3854 connectés
 Page :   1  2  3  4  5  ..  453  454  455  ..  1028  1029  1030  1031  1032  1033
[Topic Unique] NVIDIA GeForce GTX 660Ti/670/680/690/760/770 (GK104)
n°8355419
Invite_Sur​prise
Racaille de Shanghaï
Posté le 21-06-2012 à 12:46:54  profilanswer
Zarbi74 a écrit :
A prendre avec des pincettes et des mouffles:
NVIDIA GeForce GTX 660 Gets Detailed
Although we still have no accurate information about actual clock speeds, we finally have a first insight of some basic specs you would probably expect from such card.
User PHK is a VIP member of Expreview forums. He is a recognized source of many leaks. Unfortunately, he doesn’t mention GTX 660 name itself, but we may assume that he is referring to such mid-range card from NVIDIA.
If the translation is accurate, then we might expect a very short PCB (his post mentions number 4, as if those were inches, but that would be less than GT 640, so I don’t find this as actual length). What we are seeing here, is a new NVIDIA’s strategy in designing cards. It’s definitely easier to develop a new PCB and do some basic limitations to the GK104 GPU than creating a new one from scratch.
As PHK mentions further, GeForce GTX 660 will have 2GB 192-bit memory. Card will be equipped with dual-DVI, DisplayPort and one HDMI output. Card would be powered by 4-phase PWM design. What he also says is ‘single 6′. This could probably refer to the quantity of SMX clusters — 6 SMX are equal to 1152 CUDA cores. And finally total dissipated power is reported at 100 Watts.
Final specification of GeForce GTX 660 would like this:
•28nm GK104 Kepler GPU
•6 SMX clusters
•1152 CUDA Cores
•1.5 or 2GB of GDDR5 memory
•192-bit memory interface
•Dual-DVI, DisplayPort and HDMI output
•TDP of 100W
If the leak from Acer is correct, then we should expect first GeForce GTX 660 cards in a week. On the other hand, if KitGuru is right (huge overstock of GTX 570 delaying a launch of 660), then we shall wait until August.
Source (Chinois, Expreview)
PHK c'est du fiable, pas de doute  :D
Edit :
Une carte qu'on en verra certainement jamais en France, la Zotac GTX 670 Extreme :
http://tof.canardpc.com/preview2/4 [...] 0ea1ed.jpg
1400MHz ~1.25V
http://www.expreview.com/20052.html
Edit 2 :
Geforce 600 Series Gen3 Support On X79 Platform
Though we cannot officially support or guarantee 8GT/s speeds for X79/SNB-E, you can manually enable faster 8GT/s bus speeds (at your own risk) on GTX 680 or GTX 670 GPUs using the following executable: force-enable-gen3.exe
If you would like to revert back to 5GT/s bus speeds you can do so by running the following command from the DOS command line: “force-enable-gen3.exe –revert”
Message édité par Invite_Surprise le 21-06-2012 à 14:25:53
n°8355506
ccp6128
Syntax error
Posté le 21-06-2012 à 14:33:17  profilanswer
Salut à tous.
Avec la promo LDLC du jour j'envisage de prendre une GTX 670 pour remplacer mon couple GTX 460 / GT 9600 par une GTX 670/ GTX 460 (config triple screen, mais je joue en général a 1-2 jeux en fenetré + divers outils tiers sur le 3eme écran).
La config est celle de mon profil, à savoir un i5 750 un poil overclocké, et une alim corsair HX520.
Ca passe, ou vaudrait mieux que je change d'alim au passage ?
Message édité par ccp6128 le 21-06-2012 à 14:33:40
n°8355540
wnorton
Je suis néerlandophone
Posté le 21-06-2012 à 14:58:27  profilanswer
La Evga GTX690 Hydro cooper Signature
http://www.guru3d.com/news/evga-gt [...] ro-copper/
http://www.nokytech.net/images/news/Evga/690-PRESS-WATERBLOCK.jpg
Je suis néerlandophone une fois
n°8355545
wnorton
Posté le 21-06-2012 à 15:00:25  profilanswer
ccp6128 a écrit :
Salut à tous.
Si sa passe avec un SLI de GTX460 tu as ta réponse ;)
Oui les GTX670 consomme moins (beaucoup moins qu'un SLI de GTX460)  :hello:
http://www.hardware.fr/medias/photos_news/00/36/IMG0036573.gif
http://www.hardware.fr/medias/photos_news/00/30/IMG0030727.gif
Message édité par wnorton le 21-06-2012 à 15:05:37
n°8355548
MEI
|DarthPingoo(tm)|
Posté le 21-06-2012 à 15:01:32  profilanswer
wgromit a écrit :
La, ça cloche.
Si le bus est 192 bits, ça m'étonnerait qu'il y ait 2 Go de RAM.
C'est pas top mais possible, NVIDIA l'a déjà fait par le passé sur de bas de gamme.
En fait t'a pas tout les controlleur qui on la meme quantité de RAM.
n°8355560
orphen974
Posté le 21-06-2012 à 15:10:09  profilanswer
Pour les possesseurs d'une GTX 670 DirectCU II d'Asus, vous montez à combien en Mhz en pleine session de jeu sans avoir rien touché à la carte et ce via le "gpu boost"?
Message édité par orphen974 le 21-06-2012 à 15:12:13
n°8355563
ApeKx
Posté le 21-06-2012 à 15:13:48  profilanswer
1123mhz pour la mienne.
4930K @ K2 / RIVB / 16Go Patriot 2133 / Gigabyte 980Ti Xtreme Gaming / Kingston HyperX 120Go & Samsung Evo 240Go / Antec HCP 1200W / CM Cosmos 2 / 2x BenQ XL2411T
n°8355574
Invite_Sur​prise
Posté le 21-06-2012 à 15:18:38  profilanswer
GeForce 600, X79 et PCI-Express 3.0 - HFR
Si nous avions noté dans notre test d'Ivy Bridge que ces derniers proposaient de meilleures performances théoriques que la plateforme X79/SNB-E, nous avions noté en pratique un impact extrêmement mesuré par le gain de bande passante obtenu via le PCI Express 3.0. La question de la raison de l'incompatibilité reste cependant ouverte, les pilotes d'AMD activant pour rappel le PCI Express 3.0 automatiquement sur la plateforme Intel X79 avec les Radeon HD 7000.
n°8355575
orphen974
Posté le 21-06-2012 à 15:19:04  profilanswer
Ok merci, la mienne est à 1110.
n°8355579
0b1
There's good in him
Posté le 21-06-2012 à 15:20:39  profilanswer
On a des nouvelles du vrai Kepler? :o
n°8355584
wnorton
Posté le 21-06-2012 à 15:26:17  profilanswer
Oui le GK104  [:trollol]
n°8355678
jjboy91
Posté le 21-06-2012 à 16:56:02  profilanswer
Quelqu'un aurait un retour sur la GTX670 de chez Zotac en version 4 GO ?
n°8355681
valentin
Posté le 21-06-2012 à 16:57:50  profilanswer
Max Payne 3 qui est à fond consomme 1.6 Go sur mes 2go donc on est large :)
n°8355714
koinkoinko​in
ʞoıuʞoıuʞoıu
Posté le 21-06-2012 à 17:38:29  profilanswer
:/ de mémoire avec le MSAA en 8x tu peux largement dépasser les 2 Go sur Max Payne 3...
n°8355718
Invite_Sur​prise
Posté le 21-06-2012 à 17:41:58  profilanswer
Fouge a écrit :
Ca dépend de la version de GPUZ.
Sinon c'est bien une EVGA (Kingpin = EVGA), une EVGA GTX680 associée à un EVGA EPower board.
http://hfr-rehost.net/http://wccft [...] 35x428.jpg
La carte employée, la GTX 680 Classified, n'a pas été modifiée comme les précédents records de sa part :
http://tof.canardpc.com/preview2/958a6ce1-3e93-4487-99ec-f133149ea46c.jpg
Soldering iron not needed.
http://kingpincooling.com/forum/sh [...] 832&page=4
n°8355744
postal2
I regret nothing!!!!
Posté le 21-06-2012 à 18:05:18  profilanswer
je confirme tout tout à fond tu dépasse les 2go .
n°8355779
wnorton
Posté le 21-06-2012 à 18:36:20  profilanswer
Soldering iron not needed.http://kingpincooling.com/forum/showthread.php?t=1832&page=4
Il peu monté le petit en air :)
Si Classified vient de sorti, je dirais que Nvidia a enfin de meilleur GPU en 28nm.
Il commence à maitriser le fisse de gravure en 28nm (il étai temps quand même)  :o
n°8355804
tritonou
Posté le 21-06-2012 à 19:09:09  profilanswer
Bonsoir
Je suis motiver pour acheter une Asus GTX670-DC2-2GD5 2 GB ,d'aprés vous peut on l'overclocker aux memes fréquences que la top ,tout en étant stable. Si des possesseurs de la non top, pouvez me le confirmer ça me rassureré et aussi est ce que le gpu boost se régle indépendament des autres fréquences.
Merçi pour vos conseils.
n°8355816
Space
Profil: Maux des rateurs
Posté le 21-06-2012 à 19:19:17  profilanswer
n°8355826
tritonou
Posté le 21-06-2012 à 19:23:34  profilanswer
Je peut l'overclocker a peu prés a combien au minimum ,meme si  ce n'est pas les fréquences de la top?
n°8355832
Space
Posté le 21-06-2012 à 19:26:47  profilanswer
garantie à 100% vers les 1220 mhz mini en boost
n°8355836
tritonou
Posté le 21-06-2012 à 19:31:21  profilanswer
Oui et pour les autres fréquences
n°8355845
Space
Posté le 21-06-2012 à 19:38:19  profilanswer
n°8355852
tritonou
Posté le 21-06-2012 à 19:42:40  profilanswer
Space: d'aprés toi ,je peux la mettre au meme valeurs que la gigagyte 670 gtx oc. Et toi a tu toucher les fréquences de tes cartes.
n°8355859
actaruxs
Posté le 21-06-2012 à 19:49:48  profilanswer
ah, c'est avec la classified alors !!!
Comprend mieux... Elle a combien de vrm au fait ? 14 nan ?
Z'etes sur que c'est vraiment un oc sous air ?
n°8355863
actaruxs
Posté le 21-06-2012 à 19:52:11  profilanswer
Bon, je suis curieux de voir a cb elle peut s'O/Cer la mienne de 670...
Vous utiliser koi comme soft en fait ? Juste "Precision X" ?
Et msi ab, utile ou pas ?
quelle différence avec oc scanner, svp ?
Merci d'avance
Bon, vu que j'ai jamais o/c de cg nvidia... Je tente avec ma 670... avec precision x... euh...
Faudrait que je test avec des jeux, pour la stabilité, mais pour un 1er jet (donc pas trop poussé, hein)... 1291mhz en boost  :love:
Sous 3dmark 2011 => Graphic score (performance) -> 10469pts (& cpu pas o/c)
Voulez un screen ?
Message édité par actaruxs le 21-06-2012 à 21:01:12
n°8355921
Invite_Sur​prise
Posté le 21-06-2012 à 20:46:47  profilanswer
T'as pas vu la photo au dessus ?
n°8355929
actaruxs
Posté le 21-06-2012 à 20:52:52  profilanswer
Si... mais on a affirmer hier (ou tot ce matin) que c'était sous air, donc bon
n°8355931
Invite_Sur​prise
Posté le 21-06-2012 à 20:55:44  profilanswer
Passer 1400-1500MHz, tu peux oublier par air  [:clooney6]
n°8355938
actaruxs
Posté le 21-06-2012 à 21:00:51  profilanswer
Elle passera sous peu a la flotte :D
n°8355941
sonyagiova
Posté le 21-06-2012 à 21:01:59  profilanswer
et pour les questions sur le cpu limited, un i5-760 et une GTX670 çà va le faire ou pas??
n°8355943
uNReaLx77
üNReaL
Posté le 21-06-2012 à 21:04:06  profilanswer
mais oui...
au pire un petit oc et ca ira mieux
n°8355946
sonyagiova
Posté le 21-06-2012 à 21:05:04  profilanswer
Voulez un screen ?
peux tu détailler un rien ta config? merci
n°8355948
actaruxs
Posté le 21-06-2012 à 21:05:54  profilanswer
possible ça, 1400mhz sur une 670 sans volt-mod... ni ln2 ? :D
n°8355951
Invite_Sur​prise
Posté le 21-06-2012 à 21:06:57  profilanswer
Le truc, c'est qu'il faut trouver un modèle qui permette de jouer sur les tensions afin de pouvoir atteindre les 1400MHz en air avec une bonne solution de refroidissement.
La MSI pourrait bien faire bouger les choses à ce niveau-là.
Twin Frozer 4 + Softmod voltage = Win AMHA
n°8355952
uNReaLx77
üNReaL
Posté le 21-06-2012 à 21:07:46  profilanswer
tritonou a écrit :
Bonsoir
la top etant a 1137 oui, tu peux le faire sans souci
n°8355956
actaruxs
Posté le 21-06-2012 à 21:08:55  profilanswer
No problemo.
I7 920D0 @stock (21x133)
3x4go DDR3 @1866
Corsair HX1000W
3 HDD WD (mécaniques :D)
Win7 x64 Intégrale
koi d'autre... Ah oui... 1 GTX670 de ref o/c de base (pcb de 680, donc 2x6pins)... Tu veux aussi le modele/marque ?
Message édité par actaruxs le 21-06-2012 à 21:10:40
n°8355966
sonyagiova
Posté le 21-06-2012 à 21:14:57  profilanswer
Actaruxs, merci, c'est pour pouvoir comparer les perfs de nos machines plus facilement.....
n°8355971
myxpc95g5
Posté le 21-06-2012 à 21:18:59  profilanswer
Thanks ;) une cg qui promet. Espérons sa stabilité
Nb. elle fut testée en PCI-E 2.0 :spamafote:
n°8355972
uNReaLx77
üNReaL
Posté le 21-06-2012 à 21:19:08  profilanswer
un lein sur 3dmark serai mieux pour detailler ;)
n°8355978
Invite_Sur​prise
Posté le 21-06-2012 à 21:26:22  profilanswer
Concours Nvidia / questions sur les... questionsCartes Mères Z68 GIGABYTE, laquelle choisir ?
Panneau de configuration NVIDIA ?[HFR] Actu : 5 cartes A75 FM1 pour ASRock
Probleme aprés installation carte NVIDIA GEFORCE 8400 GS[HFR] Actu : Nvidia lance les GTX 580M et 570M
[HFR] Actu : 4 cartes Socket FM1 pour Gigabyte[Topic Unique] Problème pour mettre à jour sa carte réseau
Gestion des ventilateurs 3 pins avec les cartes mères P67Configuration MCP73VE NVIDIA MCP73
Plus de sujets relatifs à : [Topic Unique] NVIDIA GeForce GTX 660Ti/670/680/690/760/770 (GK104)
