre d'espace a chaque erreur...
j'ai en tout 202 erreures a 104% pas cool non?
j'ai pas trop pigé cke je dois faire de ce soft...
n°5940436
Kyosh1ro
Posté le 12-10-2007 à 20:51:48  profilanswer
Bah dès que t'avais une erreur tu pouvais arrêter, ça veut dire que ta ram déconne, ou qu'elle est mal reglée... Le principe de tester 100% c'est pour être sûr que la totalité de ta Ram soit nikelle, si t'a une erreur, aucune utilité d'aller plus loin. ;)
o_Ø | "What some people think makes us strange or weird or fucked up, we think is what makes us beautiful."
n°5940439
scalpatif
GT: scalpatif
Posté le 12-10-2007 à 20:53:44  profilanswer
tain chui trop débyle...bon bah c chelou quand meme elle est quasiment neuve ma ram, c'est peut etre le fait que je sois a 1066 , j'ai activé le sli ready avec cpu oc 0%...
n°5940440
wolfflyter
Posté le 12-10-2007 à 20:54:28  profilanswer
Bonne nouvelle confirmation de l'unclair device.
c'est bete mais pour 30 euros tu solutionnais rapidement le soucis
n°5940443
scalpatif
GT: scalpatif
Posté le 12-10-2007 à 20:56:55  profilanswer
quoi?jpige pa...
n°5940444
wolfflyter
Posté le 12-10-2007 à 20:57:57  profilanswer
Pourtant plus haut je t'ai donné la manipulation.
n°5940447
scalpatif
GT: scalpatif
Posté le 12-10-2007 à 20:59:56  profilanswer
ouais mais je comprends pas...sinon jpeu emprunter une barette d'un pote vite fait...mais je comprends pas comment faire et ce qu'il faut faire...^^
moi neuneu^^
n°5940457
wolfflyter
Posté le 12-10-2007 à 21:09:13  profilanswer
sanada95280
Ah comme j'ai l'habitude également de rien comprendre je te fais un
petit résumé , c'est une voie pas une certitude.
01 ta machine est buggé par des barrettes mémoires mal reconnues
par default par ton bios P26
02 pour solutionner ce petit soucis il te faut mettre a jour ton bios vers P29 ?
03 pour mettre a jour ton bios il ne faut pas que la machine soit planté.
la solution passe par l'utilisation d'un seule barrette mémoire DDR2 standard qui sera
bien reconnu par ton bios et qui permettera le changement de bios sans soucis.
Ensuite une fois bios a jour tu remets tes barrettes de compétitions
" turbo sport compressor " dans ta machine.
Message édité par wolfflyter le 12-10-2007 à 21:10:36
n°5940461
scalpatif
GT: scalpatif
Posté le 12-10-2007 à 21:12:13  profilanswer
ahhhhh ca j'aime bien^^ oki je te remercie, je peut pas faire ca ce soir fo que mon pote me prette sa barette mais je te remercie je vais pouvoir faire ca en debut de semaine prochaine...
n°5940462
wolfflyter
Posté le 12-10-2007 à 21:14:15  profilanswer
sanada95280
Bien que changer de bios est une opération relativement simple
fait très attention.
suis la procedure a la lettre.
n°5940498
scalpatif
GT: scalpatif
Posté le 12-10-2007 à 21:41:54  profilanswer
ouais alors je change ma ram, je mets les parametres du bios par defaut, je grave le cd image, je le mets ds le pc, je redemarre et je mets y au flashage du bios puis je redemarre le pc, j'enleve le cd, je remets ma ram et je regle ensuite mon bios avec les reglages que je veut...c'est ca?
chui un peu en flip de flasher mon bios...
n°5940591
angela-pcs
Posté le 12-10-2007 à 22:23:52  profilanswer
Le pire qui peut arriver c'est coupure d'électricité sinon le reste c'est comme mettre du jambon dans un sandwich
Message édité par angela-pcs le 12-10-2007 à 22:24:07
n°5940627
wolfflyter
Posté le 12-10-2007 à 22:50:48  profilanswer
sanada95280
" chui un peu en flip de flasher mon bios "
http://i22.servimg.com/u/f22/11/44/89/88/dancin10.gif
flip pas trop avec ton pote  ;)
P/s : laisse la barrette standard jusqu'au  re-demarrage complet
de la machine , c'est a dire que tu iras dans Windows etc....puis ensuite
tu eteindra la machine pour remettre tes barrettes " Atomistique "
Message édité par wolfflyter le 12-10-2007 à 22:51:26
n°5940876
scalpatif
GT: scalpatif
Posté le 13-10-2007 à 08:47:48  profilanswer
ok et ca c'est sensé regler les problemes de ma ram? c'est du a mon bios actuel que ma ram est pleine de problemes?
n°5941331
Le Duc 64
Music is the Best ! (FZ)
Posté le 13-10-2007 à 14:30:07  profilanswer
Sanada : e6600 (av zalman)-eVGA n680i- asus 8800 GTX-2*1Go ocz pc8500 SLI Ready avec epp-Alim Seasonic m12 600W-seagate 320Go sata2 7200rpm 16Mo cache-boitier max in power big max
 :o J'ai la même ram que toi, désactive le sliready, rentres ses specs à la main et limites toi à 2,2 V si tu veux oc, avec une bonne ventil ! J'ai déja changé cette ram, je n'ai jamais su si elle avait claqué seule ou à cause de la cm, mais une chose est sure elle ne tiendra pas longtemps le choc si tu ne la préserves pas. Chez moi elle tient 1200MHz à 2,175V aux timings d'origine, ça envoie le steak, inutile de pousser plus. Une petite idée de ce qu'elle a dans le bide ici : http://www.jmax-hardware.com/index [...] &Itemid=41 Utilise Memtest en mode boot (image à graver sur cd-rom) et fais des tests à différentes fréquences. Si ta ram génère des erreurs au dessus de 400 MHz (800) c'est peut être ta carte mère qui a rendu l'âme, dans tous les cas teste ta ram aussi sur une autre config pour t'assurer si elle est ou non fautive.
n°5941551
ebola2
ah ah ah
Posté le 13-10-2007 à 16:48:54  profilanswer
ce que j'allais dire un memtest au boot sous dos ça vaut mieux que la version windows...tu peux télécharger ultimate boot en image cd, un cd bootable en plus où tu trouveras des outils pour tester ton matos.
n°5944816
papa de lu​na
Tres DeSpe Tres Frappé!
Posté le 15-10-2007 à 19:04:58  profilanswer
salut à tous...
une question sait on jamais....
ma eVGA ne boot plus depuis 3 jours... j'étais en h24 à 3.6 tranquilou avec mon quad.
J'ai éteind le PC et 4h après plus moyen de rebooter.....
la carte reste à l'état "--" sur l'ecran de la mobo.... pas de bip, pas de vidéo rien.... si quelqu'un a une idée (j'ai déjà fait un Clear Cmos mais rien)....
sinon SAV... ça fera que la 3eme...
Mon FeedBack | Membre PiseptO (Pi7Owner)
n°5944821
Kyosh1ro
Posté le 15-10-2007 à 19:07:01  profilanswer
Tente de la débrancher complètement et de virer la pile pendant quelques heures (moi je l'avais fait une nuit), apparemment ça reglerait pas mal de soucis du genre... ;)
n°5944824
wolfflyter
Posté le 15-10-2007 à 19:08:22  profilanswer
papa de luna
A oui cela ressemble a un suicide pendant son sommeil.
que la 3 eme , tu devrais te demander pourquoi, comment
etc....
n°5944829
papa de lu​na
Posté le 15-10-2007 à 19:11:00  profilanswer
wolfflyter a écrit :
papa de luna
etc....
ben écoutes si tu trouves pourquoi tu me diras... je fais de l'OC depuis des années et c'est la seule mobo qui est partie au SAV...
La première PCI-E 1 HS.... la deuxieme identique mais PCI - e 2  et là j'en sais rien...
[topic unique] intel badaxe "d975x"[Topic Unique] X1950 Pro AGP
EVG 122-CK-NF68 (nForce 680i)mais ptain ou est ce post unique !!
Alim le bon choix pour future nforce680i SLI donc SLI C2D physique ?[Topic Unique] Boitier Akasa Mirage 62
[Topic Unique] AMD VS Intel[TOPIC UNIQUE] MSI K9N Neo-F
[Topic Unique] Asrock ConRoeXFire-eSATA2
Plus de sujets relatifs à : eVGA 680i NForce680i [topic unique]
