Another supply chain attack. 700+ GitHub repositories flagged, including PHP and Node.js projects. The malicious script was planted across all of them. When a developer installs the package, the script silently downloads a Linux file from GitHub, hides it under the name /tmp/.sshd (so it looks like a normal system file), and runs it in the background. It also skips security checks on the download and hides any error messages.
The script attempted to download a Linux binary from a GitHub Releases URL, save it to /tmp/.sshd, make it executable, and run it in the background.
Although the affected packages were all Composer packages, the malicious code was not added to composer.json. Instead, it was inserted into package.json, targeting projects that ship JavaScript build tooling alongside PHP code. That cross-ecosystem placement is notable because developers and security teams reviewing PHP dependencies may focus on Composer metadata while overlooking package.json lifecycle hooks bundled inside the package.
