8845 connectés
 Page :   1  2  3  4  5  ..  381  382  383  ..  695  696  697  698  699  700
[Topic Unique] NVidia GTX 970 & 980 - Maxwell GM204 -
n°9397080
lestanquet
Posté le 24-01-2015 à 18:17:03  profilanswer
Je suis toujours dans ce genre de coup ... Style sur le p67  [:o_noel]
n°9397095
B1LouTouF
PSN : Geo62280 / GT : Mr Geo
Posté le 24-01-2015 à 18:42:50  profilanswer
moi le coup du sandy bridge , la poste a perdu mon colis ^^
FeedBack
n°9397099
Marc
Chasseur de joce & sly
Posté le 24-01-2015 à 18:52:01  profilanswer
Réponse officielle de Nvidia
The GeForce GTX 970 is equipped with 4GB of dedicated graphics memory.  However the 970 has a different configuration of SMs than the 980, and fewer crossbar resources to the memory system. To optimally manage memory traffic in this configuration, we segment graphics memory into a 3.5GB section and a 0.5GB section.  The GPU has higher priority access to the 3.5GB section.  When a game needs less than 3.5GB of video memory per draw command then it will only access the first partition, and 3rd party applications that measure memory usage will report 3.5GB of memory in use on GTX 970, but may report more for GTX 980 if there is more memory used by other commands.  When a game requires more than 3.5GB of memory then we use both segments.
We understand there have been some questions about how the GTX 970 will perform when it accesses the 0.5GB memory segment.  The best way to test that is to look at game performance.  Compare a GTX 980 to a 970 on a game that uses less than 3.5GB.  Then turn up the settings so the game needs more than 3.5GB and compare 980 and 970 performance again.
Here’s an example of some performance data:
http://reho.st/self/408ad443b000e63e3c4d4589972f96e11a90a1d3.png
On GTX 980, Shadows of Mordor drops about 24% on GTX 980 and 25% on GTX 970, a 1% difference.  On Battlefield 4, the drop is 47% on GTX 980 and 50% on GTX 970, a 3% difference.  On CoD: AW, the drop is 41% on GTX 980 and 44% on GTX 970, a 3% difference.  As you can see, there is very little change in the performance of the GTX 970 relative to GTX 980 on these games when it is using the 0.5GB segment.
n°9397104
Angelus006​9
Posté le 24-01-2015 à 18:57:05  profilanswer
Alors elle a la mémoire asymétrique comme les gtx 660 ?
ASUS P8Z77-V DELUXE Intel Core i7 3770K @4.8Ghz/2x8Go 1866MHz Hyper-X Fury /GTX 1080TI/Crucial M550 512 go /Crucial M4 256 /ssd intel 240 go /WDC WD10EARS-00Y5B1 (931 Go)   Ecran :Acer 32" LED - Predator XB321HK
n°9397108
Proph@ne
Ouai Stou TéKaTé
Posté le 24-01-2015 à 18:59:09  profilanswer
raiton30 a écrit :
Ce mec a utiliser le bench avec windows ayant comme gpu la cg. windows utilise de la vram, et ca nique les résultat de ce bench.
Les mecs qui s'y connaissent (dont des devs) on fait le test sur des 980 en utilisant le gpu intel pour windows afin d'accéder à toute la mémoire de la cg, et il n'y a pas de problèmes.
 :jap:  merci pour l'info !
n°9397113
MEI
|DarthPingoo(tm)|
Posté le 24-01-2015 à 19:02:12  profilanswer
Non, il vaut mieux comparé ça au CPU Intel/AMD dans les configuration multi-socket, les ressources les plus proches seront plus rapides. Sauf que dans le cas du GPU, les 512 dernier Mo ne sont proche de personne, donc quand on y accède c'est toujours lent. Alors que pour le reste de la mémoire le pilote/GPU pour s'arranger de balancer le traitement au SM le plus proche.
Dans le cas du CUDA c'est clairement visible. En jeu ça doit moins l'être car le principal consommateur de la BP RAM sera la ROP et qu'en plus dans tout les cas la BP disponible pour le SM doit resté suffisante pour ne pas impacter le temps de rendu.
n°9397116
demosys61
Posté le 24-01-2015 à 19:08:46  profilanswer
Mais les 980 en sont victimes aussi alors?
C'est donc un peu comme le cache l1 l2 l3 des proc plus c'est loin moins c'est rapide...?
Message édité par demosys61 le 24-01-2015 à 19:13:34
n°9397126
Laeys
Posté le 24-01-2015 à 19:17:20  profilanswer
On on s'est fait enfumer ...
Faites un tour sur le forum Nvidia ^^
Message édité par Laeys le 24-01-2015 à 19:19:07
n°9397130
Marc
Posté le 24-01-2015 à 19:20:13  profilanswer
Faudrait déjà voir ce que le test CUDA teste au delà de 3.5 Go ... est-ce que c'est bien la VRAM dans ce cas qui est testée ou de la mémoire centrale utilisée par le GPU ? Process Explorer entre autre permet de faire le distinguo.
Message édité par Marc le 24-01-2015 à 19:20:46
n°9397139
Jovial
It's clobberin' time
Posté le 24-01-2015 à 19:28:13  profilanswer
Le choix architectural optimisé d'AMD sur les Hawai/Hawai XT va donc encore conserver son avantage un bout de temps (perso ça m'arrange)
Ca risque surement de se poursuivre avec les futures archi HMB
n°9397147
Laeys
Posté le 24-01-2015 à 19:32:11  profilanswer
En fait quand tu dépasses les 3.5Go et il y a un process pour atteindre les 500 qui manque;d'où des pertes de fps sous certaines conditions ....
Le truc c'est qu'ils ont bien vendu des cartes 4Go de Vram,mais c'est dans la gestion de ces 4Go que ça coince,hors ça personne ne le savait jusqu'à présent...
ils ont simplement segmenté la mémoire...
Les GTX 980 ne sont pas touchées,vus que la gestion est complète elle ...
D'après vous s'il ils l'avaient annoncé ? si on l'avait sue avant  vous auriez acheté des 970 ?
Techniquement les 4Go sont là ...voilà
Message édité par Laeys le 24-01-2015 à 19:33:48
n°9397158
Baron Von ​Own
Posté le 24-01-2015 à 19:44:24  profilanswer
j'avais compris qu'au dela de 3.5g on subissait une grosse chute de performance
c'est pas le cas donc?
n°9397161
Icefaab
Posté le 24-01-2015 à 19:45:43  profilanswer
http://reho.st/self/408ad443b000e6 [...] 90a1d3.png
Merci Marc pour l'info.
Vous pensez faire une news ou un petit focus sur Hardware.fr pour vérifier tout ça ?
n°9397164
petit-tigr​e
miaou
Posté le 24-01-2015 à 19:49:25  profilanswer
Tu as un avis sur la question ?
mIaOuUuUuUuUuUu
n°9397166
raiton30
LA chance.
Posté le 24-01-2015 à 19:51:49  profilanswer
 [:massys]
Donc au final ca n'a rien de grave. Les chiffres de bench montre une différence flagrante, alors que les bench en jeu non, effectivement faudrai voir ce que l'appli cuda test dans le dernier pool de 500mo.
Message édité par raiton30 le 24-01-2015 à 19:53:46
Fookin hell.
n°9397179
ol1v1er
Posté le 24-01-2015 à 20:02:36  profilanswer
J'aime ce message :o
GTX970 is not 256bit and 4GB card.
It is 208bit 3.5GB + 48bit 512Mb card.LIARS!!!!
https://forums.geforce.com/default/ [...] 5/#4432285
n°9397183
lestanquet
Posté le 24-01-2015 à 20:05:13  profilanswer
Oui mais au final ça restera  [:belzedar:4]
n°9397184
charly kan​trop
Posté le 24-01-2015 à 20:05:17  profilanswer
Ce qui serait intéressant de savoir pour un ex-futur-potentiel-acheteur comme moi, c'est même si les performances en jeu ne sont pas impactées, est-ce la même chose sur du computing avec des logiciels comme Adobe Premiere Pro ou after effects qui utilise CUDA pour  le Mercury Engine, le moteur de rendu, ou le traitement des effets en temps réel.  :??:  :??:
Car pour moi, c'est une des conditions pour l'achat de la carte :jap:
Message édité par charly kantrop le 24-01-2015 à 20:05:50
n°9397197
rullo
Posté le 24-01-2015 à 20:19:07  profilanswer
Cool, il semble que les mises à jour des bios soient en cours de déploiement  :wahoo:
https://forums.geforce.com/default/ [...] -gtx-970s/
n°9397200
Posté le 24-01-2015 à 20:19:44  answer
Toute cette afffaire alors qu'aucun test ni esprit critique n'en parlait [:moonboots:5]
n°9397203
lestanquet
Posté le 24-01-2015 à 20:21:12  profilanswer
Si justement ... Sauf en France.
n°9397205
Posté le 24-01-2015 à 20:21:42  answer
HFR = France ?
Pas sûr !
n°9397208
lestanquet
Posté le 24-01-2015 à 20:24:16  profilanswer
Remonte le topic. Ça en parlait déjà depuis un moment sur les forum NVIDIA entre autre. Rien à voir avec hfr là.
n°9397211
MEI
|DarthPingoo(tm)|
Posté le 24-01-2015 à 20:26:49  profilanswer
Non car comme tout les SM sont actif tout la zone est accessible rapidement.
n°9397213
cyberfred
Posté le 24-01-2015 à 20:27:36  profilanswer
effectivement , ca traîne pas :jap:
(je testerai demain soir sur la 970 G1 de mon second pc)
OK guys it looks like the bios update has definitely did something, games such as shadow of mordor are now able to properly use more than 3.5GB of vram at max settings at 1080p. My Vram usage jumped to 3700 mb when i got into the larger cities and my fps did not drop as they did before, i remained in the high 70 fps range at max settings. IDK it could just be a placebo effect but the Vram usage cap has seem to be solved, i will do more testing to confirm this. i would like others to take caution when flashing your bios, remember to completely uninstall your current nvidia drivers before attempting any type of gpu bios flashing and absolutely make sure you are flashing the correct version of bios to the right gpu or else you may brick it. I recommend you guys use the VGA @ bios tool that gigabyte made specifically for gigabyte gpu's
A vérifier avec d'autres tests comme il le dit :jap:
Message édité par cyberfred le 24-01-2015 à 20:30:09
n°9397214
Posté le 24-01-2015 à 20:29:39  answer
On n'est toujours pas à 4Go [:das moorrad]
n°9397215
MEI
|DarthPingoo(tm)|
Posté le 24-01-2015 à 20:29:43  profilanswer
C'est pas faux, si passé 3,5Go on ne bascule pas sur la 2e partition mais directement en PCIe, le test deviens caduque.
n°9397216
aliwonkeno​bi
Posté le 24-01-2015 à 20:30:26  profilanswer
Faut obligatoirement une carte Gigabyte j'imagine ?
Inno3d ont un bon suivi parce que leur site fait peur ? ^^
edit: c'est quand même incroyablement louche cette explication de Nvidia.L'architecture des 970 a été décortiquées et expliquées lors de nombreux tests de la part de toute la presse spécialisée mondiale, même Nvidia a tout décris.Mais ce procédé particulier d'allocation mémoire comme par hasard  serait passer à la trappe?Ils nous prennet pour des cons mais à un point...
Message édité par aliwonkenobi le 24-01-2015 à 20:43:15
Dieu a créé l'univers, Made in Taiwan a fait le reste.
n°9397221
pied2porc
Posté le 24-01-2015 à 20:41:15  profilanswer
Avec un bios de GTX980, ça fonctionne aussi ?
n°9397224
Fly2thesky
Posté le 24-01-2015 à 20:45:25  profilanswer
j'attend les bios pour les MSI 970Gtx gaming :o
Pffff moi qui avais déja un ptit bios bien modifié sans throttle ( no limit ) :o
Bon j'avais encore le bug des ventilos sur une CG :o
Ca va me forcer à faire la maj...
D'après le lien :
" I can confirm that VRAM is still on 3.5GB "
La Mise à jour du bios n'a rien changé... c'est une pure coincidence ce nouveau bios...?
Message édité par Fly2thesky le 24-01-2015 à 20:50:30
n°9397227
Posté le 24-01-2015 à 20:47:30  answer
en fait si , la première fois que j'en ai entendu parlé , c'est sur le comptoir des tocards il y a déjà quelques temps
étonnamment  :heink:
Message édité par Profil supprimé le 24-01-2015 à 20:47:54
n°9397229
Fly2thesky
Posté le 24-01-2015 à 20:48:16  profilanswer
A travers un article ?
Ou juste des commentaires par ci par la ( :o )
n°9397230
pied2porc
Posté le 24-01-2015 à 20:50:03  profilanswer
Comme d'hab, il y a collusion entre la "presse spé" et le fabricant (ici nvidia) . Il devait être gros le paquet de doritos.
n°9397237
aliwonkeno​bi
Posté le 24-01-2015 à 20:56:10  profilanswer
Non Nvidia tout seul a pu "omettre" volontairement d'en parler, et d'évoquer cette partie là lors de ses présentations et documents fournis à la presse.Je penche pour ça
n°9397238
Posté le 24-01-2015 à 20:56:14  answer
un article pointu au comptoir ?  :lol:
plus sérieusement , non en effet , à travers quelques retours d'utilisateurs
mais ça date déjà de près d'un mois
n'ayant pas la possibilité de vérifier , j'ai pas vraiment pris ça au sérieux
comme quoi , y'a pas que des tocards au comptoir  :whistle:
Message édité par Profil supprimé le 24-01-2015 à 20:58:25
n°9397256
pied2porc
Posté le 24-01-2015 à 21:28:59  profilanswer
Release note du bios :
Improve compatibility with some monitors
C'est sûr que ça vachement un rapport....
n°9397257
aliwonkeno​bi
Posté le 24-01-2015 à 21:33:35  profilanswer
Bon nouveau rebondissement le message sois disant de Nvidia posté par Marc serait un fake ne provenant pas de Nvidia.Ils disent travailler encore sur l'issue
"We are chat with Nvidia- about 10min ago, and this article is fake. This is not response of Nvidia. They say that is investigate and will update news soon."
Rumeur ou pas?
n°9397260
Marc
Posté le 24-01-2015 à 21:36:12  profilanswer
Rumeur ou pas?
Bien sûr, je m'amuse à poster des fake ...  :sarcastic:
n°9397261
ol1v1er
Posté le 24-01-2015 à 21:36:47  profilanswer
n°9397262
petit-tigr​e
miaou
Posté le 24-01-2015 à 21:37:38  profilanswer
Ben après tout, c'est ps toi l'expert en GPU.... :o :sol:
mIaOuUuUuUuUuUu
n°9397264
aliwonkeno​bi
Posté le 24-01-2015 à 21:41:01  profilanswer
mais non pas toi evidemment je me permettrais pas mais ta source peut-être, et puis j'ai dit à la fin rumeur ou pas?
[HFR] Actu : GTX 800 Gaming G1 pour Gigabyte à la rentréeDVI-D sur Nvidia GTX750
Installation de GPU AMD et NvidiaGTX 760 seulement 100FPS
GTX 780 TI + alim 650W - suffisante ?[Résolu] Pc qui reboot avec GX 780 TI
Soucis : plus d'affichage GTX 770GTX 750 TI
[HFR] Dossier : Nvidia GeForce GTX Titan Z : la carte graphique à 3000€ en test
Plus de sujets relatifs à : [Topic Unique] NVidia GTX 970 & 980 - Maxwell GM204 -
