3590 connectés
 Page :   1  2  3  4  5  ..  58  59  60  ..  1028  1029  1030  1031  1032  1033
[Topic Unique] NVIDIA GeForce GTX 660Ti/670/680/690/760/770 (GK104)
n°8207717
Agent heav​y
Posté le 03-02-2012 à 21:28:59  profilanswer
C'est peut être aussi se servir de l'absence des produits nvidia pour faire de la visite sur son site web en spéculant.
Feed-back
n°8207743
raptor68
Pouet !
Posté le 03-02-2012 à 22:02:16  profilanswer
ça y'est, il a tout casser mon moral
n°8207758
Yo80
SERIOUS SHARK :D
Posté le 03-02-2012 à 22:22:20  profilanswer
mightmagic a écrit :
Nvidia Kepler GTX680 vs Radeon HD 7970
Yesterday we have published the review of AMD Radeon HD 7950 graphic cards, which is a better alternative for GTX 580 at almost the same price. And now it’s time for Nvidia to have its own turn. We have got information from our sources that upcoming Nvidia Kepler GTX680 will be up to 45% faster than AMD’s present flagship, Radeon HD 7970.As the price point and the specifications of HD 7970 and HD 7950 are found to be the same as what we have published earlier, this time too, we believe that these specifications, price and release date of entire Kepler series mentioned below will hold true.
But surprisingly reference GTX680 will have just 2GB frame buffer, even with 1GB lesser than HD 7970, Nvidia GTX680 is able to perform 45% faster. Also GTX680 boasts double the amount of stream processors compared to GTX580. We already know that the entire Kepler series will be PCI-E 3.0 compliant. For a $100 more than HD7970 you will be getting almost a 45% faster card, now you might have guessed, GTX680 is priced at $649 and will be released in April 2012. Entire Kepler series is being manufactured on TSMC’s 28nm technology. Another rumor that had spread earlier was that Nvidia will be skipping 600 series and will use 700 series for their Kepler series, but now it’s been made clear that, Nvidia is not going to skip GTX600 series. Now you can see the specifications, price point and release date of Nvidia Kepler series GPUs.
Kepler based Nvidia GTX 600 series GPUs – Highlights
Nvidia Kepler GTX690
    750MHz Core clock
    2×1.75 GB 4.5GHz GDDR5 Memory
    2×1024 Stream Processors
    2x448bit Bus Width
    Priced at $999
Both AMD and Nvidia are following the same trend in maintaining the order of the series in GPUs. Like HD 7990, GTX 690 has a core clock lesser than GTX 680 and Bus width similar to GTX 670. Compared to AMD HD 7990′s price point of $ 849, GTX 690 is priced at $ 999. But comparing to the performance the GTX 690 can offer, HD 7990 is definitely over priced, and sure AMD has to reduce their prices drastically after the release of GTX 600 kepler series.
    850MHz Core clock
    2 GB 5.5GHz GDDR5 Memory
    512bit Bus Width
    Priced at $649
    45% faster than HD 7970
Nvidia has a clear winner in its hands and that’s why they have commented that they had expected much more from AMD. But still we already know that AMD is preparing its revised GCN HD 8000 series graphic cards, which may be release in the latter half of this year.
Nvidia Kepler GTX670
    850MHz Core clock
    1.75 GB 5GHz GDDR5 Memory
    896 Stream Processors
    448bit Bus Width
    Priced at $499
    20% faster than HD 7970
Nvidia Kepler GTX660Ti
    850MHz Core clock
    1.5 GB 5GHz GDDR5 Memory
    768 Stream Processors
    384bit Bus Width
    Priced at $399
    10% faster than HD 7950
    900MHz Core clock
    2 GB 5.8GHz GDDR5 Memory
    512 Stream Processors
    256bit Bus Width
    Priced at $319
    Performance similar to GTX580
Nvidia Kepler GTX650Ti
    850MHz Core clock
    1.75 GB 5.5GHz GDDR5 Memory
    448 Stream Processors
    224bit Bus Width
    Priced at $249
    Performance similar to GTX570
    900MHz Core clock
    1.5 GB 5.5GHz GDDR5 Memory
    256 Stream Processors
    292bit Bus Width
    Priced at $179
    Performance similar to GTX560
Nvidia Kepler GTX640
    850MHz Core clock
    192 Stream Processors
    128bit Bus Width
    Priced at $139
    Performance similar to GTX550Ti
Nvidia Kepler based GTX 690, GTX 680, GTX 670, GTX 660Ti, GTX 660, GTX 650Ti, GTX 650 and GTX 640 Specifications
Hey, ca s'appel une rumeur, arrêtez un peu de fabuler...
Mon Feed  /  Mes Ventes
n°8207780
raptor68
Pouet !
Posté le 03-02-2012 à 22:48:27  profilanswer
c'est sur, on ne sait rien de la source, mais bon, ça traite des rumeur et affirme (ni infirme) que les info glanée en soient elles mêmes
n°8207807
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 03-02-2012 à 23:14:41  profilanswer
NODeath a écrit :
:ouch: C'est pas possible que la GTX680 soit 45% plus performante que la 7970. Déjà que la 7970 est vraiment pas mal, sans parler quand on l'oc.
C'est tout à fait possible.
Elle sera ~45% plus performante.
Elle intégrera ~45% plus de transistors.
Elle consommera ~45% plus en load.
Ah oui... et elle coûtera plus cher.
n°8207832
maerens
Posté le 03-02-2012 à 23:39:11  profilanswer
t'a oublié de dire que c'était de 45%  :o
Crossfire R9-290x/290 (1Ghz 1300mhz;1Ghz 1350),I5 4690K 4,6Ghz 1,25V; Asus sabertooth Z97 Mark2; Cooler Master HAF X; Samsung 840 PRO 128GO ; Caviar Green EARS 1TO; Caviar RED EFRX 2TO; 8GB G-SKILL 1600 cl8; CORSAIR AX860I .
n°8207846
Eldem
Ultima ratio regum
Posté le 03-02-2012 à 23:50:52  profilanswer
Vous êtes pas en train de vous enflammer un peu ? C'est fiable la source qui a pondu le tableau ?
n°8207858
Kapa75
Posté le 04-02-2012 à 00:05:21  profilanswer
Non, ce n'est pas fiable du tout. (jusqu'à preuve du contraire)
Le haut de gamme de nvidia sera très certainement au dessus de la 7970.
Mais vu le potention de la 7970, rien n'empêche AMD de sortir très rapidement (et facilement) des 7980 ou 7990 qui serait des 7970+++ avec des fréquences plus haute. :)
mais bon, je suis vraiment impatient de voir ce qu'ils vont nous sortir chez nvidia, maintenant qu'ils ont parlé, ils ont intérêt à assurer derrière!! !
n°8207860
NoradII
Il y a 17 ans naquit un PC
Posté le 04-02-2012 à 00:09:57  profilanswer
[:quoted]
[:le troll hebus]
valid.x86.fr/575505 /842925 /902578
n°8207864
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 04-02-2012 à 00:14:17  profilanswer
C'est un fait.
Si ce n'est pas le cas, alors 2012 sera vraiment la fin du monde.
AMD veut simplement se garder de la marge pour les 8900, car elles seront aussi gravées en 28nm, ce qui va limiter le gain de perfs.
Il serait alors stupide de lancer un GPU overclockée car ça foutrait en l'air le plan d'AMD, sans compter que ses partenaires seraient furieux car une 7980 viendrait faire de l'ombre à leurs 7970 overclockés.
Il est donc clair que la GTX 680 reprendra donc le maillot jaune lorsqu'elle montrera enfin le bout de son ventirad.
Message édité par Wirmish le 04-02-2012 à 00:16:15
n°8207868
fire du 57
The futur is Fusion
Posté le 04-02-2012 à 00:20:48  profilanswer
[:chtiungdor]
 :lol:  Héhé....des prévisions pour les températures ? [:mostro]
En tout cas j'ai pas confiance en se leak... :o
Message édité par fire du 57 le 04-02-2012 à 00:21:31
"Si vous ne changez pas en vous-même, ne demandez pas que le monde change"
n°8207871
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 04-02-2012 à 00:24:03  profilanswer
Ce qui serait réellement un troll c'est un truc de ce genre:
Elle intégrera ~25% plus de transistors.
Elle consommera ~5% plus en load.
Ah oui... et elle coûtera moins cher.
n°8207910
NoradII
Posté le 04-02-2012 à 02:41:54  profilanswer
nan là c'est limite du flood [:ultravox]
mais c'est pas grave on t'en veut pas [:itm]
n°8207916
big e
Posté le 04-02-2012 à 03:17:56  profilanswer
Qu'elle fasse déjà 45 pour cent de mieux que la gtx 580 et ce sera déjà bien.  :o
n°8207932
luhuguet
Posté le 04-02-2012 à 07:07:04  profilanswer
je passe de temps a autre sur ce forum, histoire de prendre des nouvelles ... on a l'impression que ca avance, mais quand on lis bien, en fait ca stagne ( au sujet des infos) ... pas de reel date, pas de reels perfs, en meme temps, nvidia n'a rien donner comme info...
des la sortie du 7970, j'ai lu partout que kepler est bien plus performante
...ok... pourquoi pas ....et .. une date? on lis avril... puis plutot cette été ...avec tant de retard face à la concurence , elles ont intérêt d’être plus performante!
et le prix?... 600€ ... 650€ .... un peut élitiste pour une carte graphique....
cassons un peut du sucre sur amd :
depuis quand amd fait des cartes graphique a prix d'or???
la 7950 (que j'attendait avec impatiente) 450€ en moyenne ! non mais serieux!!! qu'est ce que c'est que cette politique de M.rde!
ma vielle 4850 3 ou 4 mois apres sa sortie, je l'ai acheter 150€ ! ....
150€!!! et encore...c’était une fanless!!! .... 2012... la même série +200% !!
la raison je la connais ... tout le monde la connais ... ils ont le monopole des perfs et ils veulent s'en mettre plein la pense !
vivement qu'il se prenne une grosse clac dans la gu..le avec kepler !! et les prix vont fondre comme neige... a moins que nvidia joue la carte des gros prix grosse perf...
dans 10 ans on achètera des cartes gr en hypothéquant sa  maison ...
voila a dans 1 moi pour les news ... qui j’espère serons plus concrète
n°8207934
NoradII
Posté le 04-02-2012 à 07:09:43  profilanswer
ça c'est du claquage de durites, dans les règles de l'art [:dream49]
n°8207952
Ill Nino
Love
Posté le 04-02-2012 à 08:46:11  profilanswer
Elles sont justes monstrueuses les perfs comparées aux GTX 500 là... Ca parait un peu gros... :/
n°8207953
Nikko 95
Posté le 04-02-2012 à 08:46:14  profilanswer
+1 luhuguet!
Le pouvoir d'achat baisse alors que les prix explosent même dans le seul domaine qu'on croyait epargné!
C'est désespérant quand on est smicart!
Enfin on va pas chialer non plus.
Cette technologie graphique reste quand même passionnante!
Message édité par Nikko 95 le 04-02-2012 à 08:46:50
n°8207961
milag62
Posté le 04-02-2012 à 09:21:23  profilanswer
Et peut être une entente "cordiale" amd nvidia pour continuer chacun sa politique des prix à s'en mettre plein les poches.
Mais bon ça reste du hs. [:ishamael666]
n°8208017
luhuguet
Posté le 04-02-2012 à 11:35:45  profilanswer
en meme temps on à pas grand chose a se mettre sous la dent ...
pour revenir a nvidia ou amd:  je changerais d'ici j'espere la fin du moi, debut mars... on vas attendre la paye ... nvidia n'aurra rien sortie, et j'espere que les 7950 seron moins cher ... passer d'une 4850 à une 7950 ca vas faire une sacré difference... tans pis pour nvidia ... je serais deja extremement ravis avec cette generation ...
ce qui me plait sur la 7950 c'est la conso au repos ... comme mon pc reste 80% du temps en veille, je vais faire des économies....
ce que je voulais de nvidia c'est la technologie physx les perfs ne s’écroulent pas au moins lors que c'est activé ... tans pis ...
 ca fait deja plus de 6 mois que je veut changer de carte .. j'attendrais pas 6 mois de plus... dommage pour la perte seche d'argent.
n°8208029
Posté le 04-02-2012 à 11:56:16  answer
Tu sais dans le reste du monde c'est déjà comme ça [:ghilghamesh]
Par exemple en Asie les cartes graphiques que nous avons, se paient à prix fort et c'est le système "si tu as de l'argent tu achètes et si tu n'as pas, tu achètes pas"
ça fait qu'eux quand ils ont quelques chose, ils le gardent bien plus longtemps que nous=plus écologique et moin gaspillage ;)
je penses qu'on devrait faire de même, arrêter de trop consommer en masse, économiser et changer de carte tout les ~3ans, là on aura Nvidia et Ati qui baisserons leur tarif :D
Il n'empeche que la hausse de TVA en France ne va pas trop aider et sa note dégradée........pas bien ça :pfff:
Message édité par Profil supprimé le 04-02-2012 à 13:25:40
n°8208044
wnorton
Je suis néerlandophone
Posté le 04-02-2012 à 12:23:26  profilanswer
Oui sauve que 1 gros mois avant la sortie des HD 7970, les rumeur se son fondé vrai sur celle-ci  ;)
Je suis néerlandophone une fois
n°8208064
fire du 57
The futur is Fusion
Posté le 04-02-2012 à 13:13:33  profilanswer
T'inquiète pas pour la 7950 on à déjà vu un bon plan avec la carte a moins de 390€...un vrai bon plan ! De plus les prix baisse peu à peu dans un mois elle coutera surement bien moins cher ! ;)
n°8208070
canard rou​ge
coin coin
Posté le 04-02-2012 à 13:18:36  profilanswer
AMD se gave comme au temps des HD6xxx avant la sortie tardive des GTX4xx puis a baissé les prix quand la concurrence s'est manifesté, là ça recommence avec les HD7xxx et les GTX6xx, donc on est intelligent et on utilise son cerveau en comprenant qu'il suffit d'attendre, ou on paye le prix fort en silence et sans troller que c'est trop ceci ou cela et que ce sont tous des salops patati patata.....
Et ça n'est pas plus mal qu'AMD se gave tant qu'ils y en a pour acheter au prix fort, sachant que c'est la branche GPU qui tire leur finance vers le bas, finance pas glorieuse depuis des années, si AMD se pète la gueule vous serez content avec des cpu Intel à 200€ le bas de gamme et 500€ le milieu, sans compter que nVidia fera la même chose sans concurrent.
Message édité par canard rouge le 04-02-2012 à 13:22:28
Fait's comme les petits canards Et pour que tout l'monde se marre Remuez le popotin En f'sant coin-coin
n°8208081
Posté le 04-02-2012 à 13:28:42  answer
Pas forcément car un cpu ou carte graphique cher= on en achète moin souvent pour le garder plus longtemps=Faible vente=Obligation de baisse de prix ou ça sera un stock invendu
Pas besoin de Amd pour faire concurence ;)
Message édité par Profil supprimé le 04-02-2012 à 13:31:38
n°8208083
Charles K
Posté le 04-02-2012 à 13:31:10  profilanswer
Je sais pas si la comparaison avec les 58xx/4xx est la bonne, étant donné que les prix des 58xx n'ont pas bougé à la sortie des 470/480. Je doute même qu'ils ont baissé à la sortie des 460 mais ça j'en suis pas sûr
( edit : alors qu'ils avaient augmenté lors de la phase de penurie et pas vraiment re-baissé après, en gros c'est ceux qui ont acheté les 58xx au début qui les ont eu le moins cher, l'attente à été infructueuse, à cause de nvidia)
Bref, vaut mieux espérer que justement ce soit différent cette fois ci
Message édité par Charles K le 04-02-2012 à 13:48:53
n°8208101
Posté le 04-02-2012 à 13:51:10  answer
Tu sais ce qu'il se passe en interne, chez AMD toi ?
n°8208115
canard rou​ge
coin coin
Posté le 04-02-2012 à 14:01:45  profilanswer
oui on voit ça avec les disques durs en ce moment, c'est vrai que la baisse du nombre d'achat par les particuliers a bien fait baisser les prix. Arrétez de réver.
n°8208173
Posté le 04-02-2012 à 14:53:02  answer
ils n'ont pas baissé parce qu'ils vivent sur la réserve (économie bénéfice de l'année précèdente) mais un moment donné, ils seront quand même obligé de faire une offre aggressive ;)
pour les voitures c'est pareil, comme peu de monde en achète, à un moment ils sont obliger de baisser le prix autrement c'est la fin voir faillite assuré ;)
la marge ils l'ont toujours, en revanche arnaquer l'acheteur=leur savoir faire à l'américaine :pfff:
Message édité par Profil supprimé le 04-02-2012 à 15:03:56
n°8208175
Posté le 04-02-2012 à 14:56:09  answer
En gros tu nous dit juste que si il n'y a plus AMD, Nvidia va couler à vendre chère ses cartes graphiques .... Je te croirais presque ! Tu sais au moins quels types de contrats à encore Nvidia et AMD à côté? Ils peuvent se le permettre, et y'a quoi, 5% des gens qui vont arrêter d'acheter des CG avec un prix pareil, autrement ils s'en foutent !
n°8208178
Posté le 04-02-2012 à 14:59:10  answer
si eux s'en foutent des clients acheteur, alors pourquoi ils insistent encore en vendant des cartes graphiques ? :o
Message édité par Profil supprimé le 04-02-2012 à 15:00:02
n°8208183
Rayaki
Posté le 04-02-2012 à 15:04:54  profilanswer
ils baissent pas les prix, ils demandent de l'aide à l'Etat parce que les vilains consommateurs ne veulent pas leur acheter leur auto ...
Encore heureux que les fabricants de CG ne fassent pas pareil !
Message édité par Rayaki le 04-02-2012 à 15:05:42
Clan Torysss.
n°8208184
Wirmish
¡sıɹdɹns zǝɹǝs snoʌ
Posté le 04-02-2012 à 15:05:43  profilanswer
Le problème c'est qu'on dirait que tout le monde veut s'acheter une carte HDG, mais ils ne veulent pas débourser plus de 150€.
Si vous n'avez pas d'argent, tant pis, achetez du moyen de gamme.
Si vous ne pouvez pas vous payer du MDG, prenez une carte d'entré de gamme.
Et si vous trouvez ça toujours trop cher, alors achetez-vous une console en ocaz et rentabilisez-la sur 10 ans.
[:obsydiankenobi:3]
n°8208186
Posté le 04-02-2012 à 15:06:40  answer
[:obsydiankenobi:3]
c'est pas faux tu as parfaitement raison :sweat:
n°8208190
Posté le 04-02-2012 à 15:09:24  answer
sauf que l'argent de l'état, vient du contribuable :o
donc de toute façon on nous oblige à consommer sans même le vouloir :pfff:
à quand un robin des bois pour carte graphique????
Message édité par Profil supprimé le 04-02-2012 à 15:12:17
n°8208194
Posté le 04-02-2012 à 15:13:49  answer
Pour toutes les raisons que tu as déjà données, auxquelles tu crois tellement que tu ne les cites même pas :??:
 :d !
n°8208201
Posté le 04-02-2012 à 15:22:56  answer
question piège :D :lol: :lol:
Message édité par Profil supprimé le 04-02-2012 à 15:23:09
n°8208214
Posté le 04-02-2012 à 15:38:26  answer
Les prix resteront hauts car ils étaient trop bas
Sauf chez AMD
Maintenant, c'est corrigé :jap: ...
PS : & si comme on a pu le supposer ici et là, qu'il y aurait eu entente entre nVidia et AMD, alors la baisse sera orchestrée
En tous cas, il ne faut pas trop croire que chacun s'observe ;) !
Leurs sorties (à défaut des prix), sont visiblement décalées pour que soit l'un, soit l'autre puisse prendre sa (grosse) part du gateau :spamafote:
Oui, car le client est toujours utile :d
Message édité par Profil supprimé le 04-02-2012 à 15:41:31
n°8208297
wnorton
Posté le 04-02-2012 à 17:25:14  profilanswer
Ha ha ha, les voitures, pas beaucoup de monde achète des Ferrari pourtant on ne diminue pas leurs prix !!!
n°8208316
NoradII
Posté le 04-02-2012 à 17:47:08  profilanswer
c'était pas plutôt les 5870 et consort ?
n°8208355
canard rou​ge
coin coin
Posté le 04-02-2012 à 18:26:04  profilanswer
oui enfin vous avez compris la démarche
Concours Nvidia / questions sur les... questionsCartes Mères Z68 GIGABYTE, laquelle choisir ?
Panneau de configuration NVIDIA ?[HFR] Actu : 5 cartes A75 FM1 pour ASRock
Probleme aprés installation carte NVIDIA GEFORCE 8400 GS[HFR] Actu : Nvidia lance les GTX 580M et 570M
[HFR] Actu : 4 cartes Socket FM1 pour Gigabyte[Topic Unique] Problème pour mettre à jour sa carte réseau
Gestion des ventilateurs 3 pins avec les cartes mères P67Configuration MCP73VE NVIDIA MCP73
Plus de sujets relatifs à : [Topic Unique] NVIDIA GeForce GTX 660Ti/670/680/690/760/770 (GK104)
